5xhs8i3o9v
Network Lock Broken in 2.11.3?
​Hi, I'm using 2.11.3 and have Network Lock enabled. When I disconnect from AirVPN, I ​cannot access google.com from a web browser. However, when I open a command prompt (Windows 8), I can ping google.com and get replies. This happens even when the client states that Network Lock is activated. Is this a known problem or am I doing something wrong?
Hello msl,
Unfortunately I cannot confirm the error you are having; the network lock feature block everything for me, including cmd pings in the newest experimental version. I'm using the filtering platform method. What are you using?
Hi techdude, thanks for the help. Automatic mode. In fact, with Network Lock "on," I can also now browse the web--it seems to not be working at all.
