I have a problem. Sometimes when using a particular server my openvpn client terminates due to the error "AUTH: Received control message: AUTH_FAILED". Just before that it states: "SENT CONTROL [server]: 'PUSH_REQUEST' (status=1)"
​I looked at the server status log and it seems it has some packet loss (up to 60%) now and then. But I don't understand why that would give this "AUTH_FAILED".
It would be helpful if you could share the complete logs. However if, as I understand it, the server you're connected to has high packet loss, why don't you try and change server to see if anything improves? . If there's package loss, then the communication between your client and the server is probably getting disrupted and hence you get errors; that's my take anyway, haha.
I wonder why you don't use Eddie, but that's just me being curious.
