Not connected, Your IP: 216.73.216.38
slyte
Ensure using AirVPN through Tor
how can i verify that that i am really using airvpn with Tor. I did check 'Tor' under Preferences -> Protocols.
If you are going from your PC-Tor-AirVPN then you can check www.ipleak.net to verify you are on the VPN server
As far as the tor part you can use wireshark to check for tor traffic to make sure you are using that.
