NothingSpecial 4 Posted ... Hello forum First post, joined a couple of days ago, all a bit confusing, but getting the hang and reading the forum. I'm using the latest Beta Eddie 2.11.8 on W10 Pro x64 (patched up to date.) i7 4790K @ 4.00Ghz, 32 GB RAM. I've set Eddie to boot with Windows and it connects automatically and successfully but takes about 40 secs plus to connect (I'm using NOD32 AV), so no problems there. However if (for whatever reason) I enable "Airplane" mode or get a short break in my wi-fi then Eddie fails to connect afterwards. This happens too if I select another server on the list and select "connect". It just goes through the list attempting to connect and then disconnecting and trying again and again? (getting some time-out failure messages). To fix it I usually have to reboot the system and it automatically runs OK again. It would be good to solve this, so any help would be appreciated. I love what AirVPN does and I appreciate the ethos, and integrity, that seems to exist here and feel I have made a right choice out of the many Providers. Thanks in advance Quote Share this post Link to post
LZ1 678 Posted ... Hello! Please post your logs - which you can find in the Eddie program. If you could do so using spoiler tags, that would be nice too. Quote Hide LZ1's signature Hide all signatures Hi there, are you new to AirVPN? Many of your questions are already answered in this guide. You may also read the Eddie Android FAQ. Moderators do not speak on behalf of AirVPN. Only the Official Staff account does. Please also do not run Tor Exit Servers behind AirVPN, thank you. Did you make a guide or how-to for something? Then contact me to get it listed in my new user guide's Guides Section, so that the community can find it more easily. Share this post Link to post
NothingSpecial 4 Posted ... Thanks for your response. I have included 2 or 3 error logs from today. I do not know how to put them in a spoiler so apology for that. Thank you. . 2016.12.02 20:19:00 - OpenVPN > DHCP SERV =. 2016.12.02 20:19:00 - OpenVPN > DHCP LEASE OBTAINED = Fri Dec 02 20:19:00 2016. 2016.12.02 20:19:00 - OpenVPN > DHCP LEASE EXPIRES = Fri Dec 02 20:19:00 2016. 2016.12.02 20:19:00 - OpenVPN > DNS SERV =. 2016.12.02 20:19:00 - OpenVPN > TAP-Windows Adapter V9. 2016.12.02 20:19:00 - OpenVPN > Index = 18. 2016.12.02 20:19:00 - OpenVPN > GUID = {F40AE409-E4BC-4ABA-B9F7-3BD827158EE3}. 2016.12.02 20:19:00 - OpenVPN > IP = 10.4.92.206/255.255.0.0. 2016.12.02 20:19:00 - OpenVPN > MAC = 00:ff:f4:0a:e4:09. 2016.12.02 20:19:00 - OpenVPN > GATEWAY = 0.0.0.0/255.255.255.255. 2016.12.02 20:19:00 - OpenVPN > DHCP SERV = 10.4.255.254/255.255.255.255. 2016.12.02 20:19:00 - OpenVPN > DHCP LEASE OBTAINED = Fri Dec 02 17:21:12 2016. 2016.12.02 20:19:00 - OpenVPN > DHCP LEASE EXPIRES = Sat Dec 02 17:21:12 2017. 2016.12.02 20:19:00 - OpenVPN > DNS SERV = 10.4.0.1/255.255.255.255. 2016.12.02 20:19:00 - OpenVPN > 300Mbps Wireless USB Adapter. 2016.12.02 20:19:00 - OpenVPN > Index = 17. 2016.12.02 20:19:00 - OpenVPN > GUID = {D6DBB021-16B1-4402-97B4-1CEEE4201C7C}. 2016.12.02 20:19:00 - OpenVPN > IP = 192.168.1.101/255.255.255.0. 2016.12.02 20:19:00 - OpenVPN > MAC = 14:cc:20:17:0d:7f. 2016.12.02 20:19:00 - OpenVPN > GATEWAY = 192.168.1.1/255.255.255.255. 2016.12.02 20:19:00 - OpenVPN > DHCP SERV = 192.168.1.1/255.255.255.255. 2016.12.02 20:19:00 - OpenVPN > DHCP LEASE OBTAINED = Fri Dec 02 18:11:06 2016. 2016.12.02 20:19:00 - OpenVPN > DHCP LEASE EXPIRES = Sat Dec 03 18:11:06 2016. 2016.12.02 20:19:00 - OpenVPN > DNS SERV = 10.4.0.1/255.255.255.255. 2016.12.02 20:19:00 - OpenVPN > Microsoft Wi-Fi Direct Virtual Adapter. 2016.12.02 20:19:00 - OpenVPN > Index = 13. 2016.12.02 20:19:00 - OpenVPN > GUID = {AEB675DF-7F7D-4FED-BC91-F8C40081B696}. 2016.12.02 20:19:00 - OpenVPN > IP = 0.0.0.0/0.0.0.0. 2016.12.02 20:19:00 - OpenVPN > MAC = 14:cc:20:17:0d:7f. 2016.12.02 20:19:00 - OpenVPN > GATEWAY = 0.0.0.0/255.255.255.255. 2016.12.02 20:19:00 - OpenVPN > DHCP SERV =. 2016.12.02 20:19:00 - OpenVPN > DHCP LEASE OBTAINED = Fri Dec 02 20:19:00 2016. 2016.12.02 20:19:00 - OpenVPN > DHCP LEASE EXPIRES = Fri Dec 02 20:19:00 2016. 2016.12.02 20:19:00 - OpenVPN > DNS SERV =. 2016.12.02 20:19:00 - Starting Management Interface. 2016.12.02 20:19:00 - OpenVPN > Initialization Sequence Completed With Errors ( see http://openvpn.net/faq.html#dhcpclientserv )! 2016.12.02 20:19:00 - Disconnecting. 2016.12.02 20:19:00 - Management - Send 'signal SIGTERM'. 2016.12.02 20:19:00 - OpenVpn Management > >INFO:OpenVPN Management Interface Version 1 -- type 'help' for more info. 2016.12.02 20:19:00 - DNS leak protection with packet filtering enabled.I 2016.12.02 20:19:00 - Flushing DNSW 2016.12.02 20:19:01 - Checking route, 4° try failed (The remote name could not be resolved: 'sheliak_exit.airservers.org'). 2016.12.02 20:19:05 - Connection terminated.. 2016.12.02 20:19:05 - DNS leak protection with packet filtering disabled.I 2016.12.02 20:19:08 - Checking authorization ...! 2016.12.02 20:19:08 - Connecting to Nash (Netherlands, Alblasserdam). 2016.12.02 20:19:08 - OpenVPN > OpenVPN 2.3.13 x86_64-w64-mingw32 [sSL (OpenSSL)] [LZO] [iPv6] built on Nov 10 2016. 2016.12.02 20:19:08 - OpenVPN > Windows version 6.2 (Windows 8 or greater) 64bit. 2016.12.02 20:19:08 - OpenVPN > library versions: OpenSSL 1.0.2j 26 Sep 2016, LZO 2.09. 2016.12.02 20:19:08 - OpenVPN > MANAGEMENT: TCP Socket listening on [AF_INET]127.0.0.1:3100. 2016.12.02 20:19:08 - OpenVPN > Control Channel Authentication: tls-auth using INLINE static key file. 2016.12.02 20:19:08 - OpenVPN > Outgoing Control Channel Authentication: Using 160 bit message hash 'SHA1' for HMAC authentication. 2016.12.02 20:19:08 - OpenVPN > Incoming Control Channel Authentication: Using 160 bit message hash 'SHA1' for HMAC authentication. 2016.12.02 20:19:08 - OpenVPN > Socket Buffers: R=[65536->262144] S=[65536->262144]. 2016.12.02 20:19:08 - OpenVPN > UDPv4 link local: [undef]. 2016.12.02 20:19:08 - OpenVPN > UDPv4 link remote: [AF_INET]213.152.161.24:443. 2016.12.02 20:19:08 - OpenVPN > TLS: Initial packet from [AF_INET]213.152.161.24:443, sid=a77639e4 f7ed1b28. 2016.12.02 20:19:08 - OpenVPN > VERIFY OK: depth=1, C=IT, ST=IT, L=Perugia, O=airvpn.org, CN=airvpn.org CA, emailAddress=info@airvpn.org. 2016.12.02 20:19:08 - OpenVPN > Validating certificate key usage. 2016.12.02 20:19:08 - OpenVPN > ++ Certificate has key usage 00a0, expects 00a0. 2016.12.02 20:19:08 - OpenVPN > VERIFY KU OK. 2016.12.02 20:19:08 - OpenVPN > Validating certificate extended key usage. 2016.12.02 20:19:08 - OpenVPN > ++ Certificate has EKU (str) TLS Web Server Authentication, expects TLS Web Server Authentication. 2016.12.02 20:19:08 - OpenVPN > VERIFY EKU OK. 2016.12.02 20:19:08 - OpenVPN > VERIFY OK: depth=0, C=IT, ST=IT, L=Perugia, O=airvpn.org, CN=server, emailAddress=info@airvpn.org. 2016.12.02 20:19:08 - OpenVPN > Data Channel Encrypt: Cipher 'AES-256-CBC' initialized with 256 bit key. 2016.12.02 20:19:08 - OpenVPN > Data Channel Encrypt: Using 160 bit message hash 'SHA1' for HMAC authentication. 2016.12.02 20:19:08 - OpenVPN > Data Channel Decrypt: Cipher 'AES-256-CBC' initialized with 256 bit key. 2016.12.02 20:19:08 - OpenVPN > Data Channel Decrypt: Using 160 bit message hash 'SHA1' for HMAC authentication. 2016.12.02 20:19:08 - OpenVPN > Control Channel: TLSv1.2, cipher TLSv1/SSLv3 DHE-RSA-AES256-GCM-SHA384, 4096 bit RSA. 2016.12.02 20:19:08 - OpenVPN > [server] Peer Connection Initiated with [AF_INET]213.152.161.24:443I 2016.12.02 20:19:08 - Checking route. 2016.12.02 20:19:11 - OpenVPN > SENT CONTROL [server]: 'PUSH_REQUEST' (status=1). 2016.12.02 20:19:11 - OpenVPN > PUSH: Received control message: 'PUSH_REPLY,redirect-gateway def1 bypass-dhcp,dhcp-option DNS 10.4.0.1,comp-lzo no,route-gateway 10.4.0.1,topology subnet,ping 10,ping-restart 60,ifconfig 10.4.94.84 255.255.0.0'. 2016.12.02 20:19:11 - OpenVPN > OPTIONS IMPORT: timers and/or timeouts modified. 2016.12.02 20:19:11 - OpenVPN > OPTIONS IMPORT: LZO parms modified. 2016.12.02 20:19:11 - OpenVPN > OPTIONS IMPORT: --ifconfig/up options modified. 2016.12.02 20:19:11 - OpenVPN > OPTIONS IMPORT: route options modified. 2016.12.02 20:19:11 - OpenVPN > OPTIONS IMPORT: route-related options modified. 2016.12.02 20:19:11 - OpenVPN > OPTIONS IMPORT: --ip-win32 and/or --dhcp-option options modified. 2016.12.02 20:19:11 - OpenVPN > ROUTE_GATEWAY 192.168.1.1/255.255.255.0 I=17 HWADDR=14:cc:20:17:0d:7f. 2016.12.02 20:19:11 - OpenVPN > do_ifconfig, tt->ipv6=0, tt->did_ifconfig_ipv6_setup=0. 2016.12.02 20:19:11 - OpenVPN > open_tun, tt->ipv6=0. 2016.12.02 20:19:11 - OpenVPN > TAP-WIN32 device [Local Area Connection 2] opened: \\.\Global\{F40AE409-E4BC-4ABA-B9F7-3BD827158EE3}.tap. 2016.12.02 20:19:11 - OpenVPN > TAP-Windows Driver Version 9.21. 2016.12.02 20:19:11 - OpenVPN > Set TAP-Windows TUN subnet mode network/local/netmask = 10.4.0.0/10.4.94.84/255.255.0.0 [sUCCEEDED]. 2016.12.02 20:19:11 - OpenVPN > Notified TAP-Windows driver to set a DHCP IP/netmask of 10.4.94.84/255.255.0.0 on interface {F40AE409-E4BC-4ABA-B9F7-3BD827158EE3} [DHCP-serv: 10.4.255.254, lease-time: 31536000]. 2016.12.02 20:19:11 - OpenVPN > Successful ARP Flush on interface [18] {F40AE409-E4BC-4ABA-B9F7-3BD827158EE3}W 2016.12.02 20:19:15 - Checking route, 5° try failed (The operation has timed out)W 2016.12.02 20:19:15 - The operation has timed out. 2016.12.02 20:19:15 - OpenVPN > MANAGEMENT: CMD 'signal SIGTERM'. 2016.12.02 20:19:15 - OpenVPN > SIGTERM received, sending exit notification to peer. 2016.12.02 20:19:15 - OpenVPN > C:\WINDOWS\system32\route.exe DELETE 213.152.161.132 MASK 255.255.255.255 192.168.1.1. 2016.12.02 20:19:15 - OpenVPN > Route deletion via IPAPI succeeded [adaptive]. 2016.12.02 20:19:15 - OpenVPN > C:\WINDOWS\system32\route.exe DELETE 0.0.0.0 MASK 128.0.0.0 10.4.0.1. 2016.12.02 20:19:15 - OpenVPN > Route deletion via IPAPI succeeded [adaptive]. 2016.12.02 20:19:15 - OpenVPN > C:\WINDOWS\system32\route.exe DELETE 128.0.0.0 MASK 128.0.0.0 10.4.0.1. 2016.12.02 20:19:15 - OpenVPN > Route deletion via IPAPI succeeded [adaptive]. 2016.12.02 20:19:15 - OpenVPN > Closing TUN/TAP interface. 2016.12.02 20:19:15 - OpenVPN > SIGTERM[soft,exit-with-notification] received, process exiting! 2016.12.02 20:19:15 - Disconnecting. 2016.12.02 20:19:15 - Connection terminated.I 2016.12.02 20:19:18 - Checking authorization ...! 2016.12.02 20:19:18 - Connecting to Kocab (Netherlands, Alblasserdam). 2016.12.02 20:19:18 - OpenVPN > OpenVPN 2.3.13 x86_64-w64-mingw32 [sSL (OpenSSL)] [LZO] [iPv6] built on Nov 10 2016. 2016.12.02 20:19:18 - OpenVPN > Windows version 6.2 (Windows 8 or greater) 64bit. 2016.12.02 20:19:18 - OpenVPN > library versions: OpenSSL 1.0.2j 26 Sep 2016, LZO 2.09. 2016.12.02 20:19:18 - OpenVPN > MANAGEMENT: TCP Socket listening on [AF_INET]127.0.0.1:3100. 2016.12.02 20:19:18 - OpenVPN > Control Channel Authentication: tls-auth using INLINE static key file. 2016.12.02 20:19:18 - OpenVPN > Outgoing Control Channel Authentication: Using 160 bit message hash 'SHA1' for HMAC authentication. 2016.12.02 20:19:18 - OpenVPN > Incoming Control Channel Authentication: Using 160 bit message hash 'SHA1' for HMAC authentication. 2016.12.02 20:19:18 - OpenVPN > Socket Buffers: R=[65536->262144] S=[65536->262144]. 2016.12.02 20:19:18 - OpenVPN > UDPv4 link local: [undef]. 2016.12.02 20:19:18 - OpenVPN > UDPv4 link remote: [AF_INET]213.152.162.180:443. 2016.12.02 20:19:18 - OpenVPN > TLS: Initial packet from [AF_INET]213.152.162.180:443, sid=e7152d1d 767e634d. 2016.12.02 20:19:18 - OpenVPN > VERIFY OK: depth=1, C=IT, ST=IT, L=Perugia, O=airvpn.org, CN=airvpn.org CA, emailAddress=info@airvpn.org. 2016.12.02 20:19:18 - OpenVPN > Validating certificate key usage. 2016.12.02 20:19:18 - OpenVPN > ++ Certificate has key usage 00a0, expects 00a0. 2016.12.02 20:19:18 - OpenVPN > VERIFY KU OK. 2016.12.02 20:19:18 - OpenVPN > Validating certificate extended key usage. 2016.12.02 20:19:18 - OpenVPN > ++ Certificate has EKU (str) TLS Web Server Authentication, expects TLS Web Server Authentication. 2016.12.02 20:19:18 - OpenVPN > VERIFY EKU OK. 2016.12.02 20:19:18 - OpenVPN > VERIFY OK: depth=0, C=IT, ST=IT, L=Perugia, O=airvpn.org, CN=server, emailAddress=info@airvpn.orgW 2016.12.02 20:19:20 - Checking route, 1° try failed (The operation has timed out). 2016.12.02 20:19:22 - OpenVPN > Data Channel Encrypt: Cipher 'AES-256-CBC' initialized with 256 bit key. 2016.12.02 20:19:22 - OpenVPN > Data Channel Encrypt: Using 160 bit message hash 'SHA1' for HMAC authentication. 2016.12.02 20:19:22 - OpenVPN > Data Channel Decrypt: Cipher 'AES-256-CBC' initialized with 256 bit key. 2016.12.02 20:19:22 - OpenVPN > Data Channel Decrypt: Using 160 bit message hash 'SHA1' for HMAC authentication. 2016.12.02 20:19:22 - OpenVPN > Control Channel: TLSv1.2, cipher TLSv1/SSLv3 DHE-RSA-AES256-GCM-SHA384, 4096 bit RSA. 2016.12.02 20:19:22 - OpenVPN > [server] Peer Connection Initiated with [AF_INET]213.152.162.180:443. 2016.12.02 20:19:25 - OpenVPN > SENT CONTROL [server]: 'PUSH_REQUEST' (status=1). 2016.12.02 20:19:25 - OpenVPN > PUSH: Received control message: 'PUSH_REPLY,redirect-gateway def1 bypass-dhcp,dhcp-option DNS 10.4.0.1,comp-lzo no,route-gateway 10.4.0.1,topology subnet,ping 10,ping-restart 60,ifconfig 10.4.75.209 255.255.0.0'. 2016.12.02 20:19:25 - OpenVPN > OPTIONS IMPORT: timers and/or timeouts modified. 2016.12.02 20:19:25 - OpenVPN > OPTIONS IMPORT: LZO parms modified. 2016.12.02 20:19:25 - OpenVPN > OPTIONS IMPORT: --ifconfig/up options modified. 2016.12.02 20:19:25 - OpenVPN > OPTIONS IMPORT: route options modified. 2016.12.02 20:19:25 - OpenVPN > OPTIONS IMPORT: route-related options modified. 2016.12.02 20:19:25 - OpenVPN > OPTIONS IMPORT: --ip-win32 and/or --dhcp-option options modified. 2016.12.02 20:19:25 - OpenVPN > ROUTE_GATEWAY 192.168.1.1/255.255.255.0 I=17 HWADDR=14:cc:20:17:0d:7f. 2016.12.02 20:19:25 - OpenVPN > do_ifconfig, tt->ipv6=0, tt->did_ifconfig_ipv6_setup=0. 2016.12.02 20:19:25 - OpenVPN > open_tun, tt->ipv6=0. 2016.12.02 20:19:25 - OpenVPN > TAP-WIN32 device [Local Area Connection 2] opened: \\.\Global\{F40AE409-E4BC-4ABA-B9F7-3BD827158EE3}.tap. 2016.12.02 20:19:25 - OpenVPN > TAP-Windows Driver Version 9.21. 2016.12.02 20:19:25 - OpenVPN > Set TAP-Windows TUN subnet mode network/local/netmask = 10.4.0.0/10.4.75.209/255.255.0.0 [sUCCEEDED]. 2016.12.02 20:19:25 - OpenVPN > Notified TAP-Windows driver to set a DHCP IP/netmask of 10.4.75.209/255.255.0.0 on interface {F40AE409-E4BC-4ABA-B9F7-3BD827158EE3} [DHCP-serv: 10.4.255.254, lease-time: 31536000]. 2016.12.02 20:19:25 - OpenVPN > Successful ARP Flush on interface [18] {F40AE409-E4BC-4ABA-B9F7-3BD827158EE3}. 2016.12.02 20:19:30 - OpenVPN > TEST ROUTES: 0/0 succeeded len=0 ret=0 a=0 u/d=down. 2016.12.02 20:19:30 - OpenVPN > Route: Waiting for TUN/TAP interface to come up.... 2016.12.02 20:19:30 - Eddie Windows Interface Hack executed (Local Area Connection 2)W 2016.12.02 20:19:32 - Checking route, 2° try failed (The operation has timed out). 2016.12.02 20:19:35 - OpenVPN > TEST ROUTES: 0/0 succeeded len=0 ret=0 a=0 u/d=down. 2016.12.02 20:19:35 - OpenVPN > Route: Waiting for TUN/TAP interface to come up.... 2016.12.02 20:19:35 - Eddie Windows Interface Hack executed (Local Area Connection 2). 2016.12.02 20:19:36 - OpenVPN > TEST ROUTES: 0/0 succeeded len=0 ret=0 a=0 u/d=down. 2016.12.02 20:19:36 - OpenVPN > Route: Waiting for TUN/TAP interface to come up.... 2016.12.02 20:19:36 - Eddie Windows Interface Hack executed (Local Area Connection 2). 2016.12.02 20:19:37 - OpenVPN > TEST ROUTES: 0/0 succeeded len=0 ret=0 a=0 u/d=down. 2016.12.02 20:19:37 - OpenVPN > Route: Waiting for TUN/TAP interface to come up.... 2016.12.02 20:19:37 - Eddie Windows Interface Hack executed (Local Area Connection 2). 2016.12.02 20:19:38 - OpenVPN > TEST ROUTES: 0/0 succeeded len=0 ret=0 a=0 u/d=down. 2016.12.02 20:19:38 - OpenVPN > Route: Waiting for TUN/TAP interface to come up.... 2016.12.02 20:19:38 - Eddie Windows Interface Hack executed (Local Area Connection 2). 2016.12.02 20:19:39 - OpenVPN > TEST ROUTES: 0/0 succeeded len=0 ret=0 a=0 u/d=down. 2016.12.02 20:19:39 - OpenVPN > Route: Waiting for TUN/TAP interface to come up.... 2016.12.02 20:19:39 - Eddie Windows Interface Hack executed (Local Area Connection 2). 2016.12.02 20:19:40 - OpenVPN > TEST ROUTES: 0/0 succeeded len=0 ret=0 a=0 u/d=down. 2016.12.02 20:19:40 - OpenVPN > Route: Waiting for TUN/TAP interface to come up.... 2016.12.02 20:19:40 - Eddie Windows Interface Hack executed (Local Area Connection 2). 2016.12.02 20:19:42 - OpenVPN > TEST ROUTES: 0/0 succeeded len=0 ret=0 a=0 u/d=down. 2016.12.02 20:19:42 - OpenVPN > Route: Waiting for TUN/TAP interface to come up.... 2016.12.02 20:19:42 - Eddie Windows Interface Hack executed (Local Area Connection 2). 2016.12.02 20:19:43 - OpenVPN > TEST ROUTES: 0/0 succeeded len=0 ret=0 a=0 u/d=down. 2016.12.02 20:19:43 - OpenVPN > Route: Waiting for TUN/TAP interface to come up.... 2016.12.02 20:19:43 - Eddie Windows Interface Hack executed (Local Area Connection 2). 2016.12.02 20:19:44 - OpenVPN > TEST ROUTES: 0/0 succeeded len=0 ret=0 a=0 u/d=down. 2016.12.02 20:19:44 - OpenVPN > Route: Waiting for TUN/TAP interface to come up.... 2016.12.02 20:19:44 - Eddie Windows Interface Hack executed (Local Area Connection 2)W 2016.12.02 20:19:44 - Checking route, 3° try failed (The operation has timed out). 2016.12.02 20:19:46 - OpenVPN > TEST ROUTES: 0/0 succeeded len=0 ret=0 a=0 u/d=down. 2016.12.02 20:19:46 - OpenVPN > Route: Waiting for TUN/TAP interface to come up.... 2016.12.02 20:19:46 - Eddie Windows Interface Hack executed (Local Area Connection 2). 2016.12.02 20:19:47 - OpenVPN > TEST ROUTES: 0/0 succeeded len=0 ret=0 a=0 u/d=down. 2016.12.02 20:19:47 - OpenVPN > Route: Waiting for TUN/TAP interface to come up.... 2016.12.02 20:19:47 - Eddie Windows Interface Hack executed (Local Area Connection 2). 2016.12.02 20:19:48 - OpenVPN > TEST ROUTES: 0/0 succeeded len=0 ret=0 a=0 u/d=down. 2016.12.02 20:19:48 - OpenVPN > Route: Waiting for TUN/TAP interface to come up.... 2016.12.02 20:19:48 - Eddie Windows Interface Hack executed (Local Area Connection 2). 2016.12.02 20:19:49 - OpenVPN > TEST ROUTES: 0/0 succeeded len=0 ret=0 a=0 u/d=down. 2016.12.02 20:19:49 - OpenVPN > Route: Waiting for TUN/TAP interface to come up.... 2016.12.02 20:19:49 - Eddie Windows Interface Hack executed (Local Area Connection 2). 2016.12.02 20:19:51 - OpenVPN > TEST ROUTES: 0/0 succeeded len=0 ret=0 a=0 u/d=down. 2016.12.02 20:19:51 - OpenVPN > Route: Waiting for TUN/TAP interface to come up.... 2016.12.02 20:19:51 - Eddie Windows Interface Hack executed (Local Area Connection 2). 2016.12.02 20:19:52 - OpenVPN > TEST ROUTES: 0/0 succeeded len=0 ret=0 a=0 u/d=down. 2016.12.02 20:19:52 - OpenVPN > Route: Waiting for TUN/TAP interface to come up.... 2016.12.02 20:19:52 - Eddie Windows Interface Hack executed (Local Area Connection 2). 2016.12.02 20:19:53 - OpenVPN > TEST ROUTES: 0/0 succeeded len=0 ret=0 a=0 u/d=down. 2016.12.02 20:19:53 - OpenVPN > Route: Waiting for TUN/TAP interface to come up.... 2016.12.02 20:19:53 - Eddie Windows Interface Hack executed (Local Area Connection 2). 2016.12.02 20:19:54 - OpenVPN > TEST ROUTES: 0/0 succeeded len=0 ret=0 a=0 u/d=down. 2016.12.02 20:19:54 - OpenVPN > Route: Waiting for TUN/TAP interface to come up.... 2016.12.02 20:19:54 - Eddie Windows Interface Hack executed (Local Area Connection 2). 2016.12.02 20:19:55 - OpenVPN > TEST ROUTES: 0/0 succeeded len=0 ret=0 a=0 u/d=down. 2016.12.02 20:19:55 - OpenVPN > Route: Waiting for TUN/TAP interface to come up.... 2016.12.02 20:19:55 - Eddie Windows Interface Hack executed (Local Area Connection 2). 2016.12.02 20:19:56 - OpenVPN > TEST ROUTES: 0/0 succeeded len=0 ret=0 a=0 u/d=down. 2016.12.02 20:19:56 - OpenVPN > Route: Waiting for TUN/TAP interface to come up.... 2016.12.02 20:19:56 - Eddie Windows Interface Hack executed (Local Area Connection 2)W 2016.12.02 20:19:56 - Checking route, 4° try failed (The operation has timed out). 2016.12.02 20:19:57 - OpenVPN > TEST ROUTES: 0/0 succeeded len=0 ret=0 a=0 u/d=down. 2016.12.02 20:19:57 - OpenVPN > Route: Waiting for TUN/TAP interface to come up.... 2016.12.02 20:19:57 - Eddie Windows Interface Hack executed (Local Area Connection 2). 2016.12.02 20:19:58 - OpenVPN > TEST ROUTES: 0/0 succeeded len=0 ret=0 a=0 u/d=down. 2016.12.02 20:19:58 - OpenVPN > Route: Waiting for TUN/TAP interface to come up.... 2016.12.02 20:19:58 - Eddie Windows Interface Hack executed (Local Area Connection 2). 2016.12.02 20:19:59 - OpenVPN > TEST ROUTES: 0/0 succeeded len=0 ret=0 a=0 u/d=down. 2016.12.02 20:19:59 - OpenVPN > Route: Waiting for TUN/TAP interface to come up.... 2016.12.02 20:19:59 - Eddie Windows Interface Hack executed (Local Area Connection 2). 2016.12.02 20:20:00 - OpenVPN > TEST ROUTES: 0/0 succeeded len=0 ret=0 a=0 u/d=down. 2016.12.02 20:20:00 - OpenVPN > C:\WINDOWS\system32\route.exe ADD 213.152.162.180 MASK 255.255.255.255 192.168.1.1. 2016.12.02 20:20:00 - OpenVPN > ROUTE: CreateIpForwardEntry succeeded with dwForwardMetric1=45 and dwForwardType=4. 2016.12.02 20:20:00 - OpenVPN > Route addition via IPAPI succeeded [adaptive]. 2016.12.02 20:20:00 - OpenVPN > C:\WINDOWS\system32\route.exe ADD 0.0.0.0 MASK 128.0.0.0 10.4.0.1. 2016.12.02 20:20:00 - OpenVPN > ROUTE: CreateIpForwardEntry succeeded with dwForwardMetric1=35 and dwForwardType=4. 2016.12.02 20:20:00 - OpenVPN > Route addition via IPAPI succeeded [adaptive]. 2016.12.02 20:20:00 - OpenVPN > C:\WINDOWS\system32\route.exe ADD 128.0.0.0 MASK 128.0.0.0 10.4.0.1. 2016.12.02 20:20:00 - OpenVPN > ROUTE: CreateIpForwardEntry succeeded with dwForwardMetric1=35 and dwForwardType=4. 2016.12.02 20:20:00 - OpenVPN > Route addition via IPAPI succeeded [adaptive]. 2016.12.02 20:20:00 - OpenVPN > SYSTEM ROUTING TABLE. 2016.12.02 20:20:00 - OpenVPN > 0.0.0.0 0.0.0.0 192.168.1.1 p=0 i=17 t=4 pr=3 a=10770 h=0 m=45/0/0/0/0. 2016.12.02 20:20:00 - OpenVPN > 0.0.0.0 128.0.0.0 10.4.0.1 p=0 i=18 t=4 pr=3 a=0 h=0 m=35/0/0/0/0. 2016.12.02 20:20:00 - OpenVPN > 10.4.0.0 255.255.0.0 10.4.92.206 p=0 i=18 t=3 pr=2 a=10728 h=0 m=291/0/0/0/0. 2016.12.02 20:20:00 - OpenVPN > 10.4.92.206 255.255.255.255 10.4.92.206 p=0 i=18 t=3 pr=2 a=10728 h=0 m=291/0/0/0/0. 2016.12.02 20:20:00 - OpenVPN > 10.4.255.255 255.255.255.255 10.4.92.206 p=0 i=18 t=3 pr=2 a=10728 h=0 m=291/0/0/0/0. 2016.12.02 20:20:00 - OpenVPN > 127.0.0.0 255.0.0.0 127.0.0.1 p=0 i=1 t=3 pr=2 a=10779 h=0 m=331/0/0/0/0. 2016.12.02 20:20:00 - OpenVPN > 127.0.0.1 255.255.255.255 127.0.0.1 p=0 i=1 t=3 pr=2 a=10779 h=0 m=331/0/0/0/0. 2016.12.02 20:20:00 - OpenVPN > 127.255.255.255 255.255.255.255 127.0.0.1 p=0 i=1 t=3 pr=2 a=10779 h=0 m=331/0/0/0/0. 2016.12.02 20:20:00 - OpenVPN > 128.0.0.0 128.0.0.0 10.4.0.1 p=0 i=18 t=4 pr=3 a=0 h=0 m=35/0/0/0/0. 2016.12.02 20:20:00 - OpenVPN > 192.168.1.0 255.255.255.0 192.168.1.101 p=0 i=17 t=3 pr=2 a=10770 h=0 m=301/0/0/0/0. 2016.12.02 20:20:00 - OpenVPN > 192.168.1.101 255.255.255.255 192.168.1.101 p=0 i=17 t=3 pr=2 a=10770 h=0 m=301/0/0/0/0. 2016.12.02 20:20:00 - OpenVPN > 192.168.1.255 255.255.255.255 192.168.1.101 p=0 i=17 t=3 pr=2 a=10770 h=0 m=301/0/0/0/0. 2016.12.02 20:20:00 - OpenVPN > 213.152.162.180 255.255.255.255 192.168.1.1 p=0 i=17 t=4 pr=3 a=0 h=0 m=45/0/0/0/0. 2016.12.02 20:20:00 - OpenVPN > 224.0.0.0 240.0.0.0 127.0.0.1 p=0 i=1 t=3 pr=2 a=10779 h=0 m=331/0/0/0/0. 2016.12.02 20:20:00 - OpenVPN > 224.0.0.0 240.0.0.0 10.4.92.206 p=0 i=18 t=3 pr=2 a=10778 h=0 m=291/0/0/0/0. 2016.12.02 20:20:00 - OpenVPN > 224.0.0.0 240.0.0.0 192.168.1.101 p=0 i=17 t=3 pr=2 a=10772 h=0 m=301/0/0/0/0. 2016.12.02 20:20:00 - OpenVPN > 255.255.255.255 255.255.255.255 127.0.0.1 p=0 i=1 t=3 pr=2 a=10779 h=0 m=331/0/0/0/0. 2016.12.02 20:20:00 - OpenVPN > 255.255.255.255 255.255.255.255 10.4.92.206 p=0 i=18 t=3 pr=2 a=10778 h=0 m=291/0/0/0/0. 2016.12.02 20:20:00 - OpenVPN > 255.255.255.255 255.255.255.255 192.168.1.101 p=0 i=17 t=3 pr=2 a=10772 h=0 m=301/0/0/0/0. 2016.12.02 20:20:00 - OpenVPN > SYSTEM ADAPTER LIST. 2016.12.02 20:20:00 - OpenVPN > Intel® Ethernet Connection I217-V. 2016.12.02 20:20:00 - OpenVPN > Index = 3. 2016.12.02 20:20:00 - OpenVPN > GUID = {1795EC65-5262-4A75-876C-4AF7E8D0D4EB}. 2016.12.02 20:20:00 - OpenVPN > IP = 0.0.0.0/0.0.0.0. 2016.12.02 20:20:00 - OpenVPN > MAC = 74:d4:35:eb:63:3e. 2016.12.02 20:20:00 - OpenVPN > GATEWAY = 0.0.0.0/255.255.255.255. 2016.12.02 20:20:00 - OpenVPN > DHCP SERV =. 2016.12.02 20:20:00 - OpenVPN > DHCP LEASE OBTAINED = Fri Dec 02 20:20:00 2016. 2016.12.02 20:20:00 - OpenVPN > DHCP LEASE EXPIRES = Fri Dec 02 20:20:00 2016. 2016.12.02 20:20:00 - OpenVPN > DNS SERV =. 2016.12.02 20:20:00 - OpenVPN > TAP-Windows Adapter V9. 2016.12.02 20:20:00 - OpenVPN > Index = 18. 2016.12.02 20:20:00 - OpenVPN > GUID = {F40AE409-E4BC-4ABA-B9F7-3BD827158EE3}. 2016.12.02 20:20:00 - OpenVPN > IP = 10.4.92.206/255.255.0.0. 2016.12.02 20:20:00 - OpenVPN > MAC = 00:ff:f4:0a:e4:09. 2016.12.02 20:20:00 - OpenVPN > GATEWAY = 0.0.0.0/255.255.255.255. 2016.12.02 20:20:00 - OpenVPN > DHCP SERV = 10.4.255.254/255.255.255.255. 2016.12.02 20:20:00 - OpenVPN > DHCP LEASE OBTAINED = Fri Dec 02 17:21:12 2016. 2016.12.02 20:20:00 - OpenVPN > DHCP LEASE EXPIRES = Sat Dec 02 17:21:12 2017. 2016.12.02 20:20:00 - OpenVPN > DNS SERV = 10.4.0.1/255.255.255.255. 2016.12.02 20:20:00 - OpenVPN > 300Mbps Wireless USB Adapter. 2016.12.02 20:20:00 - OpenVPN > Index = 17. 2016.12.02 20:20:00 - OpenVPN > GUID = {D6DBB021-16B1-4402-97B4-1CEEE4201C7C}. 2016.12.02 20:20:00 - OpenVPN > IP = 192.168.1.101/255.255.255.0. 2016.12.02 20:20:00 - OpenVPN > MAC = 14:cc:20:17:0d:7f. 2016.12.02 20:20:00 - OpenVPN > GATEWAY = 192.168.1.1/255.255.255.255. 2016.12.02 20:20:00 - OpenVPN > DHCP SERV = 192.168.1.1/255.255.255.255. 2016.12.02 20:20:00 - OpenVPN > DHCP LEASE OBTAINED = Fri Dec 02 18:11:06 2016. 2016.12.02 20:20:00 - OpenVPN > DHCP LEASE EXPIRES = Sat Dec 03 18:11:06 2016. 2016.12.02 20:20:00 - OpenVPN > DNS SERV = 10.4.0.1/255.255.255.255. 2016.12.02 20:20:00 - OpenVPN > Microsoft Wi-Fi Direct Virtual Adapter. 2016.12.02 20:20:00 - OpenVPN > Index = 13. 2016.12.02 20:20:00 - OpenVPN > GUID = {AEB675DF-7F7D-4FED-BC91-F8C40081B696}. 2016.12.02 20:20:00 - OpenVPN > IP = 0.0.0.0/0.0.0.0. 2016.12.02 20:20:00 - OpenVPN > MAC = 14:cc:20:17:0d:7f. 2016.12.02 20:20:00 - OpenVPN > GATEWAY = 0.0.0.0/255.255.255.255. 2016.12.02 20:20:00 - OpenVPN > DHCP SERV =. 2016.12.02 20:20:00 - OpenVPN > DHCP LEASE OBTAINED = Fri Dec 02 20:20:00 2016. 2016.12.02 20:20:00 - OpenVPN > DHCP LEASE EXPIRES = Fri Dec 02 20:20:00 2016. 2016.12.02 20:20:00 - OpenVPN > DNS SERV =. 2016.12.02 20:20:00 - Starting Management Interface. 2016.12.02 20:20:00 - OpenVPN > Initialization Sequence Completed With Errors ( see http://openvpn.net/faq.html#dhcpclientserv )! 2016.12.02 20:20:00 - Disconnecting. 2016.12.02 20:20:00 - Management - Send 'signal SIGTERM'. 2016.12.02 20:20:00 - OpenVpn Management > >INFO:OpenVPN Management Interface Version 1 -- type 'help' for more info. 2016.12.02 20:20:00 - DNS leak protection with packet filtering enabled.I 2016.12.02 20:20:00 - Flushing DNSW 2016.12.02 20:20:00 - Checking route, 5° try failed (The remote name could not be resolved: 'nash_exit.airservers.org')W 2016.12.02 20:20:00 - The remote name could not be resolved: 'nash_exit.airservers.org'. 2016.12.02 20:20:00 - OpenVPN > MANAGEMENT: CMD 'signal SIGTERM'. 2016.12.02 20:20:00 - OpenVPN > SIGTERM received, sending exit notification to peer. 2016.12.02 20:20:00 - OpenVPN > C:\WINDOWS\system32\route.exe DELETE 213.152.162.113 MASK 255.255.255.255 192.168.1.1. 2016.12.02 20:20:00 - OpenVPN > Route deletion via IPAPI succeeded [adaptive]. 2016.12.02 20:20:00 - OpenVPN > C:\WINDOWS\system32\route.exe DELETE 0.0.0.0 MASK 128.0.0.0 10.4.0.1. 2016.12.02 20:20:00 - OpenVPN > Route deletion via IPAPI succeeded [adaptive]. 2016.12.02 20:20:00 - OpenVPN > C:\WINDOWS\system32\route.exe DELETE 128.0.0.0 MASK 128.0.0.0 10.4.0.1. 2016.12.02 20:20:00 - OpenVPN > Route deletion via IPAPI succeeded [adaptive]. 2016.12.02 20:20:00 - OpenVPN > Closing TUN/TAP interface. 2016.12.02 20:20:00 - OpenVPN > SIGTERM[soft,exit-with-notification] received, process exiting. 2016.12.02 20:20:05 - Connection terminated.. 2016.12.02 20:20:05 - DNS leak protection with packet filtering disabled.I 2016.12.02 20:20:08 - Checking authorization ...! 2016.12.02 20:20:08 - Connecting to Miram (Netherlands, Alblasserdam). 2016.12.02 20:20:08 - OpenVPN > OpenVPN 2.3.13 x86_64-w64-mingw32 [sSL (OpenSSL)] [LZO] [iPv6] built on Nov 10 2016. 2016.12.02 20:20:08 - OpenVPN > Windows version 6.2 (Windows 8 or greater) 64bit. 2016.12.02 20:20:08 - OpenVPN > library versions: OpenSSL 1.0.2j 26 Sep 2016, LZO 2.09. 2016.12.02 20:20:08 - OpenVPN > MANAGEMENT: TCP Socket listening on [AF_INET]127.0.0.1:3100. 2016.12.02 20:20:08 - OpenVPN > Control Channel Authentication: tls-auth using INLINE static key file. 2016.12.02 20:20:08 - OpenVPN > Outgoing Control Channel Authentication: Using 160 bit message hash 'SHA1' for HMAC authentication. 2016.12.02 20:20:08 - OpenVPN > Incoming Control Channel Authentication: Using 160 bit message hash 'SHA1' for HMAC authentication. 2016.12.02 20:20:08 - OpenVPN > Socket Buffers: R=[65536->262144] S=[65536->262144]. 2016.12.02 20:20:08 - OpenVPN > UDPv4 link local: [undef]. 2016.12.02 20:20:08 - OpenVPN > UDPv4 link remote: [AF_INET]213.152.162.88:443. 2016.12.02 20:20:08 - OpenVPN > TLS: Initial packet from [AF_INET]213.152.162.88:443, sid=12a14555 c9f545b5I 2016.12.02 20:20:09 - Checking route. 2016.12.02 20:20:09 - OpenVPN > VERIFY OK: depth=1, C=IT, ST=IT, L=Perugia, O=airvpn.org, CN=airvpn.org CA, emailAddress=info@airvpn.org. 2016.12.02 20:20:09 - OpenVPN > Validating certificate key usage. 2016.12.02 20:20:09 - OpenVPN > ++ Certificate has key usage 00a0, expects 00a0. 2016.12.02 20:20:09 - OpenVPN > VERIFY KU OK. 2016.12.02 20:20:09 - OpenVPN > Validating certificate extended key usage. 2016.12.02 20:20:09 - OpenVPN > ++ Certificate has EKU (str) TLS Web Server Authentication, expects TLS Web Server Authentication. 2016.12.02 20:20:09 - OpenVPN > VERIFY EKU OK. 2016.12.02 20:20:09 - OpenVPN > VERIFY OK: depth=0, C=IT, ST=IT, L=Perugia, O=airvpn.org, CN=server, emailAddress=info@airvpn.org. 2016.12.02 20:20:09 - OpenVPN > Data Channel Encrypt: Cipher 'AES-256-CBC' initialized with 256 bit key. 2016.12.02 20:20:09 - OpenVPN > Data Channel Encrypt: Using 160 bit message hash 'SHA1' for HMAC authentication. 2016.12.02 20:20:09 - OpenVPN > Data Channel Decrypt: Cipher 'AES-256-CBC' initialized with 256 bit key. 2016.12.02 20:20:09 - OpenVPN > Data Channel Decrypt: Using 160 bit message hash 'SHA1' for HMAC authentication. 2016.12.02 20:20:09 - OpenVPN > Control Channel: TLSv1.2, cipher TLSv1/SSLv3 DHE-RSA-AES256-GCM-SHA384, 4096 bit RSA. 2016.12.02 20:20:09 - OpenVPN > [server] Peer Connection Initiated with [AF_INET]213.152.162.88:443. 2016.12.02 20:20:11 - OpenVPN > SENT CONTROL [server]: 'PUSH_REQUEST' (status=1). 2016.12.02 20:20:11 - OpenVPN > PUSH: Received control message: 'PUSH_REPLY,redirect-gateway def1 bypass-dhcp,dhcp-option DNS 10.4.0.1,comp-lzo no,route-gateway 10.4.0.1,topology subnet,ping 10,ping-restart 60,ifconfig 10.4.92.19 255.255.0.0'. 2016.12.02 20:20:11 - OpenVPN > OPTIONS IMPORT: timers and/or timeouts modified. 2016.12.02 20:20:11 - OpenVPN > OPTIONS IMPORT: LZO parms modified. 2016.12.02 20:20:11 - OpenVPN > OPTIONS IMPORT: --ifconfig/up options modified. 2016.12.02 20:20:11 - OpenVPN > OPTIONS IMPORT: route options modified. 2016.12.02 20:20:11 - OpenVPN > OPTIONS IMPORT: route-related options modified. 2016.12.02 20:20:11 - OpenVPN > OPTIONS IMPORT: --ip-win32 and/or --dhcp-option options modified. 2016.12.02 20:20:11 - OpenVPN > ROUTE_GATEWAY 192.168.1.1/255.255.255.0 I=17 HWADDR=14:cc:20:17:0d:7f. 2016.12.02 20:20:11 - OpenVPN > do_ifconfig, tt->ipv6=0, tt->did_ifconfig_ipv6_setup=0. 2016.12.02 20:20:11 - OpenVPN > open_tun, tt->ipv6=0. 2016.12.02 20:20:11 - OpenVPN > TAP-WIN32 device [Local Area Connection 2] opened: \\.\Global\{F40AE409-E4BC-4ABA-B9F7-3BD827158EE3}.tap. 2016.12.02 20:20:11 - OpenVPN > TAP-Windows Driver Version 9.21. 2016.12.02 20:20:11 - OpenVPN > Set TAP-Windows TUN subnet mode network/local/netmask = 10.4.0.0/10.4.92.19/255.255.0.0 [sUCCEEDED]. 2016.12.02 20:20:11 - OpenVPN > Notified TAP-Windows driver to set a DHCP IP/netmask of 10.4.92.19/255.255.0.0 on interface {F40AE409-E4BC-4ABA-B9F7-3BD827158EE3} [DHCP-serv: 10.4.255.254, lease-time: 31536000]. 2016.12.02 20:20:11 - OpenVPN > Successful ARP Flush on interface [18] {F40AE409-E4BC-4ABA-B9F7-3BD827158EE3}. 2016.12.02 20:20:17 - OpenVPN > TEST ROUTES: 0/0 succeeded len=0 ret=0 a=0 u/d=down. 2016.12.02 20:20:17 - OpenVPN > Route: Waiting for TUN/TAP interface to come up.... 2016.12.02 20:20:17 - Eddie Windows Interface Hack executed (Local Area Connection 2)W 2016.12.02 20:20:21 - Checking route, 1° try failed (The operation has timed out). 2016.12.02 20:20:21 - OpenVPN > TEST ROUTES: 0/0 succeeded len=0 ret=0 a=0 u/d=down. 2016.12.02 20:20:21 - OpenVPN > Route: Waiting for TUN/TAP interface to come up.... 2016.12.02 20:20:21 - Eddie Windows Interface Hack executed (Local Area Connection 2). 2016.12.02 20:20:22 - OpenVPN > TEST ROUTES: 0/0 succeeded len=0 ret=0 a=0 u/d=down. 2016.12.02 20:20:22 - OpenVPN > Route: Waiting for TUN/TAP interface to come up.... 2016.12.02 20:20:22 - Eddie Windows Interface Hack executed (Local Area Connection 2). 2016.12.02 20:20:23 - OpenVPN > TEST ROUTES: 0/0 succeeded len=0 ret=0 a=0 u/d=down. 2016.12.02 20:20:23 - OpenVPN > Route: Waiting for TUN/TAP interface to come up.... 2016.12.02 20:20:23 - Eddie Windows Interface Hack executed (Local Area Connection 2). 2016.12.02 20:20:24 - OpenVPN > TEST ROUTES: 0/0 succeeded len=0 ret=0 a=0 u/d=down. 2016.12.02 20:20:24 - OpenVPN > Route: Waiting for TUN/TAP interface to come up.... 2016.12.02 20:20:24 - Eddie Windows Interface Hack executed (Local Area Connection 2). 2016.12.02 20:20:25 - OpenVPN > TEST ROUTES: 0/0 succeeded len=0 ret=0 a=0 u/d=down. 2016.12.02 20:20:25 - OpenVPN > Route: Waiting for TUN/TAP interface to come up.... 2016.12.02 20:20:25 - Eddie Windows Interface Hack executed (Local Area Connection 2). 2016.12.02 20:20:26 - OpenVPN > TEST ROUTES: 0/0 succeeded len=0 ret=0 a=0 u/d=down. 2016.12.02 20:20:26 - OpenVPN > Route: Waiting for TUN/TAP interface to come up.... 2016.12.02 20:20:26 - Eddie Windows Interface Hack executed (Local Area Connection 2). 2016.12.02 20:20:27 - OpenVPN > TEST ROUTES: 0/0 succeeded len=0 ret=0 a=0 u/d=down. 2016.12.02 20:20:27 - OpenVPN > Route: Waiting for TUN/TAP interface to come up.... 2016.12.02 20:20:28 - Eddie Windows Interface Hack executed (Local Area Connection 2). 2016.12.02 20:20:29 - OpenVPN > TEST ROUTES: 0/0 succeeded len=0 ret=0 a=0 u/d=down. 2016.12.02 20:20:29 - OpenVPN > Route: Waiting for TUN/TAP interface to come up.... 2016.12.02 20:20:29 - Eddie Windows Interface Hack executed (Local Area Connection 2). 2016.12.02 20:20:30 - OpenVPN > TEST ROUTES: 0/0 succeeded len=0 ret=0 a=0 u/d=down. 2016.12.02 20:20:30 - OpenVPN > Route: Waiting for TUN/TAP interface to come up.... 2016.12.02 20:20:30 - Eddie Windows Interface Hack executed (Local Area Connection 2). 2016.12.02 20:20:31 - OpenVPN > TEST ROUTES: 0/0 succeeded len=0 ret=0 a=0 u/d=down. 2016.12.02 20:20:31 - OpenVPN > Route: Waiting for TUN/TAP interface to come up.... 2016.12.02 20:20:31 - Eddie Windows Interface Hack executed (Local Area Connection 2). 2016.12.02 20:20:32 - OpenVPN > TEST ROUTES: 0/0 succeeded len=0 ret=0 a=0 u/d=down. 2016.12.02 20:20:32 - OpenVPN > Route: Waiting for TUN/TAP interface to come up.... 2016.12.02 20:20:32 - Eddie Windows Interface Hack executed (Local Area Connection 2)W 2016.12.02 20:20:33 - Checking route, 2° try failed (The operation has timed out). 2016.12.02 20:20:33 - OpenVPN > TEST ROUTES: 0/0 succeeded len=0 ret=0 a=0 u/d=down. 2016.12.02 20:20:33 - OpenVPN > Route: Waiting for TUN/TAP interface to come up.... 2016.12.02 20:20:33 - Eddie Windows Interface Hack executed (Local Area Connection 2). 2016.12.02 20:20:34 - OpenVPN > TEST ROUTES: 0/0 succeeded len=0 ret=0 a=0 u/d=down. 2016.12.02 20:20:34 - OpenVPN > Route: Waiting for TUN/TAP interface to come up.... 2016.12.02 20:20:34 - Eddie Windows Interface Hack executed (Local Area Connection 2). 2016.12.02 20:20:35 - OpenVPN > TEST ROUTES: 0/0 succeeded len=0 ret=0 a=0 u/d=down. 2016.12.02 20:20:35 - OpenVPN > Route: Waiting for TUN/TAP interface to come up.... 2016.12.02 20:20:35 - Eddie Windows Interface Hack executed (Local Area Connection 2). 2016.12.02 20:20:36 - OpenVPN > TEST ROUTES: 0/0 succeeded len=0 ret=0 a=0 u/d=down. 2016.12.02 20:20:36 - OpenVPN > Route: Waiting for TUN/TAP interface to come up.... 2016.12.02 20:20:36 - Eddie Windows Interface Hack executed (Local Area Connection 2). 2016.12.02 20:20:37 - OpenVPN > TEST ROUTES: 0/0 succeeded len=0 ret=0 a=0 u/d=down. 2016.12.02 20:20:37 - OpenVPN > Route: Waiting for TUN/TAP interface to come up.... 2016.12.02 20:20:37 - Eddie Windows Interface Hack executed (Local Area Connection 2). 2016.12.02 20:20:39 - OpenVPN > TEST ROUTES: 0/0 succeeded len=0 ret=0 a=0 u/d=down. 2016.12.02 20:20:39 - OpenVPN > Route: Waiting for TUN/TAP interface to come up.... 2016.12.02 20:20:39 - Eddie Windows Interface Hack executed (Local Area Connection 2). 2016.12.02 20:20:40 - OpenVPN > TEST ROUTES: 0/0 succeeded len=0 ret=0 a=0 u/d=down. 2016.12.02 20:20:40 - OpenVPN > Route: Waiting for TUN/TAP interface to come up.... 2016.12.02 20:20:40 - Eddie Windows Interface Hack executed (Local Area Connection 2). 2016.12.02 20:20:41 - OpenVPN > TEST ROUTES: 0/0 succeeded len=0 ret=0 a=0 u/d=down. 2016.12.02 20:20:41 - OpenVPN > Route: Waiting for TUN/TAP interface to come up.... 2016.12.02 20:20:41 - Eddie Windows Interface Hack executed (Local Area Connection 2). 2016.12.02 20:20:42 - OpenVPN > TEST ROUTES: 0/0 succeeded len=0 ret=0 a=0 u/d=down. 2016.12.02 20:20:42 - OpenVPN > Route: Waiting for TUN/TAP interface to come up.... 2016.12.02 20:20:42 - Eddie Windows Interface Hack executed (Local Area Connection 2). 2016.12.02 20:20:43 - OpenVPN > TEST ROUTES: 0/0 succeeded len=0 ret=0 a=0 u/d=down. 2016.12.02 20:20:43 - OpenVPN > Route: Waiting for TUN/TAP interface to come up.... 2016.12.02 20:20:43 - Eddie Windows Interface Hack executed (Local Area Connection 2). 2016.12.02 20:20:44 - OpenVPN > TEST ROUTES: 0/0 succeeded len=0 ret=0 a=0 u/d=down. 2016.12.02 20:20:44 - OpenVPN > Route: Waiting for TUN/TAP interface to come up.... 2016.12.02 20:20:44 - Eddie Windows Interface Hack executed (Local Area Connection 2)W 2016.12.02 20:20:45 - Checking route, 3° try failed (The operation has timed out). 2016.12.02 20:20:45 - OpenVPN > TEST ROUTES: 0/0 succeeded len=0 ret=0 a=0 u/d=down. 2016.12.02 20:20:45 - OpenVPN > Route: Waiting for TUN/TAP interface to come up.... 2016.12.02 20:20:45 - Eddie Windows Interface Hack executed (Local Area Connection 2). 2016.12.02 20:20:46 - OpenVPN > TEST ROUTES: 0/0 succeeded len=0 ret=0 a=0 u/d=down. 2016.12.02 20:20:46 - OpenVPN > C:\WINDOWS\system32\route.exe ADD 213.152.162.88 MASK 255.255.255.255 192.168.1.1. 2016.12.02 20:20:46 - OpenVPN > ROUTE: CreateIpForwardEntry succeeded with dwForwardMetric1=45 and dwForwardType=4. 2016.12.02 20:20:46 - OpenVPN > Route addition via IPAPI succeeded [adaptive]. 2016.12.02 20:20:46 - OpenVPN > C:\WINDOWS\system32\route.exe ADD 0.0.0.0 MASK 128.0.0.0 10.4.0.1. 2016.12.02 20:20:46 - OpenVPN > ROUTE: CreateIpForwardEntry succeeded with dwForwardMetric1=35 and dwForwardType=4. 2016.12.02 20:20:46 - OpenVPN > Route addition via IPAPI succeeded [adaptive]. 2016.12.02 20:20:46 - OpenVPN > C:\WINDOWS\system32\route.exe ADD 128.0.0.0 MASK 128.0.0.0 10.4.0.1. 2016.12.02 20:20:46 - OpenVPN > ROUTE: CreateIpForwardEntry succeeded with dwForwardMetric1=35 and dwForwardType=4. 2016.12.02 20:20:46 - OpenVPN > Route addition via IPAPI succeeded [adaptive]. 2016.12.02 20:20:46 - OpenVPN > SYSTEM ROUTING TABLE. 2016.12.02 20:20:46 - OpenVPN > 0.0.0.0 0.0.0.0 192.168.1.1 p=0 i=17 t=4 pr=3 a=10815 h=0 m=45/0/0/0/0. 2016.12.02 20:20:46 - OpenVPN > 0.0.0.0 128.0.0.0 10.4.0.1 p=0 i=18 t=4 pr=3 a=0 h=0 m=35/0/0/0/0. 2016.12.02 20:20:46 - OpenVPN > 10.4.0.0 255.255.0.0 10.4.92.206 p=0 i=18 t=3 pr=2 a=10774 h=0 m=291/0/0/0/0. 2016.12.02 20:20:46 - OpenVPN > 10.4.92.206 255.255.255.255 10.4.92.206 p=0 i=18 t=3 pr=2 a=10774 h=0 m=291/0/0/0/0. 2016.12.02 20:20:46 - OpenVPN > 10.4.255.255 255.255.255.255 10.4.92.206 p=0 i=18 t=3 pr=2 a=10774 h=0 m=291/0/0/0/0. 2016.12.02 20:20:46 - OpenVPN > 127.0.0.0 255.0.0.0 127.0.0.1 p=0 i=1 t=3 pr=2 a=10824 h=0 m=331/0/0/0/0. 2016.12.02 20:20:46 - OpenVPN > 127.0.0.1 255.255.255.255 127.0.0.1 p=0 i=1 t=3 pr=2 a=10824 h=0 m=331/0/0/0/0. 2016.12.02 20:20:46 - OpenVPN > 127.255.255.255 255.255.255.255 127.0.0.1 p=0 i=1 t=3 pr=2 a=10824 h=0 m=331/0/0/0/0. 2016.12.02 20:20:46 - OpenVPN > 128.0.0.0 128.0.0.0 10.4.0.1 p=0 i=18 t=4 pr=3 a=0 h=0 m=35/0/0/0/0. 2016.12.02 20:20:46 - OpenVPN > 192.168.1.0 255.255.255.0 192.168.1.101 p=0 i=17 t=3 pr=2 a=10815 h=0 m=301/0/0/0/0. 2016.12.02 20:20:46 - OpenVPN > 192.168.1.101 255.255.255.255 192.168.1.101 p=0 i=17 t=3 pr=2 a=10815 h=0 m=301/0/0/0/0. 2016.12.02 20:20:46 - OpenVPN > 192.168.1.255 255.255.255.255 192.168.1.101 p=0 i=17 t=3 pr=2 a=10815 h=0 m=301/0/0/0/0. 2016.12.02 20:20:46 - OpenVPN > 213.152.162.88 255.255.255.255 192.168.1.1 p=0 i=17 t=4 pr=3 a=0 h=0 m=45/0/0/0/0. 2016.12.02 20:20:46 - OpenVPN > 224.0.0.0 240.0.0.0 127.0.0.1 p=0 i=1 t=3 pr=2 a=10824 h=0 m=331/0/0/0/0. 2016.12.02 20:20:46 - OpenVPN > 224.0.0.0 240.0.0.0 10.4.92.206 p=0 i=18 t=3 pr=2 a=10823 h=0 m=291/0/0/0/0. 2016.12.02 20:20:46 - OpenVPN > 224.0.0.0 240.0.0.0 192.168.1.101 p=0 i=17 t=3 pr=2 a=10817 h=0 m=301/0/0/0/0. 2016.12.02 20:20:46 - OpenVPN > 255.255.255.255 255.255.255.255 127.0.0.1 p=0 i=1 t=3 pr=2 a=10824 h=0 m=331/0/0/0/0. 2016.12.02 20:20:46 - OpenVPN > 255.255.255.255 255.255.255.255 10.4.92.206 p=0 i=18 t=3 pr=2 a=10823 h=0 m=291/0/0/0/0. 2016.12.02 20:20:46 - OpenVPN > 255.255.255.255 255.255.255.255 192.168.1.101 p=0 i=17 t=3 pr=2 a=10817 h=0 m=301/0/0/0/0. 2016.12.02 20:20:46 - OpenVPN > SYSTEM ADAPTER LIST. 2016.12.02 20:20:46 - OpenVPN > Intel® Ethernet Connection I217-V. 2016.12.02 20:20:46 - OpenVPN > Index = 3. 2016.12.02 20:20:46 - OpenVPN > GUID = {1795EC65-5262-4A75-876C-4AF7E8D0D4EB}. 2016.12.02 20:20:46 - OpenVPN > IP = 0.0.0.0/0.0.0.0. 2016.12.02 20:20:46 - OpenVPN > MAC = 74:d4:35:eb:63:3e. 2016.12.02 20:20:46 - OpenVPN > GATEWAY = 0.0.0.0/255.255.255.255. 2016.12.02 20:20:46 - OpenVPN > DHCP SERV =. 2016.12.02 20:20:46 - OpenVPN > DHCP LEASE OBTAINED = Fri Dec 02 20:20:46 2016. 2016.12.02 20:20:46 - OpenVPN > DHCP LEASE EXPIRES = Fri Dec 02 20:20:46 2016. 2016.12.02 20:20:46 - OpenVPN > DNS SERV =. 2016.12.02 20:20:46 - OpenVPN > TAP-Windows Adapter V9. 2016.12.02 20:20:46 - OpenVPN > Index = 18. 2016.12.02 20:20:46 - OpenVPN > GUID = {F40AE409-E4BC-4ABA-B9F7-3BD827158EE3}. 2016.12.02 20:20:46 - OpenVPN > IP = 10.4.92.206/255.255.0.0. 2016.12.02 20:20:46 - OpenVPN > MAC = 00:ff:f4:0a:e4:09. 2016.12.02 20:20:46 - OpenVPN > GATEWAY = 0.0.0.0/255.255.255.255. 2016.12.02 20:20:46 - OpenVPN > DHCP SERV = 10.4.255.254/255.255.255.255. 2016.12.02 20:20:46 - OpenVPN > DHCP LEASE OBTAINED = Fri Dec 02 17:21:12 2016. 2016.12.02 20:20:46 - OpenVPN > DHCP LEASE EXPIRES = Sat Dec 02 17:21:12 2017. 2016.12.02 20:20:46 - OpenVPN > DNS SERV = 10.4.0.1/255.255.255.255. 2016.12.02 20:20:46 - OpenVPN > 300Mbps Wireless USB Adapter. 2016.12.02 20:20:46 - OpenVPN > Index = 17. 2016.12.02 20:20:46 - OpenVPN > GUID = {D6DBB021-16B1-4402-97B4-1CEEE4201C7C}. 2016.12.02 20:20:46 - OpenVPN > IP = 192.168.1.101/255.255.255.0. 2016.12.02 20:20:46 - OpenVPN > MAC = 14:cc:20:17:0d:7f. 2016.12.02 20:20:46 - OpenVPN > GATEWAY = 192.168.1.1/255.255.255.255. 2016.12.02 20:20:46 - OpenVPN > DHCP SERV = 192.168.1.1/255.255.255.255. 2016.12.02 20:20:46 - OpenVPN > DHCP LEASE OBTAINED = Fri Dec 02 18:11:06 2016. 2016.12.02 20:20:46 - OpenVPN > DHCP LEASE EXPIRES = Sat Dec 03 18:11:06 2016. 2016.12.02 20:20:46 - OpenVPN > DNS SERV = 10.4.0.1/255.255.255.255. 2016.12.02 20:20:46 - OpenVPN > Microsoft Wi-Fi Direct Virtual Adapter. 2016.12.02 20:20:46 - OpenVPN > Index = 13. 2016.12.02 20:20:46 - OpenVPN > GUID = {AEB675DF-7F7D-4FED-BC91-F8C40081B696}. 2016.12.02 20:20:46 - OpenVPN > IP = 0.0.0.0/0.0.0.0. 2016.12.02 20:20:46 - OpenVPN > MAC = 14:cc:20:17:0d:7f. 2016.12.02 20:20:46 - OpenVPN > GATEWAY = 0.0.0.0/255.255.255.255. 2016.12.02 20:20:46 - OpenVPN > DHCP SERV =. 2016.12.02 20:20:46 - OpenVPN > DHCP LEASE OBTAINED = Fri Dec 02 20:20:46 2016. 2016.12.02 20:20:46 - OpenVPN > DHCP LEASE EXPIRES = Fri Dec 02 20:20:46 2016. 2016.12.02 20:20:46 - OpenVPN > DNS SERV =. 2016.12.02 20:20:46 - Starting Management Interface. 2016.12.02 20:20:46 - OpenVPN > Initialization Sequence Completed With Errors ( see http://openvpn.net/faq.html#dhcpclientserv ). 2016.12.02 20:20:46 - DNS leak protection with packet filtering enabled.I 2016.12.02 20:20:46 - Flushing DNS! 2016.12.02 20:20:46 - Disconnecting. 2016.12.02 20:20:46 - Management - Send 'signal SIGTERM'. 2016.12.02 20:20:46 - OpenVpn Management > >INFO:OpenVPN Management Interface Version 1 -- type 'help' for more infoW 2016.12.02 20:20:47 - Checking route, 4° try failed (The remote name could not be resolved: 'miram_exit.airservers.org'). 2016.12.02 20:20:51 - Connection terminated.. 2016.12.02 20:20:51 - DNS leak protection with packet filtering disabled.. 2016.12.02 20:20:52 - OpenVPN > MANAGEMENT: Client connected from [AF_INET]127.0.0.1:3100. 2016.12.02 20:20:52 - OpenVPN > MANAGEMENT: CMD 'signal SIGTERM'. 2016.12.02 20:20:52 - OpenVPN > SIGTERM received, sending exit notification to peer. 2016.12.02 20:20:52 - OpenVPN > C:\WINDOWS\system32\route.exe DELETE 213.152.162.88 MASK 255.255.255.255 192.168.1.1. 2016.12.02 20:20:52 - OpenVPN > Route deletion via IPAPI succeeded [adaptive]. 2016.12.02 20:20:52 - OpenVPN > C:\WINDOWS\system32\route.exe DELETE 0.0.0.0 MASK 128.0.0.0 10.4.0.1. 2016.12.02 20:20:52 - OpenVPN > Route deletion via IPAPI succeeded [adaptive]. 2016.12.02 20:20:52 - OpenVPN > C:\WINDOWS\system32\route.exe DELETE 128.0.0.0 MASK 128.0.0.0 10.4.0.1. 2016.12.02 20:20:52 - OpenVPN > Route deletion via IPAPI succeeded [adaptive]. 2016.12.02 20:20:52 - OpenVPN > Closing TUN/TAP interface. 2016.12.02 20:20:52 - OpenVPN > SIGTERM[soft,exit-with-notification] received, process exitingI 2016.12.02 20:20:54 - Checking authorization ...! 2016.12.02 20:20:55 - Connecting to Garnet (Netherlands, Alblasserdam). 2016.12.02 20:20:55 - OpenVPN > OpenVPN 2.3.13 x86_64-w64-mingw32 [sSL (OpenSSL)] [LZO] [iPv6] built on Nov 10 2016. 2016.12.02 20:20:55 - OpenVPN > Windows version 6.2 (Windows 8 or greater) 64bit. 2016.12.02 20:20:55 - OpenVPN > library versions: OpenSSL 1.0.2j 26 Sep 2016, LZO 2.09. 2016.12.02 20:20:55 - OpenVPN > MANAGEMENT: TCP Socket listening on [AF_INET]127.0.0.1:3100. 2016.12.02 20:20:55 - OpenVPN > Control Channel Authentication: tls-auth using INLINE static key file. 2016.12.02 20:20:55 - OpenVPN > Outgoing Control Channel Authentication: Using 160 bit message hash 'SHA1' for HMAC authentication. 2016.12.02 20:20:55 - OpenVPN > Incoming Control Channel Authentication: Using 160 bit message hash 'SHA1' for HMAC authentication. 2016.12.02 20:20:55 - OpenVPN > Socket Buffers: R=[65536->262144] S=[65536->262144]. 2016.12.02 20:20:55 - OpenVPN > UDPv4 link local: [undef]. 2016.12.02 20:20:55 - OpenVPN > UDPv4 link remote: [AF_INET]213.152.162.73:443. 2016.12.02 20:20:55 - OpenVPN > TLS: Initial packet from [AF_INET]213.152.162.73:443, sid=e96e02f8 c6b8c740. 2016.12.02 20:20:55 - OpenVPN > VERIFY OK: depth=1, C=IT, ST=IT, L=Perugia, O=airvpn.org, CN=airvpn.org CA, emailAddress=info@airvpn.org. 2016.12.02 20:20:55 - OpenVPN > Validating certificate key usage. 2016.12.02 20:20:55 - OpenVPN > ++ Certificate has key usage 00a0, expects 00a0. 2016.12.02 20:20:55 - OpenVPN > VERIFY KU OK. 2016.12.02 20:20:55 - OpenVPN > Validating certificate extended key usage. 2016.12.02 20:20:55 - OpenVPN > ++ Certificate has EKU (str) TLS Web Server Authentication, expects TLS Web Server Authentication. 2016.12.02 20:20:55 - OpenVPN > VERIFY EKU OK. 2016.12.02 20:20:55 - OpenVPN > VERIFY OK: depth=0, C=IT, ST=IT, L=Perugia, O=airvpn.org, CN=server, emailAddress=info@airvpn.org. 2016.12.02 20:20:59 - OpenVPN > Data Channel Encrypt: Cipher 'AES-256-CBC' initialized with 256 bit key. 2016.12.02 20:20:59 - OpenVPN > Data Channel Encrypt: Using 160 bit message hash 'SHA1' for HMAC authentication. 2016.12.02 20:20:59 - OpenVPN > Data Channel Decrypt: Cipher 'AES-256-CBC' initialized with 256 bit key. 2016.12.02 20:20:59 - OpenVPN > Data Channel Decrypt: Using 160 bit message hash 'SHA1' for HMAC authentication. 2016.12.02 20:20:59 - OpenVPN > Control Channel: TLSv1.2, cipher TLSv1/SSLv3 DHE-RSA-AES256-GCM-SHA384, 4096 bit RSA. 2016.12.02 20:20:59 - OpenVPN > [server] Peer Connection Initiated with [AF_INET]213.152.162.73:443W 2016.12.02 20:21:00 - Checking route, 5° try failed (The operation has timed out)W 2016.12.02 20:21:00 - The operation has timed out. 2016.12.02 20:21:00 - OpenVPN > MANAGEMENT: CMD 'signal SIGTERM'. 2016.12.02 20:21:00 - OpenVPN > SIGTERM received, sending exit notification to peer. 2016.12.02 20:21:00 - OpenVPN > C:\WINDOWS\system32\route.exe DELETE 213.152.162.180 MASK 255.255.255.255 192.168.1.1. 2016.12.02 20:21:00 - OpenVPN > Route deletion via IPAPI succeeded [adaptive]. 2016.12.02 20:21:00 - OpenVPN > C:\WINDOWS\system32\route.exe DELETE 0.0.0.0 MASK 128.0.0.0 10.4.0.1. 2016.12.02 20:21:00 - OpenVPN > Route deletion via IPAPI succeeded [adaptive]. 2016.12.02 20:21:00 - OpenVPN > C:\WINDOWS\system32\route.exe DELETE 128.0.0.0 MASK 128.0.0.0 10.4.0.1. 2016.12.02 20:21:00 - OpenVPN > Route deletion via IPAPI succeeded [adaptive]. 2016.12.02 20:21:00 - OpenVPN > Closing TUN/TAP interface. 2016.12.02 20:21:00 - OpenVPN > SIGTERM[soft,exit-with-notification] received, process exiting! 2016.12.02 20:21:00 - Disconnecting. 2016.12.02 20:21:00 - Connection terminated.I 2016.12.02 20:21:03 - Checking authorization ...! 2016.12.02 20:21:04 - Connecting to Merga (Netherlands, Alblasserdam). 2016.12.02 20:21:04 - OpenVPN > OpenVPN 2.3.13 x86_64-w64-mingw32 [sSL (OpenSSL)] [LZO] [iPv6] built on Nov 10 2016. 2016.12.02 20:21:04 - OpenVPN > Windows version 6.2 (Windows 8 or greater) 64bit. 2016.12.02 20:21:04 - OpenVPN > library versions: OpenSSL 1.0.2j 26 Sep 2016, LZO 2.09. 2016.12.02 20:21:04 - OpenVPN > MANAGEMENT: TCP Socket listening on [AF_INET]127.0.0.1:3100. 2016.12.02 20:21:04 - OpenVPN > Control Channel Authentication: tls-auth using INLINE static key file. 2016.12.02 20:21:04 - OpenVPN > Outgoing Control Channel Authentication: Using 160 bit message hash 'SHA1' for HMAC authentication. 2016.12.02 20:21:04 - OpenVPN > Incoming Control Channel Authentication: Using 160 bit message hash 'SHA1' for HMAC authentication. 2016.12.02 20:21:04 - OpenVPN > Socket Buffers: R=[65536->262144] S=[65536->262144]. 2016.12.02 20:21:04 - OpenVPN > UDPv4 link local: [undef]. 2016.12.02 20:21:04 - OpenVPN > UDPv4 link remote: [AF_INET]213.152.161.29:443. 2016.12.02 20:21:04 - OpenVPN > TLS: Initial packet from [AF_INET]213.152.161.29:443, sid=df19f22e a9af71d6. 2016.12.02 20:21:04 - OpenVPN > VERIFY OK: depth=1, C=IT, ST=IT, L=Perugia, O=airvpn.org, CN=airvpn.org CA, emailAddress=info@airvpn.org. 2016.12.02 20:21:04 - OpenVPN > Validating certificate key usage. 2016.12.02 20:21:04 - OpenVPN > ++ Certificate has key usage 00a0, expects 00a0. 2016.12.02 20:21:04 - OpenVPN > VERIFY KU OK. 2016.12.02 20:21:04 - OpenVPN > Validating certificate extended key usage. 2016.12.02 20:21:04 - OpenVPN > ++ Certificate has EKU (str) TLS Web Server Authentication, expects TLS Web Server Authentication. 2016.12.02 20:21:04 - OpenVPN > VERIFY EKU OK. 2016.12.02 20:21:04 - OpenVPN > VERIFY OK: depth=0, C=IT, ST=IT, L=Perugia, O=airvpn.org, CN=server, emailAddress=info@airvpn.org. 2016.12.02 20:21:04 - OpenVPN > Data Channel Encrypt: Cipher 'AES-256-CBC' initialized with 256 bit key. 2016.12.02 20:21:04 - OpenVPN > Data Channel Encrypt: Using 160 bit message hash 'SHA1' for HMAC authentication. 2016.12.02 20:21:04 - OpenVPN > Data Channel Decrypt: Cipher 'AES-256-CBC' initialized with 256 bit key. 2016.12.02 20:21:04 - OpenVPN > Data Channel Decrypt: Using 160 bit message hash 'SHA1' for HMAC authentication. 2016.12.02 20:21:04 - OpenVPN > Control Channel: TLSv1.2, cipher TLSv1/SSLv3 DHE-RSA-AES256-GCM-SHA384, 4096 bit RSA. 2016.12.02 20:21:04 - OpenVPN > [server] Peer Connection Initiated with [AF_INET]213.152.161.29:443. 2016.12.02 20:21:06 - OpenVPN > SENT CONTROL [server]: 'PUSH_REQUEST' (status=1). 2016.12.02 20:21:06 - OpenVPN > PUSH: Received control message: 'PUSH_REPLY,redirect-gateway def1 bypass-dhcp,dhcp-option DNS 10.4.0.1,comp-lzo no,route-gateway 10.4.0.1,topology subnet,ping 10,ping-restart 60,ifconfig 10.4.92.206 255.255.0.0'. 2016.12.02 20:21:06 - OpenVPN > OPTIONS IMPORT: timers and/or timeouts modified. 2016.12.02 20:21:06 - OpenVPN > OPTIONS IMPORT: LZO parms modified. 2016.12.02 20:21:06 - OpenVPN > OPTIONS IMPORT: --ifconfig/up options modified. 2016.12.02 20:21:06 - OpenVPN > OPTIONS IMPORT: route options modified. 2016.12.02 20:21:06 - OpenVPN > OPTIONS IMPORT: route-related options modified. 2016.12.02 20:21:06 - OpenVPN > OPTIONS IMPORT: --ip-win32 and/or --dhcp-option options modified. 2016.12.02 20:21:06 - OpenVPN > ROUTE_GATEWAY 192.168.1.1/255.255.255.0 I=17 HWADDR=14:cc:20:17:0d:7f. 2016.12.02 20:21:06 - OpenVPN > do_ifconfig, tt->ipv6=0, tt->did_ifconfig_ipv6_setup=0. 2016.12.02 20:21:06 - OpenVPN > open_tun, tt->ipv6=0. 2016.12.02 20:21:06 - OpenVPN > TAP-WIN32 device [Local Area Connection 2] opened: \\.\Global\{F40AE409-E4BC-4ABA-B9F7-3BD827158EE3}.tap. 2016.12.02 20:21:06 - OpenVPN > TAP-Windows Driver Version 9.21. 2016.12.02 20:21:06 - OpenVPN > Set TAP-Windows TUN subnet mode network/local/netmask = 10.4.0.0/10.4.92.206/255.255.0.0 [sUCCEEDED]. 2016.12.02 20:21:06 - OpenVPN > Notified TAP-Windows driver to set a DHCP IP/netmask of 10.4.92.206/255.255.0.0 on interface {F40AE409-E4BC-4ABA-B9F7-3BD827158EE3} [DHCP-serv: 10.4.255.254, lease-time: 31536000]. 2016.12.02 20:21:06 - OpenVPN > Successful ARP Flush on interface [18] {F40AE409-E4BC-4ABA-B9F7-3BD827158EE3}. 2016.12.02 20:21:12 - OpenVPN > TEST ROUTES: 1/1 succeeded len=0 ret=1 a=0 u/d=up. 2016.12.02 20:21:12 - OpenVPN > C:\WINDOWS\system32\route.exe ADD 213.152.161.29 MASK 255.255.255.255 192.168.1.1. 2016.12.02 20:21:12 - OpenVPN > ROUTE: CreateIpForwardEntry succeeded with dwForwardMetric1=40 and dwForwardType=4. 2016.12.02 20:21:12 - OpenVPN > Route addition via IPAPI succeeded [adaptive]. 2016.12.02 20:21:12 - OpenVPN > C:\WINDOWS\system32\route.exe ADD 0.0.0.0 MASK 128.0.0.0 10.4.0.1. 2016.12.02 20:21:12 - OpenVPN > ROUTE: CreateIpForwardEntry succeeded with dwForwardMetric1=35 and dwForwardType=4. 2016.12.02 20:21:12 - OpenVPN > Route addition via IPAPI succeeded [adaptive]. 2016.12.02 20:21:12 - OpenVPN > C:\WINDOWS\system32\route.exe ADD 128.0.0.0 MASK 128.0.0.0 10.4.0.1. 2016.12.02 20:21:12 - OpenVPN > ROUTE: CreateIpForwardEntry succeeded with dwForwardMetric1=35 and dwForwardType=4. 2016.12.02 20:21:12 - OpenVPN > Route addition via IPAPI succeeded [adaptive]. 2016.12.02 20:21:12 - Starting Management Interface. 2016.12.02 20:21:12 - OpenVPN > Initialization Sequence Completed. 2016.12.02 20:21:12 - DNS leak protection with packet filtering enabled.I 2016.12.02 20:21:12 - Flushing DNS. 2016.12.02 20:21:13 - Updating systems & servers data .... 2016.12.02 20:21:13 - Systems & servers data update completedI 2016.12.02 20:21:17 - Checking routeI 2016.12.02 20:21:18 - Checking DNS! 2016.12.02 20:21:30 - Connected.. 2016.12.02 20:21:30 - OpenVPN > MANAGEMENT: Client connected from [AF_INET]127.0.0.1:3100. 2016.12.02 20:21:30 - OpenVpn Management > >INFO:OpenVPN Management Interface Version 1 -- type 'help' for more info. 2016.12.02 20:31:15 - Updating systems & servers data .... 2016.12.02 20:31:15 - Systems & servers data update completed. 2016.12.02 20:41:16 - Updating systems & servers data .... 2016.12.02 20:41:17 - Systems & servers data update completed. 2016.12.02 20:51:18 - Updating systems & servers data .... 2016.12.02 20:51:19 - Systems & servers data update completed. 2016.12.02 20:58:06 - OpenVPN > Authenticate/Decrypt packet error: bad packet ID (may be a replay): [ #9729 ] -- see the man page entry for --no-replay and --replay-window for more info or silence this warning with --mute-replay-warnings. 2016.12.02 20:58:06 - OpenVPN > Authenticate/Decrypt packet error: bad packet ID (may be a replay): [ #9730 ] -- see the man page entry for --no-replay and --replay-window for more info or silence this warning with --mute-replay-warnings. 2016.12.02 20:58:06 - OpenVPN > Authenticate/Decrypt packet error: bad packet ID (may be a replay): [ #9731 ] -- see the man page entry for --no-replay and --replay-window for more info or silence this warning with --mute-replay-warnings. 2016.12.02 20:58:06 - OpenVPN > Authenticate/Decrypt packet error: bad packet ID (may be a replay): [ #9732 ] -- see the man page entry for --no-replay and --replay-window for more info or silence this warning with --mute-replay-warnings. 2016.12.02 20:58:06 - OpenVPN > Authenticate/Decrypt packet error: bad packet ID (may be a replay): [ #9729 ] -- see the man page entry for --no-replay and --replay-window for more info or silence this warning with --mute-replay-warnings. 2016.12.02 20:58:06 - OpenVPN > Authenticate/Decrypt packet error: bad packet ID (may be a replay): [ #9730 ] -- see the man page entry for --no-replay and --replay-window for more info or silence this warning with --mute-replay-warnings. 2016.12.02 20:58:06 - OpenVPN > Authenticate/Decrypt packet error: bad packet ID (may be a replay): [ #9731 ] -- see the man page entry for --no-replay and --replay-window for more info or silence this warning with --mute-replay-warnings. 2016.12.02 20:58:06 - OpenVPN > Authenticate/Decrypt packet error: bad packet ID (may be a replay): [ #9732 ] -- see the man page entry for --no-replay and --replay-window for more info or silence this warning with --mute-replay-warnings. 2016.12.02 20:58:06 - OpenVPN > Authenticate/Decrypt packet error: bad packet ID (may be a replay): [ #9731 ] -- see the man page entry for --no-replay and --replay-window for more info or silence this warning with --mute-replay-warnings. 2016.12.02 20:58:06 - OpenVPN > Authenticate/Decrypt packet error: bad packet ID (may be a replay): [ #9732 ] -- see the man page entry for --no-replay and --replay-window for more info or silence this warning with --mute-replay-warnings. 2016.12.02 20:58:06 - OpenVPN > Authenticate/Decrypt packet error: bad packet ID (may be a replay): [ #9729 ] -- see the man page entry for --no-replay and --replay-window for more info or silence this warning with --mute-replay-warnings. 2016.12.02 20:58:06 - OpenVPN > Authenticate/Decrypt packet error: bad packet ID (may be a replay): [ #9730 ] -- see the man page entry for --no-replay and --replay-window for more info or silence this warning with --mute-replay-warnings. 2016.12.02 20:58:06 - OpenVPN > Authenticate/Decrypt packet error: bad packet ID (may be a replay): [ #9731 ] -- see the man page entry for --no-replay and --replay-window for more info or silence this warning with --mute-replay-warnings. 2016.12.02 20:58:06 - OpenVPN > Authenticate/Decrypt packet error: bad packet ID (may be a replay): [ #9732 ] -- see the man page entry for --no-replay and --replay-window for more info or silence this warning with --mute-replay-warnings. 2016.12.02 20:58:06 - OpenVPN > Authenticate/Decrypt packet error: bad packet ID (may be a replay): [ #9752 ] -- see the man page entry for --no-replay and --replay-window for more info or silence this warning with --mute-replay-warnings. 2016.12.02 20:58:06 - OpenVPN > Authenticate/Decrypt packet error: bad packet ID (may be a replay): [ #9753 ] -- see the man page entry for --no-replay and --replay-window for more info or silence this warning with --mute-replay-warnings. 2016.12.02 20:58:06 - OpenVPN > Authenticate/Decrypt packet error: bad packet ID (may be a replay): [ #9752 ] -- see the man page entry for --no-replay and --replay-window for more info or silence this warning with --mute-replay-warnings. 2016.12.02 20:58:06 - OpenVPN > Authenticate/Decrypt packet error: bad packet ID (may be a replay): [ #9753 ] -- see the man page entry for --no-replay and --replay-window for more info or silence this warning with --mute-replay-warnings. 2016.12.02 20:58:06 - OpenVPN > Authenticate/Decrypt packet error: bad packet ID (may be a replay): [ #9752 ] -- see the man page entry for --no-replay and --replay-window for more info or silence this warning with --mute-replay-warnings. 2016.12.02 20:58:06 - OpenVPN > Authenticate/Decrypt packet error: bad packet ID (may be a replay): [ #9753 ] -- see the man page entry for --no-replay and --replay-window for more info or silence this warning with --mute-replay-warnings. 2016.12.02 20:58:06 - OpenVPN > Authenticate/Decrypt packet error: bad packet ID (may be a replay): [ #9752 ] -- see the man page entry for --no-replay and --replay-window for more info or silence this warning with --mute-replay-warnings. 2016.12.02 20:58:06 - OpenVPN > Authenticate/Decrypt packet error: bad packet ID (may be a replay): [ #9753 ] -- see the man page entry for --no-replay and --replay-window for more info or silence this warning with --mute-replay-warnings. 2016.12.02 20:58:06 - OpenVPN > Authenticate/Decrypt packet error: bad packet ID (may be a replay): [ #9752 ] -- see the man page entry for --no-replay and --replay-window for more info or silence this warning with --mute-replay-warnings. 2016.12.02 20:58:06 - OpenVPN > Authenticate/Decrypt packet error: bad packet ID (may be a replay): [ #9753 ] -- see the man page entry for --no-replay and --replay-window for more info or silence this warning with --mute-replay-warnings. 2016.12.02 20:58:06 - OpenVPN > Authenticate/Decrypt packet error: bad packet ID (may be a replay): [ #9754 ] -- see the man page entry for --no-replay and --replay-window for more info or silence this warning with --mute-replay-warnings. 2016.12.02 20:58:06 - OpenVPN > Authenticate/Decrypt packet error: bad packet ID (may be a replay): [ #9755 ] -- see the man page entry for --no-replay and --replay-window for more info or silence this warning with --mute-replay-warnings. 2016.12.02 20:58:06 - OpenVPN > Authenticate/Decrypt packet error: bad packet ID (may be a replay): [ #9754 ] -- see the man page entry for --no-replay and --replay-window for more info or silence this warning with --mute-replay-warnings. 2016.12.02 20:58:06 - OpenVPN > Authenticate/Decrypt packet error: bad packet ID (may be a replay): [ #9755 ] -- see the man page entry for --no-replay and --replay-window for more info or silence this warning with --mute-replay-warnings. 2016.12.02 20:58:06 - OpenVPN > Authenticate/Decrypt packet error: bad packet ID (may be a replay): [ #9754 ] -- see the man page entry for --no-replay and --replay-window for more info or silence this warning with --mute-replay-warnings. 2016.12.02 20:58:06 - OpenVPN > Authenticate/Decrypt packet error: bad packet ID (may be a replay): [ #9755 ] -- see the man page entry for --no-replay and --replay-window for more info or silence this warning with --mute-replay-warnings. 2016.12.02 20:58:06 - OpenVPN > Authenticate/Decrypt packet error: bad packet ID (may be a replay): [ #9754 ] -- see the man page entry for --no-replay and --replay-window for more info or silence this warning with --mute-replay-warnings. 2016.12.02 20:58:06 - OpenVPN > Authenticate/Decrypt packet error: bad packet ID (may be a replay): [ #9755 ] -- see the man page entry for --no-replay and --replay-window for more info or silence this warning with --mute-replay-warnings. 2016.12.02 20:58:06 - OpenVPN > Authenticate/Decrypt packet error: bad packet ID (may be a replay): [ #9761 ] -- see the man page entry for --no-replay and --replay-window for more info or silence this warning with --mute-replay-warnings. 2016.12.02 20:58:06 - OpenVPN > Authenticate/Decrypt packet error: bad packet ID (may be a replay): [ #9762 ] -- see the man page entry for --no-replay and --replay-window for more info or silence this warning with --mute-replay-warnings. 2016.12.02 20:58:06 - OpenVPN > Authenticate/Decrypt packet error: bad packet ID (may be a replay): [ #9761 ] -- see the man page entry for --no-replay and --replay-window for more info or silence this warning with --mute-replay-warnings. 2016.12.02 20:58:06 - OpenVPN > Authenticate/Decrypt packet error: bad packet ID (may be a replay): [ #9762 ] -- see the man page entry for --no-replay and --replay-window for more info or silence this warning with --mute-replay-warnings. 2016.12.02 20:58:06 - OpenVPN > Authenticate/Decrypt packet error: bad packet ID (may be a replay): [ #9761 ] -- see the man page entry for --no-replay and --replay-window for more info or silence this warning with --mute-replay-warnings. 2016.12.02 20:58:06 - OpenVPN > Authenticate/Decrypt packet error: bad packet ID (may be a replay): [ #9762 ] -- see the man page entry for --no-replay and --replay-window for more info or silence this warning with --mute-replay-warnings. 2016.12.02 20:58:06 - OpenVPN > Authenticate/Decrypt packet error: bad packet ID (may be a replay): [ #9761 ] -- see the man page entry for --no-replay and --replay-window for more info or silence this warning with --mute-replay-warnings. 2016.12.02 20:58:06 - OpenVPN > Authenticate/Decrypt packet error: bad packet ID (may be a replay): [ #9762 ] -- see the man page entry for --no-replay and --replay-window for more info or silence this warning with --mute-replay-warnings. 2016.12.02 20:58:06 - OpenVPN > Authenticate/Decrypt packet error: bad packet ID (may be a replay): [ #9761 ] -- see the man page entry for --no-replay and --replay-window for more info or silence this warning with --mute-replay-warnings. 2016.12.02 20:58:06 - OpenVPN > Authenticate/Decrypt packet error: bad packet ID (may be a replay): [ #9762 ] -- see the man page entry for --no-replay and --replay-window for more info or silence this warning with --mute-replay-warnings. 2016.12.02 20:58:06 - OpenVPN > Authenticate/Decrypt packet error: bad packet ID (may be a replay): [ #9763 ] -- see the man page entry for --no-replay and --replay-window for more info or silence this warning with --mute-replay-warnings. 2016.12.02 20:58:06 - OpenVPN > Authenticate/Decrypt packet error: bad packet ID (may be a replay): [ #9765 ] -- see the man page entry for --no-replay and --replay-window for more info or silence this warning with --mute-replay-warnings. 2016.12.02 20:58:06 - OpenVPN > Authenticate/Decrypt packet error: bad packet ID (may be a replay): [ #9766 ] -- see the man page entry for --no-replay and --replay-window for more info or silence this warning with --mute-replay-warnings. 2016.12.02 20:58:06 - OpenVPN > Authenticate/Decrypt packet error: bad packet ID (may be a replay): [ #9763 ] -- see the man page entry for --no-replay and --replay-window for more info or silence this warning with --mute-replay-warnings. 2016.12.02 20:58:06 - OpenVPN > Authenticate/Decrypt packet error: bad packet ID (may be a replay): [ #9765 ] -- see the man page entry for --no-replay and --replay-window for more info or silence this warning with --mute-replay-warnings. 2016.12.02 20:58:06 - OpenVPN > Authenticate/Decrypt packet error: bad packet ID (may be a replay): [ #9766 ] -- see the man page entry for --no-replay and --replay-window for more info or silence this warning with --mute-replay-warnings. 2016.12.02 20:58:06 - OpenVPN > Authenticate/Decrypt packet error: bad packet ID (may be a replay): [ #9763 ] -- see the man page entry for --no-replay and --replay-window for more info or silence this warning with --mute-replay-warnings. 2016.12.02 20:58:06 - OpenVPN > Authenticate/Decrypt packet error: bad packet ID (may be a replay): [ #9765 ] -- see the man page entry for --no-replay and --replay-window for more info or silence this warning with --mute-replay-warnings. 2016.12.02 20:58:06 - OpenVPN > Authenticate/Decrypt packet error: bad packet ID (may be a replay): [ #9766 ] -- see the man page entry for --no-replay and --replay-window for more info or silence this warning with --mute-replay-warnings. 2016.12.02 20:58:06 - OpenVPN > Authenticate/Decrypt packet error: bad packet ID (may be a replay): [ #9763 ] -- see the man page entry for --no-replay and --replay-window for more info or silence this warning with --mute-replay-warnings. 2016.12.02 20:58:06 - OpenVPN > Authenticate/Decrypt packet error: bad packet ID (may be a replay): [ #9765 ] -- see the man page entry for --no-replay and --replay-window for more info or silence this warning with --mute-replay-warnings. 2016.12.02 20:58:06 - OpenVPN > Authenticate/Decrypt packet error: bad packet ID (may be a replay): [ #9766 ] -- see the man page entry for --no-replay and --replay-window for more info or silence this warning with --mute-replay-warnings. 2016.12.02 21:00:19 - OpenVPN > Authenticate/Decrypt packet error: bad packet ID (may be a replay): [ #14443 ] -- see the man page entry for --no-replay and --replay-window for more info or silence this warning with --mute-replay-warnings. 2016.12.02 21:00:19 - OpenVPN > Authenticate/Decrypt packet error: bad packet ID (may be a replay): [ #14444 ] -- see the man page entry for --no-replay and --replay-window for more info or silence this warning with --mute-replay-warnings. 2016.12.02 21:00:19 - OpenVPN > Authenticate/Decrypt packet error: bad packet ID (may be a replay): [ #14443 ] -- see the man page entry for --no-replay and --replay-window for more info or silence this warning with --mute-replay-warnings. 2016.12.02 21:00:19 - OpenVPN > Authenticate/Decrypt packet error: bad packet ID (may be a replay): [ #14444 ] -- see the man page entry for --no-replay and --replay-window for more info or silence this warning with --mute-replay-warnings. 2016.12.02 21:00:19 - OpenVPN > Authenticate/Decrypt packet error: bad packet ID (may be a replay): [ #14443 ] -- see the man page entry for --no-replay and --replay-window for more info or silence this warning with --mute-replay-warnings. 2016.12.02 21:00:19 - OpenVPN > Authenticate/Decrypt packet error: bad packet ID (may be a replay): [ #14444 ] -- see the man page entry for --no-replay and --replay-window for more info or silence this warning with --mute-replay-warnings. 2016.12.02 21:00:19 - OpenVPN > Authenticate/Decrypt packet error: bad packet ID (may be a replay): [ #14443 ] -- see the man page entry for --no-replay and --replay-window for more info or silence this warning with --mute-replay-warnings. 2016.12.02 21:00:19 - OpenVPN > Authenticate/Decrypt packet error: bad packet ID (may be a replay): [ #14444 ] -- see the man page entry for --no-replay and --replay-window for more info or silence this warning with --mute-replay-warnings. 2016.12.02 21:00:19 - OpenVPN > Authenticate/Decrypt packet error: bad packet ID (may be a replay): [ #14443 ] -- see the man page entry for --no-replay and --replay-window for more info or silence this warning with --mute-replay-warnings. 2016.12.02 21:00:19 - OpenVPN > Authenticate/Decrypt packet error: bad packet ID (may be a replay): [ #14444 ] -- see the man page entry for --no-replay and --replay-window for more info or silence this warning with --mute-replay-warnings. 2016.12.02 21:00:32 - OpenVPN > Authenticate/Decrypt packet error: bad packet ID (may be a replay): [ #15918 ] -- see the man page entry for --no-replay and --replay-window for more info or silence this warning with --mute-replay-warnings. 2016.12.02 21:00:32 - OpenVPN > Authenticate/Decrypt packet error: bad packet ID (may be a replay): [ #15917 ] -- see the man page entry for --no-replay and --replay-window for more info or silence this warning with --mute-replay-warnings. 2016.12.02 21:00:32 - OpenVPN > Authenticate/Decrypt packet error: bad packet ID (may be a replay): [ #15918 ] -- see the man page entry for --no-replay and --replay-window for more info or silence this warning with --mute-replay-warnings. 2016.12.02 21:00:32 - OpenVPN > Authenticate/Decrypt packet error: bad packet ID (may be a replay): [ #15917 ] -- see the man page entry for --no-replay and --replay-window for more info or silence this warning with --mute-replay-warnings. 2016.12.02 21:00:32 - OpenVPN > Authenticate/Decrypt packet error: bad packet ID (may be a replay): [ #15918 ] -- see the man page entry for --no-replay and --replay-window for more info or silence this warning with --mute-replay-warnings. 2016.12.02 21:00:32 - OpenVPN > Authenticate/Decrypt packet error: bad packet ID (may be a replay): [ #15917 ] -- see the man page entry for --no-replay and --replay-window for more info or silence this warning with --mute-replay-warnings. 2016.12.02 21:01:19 - OpenVPN > Authenticate/Decrypt packet error: bad packet ID (may be a replay): [ #16215 ] -- see the man page entry for --no-replay and --replay-window for more info or silence this warning with --mute-replay-warnings. 2016.12.02 21:01:19 - OpenVPN > Authenticate/Decrypt packet error: bad packet ID (may be a replay): [ #16217 ] -- see the man page entry for --no-replay and --replay-window for more info or silence this warning with --mute-replay-warnings. 2016.12.02 21:01:19 - OpenVPN > Authenticate/Decrypt packet error: bad packet ID (may be a replay): [ #16215 ] -- see the man page entry for --no-replay and --replay-window for more info or silence this warning with --mute-replay-warnings. 2016.12.02 21:01:19 - OpenVPN > Authenticate/Decrypt packet error: bad packet ID (may be a replay): [ #16217 ] -- see the man page entry for --no-replay and --replay-window for more info or silence this warning with --mute-replay-warnings. 2016.12.02 21:01:19 - OpenVPN > Authenticate/Decrypt packet error: bad packet ID (may be a replay): [ #16215 ] -- see the man page entry for --no-replay and --replay-window for more info or silence this warning with --mute-replay-warnings. 2016.12.02 21:01:19 - OpenVPN > Authenticate/Decrypt packet error: bad packet ID (may be a replay): [ #16217 ] -- see the man page entry for --no-replay and --replay-window for more info or silence this warning with --mute-replay-warnings. 2016.12.02 21:01:19 - OpenVPN > Authenticate/Decrypt packet error: bad packet ID (may be a replay): [ #16215 ] -- see the man page entry for --no-replay and --replay-window for more info or silence this warning with --mute-replay-warnings. 2016.12.02 21:01:19 - OpenVPN > Authenticate/Decrypt packet error: bad packet ID (may be a replay): [ #16217 ] -- see the man page entry for --no-replay and --replay-window for more info or silence this warning with --mute-replay-warnings. 2016.12.02 21:01:19 - OpenVPN > Authenticate/Decrypt packet error: bad packet ID (may be a replay): [ #16215 ] -- see the man page entry for --no-replay and --replay-window for more info or silence this warning with --mute-replay-warnings. 2016.12.02 21:01:19 - OpenVPN > Authenticate/Decrypt packet error: bad packet ID (may be a replay): [ #16217 ] -- see the man page entry for --no-replay and --replay-window for more info or silence this warning with --mute-replay-warnings. 2016.12.02 21:01:29 - Updating systems & servers data .... 2016.12.02 21:01:31 - Systems & servers data update completed. 2016.12.02 21:01:55 - OpenVPN > Authenticate/Decrypt packet error: bad packet ID (may be a replay): [ #18146 ] -- see the man page entry for --no-replay and --replay-window for more info or silence this warning with --mute-replay-warnings. 2016.12.02 21:01:55 - OpenVPN > Authenticate/Decrypt packet error: bad packet ID (may be a replay): [ #18147 ] -- see the man page entry for --no-replay and --replay-window for more info or silence this warning with --mute-replay-warnings. 2016.12.02 21:01:55 - OpenVPN > Authenticate/Decrypt packet error: bad packet ID (may be a replay): [ #18148 ] -- see the man page entry for --no-replay and --replay-window for more info or silence this warning with --mute-replay-warnings. 2016.12.02 21:01:55 - OpenVPN > Authenticate/Decrypt packet error: bad packet ID (may be a replay): [ #18146 ] -- see the man page entry for --no-replay and --replay-window for more info or silence this warning with --mute-replay-warnings. 2016.12.02 21:01:55 - OpenVPN > Authenticate/Decrypt packet error: bad packet ID (may be a replay): [ #18147 ] -- see the man page entry for --no-replay and --replay-window for more info or silence this warning with --mute-replay-warnings. 2016.12.02 21:01:55 - OpenVPN > Authenticate/Decrypt packet error: bad packet ID (may be a replay): [ #18146 ] -- see the man page entry for --no-replay and --replay-window for more info or silence this warning with --mute-replay-warnings. 2016.12.02 21:01:55 - OpenVPN > Authenticate/Decrypt packet error: bad packet ID (may be a replay): [ #18147 ] -- see the man page entry for --no-replay and --replay-window for more info or silence this warning with --mute-replay-warnings. 2016.12.02 21:01:55 - OpenVPN > Authenticate/Decrypt packet error: bad packet ID (may be a replay): [ #18148 ] -- see the man page entry for --no-replay and --replay-window for more info or silence this warning with --mute-replay-warnings. 2016.12.02 21:01:55 - OpenVPN > Authenticate/Decrypt packet error: bad packet ID (may be a replay): [ #18146 ] -- see the man page entry for --no-replay and --replay-window for more info or silence this warning with --mute-replay-warnings. 2016.12.02 21:01:55 - OpenVPN > Authenticate/Decrypt packet error: bad packet ID (may be a replay): [ #18147 ] -- see the man page entry for --no-replay and --replay-window for more info or silence this warning with --mute-replay-warnings. 2016.12.02 21:01:55 - OpenVPN > Authenticate/Decrypt packet error: bad packet ID (may be a replay): [ #18148 ] -- see the man page entry for --no-replay and --replay-window for more info or silence this warning with --mute-replay-warnings. 2016.12.02 21:01:55 - OpenVPN > Authenticate/Decrypt packet error: bad packet ID (may be a replay): [ #18146 ] -- see the man page entry for --no-replay and --replay-window for more info or silence this warning with --mute-replay-warnings. 2016.12.02 21:01:55 - OpenVPN > Authenticate/Decrypt packet error: bad packet ID (may be a replay): [ #18147 ] -- see the man page entry for --no-replay and --replay-window for more info or silence this warning with --mute-replay-warnings. 2016.12.02 21:01:55 - OpenVPN > Authenticate/Decrypt packet error: bad packet ID (may be a replay): [ #18148 ] -- see the man page entry for --no-replay and --replay-window for more info or silence this warning with --mute-replay-warnings. 2016.12.02 21:04:59 - OpenVPN > Authenticate/Decrypt packet error: bad packet ID (may be a replay): [ #18467 ] -- see the man page entry for --no-replay and --replay-window for more info or silence this warning with --mute-replay-warnings. 2016.12.02 21:04:59 - OpenVPN > Authenticate/Decrypt packet error: bad packet ID (may be a replay): [ #18468 ] -- see the man page entry for --no-replay and --replay-window for more info or silence this warning with --mute-replay-warnings. 2016.12.02 21:04:59 - OpenVPN > Authenticate/Decrypt packet error: bad packet ID (may be a replay): [ #18467 ] -- see the man page entry for --no-replay and --replay-window for more info or silence this warning with --mute-replay-warnings. 2016.12.02 21:04:59 - OpenVPN > Authenticate/Decrypt packet error: bad packet ID (may be a replay): [ #18468 ] -- see the man page entry for --no-replay and --replay-window for more info or silence this warning with --mute-replay-warnings. 2016.12.02 21:04:59 - OpenVPN > Authenticate/Decrypt packet error: bad packet ID (may be a replay): [ #18467 ] -- see the man page entry for --no-replay and --replay-window for more info or silence this warning with --mute-replay-warnings. 2016.12.02 21:04:59 - OpenVPN > Authenticate/Decrypt packet error: bad packet ID (may be a replay): [ #18468 ] -- see the man page entry for --no-replay and --replay-window for more info or silence this warning with --mute-replay-warnings. 2016.12.02 21:04:59 - OpenVPN > Authenticate/Decrypt packet error: bad packet ID (may be a replay): [ #18467 ] -- see the man page entry for --no-replay and --replay-window for more info or silence this warning with --mute-replay-warnings. 2016.12.02 21:04:59 - OpenVPN > Authenticate/Decrypt packet error: bad packet ID (may be a replay): [ #18468 ] -- see the man page entry for --no-replay and --replay-window for more info or silence this warning with --mute-replay-warnings. 2016.12.02 21:04:59 - OpenVPN > Authenticate/Decrypt packet error: bad packet ID (may be a replay): [ #18467 ] -- see the man page entry for --no-replay and --replay-window for more info or silence this warning with --mute-replay-warnings. 2016.12.02 21:04:59 - OpenVPN > Authenticate/Decrypt packet error: bad packet ID (may be a replay): [ #18468 ] -- see the man page entry for --no-replay and --replay-window for more info or silence this warning with --mute-replay-warnings. 2016.12.02 21:06:29 - OpenVPN > Authenticate/Decrypt packet error: bad packet ID (may be a replay): [ #19459 ] -- see the man page entry for --no-replay and --replay-window for more info or silence this warning with --mute-replay-warnings. 2016.12.02 21:06:29 - OpenVPN > Authenticate/Decrypt packet error: bad packet ID (may be a replay): [ #19460 ] -- see the man page entry for --no-replay and --replay-window for more info or silence this warning with --mute-replay-warnings. 2016.12.02 21:06:29 - OpenVPN > Authenticate/Decrypt packet error: bad packet ID (may be a replay): [ #19459 ] -- see the man page entry for --no-replay and --replay-window for more info or silence this warning with --mute-replay-warnings. 2016.12.02 21:06:29 - OpenVPN > Authenticate/Decrypt packet error: bad packet ID (may be a replay): [ #19460 ] -- see the man page entry for --no-replay and --replay-window for more info or silence this warning with --mute-replay-warnings. 2016.12.02 21:06:29 - OpenVPN > Authenticate/Decrypt packet error: bad packet ID (may be a replay): [ #19459 ] -- see the man page entry for --no-replay and --replay-window for more info or silence this warning with --mute-replay-warnings. 2016.12.02 21:06:29 - OpenVPN > Authenticate/Decrypt packet error: bad packet ID (may be a replay): [ #19460 ] -- see the man page entry for --no-replay and --replay-window for more info or silence this warning with --mute-replay-warnings. 2016.12.02 21:06:29 - OpenVPN > Authenticate/Decrypt packet error: bad packet ID (may be a replay): [ #19459 ] -- see the man page entry for --no-replay and --replay-window for more info or silence this warning with --mute-replay-warnings. 2016.12.02 21:06:29 - OpenVPN > Authenticate/Decrypt packet error: bad packet ID (may be a replay): [ #19460 ] -- see the man page entry for --no-replay and --replay-window for more info or silence this warning with --mute-replay-warnings. 2016.12.02 21:06:29 - OpenVPN > Authenticate/Decrypt packet error: bad packet ID (may be a replay): [ #19459 ] -- see the man page entry for --no-replay and --replay-window for more info or silence this warning with --mute-replay-warnings. 2016.12.02 21:06:29 - OpenVPN > Authenticate/Decrypt packet error: bad packet ID (may be a replay): [ #19460 ] -- see the man page entry for --no-replay and --replay-window for more info or silence this warning with --mute-replay-warnings. 2016.12.02 21:06:29 - OpenVPN > Authenticate/Decrypt packet error: bad packet ID (may be a replay): [ #19461 ] -- see the man page entry for --no-replay and --replay-window for more info or silence this warning with --mute-replay-warnings. 2016.12.02 21:06:29 - OpenVPN > Authenticate/Decrypt packet error: bad packet ID (may be a replay): [ #19462 ] -- see the man page entry for --no-replay and --replay-window for more info or silence this warning with --mute-replay-warnings. 2016.12.02 21:06:29 - OpenVPN > Authenticate/Decrypt packet error: bad packet ID (may be a replay): [ #19463 ] -- see the man page entry for --no-replay and --replay-window for more info or silence this warning with --mute-replay-warnings. 2016.12.02 21:06:29 - OpenVPN > Authenticate/Decrypt packet error: bad packet ID (may be a replay): [ #19464 ] -- see the man page entry for --no-replay and --replay-window for more info or silence this warning with --mute-replay-warnings. 2016.12.02 21:06:29 - OpenVPN > Authenticate/Decrypt packet error: bad packet ID (may be a replay): [ #19465 ] -- see the man page entry for --no-replay and --replay-window for more info or silence this warning with --mute-replay-warnings. 2016.12.02 21:06:29 - OpenVPN > Authenticate/Decrypt packet error: bad packet ID (may be a replay): [ #19461 ] -- see the man page entry for --no-replay and --replay-window for more info or silence this warning with --mute-replay-warnings. 2016.12.02 21:06:29 - OpenVPN > Authenticate/Decrypt packet error: bad packet ID (may be a replay): [ #19462 ] -- see the man page entry for --no-replay and --replay-window for more info or silence this warning with --mute-replay-warnings. 2016.12.02 21:06:29 - OpenVPN > Authenticate/Decrypt packet error: bad packet ID (may be a replay): [ #19463 ] -- see the man page entry for --no-replay and --replay-window for more info or silence this warning with --mute-replay-warnings. 2016.12.02 21:06:29 - OpenVPN > Authenticate/Decrypt packet error: bad packet ID (may be a replay): [ #19464 ] -- see the man page entry for --no-replay and --replay-window for more info or silence this warning with --mute-replay-warnings. 2016.12.02 21:06:29 - OpenVPN > Authenticate/Decrypt packet error: bad packet ID (may be a replay): [ #19465 ] -- see the man page entry for --no-replay and --replay-window for more info or silence this warning with --mute-replay-warnings. 2016.12.02 21:06:29 - OpenVPN > Authenticate/Decrypt packet error: bad packet ID (may be a replay): [ #19461 ] -- see the man page entry for --no-replay and --replay-window for more info or silence this warning with --mute-replay-warnings. 2016.12.02 21:06:29 - OpenVPN > Authenticate/Decrypt packet error: bad packet ID (may be a replay): [ #19462 ] -- see the man page entry for --no-replay and --replay-window for more info or silence this warning with --mute-replay-warnings. 2016.12.02 21:06:29 - OpenVPN > Authenticate/Decrypt packet error: bad packet ID (may be a replay): [ #19463 ] -- see the man page entry for --no-replay and --replay-window for more info or silence this warning with --mute-replay-warnings. 2016.12.02 21:06:29 - OpenVPN > Authenticate/Decrypt packet error: bad packet ID (may be a replay): [ #19464 ] -- see the man page entry for --no-replay and --replay-window for more info or silence this warning with --mute-replay-warnings. 2016.12.02 21:06:29 - OpenVPN > Authenticate/Decrypt packet error: bad packet ID (may be a replay): [ #19465 ] -- see the man page entry for --no-replay and --replay-window for more info or silence this warning with --mute-replay-warnings. 2016.12.02 21:08:25 - OpenVPN > Authenticate/Decrypt packet error: bad packet ID (may be a replay): [ #23418 ] -- see the man page entry for --no-replay and --replay-window for more info or silence this warning with --mute-replay-warnings. 2016.12.02 21:08:25 - OpenVPN > Authenticate/Decrypt packet error: bad packet ID (may be a replay): [ #23419 ] -- see the man page entry for --no-replay and --replay-window for more info or silence this warning with --mute-replay-warnings. 2016.12.02 21:08:25 - OpenVPN > Authenticate/Decrypt packet error: bad packet ID (may be a replay): [ #23418 ] -- see the man page entry for --no-replay and --replay-window for more info or silence this warning with --mute-replay-warnings. 2016.12.02 21:08:25 - OpenVPN > Authenticate/Decrypt packet error: bad packet ID (may be a replay): [ #23419 ] -- see the man page entry for --no-replay and --replay-window for more info or silence this warning with --mute-replay-warnings. 2016.12.02 21:08:25 - OpenVPN > Authenticate/Decrypt packet error: bad packet ID (may be a replay): [ #23418 ] -- see the man page entry for --no-replay and --replay-window for more info or silence this warning with --mute-replay-warnings. 2016.12.02 21:08:25 - OpenVPN > Authenticate/Decrypt packet error: bad packet ID (may be a replay): [ #23419 ] -- see the man page entry for --no-replay and --replay-window for more info or silence this warning with --mute-replay-warnings. 2016.12.02 21:08:25 - OpenVPN > Authenticate/Decrypt packet error: bad packet ID (may be a replay): [ #23418 ] -- see the man page entry for --no-replay and --replay-window for more info or silence this warning with --mute-replay-warnings. 2016.12.02 21:08:25 - OpenVPN > Authenticate/Decrypt packet error: bad packet ID (may be a replay): [ #23419 ] -- see the man page entry for --no-replay and --replay-window for more info or silence this warning with --mute-replay-warnings. 2016.12.02 21:08:25 - OpenVPN > Authenticate/Decrypt packet error: bad packet ID (may be a replay): [ #23420 ] -- see the man page entry for --no-replay and --replay-window for more info or silence this warning with --mute-replay-warnings. 2016.12.02 21:08:25 - OpenVPN > Authenticate/Decrypt packet error: bad packet ID (may be a replay): [ #23421 ] -- see the man page entry for --no-replay and --replay-window for more info or silence this warning with --mute-replay-warnings. 2016.12.02 21:08:25 - OpenVPN > Authenticate/Decrypt packet error: bad packet ID (may be a replay): [ #23422 ] -- see the man page entry for --no-replay and --replay-window for more info or silence this warning with --mute-replay-warnings. 2016.12.02 21:08:25 - OpenVPN > Authenticate/Decrypt packet error: bad packet ID (may be a replay): [ #23423 ] -- see the man page entry for --no-replay and --replay-window for more info or silence this warning with --mute-replay-warnings. 2016.12.02 21:08:25 - OpenVPN > Authenticate/Decrypt packet error: bad packet ID (may be a replay): [ #23424 ] -- see the man page entry for --no-replay and --replay-window for more info or silence this warning with --mute-replay-warnings. 2016.12.02 21:08:25 - OpenVPN > Authenticate/Decrypt packet error: bad packet ID (may be a replay): [ #23425 ] -- see the man page entry for --no-replay and --replay-window for more info or silence this warning with --mute-replay-warnings. 2016.12.02 21:08:25 - OpenVPN > Authenticate/Decrypt packet error: bad packet ID (may be a replay): [ #23426 ] -- see the man page entry for --no-replay and --replay-window for more info or silence this warning with --mute-replay-warnings. 2016.12.02 21:08:25 - OpenVPN > Authenticate/Decrypt packet error: bad packet ID (may be a replay): [ #23420 ] -- see the man page entry for --no-replay and --replay-window for more info or silence this warning with --mute-replay-warnings. 2016.12.02 21:08:25 - OpenVPN > Authenticate/Decrypt packet error: bad packet ID (may be a replay): [ #23421 ] -- see the man page entry for --no-replay and --replay-window for more info or silence this warning with --mute-replay-warnings. 2016.12.02 21:08:25 - OpenVPN > Authenticate/Decrypt packet error: bad packet ID (may be a replay): [ #23422 ] -- see the man page entry for --no-replay and --replay-window for more info or silence this warning with --mute-replay-warnings. 2016.12.02 21:08:25 - OpenVPN > Authenticate/Decrypt packet error: bad packet ID (may be a replay): [ #23423 ] -- see the man page entry for --no-replay and --replay-window for more info or silence this warning with --mute-replay-warnings. 2016.12.02 21:08:25 - OpenVPN > Authenticate/Decrypt packet error: bad packet ID (may be a replay): [ #23424 ] -- see the man page entry for --no-replay and --replay-window for more info or silence this warning with --mute-replay-warnings. 2016.12.02 21:08:25 - OpenVPN > Authenticate/Decrypt packet error: bad packet ID (may be a replay): [ #23425 ] -- see the man page entry for --no-replay and --replay-window for more info or silence this warning with --mute-replay-warnings. 2016.12.02 21:08:25 - OpenVPN > Authenticate/Decrypt packet error: bad packet ID (may be a replay): [ #23426 ] -- see the man page entry for --no-replay and --replay-window for more info or silence this warning with --mute-replay-warnings. 2016.12.02 21:08:25 - OpenVPN > Authenticate/Decrypt packet error: bad packet ID (may be a replay): [ #23420 ] -- see the man page entry for --no-replay and --replay-window for more info or silence this warning with --mute-replay-warnings. 2016.12.02 21:08:25 - OpenVPN > Authenticate/Decrypt packet error: bad packet ID (may be a replay): [ #23421 ] -- see the man page entry for --no-replay and --replay-window for more info or silence this warning with --mute-replay-warnings. 2016.12.02 21:08:25 - OpenVPN > Authenticate/Decrypt packet error: bad packet ID (may be a replay): [ #23422 ] -- see the man page entry for --no-replay and --replay-window for more info or silence this warning with --mute-replay-warnings. 2016.12.02 21:08:25 - OpenVPN > Authenticate/Decrypt packet error: bad packet ID (may be a replay): [ #23423 ] -- see the man page entry for --no-replay and --replay-window for more info or silence this warning with --mute-replay-warnings. 2016.12.02 21:08:25 - OpenVPN > Authenticate/Decrypt packet error: bad packet ID (may be a replay): [ #23424 ] -- see the man page entry for --no-replay and --replay-window for more info or silence this warning with --mute-replay-warnings. 2016.12.02 21:08:25 - OpenVPN > Authenticate/Decrypt packet error: bad packet ID (may be a replay): [ #23425 ] -- see the man page entry for --no-replay and --replay-window for more info or silence this warning with --mute-replay-warnings. 2016.12.02 21:08:25 - OpenVPN > Authenticate/Decrypt packet error: bad packet ID (may be a replay): [ #23426 ] -- see the man page entry for --no-replay and --replay-window for more info or silence this warning with --mute-replay-warnings. 2016.12.02 21:08:25 - OpenVPN > Authenticate/Decrypt packet error: bad packet ID (may be a replay): [ #23420 ] -- see the man page entry for --no-replay and --replay-window for more info or silence this warning with --mute-replay-warnings. 2016.12.02 21:08:25 - OpenVPN > Authenticate/Decrypt packet error: bad packet ID (may be a replay): [ #23421 ] -- see the man page entry for --no-replay and --replay-window for more info or silence this warning with --mute-replay-warnings. 2016.12.02 21:08:25 - OpenVPN > Authenticate/Decrypt packet error: bad packet ID (may be a replay): [ #23422 ] -- see the man page entry for --no-replay and --replay-window for more info or silence this warning with --mute-replay-warnings. 2016.12.02 21:08:25 - OpenVPN > Authenticate/Decrypt packet error: bad packet ID (may be a replay): [ #23420 ] -- see the man page entry for --no-replay and --replay-window for more info or silence this warning with --mute-replay-warnings. 2016.12.02 21:08:25 - OpenVPN > Authenticate/Decrypt packet error: bad packet ID (may be a replay): [ #23421 ] -- see the man page entry for --no-replay and --replay-window for more info or silence this warning with --mute-replay-warnings. 2016.12.02 21:08:25 - OpenVPN > Authenticate/Decrypt packet error: bad packet ID (may be a replay): [ #23422 ] -- see the man page entry for --no-replay and --replay-window for more info or silence this warning with --mute-replay-warnings. 2016.12.02 21:08:25 - OpenVPN > Authenticate/Decrypt packet error: bad packet ID (may be a replay): [ #23423 ] -- see the man page entry for --no-replay and --replay-window for more info or silence this warning with --mute-replay-warnings. 2016.12.02 21:08:25 - OpenVPN > Authenticate/Decrypt packet error: bad packet ID (may be a replay): [ #23424 ] -- see the man page entry for --no-replay and --replay-window for more info or silence this warning with --mute-replay-warnings. 2016.12.02 21:08:25 - OpenVPN > Authenticate/Decrypt packet error: bad packet ID (may be a replay): [ #23425 ] -- see the man page entry for --no-replay and --replay-window for more info or silence this warning with --mute-replay-warnings. 2016.12.02 21:08:25 - OpenVPN > Authenticate/Decrypt packet error: bad packet ID (may be a replay): [ #23426 ] -- see the man page entry for --no-replay and --replay-window for more info or silence this warning with --mute-replay-warnings. 2016.12.02 21:10:00 - OpenVPN > Authenticate/Decrypt packet error: bad packet ID (may be a replay): [ #27296 ] -- see the man page entry for --no-replay and --replay-window for more info or silence this warning with --mute-replay-warnings. 2016.12.02 21:10:00 - OpenVPN > Authenticate/Decrypt packet error: bad packet ID (may be a replay): [ #27297 ] -- see the man page entry for --no-replay and --replay-window for more info or silence this warning with --mute-replay-warnings. 2016.12.02 21:10:00 - OpenVPN > Authenticate/Decrypt packet error: bad packet ID (may be a replay): [ #27296 ] -- see the man page entry for --no-replay and --replay-window for more info or silence this warning with --mute-replay-warnings. 2016.12.02 21:10:00 - OpenVPN > Authenticate/Decrypt packet error: bad packet ID (may be a replay): [ #27297 ] -- see the man page entry for --no-replay and --replay-window for more info or silence this warning with --mute-replay-warnings. 2016.12.02 21:10:00 - OpenVPN > Authenticate/Decrypt packet error: bad packet ID (may be a replay): [ #27296 ] -- see the man page entry for --no-replay and --replay-window for more info or silence this warning with --mute-replay-warnings. 2016.12.02 21:10:00 - OpenVPN > Authenticate/Decrypt packet error: bad packet ID (may be a replay): [ #27297 ] -- see the man page entry for --no-replay and --replay-window for more info or silence this warning with --mute-replay-warnings. 2016.12.02 21:10:00 - OpenVPN > Authenticate/Decrypt packet error: bad packet ID (may be a replay): [ #27296 ] -- see the man page entry for --no-replay and --replay-window for more info or silence this warning with --mute-replay-warnings. 2016.12.02 21:10:00 - OpenVPN > Authenticate/Decrypt packet error: bad packet ID (may be a replay): [ #27297 ] -- see the man page entry for --no-replay and --replay-window for more info or silence this warning with --mute-replay-warnings. 2016.12.02 21:10:00 - OpenVPN > Authenticate/Decrypt packet error: bad packet ID (may be a replay): [ #27296 ] -- see the man page entry for --no-replay and --replay-window for more info or silence this warning with --mute-replay-warnings. 2016.12.02 21:10:00 - OpenVPN > Authenticate/Decrypt packet error: bad packet ID (may be a replay): [ #27297 ] -- see the man page entry for --no-replay and --replay-window for more info or silence this warning with --mute-replay-warnings. 2016.12.02 21:10:00 - OpenVPN > Authenticate/Decrypt packet error: bad packet ID (may be a replay): [ #27325 ] -- see the man page entry for --no-replay and --replay-window for more info or silence this warning with --mute-replay-warnings. 2016.12.02 21:10:00 - OpenVPN > Authenticate/Decrypt packet error: bad packet ID (may be a replay): [ #27326 ] -- see the man page entry for --no-replay and --replay-window for more info or silence this warning with --mute-replay-warnings. 2016.12.02 21:10:00 - OpenVPN > Authenticate/Decrypt packet error: bad packet ID (may be a replay): [ #27325 ] -- see the man page entry for --no-replay and --replay-window for more info or silence this warning with --mute-replay-warnings. 2016.12.02 21:10:00 - OpenVPN > Authenticate/Decrypt packet error: bad packet ID (may be a replay): [ #27326 ] -- see the man page entry for --no-replay and --replay-window for more info or silence this warning with --mute-replay-warnings. 2016.12.02 21:10:00 - OpenVPN > Authenticate/Decrypt packet error: bad packet ID (may be a replay): [ #27325 ] -- see the man page entry for --no-replay and --replay-window for more info or silence this warning with --mute-replay-warnings. 2016.12.02 21:10:00 - OpenVPN > Authenticate/Decrypt packet error: bad packet ID (may be a replay): [ #27326 ] -- see the man page entry for --no-replay and --replay-window for more info or silence this warning with --mute-replay-warnings. 2016.12.02 21:10:00 - OpenVPN > Authenticate/Decrypt packet error: bad packet ID (may be a replay): [ #27325 ] -- see the man page entry for --no-replay and --replay-window for more info or silence this warning with --mute-replay-warnings. 2016.12.02 21:10:00 - OpenVPN > Authenticate/Decrypt packet error: bad packet ID (may be a replay): [ #27326 ] -- see the man page entry for --no-replay and --replay-window for more info or silence this warning with --mute-replay-warnings. 2016.12.02 21:10:02 - OpenVPN > Authenticate/Decrypt packet error: bad packet ID (may be a replay): [ #27574 ] -- see the man page entry for --no-replay and --replay-window for more info or silence this warning with --mute-replay-warnings. 2016.12.02 21:10:02 - OpenVPN > Authenticate/Decrypt packet error: bad packet ID (may be a replay): [ #27575 ] -- see the man page entry for --no-replay and --replay-window for more info or silence this warning with --mute-replay-warnings. 2016.12.02 21:10:02 - OpenVPN > Authenticate/Decrypt packet error: bad packet ID (may be a replay): [ #27574 ] -- see the man page entry for --no-replay and --replay-window for more info or silence this warning with --mute-replay-warnings. 2016.12.02 21:10:02 - OpenVPN > Authenticate/Decrypt packet error: bad packet ID (may be a replay): [ #27575 ] -- see the man page entry for --no-replay and --replay-window for more info or silence this warning with --mute-replay-warnings. 2016.12.02 21:10:02 - OpenVPN > Authenticate/Decrypt packet error: bad packet ID (may be a replay): [ #27574 ] -- see the man page entry for --no-replay and --replay-window for more info or silence this warning with --mute-replay-warnings. 2016.12.02 21:10:02 - OpenVPN > Authenticate/Decrypt packet error: bad packet ID (may be a replay): [ #27575 ] -- see the man page entry for --no-replay and --replay-window for more info or silence this warning with --mute-replay-warnings. 2016.12.02 21:10:02 - OpenVPN > Authenticate/Decrypt packet error: bad packet ID (may be a replay): [ #27574 ] -- see the man page entry for --no-replay and --replay-window for more info or silence this warning with --mute-replay-warnings. 2016.12.02 21:10:02 - OpenVPN > Authenticate/Decrypt packet error: bad packet ID (may be a replay): [ #27575 ] -- see the man page entry for --no-replay and --replay-window for more info or silence this warning with --mute-replay-warnings. 2016.12.02 21:10:02 - OpenVPN > Authenticate/Decrypt packet error: bad packet ID (may be a replay): [ #27574 ] -- see the man page entry for --no-replay and --replay-window for more info or silence this warning with --mute-replay-warnings. 2016.12.02 21:10:02 - OpenVPN > Authenticate/Decrypt packet error: bad packet ID (may be a replay): [ #27575 ] -- see the man page entry for --no-replay and --replay-window for more info or silence this warning with --mute-replay-warnings. 2016.12.02 21:10:36 - OpenVPN > Authenticate/Decrypt packet error: bad packet ID (may be a replay): [ #29914 ] -- see the man page entry for --no-replay and --replay-window for more info or silence this warning with --mute-replay-warnings. 2016.12.02 21:10:36 - OpenVPN > Authenticate/Decrypt packet error: bad packet ID (may be a replay): [ #29915 ] -- see the man page entry for --no-replay and --replay-window for more info or silence this warning with --mute-replay-warnings. 2016.12.02 21:10:36 - OpenVPN > Authenticate/Decrypt packet error: bad packet ID (may be a replay): [ #29914 ] -- see the man page entry for --no-replay and --replay-window for more info or silence this warning with --mute-replay-warnings. 2016.12.02 21:10:36 - OpenVPN > Authenticate/Decrypt packet error: bad packet ID (may be a replay): [ #29915 ] -- see the man page entry for --no-replay and --replay-window for more info or silence this warning with --mute-replay-warnings. 2016.12.02 21:10:36 - OpenVPN > Authenticate/Decrypt packet error: bad packet ID (may be a replay): [ #29914 ] -- see the man page entry for --no-replay and --replay-window for more info or silence this warning with --mute-replay-warnings. 2016.12.02 21:10:36 - OpenVPN > Authenticate/Decrypt packet error: bad packet ID (may be a replay): [ #29915 ] -- see the man page entry for --no-replay and --replay-window for more info or silence this warning with --mute-replay-warnings. 2016.12.02 21:10:36 - OpenVPN > Authenticate/Decrypt packet error: bad packet ID (may be a replay): [ #29914 ] -- see the man page entry for --no-replay and --replay-window for more info or silence this warning with --mute-replay-warnings. 2016.12.02 21:10:36 - OpenVPN > Authenticate/Decrypt packet error: bad packet ID (may be a replay): [ #29915 ] -- see the man page entry for --no-replay and --replay-window for more info or silence this warning with --mute-replay-warnings. 2016.12.02 21:10:36 - OpenVPN > Authenticate/Decrypt packet error: bad packet ID (may be a replay): [ #29914 ] -- see the man page entry for --no-replay and --replay-window for more info or silence this warning with --mute-replay-warnings. 2016.12.02 21:10:36 - OpenVPN > Authenticate/Decrypt packet error: bad packet ID (may be a replay): [ #29915 ] -- see the man page entry for --no-replay and --replay-window for more info or silence this warning with --mute-replay-warnings. 2016.12.02 21:11:20 - OpenVPN > Authenticate/Decrypt packet error: bad packet ID (may be a replay): [ #30560 ] -- see the man page entry for --no-replay and --replay-window for more info or silence this warning with --mute-replay-warnings. 2016.12.02 21:11:20 - OpenVPN > Authenticate/Decrypt packet error: bad packet ID (may be a replay): [ #30561 ] -- see the man page entry for --no-replay and --replay-window for more info or silence this warning with --mute-replay-warnings. 2016.12.02 21:11:20 - OpenVPN > Authenticate/Decrypt packet error: bad packet ID (may be a replay): [ #30560 ] -- see the man page entry for --no-replay and --replay-window for more info or silence this warning with --mute-replay-warnings. 2016.12.02 21:11:20 - OpenVPN > Authenticate/Decrypt packet error: bad packet ID (may be a replay): [ #30561 ] -- see the man page entry for --no-replay and --replay-window for more info or silence this warning with --mute-replay-warnings. 2016.12.02 21:11:20 - OpenVPN > Authenticate/Decrypt packet error: bad packet ID (may be a replay): [ #30560 ] -- see the man page entry for --no-replay and --replay-window for more info or silence this warning with --mute-replay-warnings. 2016.12.02 21:11:20 - OpenVPN > Authenticate/Decrypt packet error: bad packet ID (may be a replay): [ #30561 ] -- see the man page entry for --no-replay and --replay-window for more info or silence this warning with --mute-replay-warnings. 2016.12.02 21:11:20 - OpenVPN > Authenticate/Decrypt packet error: bad packet ID (may be a replay): [ #30560 ] -- see the man page entry for --no-replay and --replay-window for more info or silence this warning with --mute-replay-warnings. 2016.12.02 21:11:20 - OpenVPN > Authenticate/Decrypt packet error: bad packet ID (may be a replay): [ #30561 ] -- see the man page entry for --no-replay and --replay-window for more info or silence this warning with --mute-replay-warnings. 2016.12.02 21:11:32 - Updating systems & servers data .... 2016.12.02 21:11:33 - Systems & servers data update completed. 2016.12.02 21:21:06 - OpenVPN > VERIFY OK: depth=1, C=IT, ST=IT, L=Perugia, O=airvpn.org, CN=airvpn.org CA, emailAddress=info@airvpn.org. 2016.12.02 21:21:06 - OpenVPN > Validating certificate key usage. 2016.12.02 21:21:06 - OpenVPN > ++ Certificate has key usage 00a0, expects 00a0. 2016.12.02 21:21:06 - OpenVPN > VERIFY KU OK. 2016.12.02 21:21:06 - OpenVPN > Validating certificate extended key usage. 2016.12.02 21:21:06 - OpenVPN > ++ Certificate has EKU (str) TLS Web Server Authentication, expects TLS Web Server Authentication. 2016.12.02 21:21:06 - OpenVPN > VERIFY EKU OK. 2016.12.02 21:21:06 - OpenVPN > VERIFY OK: depth=0, C=IT, ST=IT, L=Perugia, O=airvpn.org, CN=server, emailAddress=info@airvpn.org. 2016.12.02 21:21:10 - OpenVPN > Data Channel Encrypt: Cipher 'AES-256-CBC' initialized with 256 bit key. 2016.12.02 21:21:10 - OpenVPN > Data Channel Encrypt: Using 160 bit message hash 'SHA1' for HMAC authentication. 2016.12.02 21:21:10 - OpenVPN > Data Channel Decrypt: Cipher 'AES-256-CBC' initialized with 256 bit key. 2016.12.02 21:21:10 - OpenVPN > Data Channel Decrypt: Using 160 bit message hash 'SHA1' for HMAC authentication. 2016.12.02 21:21:10 - OpenVPN > Control Channel: TLSv1.2, cipher TLSv1/SSLv3 DHE-RSA-AES256-GCM-SHA384, 4096 bit RSA. 2016.12.02 21:21:56 - Updating systems & servers data .... 2016.12.02 21:21:57 - Systems & servers data update completed. 2016.12.02 21:32:53 - Updating systems & servers data .... 2016.12.02 21:32:57 - Systems & servers data update completed. 2016.12.02 21:37:27 - OpenVPN > Authenticate/Decrypt packet error: bad packet ID (may be a replay): [ #1199 ] -- see the man page entry for --no-replay and --replay-window for more info or silence this warning with --mute-replay-warnings. 2016.12.02 21:37:27 - OpenVPN > Authenticate/Decrypt packet error: bad packet ID (may be a replay): [ #1200 ] -- see the man page entry for --no-replay and --replay-window for more info or silence this warning with --mute-replay-warnings. 2016.12.02 21:37:27 - OpenVPN > Authenticate/Decrypt packet error: bad packet ID (may be a replay): [ #1199 ] -- see the man page entry for --no-replay and --replay-window for more info or silence this warning with --mute-replay-warnings. 2016.12.02 21:37:27 - OpenVPN > Authenticate/Decrypt packet error: bad packet ID (may be a replay): [ #1200 ] -- see the man page entry for --no-replay and --replay-window for more info or silence this warning with --mute-replay-warnings. 2016.12.02 21:37:27 - OpenVPN > Authenticate/Decrypt packet error: bad packet ID (may be a replay): [ #1199 ] -- see the man page entry for --no-replay and --replay-window for more info or silence this warning with --mute-replay-warnings. 2016.12.02 21:37:27 - OpenVPN > Authenticate/Decrypt packet error: bad packet ID (may be a replay): [ #1200 ] -- see the man page entry for --no-replay and --replay-window for more info or silence this warning with --mute-replay-warnings. 2016.12.02 21:37:27 - OpenVPN > Authenticate/Decrypt packet error: bad packet ID (may be a replay): [ #1199 ] -- see the man page entry for --no-replay and --replay-window for more info or silence this warning with --mute-replay-warnings. 2016.12.02 21:37:27 - OpenVPN > Authenticate/Decrypt packet error: bad packet ID (may be a replay): [ #1200 ] -- see the man page entry for --no-replay and --replay-window for more info or silence this warning with --mute-replay-warnings. 2016.12.02 21:37:27 - OpenVPN > Authenticate/Decrypt packet error: bad packet ID (may be a replay): [ #1199 ] -- see the man page entry for --no-replay and --replay-window for more info or silence this warning with --mute-replay-warnings. 2016.12.02 21:37:27 - OpenVPN > Authenticate/Decrypt packet error: bad packet ID (may be a replay): [ #1200 ] -- see the man page entry for --no-replay and --replay-window for more info or silence this warning with --mute-replay-warnings. 2016.12.02 21:37:36 - OpenVPN > Authenticate/Decrypt packet error: bad packet ID (may be a replay): [ #1872 ] -- see the man page entry for --no-replay and --replay-window for more info or silence this warning with --mute-replay-warnings. 2016.12.02 21:37:36 - OpenVPN > Authenticate/Decrypt packet error: bad packet ID (may be a replay): [ #1873 ] -- see the man page entry for --no-replay and --replay-window for more info or silence this warning with --mute-replay-warnings. 2016.12.02 21:37:36 - OpenVPN > Authenticate/Decrypt packet error: bad packet ID (may be a replay): [ #1874 ] -- see the man page entry for --no-replay and --replay-window for more info or silence this warning with --mute-replay-warnings. 2016.12.02 21:37:36 - OpenVPN > Authenticate/Decrypt packet error: bad packet ID (may be a replay): [ #1872 ] -- see the man page entry for --no-replay and --replay-window for more info or silence this warning with --mute-replay-warnings. 2016.12.02 21:37:36 - OpenVPN > Authenticate/Decrypt packet error: bad packet ID (may be a replay): [ #1873 ] -- see the man page entry for --no-replay and --replay-window for more info or silence this warning with --mute-replay-warnings. 2016.12.02 21:37:36 - OpenVPN > Authenticate/Decrypt packet error: bad packet ID (may be a replay): [ #1874 ] -- see the man page entry for --no-replay and --replay-window for more info or silence this warning with --mute-replay-warnings. 2016.12.02 21:37:36 - OpenVPN > Authenticate/Decrypt packet error: bad packet ID (may be a replay): [ #1872 ] -- see the man page entry for --no-replay and --replay-window for more info or silence this warning with --mute-replay-warnings. 2016.12.02 21:37:36 - OpenVPN > Authenticate/Decrypt packet error: bad packet ID (may be a replay): [ #1873 ] -- see the man page entry for --no-replay and --replay-window for more info or silence this warning with --mute-replay-warnings. 2016.12.02 21:37:36 - OpenVPN > Authenticate/Decrypt packet error: bad packet ID (may be a replay): [ #1874 ] -- see the man page entry for --no-replay and --replay-window for more info or silence this warning with --mute-replay-warnings. 2016.12.02 21:37:36 - OpenVPN > Authenticate/Decrypt packet error: bad packet ID (may be a replay): [ #1872 ] -- see the man page entry for --no-replay and --replay-window for more info or silence this warning with --mute-replay-warnings. 2016.12.02 21:37:36 - OpenVPN > Authenticate/Decrypt packet error: bad packet ID (may be a replay): [ #1873 ] -- see the man page entry for --no-replay and --replay-window for more info or silence this warning with --mute-replay-warnings. 2016.12.02 21:37:36 - OpenVPN > Authenticate/Decrypt packet error: bad packet ID (may be a replay): [ #1874 ] -- see the man page entry for --no-replay and --replay-window for more info or silence this warning with --mute-replay-warnings. 2016.12.02 21:37:36 - OpenVPN > Authenticate/Decrypt packet error: bad packet ID (may be a replay): [ #1893 ] -- see the man page entry for --no-replay and --replay-window for more info or silence this warning with --mute-replay-warnings. 2016.12.02 21:37:36 - OpenVPN > Authenticate/Decrypt packet error: bad packet ID (may be a replay): [ #1894 ] -- see the man page entry for --no-replay and --replay-window for more info or silence this warning with --mute-replay-warnings. 2016.12.02 21:37:36 - OpenVPN > Authenticate/Decrypt packet error: bad packet ID (may be a replay): [ #1893 ] -- see the man page entry for --no-replay and --replay-window for more info or silence this warning with --mute-replay-warnings. 2016.12.02 21:37:36 - OpenVPN > Authenticate/Decrypt packet error: bad packet ID (may be a replay): [ #1894 ] -- see the man page entry for --no-replay and --replay-window for more info or silence this warning with --mute-replay-warnings. 2016.12.02 21:37:36 - OpenVPN > Authenticate/Decrypt packet error: bad packet ID (may be a replay): [ #1893 ] -- see the man page entry for --no-replay and --replay-window for more info or silence this warning with --mute-replay-warnings. 2016.12.02 21:37:36 - OpenVPN > Authenticate/Decrypt packet error: bad packet ID (may be a replay): [ #1894 ] -- see the man page entry for --no-replay and --replay-window for more info or silence this warning with --mute-replay-warnings. 2016.12.02 21:37:36 - OpenVPN > Authenticate/Decrypt packet error: bad packet ID (may be a replay): [ #1893 ] -- see the man page entry for --no-replay and --replay-window for more info or silence this warning with --mute-replay-warnings. 2016.12.02 21:37:36 - OpenVPN > Authenticate/Decrypt packet error: bad packet ID (may be a replay): [ #1894 ] -- see the man page entry for --no-replay and --replay-window for more info or silence this warning with --mute-replay-warnings. 2016.12.02 21:37:36 - OpenVPN > Authenticate/Decrypt packet error: bad packet ID (may be a replay): [ #1893 ] -- see the man page entry for --no-replay and --replay-window for more info or silence this warning with --mute-replay-warnings. 2016.12.02 21:37:36 - OpenVPN > Authenticate/Decrypt packet error: bad packet ID (may be a replay): [ #1894 ] -- see the man page entry for --no-replay and --replay-window for more info or silence this warning with --mute-replay-warnings. 2016.12.02 21:38:08 - OpenVPN > Authenticate/Decrypt packet error: bad packet ID (may be a replay): [ #3440 ] -- see the man page entry for --no-replay and --replay-window for more info or silence this warning with --mute-replay-warnings. 2016.12.02 21:38:08 - OpenVPN > Authenticate/Decrypt packet error: bad packet ID (may be a replay): [ #3441 ] -- see the man page entry for --no-replay and --replay-window for more info or silence this warning with --mute-replay-warnings. 2016.12.02 21:38:08 - OpenVPN > Authenticate/Decrypt packet error: bad packet ID (may be a replay): [ #3440 ] -- see the man page entry for --no-replay and --replay-window for more info or silence this warning with --mute-replay-warnings. 2016.12.02 21:38:08 - OpenVPN > Authenticate/Decrypt packet error: bad packet ID (may be a replay): [ #3441 ] -- see the man page entry for --no-replay and --replay-window for more info or silence this warning with --mute-replay-warnings. 2016.12.02 21:38:08 - OpenVPN > Authenticate/Decrypt packet error: bad packet ID (may be a replay): [ #3440 ] -- see the man page entry for --no-replay and --replay-window for more info or silence this warning with --mute-replay-warnings. 2016.12.02 21:38:08 - OpenVPN > Authenticate/Decrypt packet error: bad packet ID (may be a replay): [ #3441 ] -- see the man page entry for --no-replay and --replay-window for more info or silence this warning with --mute-replay-warnings. 2016.12.02 21:38:08 - OpenVPN > Authenticate/Decrypt packet error: bad packet ID (may be a replay): [ #3440 ] -- see the man page entry for --no-replay and --replay-window for more info or silence this warning with --mute-replay-warnings. 2016.12.02 21:38:08 - OpenVPN > Authenticate/Decrypt packet error: bad packet ID (may be a replay): [ #3441 ] -- see the man page entry for --no-replay and --replay-window for more info or silence this warning with --mute-replay-warnings. 2016.12.02 21:38:08 - OpenVPN > Authenticate/Decrypt packet error: bad packet ID (may be a replay): [ #3440 ] -- see the man page entry for --no-replay and --replay-window for more info or silence this warning with --mute-replay-warnings. 2016.12.02 21:38:08 - OpenVPN > Authenticate/Decrypt packet error: bad packet ID (may be a replay): [ #3441 ] -- see the man page entry for --no-replay and --replay-window for more info or silence this warning with --mute-replay-warnings. 2016.12.02 21:38:35 - OpenVPN > Authenticate/Decrypt packet error: bad packet ID (may be a replay): [ #3636 ] -- see the man page entry for --no-replay and --replay-window for more info or silence this warning with --mute-replay-warnings. 2016.12.02 21:38:35 - OpenVPN > Authenticate/Decrypt packet error: bad packet ID (may be a replay): [ #3637 ] -- see the man page entry for --no-replay and --replay-window for more info or silence this warning with --mute-replay-warnings. 2016.12.02 21:38:35 - OpenVPN > Authenticate/Decrypt packet error: bad packet ID (may be a replay): [ #3636 ] -- see the man page entry for --no-replay and --replay-window for more info or silence this warning with --mute-replay-warnings. 2016.12.02 21:38:35 - OpenVPN > Authenticate/Decrypt packet error: bad packet ID (may be a replay): [ #3637 ] -- see the man page entry for --no-replay and --replay-window for more info or silence this warning with --mute-replay-warnings. 2016.12.02 21:38:35 - OpenVPN > Authenticate/Decrypt packet error: bad packet ID (may be a replay): [ #3636 ] -- see the man page entry for --no-replay and --replay-window for more info or silence this warning with --mute-replay-warnings. 2016.12.02 21:38:35 - OpenVPN > Authenticate/Decrypt packet error: bad packet ID (may be a replay): [ #3637 ] -- see the man page entry for --no-replay and --replay-window for more info or silence this warning with --mute-replay-warnings. 2016.12.02 21:38:35 - OpenVPN > Authenticate/Decrypt packet error: bad packet ID (may be a replay): [ #3636 ] -- see the man page entry for --no-replay and --replay-window for more info or silence this warning with --mute-replay-warnings. 2016.12.02 21:38:35 - OpenVPN > Authenticate/Decrypt packet error: bad packet ID (may be a replay): [ #3637 ] -- see the man page entry for --no-replay and --replay-window for more info or silence this warning with --mute-replay-warnings. 2016.12.02 21:38:35 - OpenVPN > Authenticate/Decrypt packet error: bad packet ID (may be a replay): [ #3638 ] -- see the man page entry for --no-replay and --replay-window for more info or silence this warning with --mute-replay-warnings. 2016.12.02 21:38:35 - OpenVPN > Authenticate/Decrypt packet error: bad packet ID (may be a replay): [ #3639 ] -- see the man page entry for --no-replay and --replay-window for more info or silence this warning with --mute-replay-warnings. 2016.12.02 21:38:35 - OpenVPN > Authenticate/Decrypt packet error: bad packet ID (may be a replay): [ #3638 ] -- see the man page entry for --no-replay and --replay-window for more info or silence this warning with --mute-replay-warnings. 2016.12.02 21:38:35 - OpenVPN > Authenticate/Decrypt packet error: bad packet ID (may be a replay): [ #3639 ] -- see the man page entry for --no-replay and --replay-window for more info or silence this warning with --mute-replay-warnings. 2016.12.02 21:38:35 - OpenVPN > Authenticate/Decrypt packet error: bad packet ID (may be a replay): [ #3638 ] -- see the man page entry for --no-replay and --replay-window for more info or silence this warning with --mute-replay-warnings. 2016.12.02 21:38:35 - OpenVPN > Authenticate/Decrypt packet error: bad packet ID (may be a replay): [ #3639 ] -- see the man page entry for --no-replay and --replay-window for more info or silence this warning with --mute-replay-warnings. 2016.12.02 21:38:35 - OpenVPN > Authenticate/Decrypt packet error: bad packet ID (may be a replay): [ #3653 ] -- see the man page entry for --no-replay and --replay-window for more info or silence this warning with --mute-replay-warnings. 2016.12.02 21:38:35 - OpenVPN > Authenticate/Decrypt packet error: bad packet ID (may be a replay): [ #3654 ] -- see the man page entry for --no-replay and --replay-window for more info or silence this warning with --mute-replay-warnings. 2016.12.02 21:38:35 - OpenVPN > Authenticate/Decrypt packet error: bad packet ID (may be a replay): [ #3653 ] -- see the man page entry for --no-replay and --replay-window for more info or silence this warning with --mute-replay-warnings. 2016.12.02 21:38:35 - OpenVPN > Authenticate/Decrypt packet error: bad packet ID (may be a replay): [ #3654 ] -- see the man page entry for --no-replay and --replay-window for more info or silence this warning with --mute-replay-warnings. 2016.12.02 21:38:35 - OpenVPN > Authenticate/Decrypt packet error: bad packet ID (may be a replay): [ #3653 ] -- see the man page entry for --no-replay and --replay-window for more info or silence this warning with --mute-replay-warnings. 2016.12.02 21:38:35 - OpenVPN > Authenticate/Decrypt packet error: bad packet ID (may be a replay): [ #3654 ] -- see the man page entry for --no-replay and --replay-window for more info or silence this warning with --mute-replay-warnings. 2016.12.02 21:38:35 - OpenVPN > Authenticate/Decrypt packet error: bad packet ID (may be a replay): [ #3653 ] -- see the man page entry for --no-replay and --replay-window for more info or silence this warning with --mute-replay-warnings. 2016.12.02 21:38:35 - OpenVPN > Authenticate/Decrypt packet error: bad packet ID (may be a replay): [ #3654 ] -- see the man page entry for --no-replay and --replay-window for more info or silence this warning with --mute-replay-warnings. 2016.12.02 21:39:55 - OpenVPN > Authenticate/Decrypt packet error: bad packet ID (may be a replay): [ #6123 ] -- see the man page entry for --no-replay and --replay-window for more info or silence this warning with --mute-replay-warnings. 2016.12.02 21:39:55 - OpenVPN > Authenticate/Decrypt packet error: bad packet ID (may be a replay): [ #6124 ] -- see the man page entry for --no-replay and --replay-window for more info or silence this warning with --mute-replay-warnings. 2016.12.02 21:39:55 - OpenVPN > Authenticate/Decrypt packet error: bad packet ID (may be a replay): [ #6123 ] -- see the man page entry for --no-replay and --replay-window for more info or silence this warning with --mute-replay-warnings. 2016.12.02 21:39:55 - OpenVPN > Authenticate/Decrypt packet error: bad packet ID (may be a replay): [ #6124 ] -- see the man page entry for --no-replay and --replay-window for more info or silence this warning with --mute-replay-warnings. 2016.12.02 21:39:55 - OpenVPN > Authenticate/Decrypt packet error: bad packet ID (may be a replay): [ #6123 ] -- see the man page entry for --no-replay and --replay-window for more info or silence this warning with --mute-replay-warnings. 2016.12.02 21:39:55 - OpenVPN > Authenticate/Decrypt packet error: bad packet ID (may be a replay): [ #6124 ] -- see the man page entry for --no-replay and --replay-window for more info or silence this warning with --mute-replay-warnings. 2016.12.02 21:39:55 - OpenVPN > Authenticate/Decrypt packet error: bad packet ID (may be a replay): [ #6123 ] -- see the man page entry for --no-replay and --replay-window for more info or silence this warning with --mute-replay-warnings. 2016.12.02 21:39:55 - OpenVPN > Authenticate/Decrypt packet error: bad packet ID (may be a replay): [ #6124 ] -- see the man page entry for --no-replay and --replay-window for more info or silence this warning with --mute-replay-warnings. 2016.12.02 21:39:55 - OpenVPN > Authenticate/Decrypt packet error: bad packet ID (may be a replay): [ #6125 ] -- see the man page entry for --no-replay and --replay-window for more info or silence this warning with --mute-replay-warnings. 2016.12.02 21:39:55 - OpenVPN > Authenticate/Decrypt packet error: bad packet ID (may be a replay): [ #6126 ] -- see the man page entry for --no-replay and --replay-window for more info or silence this warning with --mute-replay-warnings. 2016.12.02 21:39:55 - OpenVPN > Authenticate/Decrypt packet error: bad packet ID (may be a replay): [ #6127 ] -- see the man page entry for --no-replay and --replay-window for more info or silence this warning with --mute-replay-warnings. 2016.12.02 21:39:55 - OpenVPN > Authenticate/Decrypt packet error: bad packet ID (may be a replay): [ #6125 ] -- see the man page entry for --no-replay and --replay-window for more info or silence this warning with --mute-replay-warnings. 2016.12.02 21:39:55 - OpenVPN > Authenticate/Decrypt packet error: bad packet ID (may be a replay): [ #6126 ] -- see the man page entry for --no-replay and --replay-window for more info or silence this warning with --mute-replay-warnings. 2016.12.02 21:39:55 - OpenVPN > Authenticate/Decrypt packet error: bad packet ID (may be a replay): [ #6127 ] -- see the man page entry for --no-replay and --replay-window for more info or silence this warning with --mute-replay-warnings. 2016.12.02 21:39:55 - OpenVPN > Authenticate/Decrypt packet error: bad packet ID (may be a replay): [ #6125 ] -- see the man page entry for --no-replay and --replay-window for more info or silence this warning with --mute-replay-warnings. 2016.12.02 21:39:55 - OpenVPN > Authenticate/Decrypt packet error: bad packet ID (may be a replay): [ #6126 ] -- see the man page entry for --no-replay and --replay-window for more info or silence this warning with --mute-replay-warnings. 2016.12.02 21:39:55 - OpenVPN > Authenticate/Decrypt packet error: bad packet ID (may be a replay): [ #6127 ] -- see the man page entry for --no-replay and --replay-window for more info or silence this warning with --mute-replay-warnings. 2016.12.02 21:39:55 - OpenVPN > Authenticate/Decrypt packet error: bad packet ID (may be a replay): [ #6125 ] -- see the man page entry for --no-replay and --replay-window for more info or silence this warning with --mute-replay-warnings. 2016.12.02 21:39:55 - OpenVPN > Authenticate/Decrypt packet error: bad packet ID (may be a replay): [ #6126 ] -- see the man page entry for --no-replay and --replay-window for more info or silence this warning with --mute-replay-warnings. 2016.12.02 21:39:55 - OpenVPN > Authenticate/Decrypt packet error: bad packet ID (may be a replay): [ #6127 ] -- see the man page entry for --no-replay and --replay-window for more info or silence this warning with --mute-replay-warnings. 2016.12.02 21:40:15 - OpenVPN > Authenticate/Decrypt packet error: bad packet ID (may be a replay): [ #7550 ] -- see the man page entry for --no-replay and --replay-window for more info or silence this warning with --mute-replay-warnings. 2016.12.02 21:40:15 - OpenVPN > Authenticate/Decrypt packet error: bad packet ID (may be a replay): [ #7551 ] -- see the man page entry for --no-replay and --replay-window for more info or silence this warning with --mute-replay-warnings. 2016.12.02 21:40:15 - OpenVPN > Authenticate/Decrypt packet error: bad packet ID (may be a replay): [ #7550 ] -- see the man page entry for --no-replay and --replay-window for more info or silence this warning with --mute-replay-warnings. 2016.12.02 21:40:15 - OpenVPN > Authenticate/Decrypt packet error: bad packet ID (may be a replay): [ #7551 ] -- see the man page entry for --no-replay and --replay-window for more info or silence this warning with --mute-replay-warnings. 2016.12.02 21:40:15 - OpenVPN > Authenticate/Decrypt packet error: bad packet ID (may be a replay): [ #7550 ] -- see the man page entry for --no-replay and --replay-window for more info or silence this warning with --mute-replay-warnings. 2016.12.02 21:40:15 - OpenVPN > Authenticate/Decrypt packet error: bad packet ID (may be a replay): [ #7551 ] -- see the man page entry for --no-replay and --replay-window for more info or silence this warning with --mute-replay-warnings. 2016.12.02 21:40:15 - OpenVPN > Authenticate/Decrypt packet error: bad packet ID (may be a replay): [ #7550 ] -- see the man page entry for --no-replay and --replay-window for more info or silence this warning with --mute-replay-warnings. 2016.12.02 21:40:15 - OpenVPN > Authenticate/Decrypt packet error: bad packet ID (may be a replay): [ #7551 ] -- see the man page entry for --no-replay and --replay-window for more info or silence this warning with --mute-replay-warnings. 2016.12.02 21:40:15 - OpenVPN > Authenticate/Decrypt packet error: bad packet ID (may be a replay): [ #7552 ] -- see the man page entry for --no-replay and --replay-window for more info or silence this warning with --mute-replay-warnings. 2016.12.02 21:40:15 - OpenVPN > Authenticate/Decrypt packet error: bad packet ID (may be a replay): [ #7553 ] -- see the man page entry for --no-replay and --replay-window for more info or silence this warning with --mute-replay-warnings. 2016.12.02 21:40:15 - OpenVPN > Authenticate/Decrypt packet error: bad packet ID (may be a replay): [ #7554 ] -- see the man page entry for --no-replay and --replay-window for more info or silence this warning with --mute-replay-warnings. 2016.12.02 21:40:15 - OpenVPN > Authenticate/Decrypt packet error: bad packet ID (may be a replay): [ #7552 ] -- see the man page entry for --no-replay and --replay-window for more info or silence this warning with --mute-replay-warnings. 2016.12.02 21:40:15 - OpenVPN > Authenticate/Decrypt packet error: bad packet ID (may be a replay): [ #7553 ] -- see the man page entry for --no-replay and --replay-window for more info or silence this warning with --mute-replay-warnings. 2016.12.02 21:40:15 - OpenVPN > Authenticate/Decrypt packet error: bad packet ID (may be a replay): [ #7554 ] -- see the man page entry for --no-replay and --replay-window for more info or silence this warning with --mute-replay-warnings. 2016.12.02 21:40:15 - OpenVPN > Authenticate/Decrypt packet error: bad packet ID (may be a replay): [ #7552 ] -- see the man page entry for --no-replay and --replay-window for more info or silence this warning with --mute-replay-warnings. 2016.12.02 21:40:15 - OpenVPN > Authenticate/Decrypt packet error: bad packet ID (may be a replay): [ #7553 ] -- see the man page entry for --no-replay and --replay-window for more info or silence this warning with --mute-replay-warnings. 2016.12.02 21:40:15 - OpenVPN > Authenticate/Decrypt packet error: bad packet ID (may be a replay): [ #7554 ] -- see the man page entry for --no-replay and --replay-window for more info or silence this warning with --mute-replay-warnings. 2016.12.02 21:40:15 - OpenVPN > Authenticate/Decrypt packet error: bad packet ID (may be a replay): [ #7552 ] -- see the man page entry for --no-replay and --replay-window for more info or silence this warning with --mute-replay-warnings. 2016.12.02 21:40:15 - OpenVPN > Authenticate/Decrypt packet error: bad packet ID (may be a replay): [ #7553 ] -- see the man page entry for --no-replay and --replay-window for more info or silence this warning with --mute-replay-warnings. 2016.12.02 21:40:15 - OpenVPN > Authenticate/Decrypt packet error: bad packet ID (may be a replay): [ #7554 ] -- see the man page entry for --no-replay and --replay-window for more info or silence this warning with --mute-replay-warnings. 2016.12.02 21:40:15 - OpenVPN > Authenticate/Decrypt packet error: bad packet ID (may be a replay): [ #7552 ] -- see the man page entry for --no-replay and --replay-window for more info or silence this warning with --mute-replay-warnings. 2016.12.02 21:40:15 - OpenVPN > Authenticate/Decrypt packet error: bad packet ID (may be a replay): [ #7553 ] -- see the man page entry for --no-replay and --replay-window for more info or silence this warning with --mute-replay-warnings. 2016.12.02 21:40:15 - OpenVPN > Authenticate/Decrypt packet error: bad packet ID (may be a replay): [ #7554 ] -- see the man page entry for --no-replay and --replay-window for more info or silence this warning with --mute-replay-warnings. 2016.12.02 21:40:15 - OpenVPN > Authenticate/Decrypt packet error: bad packet ID (may be a replay): [ #7555 ] -- see the man page entry for --no-replay and --replay-window for more info or silence this warning with --mute-replay-warnings. 2016.12.02 21:40:15 - OpenVPN > Authenticate/Decrypt packet error: bad packet ID (may be a replay): [ #7556 ] -- see the man page entry for --no-replay and --replay-window for more info or silence this warning with --mute-replay-warnings. 2016.12.02 21:40:15 - OpenVPN > Authenticate/Decrypt packet error: bad packet ID (may be a replay): [ #7557 ] -- see the man page entry for --no-replay and --replay-window for more info or silence this warning with --mute-replay-warnings. 2016.12.02 21:40:15 - OpenVPN > Authenticate/Decrypt packet error: bad packet ID (may be a replay): [ #7555 ] -- see the man page entry for --no-replay and --replay-window for more info or silence this warning with --mute-replay-warnings. 2016.12.02 21:40:15 - OpenVPN > Authenticate/Decrypt packet error: bad packet ID (may be a replay): [ #7556 ] -- see the man page entry for --no-replay and --replay-window for more info or silence this warning with --mute-replay-warnings. 2016.12.02 21:40:15 - OpenVPN > Authenticate/Decrypt packet error: bad packet ID (may be a replay): [ #7557 ] -- see the man page entry for --no-replay and --replay-window for more info or silence this warning with --mute-replay-warnings. 2016.12.02 21:40:15 - OpenVPN > Authenticate/Decrypt packet error: bad packet ID (may be a replay): [ #7555 ] -- see the man page entry for --no-replay and --replay-window for more info or silence this warning with --mute-replay-warnings. 2016.12.02 21:40:15 - OpenVPN > Authenticate/Decrypt packet error: bad packet ID (may be a replay): [ #7556 ] -- see the man page entry for --no-replay and --replay-window for more info or silence this warning with --mute-replay-warnings. 2016.12.02 21:40:15 - OpenVPN > Authenticate/Decrypt packet error: bad packet ID (may be a replay): [ #7557 ] -- see the man page entry for --no-replay and --replay-window for more info or silence this warning with --mute-replay-warnings. 2016.12.02 21:40:15 - OpenVPN > Authenticate/Decrypt packet error: bad packet ID (may be a replay): [ #7555 ] -- see the man page entry for --no-replay and --replay-window for more info or silence this warning with --mute-replay-warnings. 2016.12.02 21:40:15 - OpenVPN > Authenticate/Decrypt packet error: bad packet ID (may be a replay): [ #7556 ] -- see the man page entry for --no-replay and --replay-window for more info or silence this warning with --mute-replay-warnings. 2016.12.02 21:40:15 - OpenVPN > Authenticate/Decrypt packet error: bad packet ID (may be a replay): [ #7557 ] -- see the man page entry for --no-replay and --replay-window for more info or silence this warning with --mute-replay-warnings. 2016.12.02 21:40:15 - OpenVPN > Authenticate/Decrypt packet error: bad packet ID (may be a replay): [ #7555 ] -- see the man page entry for --no-replay and --replay-window for more info or silence this warning with --mute-replay-warnings. 2016.12.02 21:40:15 - OpenVPN > Authenticate/Decrypt packet error: bad packet ID (may be a replay): [ #7556 ] -- see the man page entry for --no-replay and --replay-window for more info or silence this warning with --mute-replay-warnings. 2016.12.02 21:40:15 - OpenVPN > Authenticate/Decrypt packet error: bad packet ID (may be a replay): [ #7557 ] -- see the man page entry for --no-replay and --replay-window for more info or silence this warning with --mute-replay-warnings. 2016.12.02 21:40:50 - OpenVPN > Authenticate/Decrypt packet error: bad packet ID (may be a replay): [ #7725 ] -- see the man page entry for --no-replay and --replay-window for more info or silence this warning with --mute-replay-warnings. 2016.12.02 21:40:50 - OpenVPN > Authenticate/Decrypt packet error: bad packet ID (may be a replay): [ #7726 ] -- see the man page entry for --no-replay and --replay-window for more info or silence this warning with --mute-replay-warnings. 2016.12.02 21:40:50 - OpenVPN > Authenticate/Decrypt packet error: bad packet ID (may be a replay): [ #7725 ] -- see the man page entry for --no-replay and --replay-window for more info or silence this warning with --mute-replay-warnings. 2016.12.02 21:40:50 - OpenVPN > Authenticate/Decrypt packet error: bad packet ID (may be a replay): [ #7726 ] -- see the man page entry for --no-replay and --replay-window for more info or silence this warning with --mute-replay-warnings. 2016.12.02 21:40:50 - OpenVPN > Authenticate/Decrypt packet error: bad packet ID (may be a replay): [ #7725 ] -- see the man page entry for --no-replay and --replay-window for more info or silence this warning with --mute-replay-warnings. 2016.12.02 21:40:50 - OpenVPN > Authenticate/Decrypt packet error: bad packet ID (may be a replay): [ #7726 ] -- see the man page entry for --no-replay and --replay-window for more info or silence this warning with --mute-replay-warnings. 2016.12.02 21:40:50 - OpenVPN > Authenticate/Decrypt packet error: bad packet ID (may be a replay): [ #7725 ] -- see the man page entry for --no-replay and --replay-window for more info or silence this warning with --mute-replay-warnings. 2016.12.02 21:40:50 - OpenVPN > Authenticate/Decrypt packet error: bad packet ID (may be a replay): [ #7726 ] -- see the man page entry for --no-replay and --replay-window for more info or silence this warning with --mute-replay-warnings. 2016.12.02 21:43:30 - Updating systems & servers data .... 2016.12.02 21:43:31 - Systems & servers data update completed . 2016.12.02 20:19:00 - OpenVPN > DHCP SERV =. 2016.12.02 20:19:00 - OpenVPN > DHCP LEASE OBTAINED = Fri Dec 02 20:19:00 2016. 2016.12.02 20:19:00 - OpenVPN > DHCP LEASE EXPIRES = Fri Dec 02 20:19:00 2016. 2016.12.02 20:19:00 - OpenVPN > DNS SERV =. 2016.12.02 20:19:00 - OpenVPN > TAP-Windows Adapter V9. 2016.12.02 20:19:00 - OpenVPN > Index = 18. 2016.12.02 20:19:00 - OpenVPN > GUID = {F40AE409-E4BC-4ABA-B9F7-3BD827158EE3}. 2016.12.02 20:19:00 - OpenVPN > IP = 10.4.92.206/255.255.0.0. 2016.12.02 20:19:00 - OpenVPN > MAC = 00:ff:f4:0a:e4:09. 2016.12.02 20:19:00 - OpenVPN > GATEWAY = 0.0.0.0/255.255.255.255. 2016.12.02 20:19:00 - OpenVPN > DHCP SERV = 10.4.255.254/255.255.255.255. 2016.12.02 20:19:00 - OpenVPN > DHCP LEASE OBTAINED = Fri Dec 02 17:21:12 2016. 2016.12.02 20:19:00 - OpenVPN > DHCP LEASE EXPIRES = Sat Dec 02 17:21:12 2017. 2016.12.02 20:19:00 - OpenVPN > DNS SERV = 10.4.0.1/255.255.255.255. 2016.12.02 20:19:00 - OpenVPN > 300Mbps Wireless USB Adapter. 2016.12.02 20:19:00 - OpenVPN > Index = 17. 2016.12.02 20:19:00 - OpenVPN > GUID = {D6DBB021-16B1-4402-97B4-1CEEE4201C7C}. 2016.12.02 20:19:00 - OpenVPN > IP = 192.168.1.101/255.255.255.0. 2016.12.02 20:19:00 - OpenVPN > MAC = 14:cc:20:17:0d:7f. 2016.12.02 20:19:00 - OpenVPN > GATEWAY = 192.168.1.1/255.255.255.255. 2016.12.02 20:19:00 - OpenVPN > DHCP SERV = 192.168.1.1/255.255.255.255. 2016.12.02 20:19:00 - OpenVPN > DHCP LEASE OBTAINED = Fri Dec 02 18:11:06 2016. 2016.12.02 20:19:00 - OpenVPN > DHCP LEASE EXPIRES = Sat Dec 03 18:11:06 2016. 2016.12.02 20:19:00 - OpenVPN > DNS SERV = 10.4.0.1/255.255.255.255. 2016.12.02 20:19:00 - OpenVPN > Microsoft Wi-Fi Direct Virtual Adapter. 2016.12.02 20:19:00 - OpenVPN > Index = 13. 2016.12.02 20:19:00 - OpenVPN > GUID = {AEB675DF-7F7D-4FED-BC91-F8C40081B696}. 2016.12.02 20:19:00 - OpenVPN > IP = 0.0.0.0/0.0.0.0. 2016.12.02 20:19:00 - OpenVPN > MAC = 14:cc:20:17:0d:7f. 2016.12.02 20:19:00 - OpenVPN > GATEWAY = 0.0.0.0/255.255.255.255. 2016.12.02 20:19:00 - OpenVPN > DHCP SERV =. 2016.12.02 20:19:00 - OpenVPN > DHCP LEASE OBTAINED = Fri Dec 02 20:19:00 2016. 2016.12.02 20:19:00 - OpenVPN > DHCP LEASE EXPIRES = Fri Dec 02 20:19:00 2016. 2016.12.02 20:19:00 - OpenVPN > DNS SERV =. 2016.12.02 20:19:00 - Starting Management Interface. 2016.12.02 20:19:00 - OpenVPN > Initialization Sequence Completed With Errors ( see http://openvpn.net/faq.html#dhcpclientserv )! 2016.12.02 20:19:00 - Disconnecting. 2016.12.02 20:19:00 - Management - Send 'signal SIGTERM'. 2016.12.02 20:19:00 - OpenVpn Management > >INFO:OpenVPN Management Interface Version 1 -- type 'help' for more info. 2016.12.02 20:19:00 - DNS leak protection with packet filtering enabled.I 2016.12.02 20:19:00 - Flushing DNSW 2016.12.02 20:19:01 - Checking route, 4° try failed (The remote name could not be resolved: 'sheliak_exit.airservers.org'). 2016.12.02 20:19:05 - Connection terminated.. 2016.12.02 20:19:05 - DNS leak protection with packet filtering disabled.I 2016.12.02 20:19:08 - Checking authorization ...! 2016.12.02 20:19:08 - Connecting to Nash (Netherlands, Alblasserdam). 2016.12.02 20:19:08 - OpenVPN > OpenVPN 2.3.13 x86_64-w64-mingw32 [sSL (OpenSSL)] [LZO] [iPv6] built on Nov 10 2016. 2016.12.02 20:19:08 - OpenVPN > Windows version 6.2 (Windows 8 or greater) 64bit. 2016.12.02 20:19:08 - OpenVPN > library versions: OpenSSL 1.0.2j 26 Sep 2016, LZO 2.09. 2016.12.02 20:19:08 - OpenVPN > MANAGEMENT: TCP Socket listening on [AF_INET]127.0.0.1:3100. 2016.12.02 20:19:08 - OpenVPN > Control Channel Authentication: tls-auth using INLINE static key file. 2016.12.02 20:19:08 - OpenVPN > Outgoing Control Channel Authentication: Using 160 bit message hash 'SHA1' for HMAC authentication. 2016.12.02 20:19:08 - OpenVPN > Incoming Control Channel Authentication: Using 160 bit message hash 'SHA1' for HMAC authentication. 2016.12.02 20:19:08 - OpenVPN > Socket Buffers: R=[65536->262144] S=[65536->262144]. 2016.12.02 20:19:08 - OpenVPN > UDPv4 link local: [undef]. 2016.12.02 20:19:08 - OpenVPN > UDPv4 link remote: [AF_INET]213.152.161.24:443. 2016.12.02 20:19:08 - OpenVPN > TLS: Initial packet from [AF_INET]213.152.161.24:443, sid=a77639e4 f7ed1b28. 2016.12.02 20:19:08 - OpenVPN > VERIFY OK: depth=1, C=IT, ST=IT, L=Perugia, O=airvpn.org, CN=airvpn.org CA, emailAddress=info@airvpn.org. 2016.12.02 20:19:08 - OpenVPN > Validating certificate key usage. 2016.12.02 20:19:08 - OpenVPN > ++ Certificate has key usage 00a0, expects 00a0. 2016.12.02 20:19:08 - OpenVPN > VERIFY KU OK. 2016.12.02 20:19:08 - OpenVPN > Validating certificate extended key usage. 2016.12.02 20:19:08 - OpenVPN > ++ Certificate has EKU (str) TLS Web Server Authentication, expects TLS Web Server Authentication. 2016.12.02 20:19:08 - OpenVPN > VERIFY EKU OK. 2016.12.02 20:19:08 - OpenVPN > VERIFY OK: depth=0, C=IT, ST=IT, L=Perugia, O=airvpn.org, CN=server, emailAddress=info@airvpn.org. 2016.12.02 20:19:08 - OpenVPN > Data Channel Encrypt: Cipher 'AES-256-CBC' initialized with 256 bit key. 2016.12.02 20:19:08 - OpenVPN > Data Channel Encrypt: Using 160 bit message hash 'SHA1' for HMAC authentication. 2016.12.02 20:19:08 - OpenVPN > Data Channel Decrypt: Cipher 'AES-256-CBC' initialized with 256 bit key. 2016.12.02 20:19:08 - OpenVPN > Data Channel Decrypt: Using 160 bit message hash 'SHA1' for HMAC authentication. 2016.12.02 20:19:08 - OpenVPN > Control Channel: TLSv1.2, cipher TLSv1/SSLv3 DHE-RSA-AES256-GCM-SHA384, 4096 bit RSA. 2016.12.02 20:19:08 - OpenVPN > [server] Peer Connection Initiated with [AF_INET]213.152.161.24:443I 2016.12.02 20:19:08 - Checking route. 2016.12.02 20:19:11 - OpenVPN > SENT CONTROL [server]: 'PUSH_REQUEST' (status=1). 2016.12.02 20:19:11 - OpenVPN > PUSH: Received control message: 'PUSH_REPLY,redirect-gateway def1 bypass-dhcp,dhcp-option DNS 10.4.0.1,comp-lzo no,route-gateway 10.4.0.1,topology subnet,ping 10,ping-restart 60,ifconfig 10.4.94.84 255.255.0.0'. 2016.12.02 20:19:11 - OpenVPN > OPTIONS IMPORT: timers and/or timeouts modified. 2016.12.02 20:19:11 - OpenVPN > OPTIONS IMPORT: LZO parms modified. 2016.12.02 20:19:11 - OpenVPN > OPTIONS IMPORT: --ifconfig/up options modified. 2016.12.02 20:19:11 - OpenVPN > OPTIONS IMPORT: route options modified. 2016.12.02 20:19:11 - OpenVPN > OPTIONS IMPORT: route-related options modified. 2016.12.02 20:19:11 - OpenVPN > OPTIONS IMPORT: --ip-win32 and/or --dhcp-option options modified. 2016.12.02 20:19:11 - OpenVPN > ROUTE_GATEWAY 192.168.1.1/255.255.255.0 I=17 HWADDR=14:cc:20:17:0d:7f. 2016.12.02 20:19:11 - OpenVPN > do_ifconfig, tt->ipv6=0, tt->did_ifconfig_ipv6_setup=0. 2016.12.02 20:19:11 - OpenVPN > open_tun, tt->ipv6=0. 2016.12.02 20:19:11 - OpenVPN > TAP-WIN32 device [Local Area Connection 2] opened: \\.\Global\{F40AE409-E4BC-4ABA-B9F7-3BD827158EE3}.tap. 2016.12.02 20:19:11 - OpenVPN > TAP-Windows Driver Version 9.21. 2016.12.02 20:19:11 - OpenVPN > Set TAP-Windows TUN subnet mode network/local/netmask = 10.4.0.0/10.4.94.84/255.255.0.0 [sUCCEEDED]. 2016.12.02 20:19:11 - OpenVPN > Notified TAP-Windows driver to set a DHCP IP/netmask of 10.4.94.84/255.255.0.0 on interface {F40AE409-E4BC-4ABA-B9F7-3BD827158EE3} [DHCP-serv: 10.4.255.254, lease-time: 31536000]. 2016.12.02 20:19:11 - OpenVPN > Successful ARP Flush on interface [18] {F40AE409-E4BC-4ABA-B9F7-3BD827158EE3}W 2016.12.02 20:19:15 - Checking route, 5° try failed (The operation has timed out)W 2016.12.02 20:19:15 - The operation has timed out. 2016.12.02 20:19:15 - OpenVPN > MANAGEMENT: CMD 'signal SIGTERM'. 2016.12.02 20:19:15 - OpenVPN > SIGTERM received, sending exit notification to peer. 2016.12.02 20:19:15 - OpenVPN > C:\WINDOWS\system32\route.exe DELETE 213.152.161.132 MASK 255.255.255.255 192.168.1.1. 2016.12.02 20:19:15 - OpenVPN > Route deletion via IPAPI succeeded [adaptive]. 2016.12.02 20:19:15 - OpenVPN > C:\WINDOWS\system32\route.exe DELETE 0.0.0.0 MASK 128.0.0.0 10.4.0.1. 2016.12.02 20:19:15 - OpenVPN > Route deletion via IPAPI succeeded [adaptive]. 2016.12.02 20:19:15 - OpenVPN > C:\WINDOWS\system32\route.exe DELETE 128.0.0.0 MASK 128.0.0.0 10.4.0.1. 2016.12.02 20:19:15 - OpenVPN > Route deletion via IPAPI succeeded [adaptive]. 2016.12.02 20:19:15 - OpenVPN > Closing TUN/TAP interface. 2016.12.02 20:19:15 - OpenVPN > SIGTERM[soft,exit-with-notification] received, process exiting! 2016.12.02 20:19:15 - Disconnecting. 2016.12.02 20:19:15 - Connection terminated.I 2016.12.02 20:19:18 - Checking authorization ...! 2016.12.02 20:19:18 - Connecting to Kocab (Netherlands, Alblasserdam). 2016.12.02 20:19:18 - OpenVPN > OpenVPN 2.3.13 x86_64-w64-mingw32 [sSL (OpenSSL)] [LZO] [iPv6] built on Nov 10 2016. 2016.12.02 20:19:18 - OpenVPN > Windows version 6.2 (Windows 8 or greater) 64bit. 2016.12.02 20:19:18 - OpenVPN > library versions: OpenSSL 1.0.2j 26 Sep 2016, LZO 2.09. 2016.12.02 20:19:18 - OpenVPN > MANAGEMENT: TCP Socket listening on [AF_INET]127.0.0.1:3100. 2016.12.02 20:19:18 - OpenVPN > Control Channel Authentication: tls-auth using INLINE static key file. 2016.12.02 20:19:18 - OpenVPN > Outgoing Control Channel Authentication: Using 160 bit message hash 'SHA1' for HMAC authentication. 2016.12.02 20:19:18 - OpenVPN > Incoming Control Channel Authentication: Using 160 bit message hash 'SHA1' for HMAC authentication. 2016.12.02 20:19:18 - OpenVPN > Socket Buffers: R=[65536->262144] S=[65536->262144]. 2016.12.02 20:19:18 - OpenVPN > UDPv4 link local: [undef]. 2016.12.02 20:19:18 - OpenVPN > UDPv4 link remote: [AF_INET]213.152.162.180:443. 2016.12.02 20:19:18 - OpenVPN > TLS: Initial packet from [AF_INET]213.152.162.180:443, sid=e7152d1d 767e634d. 2016.12.02 20:19:18 - OpenVPN > VERIFY OK: depth=1, C=IT, ST=IT, L=Perugia, O=airvpn.org, CN=airvpn.org CA, emailAddress=info@airvpn.org. 2016.12.02 20:19:18 - OpenVPN > Validating certificate key usage. 2016.12.02 20:19:18 - OpenVPN > ++ Certificate has key usage 00a0, expects 00a0. 2016.12.02 20:19:18 - OpenVPN > VERIFY KU OK. 2016.12.02 20:19:18 - OpenVPN > Validating certificate extended key usage. 2016.12.02 20:19:18 - OpenVPN > ++ Certificate has EKU (str) TLS Web Server Authentication, expects TLS Web Server Authentication. 2016.12.02 20:19:18 - OpenVPN > VERIFY EKU OK. 2016.12.02 20:19:18 - OpenVPN > VERIFY OK: depth=0, C=IT, ST=IT, L=Perugia, O=airvpn.org, CN=server, emailAddress=info@airvpn.orgW 2016.12.02 20:19:20 - Checking route, 1° try failed (The operation has timed out). 2016.12.02 20:19:22 - OpenVPN > Data Channel Encrypt: Cipher 'AES-256-CBC' initialized with 256 bit key. 2016.12.02 20:19:22 - OpenVPN > Data Channel Encrypt: Using 160 bit message hash 'SHA1' for HMAC authentication. 2016.12.02 20:19:22 - OpenVPN > Data Channel Decrypt: Cipher 'AES-256-CBC' initialized with 256 bit key. 2016.12.02 20:19:22 - OpenVPN > Data Channel Decrypt: Using 160 bit message hash 'SHA1' for HMAC authentication. 2016.12.02 20:19:22 - OpenVPN > Control Channel: TLSv1.2, cipher TLSv1/SSLv3 DHE-RSA-AES256-GCM-SHA384, 4096 bit RSA. 2016.12.02 20:19:22 - OpenVPN > [server] Peer Connection Initiated with [AF_INET]213.152.162.180:443. 2016.12.02 20:19:25 - OpenVPN > SENT CONTROL [server]: 'PUSH_REQUEST' (status=1). 2016.12.02 20:19:25 - OpenVPN > PUSH: Received control message: 'PUSH_REPLY,redirect-gateway def1 bypass-dhcp,dhcp-option DNS 10.4.0.1,comp-lzo no,route-gateway 10.4.0.1,topology subnet,ping 10,ping-restart 60,ifconfig 10.4.75.209 255.255.0.0'. 2016.12.02 20:19:25 - OpenVPN > OPTIONS IMPORT: timers and/or timeouts modified. 2016.12.02 20:19:25 - OpenVPN > OPTIONS IMPORT: LZO parms modified. 2016.12.02 20:19:25 - OpenVPN > OPTIONS IMPORT: --ifconfig/up options modified. 2016.12.02 20:19:25 - OpenVPN > OPTIONS IMPORT: route options modified. 2016.12.02 20:19:25 - OpenVPN > OPTIONS IMPORT: route-related options modified. 2016.12.02 20:19:25 - OpenVPN > OPTIONS IMPORT: --ip-win32 and/or --dhcp-option options modified. 2016.12.02 20:19:25 - OpenVPN > ROUTE_GATEWAY 192.168.1.1/255.255.255.0 I=17 HWADDR=14:cc:20:17:0d:7f. 2016.12.02 20:19:25 - OpenVPN > do_ifconfig, tt->ipv6=0, tt->did_ifconfig_ipv6_setup=0. 2016.12.02 20:19:25 - OpenVPN > open_tun, tt->ipv6=0. 2016.12.02 20:19:25 - OpenVPN > TAP-WIN32 device [Local Area Connection 2] opened: \\.\Global\{F40AE409-E4BC-4ABA-B9F7-3BD827158EE3}.tap. 2016.12.02 20:19:25 - OpenVPN > TAP-Windows Driver Version 9.21. 2016.12.02 20:19:25 - OpenVPN > Set TAP-Windows TUN subnet mode network/local/netmask = 10.4.0.0/10.4.75.209/255.255.0.0 [sUCCEEDED]. 2016.12.02 20:19:25 - OpenVPN > Notified TAP-Windows driver to set a DHCP IP/netmask of 10.4.75.209/255.255.0.0 on interface {F40AE409-E4BC-4ABA-B9F7-3BD827158EE3} [DHCP-serv: 10.4.255.254, lease-time: 31536000]. 2016.12.02 20:19:25 - OpenVPN > Successful ARP Flush on interface [18] {F40AE409-E4BC-4ABA-B9F7-3BD827158EE3}. 2016.12.02 20:19:30 - OpenVPN > TEST ROUTES: 0/0 succeeded len=0 ret=0 a=0 u/d=down. 2016.12.02 20:19:30 - OpenVPN > Route: Waiting for TUN/TAP interface to come up.... 2016.12.02 20:19:30 - Eddie Windows Interface Hack executed (Local Area Connection 2)W 2016.12.02 20:19:32 - Checking route, 2° try failed (The operation has timed out). 2016.12.02 20:19:35 - OpenVPN > TEST ROUTES: 0/0 succeeded len=0 ret=0 a=0 u/d=down. 2016.12.02 20:19:35 - OpenVPN > Route: Waiting for TUN/TAP interface to come up.... 2016.12.02 20:19:35 - Eddie Windows Interface Hack executed (Local Area Connection 2). 2016.12.02 20:19:36 - OpenVPN > TEST ROUTES: 0/0 succeeded len=0 ret=0 a=0 u/d=down. 2016.12.02 20:19:36 - OpenVPN > Route: Waiting for TUN/TAP interface to come up.... 2016.12.02 20:19:36 - Eddie Windows Interface Hack executed (Local Area Connection 2). 2016.12.02 20:19:37 - OpenVPN > TEST ROUTES: 0/0 succeeded len=0 ret=0 a=0 u/d=down. 2016.12.02 20:19:37 - OpenVPN > Route: Waiting for TUN/TAP interface to come up.... 2016.12.02 20:19:37 - Eddie Windows Interface Hack executed (Local Area Connection 2). 2016.12.02 20:19:38 - OpenVPN > TEST ROUTES: 0/0 succeeded len=0 ret=0 a=0 u/d=down. 2016.12.02 20:19:38 - OpenVPN > Route: Waiting for TUN/TAP interface to come up.... 2016.12.02 20:19:38 - Eddie Windows Interface Hack executed (Local Area Connection 2). 2016.12.02 20:19:39 - OpenVPN > TEST ROUTES: 0/0 succeeded len=0 ret=0 a=0 u/d=down. 2016.12.02 20:19:39 - OpenVPN > Route: Waiting for TUN/TAP interface to come up.... 2016.12.02 20:19:39 - Eddie Windows Interface Hack executed (Local Area Connection 2). 2016.12.02 20:19:40 - OpenVPN > TEST ROUTES: 0/0 succeeded len=0 ret=0 a=0 u/d=down. 2016.12.02 20:19:40 - OpenVPN > Route: Waiting for TUN/TAP interface to come up.... 2016.12.02 20:19:40 - Eddie Windows Interface Hack executed (Local Area Connection 2). 2016.12.02 20:19:42 - OpenVPN > TEST ROUTES: 0/0 succeeded len=0 ret=0 a=0 u/d=down. 2016.12.02 20:19:42 - OpenVPN > Route: Waiting for TUN/TAP interface to come up.... 2016.12.02 20:19:42 - Eddie Windows Interface Hack executed (Local Area Connection 2). 2016.12.02 20:19:43 - OpenVPN > TEST ROUTES: 0/0 succeeded len=0 ret=0 a=0 u/d=down. 2016.12.02 20:19:43 - OpenVPN > Route: Waiting for TUN/TAP interface to come up.... 2016.12.02 20:19:43 - Eddie Windows Interface Hack executed (Local Area Connection 2). 2016.12.02 20:19:44 - OpenVPN > TEST ROUTES: 0/0 succeeded len=0 ret=0 a=0 u/d=down. 2016.12.02 20:19:44 - OpenVPN > Route: Waiting for TUN/TAP interface to come up.... 2016.12.02 20:19:44 - Eddie Windows Interface Hack executed (Local Area Connection 2)W 2016.12.02 20:19:44 - Checking route, 3° try failed (The operation has timed out). 2016.12.02 20:19:46 - OpenVPN > TEST ROUTES: 0/0 succeeded len=0 ret=0 a=0 u/d=down. 2016.12.02 20:19:46 - OpenVPN > Route: Waiting for TUN/TAP interface to come up.... 2016.12.02 20:19:46 - Eddie Windows Interface Hack executed (Local Area Connection 2). 2016.12.02 20:19:47 - OpenVPN > TEST ROUTES: 0/0 succeeded len=0 ret=0 a=0 u/d=down. 2016.12.02 20:19:47 - OpenVPN > Route: Waiting for TUN/TAP interface to come up.... 2016.12.02 20:19:47 - Eddie Windows Interface Hack executed (Local Area Connection 2). 2016.12.02 20:19:48 - OpenVPN > TEST ROUTES: 0/0 succeeded len=0 ret=0 a=0 u/d=down. 2016.12.02 20:19:48 - OpenVPN > Route: Waiting for TUN/TAP interface to come up.... 2016.12.02 20:19:48 - Eddie Windows Interface Hack executed (Local Area Connection 2). 2016.12.02 20:19:49 - OpenVPN > TEST ROUTES: 0/0 succeeded len=0 ret=0 a=0 u/d=down. 2016.12.02 20:19:49 - OpenVPN > Route: Waiting for TUN/TAP interface to come up.... 2016.12.02 20:19:49 - Eddie Windows Interface Hack executed (Local Area Connection 2). 2016.12.02 20:19:51 - OpenVPN > TEST ROUTES: 0/0 succeeded len=0 ret=0 a=0 u/d=down. 2016.12.02 20:19:51 - OpenVPN > Route: Waiting for TUN/TAP interface to come up.... 2016.12.02 20:19:51 - Eddie Windows Interface Hack executed (Local Area Connection 2). 2016.12.02 20:19:52 - OpenVPN > TEST ROUTES: 0/0 succeeded len=0 ret=0 a=0 u/d=down. 2016.12.02 20:19:52 - OpenVPN > Route: Waiting for TUN/TAP interface to come up.... 2016.12.02 20:19:52 - Eddie Windows Interface Hack executed (Local Area Connection 2). 2016.12.02 20:19:53 - OpenVPN > TEST ROUTES: 0/0 succeeded len=0 ret=0 a=0 u/d=down. 2016.12.02 20:19:53 - OpenVPN > Route: Waiting for TUN/TAP interface to come up.... 2016.12.02 20:19:53 - Eddie Windows Interface Hack executed (Local Area Connection 2). 2016.12.02 20:19:54 - OpenVPN > TEST ROUTES: 0/0 succeeded len=0 ret=0 a=0 u/d=down. 2016.12.02 20:19:54 - OpenVPN > Route: Waiting for TUN/TAP interface to come up.... 2016.12.02 20:19:54 - Eddie Windows Interface Hack executed (Local Area Connection 2). 2016.12.02 20:19:55 - OpenVPN > TEST ROUTES: 0/0 succeeded len=0 ret=0 a=0 u/d=down. 2016.12.02 20:19:55 - OpenVPN > Route: Waiting for TUN/TAP interface to come up.... 2016.12.02 20:19:55 - Eddie Windows Interface Hack executed (Local Area Connection 2). 2016.12.02 20:19:56 - OpenVPN > TEST ROUTES: 0/0 succeeded len=0 ret=0 a=0 u/d=down. 2016.12.02 20:19:56 - OpenVPN > Route: Waiting for TUN/TAP interface to come up.... 2016.12.02 20:19:56 - Eddie Windows Interface Hack executed (Local Area Connection 2)W 2016.12.02 20:19:56 - Checking route, 4° try failed (The operation has timed out). 2016.12.02 20:19:57 - OpenVPN > TEST ROUTES: 0/0 succeeded len=0 ret=0 a=0 u/d=down. 2016.12.02 20:19:57 - OpenVPN > Route: Waiting for TUN/TAP interface to come up.... 2016.12.02 20:19:57 - Eddie Windows Interface Hack executed (Local Area Connection 2). 2016.12.02 20:19:58 - OpenVPN > TEST ROUTES: 0/0 succeeded len=0 ret=0 a=0 u/d=down. 2016.12.02 20:19:58 - OpenVPN > Route: Waiting for TUN/TAP interface to come up.... 2016.12.02 20:19:58 - Eddie Windows Interface Hack executed (Local Area Connection 2). 2016.12.02 20:19:59 - OpenVPN > TEST ROUTES: 0/0 succeeded len=0 ret=0 a=0 u/d=down. 2016.12.02 20:19:59 - OpenVPN > Route: Waiting for TUN/TAP interface to come up.... 2016.12.02 20:19:59 - Eddie Windows Interface Hack executed (Local Area Connection 2). 2016.12.02 20:20:00 - OpenVPN > TEST ROUTES: 0/0 succeeded len=0 ret=0 a=0 u/d=down. 2016.12.02 20:20:00 - OpenVPN > C:\WINDOWS\system32\route.exe ADD 213.152.162.180 MASK 255.255.255.255 192.168.1.1. 2016.12.02 20:20:00 - OpenVPN > ROUTE: CreateIpForwardEntry succeeded with dwForwardMetric1=45 and dwForwardType=4. 2016.12.02 20:20:00 - OpenVPN > Route addition via IPAPI succeeded [adaptive]. 2016.12.02 20:20:00 - OpenVPN > C:\WINDOWS\system32\route.exe ADD 0.0.0.0 MASK 128.0.0.0 10.4.0.1. 2016.12.02 20:20:00 - OpenVPN > ROUTE: CreateIpForwardEntry succeeded with dwForwardMetric1=35 and dwForwardType=4. 2016.12.02 20:20:00 - OpenVPN > Route addition via IPAPI succeeded [adaptive]. 2016.12.02 20:20:00 - OpenVPN > C:\WINDOWS\system32\route.exe ADD 128.0.0.0 MASK 128.0.0.0 10.4.0.1. 2016.12.02 20:20:00 - OpenVPN > ROUTE: CreateIpForwardEntry succeeded with dwForwardMetric1=35 and dwForwardType=4. 2016.12.02 20:20:00 - OpenVPN > Route addition via IPAPI succeeded [adaptive]. 2016.12.02 20:20:00 - OpenVPN > SYSTEM ROUTING TABLE. 2016.12.02 20:20:00 - OpenVPN > 0.0.0.0 0.0.0.0 192.168.1.1 p=0 i=17 t=4 pr=3 a=10770 h=0 m=45/0/0/0/0. 2016.12.02 20:20:00 - OpenVPN > 0.0.0.0 128.0.0.0 10.4.0.1 p=0 i=18 t=4 pr=3 a=0 h=0 m=35/0/0/0/0. 2016.12.02 20:20:00 - OpenVPN > 10.4.0.0 255.255.0.0 10.4.92.206 p=0 i=18 t=3 pr=2 a=10728 h=0 m=291/0/0/0/0. 2016.12.02 20:20:00 - OpenVPN > 10.4.92.206 255.255.255.255 10.4.92.206 p=0 i=18 t=3 pr=2 a=10728 h=0 m=291/0/0/0/0. 2016.12.02 20:20:00 - OpenVPN > 10.4.255.255 255.255.255.255 10.4.92.206 p=0 i=18 t=3 pr=2 a=10728 h=0 m=291/0/0/0/0. 2016.12.02 20:20:00 - OpenVPN > 127.0.0.0 255.0.0.0 127.0.0.1 p=0 i=1 t=3 pr=2 a=10779 h=0 m=331/0/0/0/0. 2016.12.02 20:20:00 - OpenVPN > 127.0.0.1 255.255.255.255 127.0.0.1 p=0 i=1 t=3 pr=2 a=10779 h=0 m=331/0/0/0/0. 2016.12.02 20:20:00 - OpenVPN > 127.255.255.255 255.255.255.255 127.0.0.1 p=0 i=1 t=3 pr=2 a=10779 h=0 m=331/0/0/0/0. 2016.12.02 20:20:00 - OpenVPN > 128.0.0.0 128.0.0.0 10.4.0.1 p=0 i=18 t=4 pr=3 a=0 h=0 m=35/0/0/0/0. 2016.12.02 20:20:00 - OpenVPN > 192.168.1.0 255.255.255.0 192.168.1.101 p=0 i=17 t=3 pr=2 a=10770 h=0 m=301/0/0/0/0. 2016.12.02 20:20:00 - OpenVPN > 192.168.1.101 255.255.255.255 192.168.1.101 p=0 i=17 t=3 pr=2 a=10770 h=0 m=301/0/0/0/0. 2016.12.02 20:20:00 - OpenVPN > 192.168.1.255 255.255.255.255 192.168.1.101 p=0 i=17 t=3 pr=2 a=10770 h=0 m=301/0/0/0/0. 2016.12.02 20:20:00 - OpenVPN > 213.152.162.180 255.255.255.255 192.168.1.1 p=0 i=17 t=4 pr=3 a=0 h=0 m=45/0/0/0/0. 2016.12.02 20:20:00 - OpenVPN > 224.0.0.0 240.0.0.0 127.0.0.1 p=0 i=1 t=3 pr=2 a=10779 h=0 m=331/0/0/0/0. 2016.12.02 20:20:00 - OpenVPN > 224.0.0.0 240.0.0.0 10.4.92.206 p=0 i=18 t=3 pr=2 a=10778 h=0 m=291/0/0/0/0. 2016.12.02 20:20:00 - OpenVPN > 224.0.0.0 240.0.0.0 192.168.1.101 p=0 i=17 t=3 pr=2 a=10772 h=0 m=301/0/0/0/0. 2016.12.02 20:20:00 - OpenVPN > 255.255.255.255 255.255.255.255 127.0.0.1 p=0 i=1 t=3 pr=2 a=10779 h=0 m=331/0/0/0/0. 2016.12.02 20:20:00 - OpenVPN > 255.255.255.255 255.255.255.255 10.4.92.206 p=0 i=18 t=3 pr=2 a=10778 h=0 m=291/0/0/0/0. 2016.12.02 20:20:00 - OpenVPN > 255.255.255.255 255.255.255.255 192.168.1.101 p=0 i=17 t=3 pr=2 a=10772 h=0 m=301/0/0/0/0. 2016.12.02 20:20:00 - OpenVPN > SYSTEM ADAPTER LIST. 2016.12.02 20:20:00 - OpenVPN > Intel® Ethernet Connection I217-V. 2016.12.02 20:20:00 - OpenVPN > Index = 3. 2016.12.02 20:20:00 - OpenVPN > GUID = {1795EC65-5262-4A75-876C-4AF7E8D0D4EB}. 2016.12.02 20:20:00 - OpenVPN > IP = 0.0.0.0/0.0.0.0. 2016.12.02 20:20:00 - OpenVPN > MAC = 74:d4:35:eb:63:3e. 2016.12.02 20:20:00 - OpenVPN > GATEWAY = 0.0.0.0/255.255.255.255. 2016.12.02 20:20:00 - OpenVPN > DHCP SERV =. 2016.12.02 20:20:00 - OpenVPN > DHCP LEASE OBTAINED = Fri Dec 02 20:20:00 2016. 2016.12.02 20:20:00 - OpenVPN > DHCP LEASE EXPIRES = Fri Dec 02 20:20:00 2016. 2016.12.02 20:20:00 - OpenVPN > DNS SERV =. 2016.12.02 20:20:00 - OpenVPN > TAP-Windows Adapter V9. 2016.12.02 20:20:00 - OpenVPN > Index = 18. 2016.12.02 20:20:00 - OpenVPN > GUID = {F40AE409-E4BC-4ABA-B9F7-3BD827158EE3}. 2016.12.02 20:20:00 - OpenVPN > IP = 10.4.92.206/255.255.0.0. 2016.12.02 20:20:00 - OpenVPN > MAC = 00:ff:f4:0a:e4:09. 2016.12.02 20:20:00 - OpenVPN > GATEWAY = 0.0.0.0/255.255.255.255. 2016.12.02 20:20:00 - OpenVPN > DHCP SERV = 10.4.255.254/255.255.255.255. 2016.12.02 20:20:00 - OpenVPN > DHCP LEASE OBTAINED = Fri Dec 02 17:21:12 2016. 2016.12.02 20:20:00 - OpenVPN > DHCP LEASE EXPIRES = Sat Dec 02 17:21:12 2017. 2016.12.02 20:20:00 - OpenVPN > DNS SERV = 10.4.0.1/255.255.255.255. 2016.12.02 20:20:00 - OpenVPN > 300Mbps Wireless USB Adapter. 2016.12.02 20:20:00 - OpenVPN > Index = 17. 2016.12.02 20:20:00 - OpenVPN > GUID = {D6DBB021-16B1-4402-97B4-1CEEE4201C7C}. 2016.12.02 20:20:00 - OpenVPN > IP = 192.168.1.101/255.255.255.0. 2016.12.02 20:20:00 - OpenVPN > MAC = 14:cc:20:17:0d:7f. 2016.12.02 20:20:00 - OpenVPN > GATEWAY = 192.168.1.1/255.255.255.255. 2016.12.02 20:20:00 - OpenVPN > DHCP SERV = 192.168.1.1/255.255.255.255. 2016.12.02 20:20:00 - OpenVPN > DHCP LEASE OBTAINED = Fri Dec 02 18:11:06 2016. 2016.12.02 20:20:00 - OpenVPN > DHCP LEASE EXPIRES = Sat Dec 03 18:11:06 2016. 2016.12.02 20:20:00 - OpenVPN > DNS SERV = 10.4.0.1/255.255.255.255. 2016.12.02 20:20:00 - OpenVPN > Microsoft Wi-Fi Direct Virtual Adapter. 2016.12.02 20:20:00 - OpenVPN > Index = 13. 2016.12.02 20:20:00 - OpenVPN > GUID = {AEB675DF-7F7D-4FED-BC91-F8C40081B696}. 2016.12.02 20:20:00 - OpenVPN > IP = 0.0.0.0/0.0.0.0. 2016.12.02 20:20:00 - OpenVPN > MAC = 14:cc:20:17:0d:7f. 2016.12.02 20:20:00 - OpenVPN > GATEWAY = 0.0.0.0/255.255.255.255. 2016.12.02 20:20:00 - OpenVPN > DHCP SERV =. 2016.12.02 20:20:00 - OpenVPN > DHCP LEASE OBTAINED = Fri Dec 02 20:20:00 2016. 2016.12.02 20:20:00 - OpenVPN > DHCP LEASE EXPIRES = Fri Dec 02 20:20:00 2016. 2016.12.02 20:20:00 - OpenVPN > DNS SERV =. 2016.12.02 20:20:00 - Starting Management Interface. 2016.12.02 20:20:00 - OpenVPN > Initialization Sequence Completed With Errors ( see http://openvpn.net/faq.html#dhcpclientserv )! 2016.12.02 20:20:00 - Disconnecting. 2016.12.02 20:20:00 - Management - Send 'signal SIGTERM'. 2016.12.02 20:20:00 - OpenVpn Management > >INFO:OpenVPN Management Interface Version 1 -- type 'help' for more info. 2016.12.02 20:20:00 - DNS leak protection with packet filtering enabled.I 2016.12.02 20:20:00 - Flushing DNSW 2016.12.02 20:20:00 - Checking route, 5° try failed (The remote name could not be resolved: 'nash_exit.airservers.org')W 2016.12.02 20:20:00 - The remote name could not be resolved: 'nash_exit.airservers.org'. 2016.12.02 20:20:00 - OpenVPN > MANAGEMENT: CMD 'signal SIGTERM'. 2016.12.02 20:20:00 - OpenVPN > SIGTERM received, sending exit notification to peer. 2016.12.02 20:20:00 - OpenVPN > C:\WINDOWS\system32\route.exe DELETE 213.152.162.113 MASK 255.255.255.255 192.168.1.1. 2016.12.02 20:20:00 - OpenVPN > Route deletion via IPAPI succeeded [adaptive]. 2016.12.02 20:20:00 - OpenVPN > C:\WINDOWS\system32\route.exe DELETE 0.0.0.0 MASK 128.0.0.0 10.4.0.1. 2016.12.02 20:20:00 - OpenVPN > Route deletion via IPAPI succeeded [adaptive]. 2016.12.02 20:20:00 - OpenVPN > C:\WINDOWS\system32\route.exe DELETE 128.0.0.0 MASK 128.0.0.0 10.4.0.1. 2016.12.02 20:20:00 - OpenVPN > Route deletion via IPAPI succeeded [adaptive]. 2016.12.02 20:20:00 - OpenVPN > Closing TUN/TAP interface. 2016.12.02 20:20:00 - OpenVPN > SIGTERM[soft,exit-with-notification] received, process exiting. 2016.12.02 20:20:05 - Connection terminated.. 2016.12.02 20:20:05 - DNS leak protection with packet filtering disabled.I 2016.12.02 20:20:08 - Checking authorization ...! 2016.12.02 20:20:08 - Connecting to Miram (Netherlands, Alblasserdam). 2016.12.02 20:20:08 - OpenVPN > OpenVPN 2.3.13 x86_64-w64-mingw32 [sSL (OpenSSL)] [LZO] [iPv6] built on Nov 10 2016. 2016.12.02 20:20:08 - OpenVPN > Windows version 6.2 (Windows 8 or greater) 64bit. 2016.12.02 20:20:08 - OpenVPN > library versions: OpenSSL 1.0.2j 26 Sep 2016, LZO 2.09. 2016.12.02 20:20:08 - OpenVPN > MANAGEMENT: TCP Socket listening on [AF_INET]127.0.0.1:3100. 2016.12.02 20:20:08 - OpenVPN > Control Channel Authentication: tls-auth using INLINE static key file. 2016.12.02 20:20:08 - OpenVPN > Outgoing Control Channel Authentication: Using 160 bit message hash 'SHA1' for HMAC authentication. 2016.12.02 20:20:08 - OpenVPN > Incoming Control Channel Authentication: Using 160 bit message hash 'SHA1' for HMAC authentication. 2016.12.02 20:20:08 - OpenVPN > Socket Buffers: R=[65536->262144] S=[65536->262144]. 2016.12.02 20:20:08 - OpenVPN > UDPv4 link local: [undef]. 2016.12.02 20:20:08 - OpenVPN > UDPv4 link remote: [AF_INET]213.152.162.88:443. 2016.12.02 20:20:08 - OpenVPN > TLS: Initial packet from [AF_INET]213.152.162.88:443, sid=12a14555 c9f545b5I 2016.12.02 20:20:09 - Checking route. 2016.12.02 20:20:09 - OpenVPN > VERIFY OK: depth=1, C=IT, ST=IT, L=Perugia, O=airvpn.org, CN=airvpn.org CA, emailAddress=info@airvpn.org. 2016.12.02 20:20:09 - OpenVPN > Validating certificate key usage. 2016.12.02 20:20:09 - OpenVPN > ++ Certificate has key usage 00a0, expects 00a0. 2016.12.02 20:20:09 - OpenVPN > VERIFY KU OK. 2016.12.02 20:20:09 - OpenVPN > Validating certificate extended key usage. 2016.12.02 20:20:09 - OpenVPN > ++ Certificate has EKU (str) TLS Web Server Authentication, expects TLS Web Server Authentication. 2016.12.02 20:20:09 - OpenVPN > VERIFY EKU OK. 2016.12.02 20:20:09 - OpenVPN > VERIFY OK: depth=0, C=IT, ST=IT, L=Perugia, O=airvpn.org, CN=server, emailAddress=info@airvpn.org. 2016.12.02 20:20:09 - OpenVPN > Data Channel Encrypt: Cipher 'AES-256-CBC' initialized with 256 bit key. 2016.12.02 20:20:09 - OpenVPN > Data Channel Encrypt: Using 160 bit message hash 'SHA1' for HMAC authentication. 2016.12.02 20:20:09 - OpenVPN > Data Channel Decrypt: Cipher 'AES-256-CBC' initialized with 256 bit key. 2016.12.02 20:20:09 - OpenVPN > Data Channel Decrypt: Using 160 bit message hash 'SHA1' for HMAC authentication. 2016.12.02 20:20:09 - OpenVPN > Control Channel: TLSv1.2, cipher TLSv1/SSLv3 DHE-RSA-AES256-GCM-SHA384, 4096 bit RSA. 2016.12.02 20:20:09 - OpenVPN > [server] Peer Connection Initiated with [AF_INET]213.152.162.88:443. 2016.12.02 20:20:11 - OpenVPN > SENT CONTROL [server]: 'PUSH_REQUEST' (status=1). 2016.12.02 20:20:11 - OpenVPN > PUSH: Received control message: 'PUSH_REPLY,redirect-gateway def1 bypass-dhcp,dhcp-option DNS 10.4.0.1,comp-lzo no,route-gateway 10.4.0.1,topology subnet,ping 10,ping-restart 60,ifconfig 10.4.92.19 255.255.0.0'. 2016.12.02 20:20:11 - OpenVPN > OPTIONS IMPORT: timers and/or timeouts modified. 2016.12.02 20:20:11 - OpenVPN > OPTIONS IMPORT: LZO parms modified. 2016.12.02 20:20:11 - OpenVPN > OPTIONS IMPORT: --ifconfig/up options modified. 2016.12.02 20:20:11 - OpenVPN > OPTIONS IMPORT: route options modified. 2016.12.02 20:20:11 - OpenVPN > OPTIONS IMPORT: route-related options modified. 2016.12.02 20:20:11 - OpenVPN > OPTIONS IMPORT: --ip-win32 and/or --dhcp-option options modified. 2016.12.02 20:20:11 - OpenVPN > ROUTE_GATEWAY 192.168.1.1/255.255.255.0 I=17 HWADDR=14:cc:20:17:0d:7f. 2016.12.02 20:20:11 - OpenVPN > do_ifconfig, tt->ipv6=0, tt->did_ifconfig_ipv6_setup=0. 2016.12.02 20:20:11 - OpenVPN > open_tun, tt->ipv6=0. 2016.12.02 20:20:11 - OpenVPN > TAP-WIN32 device [Local Area Connection 2] opened: \\.\Global\{F40AE409-E4BC-4ABA-B9F7-3BD827158EE3}.tap. 2016.12.02 20:20:11 - OpenVPN > TAP-Windows Driver Version 9.21. 2016.12.02 20:20:11 - OpenVPN > Set TAP-Windows TUN subnet mode network/local/netmask = 10.4.0.0/10.4.92.19/255.255.0.0 [sUCCEEDED]. 2016.12.02 20:20:11 - OpenVPN > Notified TAP-Windows driver to set a DHCP IP/netmask of 10.4.92.19/255.255.0.0 on interface {F40AE409-E4BC-4ABA-B9F7-3BD827158EE3} [DHCP-serv: 10.4.255.254, lease-time: 31536000]. 2016.12.02 20:20:11 - OpenVPN > Successful ARP Flush on interface [18] {F40AE409-E4BC-4ABA-B9F7-3BD827158EE3}. 2016.12.02 20:20:17 - OpenVPN > TEST ROUTES: 0/0 succeeded len=0 ret=0 a=0 u/d=down. 2016.12.02 20:20:17 - OpenVPN > Route: Waiting for TUN/TAP interface to come up.... 2016.12.02 20:20:17 - Eddie Windows Interface Hack executed (Local Area Connection 2)W 2016.12.02 20:20:21 - Checking route, 1° try failed (The operation has timed out). 2016.12.02 20:20:21 - OpenVPN > TEST ROUTES: 0/0 succeeded len=0 ret=0 a=0 u/d=down. 2016.12.02 20:20:21 - OpenVPN > Route: Waiting for TUN/TAP interface to come up.... 2016.12.02 20:20:21 - Eddie Windows Interface Hack executed (Local Area Connection 2). 2016.12.02 20:20:22 - OpenVPN > TEST ROUTES: 0/0 succeeded len=0 ret=0 a=0 u/d=down. 2016.12.02 20:20:22 - OpenVPN > Route: Waiting for TUN/TAP interface to come up.... 2016.12.02 20:20:22 - Eddie Windows Interface Hack executed (Local Area Connection 2). 2016.12.02 20:20:23 - OpenVPN > TEST ROUTES: 0/0 succeeded len=0 ret=0 a=0 u/d=down. 2016.12.02 20:20:23 - OpenVPN > Route: Waiting for TUN/TAP interface to come up.... 2016.12.02 20:20:23 - Eddie Windows Interface Hack executed (Local Area Connection 2). 2016.12.02 20:20:24 - OpenVPN > TEST ROUTES: 0/0 succeeded len=0 ret=0 a=0 u/d=down. 2016.12.02 20:20:24 - OpenVPN > Route: Waiting for TUN/TAP interface to come up.... 2016.12.02 20:20:24 - Eddie Windows Interface Hack executed (Local Area Connection 2). 2016.12.02 20:20:25 - OpenVPN > TEST ROUTES: 0/0 succeeded len=0 ret=0 a=0 u/d=down. 2016.12.02 20:20:25 - OpenVPN > Route: Waiting for TUN/TAP interface to come up.... 2016.12.02 20:20:25 - Eddie Windows Interface Hack executed (Local Area Connection 2). 2016.12.02 20:20:26 - OpenVPN > TEST ROUTES: 0/0 succeeded len=0 ret=0 a=0 u/d=down. 2016.12.02 20:20:26 - OpenVPN > Route: Waiting for TUN/TAP interface to come up.... 2016.12.02 20:20:26 - Eddie Windows Interface Hack executed (Local Area Connection 2). 2016.12.02 20:20:27 - OpenVPN > TEST ROUTES: 0/0 succeeded len=0 ret=0 a=0 u/d=down. 2016.12.02 20:20:27 - OpenVPN > Route: Waiting for TUN/TAP interface to come up.... 2016.12.02 20:20:28 - Eddie Windows Interface Hack executed (Local Area Connection 2). 2016.12.02 20:20:29 - OpenVPN > TEST ROUTES: 0/0 succeeded len=0 ret=0 a=0 u/d=down. 2016.12.02 20:20:29 - OpenVPN > Route: Waiting for TUN/TAP interface to come up.... 2016.12.02 20:20:29 - Eddie Windows Interface Hack executed (Local Area Connection 2). 2016.12.02 20:20:30 - OpenVPN > TEST ROUTES: 0/0 succeeded len=0 ret=0 a=0 u/d=down. 2016.12.02 20:20:30 - OpenVPN > Route: Waiting for TUN/TAP interface to come up.... 2016.12.02 20:20:30 - Eddie Windows Interface Hack executed (Local Area Connection 2). 2016.12.02 20:20:31 - OpenVPN > TEST ROUTES: 0/0 succeeded len=0 ret=0 a=0 u/d=down. 2016.12.02 20:20:31 - OpenVPN > Route: Waiting for TUN/TAP interface to come up.... 2016.12.02 20:20:31 - Eddie Windows Interface Hack executed (Local Area Connection 2). 2016.12.02 20:20:32 - OpenVPN > TEST ROUTES: 0/0 succeeded len=0 ret=0 a=0 u/d=down. 2016.12.02 20:20:32 - OpenVPN > Route: Waiting for TUN/TAP interface to come up.... 2016.12.02 20:20:32 - Eddie Windows Interface Hack executed (Local Area Connection 2)W 2016.12.02 20:20:33 - Checking route, 2° try failed (The operation has timed out). 2016.12.02 20:20:33 - OpenVPN > TEST ROUTES: 0/0 succeeded len=0 ret=0 a=0 u/d=down. 2016.12.02 20:20:33 - OpenVPN > Route: Waiting for TUN/TAP interface to come up.... 2016.12.02 20:20:33 - Eddie Windows Interface Hack executed (Local Area Connection 2). 2016.12.02 20:20:34 - OpenVPN > TEST ROUTES: 0/0 succeeded len=0 ret=0 a=0 u/d=down. 2016.12.02 20:20:34 - OpenVPN > Route: Waiting for TUN/TAP interface to come up.... 2016.12.02 20:20:34 - Eddie Windows Interface Hack executed (Local Area Connection 2). 2016.12.02 20:20:35 - OpenVPN > TEST ROUTES: 0/0 succeeded len=0 ret=0 a=0 u/d=down. 2016.12.02 20:20:35 - OpenVPN > Route: Waiting for TUN/TAP interface to come up.... 2016.12.02 20:20:35 - Eddie Windows Interface Hack executed (Local Area Connection 2). 2016.12.02 20:20:36 - OpenVPN > TEST ROUTES: 0/0 succeeded len=0 ret=0 a=0 u/d=down. 2016.12.02 20:20:36 - OpenVPN > Route: Waiting for TUN/TAP interface to come up.... 2016.12.02 20:20:36 - Eddie Windows Interface Hack executed (Local Area Connection 2). 2016.12.02 20:20:37 - OpenVPN > TEST ROUTES: 0/0 succeeded len=0 ret=0 a=0 u/d=down. 2016.12.02 20:20:37 - OpenVPN > Route: Waiting for TUN/TAP interface to come up.... 2016.12.02 20:20:37 - Eddie Windows Interface Hack executed (Local Area Connection 2). 2016.12.02 20:20:39 - OpenVPN > TEST ROUTES: 0/0 succeeded len=0 ret=0 a=0 u/d=down. 2016.12.02 20:20:39 - OpenVPN > Route: Waiting for TUN/TAP interface to come up.... 2016.12.02 20:20:39 - Eddie Windows Interface Hack executed (Local Area Connection 2). 2016.12.02 20:20:40 - OpenVPN > TEST ROUTES: 0/0 succeeded len=0 ret=0 a=0 u/d=down. 2016.12.02 20:20:40 - OpenVPN > Route: Waiting for TUN/TAP interface to come up.... 2016.12.02 20:20:40 - Eddie Windows Interface Hack executed (Local Area Connection 2). 2016.12.02 20:20:41 - OpenVPN > TEST ROUTES: 0/0 succeeded len=0 ret=0 a=0 u/d=down. 2016.12.02 20:20:41 - OpenVPN > Route: Waiting for TUN/TAP interface to come up.... 2016.12.02 20:20:41 - Eddie Windows Interface Hack executed (Local Area Connection 2). 2016.12.02 20:20:42 - OpenVPN > TEST ROUTES: 0/0 succeeded len=0 ret=0 a=0 u/d=down. 2016.12.02 20:20:42 - OpenVPN > Route: Waiting for TUN/TAP interface to come up.... 2016.12.02 20:20:42 - Eddie Windows Interface Hack executed (Local Area Connection 2). 2016.12.02 20:20:43 - OpenVPN > TEST ROUTES: 0/0 succeeded len=0 ret=0 a=0 u/d=down. 2016.12.02 20:20:43 - OpenVPN > Route: Waiting for TUN/TAP interface to come up.... 2016.12.02 20:20:43 - Eddie Windows Interface Hack executed (Local Area Connection 2). 2016.12.02 20:20:44 - OpenVPN > TEST ROUTES: 0/0 succeeded len=0 ret=0 a=0 u/d=down. 2016.12.02 20:20:44 - OpenVPN > Route: Waiting for TUN/TAP interface to come up.... 2016.12.02 20:20:44 - Eddie Windows Interface Hack executed (Local Area Connection 2)W 2016.12.02 20:20:45 - Checking route, 3° try failed (The operation has timed out). 2016.12.02 20:20:45 - OpenVPN > TEST ROUTES: 0/0 succeeded len=0 ret=0 a=0 u/d=down. 2016.12.02 20:20:45 - OpenVPN > Route: Waiting for TUN/TAP interface to come up.... 2016.12.02 20:20:45 - Eddie Windows Interface Hack executed (Local Area Connection 2). 2016.12.02 20:20:46 - OpenVPN > TEST ROUTES: 0/0 succeeded len=0 ret=0 a=0 u/d=down. 2016.12.02 20:20:46 - OpenVPN > C:\WINDOWS\system32\route.exe ADD 213.152.162.88 MASK 255.255.255.255 192.168.1.1. 2016.12.02 20:20:46 - OpenVPN > ROUTE: CreateIpForwardEntry succeeded with dwForwardMetric1=45 and dwForwardType=4. 2016.12.02 20:20:46 - OpenVPN > Route addition via IPAPI succeeded [adaptive]. 2016.12.02 20:20:46 - OpenVPN > C:\WINDOWS\system32\route.exe ADD 0.0.0.0 MASK 128.0.0.0 10.4.0.1. 2016.12.02 20:20:46 - OpenVPN > ROUTE: CreateIpForwardEntry succeeded with dwForwardMetric1=35 and dwForwardType=4. 2016.12.02 20:20:46 - OpenVPN > Route addition via IPAPI succeeded [adaptive]. 2016.12.02 20:20:46 - OpenVPN > C:\WINDOWS\system32\route.exe ADD 128.0.0.0 MASK 128.0.0.0 10.4.0.1. 2016.12.02 20:20:46 - OpenVPN > ROUTE: CreateIpForwardEntry succeeded with dwForwardMetric1=35 and dwForwardType=4. 2016.12.02 20:20:46 - OpenVPN > Route addition via IPAPI succeeded [adaptive]. 2016.12.02 20:20:46 - OpenVPN > SYSTEM ROUTING TABLE. 2016.12.02 20:20:46 - OpenVPN > 0.0.0.0 0.0.0.0 192.168.1.1 p=0 i=17 t=4 pr=3 a=10815 h=0 m=45/0/0/0/0. 2016.12.02 20:20:46 - OpenVPN > 0.0.0.0 128.0.0.0 10.4.0.1 p=0 i=18 t=4 pr=3 a=0 h=0 m=35/0/0/0/0. 2016.12.02 20:20:46 - OpenVPN > 10.4.0.0 255.255.0.0 10.4.92.206 p=0 i=18 t=3 pr=2 a=10774 h=0 m=291/0/0/0/0. 2016.12.02 20:20:46 - OpenVPN > 10.4.92.206 255.255.255.255 10.4.92.206 p=0 i=18 t=3 pr=2 a=10774 h=0 m=291/0/0/0/0. 2016.12.02 20:20:46 - OpenVPN > 10.4.255.255 255.255.255.255 10.4.92.206 p=0 i=18 t=3 pr=2 a=10774 h=0 m=291/0/0/0/0. 2016.12.02 20:20:46 - OpenVPN > 127.0.0.0 255.0.0.0 127.0.0.1 p=0 i=1 t=3 pr=2 a=10824 h=0 m=331/0/0/0/0. 2016.12.02 20:20:46 - OpenVPN > 127.0.0.1 255.255.255.255 127.0.0.1 p=0 i=1 t=3 pr=2 a=10824 h=0 m=331/0/0/0/0. 2016.12.02 20:20:46 - OpenVPN > 127.255.255.255 255.255.255.255 127.0.0.1 p=0 i=1 t=3 pr=2 a=10824 h=0 m=331/0/0/0/0. 2016.12.02 20:20:46 - OpenVPN > 128.0.0.0 128.0.0.0 10.4.0.1 p=0 i=18 t=4 pr=3 a=0 h=0 m=35/0/0/0/0. 2016.12.02 20:20:46 - OpenVPN > 192.168.1.0 255.255.255.0 192.168.1.101 p=0 i=17 t=3 pr=2 a=10815 h=0 m=301/0/0/0/0. 2016.12.02 20:20:46 - OpenVPN > 192.168.1.101 255.255.255.255 192.168.1.101 p=0 i=17 t=3 pr=2 a=10815 h=0 m=301/0/0/0/0. 2016.12.02 20:20:46 - OpenVPN > 192.168.1.255 255.255.255.255 192.168.1.101 p=0 i=17 t=3 pr=2 a=10815 h=0 m=301/0/0/0/0. 2016.12.02 20:20:46 - OpenVPN > 213.152.162.88 255.255.255.255 192.168.1.1 p=0 i=17 t=4 pr=3 a=0 h=0 m=45/0/0/0/0. 2016.12.02 20:20:46 - OpenVPN > 224.0.0.0 240.0.0.0 127.0.0.1 p=0 i=1 t=3 pr=2 a=10824 h=0 m=331/0/0/0/0. 2016.12.02 20:20:46 - OpenVPN > 224.0.0.0 240.0.0.0 10.4.92.206 p=0 i=18 t=3 pr=2 a=10823 h=0 m=291/0/0/0/0. 2016.12.02 20:20:46 - OpenVPN > 224.0.0.0 240.0.0.0 192.168.1.101 p=0 i=17 t=3 pr=2 a=10817 h=0 m=301/0/0/0/0. 2016.12.02 20:20:46 - OpenVPN > 255.255.255.255 255.255.255.255 127.0.0.1 p=0 i=1 t=3 pr=2 a=10824 h=0 m=331/0/0/0/0. 2016.12.02 20:20:46 - OpenVPN > 255.255.255.255 255.255.255.255 10.4.92.206 p=0 i=18 t=3 pr=2 a=10823 h=0 m=291/0/0/0/0. 2016.12.02 20:20:46 - OpenVPN > 255.255.255.255 255.255.255.255 192.168.1.101 p=0 i=17 t=3 pr=2 a=10817 h=0 m=301/0/0/0/0. 2016.12.02 20:20:46 - OpenVPN > SYSTEM ADAPTER LIST. 2016.12.02 20:20:46 - OpenVPN > Intel® Ethernet Connection I217-V. 2016.12.02 20:20:46 - OpenVPN > Index = 3. 2016.12.02 20:20:46 - OpenVPN > GUID = {1795EC65-5262-4A75-876C-4AF7E8D0D4EB}. 2016.12.02 20:20:46 - OpenVPN > IP = 0.0.0.0/0.0.0.0. 2016.12.02 20:20:46 - OpenVPN > MAC = 74:d4:35:eb:63:3e. 2016.12.02 20:20:46 - OpenVPN > GATEWAY = 0.0.0.0/255.255.255.255. 2016.12.02 20:20:46 - OpenVPN > DHCP SERV =. 2016.12.02 20:20:46 - OpenVPN > DHCP LEASE OBTAINED = Fri Dec 02 20:20:46 2016. 2016.12.02 20:20:46 - OpenVPN > DHCP LEASE EXPIRES = Fri Dec 02 20:20:46 2016. 2016.12.02 20:20:46 - OpenVPN > DNS SERV =. 2016.12.02 20:20:46 - OpenVPN > TAP-Windows Adapter V9. 2016.12.02 20:20:46 - OpenVPN > Index = 18. 2016.12.02 20:20:46 - OpenVPN > GUID = {F40AE409-E4BC-4ABA-B9F7-3BD827158EE3}. 2016.12.02 20:20:46 - OpenVPN > IP = 10.4.92.206/255.255.0.0. 2016.12.02 20:20:46 - OpenVPN > MAC = 00:ff:f4:0a:e4:09. 2016.12.02 20:20:46 - OpenVPN > GATEWAY = 0.0.0.0/255.255.255.255. 2016.12.02 20:20:46 - OpenVPN > DHCP SERV = 10.4.255.254/255.255.255.255. 2016.12.02 20:20:46 - OpenVPN > DHCP LEASE OBTAINED = Fri Dec 02 17:21:12 2016. 2016.12.02 20:20:46 - OpenVPN > DHCP LEASE EXPIRES = Sat Dec 02 17:21:12 2017. 2016.12.02 20:20:46 - OpenVPN > DNS SERV = 10.4.0.1/255.255.255.255. 2016.12.02 20:20:46 - OpenVPN > 300Mbps Wireless USB Adapter. 2016.12.02 20:20:46 - OpenVPN > Index = 17. 2016.12.02 20:20:46 - OpenVPN > GUID = {D6DBB021-16B1-4402-97B4-1CEEE4201C7C}. 2016.12.02 20:20:46 - OpenVPN > IP = 192.168.1.101/255.255.255.0. 2016.12.02 20:20:46 - OpenVPN > MAC = 14:cc:20:17:0d:7f. 2016.12.02 20:20:46 - OpenVPN > GATEWAY = 192.168.1.1/255.255.255.255. 2016.12.02 20:20:46 - OpenVPN > DHCP SERV = 192.168.1.1/255.255.255.255. 2016.12.02 20:20:46 - OpenVPN > DHCP LEASE OBTAINED = Fri Dec 02 18:11:06 2016. 2016.12.02 20:20:46 - OpenVPN > DHCP LEASE EXPIRES = Sat Dec 03 18:11:06 2016. 2016.12.02 20:20:46 - OpenVPN > DNS SERV = 10.4.0.1/255.255.255.255. 2016.12.02 20:20:46 - OpenVPN > Microsoft Wi-Fi Direct Virtual Adapter. 2016.12.02 20:20:46 - OpenVPN > Index = 13. 2016.12.02 20:20:46 - OpenVPN > GUID = {AEB675DF-7F7D-4FED-BC91-F8C40081B696}. 2016.12.02 20:20:46 - OpenVPN > IP = 0.0.0.0/0.0.0.0. 2016.12.02 20:20:46 - OpenVPN > MAC = 14:cc:20:17:0d:7f. 2016.12.02 20:20:46 - OpenVPN > GATEWAY = 0.0.0.0/255.255.255.255. 2016.12.02 20:20:46 - OpenVPN > DHCP SERV =. 2016.12.02 20:20:46 - OpenVPN > DHCP LEASE OBTAINED = Fri Dec 02 20:20:46 2016. 2016.12.02 20:20:46 - OpenVPN > DHCP LEASE EXPIRES = Fri Dec 02 20:20:46 2016. 2016.12.02 20:20:46 - OpenVPN > DNS SERV =. 2016.12.02 20:20:46 - Starting Management Interface. 2016.12.02 20:20:46 - OpenVPN > Initialization Sequence Completed With Errors ( see http://openvpn.net/faq.html#dhcpclientserv ). 2016.12.02 20:20:46 - DNS leak protection with packet filtering enabled.I 2016.12.02 20:20:46 - Flushing DNS! 2016.12.02 20:20:46 - Disconnecting. 2016.12.02 20:20:46 - Management - Send 'signal SIGTERM'. 2016.12.02 20:20:46 - OpenVpn Management > >INFO:OpenVPN Management Interface Version 1 -- type 'help' for more infoW 2016.12.02 20:20:47 - Checking route, 4° try failed (The remote name could not be resolved: 'miram_exit.airservers.org'). 2016.12.02 20:20:51 - Connection terminated.. 2016.12.02 20:20:51 - DNS leak protection with packet filtering disabled.. 2016.12.02 20:20:52 - OpenVPN > MANAGEMENT: Client connected from [AF_INET]127.0.0.1:3100. 2016.12.02 20:20:52 - OpenVPN > MANAGEMENT: CMD 'signal SIGTERM'. 2016.12.02 20:20:52 - OpenVPN > SIGTERM received, sending exit notification to peer. 2016.12.02 20:20:52 - OpenVPN > C:\WINDOWS\system32\route.exe DELETE 213.152.162.88 MASK 255.255.255.255 192.168.1.1. 2016.12.02 20:20:52 - OpenVPN > Route deletion via IPAPI succeeded [adaptive]. 2016.12.02 20:20:52 - OpenVPN > C:\WINDOWS\system32\route.exe DELETE 0.0.0.0 MASK 128.0.0.0 10.4.0.1. 2016.12.02 20:20:52 - OpenVPN > Route deletion via IPAPI succeeded [adaptive]. 2016.12.02 20:20:52 - OpenVPN > C:\WINDOWS\system32\route.exe DELETE 128.0.0.0 MASK 128.0.0.0 10.4.0.1. 2016.12.02 20:20:52 - OpenVPN > Route deletion via IPAPI succeeded [adaptive]. 2016.12.02 20:20:52 - OpenVPN > Closing TUN/TAP interface. 2016.12.02 20:20:52 - OpenVPN > SIGTERM[soft,exit-with-notification] received, process exitingI 2016.12.02 20:20:54 - Checking authorization ...! 2016.12.02 20:20:55 - Connecting to Garnet (Netherlands, Alblasserdam). 2016.12.02 20:20:55 - OpenVPN > OpenVPN 2.3.13 x86_64-w64-mingw32 [sSL (OpenSSL)] [LZO] [iPv6] built on Nov 10 2016. 2016.12.02 20:20:55 - OpenVPN > Windows version 6.2 (Windows 8 or greater) 64bit. 2016.12.02 20:20:55 - OpenVPN > library versions: OpenSSL 1.0.2j 26 Sep 2016, LZO 2.09. 2016.12.02 20:20:55 - OpenVPN > MANAGEMENT: TCP Socket listening on [AF_INET]127.0.0.1:3100. 2016.12.02 20:20:55 - OpenVPN > Control Channel Authentication: tls-auth using INLINE static key file. 2016.12.02 20:20:55 - OpenVPN > Outgoing Control Channel Authentication: Using 160 bit message hash 'SHA1' for HMAC authentication. 2016.12.02 20:20:55 - OpenVPN > Incoming Control Channel Authentication: Using 160 bit message hash 'SHA1' for HMAC authentication. 2016.12.02 20:20:55 - OpenVPN > Socket Buffers: R=[65536->262144] S=[65536->262144]. 2016.12.02 20:20:55 - OpenVPN > UDPv4 link local: [undef]. 2016.12.02 20:20:55 - OpenVPN > UDPv4 link remote: [AF_INET]213.152.162.73:443. 2016.12.02 20:20:55 - OpenVPN > TLS: Initial packet from [AF_INET]213.152.162.73:443, sid=e96e02f8 c6b8c740. 2016.12.02 20:20:55 - OpenVPN > VERIFY OK: depth=1, C=IT, ST=IT, L=Perugia, O=airvpn.org, CN=airvpn.org CA, emailAddress=info@airvpn.org. 2016.12.02 20:20:55 - OpenVPN > Validating certificate key usage. 2016.12.02 20:20:55 - OpenVPN > ++ Certificate has key usage 00a0, expects 00a0. 2016.12.02 20:20:55 - OpenVPN > VERIFY KU OK. 2016.12.02 20:20:55 - OpenVPN > Validating certificate extended key usage. 2016.12.02 20:20:55 - OpenVPN > ++ Certificate has EKU (str) TLS Web Server Authentication, expects TLS Web Server Authentication. 2016.12.02 20:20:55 - OpenVPN > VERIFY EKU OK. 2016.12.02 20:20:55 - OpenVPN > VERIFY OK: depth=0, C=IT, ST=IT, L=Perugia, O=airvpn.org, CN=server, emailAddress=info@airvpn.org. 2016.12.02 20:20:59 - OpenVPN > Data Channel Encrypt: Cipher 'AES-256-CBC' initialized with 256 bit key. 2016.12.02 20:20:59 - OpenVPN > Data Channel Encrypt: Using 160 bit message hash 'SHA1' for HMAC authentication. 2016.12.02 20:20:59 - OpenVPN > Data Channel Decrypt: Cipher 'AES-256-CBC' initialized with 256 bit key. 2016.12.02 20:20:59 - OpenVPN > Data Channel Decrypt: Using 160 bit message hash 'SHA1' for HMAC authentication. 2016.12.02 20:20:59 - OpenVPN > Control Channel: TLSv1.2, cipher TLSv1/SSLv3 DHE-RSA-AES256-GCM-SHA384, 4096 bit RSA. 2016.12.02 20:20:59 - OpenVPN > [server] Peer Connection Initiated with [AF_INET]213.152.162.73:443W 2016.12.02 20:21:00 - Checking route, 5° try failed (The operation has timed out)W 2016.12.02 20:21:00 - The operation has timed out. 2016.12.02 20:21:00 - OpenVPN > MANAGEMENT: CMD 'signal SIGTERM'. 2016.12.02 20:21:00 - OpenVPN > SIGTERM received, sending exit notification to peer. 2016.12.02 20:21:00 - OpenVPN > C:\WINDOWS\system32\route.exe DELETE 213.152.162.180 MASK 255.255.255.255 192.168.1.1. 2016.12.02 20:21:00 - OpenVPN > Route deletion via IPAPI succeeded [adaptive]. 2016.12.02 20:21:00 - OpenVPN > C:\WINDOWS\system32\route.exe DELETE 0.0.0.0 MASK 128.0.0.0 10.4.0.1. 2016.12.02 20:21:00 - OpenVPN > Route deletion via IPAPI succeeded [adaptive]. 2016.12.02 20:21:00 - OpenVPN > C:\WINDOWS\system32\route.exe DELETE 128.0.0.0 MASK 128.0.0.0 10.4.0.1. 2016.12.02 20:21:00 - OpenVPN > Route deletion via IPAPI succeeded [adaptive]. 2016.12.02 20:21:00 - OpenVPN > Closing TUN/TAP interface. 2016.12.02 20:21:00 - OpenVPN > SIGTERM[soft,exit-with-notification] received, process exiting! 2016.12.02 20:21:00 - Disconnecting. 2016.12.02 20:21:00 - Connection terminated.I 2016.12.02 20:21:03 - Checking authorization ...! 2016.12.02 20:21:04 - Connecting to Merga (Netherlands, Alblasserdam). 2016.12.02 20:21:04 - OpenVPN > OpenVPN 2.3.13 x86_64-w64-mingw32 [sSL (OpenSSL)] [LZO] [iPv6] built on Nov 10 2016. 2016.12.02 20:21:04 - OpenVPN > Windows version 6.2 (Windows 8 or greater) 64bit. 2016.12.02 20:21:04 - OpenVPN > library versions: OpenSSL 1.0.2j 26 Sep 2016, LZO 2.09. 2016.12.02 20:21:04 - OpenVPN > MANAGEMENT: TCP Socket listening on [AF_INET]127.0.0.1:3100. 2016.12.02 20:21:04 - OpenVPN > Control Channel Authentication: tls-auth using INLINE static key file. 2016.12.02 20:21:04 - OpenVPN > Outgoing Control Channel Authentication: Using 160 bit message hash 'SHA1' for HMAC authentication. 2016.12.02 20:21:04 - OpenVPN > Incoming Control Channel Authentication: Using 160 bit message hash 'SHA1' for HMAC authentication. 2016.12.02 20:21:04 - OpenVPN > Socket Buffers: R=[65536->262144] S=[65536->262144]. 2016.12.02 20:21:04 - OpenVPN > UDPv4 link local: [undef]. 2016.12.02 20:21:04 - OpenVPN > UDPv4 link remote: [AF_INET]213.152.161.29:443. 2016.12.02 20:21:04 - OpenVPN > TLS: Initial packet from [AF_INET]213.152.161.29:443, sid=df19f22e a9af71d6. 2016.12.02 20:21:04 - OpenVPN > VERIFY OK: depth=1, C=IT, ST=IT, L=Perugia, O=airvpn.org, CN=airvpn.org CA, emailAddress=info@airvpn.org. 2016.12.02 20:21:04 - OpenVPN > Validating certificate key usage. 2016.12.02 20:21:04 - OpenVPN > ++ Certificate has key usage 00a0, expects 00a0. 2016.12.02 20:21:04 - OpenVPN > VERIFY KU OK. 2016.12.02 20:21:04 - OpenVPN > Validating certificate extended key usage. 2016.12.02 20:21:04 - OpenVPN > ++ Certificate has EKU (str) TLS Web Server Authentication, expects TLS Web Server Authentication. 2016.12.02 20:21:04 - OpenVPN > VERIFY EKU OK. 2016.12.02 20:21:04 - OpenVPN > VERIFY OK: depth=0, C=IT, ST=IT, L=Perugia, O=airvpn.org, CN=server, emailAddress=info@airvpn.org. 2016.12.02 20:21:04 - OpenVPN > Data Channel Encrypt: Cipher 'AES-256-CBC' initialized with 256 bit key. 2016.12.02 20:21:04 - OpenVPN > Data Channel Encrypt: Using 160 bit message hash 'SHA1' for HMAC authentication. 2016.12.02 20:21:04 - OpenVPN > Data Channel Decrypt: Cipher 'AES-256-CBC' initialized with 256 bit key. 2016.12.02 20:21:04 - OpenVPN > Data Channel Decrypt: Using 160 bit message hash 'SHA1' for HMAC authentication. 2016.12.02 20:21:04 - OpenVPN > Control Channel: TLSv1.2, cipher TLSv1/SSLv3 DHE-RSA-AES256-GCM-SHA384, 4096 bit RSA. 2016.12.02 20:21:04 - OpenVPN > [server] Peer Connection Initiated with [AF_INET]213.152.161.29:443. 2016.12.02 20:21:06 - OpenVPN > SENT CONTROL [server]: 'PUSH_REQUEST' (status=1). 2016.12.02 20:21:06 - OpenVPN > PUSH: Received control message: 'PUSH_REPLY,redirect-gateway def1 bypass-dhcp,dhcp-option DNS 10.4.0.1,comp-lzo no,route-gateway 10.4.0.1,topology subnet,ping 10,ping-restart 60,ifconfig 10.4.92.206 255.255.0.0'. 2016.12.02 20:21:06 - OpenVPN > OPTIONS IMPORT: timers and/or timeouts modified. 2016.12.02 20:21:06 - OpenVPN > OPTIONS IMPORT: LZO parms modified. 2016.12.02 20:21:06 - OpenVPN > OPTIONS IMPORT: --ifconfig/up options modified. 2016.12.02 20:21:06 - OpenVPN > OPTIONS IMPORT: route options modified. 2016.12.02 20:21:06 - OpenVPN > OPTIONS IMPORT: route-related options modified. 2016.12.02 20:21:06 - OpenVPN > OPTIONS IMPORT: --ip-win32 and/or --dhcp-option options modified. 2016.12.02 20:21:06 - OpenVPN > ROUTE_GATEWAY 192.168.1.1/255.255.255.0 I=17 HWADDR=14:cc:20:17:0d:7f. 2016.12.02 20:21:06 - OpenVPN > do_ifconfig, tt->ipv6=0, tt->did_ifconfig_ipv6_setup=0. 2016.12.02 20:21:06 - OpenVPN > open_tun, tt->ipv6=0. 2016.12.02 20:21:06 - OpenVPN > TAP-WIN32 device [Local Area Connection 2] opened: \\.\Global\{F40AE409-E4BC-4ABA-B9F7-3BD827158EE3}.tap. 2016.12.02 20:21:06 - OpenVPN > TAP-Windows Driver Version 9.21. 2016.12.02 20:21:06 - OpenVPN > Set TAP-Windows TUN subnet mode network/local/netmask = 10.4.0.0/10.4.92.206/255.255.0.0 [sUCCEEDED]. 2016.12.02 20:21:06 - OpenVPN > Notified TAP-Windows driver to set a DHCP IP/netmask of 10.4.92.206/255.255.0.0 on interface {F40AE409-E4BC-4ABA-B9F7-3BD827158EE3} [DHCP-serv: 10.4.255.254, lease-time: 31536000]. 2016.12.02 20:21:06 - OpenVPN > Successful ARP Flush on interface [18] {F40AE409-E4BC-4ABA-B9F7-3BD827158EE3}. 2016.12.02 20:21:12 - OpenVPN > TEST ROUTES: 1/1 succeeded len=0 ret=1 a=0 u/d=up. 2016.12.02 20:21:12 - OpenVPN > C:\WINDOWS\system32\route.exe ADD 213.152.161.29 MASK 255.255.255.255 192.168.1.1. 2016.12.02 20:21:12 - OpenVPN > ROUTE: CreateIpForwardEntry succeeded with dwForwardMetric1=40 and dwForwardType=4. 2016.12.02 20:21:12 - OpenVPN > Route addition via IPAPI succeeded [adaptive]. 2016.12.02 20:21:12 - OpenVPN > C:\WINDOWS\system32\route.exe ADD 0.0.0.0 MASK 128.0.0.0 10.4.0.1. 2016.12.02 20:21:12 - OpenVPN > ROUTE: CreateIpForwardEntry succeeded with dwForwardMetric1=35 and dwForwardType=4. 2016.12.02 20:21:12 - OpenVPN > Route addition via IPAPI succeeded [adaptive]. 2016.12.02 20:21:12 - OpenVPN > C:\WINDOWS\system32\route.exe ADD 128.0.0.0 MASK 128.0.0.0 10.4.0.1. 2016.12.02 20:21:12 - OpenVPN > ROUTE: CreateIpForwardEntry succeeded with dwForwardMetric1=35 and dwForwardType=4. 2016.12.02 20:21:12 - OpenVPN > Route addition via IPAPI succeeded [adaptive]. 2016.12.02 20:21:12 - Starting Management Interface. 2016.12.02 20:21:12 - OpenVPN > Initialization Sequence Completed. 2016.12.02 20:21:12 - DNS leak protection with packet filtering enabled.I 2016.12.02 20:21:12 - Flushing DNS. 2016.12.02 20:21:13 - Updating systems & servers data .... 2016.12.02 20:21:13 - Systems & servers data update completedI 2016.12.02 20:21:17 - Checking routeI 2016.12.02 20:21:18 - Checking DNS! 2016.12.02 20:21:30 - Connected.. 2016.12.02 20:21:30 - OpenVPN > MANAGEMENT: Client connected from [AF_INET]127.0.0.1:3100. 2016.12.02 20:21:30 - OpenVpn Management > >INFO:OpenVPN Management Interface Version 1 -- type 'help' for more info. 2016.12.02 20:31:15 - Updating systems & servers data .... 2016.12.02 20:31:15 - Systems & servers data update completed. 2016.12.02 20:41:16 - Updating systems & servers data .... 2016.12.02 20:41:17 - Systems & servers data update completed. 2016.12.02 20:51:18 - Updating systems & servers data .... 2016.12.02 20:51:19 - Systems & servers data update completed. 2016.12.02 20:58:06 - OpenVPN > Authenticate/Decrypt packet error: bad packet ID (may be a replay): [ #9729 ] -- see the man page entry for --no-replay and --replay-window for more info or silence this warning with --mute-replay-warnings. 2016.12.02 20:58:06 - OpenVPN > Authenticate/Decrypt packet error: bad packet ID (may be a replay): [ #9730 ] -- see the man page entry for --no-replay and --replay-window for more info or silence this warning with --mute-replay-warnings. 2016.12.02 20:58:06 - OpenVPN > Authenticate/Decrypt packet error: bad packet ID (may be a replay): [ #9731 ] -- see the man page entry for --no-replay and --replay-window for more info or silence this warning with --mute-replay-warnings. 2016.12.02 20:58:06 - OpenVPN > Authenticate/Decrypt packet error: bad packet ID (may be a replay): [ #9732 ] -- see the man page entry for --no-replay and --replay-window for more info or silence this warning with --mute-replay-warnings. 2016.12.02 20:58:06 - OpenVPN > Authenticate/Decrypt packet error: bad packet ID (may be a replay): [ #9729 ] -- see the man page entry for --no-replay and --replay-window for more info or silence this warning with --mute-replay-warnings. 2016.12.02 20:58:06 - OpenVPN > Authenticate/Decrypt packet error: bad packet ID (may be a replay): [ #9730 ] -- see the man page entry for --no-replay and --replay-window for more info or silence this warning with --mute-replay-warnings. 2016.12.02 20:58:06 - OpenVPN > Authenticate/Decrypt packet error: bad packet ID (may be a replay): [ #9731 ] -- see the man page entry for --no-replay and --replay-window for more info or silence this warning with --mute-replay-warnings. 2016.12.02 20:58:06 - OpenVPN > Authenticate/Decrypt packet error: bad packet ID (may be a replay): [ #9732 ] -- see the man page entry for --no-replay and --replay-window for more info or silence this warning with --mute-replay-warnings. 2016.12.02 20:58:06 - OpenVPN > Authenticate/Decrypt packet error: bad packet ID (may be a replay): [ #9731 ] -- see the man page entry for --no-replay and --replay-window for more info or silence this warning with --mute-replay-warnings. 2016.12.02 20:58:06 - OpenVPN > Authenticate/Decrypt packet error: bad packet ID (may be a replay): [ #9732 ] -- see the man page entry for --no-replay and --replay-window for more info or silence this warning with --mute-replay-warnings. 2016.12.02 20:58:06 - OpenVPN > Authenticate/Decrypt packet error: bad packet ID (may be a replay): [ #9729 ] -- see the man page entry for --no-replay and --replay-window for more info or silence this warning with --mute-replay-warnings. 2016.12.02 20:58:06 - OpenVPN > Authenticate/Decrypt packet error: bad packet ID (may be a replay): [ #9730 ] -- see the man page entry for --no-replay and --replay-window for more info or silence this warning with --mute-replay-warnings. 2016.12.02 20:58:06 - OpenVPN > Authenticate/Decrypt packet error: bad packet ID (may be a replay): [ #9731 ] -- see the man page entry for --no-replay and --replay-window for more info or silence this warning with --mute-replay-warnings. 2016.12.02 20:58:06 - OpenVPN > Authenticate/Decrypt packet error: bad packet ID (may be a replay): [ #9732 ] -- see the man page entry for --no-replay and --replay-window for more info or silence this warning with --mute-replay-warnings. 2016.12.02 20:58:06 - OpenVPN > Authenticate/Decrypt packet error: bad packet ID (may be a replay): [ #9752 ] -- see the man page entry for --no-replay and --replay-window for more info or silence this warning with --mute-replay-warnings. 2016.12.02 20:58:06 - OpenVPN > Authenticate/Decrypt packet error: bad packet ID (may be a replay): [ #9753 ] -- see the man page entry for --no-replay and --replay-window for more info or silence this warning with --mute-replay-warnings. 2016.12.02 20:58:06 - OpenVPN > Authenticate/Decrypt packet error: bad packet ID (may be a replay): [ #9752 ] -- see the man page entry for --no-replay and --replay-window for more info or silence this warning with --mute-replay-warnings. 2016.12.02 20:58:06 - OpenVPN > Authenticate/Decrypt packet error: bad packet ID (may be a replay): [ #9753 ] -- see the man page entry for --no-replay and --replay-window for more info or silence this warning with --mute-replay-warnings. 2016.12.02 20:58:06 - OpenVPN > Authenticate/Decrypt packet error: bad packet ID (may be a replay): [ #9752 ] -- see the man page entry for --no-replay and --replay-window for more info or silence this warning with --mute-replay-warnings. 2016.12.02 20:58:06 - OpenVPN > Authenticate/Decrypt packet error: bad packet ID (may be a replay): [ #9753 ] -- see the man page entry for --no-replay and --replay-window for more info or silence this warning with --mute-replay-warnings. 2016.12.02 20:58:06 - OpenVPN > Authenticate/Decrypt packet error: bad packet ID (may be a replay): [ #9752 ] -- see the man page entry for --no-replay and --replay-window for more info or silence this warning with --mute-replay-warnings. 2016.12.02 20:58:06 - OpenVPN > Authenticate/Decrypt packet error: bad packet ID (may be a replay): [ #9753 ] -- see the man page entry for --no-replay and --replay-window for more info or silence this warning with --mute-replay-warnings. 2016.12.02 20:58:06 - OpenVPN > Authenticate/Decrypt packet error: bad packet ID (may be a replay): [ #9752 ] -- see the man page entry for --no-replay and --replay-window for more info or silence this warning with --mute-replay-warnings. 2016.12.02 20:58:06 - OpenVPN > Authenticate/Decrypt packet error: bad packet ID (may be a replay): [ #9753 ] -- see the man page entry for --no-replay and --replay-window for more info or silence this warning with --mute-replay-warnings. 2016.12.02 20:58:06 - OpenVPN > Authenticate/Decrypt packet error: bad packet ID (may be a replay): [ #9754 ] -- see the man page entry for --no-replay and --replay-window for more info or silence this warning with --mute-replay-warnings. 2016.12.02 20:58:06 - OpenVPN > Authenticate/Decrypt packet error: bad packet ID (may be a replay): [ #9755 ] -- see the man page entry for --no-replay and --replay-window for more info or silence this warning with --mute-replay-warnings. 2016.12.02 20:58:06 - OpenVPN > Authenticate/Decrypt packet error: bad packet ID (may be a replay): [ #9754 ] -- see the man page entry for --no-replay and --replay-window for more info or silence this warning with --mute-replay-warnings. 2016.12.02 20:58:06 - OpenVPN > Authenticate/Decrypt packet error: bad packet ID (may be a replay): [ #9755 ] -- see the man page entry for --no-replay and --replay-window for more info or silence this warning with --mute-replay-warnings. 2016.12.02 20:58:06 - OpenVPN > Authenticate/Decrypt packet error: bad packet ID (may be a replay): [ #9754 ] -- see the man page entry for --no-replay and --replay-window for more info or silence this warning with --mute-replay-warnings. 2016.12.02 20:58:06 - OpenVPN > Authenticate/Decrypt packet error: bad packet ID (may be a replay): [ #9755 ] -- see the man page entry for --no-replay and --replay-window for more info or silence this warning with --mute-replay-warnings. 2016.12.02 20:58:06 - OpenVPN > Authenticate/Decrypt packet error: bad packet ID (may be a replay): [ #9754 ] -- see the man page entry for --no-replay and --replay-window for more info or silence this warning with --mute-replay-warnings. 2016.12.02 20:58:06 - OpenVPN > Authenticate/Decrypt packet error: bad packet ID (may be a replay): [ #9755 ] -- see the man page entry for --no-replay and --replay-window for more info or silence this warning with --mute-replay-warnings. 2016.12.02 20:58:06 - OpenVPN > Authenticate/Decrypt packet error: bad packet ID (may be a replay): [ #9761 ] -- see the man page entry for --no-replay and --replay-window for more info or silence this warning with --mute-replay-warnings. 2016.12.02 20:58:06 - OpenVPN > Authenticate/Decrypt packet error: bad packet ID (may be a replay): [ #9762 ] -- see the man page entry for --no-replay and --replay-window for more info or silence this warning with --mute-replay-warnings. 2016.12.02 20:58:06 - OpenVPN > Authenticate/Decrypt packet error: bad packet ID (may be a replay): [ #9761 ] -- see the man page entry for --no-replay and --replay-window for more info or silence this warning with --mute-replay-warnings. 2016.12.02 20:58:06 - OpenVPN > Authenticate/Decrypt packet error: bad packet ID (may be a replay): [ #9762 ] -- see the man page entry for --no-replay and --replay-window for more info or silence this warning with --mute-replay-warnings. 2016.12.02 20:58:06 - OpenVPN > Authenticate/Decrypt packet error: bad packet ID (may be a replay): [ #9761 ] -- see the man page entry for --no-replay and --replay-window for more info or silence this warning with --mute-replay-warnings. 2016.12.02 20:58:06 - OpenVPN > Authenticate/Decrypt packet error: bad packet ID (may be a replay): [ #9762 ] -- see the man page entry for --no-replay and --replay-window for more info or silence this warning with --mute-replay-warnings. 2016.12.02 20:58:06 - OpenVPN > Authenticate/Decrypt packet error: bad packet ID (may be a replay): [ #9761 ] -- see the man page entry for --no-replay and --replay-window for more info or silence this warning with --mute-replay-warnings. 2016.12.02 20:58:06 - OpenVPN > Authenticate/Decrypt packet error: bad packet ID (may be a replay): [ #9762 ] -- see the man page entry for --no-replay and --replay-window for more info or silence this warning with --mute-replay-warnings. 2016.12.02 20:58:06 - OpenVPN > Authenticate/Decrypt packet error: bad packet ID (may be a replay): [ #9761 ] -- see the man page entry for --no-replay and --replay-window for more info or silence this warning with --mute-replay-warnings. 2016.12.02 20:58:06 - OpenVPN > Authenticate/Decrypt packet error: bad packet ID (may be a replay): [ #9762 ] -- see the man page entry for --no-replay and --replay-window for more info or silence this warning with --mute-replay-warnings. 2016.12.02 20:58:06 - OpenVPN > Authenticate/Decrypt packet error: bad packet ID (may be a replay): [ #9763 ] -- see the man page entry for --no-replay and --replay-window for more info or silence this warning with --mute-replay-warnings. 2016.12.02 20:58:06 - OpenVPN > Authenticate/Decrypt packet error: bad packet ID (may be a replay): [ #9765 ] -- see the man page entry for --no-replay and --replay-window for more info or silence this warning with --mute-replay-warnings. 2016.12.02 20:58:06 - OpenVPN > Authenticate/Decrypt packet error: bad packet ID (may be a replay): [ #9766 ] -- see the man page entry for --no-replay and --replay-window for more info or silence this warning with --mute-replay-warnings. 2016.12.02 20:58:06 - OpenVPN > Authenticate/Decrypt packet error: bad packet ID (may be a replay): [ #9763 ] -- see the man page entry for --no-replay and --replay-window for more info or silence this warning with --mute-replay-warnings. 2016.12.02 20:58:06 - OpenVPN > Authenticate/Decrypt packet error: bad packet ID (may be a replay): [ #9765 ] -- see the man page entry for --no-replay and --replay-window for more info or silence this warning with --mute-replay-warnings. 2016.12.02 20:58:06 - OpenVPN > Authenticate/Decrypt packet error: bad packet ID (may be a replay): [ #9766 ] -- see the man page entry for --no-replay and --replay-window for more info or silence this warning with --mute-replay-warnings. 2016.12.02 20:58:06 - OpenVPN > Authenticate/Decrypt packet error: bad packet ID (may be a replay): [ #9763 ] -- see the man page entry for --no-replay and --replay-window for more info or silence this warning with --mute-replay-warnings. 2016.12.02 20:58:06 - OpenVPN > Authenticate/Decrypt packet error: bad packet ID (may be a replay): [ #9765 ] -- see the man page entry for --no-replay and --replay-window for more info or silence this warning with --mute-replay-warnings. 2016.12.02 20:58:06 - OpenVPN > Authenticate/Decrypt packet error: bad packet ID (may be a replay): [ #9766 ] -- see the man page entry for --no-replay and --replay-window for more info or silence this warning with --mute-replay-warnings. 2016.12.02 20:58:06 - OpenVPN > Authenticate/Decrypt packet error: bad packet ID (may be a replay): [ #9763 ] -- see the man page entry for --no-replay and --replay-window for more info or silence this warning with --mute-replay-warnings. 2016.12.02 20:58:06 - OpenVPN > Authenticate/Decrypt packet error: bad packet ID (may be a replay): [ #9765 ] -- see the man page entry for --no-replay and --replay-window for more info or silence this warning with --mute-replay-warnings. 2016.12.02 20:58:06 - OpenVPN > Authenticate/Decrypt packet error: bad packet ID (may be a replay): [ #9766 ] -- see the man page entry for --no-replay and --replay-window for more info or silence this warning with --mute-replay-warnings. 2016.12.02 21:00:19 - OpenVPN > Authenticate/Decrypt packet error: bad packet ID (may be a replay): [ #14443 ] -- see the man page entry for --no-replay and --replay-window for more info or silence this warning with --mute-replay-warnings. 2016.12.02 21:00:19 - OpenVPN > Authenticate/Decrypt packet error: bad packet ID (may be a replay): [ #14444 ] -- see the man page entry for --no-replay and --replay-window for more info or silence this warning with --mute-replay-warnings. 2016.12.02 21:00:19 - OpenVPN > Authenticate/Decrypt packet error: bad packet ID (may be a replay): [ #14443 ] -- see the man page entry for --no-replay and --replay-window for more info or silence this warning with --mute-replay-warnings. 2016.12.02 21:00:19 - OpenVPN > Authenticate/Decrypt packet error: bad packet ID (may be a replay): [ #14444 ] -- see the man page entry for --no-replay and --replay-window for more info or silence this warning with --mute-replay-warnings. 2016.12.02 21:00:19 - OpenVPN > Authenticate/Decrypt packet error: bad packet ID (may be a replay): [ #14443 ] -- see the man page entry for --no-replay and --replay-window for more info or silence this warning with --mute-replay-warnings. 2016.12.02 21:00:19 - OpenVPN > Authenticate/Decrypt packet error: bad packet ID (may be a replay): [ #14444 ] -- see the man page entry for --no-replay and --replay-window for more info or silence this warning with --mute-replay-warnings. 2016.12.02 21:00:19 - OpenVPN > Authenticate/Decrypt packet error: bad packet ID (may be a replay): [ #14443 ] -- see the man page entry for --no-replay and --replay-window for more info or silence this warning with --mute-replay-warnings. 2016.12.02 21:00:19 - OpenVPN > Authenticate/Decrypt packet error: bad packet ID (may be a replay): [ #14444 ] -- see the man page entry for --no-replay and --replay-window for more info or silence this warning with --mute-replay-warnings. 2016.12.02 21:00:19 - OpenVPN > Authenticate/Decrypt packet error: bad packet ID (may be a replay): [ #14443 ] -- see the man page entry for --no-replay and --replay-window for more info or silence this warning with --mute-replay-warnings. 2016.12.02 21:00:19 - OpenVPN > Authenticate/Decrypt packet error: bad packet ID (may be a replay): [ #14444 ] -- see the man page entry for --no-replay and --replay-window for more info or silence this warning with --mute-replay-warnings. 2016.12.02 21:00:32 - OpenVPN > Authenticate/Decrypt packet error: bad packet ID (may be a replay): [ #15918 ] -- see the man page entry for --no-replay and --replay-window for more info or silence this warning with --mute-replay-warnings. 2016.12.02 21:00:32 - OpenVPN > Authenticate/Decrypt packet error: bad packet ID (may be a replay): [ #15917 ] -- see the man page entry for --no-replay and --replay-window for more info or silence this warning with --mute-replay-warnings. 2016.12.02 21:00:32 - OpenVPN > Authenticate/Decrypt packet error: bad packet ID (may be a replay): [ #15918 ] -- see the man page entry for --no-replay and --replay-window for more info or silence this warning with --mute-replay-warnings. 2016.12.02 21:00:32 - OpenVPN > Authenticate/Decrypt packet error: bad packet ID (may be a replay): [ #15917 ] -- see the man page entry for --no-replay and --replay-window for more info or silence this warning with --mute-replay-warnings. 2016.12.02 21:00:32 - OpenVPN > Authenticate/Decrypt packet error: bad packet ID (may be a replay): [ #15918 ] -- see the man page entry for --no-replay and --replay-window for more info or silence this warning with --mute-replay-warnings. 2016.12.02 21:00:32 - OpenVPN > Authenticate/Decrypt packet error: bad packet ID (may be a replay): [ #15917 ] -- see the man page entry for --no-replay and --replay-window for more info or silence this warning with --mute-replay-warnings. 2016.12.02 21:01:19 - OpenVPN > Authenticate/Decrypt packet error: bad packet ID (may be a replay): [ #16215 ] -- see the man page entry for --no-replay and --replay-window for more info or silence this warning with --mute-replay-warnings. 2016.12.02 21:01:19 - OpenVPN > Authenticate/Decrypt packet error: bad packet ID (may be a replay): [ #16217 ] -- see the man page entry for --no-replay and --replay-window for more info or silence this warning with --mute-replay-warnings. 2016.12.02 21:01:19 - OpenVPN > Authenticate/Decrypt packet error: bad packet ID (may be a replay): [ #16215 ] -- see the man page entry for --no-replay and --replay-window for more info or silence this warning with --mute-replay-warnings. 2016.12.02 21:01:19 - OpenVPN > Authenticate/Decrypt packet error: bad packet ID (may be a replay): [ #16217 ] -- see the man page entry for --no-replay and --replay-window for more info or silence this warning with --mute-replay-warnings. 2016.12.02 21:01:19 - OpenVPN > Authenticate/Decrypt packet error: bad packet ID (may be a replay): [ #16215 ] -- see the man page entry for --no-replay and --replay-window for more info or silence this warning with --mute-replay-warnings. 2016.12.02 21:01:19 - OpenVPN > Authenticate/Decrypt packet error: bad packet ID (may be a replay): [ #16217 ] -- see the man page entry for --no-replay and --replay-window for more info or silence this warning with --mute-replay-warnings. 2016.12.02 21:01:19 - OpenVPN > Authenticate/Decrypt packet error: bad packet ID (may be a replay): [ #16215 ] -- see the man page entry for --no-replay and --replay-window for more info or silence this warning with --mute-replay-warnings. 2016.12.02 21:01:19 - OpenVPN > Authenticate/Decrypt packet error: bad packet ID (may be a replay): [ #16217 ] -- see the man page entry for --no-replay and --replay-window for more info or silence this warning with --mute-replay-warnings. 2016.12.02 21:01:19 - OpenVPN > Authenticate/Decrypt packet error: bad packet ID (may be a replay): [ #16215 ] -- see the man page entry for --no-replay and --replay-window for more info or silence this warning with --mute-replay-warnings. 2016.12.02 21:01:19 - OpenVPN > Authenticate/Decrypt packet error: bad packet ID (may be a replay): [ #16217 ] -- see the man page entry for --no-replay and --replay-window for more info or silence this warning with --mute-replay-warnings. 2016.12.02 21:01:29 - Updating systems & servers data .... 2016.12.02 21:01:31 - Systems & servers data update completed. 2016.12.02 21:01:55 - OpenVPN > Authenticate/Decrypt packet error: bad packet ID (may be a replay): [ #18146 ] -- see the man page entry for --no-replay and --replay-window for more info or silence this warning with --mute-replay-warnings. 2016.12.02 21:01:55 - OpenVPN > Authenticate/Decrypt packet error: bad packet ID (may be a replay): [ #18147 ] -- see the man page entry for --no-replay and --replay-window for more info or silence this warning with --mute-replay-warnings. 2016.12.02 21:01:55 - OpenVPN > Authenticate/Decrypt packet error: bad packet ID (may be a replay): [ #18148 ] -- see the man page entry for --no-replay and --replay-window for more info or silence this warning with --mute-replay-warnings. 2016.12.02 21:01:55 - OpenVPN > Authenticate/Decrypt packet error: bad packet ID (may be a replay): [ #18146 ] -- see the man page entry for --no-replay and --replay-window for more info or silence this warning with --mute-replay-warnings. 2016.12.02 21:01:55 - OpenVPN > Authenticate/Decrypt packet error: bad packet ID (may be a replay): [ #18147 ] -- see the man page entry for --no-replay and --replay-window for more info or silence this warning with --mute-replay-warnings. 2016.12.02 21:01:55 - OpenVPN > Authenticate/Decrypt packet error: bad packet ID (may be a replay): [ #18146 ] -- see the man page entry for --no-replay and --replay-window for more info or silence this warning with --mute-replay-warnings. 2016.12.02 21:01:55 - OpenVPN > Authenticate/Decrypt packet error: bad packet ID (may be a replay): [ #18147 ] -- see the man page entry for --no-replay and --replay-window for more info or silence this warning with --mute-replay-warnings. 2016.12.02 21:01:55 - OpenVPN > Authenticate/Decrypt packet error: bad packet ID (may be a replay): [ #18148 ] -- see the man page entry for --no-replay and --replay-window for more info or silence this warning with --mute-replay-warnings. 2016.12.02 21:01:55 - OpenVPN > Authenticate/Decrypt packet error: bad packet ID (may be a replay): [ #18146 ] -- see the man page entry for --no-replay and --replay-window for more info or silence this warning with --mute-replay-warnings. 2016.12.02 21:01:55 - OpenVPN > Authenticate/Decrypt packet error: bad packet ID (may be a replay): [ #18147 ] -- see the man page entry for --no-replay and --replay-window for more info or silence this warning with --mute-replay-warnings. 2016.12.02 21:01:55 - OpenVPN > Authenticate/Decrypt packet error: bad packet ID (may be a replay): [ #18148 ] -- see the man page entry for --no-replay and --replay-window for more info or silence this warning with --mute-replay-warnings. 2016.12.02 21:01:55 - OpenVPN > Authenticate/Decrypt packet error: bad packet ID (may be a replay): [ #18146 ] -- see the man page entry for --no-replay and --replay-window for more info or silence this warning with --mute-replay-warnings. 2016.12.02 21:01:55 - OpenVPN > Authenticate/Decrypt packet error: bad packet ID (may be a replay): [ #18147 ] -- see the man page entry for --no-replay and --replay-window for more info or silence this warning with --mute-replay-warnings. 2016.12.02 21:01:55 - OpenVPN > Authenticate/Decrypt packet error: bad packet ID (may be a replay): [ #18148 ] -- see the man page entry for --no-replay and --replay-window for more info or silence this warning with --mute-replay-warnings. 2016.12.02 21:04:59 - OpenVPN > Authenticate/Decrypt packet error: bad packet ID (may be a replay): [ #18467 ] -- see the man page entry for --no-replay and --replay-window for more info or silence this warning with --mute-replay-warnings. 2016.12.02 21:04:59 - OpenVPN > Authenticate/Decrypt packet error: bad packet ID (may be a replay): [ #18468 ] -- see the man page entry for --no-replay and --replay-window for more info or silence this warning with --mute-replay-warnings. 2016.12.02 21:04:59 - OpenVPN > Authenticate/Decrypt packet error: bad packet ID (may be a replay): [ #18467 ] -- see the man page entry for --no-replay and --replay-window for more info or silence this warning with --mute-replay-warnings. 2016.12.02 21:04:59 - OpenVPN > Authenticate/Decrypt packet error: bad packet ID (may be a replay): [ #18468 ] -- see the man page entry for --no-replay and --replay-window for more info or silence this warning with --mute-replay-warnings. 2016.12.02 21:04:59 - OpenVPN > Authenticate/Decrypt packet error: bad packet ID (may be a replay): [ #18467 ] -- see the man page entry for --no-replay and --replay-window for more info or silence this warning with --mute-replay-warnings. 2016.12.02 21:04:59 - OpenVPN > Authenticate/Decrypt packet error: bad packet ID (may be a replay): [ #18468 ] -- see the man page entry for --no-replay and --replay-window for more info or silence this warning with --mute-replay-warnings. 2016.12.02 21:04:59 - OpenVPN > Authenticate/Decrypt packet error: bad packet ID (may be a replay): [ #18467 ] -- see the man page entry for --no-replay and --replay-window for more info or silence this warning with --mute-replay-warnings. 2016.12.02 21:04:59 - OpenVPN > Authenticate/Decrypt packet error: bad packet ID (may be a replay): [ #18468 ] -- see the man page entry for --no-replay and --replay-window for more info or silence this warning with --mute-replay-warnings. 2016.12.02 21:04:59 - OpenVPN > Authenticate/Decrypt packet error: bad packet ID (may be a replay): [ #18467 ] -- see the man page entry for --no-replay and --replay-window for more info or silence this warning with --mute-replay-warnings. 2016.12.02 21:04:59 - OpenVPN > Authenticate/Decrypt packet error: bad packet ID (may be a replay): [ #18468 ] -- see the man page entry for --no-replay and --replay-window for more info or silence this warning with --mute-replay-warnings. 2016.12.02 21:06:29 - OpenVPN > Authenticate/Decrypt packet error: bad packet ID (may be a replay): [ #19459 ] -- see the man page entry for --no-replay and --replay-window for more info or silence this warning with --mute-replay-warnings. 2016.12.02 21:06:29 - OpenVPN > Authenticate/Decrypt packet error: bad packet ID (may be a replay): [ #19460 ] -- see the man page entry for --no-replay and --replay-window for more info or silence this warning with --mute-replay-warnings. 2016.12.02 21:06:29 - OpenVPN > Authenticate/Decrypt packet error: bad packet ID (may be a replay): [ #19459 ] -- see the man page entry for --no-replay and --replay-window for more info or silence this warning with --mute-replay-warnings. 2016.12.02 21:06:29 - OpenVPN > Authenticate/Decrypt packet error: bad packet ID (may be a replay): [ #19460 ] -- see the man page entry for --no-replay and --replay-window for more info or silence this warning with --mute-replay-warnings. 2016.12.02 21:06:29 - OpenVPN > Authenticate/Decrypt packet error: bad packet ID (may be a replay): [ #19459 ] -- see the man page entry for --no-replay and --replay-window for more info or silence this warning with --mute-replay-warnings. 2016.12.02 21:06:29 - OpenVPN > Authenticate/Decrypt packet error: bad packet ID (may be a replay): [ #19460 ] -- see the man page entry for --no-replay and --replay-window for more info or silence this warning with --mute-replay-warnings. 2016.12.02 21:06:29 - OpenVPN > Authenticate/Decrypt packet error: bad packet ID (may be a replay): [ #19459 ] -- see the man page entry for --no-replay and --replay-window for more info or silence this warning with --mute-replay-warnings. 2016.12.02 21:06:29 - OpenVPN > Authenticate/Decrypt packet error: bad packet ID (may be a replay): [ #19460 ] -- see the man page entry for --no-replay and --replay-window for more info or silence this warning with --mute-replay-warnings. 2016.12.02 21:06:29 - OpenVPN > Authenticate/Decrypt packet error: bad packet ID (may be a replay): [ #19459 ] -- see the man page entry for --no-replay and --replay-window for more info or silence this warning with --mute-replay-warnings. 2016.12.02 21:06:29 - OpenVPN > Authenticate/Decrypt packet error: bad packet ID (may be a replay): [ #19460 ] -- see the man page entry for --no-replay and --replay-window for more info or silence this warning with --mute-replay-warnings. 2016.12.02 21:06:29 - OpenVPN > Authenticate/Decrypt packet error: bad packet ID (may be a replay): [ #19461 ] -- see the man page entry for --no-replay and --replay-window for more info or silence this warning with --mute-replay-warnings. 2016.12.02 21:06:29 - OpenVPN > Authenticate/Decrypt packet error: bad packet ID (may be a replay): [ #19462 ] -- see the man page entry for --no-replay and --replay-window for more info or silence this warning with --mute-replay-warnings. 2016.12.02 21:06:29 - OpenVPN > Authenticate/Decrypt packet error: bad packet ID (may be a replay): [ #19463 ] -- see the man page entry for --no-replay and --replay-window for more info or silence this warning with --mute-replay-warnings. 2016.12.02 21:06:29 - OpenVPN > Authenticate/Decrypt packet error: bad packet ID (may be a replay): [ #19464 ] -- see the man page entry for --no-replay and --replay-window for more info or silence this warning with --mute-replay-warnings. 2016.12.02 21:06:29 - OpenVPN > Authenticate/Decrypt packet error: bad packet ID (may be a replay): [ #19465 ] -- see the man page entry for --no-replay and --replay-window for more info or silence this warning with --mute-replay-warnings. 2016.12.02 21:06:29 - OpenVPN > Authenticate/Decrypt packet error: bad packet ID (may be a replay): [ #19461 ] -- see the man page entry for --no-replay and --replay-window for more info or silence this warning with --mute-replay-warnings. 2016.12.02 21:06:29 - OpenVPN > Authenticate/Decrypt packet error: bad packet ID (may be a replay): [ #19462 ] -- see the man page entry for --no-replay and --replay-window for more info or silence this warning with --mute-replay-warnings. 2016.12.02 21:06:29 - OpenVPN > Authenticate/Decrypt packet error: bad packet ID (may be a replay): [ #19463 ] -- see the man page entry for --no-replay and --replay-window for more info or silence this warning with --mute-replay-warnings. 2016.12.02 21:06:29 - OpenVPN > Authenticate/Decrypt packet error: bad packet ID (may be a replay): [ #19464 ] -- see the man page entry for --no-replay and --replay-window for more info or silence this warning with --mute-replay-warnings. 2016.12.02 21:06:29 - OpenVPN > Authenticate/Decrypt packet error: bad packet ID (may be a replay): [ #19465 ] -- see the man page entry for --no-replay and --replay-window for more info or silence this warning with --mute-replay-warnings. 2016.12.02 21:06:29 - OpenVPN > Authenticate/Decrypt packet error: bad packet ID (may be a replay): [ #19461 ] -- see the man page entry for --no-replay and --replay-window for more info or silence this warning with --mute-replay-warnings. 2016.12.02 21:06:29 - OpenVPN > Authenticate/Decrypt packet error: bad packet ID (may be a replay): [ #19462 ] -- see the man page entry for --no-replay and --replay-window for more info or silence this warning with --mute-replay-warnings. 2016.12.02 21:06:29 - OpenVPN > Authenticate/Decrypt packet error: bad packet ID (may be a replay): [ #19463 ] -- see the man page entry for --no-replay and --replay-window for more info or silence this warning with --mute-replay-warnings. 2016.12.02 21:06:29 - OpenVPN > Authenticate/Decrypt packet error: bad packet ID (may be a replay): [ #19464 ] -- see the man page entry for --no-replay and --replay-window for more info or silence this warning with --mute-replay-warnings. 2016.12.02 21:06:29 - OpenVPN > Authenticate/Decrypt packet error: bad packet ID (may be a replay): [ #19465 ] -- see the man page entry for --no-replay and --replay-window for more info or silence this warning with --mute-replay-warnings. 2016.12.02 21:08:25 - OpenVPN > Authenticate/Decrypt packet error: bad packet ID (may be a replay): [ #23418 ] -- see the man page entry for --no-replay and --replay-window for more info or silence this warning with --mute-replay-warnings. 2016.12.02 21:08:25 - OpenVPN > Authenticate/Decrypt packet error: bad packet ID (may be a replay): [ #23419 ] -- see the man page entry for --no-replay and --replay-window for more info or silence this warning with --mute-replay-warnings. 2016.12.02 21:08:25 - OpenVPN > Authenticate/Decrypt packet error: bad packet ID (may be a replay): [ #23418 ] -- see the man page entry for --no-replay and --replay-window for more info or silence this warning with --mute-replay-warnings. 2016.12.02 21:08:25 - OpenVPN > Authenticate/Decrypt packet error: bad packet ID (may be a replay): [ #23419 ] -- see the man page entry for --no-replay and --replay-window for more info or silence this warning with --mute-replay-warnings. 2016.12.02 21:08:25 - OpenVPN > Authenticate/Decrypt packet error: bad packet ID (may be a replay): [ #23418 ] -- see the man page entry for --no-replay and --replay-window for more info or silence this warning with --mute-replay-warnings. 2016.12.02 21:08:25 - OpenVPN > Authenticate/Decrypt packet error: bad packet ID (may be a replay): [ #23419 ] -- see the man page entry for --no-replay and --replay-window for more info or silence this warning with --mute-replay-warnings. 2016.12.02 21:08:25 - OpenVPN > Authenticate/Decrypt packet error: bad packet ID (may be a replay): [ #23418 ] -- see the man page entry for --no-replay and --replay-window for more info or silence this warning with --mute-replay-warnings. 2016.12.02 21:08:25 - OpenVPN > Authenticate/Decrypt packet error: bad packet ID (may be a replay): [ #23419 ] -- see the man page entry for --no-replay and --replay-window for more info or silence this warning with --mute-replay-warnings. 2016.12.02 21:08:25 - OpenVPN > Authenticate/Decrypt packet error: bad packet ID (may be a replay): [ #23420 ] -- see the man page entry for --no-replay and --replay-window for more info or silence this warning with --mute-replay-warnings. 2016.12.02 21:08:25 - OpenVPN > Authenticate/Decrypt packet error: bad packet ID (may be a replay): [ #23421 ] -- see the man page entry for --no-replay and --replay-window for more info or silence this warning with --mute-replay-warnings. 2016.12.02 21:08:25 - OpenVPN > Authenticate/Decrypt packet error: bad packet ID (may be a replay): [ #23422 ] -- see the man page entry for --no-replay and --replay-window for more info or silence this warning with --mute-replay-warnings. 2016.12.02 21:08:25 - OpenVPN > Authenticate/Decrypt packet error: bad packet ID (may be a replay): [ #23423 ] -- see the man page entry for --no-replay and --replay-window for more info or silence this warning with --mute-replay-warnings. 2016.12.02 21:08:25 - OpenVPN > Authenticate/Decrypt packet error: bad packet ID (may be a replay): [ #23424 ] -- see the man page entry for --no-replay and --replay-window for more info or silence this warning with --mute-replay-warnings. 2016.12.02 21:08:25 - OpenVPN > Authenticate/Decrypt packet error: bad packet ID (may be a replay): [ #23425 ] -- see the man page entry for --no-replay and --replay-window for more info or silence this warning with --mute-replay-warnings. 2016.12.02 21:08:25 - OpenVPN > Authenticate/Decrypt packet error: bad packet ID (may be a replay): [ #23426 ] -- see the man page entry for --no-replay and --replay-window for more info or silence this warning with --mute-replay-warnings. 2016.12.02 21:08:25 - OpenVPN > Authenticate/Decrypt packet error: bad packet ID (may be a replay): [ #23420 ] -- see the man page entry for --no-replay and --replay-window for more info or silence this warning with --mute-replay-warnings. 2016.12.02 21:08:25 - OpenVPN > Authenticate/Decrypt packet error: bad packet ID (may be a replay): [ #23421 ] -- see the man page entry for --no-replay and --replay-window for more info or silence this warning with --mute-replay-warnings. 2016.12.02 21:08:25 - OpenVPN > Authenticate/Decrypt packet error: bad packet ID (may be a replay): [ #23422 ] -- see the man page entry for --no-replay and --replay-window for more info or silence this warning with --mute-replay-warnings. 2016.12.02 21:08:25 - OpenVPN > Authenticate/Decrypt packet error: bad packet ID (may be a replay): [ #23423 ] -- see the man page entry for --no-replay and --replay-window for more info or silence this warning with --mute-replay-warnings. 2016.12.02 21:08:25 - OpenVPN > Authenticate/Decrypt packet error: bad packet ID (may be a replay): [ #23424 ] -- see the man page entry for --no-replay and --replay-window for more info or silence this warning with --mute-replay-warnings. 2016.12.02 21:08:25 - OpenVPN > Authenticate/Decrypt packet error: bad packet ID (may be a replay): [ #23425 ] -- see the man page entry for --no-replay and --replay-window for more info or silence this warning with --mute-replay-warnings. 2016.12.02 21:08:25 - OpenVPN > Authenticate/Decrypt packet error: bad packet ID (may be a replay): [ #23426 ] -- see the man page entry for --no-replay and --replay-window for more info or silence this warning with --mute-replay-warnings. 2016.12.02 21:08:25 - OpenVPN > Authenticate/Decrypt packet error: bad packet ID (may be a replay): [ #23420 ] -- see the man page entry for --no-replay and --replay-window for more info or silence this warning with --mute-replay-warnings. 2016.12.02 21:08:25 - OpenVPN > Authenticate/Decrypt packet error: bad packet ID (may be a replay): [ #23421 ] -- see the man page entry for --no-replay and --replay-window for more info or silence this warning with --mute-replay-warnings. 2016.12.02 21:08:25 - OpenVPN > Authenticate/Decrypt packet error: bad packet ID (may be a replay): [ #23422 ] -- see the man page entry for --no-replay and --replay-window for more info or silence this warning with --mute-replay-warnings. 2016.12.02 21:08:25 - OpenVPN > Authenticate/Decrypt packet error: bad packet ID (may be a replay): [ #23423 ] -- see the man page entry for --no-replay and --replay-window for more info or silence this warning with --mute-replay-warnings. 2016.12.02 21:08:25 - OpenVPN > Authenticate/Decrypt packet error: bad packet ID (may be a replay): [ #23424 ] -- see the man page entry for --no-replay and --replay-window for more info or silence this warning with --mute-replay-warnings. 2016.12.02 21:08:25 - OpenVPN > Authenticate/Decrypt packet error: bad packet ID (may be a replay): [ #23425 ] -- see the man page entry for --no-replay and --replay-window for more info or silence this warning with --mute-replay-warnings. 2016.12.02 21:08:25 - OpenVPN > Authenticate/Decrypt packet error: bad packet ID (may be a replay): [ #23426 ] -- see the man page entry for --no-replay and --replay-window for more info or silence this warning with --mute-replay-warnings. 2016.12.02 21:08:25 - OpenVPN > Authenticate/Decrypt packet error: bad packet ID (may be a replay): [ #23420 ] -- see the man page entry for --no-replay and --replay-window for more info or silence this warning with --mute-replay-warnings. 2016.12.02 21:08:25 - OpenVPN > Authenticate/Decrypt packet error: bad packet ID (may be a replay): [ #23421 ] -- see the man page entry for --no-replay and --replay-window for more info or silence this warning with --mute-replay-warnings. 2016.12.02 21:08:25 - OpenVPN > Authenticate/Decrypt packet error: bad packet ID (may be a replay): [ #23422 ] -- see the man page entry for --no-replay and --replay-window for more info or silence this warning with --mute-replay-warnings. 2016.12.02 21:08:25 - OpenVPN > Authenticate/Decrypt packet error: bad packet ID (may be a replay): [ #23420 ] -- see the man page entry for --no-replay and --replay-window for more info or silence this warning with --mute-replay-warnings. 2016.12.02 21:08:25 - OpenVPN > Authenticate/Decrypt packet error: bad packet ID (may be a replay): [ #23421 ] -- see the man page entry for --no-replay and --replay-window for more info or silence this warning with --mute-replay-warnings. 2016.12.02 21:08:25 - OpenVPN > Authenticate/Decrypt packet error: bad packet ID (may be a replay): [ #23422 ] -- see the man page entry for --no-replay and --replay-window for more info or silence this warning with --mute-replay-warnings. 2016.12.02 21:08:25 - OpenVPN > Authenticate/Decrypt packet error: bad packet ID (may be a replay): [ #23423 ] -- see the man page entry for --no-replay and --replay-window for more info or silence this warning with --mute-replay-warnings. 2016.12.02 21:08:25 - OpenVPN > Authenticate/Decrypt packet error: bad packet ID (may be a replay): [ #23424 ] -- see the man page entry for --no-replay and --replay-window for more info or silence this warning with --mute-replay-warnings. 2016.12.02 21:08:25 - OpenVPN > Authenticate/Decrypt packet error: bad packet ID (may be a replay): [ #23425 ] -- see the man page entry for --no-replay and --replay-window for more info or silence this warning with --mute-replay-warnings. 2016.12.02 21:08:25 - OpenVPN > Authenticate/Decrypt packet error: bad packet ID (may be a replay): [ #23426 ] -- see the man page entry for --no-replay and --replay-window for more info or silence this warning with --mute-replay-warnings. 2016.12.02 21:10:00 - OpenVPN > Authenticate/Decrypt packet error: bad packet ID (may be a replay): [ #27296 ] -- see the man page entry for --no-replay and --replay-window for more info or silence this warning with --mute-replay-warnings. 2016.12.02 21:10:00 - OpenVPN > Authenticate/Decrypt packet error: bad packet ID (may be a replay): [ #27297 ] -- see the man page entry for --no-replay and --replay-window for more info or silence this warning with --mute-replay-warnings. 2016.12.02 21:10:00 - OpenVPN > Authenticate/Decrypt packet error: bad packet ID (may be a replay): [ #27296 ] -- see the man page entry for --no-replay and --replay-window for more info or silence this warning with --mute-replay-warnings. 2016.12.02 21:10:00 - OpenVPN > Authenticate/Decrypt packet error: bad packet ID (may be a replay): [ #27297 ] -- see the man page entry for --no-replay and --replay-window for more info or silence this warning with --mute-replay-warnings. 2016.12.02 21:10:00 - OpenVPN > Authenticate/Decrypt packet error: bad packet ID (may be a replay): [ #27296 ] -- see the man page entry for --no-replay and --replay-window for more info or silence this warning with --mute-replay-warnings. 2016.12.02 21:10:00 - OpenVPN > Authenticate/Decrypt packet error: bad packet ID (may be a replay): [ #27297 ] -- see the man page entry for --no-replay and --replay-window for more info or silence this warning with --mute-replay-warnings. 2016.12.02 21:10:00 - OpenVPN > Authenticate/Decrypt packet error: bad packet ID (may be a replay): [ #27296 ] -- see the man page entry for --no-replay and --replay-window for more info or silence this warning with --mute-replay-warnings. 2016.12.02 21:10:00 - OpenVPN > Authenticate/Decrypt packet error: bad packet ID (may be a replay): [ #27297 ] -- see the man page entry for --no-replay and --replay-window for more info or silence this warning with --mute-replay-warnings. 2016.12.02 21:10:00 - OpenVPN > Authenticate/Decrypt packet error: bad packet ID (may be a replay): [ #27296 ] -- see the man page entry for --no-replay and --replay-window for more info or silence this warning with --mute-replay-warnings. 2016.12.02 21:10:00 - OpenVPN > Authenticate/Decrypt packet error: bad packet ID (may be a replay): [ #27297 ] -- see the man page entry for --no-replay and --replay-window for more info or silence this warning with --mute-replay-warnings. 2016.12.02 21:10:00 - OpenVPN > Authenticate/Decrypt packet error: bad packet ID (may be a replay): [ #27325 ] -- see the man page entry for --no-replay and --replay-window for more info or silence this warning with --mute-replay-warnings. 2016.12.02 21:10:00 - OpenVPN > Authenticate/Decrypt packet error: bad packet ID (may be a replay): [ #27326 ] -- see the man page entry for --no-replay and --replay-window for more info or silence this warning with --mute-replay-warnings. 2016.12.02 21:10:00 - OpenVPN > Authenticate/Decrypt packet error: bad packet ID (may be a replay): [ #27325 ] -- see the man page entry for --no-replay and --replay-window for more info or silence this warning with --mute-replay-warnings. 2016.12.02 21:10:00 - OpenVPN > Authenticate/Decrypt packet error: bad packet ID (may be a replay): [ #27326 ] -- see the man page entry for --no-replay and --replay-window for more info or silence this warning with --mute-replay-warnings. 2016.12.02 21:10:00 - OpenVPN > Authenticate/Decrypt packet error: bad packet ID (may be a replay): [ #27325 ] -- see the man page entry for --no-replay and --replay-window for more info or silence this warning with --mute-replay-warnings. 2016.12.02 21:10:00 - OpenVPN > Authenticate/Decrypt packet error: bad packet ID (may be a replay): [ #27326 ] -- see the man page entry for --no-replay and --replay-window for more info or silence this warning with --mute-replay-warnings. 2016.12.02 21:10:00 - OpenVPN > Authenticate/Decrypt packet error: bad packet ID (may be a replay): [ #27325 ] -- see the man page entry for --no-replay and --replay-window for more info or silence this warning with --mute-replay-warnings. 2016.12.02 21:10:00 - OpenVPN > Authenticate/Decrypt packet error: bad packet ID (may be a replay): [ #27326 ] -- see the man page entry for --no-replay and --replay-window for more info or silence this warning with --mute-replay-warnings. 2016.12.02 21:10:02 - OpenVPN > Authenticate/Decrypt packet error: bad packet ID (may be a replay): [ #27574 ] -- see the man page entry for --no-replay and --replay-window for more info or silence this warning with --mute-replay-warnings. 2016.12.02 21:10:02 - OpenVPN > Authenticate/Decrypt packet error: bad packet ID (may be a replay): [ #27575 ] -- see the man page entry for --no-replay and --replay-window for more info or silence this warning with --mute-replay-warnings. 2016.12.02 21:10:02 - OpenVPN > Authenticate/Decrypt packet error: bad packet ID (may be a replay): [ #27574 ] -- see the man page entry for --no-replay and --replay-window for more info or silence this warning with --mute-replay-warnings. 2016.12.02 21:10:02 - OpenVPN > Authenticate/Decrypt packet error: bad packet ID (may be a replay): [ #27575 ] -- see the man page entry for --no-replay and --replay-window for more info or silence this warning with --mute-replay-warnings. 2016.12.02 21:10:02 - OpenVPN > Authenticate/Decrypt packet error: bad packet ID (may be a replay): [ #27574 ] -- see the man page entry for --no-replay and --replay-window for more info or silence this warning with --mute-replay-warnings. 2016.12.02 21:10:02 - OpenVPN > Authenticate/Decrypt packet error: bad packet ID (may be a replay): [ #27575 ] -- see the man page entry for --no-replay and --replay-window for more info or silence this warning with --mute-replay-warnings. 2016.12.02 21:10:02 - OpenVPN > Authenticate/Decrypt packet error: bad packet ID (may be a replay): [ #27574 ] -- see the man page entry for --no-replay and --replay-window for more info or silence this warning with --mute-replay-warnings. 2016.12.02 21:10:02 - OpenVPN > Authenticate/Decrypt packet error: bad packet ID (may be a replay): [ #27575 ] -- see the man page entry for --no-replay and --replay-window for more info or silence this warning with --mute-replay-warnings. 2016.12.02 21:10:02 - OpenVPN > Authenticate/Decrypt packet error: bad packet ID (may be a replay): [ #27574 ] -- see the man page entry for --no-replay and --replay-window for more info or silence this warning with --mute-replay-warnings. 2016.12.02 21:10:02 - OpenVPN > Authenticate/Decrypt packet error: bad packet ID (may be a replay): [ #27575 ] -- see the man page entry for --no-replay and --replay-window for more info or silence this warning with --mute-replay-warnings. 2016.12.02 21:10:36 - OpenVPN > Authenticate/Decrypt packet error: bad packet ID (may be a replay): [ #29914 ] -- see the man page entry for --no-replay and --replay-window for more info or silence this warning with --mute-replay-warnings. 2016.12.02 21:10:36 - OpenVPN > Authenticate/Decrypt packet error: bad packet ID (may be a replay): [ #29915 ] -- see the man page entry for --no-replay and --replay-window for more info or silence this warning with --mute-replay-warnings. 2016.12.02 21:10:36 - OpenVPN > Authenticate/Decrypt packet error: bad packet ID (may be a replay): [ #29914 ] -- see the man page entry for --no-replay and --replay-window for more info or silence this warning with --mute-replay-warnings. 2016.12.02 21:10:36 - OpenVPN > Authenticate/Decrypt packet error: bad packet ID (may be a replay): [ #29915 ] -- see the man page entry for --no-replay and --replay-window for more info or silence this warning with --mute-replay-warnings. 2016.12.02 21:10:36 - OpenVPN > Authenticate/Decrypt packet error: bad packet ID (may be a replay): [ #29914 ] -- see the man page entry for --no-replay and --replay-window for more info or silence this warning with --mute-replay-warnings. 2016.12.02 21:10:36 - OpenVPN > Authenticate/Decrypt packet error: bad packet ID (may be a replay): [ #29915 ] -- see the man page entry for --no-replay and --replay-window for more info or silence this warning with --mute-replay-warnings. 2016.12.02 21:10:36 - OpenVPN > Authenticate/Decrypt packet error: bad packet ID (may be a replay): [ #29914 ] -- see the man page entry for --no-replay and --replay-window for more info or silence this warning with --mute-replay-warnings. 2016.12.02 21:10:36 - OpenVPN > Authenticate/Decrypt packet error: bad packet ID (may be a replay): [ #29915 ] -- see the man page entry for --no-replay and --replay-window for more info or silence this warning with --mute-replay-warnings. 2016.12.02 21:10:36 - OpenVPN > Authenticate/Decrypt packet error: bad packet ID (may be a replay): [ #29914 ] -- see the man page entry for --no-replay and --replay-window for more info or silence this warning with --mute-replay-warnings. 2016.12.02 21:10:36 - OpenVPN > Authenticate/Decrypt packet error: bad packet ID (may be a replay): [ #29915 ] -- see the man page entry for --no-replay and --replay-window for more info or silence this warning with --mute-replay-warnings. 2016.12.02 21:11:20 - OpenVPN > Authenticate/Decrypt packet error: bad packet ID (may be a replay): [ #30560 ] -- see the man page entry for --no-replay and --replay-window for more info or silence this warning with --mute-replay-warnings. 2016.12.02 21:11:20 - OpenVPN > Authenticate/Decrypt packet error: bad packet ID (may be a replay): [ #30561 ] -- see the man page entry for --no-replay and --replay-window for more info or silence this warning with --mute-replay-warnings. 2016.12.02 21:11:20 - OpenVPN > Authenticate/Decrypt packet error: bad packet ID (may be a replay): [ #30560 ] -- see the man page entry for --no-replay and --replay-window for more info or silence this warning with --mute-replay-warnings. 2016.12.02 21:11:20 - OpenVPN > Authenticate/Decrypt packet error: bad packet ID (may be a replay): [ #30561 ] -- see the man page entry for --no-replay and --replay-window for more info or silence this warning with --mute-replay-warnings. 2016.12.02 21:11:20 - OpenVPN > Authenticate/Decrypt packet error: bad packet ID (may be a replay): [ #30560 ] -- see the man page entry for --no-replay and --replay-window for more info or silence this warning with --mute-replay-warnings. 2016.12.02 21:11:20 - OpenVPN > Authenticate/Decrypt packet error: bad packet ID (may be a replay): [ #30561 ] -- see the man page entry for --no-replay and --replay-window for more info or silence this warning with --mute-replay-warnings. 2016.12.02 21:11:20 - OpenVPN > Authenticate/Decrypt packet error: bad packet ID (may be a replay): [ #30560 ] -- see the man page entry for --no-replay and --replay-window for more info or silence this warning with --mute-replay-warnings. 2016.12.02 21:11:20 - OpenVPN > Authenticate/Decrypt packet error: bad packet ID (may be a replay): [ #30561 ] -- see the man page entry for --no-replay and --replay-window for more info or silence this warning with --mute-replay-warnings. 2016.12.02 21:11:32 - Updating systems & servers data .... 2016.12.02 21:11:33 - Systems & servers data update completed. 2016.12.02 21:21:06 - OpenVPN > VERIFY OK: depth=1, C=IT, ST=IT, L=Perugia, O=airvpn.org, CN=airvpn.org CA, emailAddress=info@airvpn.org. 2016.12.02 21:21:06 - OpenVPN > Validating certificate key usage. 2016.12.02 21:21:06 - OpenVPN > ++ Certificate has key usage 00a0, expects 00a0. 2016.12.02 21:21:06 - OpenVPN > VERIFY KU OK. 2016.12.02 21:21:06 - OpenVPN > Validating certificate extended key usage. 2016.12.02 21:21:06 - OpenVPN > ++ Certificate has EKU (str) TLS Web Server Authentication, expects TLS Web Server Authentication. 2016.12.02 21:21:06 - OpenVPN > VERIFY EKU OK. 2016.12.02 21:21:06 - OpenVPN > VERIFY OK: depth=0, C=IT, ST=IT, L=Perugia, O=airvpn.org, CN=server, emailAddress=info@airvpn.org. 2016.12.02 21:21:10 - OpenVPN > Data Channel Encrypt: Cipher 'AES-256-CBC' initialized with 256 bit key. 2016.12.02 21:21:10 - OpenVPN > Data Channel Encrypt: Using 160 bit message hash 'SHA1' for HMAC authentication. 2016.12.02 21:21:10 - OpenVPN > Data Channel Decrypt: Cipher 'AES-256-CBC' initialized with 256 bit key. 2016.12.02 21:21:10 - OpenVPN > Data Channel Decrypt: Using 160 bit message hash 'SHA1' for HMAC authentication. 2016.12.02 21:21:10 - OpenVPN > Control Channel: TLSv1.2, cipher TLSv1/SSLv3 DHE-RSA-AES256-GCM-SHA384, 4096 bit RSA. 2016.12.02 21:21:56 - Updating systems & servers data .... 2016.12.02 21:21:57 - Systems & servers data update completed. 2016.12.02 21:32:53 - Updating systems & servers data .... 2016.12.02 21:32:57 - Systems & servers data update completed. 2016.12.02 21:37:27 - OpenVPN > Authenticate/Decrypt packet error: bad packet ID (may be a replay): [ #1199 ] -- see the man page entry for --no-replay and --replay-window for more info or silence this warning with --mute-replay-warnings. 2016.12.02 21:37:27 - OpenVPN > Authenticate/Decrypt packet error: bad packet ID (may be a replay): [ #1200 ] -- see the man page entry for --no-replay and --replay-window for more info or silence this warning with --mute-replay-warnings. 2016.12.02 21:37:27 - OpenVPN > Authenticate/Decrypt packet error: bad packet ID (may be a replay): [ #1199 ] -- see the man page entry for --no-replay and --replay-window for more info or silence this warning with --mute-replay-warnings. 2016.12.02 21:37:27 - OpenVPN > Authenticate/Decrypt packet error: bad packet ID (may be a replay): [ #1200 ] -- see the man page entry for --no-replay and --replay-window for more info or silence this warning with --mute-replay-warnings. 2016.12.02 21:37:27 - OpenVPN > Authenticate/Decrypt packet error: bad packet ID (may be a replay): [ #1199 ] -- see the man page entry for --no-replay and --replay-window for more info or silence this warning with --mute-replay-warnings. 2016.12.02 21:37:27 - OpenVPN > Authenticate/Decrypt packet error: bad packet ID (may be a replay): [ #1200 ] -- see the man page entry for --no-replay and --replay-window for more info or silence this warning with --mute-replay-warnings. 2016.12.02 21:37:27 - OpenVPN > Authenticate/Decrypt packet error: bad packet ID (may be a replay): [ #1199 ] -- see the man page entry for --no-replay and --replay-window for more info or silence this warning with --mute-replay-warnings. 2016.12.02 21:37:27 - OpenVPN > Authenticate/Decrypt packet error: bad packet ID (may be a replay): [ #1200 ] -- see the man page entry for --no-replay and --replay-window for more info or silence this warning with --mute-replay-warnings. 2016.12.02 21:37:27 - OpenVPN > Authenticate/Decrypt packet error: bad packet ID (may be a replay): [ #1199 ] -- see the man page entry for --no-replay and --replay-window for more info or silence this warning with --mute-replay-warnings. 2016.12.02 21:37:27 - OpenVPN > Authenticate/Decrypt packet error: bad packet ID (may be a replay): [ #1200 ] -- see the man page entry for --no-replay and --replay-window for more info or silence this warning with --mute-replay-warnings. 2016.12.02 21:37:36 - OpenVPN > Authenticate/Decrypt packet error: bad packet ID (may be a replay): [ #1872 ] -- see the man page entry for --no-replay and --replay-window for more info or silence this warning with --mute-replay-warnings. 2016.12.02 21:37:36 - OpenVPN > Authenticate/Decrypt packet error: bad packet ID (may be a replay): [ #1873 ] -- see the man page entry for --no-replay and --replay-window for more info or silence this warning with --mute-replay-warnings. 2016.12.02 21:37:36 - OpenVPN > Authenticate/Decrypt packet error: bad packet ID (may be a replay): [ #1874 ] -- see the man page entry for --no-replay and --replay-window for more info or silence this warning with --mute-replay-warnings. 2016.12.02 21:37:36 - OpenVPN > Authenticate/Decrypt packet error: bad packet ID (may be a replay): [ #1872 ] -- see the man page entry for --no-replay and --replay-window for more info or silence this warning with --mute-replay-warnings. 2016.12.02 21:37:36 - OpenVPN > Authenticate/Decrypt packet error: bad packet ID (may be a replay): [ #1873 ] -- see the man page entry for --no-replay and --replay-window for more info or silence this warning with --mute-replay-warnings. 2016.12.02 21:37:36 - OpenVPN > Authenticate/Decrypt packet error: bad packet ID (may be a replay): [ #1874 ] -- see the man page entry for --no-replay and --replay-window for more info or silence this warning with --mute-replay-warnings. 2016.12.02 21:37:36 - OpenVPN > Authenticate/Decrypt packet error: bad packet ID (may be a replay): [ #1872 ] -- see the man page entry for --no-replay and --replay-window for more info or silence this warning with --mute-replay-warnings. 2016.12.02 21:37:36 - OpenVPN > Authenticate/Decrypt packet error: bad packet ID (may be a replay): [ #1873 ] -- see the man page entry for --no-replay and --replay-window for more info or silence this warning with --mute-replay-warnings. 2016.12.02 21:37:36 - OpenVPN > Authenticate/Decrypt packet error: bad packet ID (may be a replay): [ #1874 ] -- see the man page entry for --no-replay and --replay-window for more info or silence this warning with --mute-replay-warnings. 2016.12.02 21:37:36 - OpenVPN > Authenticate/Decrypt packet error: bad packet ID (may be a replay): [ #1872 ] -- see the man page entry for --no-replay and --replay-window for more info or silence this warning with --mute-replay-warnings. 2016.12.02 21:37:36 - OpenVPN > Authenticate/Decrypt packet error: bad packet ID (may be a replay): [ #1873 ] -- see the man page entry for --no-replay and --replay-window for more info or silence this warning with --mute-replay-warnings. 2016.12.02 21:37:36 - OpenVPN > Authenticate/Decrypt packet error: bad packet ID (may be a replay): [ #1874 ] -- see the man page entry for --no-replay and --replay-window for more info or silence this warning with --mute-replay-warnings. 2016.12.02 21:37:36 - OpenVPN > Authenticate/Decrypt packet error: bad packet ID (may be a replay): [ #1893 ] -- see the man page entry for --no-replay and --replay-window for more info or silence this warning with --mute-replay-warnings. 2016.12.02 21:37:36 - OpenVPN > Authenticate/Decrypt packet error: bad packet ID (may be a replay): [ #1894 ] -- see the man page entry for --no-replay and --replay-window for more info or silence this warning with --mute-replay-warnings. 2016.12.02 21:37:36 - OpenVPN > Authenticate/Decrypt packet error: bad packet ID (may be a replay): [ #1893 ] -- see the man page entry for --no-replay and --replay-window for more info or silence this warning with --mute-replay-warnings. 2016.12.02 21:37:36 - OpenVPN > Authenticate/Decrypt packet error: bad packet ID (may be a replay): [ #1894 ] -- see the man page entry for --no-replay and --replay-window for more info or silence this warning with --mute-replay-warnings. 2016.12.02 21:37:36 - OpenVPN > Authenticate/Decrypt packet error: bad packet ID (may be a replay): [ #1893 ] -- see the man page entry for --no-replay and --replay-window for more info or silence this warning with --mute-replay-warnings. 2016.12.02 21:37:36 - OpenVPN > Authenticate/Decrypt packet error: bad packet ID (may be a replay): [ #1894 ] -- see the man page entry for --no-replay and --replay-window for more info or silence this warning with --mute-replay-warnings. 2016.12.02 21:37:36 - OpenVPN > Authenticate/Decrypt packet error: bad packet ID (may be a replay): [ #1893 ] -- see the man page entry for --no-replay and --replay-window for more info or silence this warning with --mute-replay-warnings. 2016.12.02 21:37:36 - OpenVPN > Authenticate/Decrypt packet error: bad packet ID (may be a replay): [ #1894 ] -- see the man page entry for --no-replay and --replay-window for more info or silence this warning with --mute-replay-warnings. 2016.12.02 21:37:36 - OpenVPN > Authenticate/Decrypt packet error: bad packet ID (may be a replay): [ #1893 ] -- see the man page entry for --no-replay and --replay-window for more info or silence this warning with --mute-replay-warnings. 2016.12.02 21:37:36 - OpenVPN > Authenticate/Decrypt packet error: bad packet ID (may be a replay): [ #1894 ] -- see the man page entry for --no-replay and --replay-window for more info or silence this warning with --mute-replay-warnings. 2016.12.02 21:38:08 - OpenVPN > Authenticate/Decrypt packet error: bad packet ID (may be a replay): [ #3440 ] -- see the man page entry for --no-replay and --replay-window for more info or silence this warning with --mute-replay-warnings. 2016.12.02 21:38:08 - OpenVPN > Authenticate/Decrypt packet error: bad packet ID (may be a replay): [ #3441 ] -- see the man page entry for --no-replay and --replay-window for more info or silence this warning with --mute-replay-warnings. 2016.12.02 21:38:08 - OpenVPN > Authenticate/Decrypt packet error: bad packet ID (may be a replay): [ #3440 ] -- see the man page entry for --no-replay and --replay-window for more info or silence this warning with --mute-replay-warnings. 2016.12.02 21:38:08 - OpenVPN > Authenticate/Decrypt packet error: bad packet ID (may be a replay): [ #3441 ] -- see the man page entry for --no-replay and --replay-window for more info or silence this warning with --mute-replay-warnings. 2016.12.02 21:38:08 - OpenVPN > Authenticate/Decrypt packet error: bad packet ID (may be a replay): [ #3440 ] -- see the man page entry for --no-replay and --replay-window for more info or silence this warning with --mute-replay-warnings. 2016.12.02 21:38:08 - OpenVPN > Authenticate/Decrypt packet error: bad packet ID (may be a replay): [ #3441 ] -- see the man page entry for --no-replay and --replay-window for more info or silence this warning with --mute-replay-warnings. 2016.12.02 21:38:08 - OpenVPN > Authenticate/Decrypt packet error: bad packet ID (may be a replay): [ #3440 ] -- see the man page entry for --no-replay and --replay-window for more info or silence this warning with --mute-replay-warnings. 2016.12.02 21:38:08 - OpenVPN > Authenticate/Decrypt packet error: bad packet ID (may be a replay): [ #3441 ] -- see the man page entry for --no-replay and --replay-window for more info or silence this warning with --mute-replay-warnings. 2016.12.02 21:38:08 - OpenVPN > Authenticate/Decrypt packet error: bad packet ID (may be a replay): [ #3440 ] -- see the man page entry for --no-replay and --replay-window for more info or silence this warning with --mute-replay-warnings. 2016.12.02 21:38:08 - OpenVPN > Authenticate/Decrypt packet error: bad packet ID (may be a replay): [ #3441 ] -- see the man page entry for --no-replay and --replay-window for more info or silence this warning with --mute-replay-warnings. 2016.12.02 21:38:35 - OpenVPN > Authenticate/Decrypt packet error: bad packet ID (may be a replay): [ #3636 ] -- see the man page entry for --no-replay and --replay-window for more info or silence this warning with --mute-replay-warnings. 2016.12.02 21:38:35 - OpenVPN > Authenticate/Decrypt packet error: bad packet ID (may be a replay): [ #3637 ] -- see the man page entry for --no-replay and --replay-window for more info or silence this warning with --mute-replay-warnings. 2016.12.02 21:38:35 - OpenVPN > Authenticate/Decrypt packet error: bad packet ID (may be a replay): [ #3636 ] -- see the man page entry for --no-replay and --replay-window for more info or silence this warning with --mute-replay-warnings. 2016.12.02 21:38:35 - OpenVPN > Authenticate/Decrypt packet error: bad packet ID (may be a replay): [ #3637 ] -- see the man page entry for --no-replay and --replay-window for more info or silence this warning with --mute-replay-warnings. 2016.12.02 21:38:35 - OpenVPN > Authenticate/Decrypt packet error: bad packet ID (may be a replay): [ #3636 ] -- see the man page entry for --no-replay and --replay-window for more info or silence this warning with --mute-replay-warnings. 2016.12.02 21:38:35 - OpenVPN > Authenticate/Decrypt packet error: bad packet ID (may be a replay): [ #3637 ] -- see the man page entry for --no-replay and --replay-window for more info or silence this warning with --mute-replay-warnings. 2016.12.02 21:38:35 - OpenVPN > Authenticate/Decrypt packet error: bad packet ID (may be a replay): [ #3636 ] -- see the man page entry for --no-replay and --replay-window for more info or silence this warning with --mute-replay-warnings. 2016.12.02 21:38:35 - OpenVPN > Authenticate/Decrypt packet error: bad packet ID (may be a replay): [ #3637 ] -- see the man page entry for --no-replay and --replay-window for more info or silence this warning with --mute-replay-warnings. 2016.12.02 21:38:35 - OpenVPN > Authenticate/Decrypt packet error: bad packet ID (may be a replay): [ #3638 ] -- see the man page entry for --no-replay and --replay-window for more info or silence this warning with --mute-replay-warnings. 2016.12.02 21:38:35 - OpenVPN > Authenticate/Decrypt packet error: bad packet ID (may be a replay): [ #3639 ] -- see the man page entry for --no-replay and --replay-window for more info or silence this warning with --mute-replay-warnings. 2016.12.02 21:38:35 - OpenVPN > Authenticate/Decrypt packet error: bad packet ID (may be a replay): [ #3638 ] -- see the man page entry for --no-replay and --replay-window for more info or silence this warning with --mute-replay-warnings. 2016.12.02 21:38:35 - OpenVPN > Authenticate/Decrypt packet error: bad packet ID (may be a replay): [ #3639 ] -- see the man page entry for --no-replay and --replay-window for more info or silence this warning with --mute-replay-warnings. 2016.12.02 21:38:35 - OpenVPN > Authenticate/Decrypt packet error: bad packet ID (may be a replay): [ #3638 ] -- see the man page entry for --no-replay and --replay-window for more info or silence this warning with --mute-replay-warnings. 2016.12.02 21:38:35 - OpenVPN > Authenticate/Decrypt packet error: bad packet ID (may be a replay): [ #3639 ] -- see the man page entry for --no-replay and --replay-window for more info or silence this warning with --mute-replay-warnings. 2016.12.02 21:38:35 - OpenVPN > Authenticate/Decrypt packet error: bad packet ID (may be a replay): [ #3653 ] -- see the man page entry for --no-replay and --replay-window for more info or silence this warning with --mute-replay-warnings. 2016.12.02 21:38:35 - OpenVPN > Authenticate/Decrypt packet error: bad packet ID (may be a replay): [ #3654 ] -- see the man page entry for --no-replay and --replay-window for more info or silence this warning with --mute-replay-warnings. 2016.12.02 21:38:35 - OpenVPN > Authenticate/Decrypt packet error: bad packet ID (may be a replay): [ #3653 ] -- see the man page entry for --no-replay and --replay-window for more info or silence this warning with --mute-replay-warnings. 2016.12.02 21:38:35 - OpenVPN > Authenticate/Decrypt packet error: bad packet ID (may be a replay): [ #3654 ] -- see the man page entry for --no-replay and --replay-window for more info or silence this warning with --mute-replay-warnings. 2016.12.02 21:38:35 - OpenVPN > Authenticate/Decrypt packet error: bad packet ID (may be a replay): [ #3653 ] -- see the man page entry for --no-replay and --replay-window for more info or silence this warning with --mute-replay-warnings. 2016.12.02 21:38:35 - OpenVPN > Authenticate/Decrypt packet error: bad packet ID (may be a replay): [ #3654 ] -- see the man page entry for --no-replay and --replay-window for more info or silence this warning with --mute-replay-warnings. 2016.12.02 21:38:35 - OpenVPN > Authenticate/Decrypt packet error: bad packet ID (may be a replay): [ #3653 ] -- see the man page entry for --no-replay and --replay-window for more info or silence this warning with --mute-replay-warnings. 2016.12.02 21:38:35 - OpenVPN > Authenticate/Decrypt packet error: bad packet ID (may be a replay): [ #3654 ] -- see the man page entry for --no-replay and --replay-window for more info or silence this warning with --mute-replay-warnings. 2016.12.02 21:39:55 - OpenVPN > Authenticate/Decrypt packet error: bad packet ID (may be a replay): [ #6123 ] -- see the man page entry for --no-replay and --replay-window for more info or silence this warning with --mute-replay-warnings. 2016.12.02 21:39:55 - OpenVPN > Authenticate/Decrypt packet error: bad packet ID (may be a replay): [ #6124 ] -- see the man page entry for --no-replay and --replay-window for more info or silence this warning with --mute-replay-warnings. 2016.12.02 21:39:55 - OpenVPN > Authenticate/Decrypt packet error: bad packet ID (may be a replay): [ #6123 ] -- see the man page entry for --no-replay and --replay-window for more info or silence this warning with --mute-replay-warnings. 2016.12.02 21:39:55 - OpenVPN > Authenticate/Decrypt packet error: bad packet ID (may be a replay): [ #6124 ] -- see the man page entry for --no-replay and --replay-window for more info or silence this warning with --mute-replay-warnings. 2016.12.02 21:39:55 - OpenVPN > Authenticate/Decrypt packet error: bad packet ID (may be a replay): [ #6123 ] -- see the man page entry for --no-replay and --replay-window for more info or silence this warning with --mute-replay-warnings. 2016.12.02 21:39:55 - OpenVPN > Authenticate/Decrypt packet error: bad packet ID (may be a replay): [ #6124 ] -- see the man page entry for --no-replay and --replay-window for more info or silence this warning with --mute-replay-warnings. 2016.12.02 21:39:55 - OpenVPN > Authenticate/Decrypt packet error: bad packet ID (may be a replay): [ #6123 ] -- see the man page entry for --no-replay and --replay-window for more info or silence this warning with --mute-replay-warnings. 2016.12.02 21:39:55 - OpenVPN > Authenticate/Decrypt packet error: bad packet ID (may be a replay): [ #6124 ] -- see the man page entry for --no-replay and --replay-window for more info or silence this warning with --mute-replay-warnings. 2016.12.02 21:39:55 - OpenVPN > Authenticate/Decrypt packet error: bad packet ID (may be a replay): [ #6125 ] -- see the man page entry for --no-replay and --replay-window for more info or silence this warning with --mute-replay-warnings. 2016.12.02 21:39:55 - OpenVPN > Authenticate/Decrypt packet error: bad packet ID (may be a replay): [ #6126 ] -- see the man page entry for --no-replay and --replay-window for more info or silence this warning with --mute-replay-warnings. 2016.12.02 21:39:55 - OpenVPN > Authenticate/Decrypt packet error: bad packet ID (may be a replay): [ #6127 ] -- see the man page entry for --no-replay and --replay-window for more info or silence this warning with --mute-replay-warnings. 2016.12.02 21:39:55 - OpenVPN > Authenticate/Decrypt packet error: bad packet ID (may be a replay): [ #6125 ] -- see the man page entry for --no-replay and --replay-window for more info or silence this warning with --mute-replay-warnings. 2016.12.02 21:39:55 - OpenVPN > Authenticate/Decrypt packet error: bad packet ID (may be a replay): [ #6126 ] -- see the man page entry for --no-replay and --replay-window for more info or silence this warning with --mute-replay-warnings. 2016.12.02 21:39:55 - OpenVPN > Authenticate/Decrypt packet error: bad packet ID (may be a replay): [ #6127 ] -- see the man page entry for --no-replay and --replay-window for more info or silence this warning with --mute-replay-warnings. 2016.12.02 21:39:55 - OpenVPN > Authenticate/Decrypt packet error: bad packet ID (may be a replay): [ #6125 ] -- see the man page entry for --no-replay and --replay-window for more info or silence this warning with --mute-replay-warnings. 2016.12.02 21:39:55 - OpenVPN > Authenticate/Decrypt packet error: bad packet ID (may be a replay): [ #6126 ] -- see the man page entry for --no-replay and --replay-window for more info or silence this warning with --mute-replay-warnings. 2016.12.02 21:39:55 - OpenVPN > Authenticate/Decrypt packet error: bad packet ID (may be a replay): [ #6127 ] -- see the man page entry for --no-replay and --replay-window for more info or silence this warning with --mute-replay-warnings. 2016.12.02 21:39:55 - OpenVPN > Authenticate/Decrypt packet error: bad packet ID (may be a replay): [ #6125 ] -- see the man page entry for --no-replay and --replay-window for more info or silence this warning with --mute-replay-warnings. 2016.12.02 21:39:55 - OpenVPN > Authenticate/Decrypt packet error: bad packet ID (may be a replay): [ #6126 ] -- see the man page entry for --no-replay and --replay-window for more info or silence this warning with --mute-replay-warnings. 2016.12.02 21:39:55 - OpenVPN > Authenticate/Decrypt packet error: bad packet ID (may be a replay): [ #6127 ] -- see the man page entry for --no-replay and --replay-window for more info or silence this warning with --mute-replay-warnings. 2016.12.02 21:40:15 - OpenVPN > Authenticate/Decrypt packet error: bad packet ID (may be a replay): [ #7550 ] -- see the man page entry for --no-replay and --replay-window for more info or silence this warning with --mute-replay-warnings. 2016.12.02 21:40:15 - OpenVPN > Authenticate/Decrypt packet error: bad packet ID (may be a replay): [ #7551 ] -- see the man page entry for --no-replay and --replay-window for more info or silence this warning with --mute-replay-warnings. 2016.12.02 21:40:15 - OpenVPN > Authenticate/Decrypt packet error: bad packet ID (may be a replay): [ #7550 ] -- see the man page entry for --no-replay and --replay-window for more info or silence this warning with --mute-replay-warnings. 2016.12.02 21:40:15 - OpenVPN > Authenticate/Decrypt packet error: bad packet ID (may be a replay): [ #7551 ] -- see the man page entry for --no-replay and --replay-window for more info or silence this warning with --mute-replay-warnings. 2016.12.02 21:40:15 - OpenVPN > Authenticate/Decrypt packet error: bad packet ID (may be a replay): [ #7550 ] -- see the man page entry for --no-replay and --replay-window for more info or silence this warning with --mute-replay-warnings. 2016.12.02 21:40:15 - OpenVPN > Authenticate/Decrypt packet error: bad packet ID (may be a replay): [ #7551 ] -- see the man page entry for --no-replay and --replay-window for more info or silence this warning with --mute-replay-warnings. 2016.12.02 21:40:15 - OpenVPN > Authenticate/Decrypt packet error: bad packet ID (may be a replay): [ #7550 ] -- see the man page entry for --no-replay and --replay-window for more info or silence this warning with --mute-replay-warnings. 2016.12.02 21:40:15 - OpenVPN > Authenticate/Decrypt packet error: bad packet ID (may be a replay): [ #7551 ] -- see the man page entry for --no-replay and --replay-window for more info or silence this warning with --mute-replay-warnings. 2016.12.02 21:40:15 - OpenVPN > Authenticate/Decrypt packet error: bad packet ID (may be a replay): [ #7552 ] -- see the man page entry for --no-replay and --replay-window for more info or silence this warning with --mute-replay-warnings. 2016.12.02 21:40:15 - OpenVPN > Authenticate/Decrypt packet error: bad packet ID (may be a replay): [ #7553 ] -- see the man page entry for --no-replay and --replay-window for more info or silence this warning with --mute-replay-warnings. 2016.12.02 21:40:15 - OpenVPN > Authenticate/Decrypt packet error: bad packet ID (may be a replay): [ #7554 ] -- see the man page entry for --no-replay and --replay-window for more info or silence this warning with --mute-replay-warnings. 2016.12.02 21:40:15 - OpenVPN > Authenticate/Decrypt packet error: bad packet ID (may be a replay): [ #7552 ] -- see the man page entry for --no-replay and --replay-window for more info or silence this warning with --mute-replay-warnings. 2016.12.02 21:40:15 - OpenVPN > Authenticate/Decrypt packet error: bad packet ID (may be a replay): [ #7553 ] -- see the man page entry for --no-replay and --replay-window for more info or silence this warning with --mute-replay-warnings. 2016.12.02 21:40:15 - OpenVPN > Authenticate/Decrypt packet error: bad packet ID (may be a replay): [ #7554 ] -- see the man page entry for --no-replay and --replay-window for more info or silence this warning with --mute-replay-warnings. 2016.12.02 21:40:15 - OpenVPN > Authenticate/Decrypt packet error: bad packet ID (may be a replay): [ #7552 ] -- see the man page entry for --no-replay and --replay-window for more info or silence this warning with --mute-replay-warnings. 2016.12.02 21:40:15 - OpenVPN > Authenticate/Decrypt packet error: bad packet ID (may be a replay): [ #7553 ] -- see the man page entry for --no-replay and --replay-window for more info or silence this warning with --mute-replay-warnings. 2016.12.02 21:40:15 - OpenVPN > Authenticate/Decrypt packet error: bad packet ID (may be a replay): [ #7554 ] -- see the man page entry for --no-replay and --replay-window for more info or silence this warning with --mute-replay-warnings. 2016.12.02 21:40:15 - OpenVPN > Authenticate/Decrypt packet error: bad packet ID (may be a replay): [ #7552 ] -- see the man page entry for --no-replay and --replay-window for more info or silence this warning with --mute-replay-warnings. 2016.12.02 21:40:15 - OpenVPN > Authenticate/Decrypt packet error: bad packet ID (may be a replay): [ #7553 ] -- see the man page entry for --no-replay and --replay-window for more info or silence this warning with --mute-replay-warnings. 2016.12.02 21:40:15 - OpenVPN > Authenticate/Decrypt packet error: bad packet ID (may be a replay): [ #7554 ] -- see the man page entry for --no-replay and --replay-window for more info or silence this warning with --mute-replay-warnings. 2016.12.02 21:40:15 - OpenVPN > Authenticate/Decrypt packet error: bad packet ID (may be a replay): [ #7552 ] -- see the man page entry for --no-replay and --replay-window for more info or silence this warning with --mute-replay-warnings. 2016.12.02 21:40:15 - OpenVPN > Authenticate/Decrypt packet error: bad packet ID (may be a replay): [ #7553 ] -- see the man page entry for --no-replay and --replay-window for more info or silence this warning with --mute-replay-warnings. 2016.12.02 21:40:15 - OpenVPN > Authenticate/Decrypt packet error: bad packet ID (may be a replay): [ #7554 ] -- see the man page entry for --no-replay and --replay-window for more info or silence this warning with --mute-replay-warnings. 2016.12.02 21:40:15 - OpenVPN > Authenticate/Decrypt packet error: bad packet ID (may be a replay): [ #7555 ] -- see the man page entry for --no-replay and --replay-window for more info or silence this warning with --mute-replay-warnings. 2016.12.02 21:40:15 - OpenVPN > Authenticate/Decrypt packet error: bad packet ID (may be a replay): [ #7556 ] -- see the man page entry for --no-replay and --replay-window for more info or silence this warning with --mute-replay-warnings. 2016.12.02 21:40:15 - OpenVPN > Authenticate/Decrypt packet error: bad packet ID (may be a replay): [ #7557 ] -- see the man page entry for --no-replay and --replay-window for more info or silence this warning with --mute-replay-warnings. 2016.12.02 21:40:15 - OpenVPN > Authenticate/Decrypt packet error: bad packet ID (may be a replay): [ #7555 ] -- see the man page entry for --no-replay and --replay-window for more info or silence this warning with --mute-replay-warnings. 2016.12.02 21:40:15 - OpenVPN > Authenticate/Decrypt packet error: bad packet ID (may be a replay): [ #7556 ] -- see the man page entry for --no-replay and --replay-window for more info or silence this warning with --mute-replay-warnings. 2016.12.02 21:40:15 - OpenVPN > Authenticate/Decrypt packet error: bad packet ID (may be a replay): [ #7557 ] -- see the man page entry for --no-replay and --replay-window for more info or silence this warning with --mute-replay-warnings. 2016.12.02 21:40:15 - OpenVPN > Authenticate/Decrypt packet error: bad packet ID (may be a replay): [ #7555 ] -- see the man page entry for --no-replay and --replay-window for more info or silence this warning with --mute-replay-warnings. 2016.12.02 21:40:15 - OpenVPN > Authenticate/Decrypt packet error: bad packet ID (may be a replay): [ #7556 ] -- see the man page entry for --no-replay and --replay-window for more info or silence this warning with --mute-replay-warnings. 2016.12.02 21:40:15 - OpenVPN > Authenticate/Decrypt packet error: bad packet ID (may be a replay): [ #7557 ] -- see the man page entry for --no-replay and --replay-window for more info or silence this warning with --mute-replay-warnings. 2016.12.02 21:40:15 - OpenVPN > Authenticate/Decrypt packet error: bad packet ID (may be a replay): [ #7555 ] -- see the man page entry for --no-replay and --replay-window for more info or silence this warning with --mute-replay-warnings. 2016.12.02 21:40:15 - OpenVPN > Authenticate/Decrypt packet error: bad packet ID (may be a replay): [ #7556 ] -- see the man page entry for --no-replay and --replay-window for more info or silence this warning with --mute-replay-warnings. 2016.12.02 21:40:15 - OpenVPN > Authenticate/Decrypt packet error: bad packet ID (may be a replay): [ #7557 ] -- see the man page entry for --no-replay and --replay-window for more info or silence this warning with --mute-replay-warnings. 2016.12.02 21:40:15 - OpenVPN > Authenticate/Decrypt packet error: bad packet ID (may be a replay): [ #7555 ] -- see the man page entry for --no-replay and --replay-window for more info or silence this warning with --mute-replay-warnings. 2016.12.02 21:40:15 - OpenVPN > Authenticate/Decrypt packet error: bad packet ID (may be a replay): [ #7556 ] -- see the man page entry for --no-replay and --replay-window for more info or silence this warning with --mute-replay-warnings. 2016.12.02 21:40:15 - OpenVPN > Authenticate/Decrypt packet error: bad packet ID (may be a replay): [ #7557 ] -- see the man page entry for --no-replay and --replay-window for more info or silence this warning with --mute-replay-warnings. 2016.12.02 21:40:50 - OpenVPN > Authenticate/Decrypt packet error: bad packet ID (may be a replay): [ #7725 ] -- see the man page entry for --no-replay and --replay-window for more info or silence this warning with --mute-replay-warnings. 2016.12.02 21:40:50 - OpenVPN > Authenticate/Decrypt packet error: bad packet ID (may be a replay): [ #7726 ] -- see the man page entry for --no-replay and --replay-window for more info or silence this warning with --mute-replay-warnings. 2016.12.02 21:40:50 - OpenVPN > Authenticate/Decrypt packet error: bad packet ID (may be a replay): [ #7725 ] -- see the man page entry for --no-replay and --replay-window for more info or silence this warning with --mute-replay-warnings. 2016.12.02 21:40:50 - OpenVPN > Authenticate/Decrypt packet error: bad packet ID (may be a replay): [ #7726 ] -- see the man page entry for --no-replay and --replay-window for more info or silence this warning with --mute-replay-warnings. 2016.12.02 21:40:50 - OpenVPN > Authenticate/Decrypt packet error: bad packet ID (may be a replay): [ #7725 ] -- see the man page entry for --no-replay and --replay-window for more info or silence this warning with --mute-replay-warnings. 2016.12.02 21:40:50 - OpenVPN > Authenticate/Decrypt packet error: bad packet ID (may be a replay): [ #7726 ] -- see the man page entry for --no-replay and --replay-window for more info or silence this warning with --mute-replay-warnings. 2016.12.02 21:40:50 - OpenVPN > Authenticate/Decrypt packet error: bad packet ID (may be a replay): [ #7725 ] -- see the man page entry for --no-replay and --replay-window for more info or silence this warning with --mute-replay-warnings. 2016.12.02 21:40:50 - OpenVPN > Authenticate/Decrypt packet error: bad packet ID (may be a replay): [ #7726 ] -- see the man page entry for --no-replay and --replay-window for more info or silence this warning with --mute-replay-warnings. 2016.12.02 21:43:30 - Updating systems & servers data .... 2016.12.02 21:43:31 - Systems & servers data update completed . 2016.12.02 20:19:00 - OpenVPN > DHCP LEASE EXPIRES = Fri Dec 02 20:19:00 2016. 2016.12.02 20:19:00 - OpenVPN > DNS SERV =. 2016.12.02 20:19:00 - OpenVPN > TAP-Windows Adapter V9. 2016.12.02 20:19:00 - OpenVPN > Index = 18. 2016.12.02 20:19:00 - OpenVPN > GUID = {F40AE409-E4BC-4ABA-B9F7-3BD827158EE3}. 2016.12.02 20:19:00 - OpenVPN > IP = 10.4.92.206/255.255.0.0. 2016.12.02 20:19:00 - OpenVPN > MAC = 00:ff:f4:0a:e4:09. 2016.12.02 20:19:00 - OpenVPN > GATEWAY = 0.0.0.0/255.255.255.255. 2016.12.02 20:19:00 - OpenVPN > DHCP SERV = 10.4.255.254/255.255.255.255. 2016.12.02 20:19:00 - OpenVPN > DHCP LEASE OBTAINED = Fri Dec 02 17:21:12 2016. 2016.12.02 20:19:00 - OpenVPN > DHCP LEASE EXPIRES = Sat Dec 02 17:21:12 2017. 2016.12.02 20:19:00 - OpenVPN > DNS SERV = 10.4.0.1/255.255.255.255. 2016.12.02 20:19:00 - OpenVPN > 300Mbps Wireless USB Adapter. 2016.12.02 20:19:00 - OpenVPN > Index = 17. 2016.12.02 20:19:00 - OpenVPN > GUID = {D6DBB021-16B1-4402-97B4-1CEEE4201C7C}. 2016.12.02 20:19:00 - OpenVPN > IP = 192.168.1.101/255.255.255.0. 2016.12.02 20:19:00 - OpenVPN > MAC = 14:cc:20:17:0d:7f. 2016.12.02 20:19:00 - OpenVPN > GATEWAY = 192.168.1.1/255.255.255.255. 2016.12.02 20:19:00 - OpenVPN > DHCP SERV = 192.168.1.1/255.255.255.255. 2016.12.02 20:19:00 - OpenVPN > DHCP LEASE OBTAINED = Fri Dec 02 18:11:06 2016. 2016.12.02 20:19:00 - OpenVPN > DHCP LEASE EXPIRES = Sat Dec 03 18:11:06 2016. 2016.12.02 20:19:00 - OpenVPN > DNS SERV = 10.4.0.1/255.255.255.255. 2016.12.02 20:19:00 - OpenVPN > Microsoft Wi-Fi Direct Virtual Adapter. 2016.12.02 20:19:00 - OpenVPN > Index = 13. 2016.12.02 20:19:00 - OpenVPN > GUID = {AEB675DF-7F7D-4FED-BC91-F8C40081B696}. 2016.12.02 20:19:00 - OpenVPN > IP = 0.0.0.0/0.0.0.0. 2016.12.02 20:19:00 - OpenVPN > MAC = 14:cc:20:17:0d:7f. 2016.12.02 20:19:00 - OpenVPN > GATEWAY = 0.0.0.0/255.255.255.255. 2016.12.02 20:19:00 - OpenVPN > DHCP SERV =. 2016.12.02 20:19:00 - OpenVPN > DHCP LEASE OBTAINED = Fri Dec 02 20:19:00 2016. 2016.12.02 20:19:00 - OpenVPN > DHCP LEASE EXPIRES = Fri Dec 02 20:19:00 2016. 2016.12.02 20:19:00 - OpenVPN > DNS SERV =. 2016.12.02 20:19:00 - Starting Management Interface. 2016.12.02 20:19:00 - OpenVPN > Initialization Sequence Completed With Errors ( see http://openvpn.net/faq.html#dhcpclientserv )! 2016.12.02 20:19:00 - Disconnecting. 2016.12.02 20:19:00 - Management - Send 'signal SIGTERM'. 2016.12.02 20:19:00 - OpenVpn Management > >INFO:OpenVPN Management Interface Version 1 -- type 'help' for more info. 2016.12.02 20:19:00 - DNS leak protection with packet filtering enabled.I 2016.12.02 20:19:00 - Flushing DNSW 2016.12.02 20:19:01 - Checking route, 4° try failed (The remote name could not be resolved: 'sheliak_exit.airservers.org'). 2016.12.02 20:19:05 - Connection terminated.. 2016.12.02 20:19:05 - DNS leak protection with packet filtering disabled.I 2016.12.02 20:19:08 - Checking authorization ...! 2016.12.02 20:19:08 - Connecting to Nash (Netherlands, Alblasserdam). 2016.12.02 20:19:08 - OpenVPN > OpenVPN 2.3.13 x86_64-w64-mingw32 [sSL (OpenSSL)] [LZO] [iPv6] built on Nov 10 2016. 2016.12.02 20:19:08 - OpenVPN > Windows version 6.2 (Windows 8 or greater) 64bit. 2016.12.02 20:19:08 - OpenVPN > library versions: OpenSSL 1.0.2j 26 Sep 2016, LZO 2.09. 2016.12.02 20:19:08 - OpenVPN > MANAGEMENT: TCP Socket listening on [AF_INET]127.0.0.1:3100. 2016.12.02 20:19:08 - OpenVPN > Control Channel Authentication: tls-auth using INLINE static key file. 2016.12.02 20:19:08 - OpenVPN > Outgoing Control Channel Authentication: Using 160 bit message hash 'SHA1' for HMAC authentication. 2016.12.02 20:19:08 - OpenVPN > Incoming Control Channel Authentication: Using 160 bit message hash 'SHA1' for HMAC authentication. 2016.12.02 20:19:08 - OpenVPN > Socket Buffers: R=[65536->262144] S=[65536->262144]. 2016.12.02 20:19:08 - OpenVPN > UDPv4 link local: [undef]. 2016.12.02 20:19:08 - OpenVPN > UDPv4 link remote: [AF_INET]213.152.161.24:443. 2016.12.02 20:19:08 - OpenVPN > TLS: Initial packet from [AF_INET]213.152.161.24:443, sid=a77639e4 f7ed1b28. 2016.12.02 20:19:08 - OpenVPN > VERIFY OK: depth=1, C=IT, ST=IT, L=Perugia, O=airvpn.org, CN=airvpn.org CA, emailAddress=info@airvpn.org. 2016.12.02 20:19:08 - OpenVPN > Validating certificate key usage. 2016.12.02 20:19:08 - OpenVPN > ++ Certificate has key usage 00a0, expects 00a0. 2016.12.02 20:19:08 - OpenVPN > VERIFY KU OK. 2016.12.02 20:19:08 - OpenVPN > Validating certificate extended key usage. 2016.12.02 20:19:08 - OpenVPN > ++ Certificate has EKU (str) TLS Web Server Authentication, expects TLS Web Server Authentication. 2016.12.02 20:19:08 - OpenVPN > VERIFY EKU OK. 2016.12.02 20:19:08 - OpenVPN > VERIFY OK: depth=0, C=IT, ST=IT, L=Perugia, O=airvpn.org, CN=server, emailAddress=info@airvpn.org. 2016.12.02 20:19:08 - OpenVPN > Data Channel Encrypt: Cipher 'AES-256-CBC' initialized with 256 bit key. 2016.12.02 20:19:08 - OpenVPN > Data Channel Encrypt: Using 160 bit message hash 'SHA1' for HMAC authentication. 2016.12.02 20:19:08 - OpenVPN > Data Channel Decrypt: Cipher 'AES-256-CBC' initialized with 256 bit key. 2016.12.02 20:19:08 - OpenVPN > Data Channel Decrypt: Using 160 bit message hash 'SHA1' for HMAC authentication. 2016.12.02 20:19:08 - OpenVPN > Control Channel: TLSv1.2, cipher TLSv1/SSLv3 DHE-RSA-AES256-GCM-SHA384, 4096 bit RSA. 2016.12.02 20:19:08 - OpenVPN > [server] Peer Connection Initiated with [AF_INET]213.152.161.24:443I 2016.12.02 20:19:08 - Checking route. 2016.12.02 20:19:11 - OpenVPN > SENT CONTROL [server]: 'PUSH_REQUEST' (status=1). 2016.12.02 20:19:11 - OpenVPN > PUSH: Received control message: 'PUSH_REPLY,redirect-gateway def1 bypass-dhcp,dhcp-option DNS 10.4.0.1,comp-lzo no,route-gateway 10.4.0.1,topology subnet,ping 10,ping-restart 60,ifconfig 10.4.94.84 255.255.0.0'. 2016.12.02 20:19:11 - OpenVPN > OPTIONS IMPORT: timers and/or timeouts modified. 2016.12.02 20:19:11 - OpenVPN > OPTIONS IMPORT: LZO parms modified. 2016.12.02 20:19:11 - OpenVPN > OPTIONS IMPORT: --ifconfig/up options modified. 2016.12.02 20:19:11 - OpenVPN > OPTIONS IMPORT: route options modified. 2016.12.02 20:19:11 - OpenVPN > OPTIONS IMPORT: route-related options modified. 2016.12.02 20:19:11 - OpenVPN > OPTIONS IMPORT: --ip-win32 and/or --dhcp-option options modified. 2016.12.02 20:19:11 - OpenVPN > ROUTE_GATEWAY 192.168.1.1/255.255.255.0 I=17 HWADDR=14:cc:20:17:0d:7f. 2016.12.02 20:19:11 - OpenVPN > do_ifconfig, tt->ipv6=0, tt->did_ifconfig_ipv6_setup=0. 2016.12.02 20:19:11 - OpenVPN > open_tun, tt->ipv6=0. 2016.12.02 20:19:11 - OpenVPN > TAP-WIN32 device [Local Area Connection 2] opened: \\.\Global\{F40AE409-E4BC-4ABA-B9F7-3BD827158EE3}.tap. 2016.12.02 20:19:11 - OpenVPN > TAP-Windows Driver Version 9.21. 2016.12.02 20:19:11 - OpenVPN > Set TAP-Windows TUN subnet mode network/local/netmask = 10.4.0.0/10.4.94.84/255.255.0.0 [sUCCEEDED]. 2016.12.02 20:19:11 - OpenVPN > Notified TAP-Windows driver to set a DHCP IP/netmask of 10.4.94.84/255.255.0.0 on interface {F40AE409-E4BC-4ABA-B9F7-3BD827158EE3} [DHCP-serv: 10.4.255.254, lease-time: 31536000]. 2016.12.02 20:19:11 - OpenVPN > Successful ARP Flush on interface [18] {F40AE409-E4BC-4ABA-B9F7-3BD827158EE3}W 2016.12.02 20:19:15 - Checking route, 5° try failed (The operation has timed out)W 2016.12.02 20:19:15 - The operation has timed out. 2016.12.02 20:19:15 - OpenVPN > MANAGEMENT: CMD 'signal SIGTERM'. 2016.12.02 20:19:15 - OpenVPN > SIGTERM received, sending exit notification to peer. 2016.12.02 20:19:15 - OpenVPN > C:\WINDOWS\system32\route.exe DELETE 213.152.161.132 MASK 255.255.255.255 192.168.1.1. 2016.12.02 20:19:15 - OpenVPN > Route deletion via IPAPI succeeded [adaptive]. 2016.12.02 20:19:15 - OpenVPN > C:\WINDOWS\system32\route.exe DELETE 0.0.0.0 MASK 128.0.0.0 10.4.0.1. 2016.12.02 20:19:15 - OpenVPN > Route deletion via IPAPI succeeded [adaptive]. 2016.12.02 20:19:15 - OpenVPN > C:\WINDOWS\system32\route.exe DELETE 128.0.0.0 MASK 128.0.0.0 10.4.0.1. 2016.12.02 20:19:15 - OpenVPN > Route deletion via IPAPI succeeded [adaptive]. 2016.12.02 20:19:15 - OpenVPN > Closing TUN/TAP interface. 2016.12.02 20:19:15 - OpenVPN > SIGTERM[soft,exit-with-notification] received, process exiting! 2016.12.02 20:19:15 - Disconnecting. 2016.12.02 20:19:15 - Connection terminated.I 2016.12.02 20:19:18 - Checking authorization ...! 2016.12.02 20:19:18 - Connecting to Kocab (Netherlands, Alblasserdam). 2016.12.02 20:19:18 - OpenVPN > OpenVPN 2.3.13 x86_64-w64-mingw32 [sSL (OpenSSL)] [LZO] [iPv6] built on Nov 10 2016. 2016.12.02 20:19:18 - OpenVPN > Windows version 6.2 (Windows 8 or greater) 64bit. 2016.12.02 20:19:18 - OpenVPN > library versions: OpenSSL 1.0.2j 26 Sep 2016, LZO 2.09. 2016.12.02 20:19:18 - OpenVPN > MANAGEMENT: TCP Socket listening on [AF_INET]127.0.0.1:3100. 2016.12.02 20:19:18 - OpenVPN > Control Channel Authentication: tls-auth using INLINE static key file. 2016.12.02 20:19:18 - OpenVPN > Outgoing Control Channel Authentication: Using 160 bit message hash 'SHA1' for HMAC authentication. 2016.12.02 20:19:18 - OpenVPN > Incoming Control Channel Authentication: Using 160 bit message hash 'SHA1' for HMAC authentication. 2016.12.02 20:19:18 - OpenVPN > Socket Buffers: R=[65536->262144] S=[65536->262144]. 2016.12.02 20:19:18 - OpenVPN > UDPv4 link local: [undef]. 2016.12.02 20:19:18 - OpenVPN > UDPv4 link remote: [AF_INET]213.152.162.180:443. 2016.12.02 20:19:18 - OpenVPN > TLS: Initial packet from [AF_INET]213.152.162.180:443, sid=e7152d1d 767e634d. 2016.12.02 20:19:18 - OpenVPN > VERIFY OK: depth=1, C=IT, ST=IT, L=Perugia, O=airvpn.org, CN=airvpn.org CA, emailAddress=info@airvpn.org. 2016.12.02 20:19:18 - OpenVPN > Validating certificate key usage. 2016.12.02 20:19:18 - OpenVPN > ++ Certificate has key usage 00a0, expects 00a0. 2016.12.02 20:19:18 - OpenVPN > VERIFY KU OK. 2016.12.02 20:19:18 - OpenVPN > Validating certificate extended key usage. 2016.12.02 20:19:18 - OpenVPN > ++ Certificate has EKU (str) TLS Web Server Authentication, expects TLS Web Server Authentication. 2016.12.02 20:19:18 - OpenVPN > VERIFY EKU OK. 2016.12.02 20:19:18 - OpenVPN > VERIFY OK: depth=0, C=IT, ST=IT, L=Perugia, O=airvpn.org, CN=server, emailAddress=info@airvpn.orgW 2016.12.02 20:19:20 - Checking route, 1° try failed (The operation has timed out). 2016.12.02 20:19:22 - OpenVPN > Data Channel Encrypt: Cipher 'AES-256-CBC' initialized with 256 bit key. 2016.12.02 20:19:22 - OpenVPN > Data Channel Encrypt: Using 160 bit message hash 'SHA1' for HMAC authentication. 2016.12.02 20:19:22 - OpenVPN > Data Channel Decrypt: Cipher 'AES-256-CBC' initialized with 256 bit key. 2016.12.02 20:19:22 - OpenVPN > Data Channel Decrypt: Using 160 bit message hash 'SHA1' for HMAC authentication. 2016.12.02 20:19:22 - OpenVPN > Control Channel: TLSv1.2, cipher TLSv1/SSLv3 DHE-RSA-AES256-GCM-SHA384, 4096 bit RSA. 2016.12.02 20:19:22 - OpenVPN > [server] Peer Connection Initiated with [AF_INET]213.152.162.180:443. 2016.12.02 20:19:25 - OpenVPN > SENT CONTROL [server]: 'PUSH_REQUEST' (status=1). 2016.12.02 20:19:25 - OpenVPN > PUSH: Received control message: 'PUSH_REPLY,redirect-gateway def1 bypass-dhcp,dhcp-option DNS 10.4.0.1,comp-lzo no,route-gateway 10.4.0.1,topology subnet,ping 10,ping-restart 60,ifconfig 10.4.75.209 255.255.0.0'. 2016.12.02 20:19:25 - OpenVPN > OPTIONS IMPORT: timers and/or timeouts modified. 2016.12.02 20:19:25 - OpenVPN > OPTIONS IMPORT: LZO parms modified. 2016.12.02 20:19:25 - OpenVPN > OPTIONS IMPORT: --ifconfig/up options modified. 2016.12.02 20:19:25 - OpenVPN > OPTIONS IMPORT: route options modified. 2016.12.02 20:19:25 - OpenVPN > OPTIONS IMPORT: route-related options modified. 2016.12.02 20:19:25 - OpenVPN > OPTIONS IMPORT: --ip-win32 and/or --dhcp-option options modified. 2016.12.02 20:19:25 - OpenVPN > ROUTE_GATEWAY 192.168.1.1/255.255.255.0 I=17 HWADDR=14:cc:20:17:0d:7f. 2016.12.02 20:19:25 - OpenVPN > do_ifconfig, tt->ipv6=0, tt->did_ifconfig_ipv6_setup=0. 2016.12.02 20:19:25 - OpenVPN > open_tun, tt->ipv6=0. 2016.12.02 20:19:25 - OpenVPN > TAP-WIN32 device [Local Area Connection 2] opened: \\.\Global\{F40AE409-E4BC-4ABA-B9F7-3BD827158EE3}.tap. 2016.12.02 20:19:25 - OpenVPN > TAP-Windows Driver Version 9.21. 2016.12.02 20:19:25 - OpenVPN > Set TAP-Windows TUN subnet mode network/local/netmask = 10.4.0.0/10.4.75.209/255.255.0.0 [sUCCEEDED]. 2016.12.02 20:19:25 - OpenVPN > Notified TAP-Windows driver to set a DHCP IP/netmask of 10.4.75.209/255.255.0.0 on interface {F40AE409-E4BC-4ABA-B9F7-3BD827158EE3} [DHCP-serv: 10.4.255.254, lease-time: 31536000]. 2016.12.02 20:19:25 - OpenVPN > Successful ARP Flush on interface [18] {F40AE409-E4BC-4ABA-B9F7-3BD827158EE3}. 2016.12.02 20:19:30 - OpenVPN > TEST ROUTES: 0/0 succeeded len=0 ret=0 a=0 u/d=down. 2016.12.02 20:19:30 - OpenVPN > Route: Waiting for TUN/TAP interface to come up.... 2016.12.02 20:19:30 - Eddie Windows Interface Hack executed (Local Area Connection 2)W 2016.12.02 20:19:32 - Checking route, 2° try failed (The operation has timed out). 2016.12.02 20:19:35 - OpenVPN > TEST ROUTES: 0/0 succeeded len=0 ret=0 a=0 u/d=down. 2016.12.02 20:19:35 - OpenVPN > Route: Waiting for TUN/TAP interface to come up.... 2016.12.02 20:19:35 - Eddie Windows Interface Hack executed (Local Area Connection 2). 2016.12.02 20:19:36 - OpenVPN > TEST ROUTES: 0/0 succeeded len=0 ret=0 a=0 u/d=down. 2016.12.02 20:19:36 - OpenVPN > Route: Waiting for TUN/TAP interface to come up.... 2016.12.02 20:19:36 - Eddie Windows Interface Hack executed (Local Area Connection 2). 2016.12.02 20:19:37 - OpenVPN > TEST ROUTES: 0/0 succeeded len=0 ret=0 a=0 u/d=down. 2016.12.02 20:19:37 - OpenVPN > Route: Waiting for TUN/TAP interface to come up.... 2016.12.02 20:19:37 - Eddie Windows Interface Hack executed (Local Area Connection 2). 2016.12.02 20:19:38 - OpenVPN > TEST ROUTES: 0/0 succeeded len=0 ret=0 a=0 u/d=down. 2016.12.02 20:19:38 - OpenVPN > Route: Waiting for TUN/TAP interface to come up.... 2016.12.02 20:19:38 - Eddie Windows Interface Hack executed (Local Area Connection 2). 2016.12.02 20:19:39 - OpenVPN > TEST ROUTES: 0/0 succeeded len=0 ret=0 a=0 u/d=down. 2016.12.02 20:19:39 - OpenVPN > Route: Waiting for TUN/TAP interface to come up.... 2016.12.02 20:19:39 - Eddie Windows Interface Hack executed (Local Area Connection 2). 2016.12.02 20:19:40 - OpenVPN > TEST ROUTES: 0/0 succeeded len=0 ret=0 a=0 u/d=down. 2016.12.02 20:19:40 - OpenVPN > Route: Waiting for TUN/TAP interface to come up.... 2016.12.02 20:19:40 - Eddie Windows Interface Hack executed (Local Area Connection 2). 2016.12.02 20:19:42 - OpenVPN > TEST ROUTES: 0/0 succeeded len=0 ret=0 a=0 u/d=down. 2016.12.02 20:19:42 - OpenVPN > Route: Waiting for TUN/TAP interface to come up.... 2016.12.02 20:19:42 - Eddie Windows Interface Hack executed (Local Area Connection 2). 2016.12.02 20:19:43 - OpenVPN > TEST ROUTES: 0/0 succeeded len=0 ret=0 a=0 u/d=down. 2016.12.02 20:19:43 - OpenVPN > Route: Waiting for TUN/TAP interface to come up.... 2016.12.02 20:19:43 - Eddie Windows Interface Hack executed (Local Area Connection 2). 2016.12.02 20:19:44 - OpenVPN > TEST ROUTES: 0/0 succeeded len=0 ret=0 a=0 u/d=down. 2016.12.02 20:19:44 - OpenVPN > Route: Waiting for TUN/TAP interface to come up.... 2016.12.02 20:19:44 - Eddie Windows Interface Hack executed (Local Area Connection 2)W 2016.12.02 20:19:44 - Checking route, 3° try failed (The operation has timed out). 2016.12.02 20:19:46 - OpenVPN > TEST ROUTES: 0/0 succeeded len=0 ret=0 a=0 u/d=down. 2016.12.02 20:19:46 - OpenVPN > Route: Waiting for TUN/TAP interface to come up.... 2016.12.02 20:19:46 - Eddie Windows Interface Hack executed (Local Area Connection 2). 2016.12.02 20:19:47 - OpenVPN > TEST ROUTES: 0/0 succeeded len=0 ret=0 a=0 u/d=down. 2016.12.02 20:19:47 - OpenVPN > Route: Waiting for TUN/TAP interface to come up.... 2016.12.02 20:19:47 - Eddie Windows Interface Hack executed (Local Area Connection 2). 2016.12.02 20:19:48 - OpenVPN > TEST ROUTES: 0/0 succeeded len=0 ret=0 a=0 u/d=down. 2016.12.02 20:19:48 - OpenVPN > Route: Waiting for TUN/TAP interface to come up.... 2016.12.02 20:19:48 - Eddie Windows Interface Hack executed (Local Area Connection 2). 2016.12.02 20:19:49 - OpenVPN > TEST ROUTES: 0/0 succeeded len=0 ret=0 a=0 u/d=down. 2016.12.02 20:19:49 - OpenVPN > Route: Waiting for TUN/TAP interface to come up.... 2016.12.02 20:19:49 - Eddie Windows Interface Hack executed (Local Area Connection 2). 2016.12.02 20:19:51 - OpenVPN > TEST ROUTES: 0/0 succeeded len=0 ret=0 a=0 u/d=down. 2016.12.02 20:19:51 - OpenVPN > Route: Waiting for TUN/TAP interface to come up.... 2016.12.02 20:19:51 - Eddie Windows Interface Hack executed (Local Area Connection 2). 2016.12.02 20:19:52 - OpenVPN > TEST ROUTES: 0/0 succeeded len=0 ret=0 a=0 u/d=down. 2016.12.02 20:19:52 - OpenVPN > Route: Waiting for TUN/TAP interface to come up.... 2016.12.02 20:19:52 - Eddie Windows Interface Hack executed (Local Area Connection 2). 2016.12.02 20:19:53 - OpenVPN > TEST ROUTES: 0/0 succeeded len=0 ret=0 a=0 u/d=down. 2016.12.02 20:19:53 - OpenVPN > Route: Waiting for TUN/TAP interface to come up.... 2016.12.02 20:19:53 - Eddie Windows Interface Hack executed (Local Area Connection 2). 2016.12.02 20:19:54 - OpenVPN > TEST ROUTES: 0/0 succeeded len=0 ret=0 a=0 u/d=down. 2016.12.02 20:19:54 - OpenVPN > Route: Waiting for TUN/TAP interface to come up.... 2016.12.02 20:19:54 - Eddie Windows Interface Hack executed (Local Area Connection 2). 2016.12.02 20:19:55 - OpenVPN > TEST ROUTES: 0/0 succeeded len=0 ret=0 a=0 u/d=down. 2016.12.02 20:19:55 - OpenVPN > Route: Waiting for TUN/TAP interface to come up.... 2016.12.02 20:19:55 - Eddie Windows Interface Hack executed (Local Area Connection 2). 2016.12.02 20:19:56 - OpenVPN > TEST ROUTES: 0/0 succeeded len=0 ret=0 a=0 u/d=down. 2016.12.02 20:19:56 - OpenVPN > Route: Waiting for TUN/TAP interface to come up.... 2016.12.02 20:19:56 - Eddie Windows Interface Hack executed (Local Area Connection 2)W 2016.12.02 20:19:56 - Checking route, 4° try failed (The operation has timed out). 2016.12.02 20:19:57 - OpenVPN > TEST ROUTES: 0/0 succeeded len=0 ret=0 a=0 u/d=down. 2016.12.02 20:19:57 - OpenVPN > Route: Waiting for TUN/TAP interface to come up.... 2016.12.02 20:19:57 - Eddie Windows Interface Hack executed (Local Area Connection 2). 2016.12.02 20:19:58 - OpenVPN > TEST ROUTES: 0/0 succeeded len=0 ret=0 a=0 u/d=down. 2016.12.02 20:19:58 - OpenVPN > Route: Waiting for TUN/TAP interface to come up.... 2016.12.02 20:19:58 - Eddie Windows Interface Hack executed (Local Area Connection 2). 2016.12.02 20:19:59 - OpenVPN > TEST ROUTES: 0/0 succeeded len=0 ret=0 a=0 u/d=down. 2016.12.02 20:19:59 - OpenVPN > Route: Waiting for TUN/TAP interface to come up.... 2016.12.02 20:19:59 - Eddie Windows Interface Hack executed (Local Area Connection 2). 2016.12.02 20:20:00 - OpenVPN > TEST ROUTES: 0/0 succeeded len=0 ret=0 a=0 u/d=down. 2016.12.02 20:20:00 - OpenVPN > C:\WINDOWS\system32\route.exe ADD 213.152.162.180 MASK 255.255.255.255 192.168.1.1. 2016.12.02 20:20:00 - OpenVPN > ROUTE: CreateIpForwardEntry succeeded with dwForwardMetric1=45 and dwForwardType=4. 2016.12.02 20:20:00 - OpenVPN > Route addition via IPAPI succeeded [adaptive]. 2016.12.02 20:20:00 - OpenVPN > C:\WINDOWS\system32\route.exe ADD 0.0.0.0 MASK 128.0.0.0 10.4.0.1. 2016.12.02 20:20:00 - OpenVPN > ROUTE: CreateIpForwardEntry succeeded with dwForwardMetric1=35 and dwForwardType=4. 2016.12.02 20:20:00 - OpenVPN > Route addition via IPAPI succeeded [adaptive]. 2016.12.02 20:20:00 - OpenVPN > C:\WINDOWS\system32\route.exe ADD 128.0.0.0 MASK 128.0.0.0 10.4.0.1. 2016.12.02 20:20:00 - OpenVPN > ROUTE: CreateIpForwardEntry succeeded with dwForwardMetric1=35 and dwForwardType=4. 2016.12.02 20:20:00 - OpenVPN > Route addition via IPAPI succeeded [adaptive]. 2016.12.02 20:20:00 - OpenVPN > SYSTEM ROUTING TABLE. 2016.12.02 20:20:00 - OpenVPN > 0.0.0.0 0.0.0.0 192.168.1.1 p=0 i=17 t=4 pr=3 a=10770 h=0 m=45/0/0/0/0. 2016.12.02 20:20:00 - OpenVPN > 0.0.0.0 128.0.0.0 10.4.0.1 p=0 i=18 t=4 pr=3 a=0 h=0 m=35/0/0/0/0. 2016.12.02 20:20:00 - OpenVPN > 10.4.0.0 255.255.0.0 10.4.92.206 p=0 i=18 t=3 pr=2 a=10728 h=0 m=291/0/0/0/0. 2016.12.02 20:20:00 - OpenVPN > 10.4.92.206 255.255.255.255 10.4.92.206 p=0 i=18 t=3 pr=2 a=10728 h=0 m=291/0/0/0/0. 2016.12.02 20:20:00 - OpenVPN > 10.4.255.255 255.255.255.255 10.4.92.206 p=0 i=18 t=3 pr=2 a=10728 h=0 m=291/0/0/0/0. 2016.12.02 20:20:00 - OpenVPN > 127.0.0.0 255.0.0.0 127.0.0.1 p=0 i=1 t=3 pr=2 a=10779 h=0 m=331/0/0/0/0. 2016.12.02 20:20:00 - OpenVPN > 127.0.0.1 255.255.255.255 127.0.0.1 p=0 i=1 t=3 pr=2 a=10779 h=0 m=331/0/0/0/0. 2016.12.02 20:20:00 - OpenVPN > 127.255.255.255 255.255.255.255 127.0.0.1 p=0 i=1 t=3 pr=2 a=10779 h=0 m=331/0/0/0/0. 2016.12.02 20:20:00 - OpenVPN > 128.0.0.0 128.0.0.0 10.4.0.1 p=0 i=18 t=4 pr=3 a=0 h=0 m=35/0/0/0/0. 2016.12.02 20:20:00 - OpenVPN > 192.168.1.0 255.255.255.0 192.168.1.101 p=0 i=17 t=3 pr=2 a=10770 h=0 m=301/0/0/0/0. 2016.12.02 20:20:00 - OpenVPN > 192.168.1.101 255.255.255.255 192.168.1.101 p=0 i=17 t=3 pr=2 a=10770 h=0 m=301/0/0/0/0. 2016.12.02 20:20:00 - OpenVPN > 192.168.1.255 255.255.255.255 192.168.1.101 p=0 i=17 t=3 pr=2 a=10770 h=0 m=301/0/0/0/0. 2016.12.02 20:20:00 - OpenVPN > 213.152.162.180 255.255.255.255 192.168.1.1 p=0 i=17 t=4 pr=3 a=0 h=0 m=45/0/0/0/0. 2016.12.02 20:20:00 - OpenVPN > 224.0.0.0 240.0.0.0 127.0.0.1 p=0 i=1 t=3 pr=2 a=10779 h=0 m=331/0/0/0/0. 2016.12.02 20:20:00 - OpenVPN > 224.0.0.0 240.0.0.0 10.4.92.206 p=0 i=18 t=3 pr=2 a=10778 h=0 m=291/0/0/0/0. 2016.12.02 20:20:00 - OpenVPN > 224.0.0.0 240.0.0.0 192.168.1.101 p=0 i=17 t=3 pr=2 a=10772 h=0 m=301/0/0/0/0. 2016.12.02 20:20:00 - OpenVPN > 255.255.255.255 255.255.255.255 127.0.0.1 p=0 i=1 t=3 pr=2 a=10779 h=0 m=331/0/0/0/0. 2016.12.02 20:20:00 - OpenVPN > 255.255.255.255 255.255.255.255 10.4.92.206 p=0 i=18 t=3 pr=2 a=10778 h=0 m=291/0/0/0/0. 2016.12.02 20:20:00 - OpenVPN > 255.255.255.255 255.255.255.255 192.168.1.101 p=0 i=17 t=3 pr=2 a=10772 h=0 m=301/0/0/0/0. 2016.12.02 20:20:00 - OpenVPN > SYSTEM ADAPTER LIST. 2016.12.02 20:20:00 - OpenVPN > Intel® Ethernet Connection I217-V. 2016.12.02 20:20:00 - OpenVPN > Index = 3. 2016.12.02 20:20:00 - OpenVPN > GUID = {1795EC65-5262-4A75-876C-4AF7E8D0D4EB}. 2016.12.02 20:20:00 - OpenVPN > IP = 0.0.0.0/0.0.0.0. 2016.12.02 20:20:00 - OpenVPN > MAC = 74:d4:35:eb:63:3e. 2016.12.02 20:20:00 - OpenVPN > GATEWAY = 0.0.0.0/255.255.255.255. 2016.12.02 20:20:00 - OpenVPN > DHCP SERV =. 2016.12.02 20:20:00 - OpenVPN > DHCP LEASE OBTAINED = Fri Dec 02 20:20:00 2016. 2016.12.02 20:20:00 - OpenVPN > DHCP LEASE EXPIRES = Fri Dec 02 20:20:00 2016. 2016.12.02 20:20:00 - OpenVPN > DNS SERV =. 2016.12.02 20:20:00 - OpenVPN > TAP-Windows Adapter V9. 2016.12.02 20:20:00 - OpenVPN > Index = 18. 2016.12.02 20:20:00 - OpenVPN > GUID = {F40AE409-E4BC-4ABA-B9F7-3BD827158EE3}. 2016.12.02 20:20:00 - OpenVPN > IP = 10.4.92.206/255.255.0.0. 2016.12.02 20:20:00 - OpenVPN > MAC = 00:ff:f4:0a:e4:09. 2016.12.02 20:20:00 - OpenVPN > GATEWAY = 0.0.0.0/255.255.255.255. 2016.12.02 20:20:00 - OpenVPN > DHCP SERV = 10.4.255.254/255.255.255.255. 2016.12.02 20:20:00 - OpenVPN > DHCP LEASE OBTAINED = Fri Dec 02 17:21:12 2016. 2016.12.02 20:20:00 - OpenVPN > DHCP LEASE EXPIRES = Sat Dec 02 17:21:12 2017. 2016.12.02 20:20:00 - OpenVPN > DNS SERV = 10.4.0.1/255.255.255.255. 2016.12.02 20:20:00 - OpenVPN > 300Mbps Wireless USB Adapter. 2016.12.02 20:20:00 - OpenVPN > Index = 17. 2016.12.02 20:20:00 - OpenVPN > GUID = {D6DBB021-16B1-4402-97B4-1CEEE4201C7C}. 2016.12.02 20:20:00 - OpenVPN > IP = 192.168.1.101/255.255.255.0. 2016.12.02 20:20:00 - OpenVPN > MAC = 14:cc:20:17:0d:7f. 2016.12.02 20:20:00 - OpenVPN > GATEWAY = 192.168.1.1/255.255.255.255. 2016.12.02 20:20:00 - OpenVPN > DHCP SERV = 192.168.1.1/255.255.255.255. 2016.12.02 20:20:00 - OpenVPN > DHCP LEASE OBTAINED = Fri Dec 02 18:11:06 2016. 2016.12.02 20:20:00 - OpenVPN > DHCP LEASE EXPIRES = Sat Dec 03 18:11:06 2016. 2016.12.02 20:20:00 - OpenVPN > DNS SERV = 10.4.0.1/255.255.255.255. 2016.12.02 20:20:00 - OpenVPN > Microsoft Wi-Fi Direct Virtual Adapter. 2016.12.02 20:20:00 - OpenVPN > Index = 13. 2016.12.02 20:20:00 - OpenVPN > GUID = {AEB675DF-7F7D-4FED-BC91-F8C40081B696}. 2016.12.02 20:20:00 - OpenVPN > IP = 0.0.0.0/0.0.0.0. 2016.12.02 20:20:00 - OpenVPN > MAC = 14:cc:20:17:0d:7f. 2016.12.02 20:20:00 - OpenVPN > GATEWAY = 0.0.0.0/255.255.255.255. 2016.12.02 20:20:00 - OpenVPN > DHCP SERV =. 2016.12.02 20:20:00 - OpenVPN > DHCP LEASE OBTAINED = Fri Dec 02 20:20:00 2016. 2016.12.02 20:20:00 - OpenVPN > DHCP LEASE EXPIRES = Fri Dec 02 20:20:00 2016. 2016.12.02 20:20:00 - OpenVPN > DNS SERV =. 2016.12.02 20:20:00 - Starting Management Interface. 2016.12.02 20:20:00 - OpenVPN > Initialization Sequence Completed With Errors ( see http://openvpn.net/faq.html#dhcpclientserv )! 2016.12.02 20:20:00 - Disconnecting. 2016.12.02 20:20:00 - Management - Send 'signal SIGTERM'. 2016.12.02 20:20:00 - OpenVpn Management > >INFO:OpenVPN Management Interface Version 1 -- type 'help' for more info. 2016.12.02 20:20:00 - DNS leak protection with packet filtering enabled.I 2016.12.02 20:20:00 - Flushing DNSW 2016.12.02 20:20:00 - Checking route, 5° try failed (The remote name could not be resolved: 'nash_exit.airservers.org')W 2016.12.02 20:20:00 - The remote name could not be resolved: 'nash_exit.airservers.org'. 2016.12.02 20:20:00 - OpenVPN > MANAGEMENT: CMD 'signal SIGTERM'. 2016.12.02 20:20:00 - OpenVPN > SIGTERM received, sending exit notification to peer. 2016.12.02 20:20:00 - OpenVPN > C:\WINDOWS\system32\route.exe DELETE 213.152.162.113 MASK 255.255.255.255 192.168.1.1. 2016.12.02 20:20:00 - OpenVPN > Route deletion via IPAPI succeeded [adaptive]. 2016.12.02 20:20:00 - OpenVPN > C:\WINDOWS\system32\route.exe DELETE 0.0.0.0 MASK 128.0.0.0 10.4.0.1. 2016.12.02 20:20:00 - OpenVPN > Route deletion via IPAPI succeeded [adaptive]. 2016.12.02 20:20:00 - OpenVPN > C:\WINDOWS\system32\route.exe DELETE 128.0.0.0 MASK 128.0.0.0 10.4.0.1. 2016.12.02 20:20:00 - OpenVPN > Route deletion via IPAPI succeeded [adaptive]. 2016.12.02 20:20:00 - OpenVPN > Closing TUN/TAP interface. 2016.12.02 20:20:00 - OpenVPN > SIGTERM[soft,exit-with-notification] received, process exiting. 2016.12.02 20:20:05 - Connection terminated.. 2016.12.02 20:20:05 - DNS leak protection with packet filtering disabled.I 2016.12.02 20:20:08 - Checking authorization ...! 2016.12.02 20:20:08 - Connecting to Miram (Netherlands, Alblasserdam). 2016.12.02 20:20:08 - OpenVPN > OpenVPN 2.3.13 x86_64-w64-mingw32 [sSL (OpenSSL)] [LZO] [iPv6] built on Nov 10 2016. 2016.12.02 20:20:08 - OpenVPN > Windows version 6.2 (Windows 8 or greater) 64bit. 2016.12.02 20:20:08 - OpenVPN > library versions: OpenSSL 1.0.2j 26 Sep 2016, LZO 2.09. 2016.12.02 20:20:08 - OpenVPN > MANAGEMENT: TCP Socket listening on [AF_INET]127.0.0.1:3100. 2016.12.02 20:20:08 - OpenVPN > Control Channel Authentication: tls-auth using INLINE static key file. 2016.12.02 20:20:08 - OpenVPN > Outgoing Control Channel Authentication: Using 160 bit message hash 'SHA1' for HMAC authentication. 2016.12.02 20:20:08 - OpenVPN > Incoming Control Channel Authentication: Using 160 bit message hash 'SHA1' for HMAC authentication. 2016.12.02 20:20:08 - OpenVPN > Socket Buffers: R=[65536->262144] S=[65536->262144]. 2016.12.02 20:20:08 - OpenVPN > UDPv4 link local: [undef]. 2016.12.02 20:20:08 - OpenVPN > UDPv4 link remote: [AF_INET]213.152.162.88:443. 2016.12.02 20:20:08 - OpenVPN > TLS: Initial packet from [AF_INET]213.152.162.88:443, sid=12a14555 c9f545b5I 2016.12.02 20:20:09 - Checking route. 2016.12.02 20:20:09 - OpenVPN > VERIFY OK: depth=1, C=IT, ST=IT, L=Perugia, O=airvpn.org, CN=airvpn.org CA, emailAddress=info@airvpn.org. 2016.12.02 20:20:09 - OpenVPN > Validating certificate key usage. 2016.12.02 20:20:09 - OpenVPN > ++ Certificate has key usage 00a0, expects 00a0. 2016.12.02 20:20:09 - OpenVPN > VERIFY KU OK. 2016.12.02 20:20:09 - OpenVPN > Validating certificate extended key usage. 2016.12.02 20:20:09 - OpenVPN > ++ Certificate has EKU (str) TLS Web Server Authentication, expects TLS Web Server Authentication. 2016.12.02 20:20:09 - OpenVPN > VERIFY EKU OK. 2016.12.02 20:20:09 - OpenVPN > VERIFY OK: depth=0, C=IT, ST=IT, L=Perugia, O=airvpn.org, CN=server, emailAddress=info@airvpn.org. 2016.12.02 20:20:09 - OpenVPN > Data Channel Encrypt: Cipher 'AES-256-CBC' initialized with 256 bit key. 2016.12.02 20:20:09 - OpenVPN > Data Channel Encrypt: Using 160 bit message hash 'SHA1' for HMAC authentication. 2016.12.02 20:20:09 - OpenVPN > Data Channel Decrypt: Cipher 'AES-256-CBC' initialized with 256 bit key. 2016.12.02 20:20:09 - OpenVPN > Data Channel Decrypt: Using 160 bit message hash 'SHA1' for HMAC authentication. 2016.12.02 20:20:09 - OpenVPN > Control Channel: TLSv1.2, cipher TLSv1/SSLv3 DHE-RSA-AES256-GCM-SHA384, 4096 bit RSA. 2016.12.02 20:20:09 - OpenVPN > [server] Peer Connection Initiated with [AF_INET]213.152.162.88:443. 2016.12.02 20:20:11 - OpenVPN > SENT CONTROL [server]: 'PUSH_REQUEST' (status=1). 2016.12.02 20:20:11 - OpenVPN > PUSH: Received control message: 'PUSH_REPLY,redirect-gateway def1 bypass-dhcp,dhcp-option DNS 10.4.0.1,comp-lzo no,route-gateway 10.4.0.1,topology subnet,ping 10,ping-restart 60,ifconfig 10.4.92.19 255.255.0.0'. 2016.12.02 20:20:11 - OpenVPN > OPTIONS IMPORT: timers and/or timeouts modified. 2016.12.02 20:20:11 - OpenVPN > OPTIONS IMPORT: LZO parms modified. 2016.12.02 20:20:11 - OpenVPN > OPTIONS IMPORT: --ifconfig/up options modified. 2016.12.02 20:20:11 - OpenVPN > OPTIONS IMPORT: route options modified. 2016.12.02 20:20:11 - OpenVPN > OPTIONS IMPORT: route-related options modified. 2016.12.02 20:20:11 - OpenVPN > OPTIONS IMPORT: --ip-win32 and/or --dhcp-option options modified. 2016.12.02 20:20:11 - OpenVPN > ROUTE_GATEWAY 192.168.1.1/255.255.255.0 I=17 HWADDR=14:cc:20:17:0d:7f. 2016.12.02 20:20:11 - OpenVPN > do_ifconfig, tt->ipv6=0, tt->did_ifconfig_ipv6_setup=0. 2016.12.02 20:20:11 - OpenVPN > open_tun, tt->ipv6=0. 2016.12.02 20:20:11 - OpenVPN > TAP-WIN32 device [Local Area Connection 2] opened: \\.\Global\{F40AE409-E4BC-4ABA-B9F7-3BD827158EE3}.tap. 2016.12.02 20:20:11 - OpenVPN > TAP-Windows Driver Version 9.21. 2016.12.02 20:20:11 - OpenVPN > Set TAP-Windows TUN subnet mode network/local/netmask = 10.4.0.0/10.4.92.19/255.255.0.0 [sUCCEEDED]. 2016.12.02 20:20:11 - OpenVPN > Notified TAP-Windows driver to set a DHCP IP/netmask of 10.4.92.19/255.255.0.0 on interface {F40AE409-E4BC-4ABA-B9F7-3BD827158EE3} [DHCP-serv: 10.4.255.254, lease-time: 31536000]. 2016.12.02 20:20:11 - OpenVPN > Successful ARP Flush on interface [18] {F40AE409-E4BC-4ABA-B9F7-3BD827158EE3}. 2016.12.02 20:20:17 - OpenVPN > TEST ROUTES: 0/0 succeeded len=0 ret=0 a=0 u/d=down. 2016.12.02 20:20:17 - OpenVPN > Route: Waiting for TUN/TAP interface to come up.... 2016.12.02 20:20:17 - Eddie Windows Interface Hack executed (Local Area Connection 2)W 2016.12.02 20:20:21 - Checking route, 1° try failed (The operation has timed out). 2016.12.02 20:20:21 - OpenVPN > TEST ROUTES: 0/0 succeeded len=0 ret=0 a=0 u/d=down. 2016.12.02 20:20:21 - OpenVPN > Route: Waiting for TUN/TAP interface to come up.... 2016.12.02 20:20:21 - Eddie Windows Interface Hack executed (Local Area Connection 2). 2016.12.02 20:20:22 - OpenVPN > TEST ROUTES: 0/0 succeeded len=0 ret=0 a=0 u/d=down. 2016.12.02 20:20:22 - OpenVPN > Route: Waiting for TUN/TAP interface to come up.... 2016.12.02 20:20:22 - Eddie Windows Interface Hack executed (Local Area Connection 2). 2016.12.02 20:20:23 - OpenVPN > TEST ROUTES: 0/0 succeeded len=0 ret=0 a=0 u/d=down. 2016.12.02 20:20:23 - OpenVPN > Route: Waiting for TUN/TAP interface to come up.... 2016.12.02 20:20:23 - Eddie Windows Interface Hack executed (Local Area Connection 2). 2016.12.02 20:20:24 - OpenVPN > TEST ROUTES: 0/0 succeeded len=0 ret=0 a=0 u/d=down. 2016.12.02 20:20:24 - OpenVPN > Route: Waiting for TUN/TAP interface to come up.... 2016.12.02 20:20:24 - Eddie Windows Interface Hack executed (Local Area Connection 2). 2016.12.02 20:20:25 - OpenVPN > TEST ROUTES: 0/0 succeeded len=0 ret=0 a=0 u/d=down. 2016.12.02 20:20:25 - OpenVPN > Route: Waiting for TUN/TAP interface to come up.... 2016.12.02 20:20:25 - Eddie Windows Interface Hack executed (Local Area Connection 2). 2016.12.02 20:20:26 - OpenVPN > TEST ROUTES: 0/0 succeeded len=0 ret=0 a=0 u/d=down. 2016.12.02 20:20:26 - OpenVPN > Route: Waiting for TUN/TAP interface to come up.... 2016.12.02 20:20:26 - Eddie Windows Interface Hack executed (Local Area Connection 2). 2016.12.02 20:20:27 - OpenVPN > TEST ROUTES: 0/0 succeeded len=0 ret=0 a=0 u/d=down. 2016.12.02 20:20:27 - OpenVPN > Route: Waiting for TUN/TAP interface to come up.... 2016.12.02 20:20:28 - Eddie Windows Interface Hack executed (Local Area Connection 2). 2016.12.02 20:20:29 - OpenVPN > TEST ROUTES: 0/0 succeeded len=0 ret=0 a=0 u/d=down. 2016.12.02 20:20:29 - OpenVPN > Route: Waiting for TUN/TAP interface to come up.... 2016.12.02 20:20:29 - Eddie Windows Interface Hack executed (Local Area Connection 2). 2016.12.02 20:20:30 - OpenVPN > TEST ROUTES: 0/0 succeeded len=0 ret=0 a=0 u/d=down. 2016.12.02 20:20:30 - OpenVPN > Route: Waiting for TUN/TAP interface to come up.... 2016.12.02 20:20:30 - Eddie Windows Interface Hack executed (Local Area Connection 2). 2016.12.02 20:20:31 - OpenVPN > TEST ROUTES: 0/0 succeeded len=0 ret=0 a=0 u/d=down. 2016.12.02 20:20:31 - OpenVPN > Route: Waiting for TUN/TAP interface to come up.... 2016.12.02 20:20:31 - Eddie Windows Interface Hack executed (Local Area Connection 2). 2016.12.02 20:20:32 - OpenVPN > TEST ROUTES: 0/0 succeeded len=0 ret=0 a=0 u/d=down. 2016.12.02 20:20:32 - OpenVPN > Route: Waiting for TUN/TAP interface to come up.... 2016.12.02 20:20:32 - Eddie Windows Interface Hack executed (Local Area Connection 2)W 2016.12.02 20:20:33 - Checking route, 2° try failed (The operation has timed out). 2016.12.02 20:20:33 - OpenVPN > TEST ROUTES: 0/0 succeeded len=0 ret=0 a=0 u/d=down. 2016.12.02 20:20:33 - OpenVPN > Route: Waiting for TUN/TAP interface to come up.... 2016.12.02 20:20:33 - Eddie Windows Interface Hack executed (Local Area Connection 2). 2016.12.02 20:20:34 - OpenVPN > TEST ROUTES: 0/0 succeeded len=0 ret=0 a=0 u/d=down. 2016.12.02 20:20:34 - OpenVPN > Route: Waiting for TUN/TAP interface to come up.... 2016.12.02 20:20:34 - Eddie Windows Interface Hack executed (Local Area Connection 2). 2016.12.02 20:20:35 - OpenVPN > TEST ROUTES: 0/0 succeeded len=0 ret=0 a=0 u/d=down. 2016.12.02 20:20:35 - OpenVPN > Route: Waiting for TUN/TAP interface to come up.... 2016.12.02 20:20:35 - Eddie Windows Interface Hack executed (Local Area Connection 2). 2016.12.02 20:20:36 - OpenVPN > TEST ROUTES: 0/0 succeeded len=0 ret=0 a=0 u/d=down. 2016.12.02 20:20:36 - OpenVPN > Route: Waiting for TUN/TAP interface to come up.... 2016.12.02 20:20:36 - Eddie Windows Interface Hack executed (Local Area Connection 2). 2016.12.02 20:20:37 - OpenVPN > TEST ROUTES: 0/0 succeeded len=0 ret=0 a=0 u/d=down. 2016.12.02 20:20:37 - OpenVPN > Route: Waiting for TUN/TAP interface to come up.... 2016.12.02 20:20:37 - Eddie Windows Interface Hack executed (Local Area Connection 2). 2016.12.02 20:20:39 - OpenVPN > TEST ROUTES: 0/0 succeeded len=0 ret=0 a=0 u/d=down. 2016.12.02 20:20:39 - OpenVPN > Route: Waiting for TUN/TAP interface to come up.... 2016.12.02 20:20:39 - Eddie Windows Interface Hack executed (Local Area Connection 2). 2016.12.02 20:20:40 - OpenVPN > TEST ROUTES: 0/0 succeeded len=0 ret=0 a=0 u/d=down. 2016.12.02 20:20:40 - OpenVPN > Route: Waiting for TUN/TAP interface to come up.... 2016.12.02 20:20:40 - Eddie Windows Interface Hack executed (Local Area Connection 2). 2016.12.02 20:20:41 - OpenVPN > TEST ROUTES: 0/0 succeeded len=0 ret=0 a=0 u/d=down. 2016.12.02 20:20:41 - OpenVPN > Route: Waiting for TUN/TAP interface to come up.... 2016.12.02 20:20:41 - Eddie Windows Interface Hack executed (Local Area Connection 2). 2016.12.02 20:20:42 - OpenVPN > TEST ROUTES: 0/0 succeeded len=0 ret=0 a=0 u/d=down. 2016.12.02 20:20:42 - OpenVPN > Route: Waiting for TUN/TAP interface to come up.... 2016.12.02 20:20:42 - Eddie Windows Interface Hack executed (Local Area Connection 2). 2016.12.02 20:20:43 - OpenVPN > TEST ROUTES: 0/0 succeeded len=0 ret=0 a=0 u/d=down. 2016.12.02 20:20:43 - OpenVPN > Route: Waiting for TUN/TAP interface to come up.... 2016.12.02 20:20:43 - Eddie Windows Interface Hack executed (Local Area Connection 2). 2016.12.02 20:20:44 - OpenVPN > TEST ROUTES: 0/0 succeeded len=0 ret=0 a=0 u/d=down. 2016.12.02 20:20:44 - OpenVPN > Route: Waiting for TUN/TAP interface to come up.... 2016.12.02 20:20:44 - Eddie Windows Interface Hack executed (Local Area Connection 2)W 2016.12.02 20:20:45 - Checking route, 3° try failed (The operation has timed out). 2016.12.02 20:20:45 - OpenVPN > TEST ROUTES: 0/0 succeeded len=0 ret=0 a=0 u/d=down. 2016.12.02 20:20:45 - OpenVPN > Route: Waiting for TUN/TAP interface to come up.... 2016.12.02 20:20:45 - Eddie Windows Interface Hack executed (Local Area Connection 2). 2016.12.02 20:20:46 - OpenVPN > TEST ROUTES: 0/0 succeeded len=0 ret=0 a=0 u/d=down. 2016.12.02 20:20:46 - OpenVPN > C:\WINDOWS\system32\route.exe ADD 213.152.162.88 MASK 255.255.255.255 192.168.1.1. 2016.12.02 20:20:46 - OpenVPN > ROUTE: CreateIpForwardEntry succeeded with dwForwardMetric1=45 and dwForwardType=4. 2016.12.02 20:20:46 - OpenVPN > Route addition via IPAPI succeeded [adaptive]. 2016.12.02 20:20:46 - OpenVPN > C:\WINDOWS\system32\route.exe ADD 0.0.0.0 MASK 128.0.0.0 10.4.0.1. 2016.12.02 20:20:46 - OpenVPN > ROUTE: CreateIpForwardEntry succeeded with dwForwardMetric1=35 and dwForwardType=4. 2016.12.02 20:20:46 - OpenVPN > Route addition via IPAPI succeeded [adaptive]. 2016.12.02 20:20:46 - OpenVPN > C:\WINDOWS\system32\route.exe ADD 128.0.0.0 MASK 128.0.0.0 10.4.0.1. 2016.12.02 20:20:46 - OpenVPN > ROUTE: CreateIpForwardEntry succeeded with dwForwardMetric1=35 and dwForwardType=4. 2016.12.02 20:20:46 - OpenVPN > Route addition via IPAPI succeeded [adaptive]. 2016.12.02 20:20:46 - OpenVPN > SYSTEM ROUTING TABLE. 2016.12.02 20:20:46 - OpenVPN > 0.0.0.0 0.0.0.0 192.168.1.1 p=0 i=17 t=4 pr=3 a=10815 h=0 m=45/0/0/0/0. 2016.12.02 20:20:46 - OpenVPN > 0.0.0.0 128.0.0.0 10.4.0.1 p=0 i=18 t=4 pr=3 a=0 h=0 m=35/0/0/0/0. 2016.12.02 20:20:46 - OpenVPN > 10.4.0.0 255.255.0.0 10.4.92.206 p=0 i=18 t=3 pr=2 a=10774 h=0 m=291/0/0/0/0. 2016.12.02 20:20:46 - OpenVPN > 10.4.92.206 255.255.255.255 10.4.92.206 p=0 i=18 t=3 pr=2 a=10774 h=0 m=291/0/0/0/0. 2016.12.02 20:20:46 - OpenVPN > 10.4.255.255 255.255.255.255 10.4.92.206 p=0 i=18 t=3 pr=2 a=10774 h=0 m=291/0/0/0/0. 2016.12.02 20:20:46 - OpenVPN > 127.0.0.0 255.0.0.0 127.0.0.1 p=0 i=1 t=3 pr=2 a=10824 h=0 m=331/0/0/0/0. 2016.12.02 20:20:46 - OpenVPN > 127.0.0.1 255.255.255.255 127.0.0.1 p=0 i=1 t=3 pr=2 a=10824 h=0 m=331/0/0/0/0. 2016.12.02 20:20:46 - OpenVPN > 127.255.255.255 255.255.255.255 127.0.0.1 p=0 i=1 t=3 pr=2 a=10824 h=0 m=331/0/0/0/0. 2016.12.02 20:20:46 - OpenVPN > 128.0.0.0 128.0.0.0 10.4.0.1 p=0 i=18 t=4 pr=3 a=0 h=0 m=35/0/0/0/0. 2016.12.02 20:20:46 - OpenVPN > 192.168.1.0 255.255.255.0 192.168.1.101 p=0 i=17 t=3 pr=2 a=10815 h=0 m=301/0/0/0/0. 2016.12.02 20:20:46 - OpenVPN > 192.168.1.101 255.255.255.255 192.168.1.101 p=0 i=17 t=3 pr=2 a=10815 h=0 m=301/0/0/0/0. 2016.12.02 20:20:46 - OpenVPN > 192.168.1.255 255.255.255.255 192.168.1.101 p=0 i=17 t=3 pr=2 a=10815 h=0 m=301/0/0/0/0. 2016.12.02 20:20:46 - OpenVPN > 213.152.162.88 255.255.255.255 192.168.1.1 p=0 i=17 t=4 pr=3 a=0 h=0 m=45/0/0/0/0. 2016.12.02 20:20:46 - OpenVPN > 224.0.0.0 240.0.0.0 127.0.0.1 p=0 i=1 t=3 pr=2 a=10824 h=0 m=331/0/0/0/0. 2016.12.02 20:20:46 - OpenVPN > 224.0.0.0 240.0.0.0 10.4.92.206 p=0 i=18 t=3 pr=2 a=10823 h=0 m=291/0/0/0/0. 2016.12.02 20:20:46 - OpenVPN > 224.0.0.0 240.0.0.0 192.168.1.101 p=0 i=17 t=3 pr=2 a=10817 h=0 m=301/0/0/0/0. 2016.12.02 20:20:46 - OpenVPN > 255.255.255.255 255.255.255.255 127.0.0.1 p=0 i=1 t=3 pr=2 a=10824 h=0 m=331/0/0/0/0. 2016.12.02 20:20:46 - OpenVPN > 255.255.255.255 255.255.255.255 10.4.92.206 p=0 i=18 t=3 pr=2 a=10823 h=0 m=291/0/0/0/0. 2016.12.02 20:20:46 - OpenVPN > 255.255.255.255 255.255.255.255 192.168.1.101 p=0 i=17 t=3 pr=2 a=10817 h=0 m=301/0/0/0/0. 2016.12.02 20:20:46 - OpenVPN > SYSTEM ADAPTER LIST. 2016.12.02 20:20:46 - OpenVPN > Intel® Ethernet Connection I217-V. 2016.12.02 20:20:46 - OpenVPN > Index = 3. 2016.12.02 20:20:46 - OpenVPN > GUID = {1795EC65-5262-4A75-876C-4AF7E8D0D4EB}. 2016.12.02 20:20:46 - OpenVPN > IP = 0.0.0.0/0.0.0.0. 2016.12.02 20:20:46 - OpenVPN > MAC = 74:d4:35:eb:63:3e. 2016.12.02 20:20:46 - OpenVPN > GATEWAY = 0.0.0.0/255.255.255.255. 2016.12.02 20:20:46 - OpenVPN > DHCP SERV =. 2016.12.02 20:20:46 - OpenVPN > DHCP LEASE OBTAINED = Fri Dec 02 20:20:46 2016. 2016.12.02 20:20:46 - OpenVPN > DHCP LEASE EXPIRES = Fri Dec 02 20:20:46 2016. 2016.12.02 20:20:46 - OpenVPN > DNS SERV =. 2016.12.02 20:20:46 - OpenVPN > TAP-Windows Adapter V9. 2016.12.02 20:20:46 - OpenVPN > Index = 18. 2016.12.02 20:20:46 - OpenVPN > GUID = {F40AE409-E4BC-4ABA-B9F7-3BD827158EE3}. 2016.12.02 20:20:46 - OpenVPN > IP = 10.4.92.206/255.255.0.0. 2016.12.02 20:20:46 - OpenVPN > MAC = 00:ff:f4:0a:e4:09. 2016.12.02 20:20:46 - OpenVPN > GATEWAY = 0.0.0.0/255.255.255.255. 2016.12.02 20:20:46 - OpenVPN > DHCP SERV = 10.4.255.254/255.255.255.255. 2016.12.02 20:20:46 - OpenVPN > DHCP LEASE OBTAINED = Fri Dec 02 17:21:12 2016. 2016.12.02 20:20:46 - OpenVPN > DHCP LEASE EXPIRES = Sat Dec 02 17:21:12 2017. 2016.12.02 20:20:46 - OpenVPN > DNS SERV = 10.4.0.1/255.255.255.255. 2016.12.02 20:20:46 - OpenVPN > 300Mbps Wireless USB Adapter. 2016.12.02 20:20:46 - OpenVPN > Index = 17. 2016.12.02 20:20:46 - OpenVPN > GUID = {D6DBB021-16B1-4402-97B4-1CEEE4201C7C}. 2016.12.02 20:20:46 - OpenVPN > IP = 192.168.1.101/255.255.255.0. 2016.12.02 20:20:46 - OpenVPN > MAC = 14:cc:20:17:0d:7f. 2016.12.02 20:20:46 - OpenVPN > GATEWAY = 192.168.1.1/255.255.255.255. 2016.12.02 20:20:46 - OpenVPN > DHCP SERV = 192.168.1.1/255.255.255.255. 2016.12.02 20:20:46 - OpenVPN > DHCP LEASE OBTAINED = Fri Dec 02 18:11:06 2016. 2016.12.02 20:20:46 - OpenVPN > DHCP LEASE EXPIRES = Sat Dec 03 18:11:06 2016. 2016.12.02 20:20:46 - OpenVPN > DNS SERV = 10.4.0.1/255.255.255.255. 2016.12.02 20:20:46 - OpenVPN > Microsoft Wi-Fi Direct Virtual Adapter. 2016.12.02 20:20:46 - OpenVPN > Index = 13. 2016.12.02 20:20:46 - OpenVPN > GUID = {AEB675DF-7F7D-4FED-BC91-F8C40081B696}. 2016.12.02 20:20:46 - OpenVPN > IP = 0.0.0.0/0.0.0.0. 2016.12.02 20:20:46 - OpenVPN > MAC = 14:cc:20:17:0d:7f. 2016.12.02 20:20:46 - OpenVPN > GATEWAY = 0.0.0.0/255.255.255.255. 2016.12.02 20:20:46 - OpenVPN > DHCP SERV =. 2016.12.02 20:20:46 - OpenVPN > DHCP LEASE OBTAINED = Fri Dec 02 20:20:46 2016. 2016.12.02 20:20:46 - OpenVPN > DHCP LEASE EXPIRES = Fri Dec 02 20:20:46 2016. 2016.12.02 20:20:46 - OpenVPN > DNS SERV =. 2016.12.02 20:20:46 - Starting Management Interface. 2016.12.02 20:20:46 - OpenVPN > Initialization Sequence Completed With Errors ( see http://openvpn.net/faq.html#dhcpclientserv ). 2016.12.02 20:20:46 - DNS leak protection with packet filtering enabled.I 2016.12.02 20:20:46 - Flushing DNS! 2016.12.02 20:20:46 - Disconnecting. 2016.12.02 20:20:46 - Management - Send 'signal SIGTERM'. 2016.12.02 20:20:46 - OpenVpn Management > >INFO:OpenVPN Management Interface Version 1 -- type 'help' for more infoW 2016.12.02 20:20:47 - Checking route, 4° try failed (The remote name could not be resolved: 'miram_exit.airservers.org'). 2016.12.02 20:20:51 - Connection terminated.. 2016.12.02 20:20:51 - DNS leak protection with packet filtering disabled.. 2016.12.02 20:20:52 - OpenVPN > MANAGEMENT: Client connected from [AF_INET]127.0.0.1:3100. 2016.12.02 20:20:52 - OpenVPN > MANAGEMENT: CMD 'signal SIGTERM'. 2016.12.02 20:20:52 - OpenVPN > SIGTERM received, sending exit notification to peer. 2016.12.02 20:20:52 - OpenVPN > C:\WINDOWS\system32\route.exe DELETE 213.152.162.88 MASK 255.255.255.255 192.168.1.1. 2016.12.02 20:20:52 - OpenVPN > Route deletion via IPAPI succeeded [adaptive]. 2016.12.02 20:20:52 - OpenVPN > C:\WINDOWS\system32\route.exe DELETE 0.0.0.0 MASK 128.0.0.0 10.4.0.1. 2016.12.02 20:20:52 - OpenVPN > Route deletion via IPAPI succeeded [adaptive]. 2016.12.02 20:20:52 - OpenVPN > C:\WINDOWS\system32\route.exe DELETE 128.0.0.0 MASK 128.0.0.0 10.4.0.1. 2016.12.02 20:20:52 - OpenVPN > Route deletion via IPAPI succeeded [adaptive]. 2016.12.02 20:20:52 - OpenVPN > Closing TUN/TAP interface. 2016.12.02 20:20:52 - OpenVPN > SIGTERM[soft,exit-with-notification] received, process exitingI 2016.12.02 20:20:54 - Checking authorization ...! 2016.12.02 20:20:55 - Connecting to Garnet (Netherlands, Alblasserdam). 2016.12.02 20:20:55 - OpenVPN > OpenVPN 2.3.13 x86_64-w64-mingw32 [sSL (OpenSSL)] [LZO] [iPv6] built on Nov 10 2016. 2016.12.02 20:20:55 - OpenVPN > Windows version 6.2 (Windows 8 or greater) 64bit. 2016.12.02 20:20:55 - OpenVPN > library versions: OpenSSL 1.0.2j 26 Sep 2016, LZO 2.09. 2016.12.02 20:20:55 - OpenVPN > MANAGEMENT: TCP Socket listening on [AF_INET]127.0.0.1:3100. 2016.12.02 20:20:55 - OpenVPN > Control Channel Authentication: tls-auth using INLINE static key file. 2016.12.02 20:20:55 - OpenVPN > Outgoing Control Channel Authentication: Using 160 bit message hash 'SHA1' for HMAC authentication. 2016.12.02 20:20:55 - OpenVPN > Incoming Control Channel Authentication: Using 160 bit message hash 'SHA1' for HMAC authentication. 2016.12.02 20:20:55 - OpenVPN > Socket Buffers: R=[65536->262144] S=[65536->262144]. 2016.12.02 20:20:55 - OpenVPN > UDPv4 link local: [undef]. 2016.12.02 20:20:55 - OpenVPN > UDPv4 link remote: [AF_INET]213.152.162.73:443. 2016.12.02 20:20:55 - OpenVPN > TLS: Initial packet from [AF_INET]213.152.162.73:443, sid=e96e02f8 c6b8c740. 2016.12.02 20:20:55 - OpenVPN > VERIFY OK: depth=1, C=IT, ST=IT, L=Perugia, O=airvpn.org, CN=airvpn.org CA, emailAddress=info@airvpn.org. 2016.12.02 20:20:55 - OpenVPN > Validating certificate key usage. 2016.12.02 20:20:55 - OpenVPN > ++ Certificate has key usage 00a0, expects 00a0. 2016.12.02 20:20:55 - OpenVPN > VERIFY KU OK. 2016.12.02 20:20:55 - OpenVPN > Validating certificate extended key usage. 2016.12.02 20:20:55 - OpenVPN > ++ Certificate has EKU (str) TLS Web Server Authentication, expects TLS Web Server Authentication. 2016.12.02 20:20:55 - OpenVPN > VERIFY EKU OK. 2016.12.02 20:20:55 - OpenVPN > VERIFY OK: depth=0, C=IT, ST=IT, L=Perugia, O=airvpn.org, CN=server, emailAddress=info@airvpn.org. 2016.12.02 20:20:59 - OpenVPN > Data Channel Encrypt: Cipher 'AES-256-CBC' initialized with 256 bit key. 2016.12.02 20:20:59 - OpenVPN > Data Channel Encrypt: Using 160 bit message hash 'SHA1' for HMAC authentication. 2016.12.02 20:20:59 - OpenVPN > Data Channel Decrypt: Cipher 'AES-256-CBC' initialized with 256 bit key. 2016.12.02 20:20:59 - OpenVPN > Data Channel Decrypt: Using 160 bit message hash 'SHA1' for HMAC authentication. 2016.12.02 20:20:59 - OpenVPN > Control Channel: TLSv1.2, cipher TLSv1/SSLv3 DHE-RSA-AES256-GCM-SHA384, 4096 bit RSA. 2016.12.02 20:20:59 - OpenVPN > [server] Peer Connection Initiated with [AF_INET]213.152.162.73:443W 2016.12.02 20:21:00 - Checking route, 5° try failed (The operation has timed out)W 2016.12.02 20:21:00 - The operation has timed out. 2016.12.02 20:21:00 - OpenVPN > MANAGEMENT: CMD 'signal SIGTERM'. 2016.12.02 20:21:00 - OpenVPN > SIGTERM received, sending exit notification to peer. 2016.12.02 20:21:00 - OpenVPN > C:\WINDOWS\system32\route.exe DELETE 213.152.162.180 MASK 255.255.255.255 192.168.1.1. 2016.12.02 20:21:00 - OpenVPN > Route deletion via IPAPI succeeded [adaptive]. 2016.12.02 20:21:00 - OpenVPN > C:\WINDOWS\system32\route.exe DELETE 0.0.0.0 MASK 128.0.0.0 10.4.0.1. 2016.12.02 20:21:00 - OpenVPN > Route deletion via IPAPI succeeded [adaptive]. 2016.12.02 20:21:00 - OpenVPN > C:\WINDOWS\system32\route.exe DELETE 128.0.0.0 MASK 128.0.0.0 10.4.0.1. 2016.12.02 20:21:00 - OpenVPN > Route deletion via IPAPI succeeded [adaptive]. 2016.12.02 20:21:00 - OpenVPN > Closing TUN/TAP interface. 2016.12.02 20:21:00 - OpenVPN > SIGTERM[soft,exit-with-notification] received, process exiting! 2016.12.02 20:21:00 - Disconnecting. 2016.12.02 20:21:00 - Connection terminated.I 2016.12.02 20:21:03 - Checking authorization ...! 2016.12.02 20:21:04 - Connecting to Merga (Netherlands, Alblasserdam). 2016.12.02 20:21:04 - OpenVPN > OpenVPN 2.3.13 x86_64-w64-mingw32 [sSL (OpenSSL)] [LZO] [iPv6] built on Nov 10 2016. 2016.12.02 20:21:04 - OpenVPN > Windows version 6.2 (Windows 8 or greater) 64bit. 2016.12.02 20:21:04 - OpenVPN > library versions: OpenSSL 1.0.2j 26 Sep 2016, LZO 2.09. 2016.12.02 20:21:04 - OpenVPN > MANAGEMENT: TCP Socket listening on [AF_INET]127.0.0.1:3100. 2016.12.02 20:21:04 - OpenVPN > Control Channel Authentication: tls-auth using INLINE static key file. 2016.12.02 20:21:04 - OpenVPN > Outgoing Control Channel Authentication: Using 160 bit message hash 'SHA1' for HMAC authentication. 2016.12.02 20:21:04 - OpenVPN > Incoming Control Channel Authentication: Using 160 bit message hash 'SHA1' for HMAC authentication. 2016.12.02 20:21:04 - OpenVPN > Socket Buffers: R=[65536->262144] S=[65536->262144]. 2016.12.02 20:21:04 - OpenVPN > UDPv4 link local: [undef]. 2016.12.02 20:21:04 - OpenVPN > UDPv4 link remote: [AF_INET]213.152.161.29:443. 2016.12.02 20:21:04 - OpenVPN > TLS: Initial packet from [AF_INET]213.152.161.29:443, sid=df19f22e a9af71d6. 2016.12.02 20:21:04 - OpenVPN > VERIFY OK: depth=1, C=IT, ST=IT, L=Perugia, O=airvpn.org, CN=airvpn.org CA, emailAddress=info@airvpn.org. 2016.12.02 20:21:04 - OpenVPN > Validating certificate key usage. 2016.12.02 20:21:04 - OpenVPN > ++ Certificate has key usage 00a0, expects 00a0. 2016.12.02 20:21:04 - OpenVPN > VERIFY KU OK. 2016.12.02 20:21:04 - OpenVPN > Validating certificate extended key usage. 2016.12.02 20:21:04 - OpenVPN > ++ Certificate has EKU (str) TLS Web Server Authentication, expects TLS Web Server Authentication. 2016.12.02 20:21:04 - OpenVPN > VERIFY EKU OK. 2016.12.02 20:21:04 - OpenVPN > VERIFY OK: depth=0, C=IT, ST=IT, L=Perugia, O=airvpn.org, CN=server, emailAddress=info@airvpn.org. 2016.12.02 20:21:04 - OpenVPN > Data Channel Encrypt: Cipher 'AES-256-CBC' initialized with 256 bit key. 2016.12.02 20:21:04 - OpenVPN > Data Channel Encrypt: Using 160 bit message hash 'SHA1' for HMAC authentication. 2016.12.02 20:21:04 - OpenVPN > Data Channel Decrypt: Cipher 'AES-256-CBC' initialized with 256 bit key. 2016.12.02 20:21:04 - OpenVPN > Data Channel Decrypt: Using 160 bit message hash 'SHA1' for HMAC authentication. 2016.12.02 20:21:04 - OpenVPN > Control Channel: TLSv1.2, cipher TLSv1/SSLv3 DHE-RSA-AES256-GCM-SHA384, 4096 bit RSA. 2016.12.02 20:21:04 - OpenVPN > [server] Peer Connection Initiated with [AF_INET]213.152.161.29:443. 2016.12.02 20:21:06 - OpenVPN > SENT CONTROL [server]: 'PUSH_REQUEST' (status=1). 2016.12.02 20:21:06 - OpenVPN > PUSH: Received control message: 'PUSH_REPLY,redirect-gateway def1 bypass-dhcp,dhcp-option DNS 10.4.0.1,comp-lzo no,route-gateway 10.4.0.1,topology subnet,ping 10,ping-restart 60,ifconfig 10.4.92.206 255.255.0.0'. 2016.12.02 20:21:06 - OpenVPN > OPTIONS IMPORT: timers and/or timeouts modified. 2016.12.02 20:21:06 - OpenVPN > OPTIONS IMPORT: LZO parms modified. 2016.12.02 20:21:06 - OpenVPN > OPTIONS IMPORT: --ifconfig/up options modified. 2016.12.02 20:21:06 - OpenVPN > OPTIONS IMPORT: route options modified. 2016.12.02 20:21:06 - OpenVPN > OPTIONS IMPORT: route-related options modified. 2016.12.02 20:21:06 - OpenVPN > OPTIONS IMPORT: --ip-win32 and/or --dhcp-option options modified. 2016.12.02 20:21:06 - OpenVPN > ROUTE_GATEWAY 192.168.1.1/255.255.255.0 I=17 HWADDR=14:cc:20:17:0d:7f. 2016.12.02 20:21:06 - OpenVPN > do_ifconfig, tt->ipv6=0, tt->did_ifconfig_ipv6_setup=0. 2016.12.02 20:21:06 - OpenVPN > open_tun, tt->ipv6=0. 2016.12.02 20:21:06 - OpenVPN > TAP-WIN32 device [Local Area Connection 2] opened: \\.\Global\{F40AE409-E4BC-4ABA-B9F7-3BD827158EE3}.tap. 2016.12.02 20:21:06 - OpenVPN > TAP-Windows Driver Version 9.21. 2016.12.02 20:21:06 - OpenVPN > Set TAP-Windows TUN subnet mode network/local/netmask = 10.4.0.0/10.4.92.206/255.255.0.0 [sUCCEEDED]. 2016.12.02 20:21:06 - OpenVPN > Notified TAP-Windows driver to set a DHCP IP/netmask of 10.4.92.206/255.255.0.0 on interface {F40AE409-E4BC-4ABA-B9F7-3BD827158EE3} [DHCP-serv: 10.4.255.254, lease-time: 31536000]. 2016.12.02 20:21:06 - OpenVPN > Successful ARP Flush on interface [18] {F40AE409-E4BC-4ABA-B9F7-3BD827158EE3}. 2016.12.02 20:21:12 - OpenVPN > TEST ROUTES: 1/1 succeeded len=0 ret=1 a=0 u/d=up. 2016.12.02 20:21:12 - OpenVPN > C:\WINDOWS\system32\route.exe ADD 213.152.161.29 MASK 255.255.255.255 192.168.1.1. 2016.12.02 20:21:12 - OpenVPN > ROUTE: CreateIpForwardEntry succeeded with dwForwardMetric1=40 and dwForwardType=4. 2016.12.02 20:21:12 - OpenVPN > Route addition via IPAPI succeeded [adaptive]. 2016.12.02 20:21:12 - OpenVPN > C:\WINDOWS\system32\route.exe ADD 0.0.0.0 MASK 128.0.0.0 10.4.0.1. 2016.12.02 20:21:12 - OpenVPN > ROUTE: CreateIpForwardEntry succeeded with dwForwardMetric1=35 and dwForwardType=4. 2016.12.02 20:21:12 - OpenVPN > Route addition via IPAPI succeeded [adaptive]. 2016.12.02 20:21:12 - OpenVPN > C:\WINDOWS\system32\route.exe ADD 128.0.0.0 MASK 128.0.0.0 10.4.0.1. 2016.12.02 20:21:12 - OpenVPN > ROUTE: CreateIpForwardEntry succeeded with dwForwardMetric1=35 and dwForwardType=4. 2016.12.02 20:21:12 - OpenVPN > Route addition via IPAPI succeeded [adaptive]. 2016.12.02 20:21:12 - Starting Management Interface. 2016.12.02 20:21:12 - OpenVPN > Initialization Sequence Completed. 2016.12.02 20:21:12 - DNS leak protection with packet filtering enabled.I 2016.12.02 20:21:12 - Flushing DNS. 2016.12.02 20:21:13 - Updating systems & servers data .... 2016.12.02 20:21:13 - Systems & servers data update completedI 2016.12.02 20:21:17 - Checking routeI 2016.12.02 20:21:18 - Checking DNS! 2016.12.02 20:21:30 - Connected.. 2016.12.02 20:21:30 - OpenVPN > MANAGEMENT: Client connected from [AF_INET]127.0.0.1:3100. 2016.12.02 20:21:30 - OpenVpn Management > >INFO:OpenVPN Management Interface Version 1 -- type 'help' for more info. 2016.12.02 20:31:15 - Updating systems & servers data .... 2016.12.02 20:31:15 - Systems & servers data update completed. 2016.12.02 20:41:16 - Updating systems & servers data .... 2016.12.02 20:41:17 - Systems & servers data update completed. 2016.12.02 20:51:18 - Updating systems & servers data .... 2016.12.02 20:51:19 - Systems & servers data update completed. 2016.12.02 20:58:06 - OpenVPN > Authenticate/Decrypt packet error: bad packet ID (may be a replay): [ #9729 ] -- see the man page entry for --no-replay and --replay-window for more info or silence this warning with --mute-replay-warnings. 2016.12.02 20:58:06 - OpenVPN > Authenticate/Decrypt packet error: bad packet ID (may be a replay): [ #9730 ] -- see the man page entry for --no-replay and --replay-window for more info or silence this warning with --mute-replay-warnings. 2016.12.02 20:58:06 - OpenVPN > Authenticate/Decrypt packet error: bad packet ID (may be a replay): [ #9731 ] -- see the man page entry for --no-replay and --replay-window for more info or silence this warning with --mute-replay-warnings. 2016.12.02 20:58:06 - OpenVPN > Authenticate/Decrypt packet error: bad packet ID (may be a replay): [ #9732 ] -- see the man page entry for --no-replay and --replay-window for more info or silence this warning with --mute-replay-warnings. 2016.12.02 20:58:06 - OpenVPN > Authenticate/Decrypt packet error: bad packet ID (may be a replay): [ #9729 ] -- see the man page entry for --no-replay and --replay-window for more info or silence this warning with --mute-replay-warnings. 2016.12.02 20:58:06 - OpenVPN > Authenticate/Decrypt packet error: bad packet ID (may be a replay): [ #9730 ] -- see the man page entry for --no-replay and --replay-window for more info or silence this warning with --mute-replay-warnings. 2016.12.02 20:58:06 - OpenVPN > Authenticate/Decrypt packet error: bad packet ID (may be a replay): [ #9731 ] -- see the man page entry for --no-replay and --replay-window for more info or silence this warning with --mute-replay-warnings. 2016.12.02 20:58:06 - OpenVPN > Authenticate/Decrypt packet error: bad packet ID (may be a replay): [ #9732 ] -- see the man page entry for --no-replay and --replay-window for more info or silence this warning with --mute-replay-warnings. 2016.12.02 20:58:06 - OpenVPN > Authenticate/Decrypt packet error: bad packet ID (may be a replay): [ #9731 ] -- see the man page entry for --no-replay and --replay-window for more info or silence this warning with --mute-replay-warnings. 2016.12.02 20:58:06 - OpenVPN > Authenticate/Decrypt packet error: bad packet ID (may be a replay): [ #9732 ] -- see the man page entry for --no-replay and --replay-window for more info or silence this warning with --mute-replay-warnings. 2016.12.02 20:58:06 - OpenVPN > Authenticate/Decrypt packet error: bad packet ID (may be a replay): [ #9729 ] -- see the man page entry for --no-replay and --replay-window for more info or silence this warning with --mute-replay-warnings. 2016.12.02 20:58:06 - OpenVPN > Authenticate/Decrypt packet error: bad packet ID (may be a replay): [ #9730 ] -- see the man page entry for --no-replay and --replay-window for more info or silence this warning with --mute-replay-warnings. 2016.12.02 20:58:06 - OpenVPN > Authenticate/Decrypt packet error: bad packet ID (may be a replay): [ #9731 ] -- see the man page entry for --no-replay and --replay-window for more info or silence this warning with --mute-replay-warnings. 2016.12.02 20:58:06 - OpenVPN > Authenticate/Decrypt packet error: bad packet ID (may be a replay): [ #9732 ] -- see the man page entry for --no-replay and --replay-window for more info or silence this warning with --mute-replay-warnings. 2016.12.02 20:58:06 - OpenVPN > Authenticate/Decrypt packet error: bad packet ID (may be a replay): [ #9752 ] -- see the man page entry for --no-replay and --replay-window for more info or silence this warning with --mute-replay-warnings. 2016.12.02 20:58:06 - OpenVPN > Authenticate/Decrypt packet error: bad packet ID (may be a replay): [ #9753 ] -- see the man page entry for --no-replay and --replay-window for more info or silence this warning with --mute-replay-warnings. 2016.12.02 20:58:06 - OpenVPN > Authenticate/Decrypt packet error: bad packet ID (may be a replay): [ #9752 ] -- see the man page entry for --no-replay and --replay-window for more info or silence this warning with --mute-replay-warnings. 2016.12.02 20:58:06 - OpenVPN > Authenticate/Decrypt packet error: bad packet ID (may be a replay): [ #9753 ] -- see the man page entry for --no-replay and --replay-window for more info or silence this warning with --mute-replay-warnings. 2016.12.02 20:58:06 - OpenVPN > Authenticate/Decrypt packet error: bad packet ID (may be a replay): [ #9752 ] -- see the man page entry for --no-replay and --replay-window for more info or silence this warning with --mute-replay-warnings. 2016.12.02 20:58:06 - OpenVPN > Authenticate/Decrypt packet error: bad packet ID (may be a replay): [ #9753 ] -- see the man page entry for --no-replay and --replay-window for more info or silence this warning with --mute-replay-warnings. 2016.12.02 20:58:06 - OpenVPN > Authenticate/Decrypt packet error: bad packet ID (may be a replay): [ #9752 ] -- see the man page entry for --no-replay and --replay-window for more info or silence this warning with --mute-replay-warnings. 2016.12.02 20:58:06 - OpenVPN > Authenticate/Decrypt packet error: bad packet ID (may be a replay): [ #9753 ] -- see the man page entry for --no-replay and --replay-window for more info or silence this warning with --mute-replay-warnings. 2016.12.02 20:58:06 - OpenVPN > Authenticate/Decrypt packet error: bad packet ID (may be a replay): [ #9752 ] -- see the man page entry for --no-replay and --replay-window for more info or silence this warning with --mute-replay-warnings. 2016.12.02 20:58:06 - OpenVPN > Authenticate/Decrypt packet error: bad packet ID (may be a replay): [ #9753 ] -- see the man page entry for --no-replay and --replay-window for more info or silence this warning with --mute-replay-warnings. 2016.12.02 20:58:06 - OpenVPN > Authenticate/Decrypt packet error: bad packet ID (may be a replay): [ #9754 ] -- see the man page entry for --no-replay and --replay-window for more info or silence this warning with --mute-replay-warnings. 2016.12.02 20:58:06 - OpenVPN > Authenticate/Decrypt packet error: bad packet ID (may be a replay): [ #9755 ] -- see the man page entry for --no-replay and --replay-window for more info or silence this warning with --mute-replay-warnings. 2016.12.02 20:58:06 - OpenVPN > Authenticate/Decrypt packet error: bad packet ID (may be a replay): [ #9754 ] -- see the man page entry for --no-replay and --replay-window for more info or silence this warning with --mute-replay-warnings. 2016.12.02 20:58:06 - OpenVPN > Authenticate/Decrypt packet error: bad packet ID (may be a replay): [ #9755 ] -- see the man page entry for --no-replay and --replay-window for more info or silence this warning with --mute-replay-warnings. 2016.12.02 20:58:06 - OpenVPN > Authenticate/Decrypt packet error: bad packet ID (may be a replay): [ #9754 ] -- see the man page entry for --no-replay and --replay-window for more info or silence this warning with --mute-replay-warnings. 2016.12.02 20:58:06 - OpenVPN > Authenticate/Decrypt packet error: bad packet ID (may be a replay): [ #9755 ] -- see the man page entry for --no-replay and --replay-window for more info or silence this warning with --mute-replay-warnings. 2016.12.02 20:58:06 - OpenVPN > Authenticate/Decrypt packet error: bad packet ID (may be a replay): [ #9754 ] -- see the man page entry for --no-replay and --replay-window for more info or silence this warning with --mute-replay-warnings. 2016.12.02 20:58:06 - OpenVPN > Authenticate/Decrypt packet error: bad packet ID (may be a replay): [ #9755 ] -- see the man page entry for --no-replay and --replay-window for more info or silence this warning with --mute-replay-warnings. 2016.12.02 20:58:06 - OpenVPN > Authenticate/Decrypt packet error: bad packet ID (may be a replay): [ #9761 ] -- see the man page entry for --no-replay and --replay-window for more info or silence this warning with --mute-replay-warnings. 2016.12.02 20:58:06 - OpenVPN > Authenticate/Decrypt packet error: bad packet ID (may be a replay): [ #9762 ] -- see the man page entry for --no-replay and --replay-window for more info or silence this warning with --mute-replay-warnings. 2016.12.02 20:58:06 - OpenVPN > Authenticate/Decrypt packet error: bad packet ID (may be a replay): [ #9761 ] -- see the man page entry for --no-replay and --replay-window for more info or silence this warning with --mute-replay-warnings. 2016.12.02 20:58:06 - OpenVPN > Authenticate/Decrypt packet error: bad packet ID (may be a replay): [ #9762 ] -- see the man page entry for --no-replay and --replay-window for more info or silence this warning with --mute-replay-warnings. 2016.12.02 20:58:06 - OpenVPN > Authenticate/Decrypt packet error: bad packet ID (may be a replay): [ #9761 ] -- see the man page entry for --no-replay and --replay-window for more info or silence this warning with --mute-replay-warnings. 2016.12.02 20:58:06 - OpenVPN > Authenticate/Decrypt packet error: bad packet ID (may be a replay): [ #9762 ] -- see the man page entry for --no-replay and --replay-window for more info or silence this warning with --mute-replay-warnings. 2016.12.02 20:58:06 - OpenVPN > Authenticate/Decrypt packet error: bad packet ID (may be a replay): [ #9761 ] -- see the man page entry for --no-replay and --replay-window for more info or silence this warning with --mute-replay-warnings. 2016.12.02 20:58:06 - OpenVPN > Authenticate/Decrypt packet error: bad packet ID (may be a replay): [ #9762 ] -- see the man page entry for --no-replay and --replay-window for more info or silence this warning with --mute-replay-warnings. 2016.12.02 20:58:06 - OpenVPN > Authenticate/Decrypt packet error: bad packet ID (may be a replay): [ #9761 ] -- see the man page entry for --no-replay and --replay-window for more info or silence this warning with --mute-replay-warnings. 2016.12.02 20:58:06 - OpenVPN > Authenticate/Decrypt packet error: bad packet ID (may be a replay): [ #9762 ] -- see the man page entry for --no-replay and --replay-window for more info or silence this warning with --mute-replay-warnings. 2016.12.02 20:58:06 - OpenVPN > Authenticate/Decrypt packet error: bad packet ID (may be a replay): [ #9763 ] -- see the man page entry for --no-replay and --replay-window for more info or silence this warning with --mute-replay-warnings. 2016.12.02 20:58:06 - OpenVPN > Authenticate/Decrypt packet error: bad packet ID (may be a replay): [ #9765 ] -- see the man page entry for --no-replay and --replay-window for more info or silence this warning with --mute-replay-warnings. 2016.12.02 20:58:06 - OpenVPN > Authenticate/Decrypt packet error: bad packet ID (may be a replay): [ #9766 ] -- see the man page entry for --no-replay and --replay-window for more info or silence this warning with --mute-replay-warnings. 2016.12.02 20:58:06 - OpenVPN > Authenticate/Decrypt packet error: bad packet ID (may be a replay): [ #9763 ] -- see the man page entry for --no-replay and --replay-window for more info or silence this warning with --mute-replay-warnings. 2016.12.02 20:58:06 - OpenVPN > Authenticate/Decrypt packet error: bad packet ID (may be a replay): [ #9765 ] -- see the man page entry for --no-replay and --replay-window for more info or silence this warning with --mute-replay-warnings. 2016.12.02 20:58:06 - OpenVPN > Authenticate/Decrypt packet error: bad packet ID (may be a replay): [ #9766 ] -- see the man page entry for --no-replay and --replay-window for more info or silence this warning with --mute-replay-warnings. 2016.12.02 20:58:06 - OpenVPN > Authenticate/Decrypt packet error: bad packet ID (may be a replay): [ #9763 ] -- see the man page entry for --no-replay and --replay-window for more info or silence this warning with --mute-replay-warnings. 2016.12.02 20:58:06 - OpenVPN > Authenticate/Decrypt packet error: bad packet ID (may be a replay): [ #9765 ] -- see the man page entry for --no-replay and --replay-window for more info or silence this warning with --mute-replay-warnings. 2016.12.02 20:58:06 - OpenVPN > Authenticate/Decrypt packet error: bad packet ID (may be a replay): [ #9766 ] -- see the man page entry for --no-replay and --replay-window for more info or silence this warning with --mute-replay-warnings. 2016.12.02 20:58:06 - OpenVPN > Authenticate/Decrypt packet error: bad packet ID (may be a replay): [ #9763 ] -- see the man page entry for --no-replay and --replay-window for more info or silence this warning with --mute-replay-warnings. 2016.12.02 20:58:06 - OpenVPN > Authenticate/Decrypt packet error: bad packet ID (may be a replay): [ #9765 ] -- see the man page entry for --no-replay and --replay-window for more info or silence this warning with --mute-replay-warnings. 2016.12.02 20:58:06 - OpenVPN > Authenticate/Decrypt packet error: bad packet ID (may be a replay): [ #9766 ] -- see the man page entry for --no-replay and --replay-window for more info or silence this warning with --mute-replay-warnings. 2016.12.02 21:00:19 - OpenVPN > Authenticate/Decrypt packet error: bad packet ID (may be a replay): [ #14443 ] -- see the man page entry for --no-replay and --replay-window for more info or silence this warning with --mute-replay-warnings. 2016.12.02 21:00:19 - OpenVPN > Authenticate/Decrypt packet error: bad packet ID (may be a replay): [ #14444 ] -- see the man page entry for --no-replay and --replay-window for more info or silence this warning with --mute-replay-warnings. 2016.12.02 21:00:19 - OpenVPN > Authenticate/Decrypt packet error: bad packet ID (may be a replay): [ #14443 ] -- see the man page entry for --no-replay and --replay-window for more info or silence this warning with --mute-replay-warnings. 2016.12.02 21:00:19 - OpenVPN > Authenticate/Decrypt packet error: bad packet ID (may be a replay): [ #14444 ] -- see the man page entry for --no-replay and --replay-window for more info or silence this warning with --mute-replay-warnings. 2016.12.02 21:00:19 - OpenVPN > Authenticate/Decrypt packet error: bad packet ID (may be a replay): [ #14443 ] -- see the man page entry for --no-replay and --replay-window for more info or silence this warning with --mute-replay-warnings. 2016.12.02 21:00:19 - OpenVPN > Authenticate/Decrypt packet error: bad packet ID (may be a replay): [ #14444 ] -- see the man page entry for --no-replay and --replay-window for more info or silence this warning with --mute-replay-warnings. 2016.12.02 21:00:19 - OpenVPN > Authenticate/Decrypt packet error: bad packet ID (may be a replay): [ #14443 ] -- see the man page entry for --no-replay and --replay-window for more info or silence this warning with --mute-replay-warnings. 2016.12.02 21:00:19 - OpenVPN > Authenticate/Decrypt packet error: bad packet ID (may be a replay): [ #14444 ] -- see the man page entry for --no-replay and --replay-window for more info or silence this warning with --mute-replay-warnings. 2016.12.02 21:00:19 - OpenVPN > Authenticate/Decrypt packet error: bad packet ID (may be a replay): [ #14443 ] -- see the man page entry for --no-replay and --replay-window for more info or silence this warning with --mute-replay-warnings. 2016.12.02 21:00:19 - OpenVPN > Authenticate/Decrypt packet error: bad packet ID (may be a replay): [ #14444 ] -- see the man page entry for --no-replay and --replay-window for more info or silence this warning with --mute-replay-warnings. 2016.12.02 21:00:32 - OpenVPN > Authenticate/Decrypt packet error: bad packet ID (may be a replay): [ #15918 ] -- see the man page entry for --no-replay and --replay-window for more info or silence this warning with --mute-replay-warnings. 2016.12.02 21:00:32 - OpenVPN > Authenticate/Decrypt packet error: bad packet ID (may be a replay): [ #15917 ] -- see the man page entry for --no-replay and --replay-window for more info or silence this warning with --mute-replay-warnings. 2016.12.02 21:00:32 - OpenVPN > Authenticate/Decrypt packet error: bad packet ID (may be a replay): [ #15918 ] -- see the man page entry for --no-replay and --replay-window for more info or silence this warning with --mute-replay-warnings. 2016.12.02 21:00:32 - OpenVPN > Authenticate/Decrypt packet error: bad packet ID (may be a replay): [ #15917 ] -- see the man page entry for --no-replay and --replay-window for more info or silence this warning with --mute-replay-warnings. 2016.12.02 21:00:32 - OpenVPN > Authenticate/Decrypt packet error: bad packet ID (may be a replay): [ #15918 ] -- see the man page entry for --no-replay and --replay-window for more info or silence this warning with --mute-replay-warnings. 2016.12.02 21:00:32 - OpenVPN > Authenticate/Decrypt packet error: bad packet ID (may be a replay): [ #15917 ] -- see the man page entry for --no-replay and --replay-window for more info or silence this warning with --mute-replay-warnings. 2016.12.02 21:01:19 - OpenVPN > Authenticate/Decrypt packet error: bad packet ID (may be a replay): [ #16215 ] -- see the man page entry for --no-replay and --replay-window for more info or silence this warning with --mute-replay-warnings. 2016.12.02 21:01:19 - OpenVPN > Authenticate/Decrypt packet error: bad packet ID (may be a replay): [ #16217 ] -- see the man page entry for --no-replay and --replay-window for more info or silence this warning with --mute-replay-warnings. 2016.12.02 21:01:19 - OpenVPN > Authenticate/Decrypt packet error: bad packet ID (may be a replay): [ #16215 ] -- see the man page entry for --no-replay and --replay-window for more info or silence this warning with --mute-replay-warnings. 2016.12.02 21:01:19 - OpenVPN > Authenticate/Decrypt packet error: bad packet ID (may be a replay): [ #16217 ] -- see the man page entry for --no-replay and --replay-window for more info or silence this warning with --mute-replay-warnings. 2016.12.02 21:01:19 - OpenVPN > Authenticate/Decrypt packet error: bad packet ID (may be a replay): [ #16215 ] -- see the man page entry for --no-replay and --replay-window for more info or silence this warning with --mute-replay-warnings. 2016.12.02 21:01:19 - OpenVPN > Authenticate/Decrypt packet error: bad packet ID (may be a replay): [ #16217 ] -- see the man page entry for --no-replay and --replay-window for more info or silence this warning with --mute-replay-warnings. 2016.12.02 21:01:19 - OpenVPN > Authenticate/Decrypt packet error: bad packet ID (may be a replay): [ #16215 ] -- see the man page entry for --no-replay and --replay-window for more info or silence this warning with --mute-replay-warnings. 2016.12.02 21:01:19 - OpenVPN > Authenticate/Decrypt packet error: bad packet ID (may be a replay): [ #16217 ] -- see the man page entry for --no-replay and --replay-window for more info or silence this warning with --mute-replay-warnings. 2016.12.02 21:01:19 - OpenVPN > Authenticate/Decrypt packet error: bad packet ID (may be a replay): [ #16215 ] -- see the man page entry for --no-replay and --replay-window for more info or silence this warning with --mute-replay-warnings. 2016.12.02 21:01:19 - OpenVPN > Authenticate/Decrypt packet error: bad packet ID (may be a replay): [ #16217 ] -- see the man page entry for --no-replay and --replay-window for more info or silence this warning with --mute-replay-warnings. 2016.12.02 21:01:29 - Updating systems & servers data .... 2016.12.02 21:01:31 - Systems & servers data update completed. 2016.12.02 21:01:55 - OpenVPN > Authenticate/Decrypt packet error: bad packet ID (may be a replay): [ #18146 ] -- see the man page entry for --no-replay and --replay-window for more info or silence this warning with --mute-replay-warnings. 2016.12.02 21:01:55 - OpenVPN > Authenticate/Decrypt packet error: bad packet ID (may be a replay): [ #18147 ] -- see the man page entry for --no-replay and --replay-window for more info or silence this warning with --mute-replay-warnings. 2016.12.02 21:01:55 - OpenVPN > Authenticate/Decrypt packet error: bad packet ID (may be a replay): [ #18148 ] -- see the man page entry for --no-replay and --replay-window for more info or silence this warning with --mute-replay-warnings. 2016.12.02 21:01:55 - OpenVPN > Authenticate/Decrypt packet error: bad packet ID (may be a replay): [ #18146 ] -- see the man page entry for --no-replay and --replay-window for more info or silence this warning with --mute-replay-warnings. 2016.12.02 21:01:55 - OpenVPN > Authenticate/Decrypt packet error: bad packet ID (may be a replay): [ #18147 ] -- see the man page entry for --no-replay and --replay-window for more info or silence this warning with --mute-replay-warnings. 2016.12.02 21:01:55 - OpenVPN > Authenticate/Decrypt packet error: bad packet ID (may be a replay): [ #18146 ] -- see the man page entry for --no-replay and --replay-window for more info or silence this warning with --mute-replay-warnings. 2016.12.02 21:01:55 - OpenVPN > Authenticate/Decrypt packet error: bad packet ID (may be a replay): [ #18147 ] -- see the man page entry for --no-replay and --replay-window for more info or silence this warning with --mute-replay-warnings. 2016.12.02 21:01:55 - OpenVPN > Authenticate/Decrypt packet error: bad packet ID (may be a replay): [ #18148 ] -- see the man page entry for --no-replay and --replay-window for more info or silence this warning with --mute-replay-warnings. 2016.12.02 21:01:55 - OpenVPN > Authenticate/Decrypt packet error: bad packet ID (may be a replay): [ #18146 ] -- see the man page entry for --no-replay and --replay-window for more info or silence this warning with --mute-replay-warnings. 2016.12.02 21:01:55 - OpenVPN > Authenticate/Decrypt packet error: bad packet ID (may be a replay): [ #18147 ] -- see the man page entry for --no-replay and --replay-window for more info or silence this warning with --mute-replay-warnings. 2016.12.02 21:01:55 - OpenVPN > Authenticate/Decrypt packet error: bad packet ID (may be a replay): [ #18148 ] -- see the man page entry for --no-replay and --replay-window for more info or silence this warning with --mute-replay-warnings. 2016.12.02 21:01:55 - OpenVPN > Authenticate/Decrypt packet error: bad packet ID (may be a replay): [ #18146 ] -- see the man page entry for --no-replay and --replay-window for more info or silence this warning with --mute-replay-warnings. 2016.12.02 21:01:55 - OpenVPN > Authenticate/Decrypt packet error: bad packet ID (may be a replay): [ #18147 ] -- see the man page entry for --no-replay and --replay-window for more info or silence this warning with --mute-replay-warnings. 2016.12.02 21:01:55 - OpenVPN > Authenticate/Decrypt packet error: bad packet ID (may be a replay): [ #18148 ] -- see the man page entry for --no-replay and --replay-window for more info or silence this warning with --mute-replay-warnings. 2016.12.02 21:04:59 - OpenVPN > Authenticate/Decrypt packet error: bad packet ID (may be a replay): [ #18467 ] -- see the man page entry for --no-replay and --replay-window for more info or silence this warning with --mute-replay-warnings. 2016.12.02 21:04:59 - OpenVPN > Authenticate/Decrypt packet error: bad packet ID (may be a replay): [ #18468 ] -- see the man page entry for --no-replay and --replay-window for more info or silence this warning with --mute-replay-warnings. 2016.12.02 21:04:59 - OpenVPN > Authenticate/Decrypt packet error: bad packet ID (may be a replay): [ #18467 ] -- see the man page entry for --no-replay and --replay-window for more info or silence this warning with --mute-replay-warnings. 2016.12.02 21:04:59 - OpenVPN > Authenticate/Decrypt packet error: bad packet ID (may be a replay): [ #18468 ] -- see the man page entry for --no-replay and --replay-window for more info or silence this warning with --mute-replay-warnings. 2016.12.02 21:04:59 - OpenVPN > Authenticate/Decrypt packet error: bad packet ID (may be a replay): [ #18467 ] -- see the man page entry for --no-replay and --replay-window for more info or silence this warning with --mute-replay-warnings. 2016.12.02 21:04:59 - OpenVPN > Authenticate/Decrypt packet error: bad packet ID (may be a replay): [ #18468 ] -- see the man page entry for --no-replay and --replay-window for more info or silence this warning with --mute-replay-warnings. 2016.12.02 21:04:59 - OpenVPN > Authenticate/Decrypt packet error: bad packet ID (may be a replay): [ #18467 ] -- see the man page entry for --no-replay and --replay-window for more info or silence this warning with --mute-replay-warnings. 2016.12.02 21:04:59 - OpenVPN > Authenticate/Decrypt packet error: bad packet ID (may be a replay): [ #18468 ] -- see the man page entry for --no-replay and --replay-window for more info or silence this warning with --mute-replay-warnings. 2016.12.02 21:04:59 - OpenVPN > Authenticate/Decrypt packet error: bad packet ID (may be a replay): [ #18467 ] -- see the man page entry for --no-replay and --replay-window for more info or silence this warning with --mute-replay-warnings. 2016.12.02 21:04:59 - OpenVPN > Authenticate/Decrypt packet error: bad packet ID (may be a replay): [ #18468 ] -- see the man page entry for --no-replay and --replay-window for more info or silence this warning with --mute-replay-warnings. 2016.12.02 21:06:29 - OpenVPN > Authenticate/Decrypt packet error: bad packet ID (may be a replay): [ #19459 ] -- see the man page entry for --no-replay and --replay-window for more info or silence this warning with --mute-replay-warnings. 2016.12.02 21:06:29 - OpenVPN > Authenticate/Decrypt packet error: bad packet ID (may be a replay): [ #19460 ] -- see the man page entry for --no-replay and --replay-window for more info or silence this warning with --mute-replay-warnings. 2016.12.02 21:06:29 - OpenVPN > Authenticate/Decrypt packet error: bad packet ID (may be a replay): [ #19459 ] -- see the man page entry for --no-replay and --replay-window for more info or silence this warning with --mute-replay-warnings. 2016.12.02 21:06:29 - OpenVPN > Authenticate/Decrypt packet error: bad packet ID (may be a replay): [ #19460 ] -- see the man page entry for --no-replay and --replay-window for more info or silence this warning with --mute-replay-warnings. 2016.12.02 21:06:29 - OpenVPN > Authenticate/Decrypt packet error: bad packet ID (may be a replay): [ #19459 ] -- see the man page entry for --no-replay and --replay-window for more info or silence this warning with --mute-replay-warnings. 2016.12.02 21:06:29 - OpenVPN > Authenticate/Decrypt packet error: bad packet ID (may be a replay): [ #19460 ] -- see the man page entry for --no-replay and --replay-window for more info or silence this warning with --mute-replay-warnings. 2016.12.02 21:06:29 - OpenVPN > Authenticate/Decrypt packet error: bad packet ID (may be a replay): [ #19459 ] -- see the man page entry for --no-replay and --replay-window for more info or silence this warning with --mute-replay-warnings. 2016.12.02 21:06:29 - OpenVPN > Authenticate/Decrypt packet error: bad packet ID (may be a replay): [ #19460 ] -- see the man page entry for --no-replay and --replay-window for more info or silence this warning with --mute-replay-warnings. 2016.12.02 21:06:29 - OpenVPN > Authenticate/Decrypt packet error: bad packet ID (may be a replay): [ #19459 ] -- see the man page entry for --no-replay and --replay-window for more info or silence this warning with --mute-replay-warnings. 2016.12.02 21:06:29 - OpenVPN > Authenticate/Decrypt packet error: bad packet ID (may be a replay): [ #19460 ] -- see the man page entry for --no-replay and --replay-window for more info or silence this warning with --mute-replay-warnings. 2016.12.02 21:06:29 - OpenVPN > Authenticate/Decrypt packet error: bad packet ID (may be a replay): [ #19461 ] -- see the man page entry for --no-replay and --replay-window for more info or silence this warning with --mute-replay-warnings. 2016.12.02 21:06:29 - OpenVPN > Authenticate/Decrypt packet error: bad packet ID (may be a replay): [ #19462 ] -- see the man page entry for --no-replay and --replay-window for more info or silence this warning with --mute-replay-warnings. 2016.12.02 21:06:29 - OpenVPN > Authenticate/Decrypt packet error: bad packet ID (may be a replay): [ #19463 ] -- see the man page entry for --no-replay and --replay-window for more info or silence this warning with --mute-replay-warnings. 2016.12.02 21:06:29 - OpenVPN > Authenticate/Decrypt packet error: bad packet ID (may be a replay): [ #19464 ] -- see the man page entry for --no-replay and --replay-window for more info or silence this warning with --mute-replay-warnings. 2016.12.02 21:06:29 - OpenVPN > Authenticate/Decrypt packet error: bad packet ID (may be a replay): [ #19465 ] -- see the man page entry for --no-replay and --replay-window for more info or silence this warning with --mute-replay-warnings. 2016.12.02 21:06:29 - OpenVPN > Authenticate/Decrypt packet error: bad packet ID (may be a replay): [ #19461 ] -- see the man page entry for --no-replay and --replay-window for more info or silence this warning with --mute-replay-warnings. 2016.12.02 21:06:29 - OpenVPN > Authenticate/Decrypt packet error: bad packet ID (may be a replay): [ #19462 ] -- see the man page entry for --no-replay and --replay-window for more info or silence this warning with --mute-replay-warnings. 2016.12.02 21:06:29 - OpenVPN > Authenticate/Decrypt packet error: bad packet ID (may be a replay): [ #19463 ] -- see the man page entry for --no-replay and --replay-window for more info or silence this warning with --mute-replay-warnings. 2016.12.02 21:06:29 - OpenVPN > Authenticate/Decrypt packet error: bad packet ID (may be a replay): [ #19464 ] -- see the man page entry for --no-replay and --replay-window for more info or silence this warning with --mute-replay-warnings. 2016.12.02 21:06:29 - OpenVPN > Authenticate/Decrypt packet error: bad packet ID (may be a replay): [ #19465 ] -- see the man page entry for --no-replay and --replay-window for more info or silence this warning with --mute-replay-warnings. 2016.12.02 21:06:29 - OpenVPN > Authenticate/Decrypt packet error: bad packet ID (may be a replay): [ #19461 ] -- see the man page entry for --no-replay and --replay-window for more info or silence this warning with --mute-replay-warnings. 2016.12.02 21:06:29 - OpenVPN > Authenticate/Decrypt packet error: bad packet ID (may be a replay): [ #19462 ] -- see the man page entry for --no-replay and --replay-window for more info or silence this warning with --mute-replay-warnings. 2016.12.02 21:06:29 - OpenVPN > Authenticate/Decrypt packet error: bad packet ID (may be a replay): [ #19463 ] -- see the man page entry for --no-replay and --replay-window for more info or silence this warning with --mute-replay-warnings. 2016.12.02 21:06:29 - OpenVPN > Authenticate/Decrypt packet error: bad packet ID (may be a replay): [ #19464 ] -- see the man page entry for --no-replay and --replay-window for more info or silence this warning with --mute-replay-warnings. 2016.12.02 21:06:29 - OpenVPN > Authenticate/Decrypt packet error: bad packet ID (may be a replay): [ #19465 ] -- see the man page entry for --no-replay and --replay-window for more info or silence this warning with --mute-replay-warnings. 2016.12.02 21:08:25 - OpenVPN > Authenticate/Decrypt packet error: bad packet ID (may be a replay): [ #23418 ] -- see the man page entry for --no-replay and --replay-window for more info or silence this warning with --mute-replay-warnings. 2016.12.02 21:08:25 - OpenVPN > Authenticate/Decrypt packet error: bad packet ID (may be a replay): [ #23419 ] -- see the man page entry for --no-replay and --replay-window for more info or silence this warning with --mute-replay-warnings. 2016.12.02 21:08:25 - OpenVPN > Authenticate/Decrypt packet error: bad packet ID (may be a replay): [ #23418 ] -- see the man page entry for --no-replay and --replay-window for more info or silence this warning with --mute-replay-warnings. 2016.12.02 21:08:25 - OpenVPN > Authenticate/Decrypt packet error: bad packet ID (may be a replay): [ #23419 ] -- see the man page entry for --no-replay and --replay-window for more info or silence this warning with --mute-replay-warnings. 2016.12.02 21:08:25 - OpenVPN > Authenticate/Decrypt packet error: bad packet ID (may be a replay): [ #23418 ] -- see the man page entry for --no-replay and --replay-window for more info or silence this warning with --mute-replay-warnings. 2016.12.02 21:08:25 - OpenVPN > Authenticate/Decrypt packet error: bad packet ID (may be a replay): [ #23419 ] -- see the man page entry for --no-replay and --replay-window for more info or silence this warning with --mute-replay-warnings. 2016.12.02 21:08:25 - OpenVPN > Authenticate/Decrypt packet error: bad packet ID (may be a replay): [ #23418 ] -- see the man page entry for --no-replay and --replay-window for more info or silence this warning with --mute-replay-warnings. 2016.12.02 21:08:25 - OpenVPN > Authenticate/Decrypt packet error: bad packet ID (may be a replay): [ #23419 ] -- see the man page entry for --no-replay and --replay-window for more info or silence this warning with --mute-replay-warnings. 2016.12.02 21:08:25 - OpenVPN > Authenticate/Decrypt packet error: bad packet ID (may be a replay): [ #23420 ] -- see the man page entry for --no-replay and --replay-window for more info or silence this warning with --mute-replay-warnings. 2016.12.02 21:08:25 - OpenVPN > Authenticate/Decrypt packet error: bad packet ID (may be a replay): [ #23421 ] -- see the man page entry for --no-replay and --replay-window for more info or silence this warning with --mute-replay-warnings. 2016.12.02 21:08:25 - OpenVPN > Authenticate/Decrypt packet error: bad packet ID (may be a replay): [ #23422 ] -- see the man page entry for --no-replay and --replay-window for more info or silence this warning with --mute-replay-warnings. 2016.12.02 21:08:25 - OpenVPN > Authenticate/Decrypt packet error: bad packet ID (may be a replay): [ #23423 ] -- see the man page entry for --no-replay and --replay-window for more info or silence this warning with --mute-replay-warnings. 2016.12.02 21:08:25 - OpenVPN > Authenticate/Decrypt packet error: bad packet ID (may be a replay): [ #23424 ] -- see the man page entry for --no-replay and --replay-window for more info or silence this warning with --mute-replay-warnings. 2016.12.02 21:08:25 - OpenVPN > Authenticate/Decrypt packet error: bad packet ID (may be a replay): [ #23425 ] -- see the man page entry for --no-replay and --replay-window for more info or silence this warning with --mute-replay-warnings. 2016.12.02 21:08:25 - OpenVPN > Authenticate/Decrypt packet error: bad packet ID (may be a replay): [ #23426 ] -- see the man page entry for --no-replay and --replay-window for more info or silence this warning with --mute-replay-warnings. 2016.12.02 21:08:25 - OpenVPN > Authenticate/Decrypt packet error: bad packet ID (may be a replay): [ #23420 ] -- see the man page entry for --no-replay and --replay-window for more info or silence this warning with --mute-replay-warnings. 2016.12.02 21:08:25 - OpenVPN > Authenticate/Decrypt packet error: bad packet ID (may be a replay): [ #23421 ] -- see the man page entry for --no-replay and --replay-window for more info or silence this warning with --mute-replay-warnings. 2016.12.02 21:08:25 - OpenVPN > Authenticate/Decrypt packet error: bad packet ID (may be a replay): [ #23422 ] -- see the man page entry for --no-replay and --replay-window for more info or silence this warning with --mute-replay-warnings. 2016.12.02 21:08:25 - OpenVPN > Authenticate/Decrypt packet error: bad packet ID (may be a replay): [ #23423 ] -- see the man page entry for --no-replay and --replay-window for more info or silence this warning with --mute-replay-warnings. 2016.12.02 21:08:25 - OpenVPN > Authenticate/Decrypt packet error: bad packet ID (may be a replay): [ #23424 ] -- see the man page entry for --no-replay and --replay-window for more info or silence this warning with --mute-replay-warnings. 2016.12.02 21:08:25 - OpenVPN > Authenticate/Decrypt packet error: bad packet ID (may be a replay): [ #23425 ] -- see the man page entry for --no-replay and --replay-window for more info or silence this warning with --mute-replay-warnings. 2016.12.02 21:08:25 - OpenVPN > Authenticate/Decrypt packet error: bad packet ID (may be a replay): [ #23426 ] -- see the man page entry for --no-replay and --replay-window for more info or silence this warning with --mute-replay-warnings. 2016.12.02 21:08:25 - OpenVPN > Authenticate/Decrypt packet error: bad packet ID (may be a replay): [ #23420 ] -- see the man page entry for --no-replay and --replay-window for more info or silence this warning with --mute-replay-warnings. 2016.12.02 21:08:25 - OpenVPN > Authenticate/Decrypt packet error: bad packet ID (may be a replay): [ #23421 ] -- see the man page entry for --no-replay and --replay-window for more info or silence this warning with --mute-replay-warnings. 2016.12.02 21:08:25 - OpenVPN > Authenticate/Decrypt packet error: bad packet ID (may be a replay): [ #23422 ] -- see the man page entry for --no-replay and --replay-window for more info or silence this warning with --mute-replay-warnings. 2016.12.02 21:08:25 - OpenVPN > Authenticate/Decrypt packet error: bad packet ID (may be a replay): [ #23423 ] -- see the man page entry for --no-replay and --replay-window for more info or silence this warning with --mute-replay-warnings. 2016.12.02 21:08:25 - OpenVPN > Authenticate/Decrypt packet error: bad packet ID (may be a replay): [ #23424 ] -- see the man page entry for --no-replay and --replay-window for more info or silence this warning with --mute-replay-warnings. 2016.12.02 21:08:25 - OpenVPN > Authenticate/Decrypt packet error: bad packet ID (may be a replay): [ #23425 ] -- see the man page entry for --no-replay and --replay-window for more info or silence this warning with --mute-replay-warnings. 2016.12.02 21:08:25 - OpenVPN > Authenticate/Decrypt packet error: bad packet ID (may be a replay): [ #23426 ] -- see the man page entry for --no-replay and --replay-window for more info or silence this warning with --mute-replay-warnings. 2016.12.02 21:08:25 - OpenVPN > Authenticate/Decrypt packet error: bad packet ID (may be a replay): [ #23420 ] -- see the man page entry for --no-replay and --replay-window for more info or silence this warning with --mute-replay-warnings. 2016.12.02 21:08:25 - OpenVPN > Authenticate/Decrypt packet error: bad packet ID (may be a replay): [ #23421 ] -- see the man page entry for --no-replay and --replay-window for more info or silence this warning with --mute-replay-warnings. 2016.12.02 21:08:25 - OpenVPN > Authenticate/Decrypt packet error: bad packet ID (may be a replay): [ #23422 ] -- see the man page entry for --no-replay and --replay-window for more info or silence this warning with --mute-replay-warnings. 2016.12.02 21:08:25 - OpenVPN > Authenticate/Decrypt packet error: bad packet ID (may be a replay): [ #23420 ] -- see the man page entry for --no-replay and --replay-window for more info or silence this warning with --mute-replay-warnings. 2016.12.02 21:08:25 - OpenVPN > Authenticate/Decrypt packet error: bad packet ID (may be a replay): [ #23421 ] -- see the man page entry for --no-replay and --replay-window for more info or silence this warning with --mute-replay-warnings. 2016.12.02 21:08:25 - OpenVPN > Authenticate/Decrypt packet error: bad packet ID (may be a replay): [ #23422 ] -- see the man page entry for --no-replay and --replay-window for more info or silence this warning with --mute-replay-warnings. 2016.12.02 21:08:25 - OpenVPN > Authenticate/Decrypt packet error: bad packet ID (may be a replay): [ #23423 ] -- see the man page entry for --no-replay and --replay-window for more info or silence this warning with --mute-replay-warnings. 2016.12.02 21:08:25 - OpenVPN > Authenticate/Decrypt packet error: bad packet ID (may be a replay): [ #23424 ] -- see the man page entry for --no-replay and --replay-window for more info or silence this warning with --mute-replay-warnings. 2016.12.02 21:08:25 - OpenVPN > Authenticate/Decrypt packet error: bad packet ID (may be a replay): [ #23425 ] -- see the man page entry for --no-replay and --replay-window for more info or silence this warning with --mute-replay-warnings. 2016.12.02 21:08:25 - OpenVPN > Authenticate/Decrypt packet error: bad packet ID (may be a replay): [ #23426 ] -- see the man page entry for --no-replay and --replay-window for more info or silence this warning with --mute-replay-warnings. 2016.12.02 21:10:00 - OpenVPN > Authenticate/Decrypt packet error: bad packet ID (may be a replay): [ #27296 ] -- see the man page entry for --no-replay and --replay-window for more info or silence this warning with --mute-replay-warnings. 2016.12.02 21:10:00 - OpenVPN > Authenticate/Decrypt packet error: bad packet ID (may be a replay): [ #27297 ] -- see the man page entry for --no-replay and --replay-window for more info or silence this warning with --mute-replay-warnings. 2016.12.02 21:10:00 - OpenVPN > Authenticate/Decrypt packet error: bad packet ID (may be a replay): [ #27296 ] -- see the man page entry for --no-replay and --replay-window for more info or silence this warning with --mute-replay-warnings. 2016.12.02 21:10:00 - OpenVPN > Authenticate/Decrypt packet error: bad packet ID (may be a replay): [ #27297 ] -- see the man page entry for --no-replay and --replay-window for more info or silence this warning with --mute-replay-warnings. 2016.12.02 21:10:00 - OpenVPN > Authenticate/Decrypt packet error: bad packet ID (may be a replay): [ #27296 ] -- see the man page entry for --no-replay and --replay-window for more info or silence this warning with --mute-replay-warnings. 2016.12.02 21:10:00 - OpenVPN > Authenticate/Decrypt packet error: bad packet ID (may be a replay): [ #27297 ] -- see the man page entry for --no-replay and --replay-window for more info or silence this warning with --mute-replay-warnings. 2016.12.02 21:10:00 - OpenVPN > Authenticate/Decrypt packet error: bad packet ID (may be a replay): [ #27296 ] -- see the man page entry for --no-replay and --replay-window for more info or silence this warning with --mute-replay-warnings. 2016.12.02 21:10:00 - OpenVPN > Authenticate/Decrypt packet error: bad packet ID (may be a replay): [ #27297 ] -- see the man page entry for --no-replay and --replay-window for more info or silence this warning with --mute-replay-warnings. 2016.12.02 21:10:00 - OpenVPN > Authenticate/Decrypt packet error: bad packet ID (may be a replay): [ #27296 ] -- see the man page entry for --no-replay and --replay-window for more info or silence this warning with --mute-replay-warnings. 2016.12.02 21:10:00 - OpenVPN > Authenticate/Decrypt packet error: bad packet ID (may be a replay): [ #27297 ] -- see the man page entry for --no-replay and --replay-window for more info or silence this warning with --mute-replay-warnings. 2016.12.02 21:10:00 - OpenVPN > Authenticate/Decrypt packet error: bad packet ID (may be a replay): [ #27325 ] -- see the man page entry for --no-replay and --replay-window for more info or silence this warning with --mute-replay-warnings. 2016.12.02 21:10:00 - OpenVPN > Authenticate/Decrypt packet error: bad packet ID (may be a replay): [ #27326 ] -- see the man page entry for --no-replay and --replay-window for more info or silence this warning with --mute-replay-warnings. 2016.12.02 21:10:00 - OpenVPN > Authenticate/Decrypt packet error: bad packet ID (may be a replay): [ #27325 ] -- see the man page entry for --no-replay and --replay-window for more info or silence this warning with --mute-replay-warnings. 2016.12.02 21:10:00 - OpenVPN > Authenticate/Decrypt packet error: bad packet ID (may be a replay): [ #27326 ] -- see the man page entry for --no-replay and --replay-window for more info or silence this warning with --mute-replay-warnings. 2016.12.02 21:10:00 - OpenVPN > Authenticate/Decrypt packet error: bad packet ID (may be a replay): [ #27325 ] -- see the man page entry for --no-replay and --replay-window for more info or silence this warning with --mute-replay-warnings. 2016.12.02 21:10:00 - OpenVPN > Authenticate/Decrypt packet error: bad packet ID (may be a replay): [ #27326 ] -- see the man page entry for --no-replay and --replay-window for more info or silence this warning with --mute-replay-warnings. 2016.12.02 21:10:00 - OpenVPN > Authenticate/Decrypt packet error: bad packet ID (may be a replay): [ #27325 ] -- see the man page entry for --no-replay and --replay-window for more info or silence this warning with --mute-replay-warnings. 2016.12.02 21:10:00 - OpenVPN > Authenticate/Decrypt packet error: bad packet ID (may be a replay): [ #27326 ] -- see the man page entry for --no-replay and --replay-window for more info or silence this warning with --mute-replay-warnings. 2016.12.02 21:10:02 - OpenVPN > Authenticate/Decrypt packet error: bad packet ID (may be a replay): [ #27574 ] -- see the man page entry for --no-replay and --replay-window for more info or silence this warning with --mute-replay-warnings. 2016.12.02 21:10:02 - OpenVPN > Authenticate/Decrypt packet error: bad packet ID (may be a replay): [ #27575 ] -- see the man page entry for --no-replay and --replay-window for more info or silence this warning with --mute-replay-warnings. 2016.12.02 21:10:02 - OpenVPN > Authenticate/Decrypt packet error: bad packet ID (may be a replay): [ #27574 ] -- see the man page entry for --no-replay and --replay-window for more info or silence this warning with --mute-replay-warnings. 2016.12.02 21:10:02 - OpenVPN > Authenticate/Decrypt packet error: bad packet ID (may be a replay): [ #27575 ] -- see the man page entry for --no-replay and --replay-window for more info or silence this warning with --mute-replay-warnings. 2016.12.02 21:10:02 - OpenVPN > Authenticate/Decrypt packet error: bad packet ID (may be a replay): [ #27574 ] -- see the man page entry for --no-replay and --replay-window for more info or silence this warning with --mute-replay-warnings. 2016.12.02 21:10:02 - OpenVPN > Authenticate/Decrypt packet error: bad packet ID (may be a replay): [ #27575 ] -- see the man page entry for --no-replay and --replay-window for more info or silence this warning with --mute-replay-warnings. 2016.12.02 21:10:02 - OpenVPN > Authenticate/Decrypt packet error: bad packet ID (may be a replay): [ #27574 ] -- see the man page entry for --no-replay and --replay-window for more info or silence this warning with --mute-replay-warnings. 2016.12.02 21:10:02 - OpenVPN > Authenticate/Decrypt packet error: bad packet ID (may be a replay): [ #27575 ] -- see the man page entry for --no-replay and --replay-window for more info or silence this warning with --mute-replay-warnings. 2016.12.02 21:10:02 - OpenVPN > Authenticate/Decrypt packet error: bad packet ID (may be a replay): [ #27574 ] -- see the man page entry for --no-replay and --replay-window for more info or silence this warning with --mute-replay-warnings. 2016.12.02 21:10:02 - OpenVPN > Authenticate/Decrypt packet error: bad packet ID (may be a replay): [ #27575 ] -- see the man page entry for --no-replay and --replay-window for more info or silence this warning with --mute-replay-warnings. 2016.12.02 21:10:36 - OpenVPN > Authenticate/Decrypt packet error: bad packet ID (may be a replay): [ #29914 ] -- see the man page entry for --no-replay and --replay-window for more info or silence this warning with --mute-replay-warnings. 2016.12.02 21:10:36 - OpenVPN > Authenticate/Decrypt packet error: bad packet ID (may be a replay): [ #29915 ] -- see the man page entry for --no-replay and --replay-window for more info or silence this warning with --mute-replay-warnings. 2016.12.02 21:10:36 - OpenVPN > Authenticate/Decrypt packet error: bad packet ID (may be a replay): [ #29914 ] -- see the man page entry for --no-replay and --replay-window for more info or silence this warning with --mute-replay-warnings. 2016.12.02 21:10:36 - OpenVPN > Authenticate/Decrypt packet error: bad packet ID (may be a replay): [ #29915 ] -- see the man page entry for --no-replay and --replay-window for more info or silence this warning with --mute-replay-warnings. 2016.12.02 21:10:36 - OpenVPN > Authenticate/Decrypt packet error: bad packet ID (may be a replay): [ #29914 ] -- see the man page entry for --no-replay and --replay-window for more info or silence this warning with --mute-replay-warnings. 2016.12.02 21:10:36 - OpenVPN > Authenticate/Decrypt packet error: bad packet ID (may be a replay): [ #29915 ] -- see the man page entry for --no-replay and --replay-window for more info or silence this warning with --mute-replay-warnings. 2016.12.02 21:10:36 - OpenVPN > Authenticate/Decrypt packet error: bad packet ID (may be a replay): [ #29914 ] -- see the man page entry for --no-replay and --replay-window for more info or silence this warning with --mute-replay-warnings. 2016.12.02 21:10:36 - OpenVPN > Authenticate/Decrypt packet error: bad packet ID (may be a replay): [ #29915 ] -- see the man page entry for --no-replay and --replay-window for more info or silence this warning with --mute-replay-warnings. 2016.12.02 21:10:36 - OpenVPN > Authenticate/Decrypt packet error: bad packet ID (may be a replay): [ #29914 ] -- see the man page entry for --no-replay and --replay-window for more info or silence this warning with --mute-replay-warnings. 2016.12.02 21:10:36 - OpenVPN > Authenticate/Decrypt packet error: bad packet ID (may be a replay): [ #29915 ] -- see the man page entry for --no-replay and --replay-window for more info or silence this warning with --mute-replay-warnings. 2016.12.02 21:11:20 - OpenVPN > Authenticate/Decrypt packet error: bad packet ID (may be a replay): [ #30560 ] -- see the man page entry for --no-replay and --replay-window for more info or silence this warning with --mute-replay-warnings. 2016.12.02 21:11:20 - OpenVPN > Authenticate/Decrypt packet error: bad packet ID (may be a replay): [ #30561 ] -- see the man page entry for --no-replay and --replay-window for more info or silence this warning with --mute-replay-warnings. 2016.12.02 21:11:20 - OpenVPN > Authenticate/Decrypt packet error: bad packet ID (may be a replay): [ #30560 ] -- see the man page entry for --no-replay and --replay-window for more info or silence this warning with --mute-replay-warnings. 2016.12.02 21:11:20 - OpenVPN > Authenticate/Decrypt packet error: bad packet ID (may be a replay): [ #30561 ] -- see the man page entry for --no-replay and --replay-window for more info or silence this warning with --mute-replay-warnings. 2016.12.02 21:11:20 - OpenVPN > Authenticate/Decrypt packet error: bad packet ID (may be a replay): [ #30560 ] -- see the man page entry for --no-replay and --replay-window for more info or silence this warning with --mute-replay-warnings. 2016.12.02 21:11:20 - OpenVPN > Authenticate/Decrypt packet error: bad packet ID (may be a replay): [ #30561 ] -- see the man page entry for --no-replay and --replay-window for more info or silence this warning with --mute-replay-warnings. 2016.12.02 21:11:20 - OpenVPN > Authenticate/Decrypt packet error: bad packet ID (may be a replay): [ #30560 ] -- see the man page entry for --no-replay and --replay-window for more info or silence this warning with --mute-replay-warnings. 2016.12.02 21:11:20 - OpenVPN > Authenticate/Decrypt packet error: bad packet ID (may be a replay): [ #30561 ] -- see the man page entry for --no-replay and --replay-window for more info or silence this warning with --mute-replay-warnings. 2016.12.02 21:11:32 - Updating systems & servers data .... 2016.12.02 21:11:33 - Systems & servers data update completed. 2016.12.02 21:21:06 - OpenVPN > VERIFY OK: depth=1, C=IT, ST=IT, L=Perugia, O=airvpn.org, CN=airvpn.org CA, emailAddress=info@airvpn.org. 2016.12.02 21:21:06 - OpenVPN > Validating certificate key usage. 2016.12.02 21:21:06 - OpenVPN > ++ Certificate has key usage 00a0, expects 00a0. 2016.12.02 21:21:06 - OpenVPN > VERIFY KU OK. 2016.12.02 21:21:06 - OpenVPN > Validating certificate extended key usage. 2016.12.02 21:21:06 - OpenVPN > ++ Certificate has EKU (str) TLS Web Server Authentication, expects TLS Web Server Authentication. 2016.12.02 21:21:06 - OpenVPN > VERIFY EKU OK. 2016.12.02 21:21:06 - OpenVPN > VERIFY OK: depth=0, C=IT, ST=IT, L=Perugia, O=airvpn.org, CN=server, emailAddress=info@airvpn.org. 2016.12.02 21:21:10 - OpenVPN > Data Channel Encrypt: Cipher 'AES-256-CBC' initialized with 256 bit key. 2016.12.02 21:21:10 - OpenVPN > Data Channel Encrypt: Using 160 bit message hash 'SHA1' for HMAC authentication. 2016.12.02 21:21:10 - OpenVPN > Data Channel Decrypt: Cipher 'AES-256-CBC' initialized with 256 bit key. 2016.12.02 21:21:10 - OpenVPN > Data Channel Decrypt: Using 160 bit message hash 'SHA1' for HMAC authentication. 2016.12.02 21:21:10 - OpenVPN > Control Channel: TLSv1.2, cipher TLSv1/SSLv3 DHE-RSA-AES256-GCM-SHA384, 4096 bit RSA. 2016.12.02 21:21:56 - Updating systems & servers data .... 2016.12.02 21:21:57 - Systems & servers data update completed. 2016.12.02 21:32:53 - Updating systems & servers data .... 2016.12.02 21:32:57 - Systems & servers data update completed. 2016.12.02 21:37:27 - OpenVPN > Authenticate/Decrypt packet error: bad packet ID (may be a replay): [ #1199 ] -- see the man page entry for --no-replay and --replay-window for more info or silence this warning with --mute-replay-warnings. 2016.12.02 21:37:27 - OpenVPN > Authenticate/Decrypt packet error: bad packet ID (may be a replay): [ #1200 ] -- see the man page entry for --no-replay and --replay-window for more info or silence this warning with --mute-replay-warnings. 2016.12.02 21:37:27 - OpenVPN > Authenticate/Decrypt packet error: bad packet ID (may be a replay): [ #1199 ] -- see the man page entry for --no-replay and --replay-window for more info or silence this warning with --mute-replay-warnings. 2016.12.02 21:37:27 - OpenVPN > Authenticate/Decrypt packet error: bad packet ID (may be a replay): [ #1200 ] -- see the man page entry for --no-replay and --replay-window for more info or silence this warning with --mute-replay-warnings. 2016.12.02 21:37:27 - OpenVPN > Authenticate/Decrypt packet error: bad packet ID (may be a replay): [ #1199 ] -- see the man page entry for --no-replay and --replay-window for more info or silence this warning with --mute-replay-warnings. 2016.12.02 21:37:27 - OpenVPN > Authenticate/Decrypt packet error: bad packet ID (may be a replay): [ #1200 ] -- see the man page entry for --no-replay and --replay-window for more info or silence this warning with --mute-replay-warnings. 2016.12.02 21:37:27 - OpenVPN > Authenticate/Decrypt packet error: bad packet ID (may be a replay): [ #1199 ] -- see the man page entry for --no-replay and --replay-window for more info or silence this warning with --mute-replay-warnings. 2016.12.02 21:37:27 - OpenVPN > Authenticate/Decrypt packet error: bad packet ID (may be a replay): [ #1200 ] -- see the man page entry for --no-replay and --replay-window for more info or silence this warning with --mute-replay-warnings. 2016.12.02 21:37:27 - OpenVPN > Authenticate/Decrypt packet error: bad packet ID (may be a replay): [ #1199 ] -- see the man page entry for --no-replay and --replay-window for more info or silence this warning with --mute-replay-warnings. 2016.12.02 21:37:27 - OpenVPN > Authenticate/Decrypt packet error: bad packet ID (may be a replay): [ #1200 ] -- see the man page entry for --no-replay and --replay-window for more info or silence this warning with --mute-replay-warnings. 2016.12.02 21:37:36 - OpenVPN > Authenticate/Decrypt packet error: bad packet ID (may be a replay): [ #1872 ] -- see the man page entry for --no-replay and --replay-window for more info or silence this warning with --mute-replay-warnings. 2016.12.02 21:37:36 - OpenVPN > Authenticate/Decrypt packet error: bad packet ID (may be a replay): [ #1873 ] -- see the man page entry for --no-replay and --replay-window for more info or silence this warning with --mute-replay-warnings. 2016.12.02 21:37:36 - OpenVPN > Authenticate/Decrypt packet error: bad packet ID (may be a replay): [ #1874 ] -- see the man page entry for --no-replay and --replay-window for more info or silence this warning with --mute-replay-warnings. 2016.12.02 21:37:36 - OpenVPN > Authenticate/Decrypt packet error: bad packet ID (may be a replay): [ #1872 ] -- see the man page entry for --no-replay and --replay-window for more info or silence this warning with --mute-replay-warnings. 2016.12.02 21:37:36 - OpenVPN > Authenticate/Decrypt packet error: bad packet ID (may be a replay): [ #1873 ] -- see the man page entry for --no-replay and --replay-window for more info or silence this warning with --mute-replay-warnings. 2016.12.02 21:37:36 - OpenVPN > Authenticate/Decrypt packet error: bad packet ID (may be a replay): [ #1874 ] -- see the man page entry for --no-replay and --replay-window for more info or silence this warning with --mute-replay-warnings. 2016.12.02 21:37:36 - OpenVPN > Authenticate/Decrypt packet error: bad packet ID (may be a replay): [ #1872 ] -- see the man page entry for --no-replay and --replay-window for more info or silence this warning with --mute-replay-warnings. 2016.12.02 21:37:36 - OpenVPN > Authenticate/Decrypt packet error: bad packet ID (may be a replay): [ #1873 ] -- see the man page entry for --no-replay and --replay-window for more info or silence this warning with --mute-replay-warnings. 2016.12.02 21:37:36 - OpenVPN > Authenticate/Decrypt packet error: bad packet ID (may be a replay): [ #1874 ] -- see the man page entry for --no-replay and --replay-window for more info or silence this warning with --mute-replay-warnings. 2016.12.02 21:37:36 - OpenVPN > Authenticate/Decrypt packet error: bad packet ID (may be a replay): [ #1872 ] -- see the man page entry for --no-replay and --replay-window for more info or silence this warning with --mute-replay-warnings. 2016.12.02 21:37:36 - OpenVPN > Authenticate/Decrypt packet error: bad packet ID (may be a replay): [ #1873 ] -- see the man page entry for --no-replay and --replay-window for more info or silence this warning with --mute-replay-warnings. 2016.12.02 21:37:36 - OpenVPN > Authenticate/Decrypt packet error: bad packet ID (may be a replay): [ #1874 ] -- see the man page entry for --no-replay and --replay-window for more info or silence this warning with --mute-replay-warnings. 2016.12.02 21:37:36 - OpenVPN > Authenticate/Decrypt packet error: bad packet ID (may be a replay): [ #1893 ] -- see the man page entry for --no-replay and --replay-window for more info or silence this warning with --mute-replay-warnings. 2016.12.02 21:37:36 - OpenVPN > Authenticate/Decrypt packet error: bad packet ID (may be a replay): [ #1894 ] -- see the man page entry for --no-replay and --replay-window for more info or silence this warning with --mute-replay-warnings. 2016.12.02 21:37:36 - OpenVPN > Authenticate/Decrypt packet error: bad packet ID (may be a replay): [ #1893 ] -- see the man page entry for --no-replay and --replay-window for more info or silence this warning with --mute-replay-warnings. 2016.12.02 21:37:36 - OpenVPN > Authenticate/Decrypt packet error: bad packet ID (may be a replay): [ #1894 ] -- see the man page entry for --no-replay and --replay-window for more info or silence this warning with --mute-replay-warnings. 2016.12.02 21:37:36 - OpenVPN > Authenticate/Decrypt packet error: bad packet ID (may be a replay): [ #1893 ] -- see the man page entry for --no-replay and --replay-window for more info or silence this warning with --mute-replay-warnings. 2016.12.02 21:37:36 - OpenVPN > Authenticate/Decrypt packet error: bad packet ID (may be a replay): [ #1894 ] -- see the man page entry for --no-replay and --replay-window for more info or silence this warning with --mute-replay-warnings. 2016.12.02 21:37:36 - OpenVPN > Authenticate/Decrypt packet error: bad packet ID (may be a replay): [ #1893 ] -- see the man page entry for --no-replay and --replay-window for more info or silence this warning with --mute-replay-warnings. 2016.12.02 21:37:36 - OpenVPN > Authenticate/Decrypt packet error: bad packet ID (may be a replay): [ #1894 ] -- see the man page entry for --no-replay and --replay-window for more info or silence this warning with --mute-replay-warnings. 2016.12.02 21:37:36 - OpenVPN > Authenticate/Decrypt packet error: bad packet ID (may be a replay): [ #1893 ] -- see the man page entry for --no-replay and --replay-window for more info or silence this warning with --mute-replay-warnings. 2016.12.02 21:37:36 - OpenVPN > Authenticate/Decrypt packet error: bad packet ID (may be a replay): [ #1894 ] -- see the man page entry for --no-replay and --replay-window for more info or silence this warning with --mute-replay-warnings. 2016.12.02 21:38:08 - OpenVPN > Authenticate/Decrypt packet error: bad packet ID (may be a replay): [ #3440 ] -- see the man page entry for --no-replay and --replay-window for more info or silence this warning with --mute-replay-warnings. 2016.12.02 21:38:08 - OpenVPN > Authenticate/Decrypt packet error: bad packet ID (may be a replay): [ #3441 ] -- see the man page entry for --no-replay and --replay-window for more info or silence this warning with --mute-replay-warnings. 2016.12.02 21:38:08 - OpenVPN > Authenticate/Decrypt packet error: bad packet ID (may be a replay): [ #3440 ] -- see the man page entry for --no-replay and --replay-window for more info or silence this warning with --mute-replay-warnings. 2016.12.02 21:38:08 - OpenVPN > Authenticate/Decrypt packet error: bad packet ID (may be a replay): [ #3441 ] -- see the man page entry for --no-replay and --replay-window for more info or silence this warning with --mute-replay-warnings. 2016.12.02 21:38:08 - OpenVPN > Authenticate/Decrypt packet error: bad packet ID (may be a replay): [ #3440 ] -- see the man page entry for --no-replay and --replay-window for more info or silence this warning with --mute-replay-warnings. 2016.12.02 21:38:08 - OpenVPN > Authenticate/Decrypt packet error: bad packet ID (may be a replay): [ #3441 ] -- see the man page entry for --no-replay and --replay-window for more info or silence this warning with --mute-replay-warnings. 2016.12.02 21:38:08 - OpenVPN > Authenticate/Decrypt packet error: bad packet ID (may be a replay): [ #3440 ] -- see the man page entry for --no-replay and --replay-window for more info or silence this warning with --mute-replay-warnings. 2016.12.02 21:38:08 - OpenVPN > Authenticate/Decrypt packet error: bad packet ID (may be a replay): [ #3441 ] -- see the man page entry for --no-replay and --replay-window for more info or silence this warning with --mute-replay-warnings. 2016.12.02 21:38:08 - OpenVPN > Authenticate/Decrypt packet error: bad packet ID (may be a replay): [ #3440 ] -- see the man page entry for --no-replay and --replay-window for more info or silence this warning with --mute-replay-warnings. 2016.12.02 21:38:08 - OpenVPN > Authenticate/Decrypt packet error: bad packet ID (may be a replay): [ #3441 ] -- see the man page entry for --no-replay and --replay-window for more info or silence this warning with --mute-replay-warnings. 2016.12.02 21:38:35 - OpenVPN > Authenticate/Decrypt packet error: bad packet ID (may be a replay): [ #3636 ] -- see the man page entry for --no-replay and --replay-window for more info or silence this warning with --mute-replay-warnings. 2016.12.02 21:38:35 - OpenVPN > Authenticate/Decrypt packet error: bad packet ID (may be a replay): [ #3637 ] -- see the man page entry for --no-replay and --replay-window for more info or silence this warning with --mute-replay-warnings. 2016.12.02 21:38:35 - OpenVPN > Authenticate/Decrypt packet error: bad packet ID (may be a replay): [ #3636 ] -- see the man page entry for --no-replay and --replay-window for more info or silence this warning with --mute-replay-warnings. 2016.12.02 21:38:35 - OpenVPN > Authenticate/Decrypt packet error: bad packet ID (may be a replay): [ #3637 ] -- see the man page entry for --no-replay and --replay-window for more info or silence this warning with --mute-replay-warnings. 2016.12.02 21:38:35 - OpenVPN > Authenticate/Decrypt packet error: bad packet ID (may be a replay): [ #3636 ] -- see the man page entry for --no-replay and --replay-window for more info or silence this warning with --mute-replay-warnings. 2016.12.02 21:38:35 - OpenVPN > Authenticate/Decrypt packet error: bad packet ID (may be a replay): [ #3637 ] -- see the man page entry for --no-replay and --replay-window for more info or silence this warning with --mute-replay-warnings. 2016.12.02 21:38:35 - OpenVPN > Authenticate/Decrypt packet error: bad packet ID (may be a replay): [ #3636 ] -- see the man page entry for --no-replay and --replay-window for more info or silence this warning with --mute-replay-warnings. 2016.12.02 21:38:35 - OpenVPN > Authenticate/Decrypt packet error: bad packet ID (may be a replay): [ #3637 ] -- see the man page entry for --no-replay and --replay-window for more info or silence this warning with --mute-replay-warnings. 2016.12.02 21:38:35 - OpenVPN > Authenticate/Decrypt packet error: bad packet ID (may be a replay): [ #3638 ] -- see the man page entry for --no-replay and --replay-window for more info or silence this warning with --mute-replay-warnings. 2016.12.02 21:38:35 - OpenVPN > Authenticate/Decrypt packet error: bad packet ID (may be a replay): [ #3639 ] -- see the man page entry for --no-replay and --replay-window for more info or silence this warning with --mute-replay-warnings. 2016.12.02 21:38:35 - OpenVPN > Authenticate/Decrypt packet error: bad packet ID (may be a replay): [ #3638 ] -- see the man page entry for --no-replay and --replay-window for more info or silence this warning with --mute-replay-warnings. 2016.12.02 21:38:35 - OpenVPN > Authenticate/Decrypt packet error: bad packet ID (may be a replay): [ #3639 ] -- see the man page entry for --no-replay and --replay-window for more info or silence this warning with --mute-replay-warnings. 2016.12.02 21:38:35 - OpenVPN > Authenticate/Decrypt packet error: bad packet ID (may be a replay): [ #3638 ] -- see the man page entry for --no-replay and --replay-window for more info or silence this warning with --mute-replay-warnings. 2016.12.02 21:38:35 - OpenVPN > Authenticate/Decrypt packet error: bad packet ID (may be a replay): [ #3639 ] -- see the man page entry for --no-replay and --replay-window for more info or silence this warning with --mute-replay-warnings. 2016.12.02 21:38:35 - OpenVPN > Authenticate/Decrypt packet error: bad packet ID (may be a replay): [ #3653 ] -- see the man page entry for --no-replay and --replay-window for more info or silence this warning with --mute-replay-warnings. 2016.12.02 21:38:35 - OpenVPN > Authenticate/Decrypt packet error: bad packet ID (may be a replay): [ #3654 ] -- see the man page entry for --no-replay and --replay-window for more info or silence this warning with --mute-replay-warnings. 2016.12.02 21:38:35 - OpenVPN > Authenticate/Decrypt packet error: bad packet ID (may be a replay): [ #3653 ] -- see the man page entry for --no-replay and --replay-window for more info or silence this warning with --mute-replay-warnings. 2016.12.02 21:38:35 - OpenVPN > Authenticate/Decrypt packet error: bad packet ID (may be a replay): [ #3654 ] -- see the man page entry for --no-replay and --replay-window for more info or silence this warning with --mute-replay-warnings. 2016.12.02 21:38:35 - OpenVPN > Authenticate/Decrypt packet error: bad packet ID (may be a replay): [ #3653 ] -- see the man page entry for --no-replay and --replay-window for more info or silence this warning with --mute-replay-warnings. 2016.12.02 21:38:35 - OpenVPN > Authenticate/Decrypt packet error: bad packet ID (may be a replay): [ #3654 ] -- see the man page entry for --no-replay and --replay-window for more info or silence this warning with --mute-replay-warnings. 2016.12.02 21:38:35 - OpenVPN > Authenticate/Decrypt packet error: bad packet ID (may be a replay): [ #3653 ] -- see the man page entry for --no-replay and --replay-window for more info or silence this warning with --mute-replay-warnings. 2016.12.02 21:38:35 - OpenVPN > Authenticate/Decrypt packet error: bad packet ID (may be a replay): [ #3654 ] -- see the man page entry for --no-replay and --replay-window for more info or silence this warning with --mute-replay-warnings. 2016.12.02 21:39:55 - OpenVPN > Authenticate/Decrypt packet error: bad packet ID (may be a replay): [ #6123 ] -- see the man page entry for --no-replay and --replay-window for more info or silence this warning with --mute-replay-warnings. 2016.12.02 21:39:55 - OpenVPN > Authenticate/Decrypt packet error: bad packet ID (may be a replay): [ #6124 ] -- see the man page entry for --no-replay and --replay-window for more info or silence this warning with --mute-replay-warnings. 2016.12.02 21:39:55 - OpenVPN > Authenticate/Decrypt packet error: bad packet ID (may be a replay): [ #6123 ] -- see the man page entry for --no-replay and --replay-window for more info or silence this warning with --mute-replay-warnings. 2016.12.02 21:39:55 - OpenVPN > Authenticate/Decrypt packet error: bad packet ID (may be a replay): [ #6124 ] -- see the man page entry for --no-replay and --replay-window for more info or silence this warning with --mute-replay-warnings. 2016.12.02 21:39:55 - OpenVPN > Authenticate/Decrypt packet error: bad packet ID (may be a replay): [ #6123 ] -- see the man page entry for --no-replay and --replay-window for more info or silence this warning with --mute-replay-warnings. 2016.12.02 21:39:55 - OpenVPN > Authenticate/Decrypt packet error: bad packet ID (may be a replay): [ #6124 ] -- see the man page entry for --no-replay and --replay-window for more info or silence this warning with --mute-replay-warnings. 2016.12.02 21:39:55 - OpenVPN > Authenticate/Decrypt packet error: bad packet ID (may be a replay): [ #6123 ] -- see the man page entry for --no-replay and --replay-window for more info or silence this warning with --mute-replay-warnings. 2016.12.02 21:39:55 - OpenVPN > Authenticate/Decrypt packet error: bad packet ID (may be a replay): [ #6124 ] -- see the man page entry for --no-replay and --replay-window for more info or silence this warning with --mute-replay-warnings. 2016.12.02 21:39:55 - OpenVPN > Authenticate/Decrypt packet error: bad packet ID (may be a replay): [ #6125 ] -- see the man page entry for --no-replay and --replay-window for more info or silence this warning with --mute-replay-warnings. 2016.12.02 21:39:55 - OpenVPN > Authenticate/Decrypt packet error: bad packet ID (may be a replay): [ #6126 ] -- see the man page entry for --no-replay and --replay-window for more info or silence this warning with --mute-replay-warnings. 2016.12.02 21:39:55 - OpenVPN > Authenticate/Decrypt packet error: bad packet ID (may be a replay): [ #6127 ] -- see the man page entry for --no-replay and --replay-window for more info or silence this warning with --mute-replay-warnings. 2016.12.02 21:39:55 - OpenVPN > Authenticate/Decrypt packet error: bad packet ID (may be a replay): [ #6125 ] -- see the man page entry for --no-replay and --replay-window for more info or silence this warning with --mute-replay-warnings. 2016.12.02 21:39:55 - OpenVPN > Authenticate/Decrypt packet error: bad packet ID (may be a replay): [ #6126 ] -- see the man page entry for --no-replay and --replay-window for more info or silence this warning with --mute-replay-warnings. 2016.12.02 21:39:55 - OpenVPN > Authenticate/Decrypt packet error: bad packet ID (may be a replay): [ #6127 ] -- see the man page entry for --no-replay and --replay-window for more info or silence this warning with --mute-replay-warnings. 2016.12.02 21:39:55 - OpenVPN > Authenticate/Decrypt packet error: bad packet ID (may be a replay): [ #6125 ] -- see the man page entry for --no-replay and --replay-window for more info or silence this warning with --mute-replay-warnings. 2016.12.02 21:39:55 - OpenVPN > Authenticate/Decrypt packet error: bad packet ID (may be a replay): [ #6126 ] -- see the man page entry for --no-replay and --replay-window for more info or silence this warning with --mute-replay-warnings. 2016.12.02 21:39:55 - OpenVPN > Authenticate/Decrypt packet error: bad packet ID (may be a replay): [ #6127 ] -- see the man page entry for --no-replay and --replay-window for more info or silence this warning with --mute-replay-warnings. 2016.12.02 21:39:55 - OpenVPN > Authenticate/Decrypt packet error: bad packet ID (may be a replay): [ #6125 ] -- see the man page entry for --no-replay and --replay-window for more info or silence this warning with --mute-replay-warnings. 2016.12.02 21:39:55 - OpenVPN > Authenticate/Decrypt packet error: bad packet ID (may be a replay): [ #6126 ] -- see the man page entry for --no-replay and --replay-window for more info or silence this warning with --mute-replay-warnings. 2016.12.02 21:39:55 - OpenVPN > Authenticate/Decrypt packet error: bad packet ID (may be a replay): [ #6127 ] -- see the man page entry for --no-replay and --replay-window for more info or silence this warning with --mute-replay-warnings. 2016.12.02 21:40:15 - OpenVPN > Authenticate/Decrypt packet error: bad packet ID (may be a replay): [ #7550 ] -- see the man page entry for --no-replay and --replay-window for more info or silence this warning with --mute-replay-warnings. 2016.12.02 21:40:15 - OpenVPN > Authenticate/Decrypt packet error: bad packet ID (may be a replay): [ #7551 ] -- see the man page entry for --no-replay and --replay-window for more info or silence this warning with --mute-replay-warnings. 2016.12.02 21:40:15 - OpenVPN > Authenticate/Decrypt packet error: bad packet ID (may be a replay): [ #7550 ] -- see the man page entry for --no-replay and --replay-window for more info or silence this warning with --mute-replay-warnings. 2016.12.02 21:40:15 - OpenVPN > Authenticate/Decrypt packet error: bad packet ID (may be a replay): [ #7551 ] -- see the man page entry for --no-replay and --replay-window for more info or silence this warning with --mute-replay-warnings. 2016.12.02 21:40:15 - OpenVPN > Authenticate/Decrypt packet error: bad packet ID (may be a replay): [ #7550 ] -- see the man page entry for --no-replay and --replay-window for more info or silence this warning with --mute-replay-warnings. 2016.12.02 21:40:15 - OpenVPN > Authenticate/Decrypt packet error: bad packet ID (may be a replay): [ #7551 ] -- see the man page entry for --no-replay and --replay-window for more info or silence this warning with --mute-replay-warnings. 2016.12.02 21:40:15 - OpenVPN > Authenticate/Decrypt packet error: bad packet ID (may be a replay): [ #7550 ] -- see the man page entry for --no-replay and --replay-window for more info or silence this warning with --mute-replay-warnings. 2016.12.02 21:40:15 - OpenVPN > Authenticate/Decrypt packet error: bad packet ID (may be a replay): [ #7551 ] -- see the man page entry for --no-replay and --replay-window for more info or silence this warning with --mute-replay-warnings. 2016.12.02 21:40:15 - OpenVPN > Authenticate/Decrypt packet error: bad packet ID (may be a replay): [ #7552 ] -- see the man page entry for --no-replay and --replay-window for more info or silence this warning with --mute-replay-warnings. 2016.12.02 21:40:15 - OpenVPN > Authenticate/Decrypt packet error: bad packet ID (may be a replay): [ #7553 ] -- see the man page entry for --no-replay and --replay-window for more info or silence this warning with --mute-replay-warnings. 2016.12.02 21:40:15 - OpenVPN > Authenticate/Decrypt packet error: bad packet ID (may be a replay): [ #7554 ] -- see the man page entry for --no-replay and --replay-window for more info or silence this warning with --mute-replay-warnings. 2016.12.02 21:40:15 - OpenVPN > Authenticate/Decrypt packet error: bad packet ID (may be a replay): [ #7552 ] -- see the man page entry for --no-replay and --replay-window for more info or silence this warning with --mute-replay-warnings. 2016.12.02 21:40:15 - OpenVPN > Authenticate/Decrypt packet error: bad packet ID (may be a replay): [ #7553 ] -- see the man page entry for --no-replay and --replay-window for more info or silence this warning with --mute-replay-warnings. 2016.12.02 21:40:15 - OpenVPN > Authenticate/Decrypt packet error: bad packet ID (may be a replay): [ #7554 ] -- see the man page entry for --no-replay and --replay-window for more info or silence this warning with --mute-replay-warnings. 2016.12.02 21:40:15 - OpenVPN > Authenticate/Decrypt packet error: bad packet ID (may be a replay): [ #7552 ] -- see the man page entry for --no-replay and --replay-window for more info or silence this warning with --mute-replay-warnings. 2016.12.02 21:40:15 - OpenVPN > Authenticate/Decrypt packet error: bad packet ID (may be a replay): [ #7553 ] -- see the man page entry for --no-replay and --replay-window for more info or silence this warning with --mute-replay-warnings. 2016.12.02 21:40:15 - OpenVPN > Authenticate/Decrypt packet error: bad packet ID (may be a replay): [ #7554 ] -- see the man page entry for --no-replay and --replay-window for more info or silence this warning with --mute-replay-warnings. 2016.12.02 21:40:15 - OpenVPN > Authenticate/Decrypt packet error: bad packet ID (may be a replay): [ #7552 ] -- see the man page entry for --no-replay and --replay-window for more info or silence this warning with --mute-replay-warnings. 2016.12.02 21:40:15 - OpenVPN > Authenticate/Decrypt packet error: bad packet ID (may be a replay): [ #7553 ] -- see the man page entry for --no-replay and --replay-window for more info or silence this warning with --mute-replay-warnings. 2016.12.02 21:40:15 - OpenVPN > Authenticate/Decrypt packet error: bad packet ID (may be a replay): [ #7554 ] -- see the man page entry for --no-replay and --replay-window for more info or silence this warning with --mute-replay-warnings. 2016.12.02 21:40:15 - OpenVPN > Authenticate/Decrypt packet error: bad packet ID (may be a replay): [ #7552 ] -- see the man page entry for --no-replay and --replay-window for more info or silence this warning with --mute-replay-warnings. 2016.12.02 21:40:15 - OpenVPN > Authenticate/Decrypt packet error: bad packet ID (may be a replay): [ #7553 ] -- see the man page entry for --no-replay and --replay-window for more info or silence this warning with --mute-replay-warnings. 2016.12.02 21:40:15 - OpenVPN > Authenticate/Decrypt packet error: bad packet ID (may be a replay): [ #7554 ] -- see the man page entry for --no-replay and --replay-window for more info or silence this warning with --mute-replay-warnings. 2016.12.02 21:40:15 - OpenVPN > Authenticate/Decrypt packet error: bad packet ID (may be a replay): [ #7555 ] -- see the man page entry for --no-replay and --replay-window for more info or silence this warning with --mute-replay-warnings. 2016.12.02 21:40:15 - OpenVPN > Authenticate/Decrypt packet error: bad packet ID (may be a replay): [ #7556 ] -- see the man page entry for --no-replay and --replay-window for more info or silence this warning with --mute-replay-warnings. 2016.12.02 21:40:15 - OpenVPN > Authenticate/Decrypt packet error: bad packet ID (may be a replay): [ #7557 ] -- see the man page entry for --no-replay and --replay-window for more info or silence this warning with --mute-replay-warnings. 2016.12.02 21:40:15 - OpenVPN > Authenticate/Decrypt packet error: bad packet ID (may be a replay): [ #7555 ] -- see the man page entry for --no-replay and --replay-window for more info or silence this warning with --mute-replay-warnings. 2016.12.02 21:40:15 - OpenVPN > Authenticate/Decrypt packet error: bad packet ID (may be a replay): [ #7556 ] -- see the man page entry for --no-replay and --replay-window for more info or silence this warning with --mute-replay-warnings. 2016.12.02 21:40:15 - OpenVPN > Authenticate/Decrypt packet error: bad packet ID (may be a replay): [ #7557 ] -- see the man page entry for --no-replay and --replay-window for more info or silence this warning with --mute-replay-warnings. 2016.12.02 21:40:15 - OpenVPN > Authenticate/Decrypt packet error: bad packet ID (may be a replay): [ #7555 ] -- see the man page entry for --no-replay and --replay-window for more info or silence this warning with --mute-replay-warnings. 2016.12.02 21:40:15 - OpenVPN > Authenticate/Decrypt packet error: bad packet ID (may be a replay): [ #7556 ] -- see the man page entry for --no-replay and --replay-window for more info or silence this warning with --mute-replay-warnings. 2016.12.02 21:40:15 - OpenVPN > Authenticate/Decrypt packet error: bad packet ID (may be a replay): [ #7557 ] -- see the man page entry for --no-replay and --replay-window for more info or silence this warning with --mute-replay-warnings. 2016.12.02 21:40:15 - OpenVPN > Authenticate/Decrypt packet error: bad packet ID (may be a replay): [ #7555 ] -- see the man page entry for --no-replay and --replay-window for more info or silence this warning with --mute-replay-warnings. 2016.12.02 21:40:15 - OpenVPN > Authenticate/Decrypt packet error: bad packet ID (may be a replay): [ #7556 ] -- see the man page entry for --no-replay and --replay-window for more info or silence this warning with --mute-replay-warnings. 2016.12.02 21:40:15 - OpenVPN > Authenticate/Decrypt packet error: bad packet ID (may be a replay): [ #7557 ] -- see the man page entry for --no-replay and --replay-window for more info or silence this warning with --mute-replay-warnings. 2016.12.02 21:40:15 - OpenVPN > Authenticate/Decrypt packet error: bad packet ID (may be a replay): [ #7555 ] -- see the man page entry for --no-replay and --replay-window for more info or silence this warning with --mute-replay-warnings. 2016.12.02 21:40:15 - OpenVPN > Authenticate/Decrypt packet error: bad packet ID (may be a replay): [ #7556 ] -- see the man page entry for --no-replay and --replay-window for more info or silence this warning with --mute-replay-warnings. 2016.12.02 21:40:15 - OpenVPN > Authenticate/Decrypt packet error: bad packet ID (may be a replay): [ #7557 ] -- see the man page entry for --no-replay and --replay-window for more info or silence this warning with --mute-replay-warnings. 2016.12.02 21:40:50 - OpenVPN > Authenticate/Decrypt packet error: bad packet ID (may be a replay): [ #7725 ] -- see the man page entry for --no-replay and --replay-window for more info or silence this warning with --mute-replay-warnings. 2016.12.02 21:40:50 - OpenVPN > Authenticate/Decrypt packet error: bad packet ID (may be a replay): [ #7726 ] -- see the man page entry for --no-replay and --replay-window for more info or silence this warning with --mute-replay-warnings. 2016.12.02 21:40:50 - OpenVPN > Authenticate/Decrypt packet error: bad packet ID (may be a replay): [ #7725 ] -- see the man page entry for --no-replay and --replay-window for more info or silence this warning with --mute-replay-warnings. 2016.12.02 21:40:50 - OpenVPN > Authenticate/Decrypt packet error: bad packet ID (may be a replay): [ #7726 ] -- see the man page entry for --no-replay and --replay-window for more info or silence this warning with --mute-replay-warnings. 2016.12.02 21:40:50 - OpenVPN > Authenticate/Decrypt packet error: bad packet ID (may be a replay): [ #7725 ] -- see the man page entry for --no-replay and --replay-window for more info or silence this warning with --mute-replay-warnings. 2016.12.02 21:40:50 - OpenVPN > Authenticate/Decrypt packet error: bad packet ID (may be a replay): [ #7726 ] -- see the man page entry for --no-replay and --replay-window for more info or silence this warning with --mute-replay-warnings. 2016.12.02 21:40:50 - OpenVPN > Authenticate/Decrypt packet error: bad packet ID (may be a replay): [ #7725 ] -- see the man page entry for --no-replay and --replay-window for more info or silence this warning with --mute-replay-warnings. 2016.12.02 21:40:50 - OpenVPN > Authenticate/Decrypt packet error: bad packet ID (may be a replay): [ #7726 ] -- see the man page entry for --no-replay and --replay-window for more info or silence this warning with --mute-replay-warnings. 2016.12.02 21:43:30 - Updating systems & servers data .... 2016.12.02 21:43:31 - Systems & servers data update completed. 2016.12.02 21:53:32 - Updating systems & servers data .... 2016.12.02 21:53:33 - Systems & servers data update completed Quote Share this post Link to post
LZ1 678 Posted ... You can check my signature for how. It's the red one. . 2016.12.02 20:19:36 - OpenVPN > Route: Waiting for TUN/TAP interface to come up.... 2016.12.02 20:19:36 - Eddie Windows Interface Hack executed (Local Area Connection 2) According to this, try go to your Control Panel>Networks & Connections>Relevant Tun/Tap driver adapter>Properties>Configure>Advanced>Change media status to either "Application controlled" or "Always up">Click Apply, depending on which mode it's already in. W 2016.12.02 20:20:00 - Checking route, 5° try failed (The remote name could not be resolved: 'nash_exit.airservers.org') Since you got checking route errors, you can try to go to the Eddie preferences and disable either one of both of IP or DNS Route Checking. See what works. You may also want to disable any IPv6 on your system if possible and any networking adapters you don't need. Likewise, you can experiment with using a wired and wireless connection, to rule one or the other out, if need be. Try that. Quote Hide LZ1's signature Hide all signatures Hi there, are you new to AirVPN? Many of your questions are already answered in this guide. You may also read the Eddie Android FAQ. Moderators do not speak on behalf of AirVPN. Only the Official Staff account does. Please also do not run Tor Exit Servers behind AirVPN, thank you. Did you make a guide or how-to for something? Then contact me to get it listed in my new user guide's Guides Section, so that the community can find it more easily. Share this post Link to post
NothingSpecial 4 Posted ... Thanks for your reply. I checked my settings with the info you provided and all was as should be. The problem remains in that any connection to a server within Eddie fails to connect and gets stuck in an endless loop. Only a re-boot sorts it out. However I have more issues now. I exited Eddie completely in order to access and log-in to some financial sites I use (PayPal for example) and I could not get a connection through my router. I uninstalled Eddie from my system and after a re-boot tried again and again without any success. I simply could not get a connection to my normal ISP server -- Error message = "Windows can't connect with primary DNS Server" I have reset my router to its factory defaults several times and the problem persists. I have had to use my old BT router HUB as a replacement and I can connect through that. However I am now unwilling to run AirVPN with this old router as I don't want to screw-up my net connection again completely. I would like to reinstall my newer router and get AirVPN up and running again but at the moment it simply trashes my normal net connection when I use it and disconnect. To be honest I am a very unhappy customer right now. I have paid for a years subscription and are now past the 3 day refund option. I would like to use AirVPN with my new router but cannot. I would like to disconnect from AirVPN easily and still use my normal net connection as and when required and then go back to AirVPN easily with a couple of mouse clicks. Eddie is not working properly (and I'm using the latest Beta that apparently from I have read should fix the missing "default DNS settings" but doesn't. I'm running out of patience and don't have the time to spend endless hours getting this to work properly. I would appreciate hearing a solution that can be implemented easily and works without hassle. Thank you. Quote Share this post Link to post
Khariz 109 Posted ... Sounds like you need to reset your DNS at the adapter level, not the router level. Go into your Network and Sharing Center, go to your ethernet adapter, go into the properties, got the ipv4 properties and tell it to automatically acquire DNS (or set it to something else). It's probably stuck on the 10.4.0.1 address that AirVPN sets it to. If you never manually resolved that before installing the new beta Eddie, the beta Eddie would have seen the 10.4.0.1 address as the "default" from the previous Eddie setting it that way. Quote Share this post Link to post
NothingSpecial 4 Posted ... Thank you Khariz. That indeed was the problem. I found it mentioned in another thread and applied it yesterday and Yes it worked. So thanks again for posting -- I'm sure this will help many newbies on this forum. The issues about (not) changing Servers in Eddie still remain but at least I can operate without too much hassle right now and that's the main thing. Boy do I feel exposed now using the net without AirVPM, especially in the UK with the Draconian "Snoopers Charter" now turned into another BS law. Thanks for helping, much appreciated. 1 LZ1 reacted to this Quote Share this post Link to post
Khariz 109 Posted ... Well, while we are posting back and forth, did you know that you can use Eddie to route things that you must use your local connection for outside of the VPN tunnel? This may help you not have to keep connecting reconnecting. Go to Preferences in the Eddie Client and then go to Routes. You can configure whatever sites you want to always be outside of the VPN Tunnel if you need to. Quote Share this post Link to post
NothingSpecial 4 Posted ... Thank you Khariz -- That is extremely helpful to know, in fact it is exactly what I need to know. I will check it out. I guess like most people there's only a few sites I need to access occasionally "outside" the tunnel, (official stuff like banking, paypal etc) most of the time I am researching topics that don't fall into the mainstream category. I have read on the forum that the correct closure of Eddie is necessary to prevent potential problems I would be grateful if anyone can provide a link or more info on this. Thanks for the help and advice, it really is appreciated. Quote Share this post Link to post
Khariz 109 Posted ... Basically, if you shutdown/restart your computer without properly shutting down Eddie (particularly when you are a user of the Network Lock feature), Eddie may not rollback some of the firewall/IPtable rules put in place by the software, and also may not reset the DNS settings of the adapters. The end result is not being able to use the internet at all after you restart your computer, until you start up Eddie, connect, and then disconnect again. You may also have DNS and routing table settings that are "stuck" and require manual intervention due to Eddie thinking the "default" state is the previously "modified" state. Does that make sense? Quote Share this post Link to post
NothingSpecial 4 Posted ... Yes Thank you it makes perfect sense. The thing I remain unclear about is the exact sequence to shut-down properly? Do I "Disconnect" and then click the close button in the top right? Do I have to eventually log-out too... all very confusing and cannot find any info on this. re "Go to Preferences in the Eddie Client and then go to Routes. You can configure whatever sites you want to always be outside of the VPN Tunnel if you need to."I tried pasting in the PayPal https site details and it does not work! It requires an IP / Host address (whatever that is?) How do I find that for the PayPal site? Thanks in advance. Quote Share this post Link to post
Khariz 109 Posted ... Shutdown procedure: 1. disconnect2. deactivate network lock (if you use it)3. close eddie4. Shutdown/restart computer Find the IP address: 1. Open up a command prompt2. type ping paypal.com3. Note that paypal's IP address is 64.4.250.32 Quote Share this post Link to post
Staff 10434 Posted ... Shutdown procedure: 1. disconnect2. deactivate network lock (if you use it)3. close eddie (optional) IMPORTANT NOTE: point 2 is optional, point 3 is MANDATORY. Actually point 2 can be ignored. Point 1 is included in point 3. Kind regards Quote Share this post Link to post
NothingSpecial 4 Posted ... Thank you for your kind help guys, it is appreciated. Yesterday while using AirVPN I checked exhaustively by logging-in to quite a few shopping sites, forums, even my bank, updated some important music software all while in the "tunnel" and I am very pleased to note that everything worked perfectly. I now have an efficient solution to PayPal which currently was the only real spanner in the works. I would like to take this opportunity to add that I am very impressed with AirVPN and the helpful forum here. I would like to extend my gratitude and appreciation to the guys who have worked so hard to create this software and network, so people like me can use it to protect my right to privacy. I am very grateful. THANK YOU. 1 Khariz reacted to this Quote Share this post Link to post
Khariz 109 Posted ... I love it here too. I've been a subscriber to 27 different VPN services, and this one is by far the best. Quote Share this post Link to post
