Bobby62
Problem of Upload with Download Station (Synology) and forwarding ports
Hello everyone!
I have a Synology NAS, a router (Freebox V5), AirVPN and I use Download Station (DS). I can download torrents but not upload ...
I chose the 50500 TCP port for Bittorent. I opened this port 50500 TCP / UDP on my router and on the firewall of DS. I put some pictures of my configuration. I don't understand all the things about the port opening, forwarding port ... and I think the problem comes from there. Especially with AirVPN. I don't know what I need to do after read that: "Anyway, change your default HTTP / HTTPS port is forwarded to your Syno AirVPN harbor and you shoulds be fine." I tried to put 50500 local TCP / UDP port with forwarding port, but it does not work ...
BT network configuration under DS:
Configuration of the firewall under DS:
Configuration of the port opening on the router Freebox V5:
And what to put in this port forwarding with AirVPN...?:
Thank you in advance for your ideas!
PS: the configuration of DS and the router are in french...sorry.
