magnet2
Split from Eddie 2.11.3
I am on Windows 10, no IPv6, I do have DNS leaks.
I couldn't find some of the settings you are referring to into the first message:
- Settings -> Advanced -> Force all network interfaces for DNS: DISABLED
- Settings -> Advanced -> Ensure DNS lock: enabled
- Settings -> Advanced -> WFP: enabled
Anyway I left every setting at default.
Here are logs:
I 2016.08.24 10:33:49 - AirVPN client version: 2.10.3 / x64, System: Windows, Name: Microsoft Windows NT 6.2.9200.0 / x64
. 2016.08.24 10:33:49 - Reading options from C:\Users\Maurizio\AppData\Local\AirVPN\AirVPN.xml
. 2016.08.24 10:33:49 - Data Path: C:\Users\Maurizio\AppData\Local\AirVPN
. 2016.08.24 10:33:49 - App Path: C:\Program Files\AirVPN
. 2016.08.24 10:33:49 - Executable Path: C:\Program Files\AirVPN\AirVPN.exe
. 2016.08.24 10:33:49 - Command line arguments (1): path="home"
. 2016.08.24 10:33:49 - Operating System: Microsoft Windows NT 6.2.9200.0
. 2016.08.24 10:33:49 - Updating systems & servers data ...
. 2016.08.24 10:33:49 - Cannot find tunnel adapter.
E 2016.08.24 10:33:49 - OpenVPN Driver - Not available
I 2016.08.24 10:33:49 - OpenVPN - Version: OpenVPN 2.3.8 (C:\Program Files\AirVPN\openvpn.exe)
I 2016.08.24 10:33:49 - SSH - Version: plink 0.63 (C:\Program Files\AirVPN\plink.exe)
I 2016.08.24 10:33:49 - SSL - Version: stunnel 5.17 (C:\Program Files\AirVPN\stunnel.exe)
! 2016.08.24 10:33:49 - Ready
. 2016.08.24 10:33:50 - Systems & servers data update completed
. 2016.08.24 10:34:14 - Updating systems & servers data ...
. 2016.08.24 10:34:14 - Systems & servers data update completed
I 2016.08.24 10:34:52 - Checking login ...
! 2016.08.24 10:34:52 - Logged in.
I 2016.08.24 10:34:57 - Session starting.
. 2016.08.24 10:34:57 - Cannot find tunnel adapter.
! 2016.08.24 10:34:57 - Installing tunnel driver
I 2016.08.24 10:35:08 - IPv6 disabled.
I 2016.08.24 10:35:08 - Checking authorization ...
! 2016.08.24 10:35:08 - Connecting to Celaeno (Netherlands, Alblasserdam)
. 2016.08.24 10:35:09 - OpenVPN > OpenVPN 2.3.8 x86_64-w64-mingw32 [sSL (OpenSSL)] [LZO] [iPv6] built on Aug 13 2015
. 2016.08.24 10:35:09 - OpenVPN > library versions: OpenSSL 1.0.2d 9 Jul 2015, LZO 2.08
. 2016.08.24 10:35:09 - OpenVPN > MANAGEMENT: TCP Socket listening on [AF_INET]127.0.0.1:3100
. 2016.08.24 10:35:09 - OpenVPN > Control Channel Authentication: tls-auth using INLINE static key file
. 2016.08.24 10:35:09 - OpenVPN > Outgoing Control Channel Authentication: Using 160 bit message hash 'SHA1' for HMAC authentication
. 2016.08.24 10:35:09 - OpenVPN > Incoming Control Channel Authentication: Using 160 bit message hash 'SHA1' for HMAC authentication
. 2016.08.24 10:35:09 - OpenVPN > Socket Buffers: R=[65536->131072] S=[65536->131072]
. 2016.08.24 10:35:09 - OpenVPN > UDPv4 link local: [undef]
. 2016.08.24 10:35:09 - OpenVPN > UDPv4 link remote: [AF_INET]213.152.161.68:443
. 2016.08.24 10:35:09 - OpenVPN > TLS: Initial packet from [AF_INET]213.152.161.68:443, sid=4ebac905 03883f47
. 2016.08.24 10:35:09 - OpenVPN > VERIFY OK: depth=1, C=IT, ST=IT, L=Perugia, O=airvpn.org, CN=airvpn.org CA, emailAddress=info@airvpn.org
. 2016.08.24 10:35:09 - OpenVPN > Validating certificate key usage
. 2016.08.24 10:35:09 - OpenVPN > ++ Certificate has key usage  00a0, expects 00a0
. 2016.08.24 10:35:09 - OpenVPN > VERIFY KU OK
. 2016.08.24 10:35:09 - OpenVPN > Validating certificate extended key usage
. 2016.08.24 10:35:09 - OpenVPN > ++ Certificate has EKU (str) TLS Web Server Authentication, expects TLS Web Server Authentication
. 2016.08.24 10:35:09 - OpenVPN > VERIFY EKU OK
. 2016.08.24 10:35:09 - OpenVPN > VERIFY OK: depth=0, C=IT, ST=IT, L=Perugia, O=airvpn.org, CN=server, emailAddress=info@airvpn.org
. 2016.08.24 10:35:09 - OpenVPN > Data Channel Encrypt: Cipher 'AES-256-CBC' initialized with 256 bit key
. 2016.08.24 10:35:09 - OpenVPN > Data Channel Encrypt: Using 160 bit message hash 'SHA1' for HMAC authentication
. 2016.08.24 10:35:09 - OpenVPN > Data Channel Decrypt: Cipher 'AES-256-CBC' initialized with 256 bit key
. 2016.08.24 10:35:09 - OpenVPN > Data Channel Decrypt: Using 160 bit message hash 'SHA1' for HMAC authentication
. 2016.08.24 10:35:09 - OpenVPN > Control Channel: TLSv1.2, cipher TLSv1/SSLv3 DHE-RSA-AES256-GCM-SHA384, 4096 bit RSA
. 2016.08.24 10:35:09 - OpenVPN > [server] Peer Connection Initiated with [AF_INET]213.152.161.68:443
. 2016.08.24 10:35:12 - OpenVPN > SENT CONTROL [server]: 'PUSH_REQUEST' (status=1)
. 2016.08.24 10:35:12 - OpenVPN > PUSH: Received control message: 'PUSH_REPLY,redirect-gateway def1 bypass-dhcp,dhcp-option DNS 10.4.0.1,comp-lzo no,route-gateway 10.4.0.1,topology subnet,ping 10,ping-restart 60,ifconfig 10.4.76.10 255.255.0.0'
. 2016.08.24 10:35:12 - OpenVPN > OPTIONS IMPORT: timers and/or timeouts modified
. 2016.08.24 10:35:12 - OpenVPN > OPTIONS IMPORT: LZO parms modified
. 2016.08.24 10:35:12 - OpenVPN > OPTIONS IMPORT: --ifconfig/up options modified
. 2016.08.24 10:35:12 - OpenVPN > OPTIONS IMPORT: route options modified
. 2016.08.24 10:35:12 - OpenVPN > OPTIONS IMPORT: route-related options modified
. 2016.08.24 10:35:12 - OpenVPN > OPTIONS IMPORT: --ip-win32 and/or --dhcp-option options modified
. 2016.08.24 10:35:12 - OpenVPN > do_ifconfig, tt->ipv6=0, tt->did_ifconfig_ipv6_setup=0
. 2016.08.24 10:35:12 - OpenVPN > open_tun, tt->ipv6=0
. 2016.08.24 10:35:12 - OpenVPN > TAP-WIN32 device [Ethernet 3] opened: \\.\Global\{3B5251B0-000A-481D-875B-0E6C3C710727}.tap
. 2016.08.24 10:35:12 - OpenVPN > TAP-Windows Driver Version 9.21
. 2016.08.24 10:35:12 - OpenVPN > Set TAP-Windows TUN subnet mode network/local/netmask = 10.4.0.0/10.4.76.10/255.255.0.0 [sUCCEEDED]
. 2016.08.24 10:35:12 - OpenVPN > Notified TAP-Windows driver to set a DHCP IP/netmask of 10.4.76.10/255.255.0.0 on interface {3B5251B0-000A-481D-875B-0E6C3C710727} [DHCP-serv: 10.4.255.254, lease-time: 31536000]
. 2016.08.24 10:35:12 - OpenVPN > Successful ARP Flush on interface [34] {3B5251B0-000A-481D-875B-0E6C3C710727}
. 2016.08.24 10:35:17 - OpenVPN > TEST ROUTES: 1/1 succeeded len=0 ret=1 a=0 u/d=up
. 2016.08.24 10:35:17 - OpenVPN > C:\WINDOWS\system32\route.exe ADD 213.152.161.68 MASK 255.255.255.255 192.168.0.1
. 2016.08.24 10:35:17 - OpenVPN > ROUTE: CreateIpForwardEntry succeeded with dwForwardMetric1=25 and dwForwardType=4
. 2016.08.24 10:35:17 - OpenVPN > Route addition via IPAPI succeeded [adaptive]
. 2016.08.24 10:35:17 - OpenVPN > C:\WINDOWS\system32\route.exe ADD 192.168.0.1 MASK 255.255.255.255 192.168.0.1 IF 2
. 2016.08.24 10:35:17 - OpenVPN > C:\WINDOWS\system32\route.exe ADD 0.0.0.0 MASK 128.0.0.0 10.4.0.1
. 2016.08.24 10:35:17 - OpenVPN > ROUTE: CreateIpForwardEntry succeeded with dwForwardMetric1=20 and dwForwardType=4
. 2016.08.24 10:35:17 - OpenVPN > C:\WINDOWS\system32\route.exe ADD 128.0.0.0 MASK 128.0.0.0 10.4.0.1
. 2016.08.24 10:35:17 - Starting Management Interface
. 2016.08.24 10:35:17 - OpenVPN > Initialization Sequence Completed
I 2016.08.24 10:35:17 - DNS of a network adapter forced (Intel® Centrino® Advanced-N 6235)
I 2016.08.24 10:35:17 - DNS of a network adapter forced (TAP-Windows Adapter V9)
I 2016.08.24 10:35:17 - Flushing DNS
I 2016.08.24 10:35:17 - Checking route
I 2016.08.24 10:35:17 - Checking DNS
! 2016.08.24 10:35:17 - Connected.
. 2016.08.24 10:35:17 - OpenVPN > MANAGEMENT: Client connected from [AF_INET]127.0.0.1:3100
. 2016.08.24 10:35:17 - OpenVpn Management > >INFO:OpenVPN Management Interface Version 1 -- type 'help' for more info
! 2016.08.24 10:39:42 - Disconnecting
. 2016.08.24 10:39:42 - Management - Send 'signal SIGTERM'
. 2016.08.24 10:39:42 - OpenVPN > MANAGEMENT: CMD 'signal SIGTERM'
. 2016.08.24 10:39:42 - OpenVPN > SIGTERM received, sending exit notification to peer
. 2016.08.24 10:39:47 - OpenVPN > C:\WINDOWS\system32\route.exe DELETE 213.152.161.68 MASK 255.255.255.255 192.168.0.1
. 2016.08.24 10:39:47 - OpenVPN > Route deletion via IPAPI succeeded [adaptive]
. 2016.08.24 10:39:47 - OpenVPN > C:\WINDOWS\system32\route.exe DELETE 192.168.0.1 MASK 255.255.255.255 192.168.0.1
. 2016.08.24 10:39:47 - OpenVPN > C:\WINDOWS\system32\route.exe DELETE 0.0.0.0 MASK 128.0.0.0 10.4.0.1
. 2016.08.24 10:39:47 - OpenVPN > C:\WINDOWS\system32\route.exe DELETE 128.0.0.0 MASK 128.0.0.0 10.4.0.1
. 2016.08.24 10:39:47 - OpenVPN > Closing TUN/TAP interface
. 2016.08.24 10:39:47 - OpenVPN > SIGTERM[soft,exit-with-notification] received, process exiting
. 2016.08.24 10:39:47 - Connection terminated.
I 2016.08.24 10:39:47 - DNS of a network adapter restored to original settings (Intel® Centrino® Advanced-N 6235)
I 2016.08.24 10:39:47 - DNS of a network adapter restored to original settings (TAP-Windows Adapter V9)
I 2016.08.24 10:39:47 - IPv6 restored.
! 2016.08.24 10:39:47 - Session terminated.
I 2016.08.24 10:41:17 - Session starting.
I 2016.08.24 10:41:18 - IPv6 disabled.
I 2016.08.24 10:41:18 - Checking authorization ...
! 2016.08.24 10:41:18 - Connecting to Rastaban (Sweden, Uppsala)
. 2016.08.24 10:41:18 - OpenVPN > OpenVPN 2.3.8 x86_64-w64-mingw32 [sSL (OpenSSL)] [LZO] [iPv6] built on Aug 13 2015
. 2016.08.24 10:41:18 - OpenVPN > library versions: OpenSSL 1.0.2d 9 Jul 2015, LZO 2.08
. 2016.08.24 10:41:18 - OpenVPN > MANAGEMENT: TCP Socket listening on [AF_INET]127.0.0.1:3100
. 2016.08.24 10:41:18 - OpenVPN > Control Channel Authentication: tls-auth using INLINE static key file
. 2016.08.24 10:41:18 - OpenVPN > Outgoing Control Channel Authentication: Using 160 bit message hash 'SHA1' for HMAC authentication
. 2016.08.24 10:41:18 - OpenVPN > Incoming Control Channel Authentication: Using 160 bit message hash 'SHA1' for HMAC authentication
. 2016.08.24 10:41:18 - OpenVPN > Socket Buffers: R=[65536->131072] S=[65536->131072]
. 2016.08.24 10:41:18 - OpenVPN > UDPv4 link local: [undef]
. 2016.08.24 10:41:18 - OpenVPN > UDPv4 link remote: [AF_INET]62.102.148.135:443
. 2016.08.24 10:41:18 - OpenVPN > TLS: Initial packet from [AF_INET]62.102.148.135:443, sid=9315b141 bc2a1c6f
. 2016.08.24 10:41:18 - OpenVPN > VERIFY OK: depth=1, C=IT, ST=IT, L=Perugia, O=airvpn.org, CN=airvpn.org CA, emailAddress=info@airvpn.org
. 2016.08.24 10:41:18 - OpenVPN > Validating certificate key usage
. 2016.08.24 10:41:18 - OpenVPN > ++ Certificate has key usage  00a0, expects 00a0
. 2016.08.24 10:41:18 - OpenVPN > VERIFY KU OK
. 2016.08.24 10:41:18 - OpenVPN > Validating certificate extended key usage
. 2016.08.24 10:41:18 - OpenVPN > ++ Certificate has EKU (str) TLS Web Server Authentication, expects TLS Web Server Authentication
. 2016.08.24 10:41:18 - OpenVPN > VERIFY EKU OK
. 2016.08.24 10:41:18 - OpenVPN > VERIFY OK: depth=0, C=IT, ST=IT, L=Perugia, O=airvpn.org, CN=server, emailAddress=info@airvpn.org
. 2016.08.24 10:41:19 - OpenVPN > Data Channel Encrypt: Cipher 'AES-256-CBC' initialized with 256 bit key
. 2016.08.24 10:41:19 - OpenVPN > Data Channel Encrypt: Using 160 bit message hash 'SHA1' for HMAC authentication
. 2016.08.24 10:41:19 - OpenVPN > Data Channel Decrypt: Cipher 'AES-256-CBC' initialized with 256 bit key
. 2016.08.24 10:41:19 - OpenVPN > Data Channel Decrypt: Using 160 bit message hash 'SHA1' for HMAC authentication
. 2016.08.24 10:41:19 - OpenVPN > Control Channel: TLSv1.2, cipher TLSv1/SSLv3 DHE-RSA-AES256-GCM-SHA384, 4096 bit RSA
. 2016.08.24 10:41:19 - OpenVPN > [server] Peer Connection Initiated with [AF_INET]62.102.148.135:443
. 2016.08.24 10:41:21 - OpenVPN > SENT CONTROL [server]: 'PUSH_REQUEST' (status=1)
. 2016.08.24 10:41:21 - OpenVPN > PUSH: Received control message: 'PUSH_REPLY,redirect-gateway def1 bypass-dhcp,dhcp-option DNS 10.4.0.1,comp-lzo no,route-gateway 10.4.0.1,topology subnet,ping 10,ping-restart 60,ifconfig 10.4.59.139 255.255.0.0'
. 2016.08.24 10:41:21 - OpenVPN > OPTIONS IMPORT: timers and/or timeouts modified
. 2016.08.24 10:41:21 - OpenVPN > OPTIONS IMPORT: LZO parms modified
. 2016.08.24 10:41:21 - OpenVPN > OPTIONS IMPORT: --ifconfig/up options modified
. 2016.08.24 10:41:21 - OpenVPN > OPTIONS IMPORT: route options modified
. 2016.08.24 10:41:21 - OpenVPN > OPTIONS IMPORT: route-related options modified
. 2016.08.24 10:41:21 - OpenVPN > OPTIONS IMPORT: --ip-win32 and/or --dhcp-option options modified
. 2016.08.24 10:41:21 - OpenVPN > do_ifconfig, tt->ipv6=0, tt->did_ifconfig_ipv6_setup=0
. 2016.08.24 10:41:21 - OpenVPN > open_tun, tt->ipv6=0
. 2016.08.24 10:41:21 - OpenVPN > TAP-WIN32 device [Ethernet 3] opened: \\.\Global\{3B5251B0-000A-481D-875B-0E6C3C710727}.tap
. 2016.08.24 10:41:21 - OpenVPN > TAP-Windows Driver Version 9.21
. 2016.08.24 10:41:21 - OpenVPN > Set TAP-Windows TUN subnet mode network/local/netmask = 10.4.0.0/10.4.59.139/255.255.0.0 [sUCCEEDED]
. 2016.08.24 10:41:21 - OpenVPN > Notified TAP-Windows driver to set a DHCP IP/netmask of 10.4.59.139/255.255.0.0 on interface {3B5251B0-000A-481D-875B-0E6C3C710727} [DHCP-serv: 10.4.255.254, lease-time: 31536000]
. 2016.08.24 10:41:21 - OpenVPN > Successful ARP Flush on interface [34] {3B5251B0-000A-481D-875B-0E6C3C710727}
. 2016.08.24 10:41:26 - OpenVPN > TEST ROUTES: 1/1 succeeded len=0 ret=1 a=0 u/d=up
. 2016.08.24 10:41:26 - OpenVPN > C:\WINDOWS\system32\route.exe ADD 62.102.148.135 MASK 255.255.255.255 192.168.0.1
. 2016.08.24 10:41:26 - OpenVPN > ROUTE: CreateIpForwardEntry succeeded with dwForwardMetric1=25 and dwForwardType=4
. 2016.08.24 10:41:26 - OpenVPN > Route addition via IPAPI succeeded [adaptive]
. 2016.08.24 10:41:26 - OpenVPN > C:\WINDOWS\system32\route.exe ADD 192.168.0.1 MASK 255.255.255.255 192.168.0.1 IF 2
. 2016.08.24 10:41:26 - OpenVPN > C:\WINDOWS\system32\route.exe ADD 0.0.0.0 MASK 128.0.0.0 10.4.0.1
. 2016.08.24 10:41:26 - OpenVPN > ROUTE: CreateIpForwardEntry succeeded with dwForwardMetric1=20 and dwForwardType=4
. 2016.08.24 10:41:26 - OpenVPN > C:\WINDOWS\system32\route.exe ADD 128.0.0.0 MASK 128.0.0.0 10.4.0.1
. 2016.08.24 10:41:26 - Starting Management Interface
. 2016.08.24 10:41:26 - OpenVPN > Initialization Sequence Completed
I 2016.08.24 10:41:26 - DNS of a network adapter forced (Intel® Centrino® Advanced-N 6235)
I 2016.08.24 10:41:26 - DNS of a network adapter forced (TAP-Windows Adapter V9)
I 2016.08.24 10:41:26 - Flushing DNS
I 2016.08.24 10:41:26 - Checking route
I 2016.08.24 10:41:26 - Checking DNS
! 2016.08.24 10:41:26 - Connected.
. 2016.08.24 10:41:26 - OpenVpn Management > >INFO:OpenVPN Management Interface Version 1 -- type 'help' for more info
. 2016.08.24 10:41:26 - OpenVPN > MANAGEMENT: Client connected from [AF_INET]127.0.0.1:3100
! 2016.08.24 10:50:34 - Disconnecting
. 2016.08.24 10:50:34 - Management - Send 'signal SIGTERM'
. 2016.08.24 10:50:34 - OpenVPN > MANAGEMENT: CMD 'signal SIGTERM'
. 2016.08.24 10:50:34 - OpenVPN > SIGTERM received, sending exit notification to peer
. 2016.08.24 10:50:39 - OpenVPN > C:\WINDOWS\system32\route.exe DELETE 62.102.148.135 MASK 255.255.255.255 192.168.0.1
. 2016.08.24 10:50:39 - OpenVPN > Route deletion via IPAPI succeeded [adaptive]
. 2016.08.24 10:50:39 - OpenVPN > C:\WINDOWS\system32\route.exe DELETE 192.168.0.1 MASK 255.255.255.255 192.168.0.1
. 2016.08.24 10:50:39 - OpenVPN > C:\WINDOWS\system32\route.exe DELETE 0.0.0.0 MASK 128.0.0.0 10.4.0.1
. 2016.08.24 10:50:39 - OpenVPN > C:\WINDOWS\system32\route.exe DELETE 128.0.0.0 MASK 128.0.0.0 10.4.0.1
. 2016.08.24 10:50:39 - OpenVPN > Closing TUN/TAP interface
. 2016.08.24 10:50:39 - OpenVPN > SIGTERM[soft,exit-with-notification] received, process exiting
. 2016.08.24 10:50:39 - Connection terminated.
I 2016.08.24 10:50:39 - DNS of a network adapter restored to original settings (Intel® Centrino® Advanced-N 6235)
I 2016.08.24 10:50:39 - DNS of a network adapter restored to original settings (TAP-Windows Adapter V9)
I 2016.08.24 10:50:39 - IPv6 restored.
! 2016.08.24 10:50:39 - Session terminated.
I 2016.08.24 10:51:17 - Session starting.
I 2016.08.24 10:51:17 - IPv6 disabled.
I 2016.08.24 10:51:17 - Checking authorization ...
! 2016.08.24 10:51:17 - Connecting to Benetnasch (Sweden, Uppsala)
. 2016.08.24 10:51:17 - OpenVPN > OpenVPN 2.3.8 x86_64-w64-mingw32 [sSL (OpenSSL)] [LZO] [iPv6] built on Aug 13 2015
. 2016.08.24 10:51:17 - OpenVPN > library versions: OpenSSL 1.0.2d 9 Jul 2015, LZO 2.08
. 2016.08.24 10:51:17 - OpenVPN > MANAGEMENT: TCP Socket listening on [AF_INET]127.0.0.1:3100
. 2016.08.24 10:51:18 - OpenVPN > Control Channel Authentication: tls-auth using INLINE static key file
. 2016.08.24 10:51:18 - OpenVPN > Outgoing Control Channel Authentication: Using 160 bit message hash 'SHA1' for HMAC authentication
. 2016.08.24 10:51:18 - OpenVPN > Incoming Control Channel Authentication: Using 160 bit message hash 'SHA1' for HMAC authentication
. 2016.08.24 10:51:18 - OpenVPN > Socket Buffers: R=[65536->131072] S=[65536->131072]
. 2016.08.24 10:51:18 - OpenVPN > UDPv4 link local: [undef]
. 2016.08.24 10:51:18 - OpenVPN > UDPv4 link remote: [AF_INET]62.102.148.148:443
. 2016.08.24 10:51:18 - OpenVPN > TLS: Initial packet from [AF_INET]62.102.148.148:443, sid=e5e03c37 89580644
. 2016.08.24 10:51:18 - OpenVPN > VERIFY OK: depth=1, C=IT, ST=IT, L=Perugia, O=airvpn.org, CN=airvpn.org CA, emailAddress=info@airvpn.org
. 2016.08.24 10:51:18 - OpenVPN > Validating certificate key usage
. 2016.08.24 10:51:18 - OpenVPN > ++ Certificate has key usage  00a0, expects 00a0
. 2016.08.24 10:51:18 - OpenVPN > VERIFY KU OK
. 2016.08.24 10:51:18 - OpenVPN > Validating certificate extended key usage
. 2016.08.24 10:51:18 - OpenVPN > ++ Certificate has EKU (str) TLS Web Server Authentication, expects TLS Web Server Authentication
. 2016.08.24 10:51:18 - OpenVPN > VERIFY EKU OK
. 2016.08.24 10:51:18 - OpenVPN > VERIFY OK: depth=0, C=IT, ST=IT, L=Perugia, O=airvpn.org, CN=server, emailAddress=info@airvpn.org
. 2016.08.24 10:51:18 - OpenVPN > Data Channel Encrypt: Cipher 'AES-256-CBC' initialized with 256 bit key
. 2016.08.24 10:51:18 - OpenVPN > Data Channel Encrypt: Using 160 bit message hash 'SHA1' for HMAC authentication
. 2016.08.24 10:51:18 - OpenVPN > Data Channel Decrypt: Cipher 'AES-256-CBC' initialized with 256 bit key
. 2016.08.24 10:51:18 - OpenVPN > Data Channel Decrypt: Using 160 bit message hash 'SHA1' for HMAC authentication
. 2016.08.24 10:51:18 - OpenVPN > Control Channel: TLSv1.2, cipher TLSv1/SSLv3 DHE-RSA-AES256-GCM-SHA384, 4096 bit RSA
. 2016.08.24 10:51:18 - OpenVPN > [server] Peer Connection Initiated with [AF_INET]62.102.148.148:443
. 2016.08.24 10:51:20 - OpenVPN > SENT CONTROL [server]: 'PUSH_REQUEST' (status=1)
. 2016.08.24 10:51:20 - OpenVPN > PUSH: Received control message: 'PUSH_REPLY,redirect-gateway def1 bypass-dhcp,dhcp-option DNS 10.4.0.1,comp-lzo no,route-gateway 10.4.0.1,topology subnet,ping 10,ping-restart 60,ifconfig 10.4.24.70 255.255.0.0'
. 2016.08.24 10:51:20 - OpenVPN > OPTIONS IMPORT: timers and/or timeouts modified
. 2016.08.24 10:51:20 - OpenVPN > OPTIONS IMPORT: LZO parms modified
. 2016.08.24 10:51:20 - OpenVPN > OPTIONS IMPORT: --ifconfig/up options modified
. 2016.08.24 10:51:20 - OpenVPN > OPTIONS IMPORT: route options modified
. 2016.08.24 10:51:20 - OpenVPN > OPTIONS IMPORT: route-related options modified
. 2016.08.24 10:51:20 - OpenVPN > OPTIONS IMPORT: --ip-win32 and/or --dhcp-option options modified
. 2016.08.24 10:51:20 - OpenVPN > do_ifconfig, tt->ipv6=0, tt->did_ifconfig_ipv6_setup=0
. 2016.08.24 10:51:20 - OpenVPN > open_tun, tt->ipv6=0
. 2016.08.24 10:51:20 - OpenVPN > TAP-WIN32 device [Ethernet 3] opened: \\.\Global\{3B5251B0-000A-481D-875B-0E6C3C710727}.tap
. 2016.08.24 10:51:20 - OpenVPN > TAP-Windows Driver Version 9.21
. 2016.08.24 10:51:20 - OpenVPN > Set TAP-Windows TUN subnet mode network/local/netmask = 10.4.0.0/10.4.24.70/255.255.0.0 [sUCCEEDED]
. 2016.08.24 10:51:20 - OpenVPN > Notified TAP-Windows driver to set a DHCP IP/netmask of 10.4.24.70/255.255.0.0 on interface {3B5251B0-000A-481D-875B-0E6C3C710727} [DHCP-serv: 10.4.255.254, lease-time: 31536000]
. 2016.08.24 10:51:20 - OpenVPN > Successful ARP Flush on interface [34] {3B5251B0-000A-481D-875B-0E6C3C710727}
. 2016.08.24 10:51:25 - OpenVPN > TEST ROUTES: 1/1 succeeded len=0 ret=1 a=0 u/d=up
. 2016.08.24 10:51:25 - OpenVPN > C:\WINDOWS\system32\route.exe ADD 62.102.148.148 MASK 255.255.255.255 192.168.0.1
. 2016.08.24 10:51:25 - OpenVPN > ROUTE: CreateIpForwardEntry succeeded with dwForwardMetric1=25 and dwForwardType=4
. 2016.08.24 10:51:25 - OpenVPN > Route addition via IPAPI succeeded [adaptive]
. 2016.08.24 10:51:25 - OpenVPN > C:\WINDOWS\system32\route.exe ADD 192.168.0.1 MASK 255.255.255.255 192.168.0.1 IF 2
. 2016.08.24 10:51:25 - OpenVPN > C:\WINDOWS\system32\route.exe ADD 0.0.0.0 MASK 128.0.0.0 10.4.0.1
. 2016.08.24 10:51:25 - OpenVPN > ROUTE: CreateIpForwardEntry succeeded with dwForwardMetric1=20 and dwForwardType=4
. 2016.08.24 10:51:25 - OpenVPN > C:\WINDOWS\system32\route.exe ADD 128.0.0.0 MASK 128.0.0.0 10.4.0.1
. 2016.08.24 10:51:25 - Starting Management Interface
. 2016.08.24 10:51:25 - OpenVPN > Initialization Sequence Completed
I 2016.08.24 10:51:25 - DNS of a network adapter forced (Intel® Centrino® Advanced-N 6235)
I 2016.08.24 10:51:25 - DNS of a network adapter forced (TAP-Windows Adapter V9)
I 2016.08.24 10:51:25 - Flushing DNS
I 2016.08.24 10:51:25 - Checking route
I 2016.08.24 10:51:25 - Checking DNS
! 2016.08.24 10:51:25 - Connected.
. 2016.08.24 10:51:25 - OpenVPN > MANAGEMENT: Client connected from [AF_INET]127.0.0.1:3100
. 2016.08.24 10:51:25 - OpenVpn Management > >INFO:OpenVPN Management Interface Version 1 -- type 'help' for more info
. 2016.08.24 10:54:41 - OpenVPN > [server] Inactivity timeout (--ping-restart), restarting
. 2016.08.24 10:54:41 - OpenVPN > SIGUSR1[soft,ping-restart] received, process restarting
. 2016.08.24 10:54:41 - OpenVPN > Restart pause, 2 second(s)
! 2016.08.24 10:54:41 - Disconnecting
. 2016.08.24 10:54:41 - Management - Send 'signal SIGTERM'
. 2016.08.24 10:54:41 - OpenVPN > MANAGEMENT: CMD 'signal SIGTERM'
. 2016.08.24 10:54:41 - OpenVPN > MANAGEMENT: Client disconnected
. 2016.08.24 10:54:41 - OpenVPN > Assertion failed at misc.c:779
. 2016.08.24 10:54:41 - OpenVPN > Exiting due to fatal error
. 2016.08.24 10:54:41 - Connection terminated.
I 2016.08.24 10:54:41 - DNS of a network adapter restored to original settings (Intel® Centrino® Advanced-N 6235)
I 2016.08.24 10:54:41 - DNS of a network adapter restored to original settings (TAP-Windows Adapter V9)
I 2016.08.24 10:54:44 - Checking authorization ...
! 2016.08.24 10:54:44 - Connecting to Celaeno (Netherlands, Alblasserdam)
. 2016.08.24 10:54:44 - OpenVPN > OpenVPN 2.3.8 x86_64-w64-mingw32 [sSL (OpenSSL)] [LZO] [iPv6] built on Aug 13 2015
. 2016.08.24 10:54:44 - OpenVPN > library versions: OpenSSL 1.0.2d 9 Jul 2015, LZO 2.08
. 2016.08.24 10:54:44 - OpenVPN > MANAGEMENT: TCP Socket listening on [AF_INET]127.0.0.1:3100
. 2016.08.24 10:54:44 - OpenVPN > Control Channel Authentication: tls-auth using INLINE static key file
. 2016.08.24 10:54:44 - OpenVPN > Outgoing Control Channel Authentication: Using 160 bit message hash 'SHA1' for HMAC authentication
. 2016.08.24 10:54:44 - OpenVPN > Incoming Control Channel Authentication: Using 160 bit message hash 'SHA1' for HMAC authentication
. 2016.08.24 10:54:44 - OpenVPN > Socket Buffers: R=[65536->131072] S=[65536->131072]
. 2016.08.24 10:54:44 - OpenVPN > UDPv4 link local: [undef]
. 2016.08.24 10:54:44 - OpenVPN > UDPv4 link remote: [AF_INET]213.152.161.68:443
. 2016.08.24 10:54:44 - OpenVPN > TLS: Initial packet from [AF_INET]213.152.161.68:443, sid=c0dc7f84 35bd7eb3
. 2016.08.24 10:54:44 - OpenVPN > VERIFY OK: depth=1, C=IT, ST=IT, L=Perugia, O=airvpn.org, CN=airvpn.org CA, emailAddress=info@airvpn.org
. 2016.08.24 10:54:44 - OpenVPN > Validating certificate key usage
. 2016.08.24 10:54:44 - OpenVPN > ++ Certificate has key usage  00a0, expects 00a0
. 2016.08.24 10:54:44 - OpenVPN > VERIFY KU OK
. 2016.08.24 10:54:44 - OpenVPN > Validating certificate extended key usage
. 2016.08.24 10:54:44 - OpenVPN > ++ Certificate has EKU (str) TLS Web Server Authentication, expects TLS Web Server Authentication
. 2016.08.24 10:54:44 - OpenVPN > VERIFY EKU OK
. 2016.08.24 10:54:44 - OpenVPN > VERIFY OK: depth=0, C=IT, ST=IT, L=Perugia, O=airvpn.org, CN=server, emailAddress=info@airvpn.org
. 2016.08.24 10:54:45 - OpenVPN > Data Channel Encrypt: Cipher 'AES-256-CBC' initialized with 256 bit key
. 2016.08.24 10:54:45 - OpenVPN > Data Channel Encrypt: Using 160 bit message hash 'SHA1' for HMAC authentication
. 2016.08.24 10:54:45 - OpenVPN > Data Channel Decrypt: Cipher 'AES-256-CBC' initialized with 256 bit key
. 2016.08.24 10:54:45 - OpenVPN > Data Channel Decrypt: Using 160 bit message hash 'SHA1' for HMAC authentication
. 2016.08.24 10:54:45 - OpenVPN > Control Channel: TLSv1.2, cipher TLSv1/SSLv3 DHE-RSA-AES256-GCM-SHA384, 4096 bit RSA
. 2016.08.24 10:54:45 - OpenVPN > [server] Peer Connection Initiated with [AF_INET]213.152.161.68:443
. 2016.08.24 10:54:47 - OpenVPN > SENT CONTROL [server]: 'PUSH_REQUEST' (status=1)
. 2016.08.24 10:54:47 - OpenVPN > PUSH: Received control message: 'PUSH_REPLY,redirect-gateway def1 bypass-dhcp,dhcp-option DNS 10.4.0.1,comp-lzo no,route-gateway 10.4.0.1,topology subnet,ping 10,ping-restart 60,ifconfig 10.4.76.10 255.255.0.0'
. 2016.08.24 10:54:47 - OpenVPN > OPTIONS IMPORT: timers and/or timeouts modified
. 2016.08.24 10:54:47 - OpenVPN > OPTIONS IMPORT: LZO parms modified
. 2016.08.24 10:54:47 - OpenVPN > OPTIONS IMPORT: --ifconfig/up options modified
. 2016.08.24 10:54:47 - OpenVPN > OPTIONS IMPORT: route options modified
. 2016.08.24 10:54:47 - OpenVPN > OPTIONS IMPORT: route-related options modified
. 2016.08.24 10:54:47 - OpenVPN > OPTIONS IMPORT: --ip-win32 and/or --dhcp-option options modified
. 2016.08.24 10:54:47 - OpenVPN > do_ifconfig, tt->ipv6=0, tt->did_ifconfig_ipv6_setup=0
. 2016.08.24 10:54:47 - OpenVPN > open_tun, tt->ipv6=0
. 2016.08.24 10:54:47 - OpenVPN > TAP-WIN32 device [Ethernet 3] opened: \\.\Global\{3B5251B0-000A-481D-875B-0E6C3C710727}.tap
. 2016.08.24 10:54:47 - OpenVPN > TAP-Windows Driver Version 9.21
. 2016.08.24 10:54:47 - OpenVPN > Set TAP-Windows TUN subnet mode network/local/netmask = 10.4.0.0/10.4.76.10/255.255.0.0 [sUCCEEDED]
. 2016.08.24 10:54:47 - OpenVPN > Notified TAP-Windows driver to set a DHCP IP/netmask of 10.4.76.10/255.255.0.0 on interface {3B5251B0-000A-481D-875B-0E6C3C710727} [DHCP-serv: 10.4.255.254, lease-time: 31536000]
. 2016.08.24 10:54:47 - OpenVPN > Successful ARP Flush on interface [34] {3B5251B0-000A-481D-875B-0E6C3C710727}
. 2016.08.24 10:54:52 - OpenVPN > TEST ROUTES: 1/1 succeeded len=0 ret=1 a=0 u/d=up
. 2016.08.24 10:54:52 - OpenVPN > C:\WINDOWS\system32\route.exe ADD 213.152.161.68 MASK 255.255.255.255 192.168.0.1
. 2016.08.24 10:54:52 - OpenVPN > ROUTE: CreateIpForwardEntry succeeded with dwForwardMetric1=25 and dwForwardType=4
. 2016.08.24 10:54:52 - OpenVPN > Route addition via IPAPI succeeded [adaptive]
. 2016.08.24 10:54:52 - OpenVPN > C:\WINDOWS\system32\route.exe ADD 192.168.0.1 MASK 255.255.255.255 192.168.0.1 IF 2
. 2016.08.24 10:54:52 - OpenVPN > ROUTE: route addition failed using CreateIpForwardEntry: L'oggetto esiste già.   [status=5010 if_index=2]
. 2016.08.24 10:54:52 - OpenVPN > Route addition via IPAPI failed [adaptive]
. 2016.08.24 10:54:52 - OpenVPN > Route addition fallback to route.exe
. 2016.08.24 10:54:52 - OpenVPN > env_block: add PATH=C:\Windows\System32;C:\WINDOWS;C:\WINDOWS\System32\Wbem
. 2016.08.24 10:54:52 - OpenVPN > C:\WINDOWS\system32\route.exe ADD 0.0.0.0 MASK 128.0.0.0 10.4.0.1
. 2016.08.24 10:54:52 - OpenVPN > ROUTE: route addition failed using CreateIpForwardEntry: L'oggetto esiste già.   [status=5010 if_index=34]
. 2016.08.24 10:54:52 - OpenVPN > C:\WINDOWS\system32\route.exe ADD 128.0.0.0 MASK 128.0.0.0 10.4.0.1
. 2016.08.24 10:54:52 - Starting Management Interface
. 2016.08.24 10:54:52 - OpenVPN > Initialization Sequence Completed
I 2016.08.24 10:54:52 - DNS of a network adapter forced (Intel® Centrino® Advanced-N 6235)
I 2016.08.24 10:54:52 - DNS of a network adapter forced (TAP-Windows Adapter V9)
I 2016.08.24 10:54:52 - Flushing DNS
I 2016.08.24 10:54:52 - Checking route
I 2016.08.24 10:54:53 - Checking DNS
! 2016.08.24 10:54:54 - Connected.
. 2016.08.24 10:54:54 - OpenVPN > MANAGEMENT: Client connected from [AF_INET]127.0.0.1:3100
. 2016.08.24 10:54:54 - OpenVpn Management > >INFO:OpenVPN Management Interface Version 1 -- type 'help' for more info
! 2016.08.24 10:56:53 - Disconnecting
. 2016.08.24 10:56:53 - Management - Send 'signal SIGTERM'
. 2016.08.24 10:56:53 - OpenVPN > MANAGEMENT: CMD 'signal SIGTERM'
. 2016.08.24 10:56:53 - OpenVPN > SIGTERM received, sending exit notification to peer
. 2016.08.24 10:56:58 - OpenVPN > C:\WINDOWS\system32\route.exe DELETE 213.152.161.68 MASK 255.255.255.255 192.168.0.1
. 2016.08.24 10:56:58 - OpenVPN > Route deletion via IPAPI succeeded [adaptive]
. 2016.08.24 10:56:58 - OpenVPN > C:\WINDOWS\system32\route.exe DELETE 192.168.0.1 MASK 255.255.255.255 192.168.0.1
. 2016.08.24 10:56:58 - OpenVPN > C:\WINDOWS\system32\route.exe DELETE 0.0.0.0 MASK 128.0.0.0 10.4.0.1
. 2016.08.24 10:56:58 - OpenVPN > C:\WINDOWS\system32\route.exe DELETE 128.0.0.0 MASK 128.0.0.0 10.4.0.1
. 2016.08.24 10:56:58 - OpenVPN > Closing TUN/TAP interface
. 2016.08.24 10:56:58 - OpenVPN > SIGTERM[soft,exit-with-notification] received, process exiting
. 2016.08.24 10:56:58 - Connection terminated.
I 2016.08.24 10:56:58 - DNS of a network adapter restored to original settings (Intel® Centrino® Advanced-N 6235)
I 2016.08.24 10:56:58 - DNS of a network adapter restored to original settings (TAP-Windows Adapter V9)
I 2016.08.24 10:56:58 - IPv6 restored.
! 2016.08.24 10:56:58 - Session terminated.
! 2016.08.24 10:57:15 - Activation of Network Lock - Windows Firewall
I 2016.08.24 10:57:26 - Session starting.
I 2016.08.24 10:57:26 - IPv6 disabled.
I 2016.08.24 10:57:26 - Checking authorization ...
! 2016.08.24 10:57:26 - Connecting to Zaniah (Sweden, Uppsala)
. 2016.08.24 10:57:26 - OpenVPN > OpenVPN 2.3.8 x86_64-w64-mingw32 [sSL (OpenSSL)] [LZO] [iPv6] built on Aug 13 2015
. 2016.08.24 10:57:26 - OpenVPN > library versions: OpenSSL 1.0.2d 9 Jul 2015, LZO 2.08
. 2016.08.24 10:57:26 - OpenVPN > MANAGEMENT: TCP Socket listening on [AF_INET]127.0.0.1:3100
. 2016.08.24 10:57:26 - OpenVPN > Control Channel Authentication: tls-auth using INLINE static key file
. 2016.08.24 10:57:26 - OpenVPN > Outgoing Control Channel Authentication: Using 160 bit message hash 'SHA1' for HMAC authentication
. 2016.08.24 10:57:26 - OpenVPN > Incoming Control Channel Authentication: Using 160 bit message hash 'SHA1' for HMAC authentication
. 2016.08.24 10:57:26 - OpenVPN > Socket Buffers: R=[65536->131072] S=[65536->131072]
. 2016.08.24 10:57:26 - OpenVPN > UDPv4 link local: [undef]
. 2016.08.24 10:57:26 - OpenVPN > UDPv4 link remote: [AF_INET]62.102.148.136:443
. 2016.08.24 10:57:26 - OpenVPN > TLS: Initial packet from [AF_INET]62.102.148.136:443, sid=fe107028 137569dc
. 2016.08.24 10:57:26 - OpenVPN > VERIFY OK: depth=1, C=IT, ST=IT, L=Perugia, O=airvpn.org, CN=airvpn.org CA, emailAddress=info@airvpn.org
. 2016.08.24 10:57:26 - OpenVPN > Validating certificate key usage
. 2016.08.24 10:57:26 - OpenVPN > ++ Certificate has key usage  00a0, expects 00a0
. 2016.08.24 10:57:26 - OpenVPN > VERIFY KU OK
. 2016.08.24 10:57:26 - OpenVPN > Validating certificate extended key usage
. 2016.08.24 10:57:26 - OpenVPN > ++ Certificate has EKU (str) TLS Web Server Authentication, expects TLS Web Server Authentication
. 2016.08.24 10:57:26 - OpenVPN > VERIFY EKU OK
. 2016.08.24 10:57:26 - OpenVPN > VERIFY OK: depth=0, C=IT, ST=IT, L=Perugia, O=airvpn.org, CN=server, emailAddress=info@airvpn.org
. 2016.08.24 10:57:27 - OpenVPN > Data Channel Encrypt: Cipher 'AES-256-CBC' initialized with 256 bit key
. 2016.08.24 10:57:27 - OpenVPN > Data Channel Encrypt: Using 160 bit message hash 'SHA1' for HMAC authentication
. 2016.08.24 10:57:27 - OpenVPN > Data Channel Decrypt: Cipher 'AES-256-CBC' initialized with 256 bit key
. 2016.08.24 10:57:27 - OpenVPN > Data Channel Decrypt: Using 160 bit message hash 'SHA1' for HMAC authentication
. 2016.08.24 10:57:27 - OpenVPN > Control Channel: TLSv1.2, cipher TLSv1/SSLv3 DHE-RSA-AES256-GCM-SHA384, 4096 bit RSA
. 2016.08.24 10:57:27 - OpenVPN > [server] Peer Connection Initiated with [AF_INET]62.102.148.136:443
. 2016.08.24 10:57:29 - OpenVPN > SENT CONTROL [server]: 'PUSH_REQUEST' (status=1)
. 2016.08.24 10:57:29 - OpenVPN > PUSH: Received control message: 'PUSH_REPLY,redirect-gateway def1 bypass-dhcp,dhcp-option DNS 10.4.0.1,comp-lzo no,route-gateway 10.4.0.1,topology subnet,ping 10,ping-restart 60,ifconfig 10.4.60.48 255.255.0.0'
. 2016.08.24 10:57:29 - OpenVPN > OPTIONS IMPORT: timers and/or timeouts modified
. 2016.08.24 10:57:29 - OpenVPN > OPTIONS IMPORT: LZO parms modified
. 2016.08.24 10:57:29 - OpenVPN > OPTIONS IMPORT: --ifconfig/up options modified
. 2016.08.24 10:57:29 - OpenVPN > OPTIONS IMPORT: route options modified
. 2016.08.24 10:57:29 - OpenVPN > OPTIONS IMPORT: route-related options modified
. 2016.08.24 10:57:29 - OpenVPN > OPTIONS IMPORT: --ip-win32 and/or --dhcp-option options modified
. 2016.08.24 10:57:29 - OpenVPN > do_ifconfig, tt->ipv6=0, tt->did_ifconfig_ipv6_setup=0
. 2016.08.24 10:57:29 - OpenVPN > open_tun, tt->ipv6=0
. 2016.08.24 10:57:29 - OpenVPN > TAP-WIN32 device [Ethernet 3] opened: \\.\Global\{3B5251B0-000A-481D-875B-0E6C3C710727}.tap
. 2016.08.24 10:57:29 - OpenVPN > TAP-Windows Driver Version 9.21
. 2016.08.24 10:57:29 - OpenVPN > Set TAP-Windows TUN subnet mode network/local/netmask = 10.4.0.0/10.4.60.48/255.255.0.0 [sUCCEEDED]
. 2016.08.24 10:57:29 - OpenVPN > Notified TAP-Windows driver to set a DHCP IP/netmask of 10.4.60.48/255.255.0.0 on interface {3B5251B0-000A-481D-875B-0E6C3C710727} [DHCP-serv: 10.4.255.254, lease-time: 31536000]
. 2016.08.24 10:57:29 - OpenVPN > Successful ARP Flush on interface [34] {3B5251B0-000A-481D-875B-0E6C3C710727}
. 2016.08.24 10:57:34 - OpenVPN > TEST ROUTES: 1/1 succeeded len=0 ret=1 a=0 u/d=up
. 2016.08.24 10:57:34 - OpenVPN > C:\WINDOWS\system32\route.exe ADD 62.102.148.136 MASK 255.255.255.255 192.168.0.1
. 2016.08.24 10:57:34 - OpenVPN > ROUTE: CreateIpForwardEntry succeeded with dwForwardMetric1=25 and dwForwardType=4
. 2016.08.24 10:57:34 - OpenVPN > Route addition via IPAPI succeeded [adaptive]
. 2016.08.24 10:57:34 - OpenVPN > C:\WINDOWS\system32\route.exe ADD 192.168.0.1 MASK 255.255.255.255 192.168.0.1 IF 2
. 2016.08.24 10:57:34 - OpenVPN > C:\WINDOWS\system32\route.exe ADD 0.0.0.0 MASK 128.0.0.0 10.4.0.1
. 2016.08.24 10:57:34 - OpenVPN > ROUTE: CreateIpForwardEntry succeeded with dwForwardMetric1=20 and dwForwardType=4
. 2016.08.24 10:57:34 - OpenVPN > C:\WINDOWS\system32\route.exe ADD 128.0.0.0 MASK 128.0.0.0 10.4.0.1
. 2016.08.24 10:57:34 - Starting Management Interface
. 2016.08.24 10:57:34 - OpenVPN > Initialization Sequence Completed
I 2016.08.24 10:57:34 - DNS of a network adapter forced (Intel® Centrino® Advanced-N 6235)
I 2016.08.24 10:57:34 - DNS of a network adapter forced (TAP-Windows Adapter V9)
I 2016.08.24 10:57:34 - Flushing DNS
I 2016.08.24 10:57:34 - Checking route
I 2016.08.24 10:57:35 - Checking DNS
! 2016.08.24 10:57:35 - Connected.
. 2016.08.24 10:57:35 - OpenVPN > MANAGEMENT: Client connected from [AF_INET]127.0.0.1:3100
. 2016.08.24 10:57:35 - OpenVpn Management > >INFO:OpenVPN Management Interface Version 1 -- type 'help' for more info
. 2016.08.24 11:04:20 - Updating systems & servers data ...
. 2016.08.24 11:04:20 - Systems & servers data update completed
. 2016.08.24 11:34:25 - Updating systems & servers data ...
. 2016.08.24 11:34:26 - Systems & servers data update completed
. 2016.08.24 11:57:26 - OpenVPN > VERIFY OK: depth=1, C=IT, ST=IT, L=Perugia, O=airvpn.org, CN=airvpn.org CA, emailAddress=info@airvpn.org
. 2016.08.24 11:57:26 - OpenVPN > Validating certificate key usage
. 2016.08.24 11:57:26 - OpenVPN > ++ Certificate has key usage  00a0, expects 00a0
. 2016.08.24 11:57:26 - OpenVPN > VERIFY KU OK
. 2016.08.24 11:57:26 - OpenVPN > Validating certificate extended key usage
. 2016.08.24 11:57:26 - OpenVPN > ++ Certificate has EKU (str) TLS Web Server Authentication, expects TLS Web Server Authentication
. 2016.08.24 11:57:26 - OpenVPN > VERIFY EKU OK
. 2016.08.24 11:57:26 - OpenVPN > VERIFY OK: depth=0, C=IT, ST=IT, L=Perugia, O=airvpn.org, CN=server, emailAddress=info@airvpn.org
. 2016.08.24 11:57:27 - OpenVPN > Data Channel Encrypt: Cipher 'AES-256-CBC' initialized with 256 bit key
. 2016.08.24 11:57:27 - OpenVPN > Data Channel Encrypt: Using 160 bit message hash 'SHA1' for HMAC authentication
. 2016.08.24 11:57:27 - OpenVPN > Data Channel Decrypt: Cipher 'AES-256-CBC' initialized with 256 bit key
. 2016.08.24 11:57:27 - OpenVPN > Data Channel Decrypt: Using 160 bit message hash 'SHA1' for HMAC authentication
. 2016.08.24 11:57:27 - OpenVPN > Control Channel: TLSv1.2, cipher TLSv1/SSLv3 DHE-RSA-AES256-GCM-SHA384, 4096 bit RSA
. 2016.08.24 12:04:32 - Updating systems & servers data ...
. 2016.08.24 12:04:33 - Systems & servers data update completed
! 2016.08.24 12:08:24 - Disconnecting
. 2016.08.24 12:08:24 - Management - Send 'signal SIGTERM'
. 2016.08.24 12:08:24 - OpenVPN > MANAGEMENT: CMD 'signal SIGTERM'
. 2016.08.24 12:08:24 - OpenVPN > SIGTERM received, sending exit notification to peer
. 2016.08.24 12:08:29 - OpenVPN > C:\WINDOWS\system32\route.exe DELETE 62.102.148.136 MASK 255.255.255.255 192.168.0.1
. 2016.08.24 12:08:29 - OpenVPN > Route deletion via IPAPI succeeded [adaptive]
. 2016.08.24 12:08:29 - OpenVPN > C:\WINDOWS\system32\route.exe DELETE 192.168.0.1 MASK 255.255.255.255 192.168.0.1
. 2016.08.24 12:08:29 - OpenVPN > C:\WINDOWS\system32\route.exe DELETE 0.0.0.0 MASK 128.0.0.0 10.4.0.1
. 2016.08.24 12:08:29 - OpenVPN > C:\WINDOWS\system32\route.exe DELETE 128.0.0.0 MASK 128.0.0.0 10.4.0.1
. 2016.08.24 12:08:29 - OpenVPN > Closing TUN/TAP interface
. 2016.08.24 12:08:29 - OpenVPN > SIGTERM[soft,exit-with-notification] received, process exiting
. 2016.08.24 12:08:29 - Connection terminated.
I 2016.08.24 12:08:29 - DNS of a network adapter restored to original settings (Intel® Centrino® Advanced-N 6235)
I 2016.08.24 12:08:29 - DNS of a network adapter restored to original settings (TAP-Windows Adapter V9)
I 2016.08.24 12:08:29 - IPv6 restored.
! 2016.08.24 12:08:29 - Session terminated.
I 2016.08.24 12:08:54 - Session starting.
I 2016.08.24 12:08:54 - IPv6 disabled.
I 2016.08.24 12:08:54 - Checking authorization ...
! 2016.08.24 12:08:54 - Connecting to Algorab (Sweden, Uppsala)
. 2016.08.24 12:08:54 - OpenVPN > OpenVPN 2.3.8 x86_64-w64-mingw32 [sSL (OpenSSL)] [LZO] [iPv6] built on Aug 13 2015
. 2016.08.24 12:08:54 - OpenVPN > library versions: OpenSSL 1.0.2d 9 Jul 2015, LZO 2.08
. 2016.08.24 12:08:54 - OpenVPN > MANAGEMENT: TCP Socket listening on [AF_INET]127.0.0.1:3100
. 2016.08.24 12:08:54 - OpenVPN > Control Channel Authentication: tls-auth using INLINE static key file
. 2016.08.24 12:08:54 - OpenVPN > Outgoing Control Channel Authentication: Using 160 bit message hash 'SHA1' for HMAC authentication
. 2016.08.24 12:08:54 - OpenVPN > Incoming Control Channel Authentication: Using 160 bit message hash 'SHA1' for HMAC authentication
. 2016.08.24 12:08:54 - OpenVPN > Socket Buffers: R=[65536->131072] S=[65536->131072]
. 2016.08.24 12:08:54 - OpenVPN > UDPv4 link local: [undef]
. 2016.08.24 12:08:54 - OpenVPN > UDPv4 link remote: [AF_INET]62.102.148.147:443
. 2016.08.24 12:08:54 - OpenVPN > TLS: Initial packet from [AF_INET]62.102.148.147:443, sid=179314c3 2aca7337
. 2016.08.24 12:08:54 - OpenVPN > VERIFY OK: depth=1, C=IT, ST=IT, L=Perugia, O=airvpn.org, CN=airvpn.org CA, emailAddress=info@airvpn.org
. 2016.08.24 12:08:54 - OpenVPN > Validating certificate key usage
. 2016.08.24 12:08:54 - OpenVPN > ++ Certificate has key usage  00a0, expects 00a0
. 2016.08.24 12:08:54 - OpenVPN > VERIFY KU OK
. 2016.08.24 12:08:54 - OpenVPN > Validating certificate extended key usage
. 2016.08.24 12:08:54 - OpenVPN > ++ Certificate has EKU (str) TLS Web Server Authentication, expects TLS Web Server Authentication
. 2016.08.24 12:08:54 - OpenVPN > VERIFY EKU OK
. 2016.08.24 12:08:54 - OpenVPN > VERIFY OK: depth=0, C=IT, ST=IT, L=Perugia, O=airvpn.org, CN=server, emailAddress=info@airvpn.org
. 2016.08.24 12:08:55 - OpenVPN > Data Channel Encrypt: Cipher 'AES-256-CBC' initialized with 256 bit key
. 2016.08.24 12:08:55 - OpenVPN > Data Channel Encrypt: Using 160 bit message hash 'SHA1' for HMAC authentication
. 2016.08.24 12:08:55 - OpenVPN > Data Channel Decrypt: Cipher 'AES-256-CBC' initialized with 256 bit key
. 2016.08.24 12:08:55 - OpenVPN > Data Channel Decrypt: Using 160 bit message hash 'SHA1' for HMAC authentication
. 2016.08.24 12:08:55 - OpenVPN > Control Channel: TLSv1.2, cipher TLSv1/SSLv3 DHE-RSA-AES256-GCM-SHA384, 4096 bit RSA
. 2016.08.24 12:08:55 - OpenVPN > [server] Peer Connection Initiated with [AF_INET]62.102.148.147:443
. 2016.08.24 12:08:57 - OpenVPN > SENT CONTROL [server]: 'PUSH_REQUEST' (status=1)
. 2016.08.24 12:08:57 - OpenVPN > PUSH: Received control message: 'PUSH_REPLY,redirect-gateway def1 bypass-dhcp,dhcp-option DNS 10.4.0.1,comp-lzo no,route-gateway 10.4.0.1,topology subnet,ping 10,ping-restart 60,ifconfig 10.4.26.43 255.255.0.0'
. 2016.08.24 12:08:57 - OpenVPN > OPTIONS IMPORT: timers and/or timeouts modified
. 2016.08.24 12:08:57 - OpenVPN > OPTIONS IMPORT: LZO parms modified
. 2016.08.24 12:08:57 - OpenVPN > OPTIONS IMPORT: --ifconfig/up options modified
. 2016.08.24 12:08:57 - OpenVPN > OPTIONS IMPORT: route options modified
. 2016.08.24 12:08:57 - OpenVPN > OPTIONS IMPORT: route-related options modified
. 2016.08.24 12:08:57 - OpenVPN > OPTIONS IMPORT: --ip-win32 and/or --dhcp-option options modified
. 2016.08.24 12:08:57 - OpenVPN > do_ifconfig, tt->ipv6=0, tt->did_ifconfig_ipv6_setup=0
. 2016.08.24 12:08:57 - OpenVPN > open_tun, tt->ipv6=0
. 2016.08.24 12:08:57 - OpenVPN > TAP-WIN32 device [Ethernet 3] opened: \\.\Global\{3B5251B0-000A-481D-875B-0E6C3C710727}.tap
. 2016.08.24 12:08:57 - OpenVPN > TAP-Windows Driver Version 9.21
. 2016.08.24 12:08:57 - OpenVPN > Set TAP-Windows TUN subnet mode network/local/netmask = 10.4.0.0/10.4.26.43/255.255.0.0 [sUCCEEDED]
. 2016.08.24 12:08:57 - OpenVPN > Notified TAP-Windows driver to set a DHCP IP/netmask of 10.4.26.43/255.255.0.0 on interface {3B5251B0-000A-481D-875B-0E6C3C710727} [DHCP-serv: 10.4.255.254, lease-time: 31536000]
. 2016.08.24 12:08:57 - OpenVPN > Successful ARP Flush on interface [34] {3B5251B0-000A-481D-875B-0E6C3C710727}
. 2016.08.24 12:09:02 - OpenVPN > TEST ROUTES: 1/1 succeeded len=0 ret=1 a=0 u/d=up
. 2016.08.24 12:09:02 - OpenVPN > C:\WINDOWS\system32\route.exe ADD 62.102.148.147 MASK 255.255.255.255 192.168.0.1
. 2016.08.24 12:09:02 - OpenVPN > ROUTE: CreateIpForwardEntry succeeded with dwForwardMetric1=25 and dwForwardType=4
. 2016.08.24 12:09:02 - OpenVPN > Route addition via IPAPI succeeded [adaptive]
. 2016.08.24 12:09:02 - OpenVPN > C:\WINDOWS\system32\route.exe ADD 192.168.0.1 MASK 255.255.255.255 192.168.0.1 IF 2
. 2016.08.24 12:09:02 - OpenVPN > C:\WINDOWS\system32\route.exe ADD 0.0.0.0 MASK 128.0.0.0 10.4.0.1
. 2016.08.24 12:09:02 - OpenVPN > ROUTE: CreateIpForwardEntry succeeded with dwForwardMetric1=20 and dwForwardType=4
. 2016.08.24 12:09:02 - OpenVPN > C:\WINDOWS\system32\route.exe ADD 128.0.0.0 MASK 128.0.0.0 10.4.0.1
. 2016.08.24 12:09:02 - Starting Management Interface
. 2016.08.24 12:09:02 - OpenVPN > Initialization Sequence Completed
I 2016.08.24 12:09:02 - DNS of a network adapter forced (Intel® Centrino® Advanced-N 6235)
I 2016.08.24 12:09:02 - DNS of a network adapter forced (TAP-Windows Adapter V9)
I 2016.08.24 12:09:03 - Flushing DNS
I 2016.08.24 12:09:03 - Checking route
I 2016.08.24 12:09:03 - Checking DNS
! 2016.08.24 12:09:03 - Connected.
. 2016.08.24 12:09:03 - OpenVpn Management > >INFO:OpenVPN Management Interface Version 1 -- type 'help' for more info
. 2016.08.24 12:09:03 - OpenVPN > MANAGEMENT: Client connected from [AF_INET]127.0.0.1:3100
You are running Eddie 2.10.3 while the thread was dedicated to 2.11.x, so your message has been split from the original topic. Before anything else please upgrade to Eddie 2.11.x beta. Thread locked.
