dvlondon 0 Posted ... Hello everybody I am having some small issues with Airvpn every time i try to connect to a server it connects but it shows me in a completely different location than the server i have chose. EXAMPLE if i want to use a server in Netherlands it connects but shows my IP being in Canada LOG I 2016.12.06 13:42:15 - Session starting.I 2016.12.06 13:42:16 - IPv6 disabled on network adapter (Wi-Fi)I 2016.12.06 13:42:16 - IPv6 disabled on network adapter (Bluetooth PAN)I 2016.12.06 13:42:16 - Checking authorization ...! 2016.12.06 13:42:16 - Connecting to Denebola (United Kingdom, Maidenhead). 2016.12.06 13:42:16 - OpenVPN > OpenVPN 2.3.8 x86_64-apple-darwin14.4.0 [sSL (OpenSSL)] [LZO] [MH] [iPv6] built on Aug 13 2015. 2016.12.06 13:42:16 - OpenVPN > library versions: OpenSSL 1.0.2d 9 Jul 2015, LZO 2.08. 2016.12.06 13:42:16 - OpenVPN > MANAGEMENT: TCP Socket listening on [AF_INET]127.0.0.1:3101. 2016.12.06 13:42:16 - OpenVPN > Control Channel Authentication: tls-auth using INLINE static key file. 2016.12.06 13:42:16 - OpenVPN > Outgoing Control Channel Authentication: Using 160 bit message hash 'SHA1' for HMAC authentication. 2016.12.06 13:42:17 - OpenVPN > Incoming Control Channel Authentication: Using 160 bit message hash 'SHA1' for HMAC authentication. 2016.12.06 13:42:17 - OpenVPN > Socket Buffers: R=[196724->131072] S=[9216->131072]. 2016.12.06 13:42:17 - OpenVPN > UDPv4 link local: [undef]. 2016.12.06 13:42:17 - OpenVPN > UDPv4 link remote: [AF_INET]185.103.96.133:443. 2016.12.06 13:42:17 - OpenVPN > TLS: Initial packet from [AF_INET]185.103.96.133:443, sid=3752ebd7 6e1ca431. 2016.12.06 13:42:17 - OpenVPN > VERIFY OK: depth=1, C=IT, ST=IT, L=Perugia, O=airvpn.org, CN=airvpn.org CA, emailAddress=info@airvpn.org. 2016.12.06 13:42:17 - OpenVPN > Validating certificate key usage. 2016.12.06 13:42:17 - OpenVPN > ++ Certificate has key usage 00a0, expects 00a0. 2016.12.06 13:42:17 - OpenVPN > VERIFY KU OK. 2016.12.06 13:42:17 - OpenVPN > Validating certificate extended key usage. 2016.12.06 13:42:17 - OpenVPN > ++ Certificate has EKU (str) TLS Web Server Authentication, expects TLS Web Server Authentication. 2016.12.06 13:42:17 - OpenVPN > VERIFY EKU OK. 2016.12.06 13:42:17 - OpenVPN > VERIFY OK: depth=0, C=IT, ST=IT, L=Perugia, O=airvpn.org, CN=server, emailAddress=info@airvpn.org. 2016.12.06 13:42:17 - OpenVPN > Data Channel Encrypt: Cipher 'AES-256-CBC' initialized with 256 bit key. 2016.12.06 13:42:17 - OpenVPN > Data Channel Encrypt: Using 160 bit message hash 'SHA1' for HMAC authentication. 2016.12.06 13:42:17 - OpenVPN > Data Channel Decrypt: Cipher 'AES-256-CBC' initialized with 256 bit key. 2016.12.06 13:42:17 - OpenVPN > Data Channel Decrypt: Using 160 bit message hash 'SHA1' for HMAC authentication. 2016.12.06 13:42:17 - OpenVPN > Control Channel: TLSv1.2, cipher TLSv1/SSLv3 DHE-RSA-AES256-GCM-SHA384, 4096 bit RSA. 2016.12.06 13:42:17 - OpenVPN > [server] Peer Connection Initiated with [AF_INET]185.103.96.133:443. 2016.12.06 13:42:19 - OpenVPN > SENT CONTROL [server]: 'PUSH_REQUEST' (status=1). 2016.12.06 13:42:20 - OpenVPN > PUSH: Received control message: 'PUSH_REPLY,redirect-gateway def1 bypass-dhcp,dhcp-option DNS 10.4.0.1,comp-lzo no,route-gateway 10.4.0.1,topology subnet,ping 10,ping-restart 60,ifconfig 10.4.25.116 255.255.0.0'. 2016.12.06 13:42:20 - OpenVPN > OPTIONS IMPORT: timers and/or timeouts modified. 2016.12.06 13:42:20 - OpenVPN > ifconfig: ioctl (SIOCDIFADDR): Can't assign requested address. 2016.12.06 13:42:20 - OpenVPN > OPTIONS IMPORT: LZO parms modified. 2016.12.06 13:42:20 - OpenVPN > route: writing to routing socket: File exists. 2016.12.06 13:42:20 - OpenVPN > OPTIONS IMPORT: --ifconfig/up options modified. 2016.12.06 13:42:20 - OpenVPN > route: writing to routing socket: File exists. 2016.12.06 13:42:20 - OpenVPN > OPTIONS IMPORT: route options modified. 2016.12.06 13:42:20 - OpenVPN > OPTIONS IMPORT: route-related options modified. 2016.12.06 13:42:20 - OpenVPN > OPTIONS IMPORT: --ip-win32 and/or --dhcp-option options modified. 2016.12.06 13:42:20 - OpenVPN > Opening utun (connect(AF_SYS_CONTROL)): Resource busy. 2016.12.06 13:42:20 - OpenVPN > Opened utun device utun1. 2016.12.06 13:42:20 - OpenVPN > do_ifconfig, tt->ipv6=0, tt->did_ifconfig_ipv6_setup=0. 2016.12.06 13:42:20 - OpenVPN > /sbin/ifconfig utun1 delete. 2016.12.06 13:42:20 - OpenVPN > NOTE: Tried to delete pre-existing tun/tap instance -- No Problem if failure. 2016.12.06 13:42:20 - OpenVPN > /sbin/ifconfig utun1 10.4.25.116 10.4.25.116 netmask 255.255.0.0 mtu 1500 up. 2016.12.06 13:42:20 - OpenVPN > /sbin/route add -net 10.4.0.0 10.4.25.116 255.255.0.0. 2016.12.06 13:42:20 - OpenVPN > add net 10.4.0.0: gateway 10.4.25.116: File exists. 2016.12.06 13:42:20 - OpenVPN > /sbin/route add -net 185.103.96.133 192.168.0.1 255.255.255.255. 2016.12.06 13:42:20 - OpenVPN > add net 185.103.96.133: gateway 192.168.0.1: File exists. 2016.12.06 13:42:20 - OpenVPN > /sbin/route add -net 0.0.0.0 10.4.0.1 128.0.0.0. 2016.12.06 13:42:20 - OpenVPN > add net 0.0.0.0: gateway 10.4.0.1. 2016.12.06 13:42:20 - OpenVPN > /sbin/route add -net 128.0.0.0 10.4.0.1 128.0.0.0. 2016.12.06 13:42:20 - OpenVPN > add net 128.0.0.0: gateway 10.4.0.1. 2016.12.06 13:42:20 - Starting Management Interface. 2016.12.06 13:42:20 - OpenVPN > Initialization Sequence CompletedI 2016.12.06 13:42:20 - DNS of a network adapter forced (Wi-Fi)I 2016.12.06 13:42:20 - DNS of a network adapter forced (Bluetooth PAN)I 2016.12.06 13:42:20 - Flushing DNS! 2016.12.06 13:42:21 - Connected.. 2016.12.06 13:42:21 - OpenVpn Management > >INFO:OpenVPN Management Interface Version 1 -- type 'help' for more info. 2016.12.06 13:42:21 - OpenVPN > MANAGEMENT: Client connected from [AF_INET]127.0.0.1:3101 Quote Share this post Link to post
greenclaydog 6 Posted ... 185.103.96.133 Oddly enough that IP is for the UK, although it is just an entry ip rather than the actual server exit. Quote Share this post Link to post
dvlondon 0 Posted ... 185.103.96.133 Oddly enough that IP is for the UK, although it is just an entry ip rather than the actual server exit. Whatever server i try connect to it always keeps showing me up as this IP 137.63.71.51 Quote Share this post Link to post
Tech Jedi Alex 1501 Posted ... You want to use a NL server.It shows you in CA.The logs show you connect to UK. How do you know you are in the wrong country? Which website shows this? Quote Hide Tech Jedi Alex's signature Hide all signatures NOT AN AIRVPN TEAM MEMBER. USE TICKETS FOR PROFESSIONAL SUPPORT. LZ1's New User Guide to AirVPN « Plenty of stuff for advanced users, too! Want to contact me directly? All relevant methods are on my About me page. Share this post Link to post
