lahey
wireshark shows quic protocol, not udp or tcp
hi, i've started airvpn new experimental client and made wireshark filter: not host 192.168.0.1 and not udp
so i see that my pc sends to  vpn server via quic protocol. is it normal?
also may be can you advice other filters to check if airvpn client works proper.
arp queries are ok in logs?
Hello! Yes, it is normal to see this. The following explains what these protocols are.
https://en.wikipedia.org/wiki/QUIC
https://en.wikipedia.org/wiki/Address_Resolution_Protocol
"I don't see myself as a hero because what I'm doing is self-interested: I don't want to live in a world where there's no privacy and therefore no room for intellectual exploration and creativity." - Edward Snowden
"The Internet is by the people, for the people." - Kim Dotcom
could be a wireshark bug to see them as quic. You can force wireshark to see them as open vpn traffic and you end up with message type: P_DATA_V1
