whiskey_76
DNS address not showing up on test
Hey guys,
So pretty much every time I connect to airvpn through the client and I always use ipleak.net to check that im not leaking DNS and everything looks right. I'm using the portable version without mono required on linux. Since last night everytime I go to check on ipleak.net it can find the ip address but it gives an error when it looks for the DNS address. It gives little triangles with exclamation points and says no ip internal error. This is not normal, what is going on? I disabled my script blocker and it still does this. It doesnt leak my real ip anywhere though because I have network lock on and web rtic disabled as always just kinda scratching my head.
Ipleak has been having some issues lately, due to some changes that were implemented I think. Thanks for the notice . You could use the experimental version, as it works with Mono I believe.
Hello new to this forum and just recently signed up to AirVpn like whiskey_76 above i always check on ipleak.net to see if i'm leaking all is good never had those yellow triangles using windows 7/64 Bit and using Eddie 2.10.3  bit but today i did get them.When i go to other dnsleak sites all is good.Should i be using another client or is this an issue that will be fixed?
Thanks in advance
Thanks in advance
Welcome to AirVPN !
You can count on Air fixing the issue - especially if many are having it. I've checked and I get the same issue, in the DNS field. Your client is fine, it's just that changes were recently added to ipleak and the site is run by Air .
