Not connected, Your IP: 216.73.216.54
ahmedalmosawi
checking route then times out. cant connect.
help please.
on my first 5 minutes of starting this service and i cant connect. it gets stuck on ((checking route)) and then times out.
I 2016.12.14 00:20:35 - Eddie client version: 2.11.9 / windows_x64, System: Windows, Name: Microsoft Windows NT 10.0.10586.0, Mono/.Net Framework: v4.0.30319
. 2016.12.14 00:20:35 - Reading options from C:\Users\xavier\AppData\Local\AirVPN\AirVPN.xml
. 2016.12.14 00:20:36 - Data path: C:\Users\xavier\AppData\Local\AirVPN
. 2016.12.14 00:20:36 - Application path: D:\Program Files\AirVPN
. 2016.12.14 00:20:36 - Executable path: D:\Program Files\AirVPN\AirVPN.exe
. 2016.12.14 00:20:36 - Command line arguments (1): path="home"
. 2016.12.14 00:20:36 - Operating System: Microsoft Windows NT 10.0.10586.0
W 2016.12.14 00:20:36 - Tunnel driver will be upgraded, from 9.21.1 to 9.21.2.
E 2016.12.14 00:20:36 - OpenVPN Driver - Not available - Will be installed at next connection.
I 2016.12.14 00:20:36 - OpenVPN - Version: 2.3.13 - OpenSSL 1.0.2j  26 Sep 2016, LZO 2.09 (D:\Program Files\AirVPN\openvpn.exe)
I 2016.12.14 00:20:36 - SSH - Version: plink 0.67 (D:\Program Files\AirVPN\plink.exe)
I 2016.12.14 00:20:36 - SSL - Version: stunnel 5.37 (D:\Program Files\AirVPN\stunnel.exe)
! 2016.12.14 00:20:36 - Ready
. 2016.12.14 00:20:36 - Updating systems & servers data ...
! 2016.12.14 00:20:42 - Logged out.
I 2016.12.14 00:20:43 - Checking login ...
. 2016.12.14 00:20:43 - Systems & servers data update completed
! 2016.12.14 00:20:44 - Logged in.
I 2016.12.14 00:21:43 - Session starting.
. 2016.12.14 00:21:51 - IPv6 disabled with packet filtering.
I 2016.12.14 00:21:51 - Checking authorization ...
! 2016.12.14 00:21:51 - Connecting to Hamal (Switzerland, Zurich)
. 2016.12.14 00:21:51 - OpenVPN > OpenVPN 2.3.13 x86_64-w64-mingw32 [SSL (OpenSSL)] [LZO] [IPv6] built on Nov 10 2016
. 2016.12.14 00:21:51 - OpenVPN > Windows version 6.2 (Windows 8 or greater) 64bit
. 2016.12.14 00:21:51 - OpenVPN > library versions: OpenSSL 1.0.2j  26 Sep 2016, LZO 2.09
. 2016.12.14 00:21:51 - OpenVPN > MANAGEMENT: TCP Socket listening on [AF_INET]127.0.0.1:3100
. 2016.12.14 00:21:51 - OpenVPN > Control Channel Authentication: tls-auth using INLINE static key file
. 2016.12.14 00:21:51 - OpenVPN > Outgoing Control Channel Authentication: Using 160 bit message hash 'SHA1' for HMAC authentication
. 2016.12.14 00:21:51 - OpenVPN > Incoming Control Channel Authentication: Using 160 bit message hash 'SHA1' for HMAC authentication
. 2016.12.14 00:21:51 - OpenVPN > Socket Buffers: R=[65536->262144] S=[65536->262144]
. 2016.12.14 00:21:51 - OpenVPN > UDPv4 link local: [undef]
. 2016.12.14 00:21:51 - OpenVPN > UDPv4 link remote: [AF_INET]185.156.175.42:443
. 2016.12.14 00:21:51 - OpenVPN > TLS: Initial packet from [AF_INET]185.156.175.42:443, sid=3970e895 07f2078c
. 2016.12.14 00:21:52 - OpenVPN > VERIFY OK: depth=1, C=IT, ST=IT, L=Perugia, O=airvpn.org, CN=airvpn.org CA, emailAddress=info@airvpn.org
. 2016.12.14 00:21:52 - OpenVPN > Validating certificate key usage
. 2016.12.14 00:21:52 - OpenVPN > ++ Certificate has key usage  00a0, expects 00a0
. 2016.12.14 00:21:52 - OpenVPN > VERIFY KU OK
. 2016.12.14 00:21:52 - OpenVPN > Validating certificate extended key usage
. 2016.12.14 00:21:52 - OpenVPN > ++ Certificate has EKU (str) TLS Web Server Authentication, expects TLS Web Server Authentication
. 2016.12.14 00:21:52 - OpenVPN > VERIFY EKU OK
. 2016.12.14 00:21:52 - OpenVPN > VERIFY OK: depth=0, C=IT, ST=IT, L=Perugia, O=airvpn.org, CN=server, emailAddress=info@airvpn.org
. 2016.12.14 00:21:52 - OpenVPN > Data Channel Encrypt: Cipher 'AES-256-CBC' initialized with 256 bit key
. 2016.12.14 00:21:52 - OpenVPN > Data Channel Encrypt: Using 160 bit message hash 'SHA1' for HMAC authentication
. 2016.12.14 00:21:52 - OpenVPN > Data Channel Decrypt: Cipher 'AES-256-CBC' initialized with 256 bit key
. 2016.12.14 00:21:52 - OpenVPN > Data Channel Decrypt: Using 160 bit message hash 'SHA1' for HMAC authentication
. 2016.12.14 00:21:52 - OpenVPN > Control Channel: TLSv1.2, cipher TLSv1/SSLv3 DHE-RSA-AES256-GCM-SHA384, 4096 bit RSA
. 2016.12.14 00:21:52 - OpenVPN > [server] Peer Connection Initiated with [AF_INET]185.156.175.42:443
. 2016.12.14 00:21:54 - OpenVPN > SENT CONTROL [server]: 'PUSH_REQUEST' (status=1)
. 2016.12.14 00:21:54 - OpenVPN > PUSH: Received control message: 'PUSH_REPLY,redirect-gateway def1 bypass-dhcp,dhcp-option DNS 10.4.0.1,comp-lzo no,route-gateway 10.4.0.1,topology subnet,ping 10,ping-restart 60,ifconfig 10.4.5.98 255.255.0.0'
. 2016.12.14 00:21:54 - OpenVPN > OPTIONS IMPORT: timers and/or timeouts modified
. 2016.12.14 00:21:54 - OpenVPN > OPTIONS IMPORT: LZO parms modified
. 2016.12.14 00:21:54 - OpenVPN > OPTIONS IMPORT: --ifconfig/up options modified
. 2016.12.14 00:21:54 - OpenVPN > OPTIONS IMPORT: route options modified
. 2016.12.14 00:21:54 - OpenVPN > OPTIONS IMPORT: route-related options modified
. 2016.12.14 00:21:54 - OpenVPN > OPTIONS IMPORT: --ip-win32 and/or --dhcp-option options modified
. 2016.12.14 00:21:54 - OpenVPN > ROUTE_GATEWAY 192.168.60.1/255.255.255.0 I=24 HWADDR=50:7b:9d:94:1b:d7
. 2016.12.14 00:21:54 - OpenVPN > do_ifconfig, tt->ipv6=0, tt->did_ifconfig_ipv6_setup=0
. 2016.12.14 00:21:54 - OpenVPN > open_tun, tt->ipv6=0
. 2016.12.14 00:21:54 - OpenVPN > TAP-WIN32 device [Ethernet 3] opened: \\.\Global\{E18C6A47-147A-4242-9970-9FAF0250BE66}.tap
. 2016.12.14 00:21:54 - OpenVPN > TAP-Windows Driver Version 9.21
. 2016.12.14 00:21:54 - OpenVPN > Set TAP-Windows TUN subnet mode network/local/netmask = 10.4.0.0/10.4.5.98/255.255.0.0 [SUCCEEDED]
. 2016.12.14 00:21:54 - OpenVPN > Notified TAP-Windows driver to set a DHCP IP/netmask of 10.4.5.98/255.255.0.0 on interface {E18C6A47-147A-4242-9970-9FAF0250BE66} [DHCP-serv: 10.4.255.254, lease-time: 31536000]
. 2016.12.14 00:21:54 - OpenVPN > Successful ARP Flush on interface [26] {E18C6A47-147A-4242-9970-9FAF0250BE66}
. 2016.12.14 00:21:59 - OpenVPN > TEST ROUTES: 1/1 succeeded len=0 ret=1 a=0 u/d=up
. 2016.12.14 00:21:59 - OpenVPN > C:\Windows\system32\route.exe ADD 185.156.175.42 MASK 255.255.255.255 192.168.60.1
. 2016.12.14 00:21:59 - OpenVPN > ROUTE: CreateIpForwardEntry succeeded with dwForwardMetric1=10 and dwForwardType=4
. 2016.12.14 00:21:59 - OpenVPN > Route addition via IPAPI succeeded [adaptive]
. 2016.12.14 00:21:59 - OpenVPN > C:\Windows\system32\route.exe ADD 0.0.0.0 MASK 128.0.0.0 10.4.0.1
. 2016.12.14 00:21:59 - OpenVPN > ROUTE: CreateIpForwardEntry succeeded with dwForwardMetric1=20 and dwForwardType=4
. 2016.12.14 00:21:59 - OpenVPN > C:\Windows\system32\route.exe ADD 128.0.0.0 MASK 128.0.0.0 10.4.0.1
. 2016.12.14 00:21:59 - Starting Management Interface
. 2016.12.14 00:21:59 - OpenVPN > Initialization Sequence Completed
. 2016.12.14 00:21:59 - DNS leak protection with packet filtering enabled.
. 2016.12.14 00:21:59 - DNS of a network adapter forced (Realtek PCIe GBE Family Controller, from manual (156.154.70.1) to 10.4.0.1)
I 2016.12.14 00:21:59 - Flushing DNS
I 2016.12.14 00:22:19 - Checking route
W 2016.12.14 00:23:11 - The operation has timed out
! 2016.12.14 00:23:11 - Disconnecting
. 2016.12.14 00:23:11 - Management - Send 'signal SIGTERM'
. 2016.12.14 00:23:11 - OpenVPN > MANAGEMENT: CMD 'signal SIGTERM'
. 2016.12.14 00:23:11 - OpenVPN > SIGTERM received, sending exit notification to peer
. 2016.12.14 00:23:11 - OpenVpn Management > >INFO:OpenVPN Management Interface Version 1 -- type 'help' for more info
. 2016.12.14 00:23:16 - OpenVPN > C:\Windows\system32\route.exe DELETE 185.156.175.42 MASK 255.255.255.255 192.168.60.1
. 2016.12.14 00:23:16 - OpenVPN > Route deletion via IPAPI succeeded [adaptive]
. 2016.12.14 00:23:16 - OpenVPN > C:\Windows\system32\route.exe DELETE 0.0.0.0 MASK 128.0.0.0 10.4.0.1
. 2016.12.14 00:23:16 - OpenVPN > C:\Windows\system32\route.exe DELETE 128.0.0.0 MASK 128.0.0.0 10.4.0.1
. 2016.12.14 00:23:16 - OpenVPN > Closing TUN/TAP interface
. 2016.12.14 00:23:16 - OpenVPN > SIGTERM[soft,exit-with-notification] received, process exiting
. 2016.12.14 00:23:16 - Connection terminated.
. 2016.12.14 00:23:16 - DNS of a network adapter restored to original settings (Realtek PCIe GBE Family Controller, to 156.154.70.1)
. 2016.12.14 00:23:16 - DNS leak protection with packet filtering disabled.
I 2016.12.14 00:23:18 - Cancel requested.
. 2016.12.14 00:23:18 - IPv6 restored with packet filtering.
You should fix this first, and then a reboot is necessary if you had an older one loaded, 9.21.1 was very unstable under Windows 10.
