Not connected, Your IP: 216.73.216.161
whistlewright
OpenVPN for Android Connection Refused
Motorola Droid Maxx phone xt1080 with Android 4.4.4 started getting connection refused errors a couple of hours ago when trying to connect to Airvpn. I do not allow any automatic updates and I have not manually updated anything since I started using Airvpn earlier this week. I really need it to work on my phone. Here is the log:
2016-10-20 18:30:47 F-Droid built and signed version 0.6.60 running on motorola XT1080 (MSM8960), Android 4.4.4 (SU6-7.7) API 19, ABI armeabi-v7a, (motorola/obake-maxx_verizon/obake-maxx:4.4.4/SU6-7.7/5:user/release-keys)
2016-10-20 18:30:47 Building configuration…
2016-10-20 18:30:48 MANAGEMENT: CMD 'signal SIGINT'
2016-10-20 18:30:48 SIGTERM received, sending exit notification to peer
2016-10-20 18:30:50 started Socket Thread
2016-10-20 18:30:50 Network Status: CONNECTED to WIFI "suddenlink.net-E7D2-5G"
2016-10-20 18:30:50 Current Parameter Settings:
2016-10-20 18:30:50 config = '/data/data/de.blinkt.openvpn/cache/android.conf'
2016-10-20 18:30:50 mode = 0
2016-10-20 18:30:50 show_ciphers = DISABLED
2016-10-20 18:30:50 show_digests = DISABLED
2016-10-20 18:30:50 show_engines = DISABLED
2016-10-20 18:30:50 genkey = DISABLED
2016-10-20 18:30:50 key_pass_file = '[uNDEF]'
2016-10-20 18:30:50 show_tls_ciphers = DISABLED
2016-10-20 18:30:50 connect_retry_max = 0
2016-10-20 18:30:50 Connection profiles [0]:
2016-10-20 18:30:50 proto = udp
2016-10-20 18:30:50 local = '[uNDEF]'
2016-10-20 18:30:50 local_port = '[uNDEF]'
2016-10-20 18:30:50 remote = 'earth.vpn.airdns.org'
2016-10-20 18:30:50 remote_port = '443'
2016-10-20 18:30:50 remote_float = DISABLED
2016-10-20 18:30:50 bind_defined = DISABLED
2016-10-20 18:30:50 bind_local = DISABLED
2016-10-20 18:30:50 bind_ipv6_only = DISABLED
2016-10-20 18:30:50 connect_retry_seconds = 2
2016-10-20 18:30:50 connect_timeout = 120
2016-10-20 18:30:50 socks_proxy_server = '[uNDEF]'
2016-10-20 18:30:50 socks_proxy_port = '[uNDEF]'
2016-10-20 18:30:50 tun_mtu = 1500
2016-10-20 18:30:50 tun_mtu_defined = ENABLED
2016-10-20 18:30:50 link_mtu = 1500
2016-10-20 18:30:50 link_mtu_defined = DISABLED
2016-10-20 18:30:50 tun_mtu_extra = 0
2016-10-20 18:30:50 tun_mtu_extra_defined = DISABLED
2016-10-20 18:30:50 mtu_discover_type = -1
2016-10-20 18:30:50 fragment = 0
2016-10-20 18:30:50 mssfix = 1450
2016-10-20 18:30:50 explicit_exit_notification = 5
2016-10-20 18:30:50 Connection profiles END
2016-10-20 18:30:50 remote_random = DISABLED
2016-10-20 18:30:50 ipchange = '[uNDEF]'
2016-10-20 18:30:50 dev = 'tun'
2016-10-20 18:30:50 dev_type = '[uNDEF]'
2016-10-20 18:30:50 dev_node = '[uNDEF]'
2016-10-20 18:30:50 lladdr = '[uNDEF]'
2016-10-20 18:30:50 topology = 1
2016-10-20 18:30:50 ifconfig_local = '[uNDEF]'
2016-10-20 18:30:50 ifconfig_remote_netmask = '[uNDEF]'
2016-10-20 18:30:50 ifconfig_noexec = DISABLED
2016-10-20 18:30:50 ifconfig_nowarn = ENABLED
2016-10-20 18:30:50 ifconfig_ipv6_local = '[uNDEF]'
2016-10-20 18:30:50 ifconfig_ipv6_netbits = 0
2016-10-20 18:30:50 ifconfig_ipv6_remote = '[uNDEF]'
2016-10-20 18:30:50 shaper = 0
2016-10-20 18:30:50 mtu_test = 0
2016-10-20 18:30:50 mlock = DISABLED
2016-10-20 18:30:50 keepalive_ping = 0
2016-10-20 18:30:50 keepalive_timeout = 0
2016-10-20 18:30:50 inactivity_timeout = 0
2016-10-20 18:30:50 ping_send_timeout = 0
2016-10-20 18:30:50 ping_rec_timeout = 0
2016-10-20 18:30:50 ping_rec_timeout_action = 0
2016-10-20 18:30:50 ping_timer_remote = DISABLED
2016-10-20 18:30:50 remap_sigusr1 = 0
2016-10-20 18:30:50 persist_tun = ENABLED
2016-10-20 18:30:50 persist_local_ip = DISABLED
2016-10-20 18:30:50 persist_remote_ip = DISABLED
2016-10-20 18:30:50 persist_key = DISABLED
2016-10-20 18:30:50 passtos = DISABLED
2016-10-20 18:30:50 resolve_retry_seconds = 1000000000
2016-10-20 18:30:50 resolve_in_advance = ENABLED
2016-10-20 18:30:50 username = '[uNDEF]'
2016-10-20 18:30:50 groupname = '[uNDEF]'
2016-10-20 18:30:50 chroot_dir = '[uNDEF]'
2016-10-20 18:30:50 cd_dir = '[uNDEF]'
2016-10-20 18:30:50 writepid = '[uNDEF]'
2016-10-20 18:30:50 up_script = '[uNDEF]'
2016-10-20 18:30:50 down_script = '[uNDEF]'
2016-10-20 18:30:50 down_pre = DISABLED
2016-10-20 18:30:50 up_restart = DISABLED
2016-10-20 18:30:50 up_delay = DISABLED
2016-10-20 18:30:50 daemon = DISABLED
2016-10-20 18:30:50 inetd = 0
2016-10-20 18:30:50 log = DISABLED
2016-10-20 18:30:50 suppress_timestamps = DISABLED
2016-10-20 18:30:50 machine_readable_output = ENABLED
2016-10-20 18:30:50 nice = 0
2016-10-20 18:30:50 verbosity = 4
2016-10-20 18:30:50 mute = 0
2016-10-20 18:30:50 gremlin = 0
2016-10-20 18:30:50 status_file = '[uNDEF]'
2016-10-20 18:30:50 status_file_version = 1
2016-10-20 18:30:50 status_file_update_freq = 60
2016-10-20 18:30:50 occ = ENABLED
2016-10-20 18:30:50 rcvbuf = 0
2016-10-20 18:30:50 sndbuf = 0
2016-10-20 18:30:50 sockflags = 0
2016-10-20 18:30:50 fast_io = DISABLED
2016-10-20 18:30:50 comp.alg = 2
2016-10-20 18:30:50 comp.flags = 1
2016-10-20 18:30:50 route_script = '[uNDEF]'
2016-10-20 18:30:50 route_default_gateway = '[uNDEF]'
2016-10-20 18:30:50 route_default_metric = 0
2016-10-20 18:30:50 route_noexec = DISABLED
2016-10-20 18:30:50 route_delay = 0
2016-10-20 18:30:50 route_delay_window = 30
2016-10-20 18:30:50 route_delay_defined = DISABLED
2016-10-20 18:30:50 route_nopull = DISABLED
2016-10-20 18:30:50 route_gateway_via_dhcp = DISABLED
2016-10-20 18:30:50 allow_pull_fqdn = DISABLED
2016-10-20 18:30:50 management_addr = '/data/data/de.blinkt.openvpn/cache/mgmtsocket'
2016-10-20 18:30:50 management_port = 'unix'
2016-10-20 18:30:50 management_user_pass = '[uNDEF]'
2016-10-20 18:30:50 management_log_history_cache = 250
2016-10-20 18:30:50 management_echo_buffer_size = 100
2016-10-20 18:30:50 management_write_peer_info_file = '[uNDEF]'
2016-10-20 18:30:50 management_client_user = '[uNDEF]'
2016-10-20 18:30:50 management_client_group = '[uNDEF]'
2016-10-20 18:30:50 management_flags = 4390
2016-10-20 18:30:50 shared_secret_file = '[uNDEF]'
2016-10-20 18:30:50 key_direction = 2
2016-10-20 18:30:50 ciphername = 'AES-256-CBC'
2016-10-20 18:30:50 authname = 'SHA1'
2016-10-20 18:30:50 prng_hash = 'SHA1'
2016-10-20 18:30:50 prng_nonce_secret_len = 16
2016-10-20 18:30:50 keysize = 0
2016-10-20 18:30:50 engine = DISABLED
2016-10-20 18:30:50 replay = ENABLED
2016-10-20 18:30:50 mute_replay_warnings = DISABLED
2016-10-20 18:30:50 replay_window = 64
2016-10-20 18:30:50 replay_time = 15
2016-10-20 18:30:50 packet_id_file = '[uNDEF]'
2016-10-20 18:30:50 use_iv = ENABLED
2016-10-20 18:30:50 test_crypto = DISABLED
2016-10-20 18:30:50 tls_server = DISABLED
2016-10-20 18:30:50 tls_client = ENABLED
2016-10-20 18:30:50 key_method = 2
2016-10-20 18:30:50 ca_file = '[[iNLINE]]'
2016-10-20 18:30:50 ca_path = '[uNDEF]'
2016-10-20 18:30:50 dh_file = '[uNDEF]'
2016-10-20 18:30:50 cert_file = '[[iNLINE]]'
2016-10-20 18:30:50 extra_certs_file = '[uNDEF]'
2016-10-20 18:30:50 priv_key_file = '[[iNLINE]]'
2016-10-20 18:30:50 pkcs12_file = '[uNDEF]'
2016-10-20 18:30:50 cipher_list = '[uNDEF]'
2016-10-20 18:30:50 tls_verify = '[uNDEF]'
2016-10-20 18:30:50 tls_export_cert = '[uNDEF]'
2016-10-20 18:30:50 verify_x509_type = 0
2016-10-20 18:30:50 verify_x509_name = '[uNDEF]'
2016-10-20 18:30:50 crl_file = '[uNDEF]'
2016-10-20 18:30:50 ns_cert_type = 0
2016-10-20 18:30:50 remote_cert_ku = 160
2016-10-20 18:30:50 remote_cert_ku = 136
2016-10-20 18:30:50 remote_cert_ku = 0
2016-10-20 18:30:50 remote_cert_eku = 'TLS Web Server Authentication'
2016-10-20 18:30:50 ssl_flags = 0
2016-10-20 18:30:50 tls_timeout = 2
2016-10-20 18:30:50 renegotiate_bytes = 0
2016-10-20 18:30:50 renegotiate_packets = 0
2016-10-20 18:30:50 renegotiate_seconds = 3600
2016-10-20 18:30:50 handshake_window = 60
2016-10-20 18:30:50 transition_window = 3600
2016-10-20 18:30:50 single_session = DISABLED
2016-10-20 18:30:50 push_peer_info = DISABLED
2016-10-20 18:30:50 tls_exit = DISABLED
2016-10-20 18:30:50 tls_auth_file = '[[iNLINE]]'
2016-10-20 18:30:50 client = ENABLED
2016-10-20 18:30:50 pull = ENABLED
2016-10-20 18:30:50 auth_user_pass_file = '[uNDEF]'
2016-10-20 18:30:50 OpenVPN 2.4-icsopenvpn [git:HEAD-9d8801b6185d7453] android-14-armeabi-v7a [sSL (OpenSSL)] [LZO] [LZ4] [EPOLL] [MH/PKTINFO] [iPv6] built on Oct 13 2016
2016-10-20 18:30:50 library versions: OpenSSL 1.0.2j 26 Sep 2016, LZO 2.09
2016-10-20 18:30:50 MANAGEMENT: Connected to management server at /data/data/de.blinkt.openvpn/cache/mgmtsocket
2016-10-20 18:30:50 MANAGEMENT: CMD 'hold release'
2016-10-20 18:30:50 MANAGEMENT: CMD 'bytecount 2'
2016-10-20 18:30:50 MANAGEMENT: CMD 'state on'
2016-10-20 18:30:50 MANAGEMENT: CMD 'proxy NONE'
2016-10-20 18:30:50 Connection to OpenVPN closed (socket closed)
2016-10-20 18:30:50 MANAGEMENT: Client disconnected
2016-10-20 18:30:50 MANAGEMENT: Triggering management exit
2016-10-20 18:30:50 TCP/UDP: Closing socket
2016-10-20 18:30:50 SIGTERM[soft,management-exit] received, process exiting
2016-10-20 18:30:50 MANAGEMENT: >STATE:1477006250,EXITING,management-exit,,,,,
2016-10-20 18:30:51 Outgoing Control Channel Authentication: Using 160 bit message hash 'SHA1' for HMAC authentication
2016-10-20 18:30:51 Incoming Control Channel Authentication: Using 160 bit message hash 'SHA1' for HMAC authentication
2016-10-20 18:30:51 LZO compression initializing
2016-10-20 18:30:51 Control Channel MTU parms [ L:1622 D:1184 EF:66 EB:0 ET:0 EL:3 ]
2016-10-20 18:30:51 Data Channel MTU parms [ L:1622 D:1450 EF:122 EB:406 ET:0 EL:3 ]
2016-10-20 18:30:51 Local Options String (VER=V4): 'V4,dev-type tun,link-mtu 1558,tun-mtu 1500,proto UDPv4,comp-lzo,keydir 1,cipher AES-256-CBC,auth SHA1,keysize 256,tls-auth,key-method 2,tls-client'
2016-10-20 18:30:51 Expected Remote Options String (VER=V4): 'V4,dev-type tun,link-mtu 1558,tun-mtu 1500,proto UDPv4,comp-lzo,keydir 0,cipher AES-256-CBC,auth SHA1,keysize 256,tls-auth,key-method 2,tls-server'
2016-10-20 18:30:51 TCP/UDP: Preserving recently used remote address: [AF_INET]71.19.249.195:443
2016-10-20 18:30:51 Socket Buffers: R=[163840->163840] S=[163840->163840]
2016-10-20 18:30:51 MANAGEMENT: CMD 'needok 'PROTECTFD' ok'
2016-10-20 18:30:51 UDP link local: (not bound)
2016-10-20 18:30:51 UDP link remote: [AF_INET]71.19.249.195:443
2016-10-20 18:30:51 MANAGEMENT: >STATE:1477006251,WAIT,,,,,,
2016-10-20 18:30:51 read UDP [ECONNREFUSED]: Connection refused (code=111)
2016-10-20 18:30:53 read UDP [ECONNREFUSED]: Connection refused (code=111)
2016-10-20 18:30:57 read UDP [ECONNREFUSED]: Connection refused (code=111)
2016-10-20 18:31:05 read UDP [ECONNREFUSED]: Connection refused (code=111)
2016-10-20 18:31:21 read UDP [ECONNREFUSED]: Connection refused (code=111)
2016-10-20 18:31:51 TLS Error: TLS key negotiation failed to occur within 60 seconds (check your network connectivity)
2016-10-20 18:31:51 TLS Error: TLS handshake failed
2016-10-20 18:31:51 TCP/UDP: Closing socket
2016-10-20 18:31:51 SIGUSR1[soft,tls-error] received, process restarting
2016-10-20 18:31:51 MANAGEMENT: >STATE:1477006311,RECONNECTING,tls-error,,,,,
2016-10-20 18:31:53 MANAGEMENT: CMD 'hold release'
2016-10-20 18:31:53 MANAGEMENT: CMD 'bytecount 2'
2016-10-20 18:31:53 MANAGEMENT: CMD 'state on'
2016-10-20 18:31:53 MANAGEMENT: CMD 'proxy NONE'
2016-10-20 18:31:54 Outgoing Control Channel Authentication: Using 160 bit message hash 'SHA1' for HMAC authentication
2016-10-20 18:31:54 Incoming Control Channel Authentication: Using 160 bit message hash 'SHA1' for HMAC authentication
2016-10-20 18:31:54 LZO compression initializing
2016-10-20 18:31:54 Control Channel MTU parms [ L:1622 D:1184 EF:66 EB:0 ET:0 EL:3 ]
2016-10-20 18:31:54 Data Channel MTU parms [ L:1622 D:1450 EF:122 EB:406 ET:0 EL:3 ]
2016-10-20 18:31:54 Local Options String (VER=V4): 'V4,dev-type tun,link-mtu 1558,tun-mtu 1500,proto UDPv4,comp-lzo,keydir 1,cipher AES-256-CBC,auth SHA1,keysize 256,tls-auth,key-method 2,tls-client'
2016-10-20 18:31:54 Expected Remote Options String (VER=V4): 'V4,dev-type tun,link-mtu 1558,tun-mtu 1500,proto UDPv4,comp-lzo,keydir 0,cipher AES-256-CBC,auth SHA1,keysize 256,tls-auth,key-method 2,tls-server'
2016-10-20 18:31:54 TCP/UDP: Preserving recently used remote address: [AF_INET]71.19.249.195:443
2016-10-20 18:31:54 Socket Buffers: R=[163840->163840] S=[163840->163840]
2016-10-20 18:31:54 MANAGEMENT: CMD 'needok 'PROTECTFD' ok'
2016-10-20 18:31:54 UDP link local: (not bound)
2016-10-20 18:31:54 UDP link remote: [AF_INET]71.19.249.195:443
2016-10-20 18:31:54 MANAGEMENT: >STATE:1477006314,WAIT,,,,,,
2016-10-20 18:31:54 read UDP [ECONNREFUSED]: Connection refused (code=111)
2016-10-20 18:31:56 read UDP [ECONNREFUSED]: Connection refused (code=111)
2016-10-20 18:32:01 read UDP [ECONNREFUSED]: Connection refused (code=111)
2016-10-20 18:32:10 read UDP [ECONNREFUSED]: Connection refused (code=111)
2016-10-20 18:32:25 read UDP [ECONNREFUSED]: Connection refused (code=111)
2016-10-20 18:32:54 TLS Error: TLS key negotiation failed to occur within 60 seconds (check your network connectivity)
2016-10-20 18:32:54 TLS Error: TLS handshake failed
2016-10-20 18:32:54 TCP/UDP: Closing socket
2016-10-20 18:32:54 SIGUSR1[soft,tls-error] received, process restarting
2016-10-20 18:32:54 MANAGEMENT: >STATE:1477006374,RECONNECTING,tls-error,,,,,
2016-10-20 18:32:56 MANAGEMENT: CMD 'hold release'
2016-10-20 18:32:56 MANAGEMENT: CMD 'proxy NONE'
2016-10-20 18:32:56 MANAGEMENT: CMD 'bytecount 2'
2016-10-20 18:32:56 MANAGEMENT: CMD 'state on'
Help please.
This thread is a bit aged, but I'll add what worked for me. I was having connection refused issue on a Nexus 5 and Samsung Tab S using OpenVPN for Android 0.6.63 with an AirVPN Linux UDP 443 profile. The fix for me, was to edit the profile under Routing to uncheck the Bypass VPN for local networks setting.
As a side note, on a Samsung Tab A the profile connects successfully regardless if the Bypass setting is on or off. I have no idea why the difference. All devices are currently running Android 6.0.1.
Thank you for sharing your solution with the community
Staff did sticky a thread in the Eddie Client forum regarding connection refused.
Could you try upgrading to version 0.6.63? Apparently it is using OpenVPN 2.5 already...
13:17 OpenVPN 2.5-icsopenvpn [git:icsopenvpn-d0314998c474c182+] android-14-armeabi-v7a [SSL (OpenSSL)] [LZO] [LZ4] [EPOLL] [MH/PKTINFO] [AEAD] built on Dec 26 201
Also reenable the bypass option after updating.
