Not connected, Your IP: 216.73.216.63
SodaStream
routing some traffic outside the airvpn tunnel
Im not very experienced with pfsense, and I could need some beginner help.
I see a need to create a special vpn tunnel or gateway for geographical dependent services like netflix, hbo and internet radio.
I have already setup airvpn on pfsense, but it routes all my traffic thru the airvpn tunnel, and this creates a problem when I have to change airvpn server to a different country when my own countrys airvpn servers get performance issues.
Can I use 2 vpn tunnels on the same internet line, or how should I go around to sort this out?
This network conflicts with address configured on interface 2
or if I tried to route a specific ip from AirVPN_LAN also have this conflict
can you help me please
Use the /system_routes.php page in the dashboard and choose the static routes tab.
From there you can specify the ranges you want and the gateway that should be used,
which can be either your WAN or another VPN interface.
