Not connected, Your IP: 216.73.216.54
WxjThf8HJV5ShAQ
VyOS config for port forwarding
I have successfully setup vyos to use openvpn to connect to AirVPN, however I am struggling with port forwarding incoming connections. Does anyone have any reference material or pointers on how to do this?
Thank you.
Looks like the syntax is from Cisco/Juniper firewalls, so for NAT you will need something from here:
http://wiki.vyos.net/wiki/User_Guide
set nat destination rule 10 description 'Port Forward: HTTP to 192.168.0.100'
set nat destination rule 10 destination port '80'
set nat destination rule 10 inbound-interface 'eth0'
set nat destination rule 10 protocol 'tcp'
set nat destination rule 10 translation address '192.168.0.100'
Change the IP addresses according to your LAN, the port you need, and the inbound-interface should be tunX or vtunX.
Thank you for your speedy reply. Yes, my destination NAT looks like this:
set nat destination rule 10 destination port '2255'
set nat destination rule 10 inbound-interface 'vtun99'
set nat destination rule 10 log 'enable'
set nat destination rule 10 translation address '192.168.235.100'
set nat destination rule 10 translation port '2255'
I think the traffic is coming through but may not be finding its way back.
