Having troubles connecting. I'm unable to connect to any servers for the last few days, other than a period last night when I managed to connect  to one server.
My internet connection is fine and working, I've tried reinstalling the openvpn software, restarting computer/router etc.
It will get to the stage of 'checking route', then disconnect.  Sometimes the message "The underlying connection was closed: An unexpected error occurred on a send" will pop up.
I have pasted the log below.  Any help would be great,  thanks!
2016.09.13 17:45:54 - Session starting.
I 2016.09.13 17:45:55 - Checking authorization ...
! 2016.09.13 17:45:56 - Connecting to Persei (United States, Fremont, California)
. 2016.09.13 17:45:56 - OpenVPN > OpenVPN 2.3.6 i686-w64-mingw32 [sSL (OpenSSL)] [LZO] [iPv6] built on Jun  5 2015
. 2016.09.13 17:45:56 - OpenVPN > library versions: OpenSSL 1.0.2a 19 Mar 2015, LZO 2.08
. 2016.09.13 17:45:56 - OpenVPN > MANAGEMENT: TCP Socket listening on [AF_INET]127.0.0.1:3101
. 2016.09.13 17:45:56 - OpenVPN > Control Channel Authentication: tls-auth using INLINE static key file
. 2016.09.13 17:45:56 - OpenVPN > Outgoing Control Channel Authentication: Using 160 bit message hash 'SHA1' for HMAC authentication
. 2016.09.13 17:45:56 - OpenVPN > Incoming Control Channel Authentication: Using 160 bit message hash 'SHA1' for HMAC authentication
. 2016.09.13 17:45:56 - OpenVPN > Socket Buffers: R=[8192->131072] S=[8192->131072]
. 2016.09.13 17:45:56 - OpenVPN > UDPv4 link local: [undef]
. 2016.09.13 17:45:56 - OpenVPN > UDPv4 link remote: [AF_INET]94.100.23.162:443
. 2016.09.13 17:45:57 - OpenVPN > TLS: Initial packet from [AF_INET]94.100.23.162:443, sid=5873b72b ef37c24e
. 2016.09.13 17:45:57 - OpenVPN > VERIFY OK: depth=1, C=IT, ST=IT, L=Perugia, O=airvpn.org, CN=airvpn.org CA, emailAddress=info@airvpn.org
. 2016.09.13 17:45:57 - OpenVPN > Validating certificate key usage
. 2016.09.13 17:45:57 - OpenVPN > ++ Certificate has key usage  00a0, expects 00a0
. 2016.09.13 17:45:57 - OpenVPN > VERIFY KU OK
. 2016.09.13 17:45:57 - OpenVPN > Validating certificate extended key usage
. 2016.09.13 17:45:57 - OpenVPN > ++ Certificate has EKU (str) TLS Web Server Authentication, expects TLS Web Server Authentication
. 2016.09.13 17:45:57 - OpenVPN > VERIFY EKU OK
. 2016.09.13 17:45:57 - OpenVPN > VERIFY OK: depth=0, C=IT, ST=IT, L=Perugia, O=airvpn.org, CN=server, emailAddress=info@airvpn.org
. 2016.09.13 17:45:59 - OpenVPN > Data Channel Encrypt: Cipher 'AES-256-CBC' initialized with 256 bit key
. 2016.09.13 17:45:59 - OpenVPN > Data Channel Encrypt: Using 160 bit message hash 'SHA1' for HMAC authentication
. 2016.09.13 17:45:59 - OpenVPN > Data Channel Decrypt: Cipher 'AES-256-CBC' initialized with 256 bit key
. 2016.09.13 17:45:59 - OpenVPN > Data Channel Decrypt: Using 160 bit message hash 'SHA1' for HMAC authentication
. 2016.09.13 17:45:59 - OpenVPN > Control Channel: TLSv1, cipher TLSv1/SSLv3 DHE-RSA-AES256-SHA, 4096 bit RSA
. 2016.09.13 17:45:59 - OpenVPN > [server] Peer Connection Initiated with [AF_INET]94.100.23.162:443
. 2016.09.13 17:46:01 - OpenVPN > SENT CONTROL [server]: 'PUSH_REQUEST' (status=1)
. 2016.09.13 17:46:02 - OpenVPN > PUSH: Received control message: 'PUSH_REPLY,redirect-gateway def1 bypass-dhcp,dhcp-option DNS 10.4.0.1,comp-lzo no,route-gateway 10.4.0.1,topology subnet,ping 10,ping-restart 60,ifconfig 10.4.4.124 255.255.0.0'
. 2016.09.13 17:46:02 - OpenVPN > OPTIONS IMPORT: timers and/or timeouts modified
. 2016.09.13 17:46:02 - OpenVPN > OPTIONS IMPORT: LZO parms modified
. 2016.09.13 17:46:02 - OpenVPN > OPTIONS IMPORT: --ifconfig/up options modified
. 2016.09.13 17:46:02 - OpenVPN > OPTIONS IMPORT: route options modified
. 2016.09.13 17:46:02 - OpenVPN > OPTIONS IMPORT: route-related options modified
. 2016.09.13 17:46:02 - OpenVPN > OPTIONS IMPORT: --ip-win32 and/or --dhcp-option options modified
. 2016.09.13 17:46:02 - OpenVPN > do_ifconfig, tt->ipv6=0, tt->did_ifconfig_ipv6_setup=0
. 2016.09.13 17:46:02 - OpenVPN > open_tun, tt->ipv6=0
. 2016.09.13 17:46:02 - OpenVPN > TAP-WIN32 device [Local Area Connection 6] opened: \\.\Global\{F4F7DBD7-0689-4559-8EAF-DC8DCC1C5170}.tap
. 2016.09.13 17:46:02 - OpenVPN > TAP-Windows Driver Version 9.9
. 2016.09.13 17:46:02 - OpenVPN > Set TAP-Windows TUN subnet mode network/local/netmask = 10.4.0.0/10.4.4.124/255.255.0.0 [sUCCEEDED]
. 2016.09.13 17:46:02 - OpenVPN > Notified TAP-Windows driver to set a DHCP IP/netmask of 10.4.4.124/255.255.0.0 on interface {F4F7DBD7-0689-4559-8EAF-DC8DCC1C5170} [DHCP-serv: 10.4.255.254, lease-time: 31536000]
. 2016.09.13 17:46:02 - OpenVPN > Successful ARP Flush on interface [3] {F4F7DBD7-0689-4559-8EAF-DC8DCC1C5170}
. 2016.09.13 17:46:07 - OpenVPN > TEST ROUTES: 1/1 succeeded len=0 ret=1 a=0 u/d=up
. 2016.09.13 17:46:07 - OpenVPN > C:\WINDOWS\system32\route.exe ADD 94.100.23.162 MASK 255.255.255.255 192.168.1.1
. 2016.09.13 17:46:07 - OpenVPN > Route addition via IPAPI succeeded [adaptive]
. 2016.09.13 17:46:07 - OpenVPN > C:\WINDOWS\system32\route.exe ADD 192.168.1.1 MASK 255.255.255.255 192.168.1.1 IF 2
. 2016.09.13 17:46:07 - OpenVPN > C:\WINDOWS\system32\route.exe ADD 0.0.0.0 MASK 128.0.0.0 10.4.0.1
. 2016.09.13 17:46:07 - OpenVPN > C:\WINDOWS\system32\route.exe ADD 128.0.0.0 MASK 128.0.0.0 10.4.0.1
. 2016.09.13 17:46:07 - Starting Management Interface
. 2016.09.13 17:46:07 - OpenVPN > Initialization Sequence Completed
I 2016.09.13 17:46:07 - DNS of a network adapter forced (Realtek RTL8168/8111 PCI-E Gigabit Ethernet NIC - Packet Scheduler Miniport)
I 2016.09.13 17:46:07 - DNS of a network adapter forced (TAP-Windows Adapter V9 - Packet Scheduler Miniport)
I 2016.09.13 17:46:07 - Flushing DNS
I 2016.09.13 17:46:07 - Checking route
W 2016.09.13 17:46:11 - The underlying connection was closed: An unexpected error occurred on a send.
! 2016.09.13 17:46:11 - Disconnecting
. 2016.09.13 17:46:11 - Management - Send 'signal SIGTERM'
. 2016.09.13 17:46:11 - OpenVPN > MANAGEMENT: CMD 'signal SIGTERM'
. 2016.09.13 17:46:11 - OpenVPN > SIGTERM received, sending exit notification to peer
. 2016.09.13 17:46:11 - OpenVpn Management > >INFO:OpenVPN Management Interface Version 1 -- type 'help' for more info
. 2016.09.13 17:46:11 - OpenVpn Management > SUCCESS: signal SIGTERM thrown
. 2016.09.13 17:46:16 - OpenVPN > C:\WINDOWS\system32\route.exe DELETE 94.100.23.162 MASK 255.255.255.255 192.168.1.1
. 2016.09.13 17:46:16 - OpenVPN > Route deletion via IPAPI succeeded [adaptive]
. 2016.09.13 17:46:16 - OpenVPN > C:\WINDOWS\system32\route.exe DELETE 192.168.1.1 MASK 255.255.255.255 192.168.1.1
. 2016.09.13 17:46:16 - OpenVPN > C:\WINDOWS\system32\route.exe DELETE 0.0.0.0 MASK 128.0.0.0 10.4.0.1
. 2016.09.13 17:46:16 - OpenVPN > C:\WINDOWS\system32\route.exe DELETE 128.0.0.0 MASK 128.0.0.0 10.4.0.1
. 2016.09.13 17:46:16 - OpenVPN > Closing TUN/TAP interface
. 2016.09.13 17:46:16 - OpenVPN > SIGTERM[soft,exit-with-notification] received, process exiting
. 2016.09.13 17:46:16 - Connection terminated.
I 2016.09.13 17:46:17 - DNS of a network adapter restored to original settings (Realtek RTL8168/8111 PCI-E Gigabit Ethernet NIC - Packet Scheduler Miniport)
I 2016.09.13 17:46:17 - DNS of a network adapter restored to original settings (TAP-Windows Adapter V9 - Packet Scheduler Miniport)
I 2016.09.13 17:46:20 - Checking authorization ...
! 2016.09.13 17:46:21 - Connecting to Yed (Hong Kong, Hong Kong)
