mrtrshll
Eddie not starting minimized in W7
Hi !
As said in the title, Eddie on my system is configured to start with windows and automatically login. But although the checkbox "minimize on tray icon" in preferences is checked, Eddie keeps showing up at windows startup.
Any workaround for this ?
In the Eddie Beta you can check a box called "Start Minimized" and I think that's what you're looking for.
