Hello people,
I'm using openvpn connect 1.1.17 on android 5.1.1.
When i connect to any .ovpn file it will disconnect when i press the home button, back button and switch app button.
Before it disconnects everything looks good in the log file.
I tryed all 3 apps recommered by airvpn but they all do the same.
Help is much appriciated.
Thanks in advance.
OpenVPN for Android retains the log file from previous connections and therefore might contain clues why the connection breaks. That is, of course, when you are sure that Android doesn't kill all these apps due to RAM capacity issues.
Thank you for replying,
I tryed that and when i press any key to go to a different app it just disconnect and the logs says nothing.
Tryed with closing all apps except openvpn got 500mb ram free and still disconnects when switching app.
Help is really apriciated
Thanks in advance
What smartphone are you using? Which ROM? Post the contents of Settings > Info.
Are you using apps which have access to Android's task list, such as antivirus or "system cleaner" apps? If you like, install List My Apps and share the list of all user apps as plain text (launch > Menu > Select all > Copy to clipboard/share with..). Don't forget to encapsulate this list in spoilers if you decide to share the list, How-To in my signature.
