Running a server on my network with windows 10 and AirVPN software running. This is my media server and the main reason I have AirVPN is because my ISP (mobile broadband) uses double NAT which make remote access difficult.
With the VPN connected when browsing the web I get very slow responses. Using the AirVPN speed checker within the Client section shows 20.59 (out-tunnel) and 0.09 (in-tunnel) for download and 8.66 (out-tunnel) and 4.89 (in-tunnel) for upload.
Other devices on the network which do no go through VPN get 20mb/s all day long and normally much more.
The unusual thing however is that I can remotely access my media using Plex with no issues in speed. Also no issues with  remote VNC either.
This is a stab in the dark, but perhaps you should try a different TAP driver. Check the troubleshooting forum . You might also want to take a look at some remote port forwarding, if applicable in your situation.
