Guest Posted ... Did my connection to the server change or something is wrong with it. I went from max 80 ping to 230. Anyone facing the same issue? Quote Share this post Link to post
Tech Jedi Alex 1501 Posted ... Did my connection to the server change Only logs can tell. I herewith request them from you. From line 1, please! Quote Hide Tech Jedi Alex's signature Hide all signatures NOT AN AIRVPN TEAM MEMBER. USE TICKETS FOR PROFESSIONAL SUPPORT. LZ1's New User Guide to AirVPN « Plenty of stuff for advanced users, too! Want to contact me directly? All relevant methods are on my About me page. Share this post Link to post
Guest Posted ... Did my connection to the server change Only logs can tell. I herewith request them from you. From line 1, please!What logs are this and where do i find them? Airvpn gui logs don't seem to have anything relevant. Quote Share this post Link to post
me.moo@posteo.me 80 Posted ... Everything could be relevant. You haven't even told us which server you are using. How do you expect anyone to know anything?The log is under a tab called 'Logs'. Quote Share this post Link to post
Guest Posted ... I already told you the server is Brachium. All i want to know is if anyone notice the problem with the specific server. My ping is the same with all other airvpn servers. Quote Share this post Link to post
me.moo@posteo.me 80 Posted ... I already told you the server is Brachium. Where? Quote Share this post Link to post
Tech Jedi Alex 1501 Posted ... Brachium - Seems to be okay.As far as I know, network infrastructure and peering in ES is far from being good. Airvpn gui logs don't seem to have anything relevant. May we confirm this statement, please? Post your logs from line 1. Quote Hide Tech Jedi Alex's signature Hide all signatures NOT AN AIRVPN TEAM MEMBER. USE TICKETS FOR PROFESSIONAL SUPPORT. LZ1's New User Guide to AirVPN « Plenty of stuff for advanced users, too! Want to contact me directly? All relevant methods are on my About me page. Share this post Link to post
go558a83nk 380 Posted ... unless a server is under super high load nothing about the server itself will change your "ping". ping is a measure of the latency between you and the server. I'm sure you realize there's a lot of internet between you and the server that can change. best practice is to get an idea of the usual route between you and the server and see if that changes from time to time. Quote Share this post Link to post
Guest Posted ... Brachium - Seems to be okay.As far as I know, network infrastructure and peering in ES is far from being good. Airvpn gui logs don't seem to have anything relevant. May we confirm this statement, please? Post your logs from line 1. Sure. Just tell me if i need to connect to the server i have issues or another server and if i need to remove personal info from the logs if they show any. Thanks. I already told you the server is Brachium. Where? Title Quote Share this post Link to post
Tech Jedi Alex 1501 Posted ... Sure. Just tell me if i need to connect to the server i have issues or another server and if i need to remove personal info from the logs if they show any. Thanks You connect, and if you run into the issue you instantly pull the entire logs and paste them here in spoilers. Quote Hide Tech Jedi Alex's signature Hide all signatures NOT AN AIRVPN TEAM MEMBER. USE TICKETS FOR PROFESSIONAL SUPPORT. LZ1's New User Guide to AirVPN « Plenty of stuff for advanced users, too! Want to contact me directly? All relevant methods are on my About me page. Share this post Link to post
Guest Posted ... Connected to brachium and grabbed the logs. Didn't have to wait because ping is bad always this days. I guess my routing to Spain changed for some reason.I 2016.10.21 10:15:28 - Session starting.. 2016.10.21 10:15:29 - IPv6 disabled with packet filtering.I 2016.10.21 10:15:29 - Checking authorization ...! 2016.10.21 10:15:29 - Connecting to Brachium (Spain, Valencia). 2016.10.21 10:15:29 - OpenVPN > OpenVPN 2.3.12 x86_64-w64-mingw32 [sSL (OpenSSL)] [LZO] [iPv6] built on Sep 5 2016. 2016.10.21 10:15:29 - OpenVPN > Windows version 6.2 (Windows 8 or greater) 64bit. 2016.10.21 10:15:29 - OpenVPN > library versions: OpenSSL 1.0.2h 3 May 2016, LZO 2.09. 2016.10.21 10:15:29 - OpenVPN > MANAGEMENT: TCP Socket listening on [AF_INET]127.0.0.1:3100. 2016.10.21 10:15:29 - OpenVPN > Control Channel Authentication: tls-auth using INLINE static key file. 2016.10.21 10:15:29 - OpenVPN > Outgoing Control Channel Authentication: Using 160 bit message hash 'SHA1' for HMAC authentication. 2016.10.21 10:15:29 - OpenVPN > Incoming Control Channel Authentication: Using 160 bit message hash 'SHA1' for HMAC authentication. 2016.10.21 10:15:29 - OpenVPN > Socket Buffers: R=[65536->262144] S=[65536->262144]. 2016.10.21 10:15:29 - OpenVPN > UDPv4 link local: [undef]. 2016.10.21 10:15:29 - OpenVPN > UDPv4 link remote: [AF_INET]95.215.62.91:443. 2016.10.21 10:15:30 - OpenVPN > TLS: Initial packet from [AF_INET]95.215.62.91:443, sid=812bb561 55457f31. 2016.10.21 10:15:30 - OpenVPN > VERIFY OK: depth=1, C=IT, ST=IT, L=Perugia, O=airvpn.org, CN=airvpn.org CA, emailAddress=info@airvpn.org. 2016.10.21 10:15:30 - OpenVPN > Validating certificate key usage. 2016.10.21 10:15:30 - OpenVPN > ++ Certificate has key usage 00a0, expects 00a0. 2016.10.21 10:15:30 - OpenVPN > VERIFY KU OK. 2016.10.21 10:15:30 - OpenVPN > Validating certificate extended key usage. 2016.10.21 10:15:30 - OpenVPN > ++ Certificate has EKU (str) TLS Web Server Authentication, expects TLS Web Server Authentication. 2016.10.21 10:15:30 - OpenVPN > VERIFY EKU OK. 2016.10.21 10:15:30 - OpenVPN > VERIFY OK: depth=0, C=IT, ST=IT, L=Perugia, O=airvpn.org, CN=server, emailAddress=info@airvpn.org. 2016.10.21 10:15:31 - OpenVPN > Data Channel Encrypt: Cipher 'AES-256-CBC' initialized with 256 bit key. 2016.10.21 10:15:31 - OpenVPN > Data Channel Encrypt: Using 160 bit message hash 'SHA1' for HMAC authentication. 2016.10.21 10:15:31 - OpenVPN > Data Channel Decrypt: Cipher 'AES-256-CBC' initialized with 256 bit key. 2016.10.21 10:15:31 - OpenVPN > Data Channel Decrypt: Using 160 bit message hash 'SHA1' for HMAC authentication. 2016.10.21 10:15:31 - OpenVPN > Control Channel: TLSv1.2, cipher TLSv1/SSLv3 DHE-RSA-AES256-GCM-SHA384, 4096 bit RSA. 2016.10.21 10:15:31 - OpenVPN > [server] Peer Connection Initiated with [AF_INET]95.215.62.91:443. 2016.10.21 10:15:33 - OpenVPN > SENT CONTROL [server]: 'PUSH_REQUEST' (status=1). 2016.10.21 10:15:33 - OpenVPN > PUSH: Received control message: 'PUSH_REPLY,redirect-gateway def1 bypass-dhcp,dhcp-option DNS 10.4.0.1,comp-lzo no,route-gateway 10.4.0.1,topology subnet,ping 10,ping-restart 60,ifconfig 10.4.4.90 255.255.0.0'. 2016.10.21 10:15:33 - OpenVPN > OPTIONS IMPORT: timers and/or timeouts modified. 2016.10.21 10:15:33 - OpenVPN > OPTIONS IMPORT: LZO parms modified. 2016.10.21 10:15:33 - OpenVPN > OPTIONS IMPORT: --ifconfig/up options modified. 2016.10.21 10:15:33 - OpenVPN > OPTIONS IMPORT: route options modified. 2016.10.21 10:15:33 - OpenVPN > OPTIONS IMPORT: route-related options modified. 2016.10.21 10:15:33 - OpenVPN > OPTIONS IMPORT: --ip-win32 and/or --dhcp-option options modified. 2016.10.21 10:15:33 - OpenVPN > ROUTE_GATEWAY 192.168.10.254/255.255.255.0 I=10 HWADDR=4c:eb:42:11:2c:13. 2016.10.21 10:15:33 - OpenVPN > do_ifconfig, tt->ipv6=0, tt->did_ifconfig_ipv6_setup=0. 2016.10.21 10:15:33 - OpenVPN > open_tun, tt->ipv6=0. 2016.10.21 10:15:34 - OpenVPN > TAP-WIN32 device [Ethernet 2] opened: \\.\Global\{E074FD2C-3227-4689-97AD-CB049067976C}.tap. 2016.10.21 10:15:34 - OpenVPN > TAP-Windows Driver Version 9.21. 2016.10.21 10:15:34 - OpenVPN > Set TAP-Windows TUN subnet mode network/local/netmask = 10.4.0.0/10.4.4.90/255.255.0.0 [sUCCEEDED]. 2016.10.21 10:15:34 - OpenVPN > Notified TAP-Windows driver to set a DHCP IP/netmask of 10.4.4.90/255.255.0.0 on interface {E074FD2C-3227-4689-97AD-CB049067976C} [DHCP-serv: 10.4.255.254, lease-time: 31536000]. 2016.10.21 10:15:34 - OpenVPN > Successful ARP Flush on interface [17] {E074FD2C-3227-4689-97AD-CB049067976C}. 2016.10.21 10:15:38 - OpenVPN > TEST ROUTES: 1/1 succeeded len=0 ret=1 a=0 u/d=up. 2016.10.21 10:15:38 - OpenVPN > C:\Windows\system32\route.exe ADD 95.215.62.91 MASK 255.255.255.255 192.168.10.254. 2016.10.21 10:15:38 - OpenVPN > ROUTE: CreateIpForwardEntry succeeded with dwForwardMetric1=50 and dwForwardType=4. 2016.10.21 10:15:38 - OpenVPN > Route addition via IPAPI succeeded [adaptive]. 2016.10.21 10:15:38 - OpenVPN > C:\Windows\system32\route.exe ADD 0.0.0.0 MASK 128.0.0.0 10.4.0.1. 2016.10.21 10:15:38 - OpenVPN > ROUTE: CreateIpForwardEntry succeeded with dwForwardMetric1=35 and dwForwardType=4. 2016.10.21 10:15:38 - OpenVPN > Route addition via IPAPI succeeded [adaptive]. 2016.10.21 10:15:38 - OpenVPN > C:\Windows\system32\route.exe ADD 128.0.0.0 MASK 128.0.0.0 10.4.0.1. 2016.10.21 10:15:38 - OpenVPN > ROUTE: CreateIpForwardEntry succeeded with dwForwardMetric1=35 and dwForwardType=4. 2016.10.21 10:15:38 - OpenVPN > Route addition via IPAPI succeeded [adaptive]. 2016.10.21 10:15:38 - Starting Management Interface. 2016.10.21 10:15:38 - OpenVPN > Initialization Sequence Completed. 2016.10.21 10:15:38 - DNS leak protection with packet filtering enabled.I 2016.10.21 10:15:38 - Flushing DNSI 2016.10.21 10:15:38 - Checking routeI 2016.10.21 10:15:40 - Checking DNS! 2016.10.21 10:15:53 - Connected.. 2016.10.21 10:15:53 - OpenVPN > MANAGEMENT: Client connected from [AF_INET]127.0.0.1:3100. 2016.10.21 10:15:53 - OpenVpn Management > >INFO:OpenVPN Management Interface Version 1 -- type 'help' for more info Quote Share this post Link to post
Tech Jedi Alex 1501 Posted ... The first line of my logs is the AirVPN client version... Anyways, why are you even connecting to Brachium? Are there no other options? Practically all of Europe is available Quote Hide Tech Jedi Alex's signature Hide all signatures NOT AN AIRVPN TEAM MEMBER. USE TICKETS FOR PROFESSIONAL SUPPORT. LZ1's New User Guide to AirVPN « Plenty of stuff for advanced users, too! Want to contact me directly? All relevant methods are on my About me page. Share this post Link to post
Guest Posted ... The first line of my logs is the AirVPN client version... Anyways, why are you even connecting to Brachium? Are there no other options? Practically all of Europe is available I connected from another server and cleared the log before connecting to Brachium to show you only the relevant info. I had 10-20 lower ping than any server in EU. I guess something changed because ping to that server is now 4 times what it was. Unfortunately i don't have a traceroute of before.Anw thanks for any help. Quote Share this post Link to post
Staff 10344 Posted ... Did my connection to the server change or something is wrong with it. I went from max 80 ping to 230. Anyone facing the same issue? Did it happen when (if) you upgraded to Eddie 2.11.x beta? Is your system GNU/LInux based? If so: the ping method has changed in Eddie 2.11.5beta for Linux. Just consider, at the moment, the round trip times as relative values. Nothing changes operationally for you in the choice of the "best" server. Kind regards Quote Share this post Link to post
Guest Posted ... Did my connection to the server change or something is wrong with it. I went from max 80 ping to 230. Anyone facing the same issue? Did it happen when (if) you upgraded to Eddie 2.11.x beta? Is your system GNU/LInux based? If so: the ping method has changed in Eddie 2.11.5beta for Linux. Just consider, at the moment, the round trip times as relative values. Nothing changes operationally for you in the choice of the "best" server. Kind regardsI use windows 10 latest 64 bit. It's not related to new client because i have been using it since it was released and ping was fine. Probably something changed from my location to Spain servers. Unfortunately i don't have an old traceroute. Quote Share this post Link to post
