duconlajoie 1 Posted ... Hello, I get 0.0000 Mbs with speedtest, is that normal ? Down: 11.520 Mbit/s Out, 0.000 Mbit/s In (0%), 20MB - Up: 0.624 Mbit/s Out, 0.000 Mbit/s In (0%), 1MB - Date: Sun, 11 Sep 2016 22:47:16 GMT - Buffers: 20MB/1MB - Laps: 3, Time: 76.80 secs In reality have around 2-20kbs. (i use last charlie) Quote Share this post Link to post
Tech Jedi Alex 1515 Posted ... Turn off NoScript's Application Boundaries Enforcer. And use another speedtest, AirVPN's is very inaccurate most of the time. Quote Hide Tech Jedi Alex's signature Hide all signatures NOT AN AIRVPN TEAM MEMBER. USE TICKETS FOR PROFESSIONAL SUPPORT. LZ1's New User Guide to AirVPN « Plenty of stuff for advanced users, too! Want to contact me directly? All relevant methods are on my About me page. Share this post Link to post
duconlajoie 1 Posted ... I already turn off NoScript Anyway i did a speedtest.net on a browser without any protection : But why don't I have really have this ? Is the VPN test or my real connection ? Thank you. Quote Share this post Link to post
Tech Jedi Alex 1515 Posted ... I already turn off NoScript Just turned off JavaScript blocking or completely disabled it? Because NoScript's protective features like ABE, ClearClick and others can work on their own with JavaScript blocking turned off. But why don't I have really have this ? Is the VPN test or my real connection ? Try other servers, ports and/or protocols. Quote Hide Tech Jedi Alex's signature Hide all signatures NOT AN AIRVPN TEAM MEMBER. USE TICKETS FOR PROFESSIONAL SUPPORT. LZ1's New User Guide to AirVPN « Plenty of stuff for advanced users, too! Want to contact me directly? All relevant methods are on my About me page. Share this post Link to post
duconlajoie 1 Posted ... I already turn off NoScript Just turned off JavaScript blocking or completely disabled it? Because NoScript's protective features like ABE, ClearClick and others can work on their own with JavaScript blocking turned off. I only allow airvpn.org.. But why don't I have really have this ? Is the VPN test or my real connection ? Try other servers, ports and/or protocols. OK, thank you, i just try a few port (in 4 days i have try many servers with all the time same slow speed). Do i have to disconnect/connect after i change ports or protocols ? Quote Share this post Link to post
go558a83nk 382 Posted ... I already turn off NoScript Just turned off JavaScript blocking or completely disabled it? Because NoScript's protective features like ABE, ClearClick and others can work on their own with JavaScript blocking turned off. I only allow airvpn.org.. > But why don't I have really have this ? Is the VPN test or my real connection ? Try other servers, ports and/or protocols. OK, thank you, i just try a few port (in 4 days i have try many servers with all the time same slow speed). Do i have to disconnect/connect after i change ports or protocols ? AirVPN speed test may use another domain other than airvpn.org. Only allowing airvpn.org may not be enough for the speed test to work. yes, you must disconnect and reconnect to begin using a different port/protocol. Quote Share this post Link to post
Tech Jedi Alex 1515 Posted ... I only allow airvpn.org.. It means you allowed script execution on airvpn.org. ABE is still enabled and causing your problems with this speed test. Disable NoScript. It will ask you to only allow all scripts, press the other button. Quote Hide Tech Jedi Alex's signature Hide all signatures NOT AN AIRVPN TEAM MEMBER. USE TICKETS FOR PROFESSIONAL SUPPORT. LZ1's New User Guide to AirVPN « Plenty of stuff for advanced users, too! Want to contact me directly? All relevant methods are on my About me page. Share this post Link to post
duconlajoie 1 Posted ... Hello! My internet box was redirect torrent to 25 port and no idea whats this spamflter oes, your client area didn't know neither Since i remove it look like it work, but so fluctuate, sometimes my VPN rules, sometimes only one picture 640x480 on twitter fail 5 times.. Is that VPN rules have to accept ? If yes ok i just leave. Thank you for answer, more 40 days i try to configure it. Quote Share this post Link to post
zhang888 1067 Posted ... Port 25 is blocked to prevent unauthenticated SMTP spam. It's the only port that is blocked.Change your torrent port to another high port, running it on port 25 is a bad idea in any case,since many ISPs filter it as well or at least require valid SMTP headers on it, so you are goingto lose many potential peers. Quote Hide zhang888's signature Hide all signatures Occasional moderator, sometimes BOFH. Opinions are my own, except when my wife disagrees. Share this post Link to post
