Firas22 1 Posted ... After installing the eddie client airvpn unable to connect here are my logs I 2016.08.16 01:00:55 - AirVPN client version: 2.10.3 / x64, System: Windows, Name: Microsoft Windows NT 6.2.9200.0 / x64. 2016.08.16 01:00:55 - Reading options from C:\Users\Emudem\AppData\Local\AirVPN\AirVPN.xml. 2016.08.16 01:00:55 - Data Path: C:\Users\Emudem\AppData\Local\AirVPN. 2016.08.16 01:00:55 - App Path: C:\AirVPN. 2016.08.16 01:00:55 - Executable Path: C:\AirVPN\AirVPN.exe. 2016.08.16 01:00:55 - Command line arguments (1): path="home". 2016.08.16 01:00:55 - Operating System: Microsoft Windows NT 6.2.9200.0. 2016.08.16 01:00:55 - Updating systems & servers data .... 2016.08.16 01:00:56 - Systems & servers data update completedI 2016.08.16 01:00:56 - OpenVPN Driver - TAP-Windows Adapter V9, version 9.21.1I 2016.08.16 01:00:56 - OpenVPN - Version: OpenVPN 2.3.8 (C:\AirVPN\openvpn.exe)I 2016.08.16 01:00:56 - SSH - Version: plink 0.63 (C:\AirVPN\plink.exe)I 2016.08.16 01:00:56 - SSL - Version: stunnel 5.17 (C:\AirVPN\stunnel.exe)! 2016.08.16 01:00:56 - ReadyI 2016.08.16 01:00:58 - Checking login ...! 2016.08.16 01:00:59 - Logged in.I 2016.08.16 01:01:06 - Session starting.I 2016.08.16 01:01:06 - IPv6 disabled.I 2016.08.16 01:01:06 - Checking authorization ...! 2016.08.16 01:01:06 - Connecting to Seginus (Germany, Frankfurt). 2016.08.16 01:01:43 - OpenVPN > OpenVPN 2.3.8 x86_64-w64-mingw32 [sSL (OpenSSL)] [LZO] [iPv6] built on Aug 13 2015. 2016.08.16 01:01:43 - OpenVPN > library versions: OpenSSL 1.0.2d 9 Jul 2015, LZO 2.08. 2016.08.16 01:01:43 - OpenVPN > MANAGEMENT: TCP Socket listening on [AF_INET]127.0.0.1:3100. 2016.08.16 01:01:43 - OpenVPN > Control Channel Authentication: tls-auth using INLINE static key file. 2016.08.16 01:01:43 - OpenVPN > Outgoing Control Channel Authentication: Using 160 bit message hash 'SHA1' for HMAC authentication. 2016.08.16 01:01:43 - OpenVPN > Incoming Control Channel Authentication: Using 160 bit message hash 'SHA1' for HMAC authentication. 2016.08.16 01:01:43 - OpenVPN > Socket Buffers: R=[65536->131072] S=[65536->131072]. 2016.08.16 01:01:43 - OpenVPN > UDPv4 link local: [undef]. 2016.08.16 01:01:43 - OpenVPN > UDPv4 link remote: [AF_INET]178.162.198.103:443. 2016.08.16 01:01:43 - OpenVPN > TLS: Initial packet from [AF_INET]178.162.198.103:443, sid=e59b2321 c81e0195. 2016.08.16 01:01:43 - OpenVPN > VERIFY OK: depth=1, C=IT, ST=IT, L=Perugia, O=airvpn.org, CN=airvpn.org CA, emailAddress=info@airvpn.org. 2016.08.16 01:01:43 - OpenVPN > Validating certificate key usage. 2016.08.16 01:01:43 - OpenVPN > ++ Certificate has key usage 00a0, expects 00a0. 2016.08.16 01:01:43 - OpenVPN > VERIFY KU OK. 2016.08.16 01:01:43 - OpenVPN > Validating certificate extended key usage. 2016.08.16 01:01:43 - OpenVPN > ++ Certificate has EKU (str) TLS Web Server Authentication, expects TLS Web Server Authentication. 2016.08.16 01:01:43 - OpenVPN > VERIFY EKU OK. 2016.08.16 01:01:43 - OpenVPN > VERIFY OK: depth=0, C=IT, ST=IT, L=Perugia, O=airvpn.org, CN=server, emailAddress=info@airvpn.org. 2016.08.16 01:01:43 - OpenVPN > Data Channel Encrypt: Cipher 'AES-256-CBC' initialized with 256 bit key. 2016.08.16 01:01:43 - OpenVPN > Data Channel Encrypt: Using 160 bit message hash 'SHA1' for HMAC authentication. 2016.08.16 01:01:43 - OpenVPN > Data Channel Decrypt: Cipher 'AES-256-CBC' initialized with 256 bit key. 2016.08.16 01:01:43 - OpenVPN > Data Channel Decrypt: Using 160 bit message hash 'SHA1' for HMAC authentication. 2016.08.16 01:01:43 - OpenVPN > Control Channel: TLSv1.2, cipher TLSv1/SSLv3 DHE-RSA-AES256-GCM-SHA384, 4096 bit RSA. 2016.08.16 01:01:43 - OpenVPN > [server] Peer Connection Initiated with [AF_INET]178.162.198.103:443. 2016.08.16 01:01:43 - OpenVPN > SENT CONTROL [server]: 'PUSH_REQUEST' (status=1). 2016.08.16 01:01:43 - OpenVPN > PUSH: Received control message: 'PUSH_REPLY,redirect-gateway def1 bypass-dhcp,dhcp-option DNS 10.4.0.1,comp-lzo no,route-gateway 10.4.0.1,topology subnet,ping 10,ping-restart 60,ifconfig 10.4.26.51 255.255.0.0'. 2016.08.16 01:01:43 - OpenVPN > OPTIONS IMPORT: timers and/or timeouts modified. 2016.08.16 01:01:43 - OpenVPN > OPTIONS IMPORT: LZO parms modified. 2016.08.16 01:01:43 - OpenVPN > OPTIONS IMPORT: --ifconfig/up options modified. 2016.08.16 01:01:43 - OpenVPN > OPTIONS IMPORT: route options modified. 2016.08.16 01:01:43 - OpenVPN > OPTIONS IMPORT: route-related options modified. 2016.08.16 01:01:43 - OpenVPN > OPTIONS IMPORT: --ip-win32 and/or --dhcp-option options modified. 2016.08.16 01:01:43 - OpenVPN > do_ifconfig, tt->ipv6=0, tt->did_ifconfig_ipv6_setup=0. 2016.08.16 01:01:43 - OpenVPN > open_tun, tt->ipv6=0. 2016.08.16 01:01:43 - OpenVPN > TAP-WIN32 device [Ethernet 2] opened: \\.\Global\{5342D826-9FD5-4B3E-A915-554A736E2963}.tap. 2016.08.16 01:01:43 - OpenVPN > TAP-Windows Driver Version 9.21. 2016.08.16 01:01:43 - OpenVPN > Set TAP-Windows TUN subnet mode network/local/netmask = 10.4.0.0/10.4.26.51/255.255.0.0 [sUCCEEDED]. 2016.08.16 01:01:43 - OpenVPN > Notified TAP-Windows driver to set a DHCP IP/netmask of 10.4.26.51/255.255.0.0 on interface {5342D826-9FD5-4B3E-A915-554A736E2963} [DHCP-serv: 10.4.255.254, lease-time: 31536000]. 2016.08.16 01:01:43 - OpenVPN > Successful ARP Flush on interface [6] {5342D826-9FD5-4B3E-A915-554A736E2963}. 2016.08.16 01:01:43 - OpenVPN > TEST ROUTES: 1/1 succeeded len=0 ret=1 a=0 u/d=up. 2016.08.16 01:01:43 - OpenVPN > C:\WINDOWS\system32\route.exe ADD 178.162.198.103 MASK 255.255.255.255 192.168.178.1. 2016.08.16 01:01:43 - OpenVPN > ROUTE: CreateIpForwardEntry succeeded with dwForwardMetric1=35 and dwForwardType=4. 2016.08.16 01:01:43 - OpenVPN > Route addition via IPAPI succeeded [adaptive]. 2016.08.16 01:01:43 - OpenVPN > C:\WINDOWS\system32\route.exe ADD 192.168.178.1 MASK 255.255.255.255 192.168.178.1 IF 4. 2016.08.16 01:01:43 - OpenVPN > ROUTE: CreateIpForwardEntry succeeded with dwForwardMetric1=35 and dwForwardType=4. 2016.08.16 01:01:43 - OpenVPN > Route addition via IPAPI succeeded [adaptive]. 2016.08.16 01:01:43 - OpenVPN > C:\WINDOWS\system32\route.exe ADD 0.0.0.0 MASK 128.0.0.0 10.4.0.1. 2016.08.16 01:01:43 - OpenVPN > ROUTE: CreateIpForwardEntry succeeded with dwForwardMetric1=35 and dwForwardType=4. 2016.08.16 01:01:43 - OpenVPN > Route addition via IPAPI succeeded [adaptive]. 2016.08.16 01:01:43 - OpenVPN > C:\WINDOWS\system32\route.exe ADD 128.0.0.0 MASK 128.0.0.0 10.4.0.1. 2016.08.16 01:01:43 - OpenVPN > ROUTE: CreateIpForwardEntry succeeded with dwForwardMetric1=35 and dwForwardType=4. 2016.08.16 01:01:43 - OpenVPN > Route addition via IPAPI succeeded [adaptive]. 2016.08.16 01:01:43 - Starting Management Interface. 2016.08.16 01:01:43 - OpenVPN > Initialization Sequence CompletedI 2016.08.16 01:01:43 - DNS of a network adapter forced (Killer E2200 Gigabit Ethernet Controller)I 2016.08.16 01:01:43 - DNS of a network adapter forced (TAP-Windows Adapter V9)I 2016.08.16 01:01:43 - Flushing DNSI 2016.08.16 01:01:43 - Checking routeW 2016.08.16 01:02:07 - The remote name could not be resolved: 'seginus_exit.airservers.org'! 2016.08.16 01:02:07 - Disconnecting. 2016.08.16 01:02:07 - Management - Send 'signal SIGTERM'. 2016.08.16 01:02:07 - OpenVpn Management > >INFO:OpenVPN Management Interface Version 1 -- type 'help' for more info. 2016.08.16 01:02:07 - OpenVPN > MANAGEMENT: CMD 'signal SIGTERM'. 2016.08.16 01:02:07 - OpenVPN > SIGTERM received, sending exit notification to peer. 2016.08.16 01:02:12 - OpenVPN > C:\WINDOWS\system32\route.exe DELETE 178.162.198.103 MASK 255.255.255.255 192.168.178.1. 2016.08.16 01:02:12 - OpenVPN > Route deletion via IPAPI succeeded [adaptive]. 2016.08.16 01:02:12 - OpenVPN > C:\WINDOWS\system32\route.exe DELETE 192.168.178.1 MASK 255.255.255.255 192.168.178.1. 2016.08.16 01:02:12 - OpenVPN > Route deletion via IPAPI succeeded [adaptive]. 2016.08.16 01:02:12 - OpenVPN > C:\WINDOWS\system32\route.exe DELETE 0.0.0.0 MASK 128.0.0.0 10.4.0.1. 2016.08.16 01:02:12 - OpenVPN > Route deletion via IPAPI succeeded [adaptive]. 2016.08.16 01:02:12 - OpenVPN > C:\WINDOWS\system32\route.exe DELETE 128.0.0.0 MASK 128.0.0.0 10.4.0.1. 2016.08.16 01:02:12 - OpenVPN > Route deletion via IPAPI succeeded [adaptive]. 2016.08.16 01:02:12 - OpenVPN > Closing TUN/TAP interface. 2016.08.16 01:02:12 - OpenVPN > SIGTERM[soft,exit-with-notification] received, process exiting. 2016.08.16 01:02:12 - Connection terminated.I 2016.08.16 01:02:12 - DNS of a network adapter restored to original settings (Killer E2200 Gigabit Ethernet Controller)I 2016.08.16 01:02:12 - DNS of a network adapter restored to original settings (TAP-Windows Adapter V9)I 2016.08.16 01:02:15 - Checking authorization ...! 2016.08.16 01:02:15 - Connecting to Velorum (Germany, Frankfurt). 2016.08.16 01:02:15 - OpenVPN > OpenVPN 2.3.8 x86_64-w64-mingw32 [sSL (OpenSSL)] [LZO] [iPv6] built on Aug 13 2015. 2016.08.16 01:02:15 - OpenVPN > library versions: OpenSSL 1.0.2d 9 Jul 2015, LZO 2.08. 2016.08.16 01:02:25 - OpenVPN > MANAGEMENT: TCP Socket listening on [AF_INET]127.0.0.1:3100. 2016.08.16 01:02:26 - OpenVPN > Control Channel Authentication: tls-auth using INLINE static key file. 2016.08.16 01:02:26 - OpenVPN > Outgoing Control Channel Authentication: Using 160 bit message hash 'SHA1' for HMAC authentication. 2016.08.16 01:02:26 - OpenVPN > Incoming Control Channel Authentication: Using 160 bit message hash 'SHA1' for HMAC authentication. 2016.08.16 01:02:26 - OpenVPN > Socket Buffers: R=[65536->131072] S=[65536->131072]. 2016.08.16 01:02:26 - OpenVPN > UDPv4 link local: [undef]. 2016.08.16 01:02:26 - OpenVPN > UDPv4 link remote: [AF_INET]46.165.208.69:443. 2016.08.16 01:02:26 - OpenVPN > TLS: Initial packet from [AF_INET]46.165.208.69:443, sid=74b86251 98cc275f. 2016.08.16 01:02:26 - OpenVPN > VERIFY OK: depth=1, C=IT, ST=IT, L=Perugia, O=airvpn.org, CN=airvpn.org CA, emailAddress=info@airvpn.org. 2016.08.16 01:02:26 - OpenVPN > Validating certificate key usage. 2016.08.16 01:02:26 - OpenVPN > ++ Certificate has key usage 00a0, expects 00a0. 2016.08.16 01:02:26 - OpenVPN > VERIFY KU OK. 2016.08.16 01:02:26 - OpenVPN > Validating certificate extended key usage. 2016.08.16 01:02:26 - OpenVPN > ++ Certificate has EKU (str) TLS Web Server Authentication, expects TLS Web Server Authentication. 2016.08.16 01:02:26 - OpenVPN > VERIFY EKU OK. 2016.08.16 01:02:26 - OpenVPN > VERIFY OK: depth=0, C=IT, ST=IT, L=Perugia, O=airvpn.org, CN=server, emailAddress=info@airvpn.org. 2016.08.16 01:02:26 - OpenVPN > Data Channel Encrypt: Cipher 'AES-256-CBC' initialized with 256 bit key. 2016.08.16 01:02:26 - OpenVPN > Data Channel Encrypt: Using 160 bit message hash 'SHA1' for HMAC authentication. 2016.08.16 01:02:26 - OpenVPN > Data Channel Decrypt: Cipher 'AES-256-CBC' initialized with 256 bit key. 2016.08.16 01:02:26 - OpenVPN > Data Channel Decrypt: Using 160 bit message hash 'SHA1' for HMAC authentication. 2016.08.16 01:02:26 - OpenVPN > Control Channel: TLSv1.2, cipher TLSv1/SSLv3 DHE-RSA-AES256-GCM-SHA384, 4096 bit RSA. 2016.08.16 01:02:26 - OpenVPN > [server] Peer Connection Initiated with [AF_INET]46.165.208.69:443. 2016.08.16 01:02:28 - OpenVPN > SENT CONTROL [server]: 'PUSH_REQUEST' (status=1). 2016.08.16 01:02:29 - OpenVPN > PUSH: Received control message: 'PUSH_REPLY,redirect-gateway def1 bypass-dhcp,dhcp-option DNS 10.4.0.1,comp-lzo no,route-gateway 10.4.0.1,topology subnet,ping 10,ping-restart 60,ifconfig 10.4.21.208 255.255.0.0'. 2016.08.16 01:02:29 - OpenVPN > OPTIONS IMPORT: timers and/or timeouts modified. 2016.08.16 01:02:29 - OpenVPN > OPTIONS IMPORT: LZO parms modified. 2016.08.16 01:02:29 - OpenVPN > OPTIONS IMPORT: --ifconfig/up options modified. 2016.08.16 01:02:29 - OpenVPN > OPTIONS IMPORT: route options modified. 2016.08.16 01:02:29 - OpenVPN > OPTIONS IMPORT: route-related options modified. 2016.08.16 01:02:29 - OpenVPN > OPTIONS IMPORT: --ip-win32 and/or --dhcp-option options modified. 2016.08.16 01:02:29 - OpenVPN > do_ifconfig, tt->ipv6=0, tt->did_ifconfig_ipv6_setup=0. 2016.08.16 01:02:29 - OpenVPN > open_tun, tt->ipv6=0. 2016.08.16 01:02:29 - OpenVPN > TAP-WIN32 device [Ethernet 2] opened: \\.\Global\{5342D826-9FD5-4B3E-A915-554A736E2963}.tap. 2016.08.16 01:02:29 - OpenVPN > TAP-Windows Driver Version 9.21. 2016.08.16 01:02:29 - OpenVPN > Set TAP-Windows TUN subnet mode network/local/netmask = 10.4.0.0/10.4.21.208/255.255.0.0 [sUCCEEDED]. 2016.08.16 01:02:29 - OpenVPN > Notified TAP-Windows driver to set a DHCP IP/netmask of 10.4.21.208/255.255.0.0 on interface {5342D826-9FD5-4B3E-A915-554A736E2963} [DHCP-serv: 10.4.255.254, lease-time: 31536000]. 2016.08.16 01:02:29 - OpenVPN > Successful ARP Flush on interface [6] {5342D826-9FD5-4B3E-A915-554A736E2963}. 2016.08.16 01:02:35 - OpenVPN > TEST ROUTES: 1/1 succeeded len=0 ret=1 a=0 u/d=up. 2016.08.16 01:02:35 - OpenVPN > C:\WINDOWS\system32\route.exe ADD 46.165.208.69 MASK 255.255.255.255 192.168.178.1. 2016.08.16 01:02:35 - OpenVPN > ROUTE: CreateIpForwardEntry succeeded with dwForwardMetric1=35 and dwForwardType=4. 2016.08.16 01:02:35 - OpenVPN > Route addition via IPAPI succeeded [adaptive]. 2016.08.16 01:02:35 - OpenVPN > C:\WINDOWS\system32\route.exe ADD 192.168.178.1 MASK 255.255.255.255 192.168.178.1 IF 4. 2016.08.16 01:02:35 - OpenVPN > ROUTE: CreateIpForwardEntry succeeded with dwForwardMetric1=35 and dwForwardType=4. 2016.08.16 01:02:35 - OpenVPN > Route addition via IPAPI succeeded [adaptive]. 2016.08.16 01:02:35 - OpenVPN > C:\WINDOWS\system32\route.exe ADD 0.0.0.0 MASK 128.0.0.0 10.4.0.1. 2016.08.16 01:02:35 - OpenVPN > ROUTE: CreateIpForwardEntry succeeded with dwForwardMetric1=35 and dwForwardType=4. 2016.08.16 01:02:35 - OpenVPN > Route addition via IPAPI succeeded [adaptive]. 2016.08.16 01:02:35 - OpenVPN > C:\WINDOWS\system32\route.exe ADD 128.0.0.0 MASK 128.0.0.0 10.4.0.1. 2016.08.16 01:02:35 - OpenVPN > ROUTE: CreateIpForwardEntry succeeded with dwForwardMetric1=35 and dwForwardType=4. 2016.08.16 01:02:35 - OpenVPN > Route addition via IPAPI succeeded [adaptive]. 2016.08.16 01:02:35 - Starting Management Interface. 2016.08.16 01:02:35 - OpenVPN > Initialization Sequence CompletedI 2016.08.16 01:02:35 - DNS of a network adapter forced (Killer E2200 Gigabit Ethernet Controller)I 2016.08.16 01:02:35 - DNS of a network adapter forced (TAP-Windows Adapter V9)I 2016.08.16 01:02:35 - Flushing DNSI 2016.08.16 01:02:35 - Checking routeW 2016.08.16 01:02:59 - The remote name could not be resolved: 'velorum_exit.airservers.org'! 2016.08.16 01:02:59 - Disconnecting. 2016.08.16 01:02:59 - Management - Send 'signal SIGTERM'. 2016.08.16 01:02:59 - OpenVpn Management > >INFO:OpenVPN Management Interface Version 1 -- type 'help' for more info. 2016.08.16 01:02:59 - OpenVPN > MANAGEMENT: CMD 'signal SIGTERM'. 2016.08.16 01:02:59 - OpenVPN > SIGTERM received, sending exit notification to peer. 2016.08.16 01:03:04 - OpenVPN > C:\WINDOWS\system32\route.exe DELETE 46.165.208.69 MASK 255.255.255.255 192.168.178.1. 2016.08.16 01:03:04 - OpenVPN > Route deletion via IPAPI succeeded [adaptive]. 2016.08.16 01:03:04 - OpenVPN > C:\WINDOWS\system32\route.exe DELETE 192.168.178.1 MASK 255.255.255.255 192.168.178.1. 2016.08.16 01:03:04 - OpenVPN > Route deletion via IPAPI succeeded [adaptive]. 2016.08.16 01:03:04 - OpenVPN > C:\WINDOWS\system32\route.exe DELETE 0.0.0.0 MASK 128.0.0.0 10.4.0.1. 2016.08.16 01:03:04 - OpenVPN > Route deletion via IPAPI succeeded [adaptive]. 2016.08.16 01:03:04 - OpenVPN > C:\WINDOWS\system32\route.exe DELETE 128.0.0.0 MASK 128.0.0.0 10.4.0.1. 2016.08.16 01:03:04 - OpenVPN > Route deletion via IPAPI succeeded [adaptive]. 2016.08.16 01:03:04 - OpenVPN > Closing TUN/TAP interface. 2016.08.16 01:03:04 - OpenVPN > SIGTERM[soft,exit-with-notification] received, process exiting. 2016.08.16 01:03:04 - Connection terminated.I 2016.08.16 01:03:04 - DNS of a network adapter restored to original settings (Killer E2200 Gigabit Ethernet Controller)I 2016.08.16 01:03:04 - DNS of a network adapter restored to original settings (TAP-Windows Adapter V9)I 2016.08.16 01:03:07 - Checking authorization ...! 2016.08.16 01:03:07 - Connecting to Velorum (Germany, Frankfurt). 2016.08.16 01:03:07 - OpenVPN > OpenVPN 2.3.8 x86_64-w64-mingw32 [sSL (OpenSSL)] [LZO] [iPv6] built on Aug 13 2015. 2016.08.16 01:03:07 - OpenVPN > library versions: OpenSSL 1.0.2d 9 Jul 2015, LZO 2.08. 2016.08.16 01:03:17 - OpenVPN > MANAGEMENT: TCP Socket listening on [AF_INET]127.0.0.1:3100. 2016.08.16 01:03:17 - OpenVPN > Control Channel Authentication: tls-auth using INLINE static key file. 2016.08.16 01:03:17 - OpenVPN > Outgoing Control Channel Authentication: Using 160 bit message hash 'SHA1' for HMAC authentication. 2016.08.16 01:03:17 - OpenVPN > Incoming Control Channel Authentication: Using 160 bit message hash 'SHA1' for HMAC authentication. 2016.08.16 01:03:17 - OpenVPN > Socket Buffers: R=[65536->131072] S=[65536->131072]. 2016.08.16 01:03:17 - OpenVPN > UDPv4 link local: [undef]. 2016.08.16 01:03:17 - OpenVPN > UDPv4 link remote: [AF_INET]46.165.208.69:443. 2016.08.16 01:03:17 - OpenVPN > TLS: Initial packet from [AF_INET]46.165.208.69:443, sid=f282626c bcc9cb02. 2016.08.16 01:03:17 - OpenVPN > VERIFY OK: depth=1, C=IT, ST=IT, L=Perugia, O=airvpn.org, CN=airvpn.org CA, emailAddress=info@airvpn.org. 2016.08.16 01:03:17 - OpenVPN > Validating certificate key usage. 2016.08.16 01:03:17 - OpenVPN > ++ Certificate has key usage 00a0, expects 00a0. 2016.08.16 01:03:17 - OpenVPN > VERIFY KU OK. 2016.08.16 01:03:17 - OpenVPN > Validating certificate extended key usage. 2016.08.16 01:03:17 - OpenVPN > ++ Certificate has EKU (str) TLS Web Server Authentication, expects TLS Web Server Authentication. 2016.08.16 01:03:17 - OpenVPN > VERIFY EKU OK. 2016.08.16 01:03:17 - OpenVPN > VERIFY OK: depth=0, C=IT, ST=IT, L=Perugia, O=airvpn.org, CN=server, emailAddress=info@airvpn.org. 2016.08.16 01:03:18 - OpenVPN > Data Channel Encrypt: Cipher 'AES-256-CBC' initialized with 256 bit key. 2016.08.16 01:03:18 - OpenVPN > Data Channel Encrypt: Using 160 bit message hash 'SHA1' for HMAC authentication. 2016.08.16 01:03:18 - OpenVPN > Data Channel Decrypt: Cipher 'AES-256-CBC' initialized with 256 bit key. 2016.08.16 01:03:18 - OpenVPN > Data Channel Decrypt: Using 160 bit message hash 'SHA1' for HMAC authentication. 2016.08.16 01:03:18 - OpenVPN > Control Channel: TLSv1.2, cipher TLSv1/SSLv3 DHE-RSA-AES256-GCM-SHA384, 4096 bit RSA. 2016.08.16 01:03:18 - OpenVPN > [server] Peer Connection Initiated with [AF_INET]46.165.208.69:443. 2016.08.16 01:03:20 - OpenVPN > SENT CONTROL [server]: 'PUSH_REQUEST' (status=1). 2016.08.16 01:03:20 - OpenVPN > PUSH: Received control message: 'PUSH_REPLY,redirect-gateway def1 bypass-dhcp,dhcp-option DNS 10.4.0.1,comp-lzo no,route-gateway 10.4.0.1,topology subnet,ping 10,ping-restart 60,ifconfig 10.4.21.208 255.255.0.0'. 2016.08.16 01:03:20 - OpenVPN > OPTIONS IMPORT: timers and/or timeouts modified. 2016.08.16 01:03:20 - OpenVPN > OPTIONS IMPORT: LZO parms modified. 2016.08.16 01:03:20 - OpenVPN > OPTIONS IMPORT: --ifconfig/up options modified. 2016.08.16 01:03:20 - OpenVPN > OPTIONS IMPORT: route options modified. 2016.08.16 01:03:20 - OpenVPN > OPTIONS IMPORT: route-related options modified. 2016.08.16 01:03:20 - OpenVPN > OPTIONS IMPORT: --ip-win32 and/or --dhcp-option options modified. 2016.08.16 01:03:20 - OpenVPN > do_ifconfig, tt->ipv6=0, tt->did_ifconfig_ipv6_setup=0. 2016.08.16 01:03:20 - OpenVPN > open_tun, tt->ipv6=0. 2016.08.16 01:03:20 - OpenVPN > TAP-WIN32 device [Ethernet 2] opened: \\.\Global\{5342D826-9FD5-4B3E-A915-554A736E2963}.tap. 2016.08.16 01:03:20 - OpenVPN > TAP-Windows Driver Version 9.21. 2016.08.16 01:03:20 - OpenVPN > Set TAP-Windows TUN subnet mode network/local/netmask = 10.4.0.0/10.4.21.208/255.255.0.0 [sUCCEEDED]. 2016.08.16 01:03:20 - OpenVPN > Notified TAP-Windows driver to set a DHCP IP/netmask of 10.4.21.208/255.255.0.0 on interface {5342D826-9FD5-4B3E-A915-554A736E2963} [DHCP-serv: 10.4.255.254, lease-time: 31536000]. 2016.08.16 01:03:20 - OpenVPN > Successful ARP Flush on interface [6] {5342D826-9FD5-4B3E-A915-554A736E2963}. 2016.08.16 01:03:25 - OpenVPN > TEST ROUTES: 1/1 succeeded len=0 ret=1 a=0 u/d=up. 2016.08.16 01:03:25 - OpenVPN > C:\WINDOWS\system32\route.exe ADD 46.165.208.69 MASK 255.255.255.255 192.168.178.1. 2016.08.16 01:03:25 - OpenVPN > ROUTE: CreateIpForwardEntry succeeded with dwForwardMetric1=35 and dwForwardType=4. 2016.08.16 01:03:25 - OpenVPN > Route addition via IPAPI succeeded [adaptive]. 2016.08.16 01:03:25 - OpenVPN > C:\WINDOWS\system32\route.exe ADD 192.168.178.1 MASK 255.255.255.255 192.168.178.1 IF 4. 2016.08.16 01:03:25 - OpenVPN > ROUTE: CreateIpForwardEntry succeeded with dwForwardMetric1=35 and dwForwardType=4. 2016.08.16 01:03:25 - OpenVPN > Route addition via IPAPI succeeded [adaptive]. 2016.08.16 01:03:25 - OpenVPN > C:\WINDOWS\system32\route.exe ADD 0.0.0.0 MASK 128.0.0.0 10.4.0.1. 2016.08.16 01:03:25 - OpenVPN > ROUTE: CreateIpForwardEntry succeeded with dwForwardMetric1=35 and dwForwardType=4. 2016.08.16 01:03:25 - OpenVPN > Route addition via IPAPI succeeded [adaptive]. 2016.08.16 01:03:25 - OpenVPN > C:\WINDOWS\system32\route.exe ADD 128.0.0.0 MASK 128.0.0.0 10.4.0.1. 2016.08.16 01:03:25 - OpenVPN > ROUTE: CreateIpForwardEntry succeeded with dwForwardMetric1=35 and dwForwardType=4. 2016.08.16 01:03:25 - OpenVPN > Route addition via IPAPI succeeded [adaptive]. 2016.08.16 01:03:25 - Starting Management Interface. 2016.08.16 01:03:25 - OpenVPN > Initialization Sequence CompletedI 2016.08.16 01:03:25 - DNS of a network adapter forced (Killer E2200 Gigabit Ethernet Controller)I 2016.08.16 01:03:25 - DNS of a network adapter forced (TAP-Windows Adapter V9)I 2016.08.16 01:03:25 - Flushing DNSI 2016.08.16 01:03:25 - Checking routeW 2016.08.16 01:03:49 - The remote name could not be resolved: 'velorum_exit.airservers.org'! 2016.08.16 01:03:50 - Disconnecting. 2016.08.16 01:03:50 - Management - Send 'signal SIGTERM'. 2016.08.16 01:03:50 - OpenVpn Management > >INFO:OpenVPN Management Interface Version 1 -- type 'help' for more info. 2016.08.16 01:03:50 - OpenVPN > MANAGEMENT: CMD 'signal SIGTERM'. 2016.08.16 01:03:50 - OpenVPN > SIGTERM received, sending exit notification to peer. 2016.08.16 01:03:55 - OpenVPN > C:\WINDOWS\system32\route.exe DELETE 46.165.208.69 MASK 255.255.255.255 192.168.178.1. 2016.08.16 01:03:55 - OpenVPN > Route deletion via IPAPI succeeded [adaptive]. 2016.08.16 01:03:55 - OpenVPN > C:\WINDOWS\system32\route.exe DELETE 192.168.178.1 MASK 255.255.255.255 192.168.178.1. 2016.08.16 01:03:55 - OpenVPN > Route deletion via IPAPI succeeded [adaptive]. 2016.08.16 01:03:55 - OpenVPN > C:\WINDOWS\system32\route.exe DELETE 0.0.0.0 MASK 128.0.0.0 10.4.0.1. 2016.08.16 01:03:55 - OpenVPN > Route deletion via IPAPI succeeded [adaptive]. 2016.08.16 01:03:55 - OpenVPN > C:\WINDOWS\system32\route.exe DELETE 128.0.0.0 MASK 128.0.0.0 10.4.0.1. 2016.08.16 01:03:55 - OpenVPN > Route deletion via IPAPI succeeded [adaptive]. 2016.08.16 01:03:55 - OpenVPN > Closing TUN/TAP interface. 2016.08.16 01:03:55 - OpenVPN > SIGTERM[soft,exit-with-notification] received, process exiting. 2016.08.16 01:03:55 - Connection terminated.I 2016.08.16 01:03:55 - DNS of a network adapter restored to original settings (Killer E2200 Gigabit Ethernet Controller)I 2016.08.16 01:03:55 - DNS of a network adapter restored to original settings (TAP-Windows Adapter V9)I 2016.08.16 01:03:58 - Checking authorization ...! 2016.08.16 01:03:59 - Connecting to Velorum (Germany, Frankfurt). 2016.08.16 01:03:59 - OpenVPN > OpenVPN 2.3.8 x86_64-w64-mingw32 [sSL (OpenSSL)] [LZO] [iPv6] built on Aug 13 2015. 2016.08.16 01:03:59 - OpenVPN > library versions: OpenSSL 1.0.2d 9 Jul 2015, LZO 2.08. 2016.08.16 01:04:04 - OpenVPN > MANAGEMENT: TCP Socket listening on [AF_INET]127.0.0.1:3100. 2016.08.16 01:04:04 - OpenVPN > Control Channel Authentication: tls-auth using INLINE static key file. 2016.08.16 01:04:04 - OpenVPN > Outgoing Control Channel Authentication: Using 160 bit message hash 'SHA1' for HMAC authentication. 2016.08.16 01:04:04 - OpenVPN > Incoming Control Channel Authentication: Using 160 bit message hash 'SHA1' for HMAC authentication. 2016.08.16 01:04:04 - OpenVPN > Socket Buffers: R=[65536->131072] S=[65536->131072]. 2016.08.16 01:04:04 - OpenVPN > UDPv4 link local: [undef]. 2016.08.16 01:04:04 - OpenVPN > UDPv4 link remote: [AF_INET]46.165.208.69:443. 2016.08.16 01:04:04 - OpenVPN > TLS: Initial packet from [AF_INET]46.165.208.69:443, sid=e1d13a42 792b45f9. 2016.08.16 01:04:04 - OpenVPN > VERIFY OK: depth=1, C=IT, ST=IT, L=Perugia, O=airvpn.org, CN=airvpn.org CA, emailAddress=info@airvpn.org. 2016.08.16 01:04:04 - OpenVPN > Validating certificate key usage. 2016.08.16 01:04:04 - OpenVPN > ++ Certificate has key usage 00a0, expects 00a0. 2016.08.16 01:04:04 - OpenVPN > VERIFY KU OK. 2016.08.16 01:04:04 - OpenVPN > Validating certificate extended key usage. 2016.08.16 01:04:04 - OpenVPN > ++ Certificate has EKU (str) TLS Web Server Authentication, expects TLS Web Server Authentication. 2016.08.16 01:04:04 - OpenVPN > VERIFY EKU OK. 2016.08.16 01:04:04 - OpenVPN > VERIFY OK: depth=0, C=IT, ST=IT, L=Perugia, O=airvpn.org, CN=server, emailAddress=info@airvpn.org. 2016.08.16 01:04:04 - OpenVPN > Data Channel Encrypt: Cipher 'AES-256-CBC' initialized with 256 bit key. 2016.08.16 01:04:04 - OpenVPN > Data Channel Encrypt: Using 160 bit message hash 'SHA1' for HMAC authentication. 2016.08.16 01:04:04 - OpenVPN > Data Channel Decrypt: Cipher 'AES-256-CBC' initialized with 256 bit key. 2016.08.16 01:04:04 - OpenVPN > Data Channel Decrypt: Using 160 bit message hash 'SHA1' for HMAC authentication. 2016.08.16 01:04:04 - OpenVPN > Control Channel: TLSv1.2, cipher TLSv1/SSLv3 DHE-RSA-AES256-GCM-SHA384, 4096 bit RSA. 2016.08.16 01:04:04 - OpenVPN > [server] Peer Connection Initiated with [AF_INET]46.165.208.69:443. 2016.08.16 01:04:06 - OpenVPN > SENT CONTROL [server]: 'PUSH_REQUEST' (status=1). 2016.08.16 01:04:06 - OpenVPN > PUSH: Received control message: 'PUSH_REPLY,redirect-gateway def1 bypass-dhcp,dhcp-option DNS 10.4.0.1,comp-lzo no,route-gateway 10.4.0.1,topology subnet,ping 10,ping-restart 60,ifconfig 10.4.21.208 255.255.0.0'. 2016.08.16 01:04:06 - OpenVPN > OPTIONS IMPORT: timers and/or timeouts modified. 2016.08.16 01:04:06 - OpenVPN > OPTIONS IMPORT: LZO parms modified. 2016.08.16 01:04:06 - OpenVPN > OPTIONS IMPORT: --ifconfig/up options modified. 2016.08.16 01:04:06 - OpenVPN > OPTIONS IMPORT: route options modified. 2016.08.16 01:04:06 - OpenVPN > OPTIONS IMPORT: route-related options modified. 2016.08.16 01:04:06 - OpenVPN > OPTIONS IMPORT: --ip-win32 and/or --dhcp-option options modified. 2016.08.16 01:04:06 - OpenVPN > do_ifconfig, tt->ipv6=0, tt->did_ifconfig_ipv6_setup=0. 2016.08.16 01:04:06 - OpenVPN > open_tun, tt->ipv6=0. 2016.08.16 01:04:06 - OpenVPN > TAP-WIN32 device [Ethernet 2] opened: \\.\Global\{5342D826-9FD5-4B3E-A915-554A736E2963}.tap. 2016.08.16 01:04:06 - OpenVPN > TAP-Windows Driver Version 9.21. 2016.08.16 01:04:06 - OpenVPN > Set TAP-Windows TUN subnet mode network/local/netmask = 10.4.0.0/10.4.21.208/255.255.0.0 [sUCCEEDED]. 2016.08.16 01:04:06 - OpenVPN > Notified TAP-Windows driver to set a DHCP IP/netmask of 10.4.21.208/255.255.0.0 on interface {5342D826-9FD5-4B3E-A915-554A736E2963} [DHCP-serv: 10.4.255.254, lease-time: 31536000]. 2016.08.16 01:04:06 - OpenVPN > Successful ARP Flush on interface [6] {5342D826-9FD5-4B3E-A915-554A736E2963}. 2016.08.16 01:04:12 - OpenVPN > TEST ROUTES: 1/1 succeeded len=0 ret=1 a=0 u/d=up. 2016.08.16 01:04:12 - OpenVPN > C:\WINDOWS\system32\route.exe ADD 46.165.208.69 MASK 255.255.255.255 192.168.178.1. 2016.08.16 01:04:12 - OpenVPN > ROUTE: CreateIpForwardEntry succeeded with dwForwardMetric1=35 and dwForwardType=4. 2016.08.16 01:04:12 - OpenVPN > Route addition via IPAPI succeeded [adaptive]. 2016.08.16 01:04:12 - OpenVPN > C:\WINDOWS\system32\route.exe ADD 192.168.178.1 MASK 255.255.255.255 192.168.178.1 IF 4. 2016.08.16 01:04:12 - OpenVPN > ROUTE: CreateIpForwardEntry succeeded with dwForwardMetric1=35 and dwForwardType=4. 2016.08.16 01:04:12 - OpenVPN > Route addition via IPAPI succeeded [adaptive]. 2016.08.16 01:04:12 - OpenVPN > C:\WINDOWS\system32\route.exe ADD 0.0.0.0 MASK 128.0.0.0 10.4.0.1. 2016.08.16 01:04:12 - OpenVPN > ROUTE: CreateIpForwardEntry succeeded with dwForwardMetric1=35 and dwForwardType=4. 2016.08.16 01:04:12 - OpenVPN > Route addition via IPAPI succeeded [adaptive]. 2016.08.16 01:04:12 - OpenVPN > C:\WINDOWS\system32\route.exe ADD 128.0.0.0 MASK 128.0.0.0 10.4.0.1. 2016.08.16 01:04:12 - OpenVPN > ROUTE: CreateIpForwardEntry succeeded with dwForwardMetric1=35 and dwForwardType=4. 2016.08.16 01:04:12 - OpenVPN > Route addition via IPAPI succeeded [adaptive]. 2016.08.16 01:04:12 - Starting Management Interface. 2016.08.16 01:04:12 - OpenVPN > Initialization Sequence CompletedI 2016.08.16 01:04:12 - DNS of a network adapter forced (Killer E2200 Gigabit Ethernet Controller)I 2016.08.16 01:04:12 - DNS of a network adapter forced (TAP-Windows Adapter V9)I 2016.08.16 01:04:12 - Flushing DNSI 2016.08.16 01:04:12 - Checking routeW 2016.08.16 01:04:36 - The remote name could not be resolved: 'velorum_exit.airservers.org'! 2016.08.16 01:04:36 - Disconnecting. 2016.08.16 01:04:36 - Management - Send 'signal SIGTERM'. 2016.08.16 01:04:36 - OpenVpn Management > >INFO:OpenVPN Management Interface Version 1 -- type 'help' for more info. 2016.08.16 01:04:36 - OpenVPN > MANAGEMENT: CMD 'signal SIGTERM'. 2016.08.16 01:04:36 - OpenVPN > SIGTERM received, sending exit notification to peer. 2016.08.16 01:04:41 - OpenVPN > C:\WINDOWS\system32\route.exe DELETE 46.165.208.69 MASK 255.255.255.255 192.168.178.1. 2016.08.16 01:04:41 - OpenVPN > Route deletion via IPAPI succeeded [adaptive]. 2016.08.16 01:04:41 - OpenVPN > C:\WINDOWS\system32\route.exe DELETE 192.168.178.1 MASK 255.255.255.255 192.168.178.1. 2016.08.16 01:04:41 - OpenVPN > Route deletion via IPAPI succeeded [adaptive]. 2016.08.16 01:04:41 - OpenVPN > C:\WINDOWS\system32\route.exe DELETE 0.0.0.0 MASK 128.0.0.0 10.4.0.1. 2016.08.16 01:04:41 - OpenVPN > Route deletion via IPAPI succeeded [adaptive]. 2016.08.16 01:04:41 - OpenVPN > C:\WINDOWS\system32\route.exe DELETE 128.0.0.0 MASK 128.0.0.0 10.4.0.1. 2016.08.16 01:04:41 - OpenVPN > Route deletion via IPAPI succeeded [adaptive]. 2016.08.16 01:04:41 - OpenVPN > Closing TUN/TAP interface. 2016.08.16 01:04:41 - OpenVPN > SIGTERM[soft,exit-with-notification] received, process exiting. 2016.08.16 01:04:41 - Connection terminated.I 2016.08.16 01:04:41 - DNS of a network adapter restored to original settings (Killer E2200 Gigabit Ethernet Controller)I 2016.08.16 01:04:41 - DNS of a network adapter restored to original settings (TAP-Windows Adapter V9)I 2016.08.16 01:04:44 - Checking authorization ...! 2016.08.16 01:04:44 - Connecting to Velorum (Germany, Frankfurt). 2016.08.16 01:04:44 - OpenVPN > OpenVPN 2.3.8 x86_64-w64-mingw32 [sSL (OpenSSL)] [LZO] [iPv6] built on Aug 13 2015. 2016.08.16 01:04:44 - OpenVPN > library versions: OpenSSL 1.0.2d 9 Jul 2015, LZO 2.08. 2016.08.16 01:04:54 - OpenVPN > MANAGEMENT: TCP Socket listening on [AF_INET]127.0.0.1:3100. 2016.08.16 01:04:54 - OpenVPN > Control Channel Authentication: tls-auth using INLINE static key file. 2016.08.16 01:04:54 - OpenVPN > Outgoing Control Channel Authentication: Using 160 bit message hash 'SHA1' for HMAC authentication. 2016.08.16 01:04:54 - OpenVPN > Incoming Control Channel Authentication: Using 160 bit message hash 'SHA1' for HMAC authentication. 2016.08.16 01:04:54 - OpenVPN > Socket Buffers: R=[65536->131072] S=[65536->131072]. 2016.08.16 01:04:54 - OpenVPN > UDPv4 link local: [undef]. 2016.08.16 01:04:54 - OpenVPN > UDPv4 link remote: [AF_INET]46.165.208.69:443. 2016.08.16 01:04:54 - OpenVPN > TLS: Initial packet from [AF_INET]46.165.208.69:443, sid=4cff9557 558a9623. 2016.08.16 01:04:54 - OpenVPN > VERIFY OK: depth=1, C=IT, ST=IT, L=Perugia, O=airvpn.org, CN=airvpn.org CA, emailAddress=info@airvpn.org. 2016.08.16 01:04:54 - OpenVPN > Validating certificate key usage. 2016.08.16 01:04:54 - OpenVPN > ++ Certificate has key usage 00a0, expects 00a0. 2016.08.16 01:04:54 - OpenVPN > VERIFY KU OK. 2016.08.16 01:04:54 - OpenVPN > Validating certificate extended key usage. 2016.08.16 01:04:54 - OpenVPN > ++ Certificate has EKU (str) TLS Web Server Authentication, expects TLS Web Server Authentication. 2016.08.16 01:04:54 - OpenVPN > VERIFY EKU OK. 2016.08.16 01:04:54 - OpenVPN > VERIFY OK: depth=0, C=IT, ST=IT, L=Perugia, O=airvpn.org, CN=server, emailAddress=info@airvpn.org. 2016.08.16 01:04:55 - OpenVPN > Data Channel Encrypt: Cipher 'AES-256-CBC' initialized with 256 bit key. 2016.08.16 01:04:55 - OpenVPN > Data Channel Encrypt: Using 160 bit message hash 'SHA1' for HMAC authentication. 2016.08.16 01:04:55 - OpenVPN > Data Channel Decrypt: Cipher 'AES-256-CBC' initialized with 256 bit key. 2016.08.16 01:04:55 - OpenVPN > Data Channel Decrypt: Using 160 bit message hash 'SHA1' for HMAC authentication. 2016.08.16 01:04:55 - OpenVPN > Control Channel: TLSv1.2, cipher TLSv1/SSLv3 DHE-RSA-AES256-GCM-SHA384, 4096 bit RSA. 2016.08.16 01:04:55 - OpenVPN > [server] Peer Connection Initiated with [AF_INET]46.165.208.69:443. 2016.08.16 01:04:58 - OpenVPN > SENT CONTROL [server]: 'PUSH_REQUEST' (status=1). 2016.08.16 01:04:58 - OpenVPN > PUSH: Received control message: 'PUSH_REPLY,redirect-gateway def1 bypass-dhcp,dhcp-option DNS 10.4.0.1,comp-lzo no,route-gateway 10.4.0.1,topology subnet,ping 10,ping-restart 60,ifconfig 10.4.21.208 255.255.0.0'. 2016.08.16 01:04:58 - OpenVPN > OPTIONS IMPORT: timers and/or timeouts modified. 2016.08.16 01:04:58 - OpenVPN > OPTIONS IMPORT: LZO parms modified. 2016.08.16 01:04:58 - OpenVPN > OPTIONS IMPORT: --ifconfig/up options modified. 2016.08.16 01:04:58 - OpenVPN > OPTIONS IMPORT: route options modified. 2016.08.16 01:04:58 - OpenVPN > OPTIONS IMPORT: route-related options modified. 2016.08.16 01:04:58 - OpenVPN > OPTIONS IMPORT: --ip-win32 and/or --dhcp-option options modified. 2016.08.16 01:04:58 - OpenVPN > do_ifconfig, tt->ipv6=0, tt->did_ifconfig_ipv6_setup=0. 2016.08.16 01:04:58 - OpenVPN > open_tun, tt->ipv6=0. 2016.08.16 01:04:58 - OpenVPN > TAP-WIN32 device [Ethernet 2] opened: \\.\Global\{5342D826-9FD5-4B3E-A915-554A736E2963}.tap. 2016.08.16 01:04:58 - OpenVPN > TAP-Windows Driver Version 9.21. 2016.08.16 01:04:58 - OpenVPN > Set TAP-Windows TUN subnet mode network/local/netmask = 10.4.0.0/10.4.21.208/255.255.0.0 [sUCCEEDED]. 2016.08.16 01:04:58 - OpenVPN > Notified TAP-Windows driver to set a DHCP IP/netmask of 10.4.21.208/255.255.0.0 on interface {5342D826-9FD5-4B3E-A915-554A736E2963} [DHCP-serv: 10.4.255.254, lease-time: 31536000]. 2016.08.16 01:04:58 - OpenVPN > Successful ARP Flush on interface [6] {5342D826-9FD5-4B3E-A915-554A736E2963}. 2016.08.16 01:05:03 - OpenVPN > TEST ROUTES: 1/1 succeeded len=0 ret=1 a=0 u/d=up. 2016.08.16 01:05:03 - OpenVPN > C:\WINDOWS\system32\route.exe ADD 46.165.208.69 MASK 255.255.255.255 192.168.178.1. 2016.08.16 01:05:03 - OpenVPN > ROUTE: CreateIpForwardEntry succeeded with dwForwardMetric1=35 and dwForwardType=4. 2016.08.16 01:05:03 - OpenVPN > Route addition via IPAPI succeeded [adaptive]. 2016.08.16 01:05:03 - OpenVPN > C:\WINDOWS\system32\route.exe ADD 192.168.178.1 MASK 255.255.255.255 192.168.178.1 IF 4. 2016.08.16 01:05:03 - OpenVPN > ROUTE: CreateIpForwardEntry succeeded with dwForwardMetric1=35 and dwForwardType=4. 2016.08.16 01:05:03 - OpenVPN > Route addition via IPAPI succeeded [adaptive]. 2016.08.16 01:05:03 - OpenVPN > C:\WINDOWS\system32\route.exe ADD 0.0.0.0 MASK 128.0.0.0 10.4.0.1. 2016.08.16 01:05:03 - OpenVPN > ROUTE: CreateIpForwardEntry succeeded with dwForwardMetric1=35 and dwForwardType=4. 2016.08.16 01:05:03 - OpenVPN > Route addition via IPAPI succeeded [adaptive]. 2016.08.16 01:05:03 - OpenVPN > C:\WINDOWS\system32\route.exe ADD 128.0.0.0 MASK 128.0.0.0 10.4.0.1. 2016.08.16 01:05:03 - OpenVPN > ROUTE: CreateIpForwardEntry succeeded with dwForwardMetric1=35 and dwForwardType=4. 2016.08.16 01:05:03 - OpenVPN > Route addition via IPAPI succeeded [adaptive]. 2016.08.16 01:05:03 - Starting Management Interface. 2016.08.16 01:05:03 - OpenVPN > Initialization Sequence CompletedI 2016.08.16 01:05:03 - DNS of a network adapter forced (Killer E2200 Gigabit Ethernet Controller)I 2016.08.16 01:05:03 - DNS of a network adapter forced (TAP-Windows Adapter V9)I 2016.08.16 01:05:03 - Flushing DNSI 2016.08.16 01:05:03 - Checking routeW 2016.08.16 01:05:27 - The remote name could not be resolved: 'velorum_exit.airservers.org'! 2016.08.16 01:05:27 - Disconnecting. 2016.08.16 01:05:27 - Management - Send 'signal SIGTERM'. 2016.08.16 01:05:27 - OpenVpn Management > >INFO:OpenVPN Management Interface Version 1 -- type 'help' for more info. 2016.08.16 01:05:27 - OpenVPN > MANAGEMENT: CMD 'signal SIGTERM'. 2016.08.16 01:05:27 - OpenVPN > SIGTERM received, sending exit notification to peer. 2016.08.16 01:05:32 - OpenVPN > C:\WINDOWS\system32\route.exe DELETE 46.165.208.69 MASK 255.255.255.255 192.168.178.1. 2016.08.16 01:05:32 - OpenVPN > Route deletion via IPAPI succeeded [adaptive]. 2016.08.16 01:05:32 - OpenVPN > C:\WINDOWS\system32\route.exe DELETE 192.168.178.1 MASK 255.255.255.255 192.168.178.1. 2016.08.16 01:05:32 - OpenVPN > Route deletion via IPAPI succeeded [adaptive]. 2016.08.16 01:05:32 - OpenVPN > C:\WINDOWS\system32\route.exe DELETE 0.0.0.0 MASK 128.0.0.0 10.4.0.1. 2016.08.16 01:05:32 - OpenVPN > Route deletion via IPAPI succeeded [adaptive]. 2016.08.16 01:05:32 - OpenVPN > C:\WINDOWS\system32\route.exe DELETE 128.0.0.0 MASK 128.0.0.0 10.4.0.1. 2016.08.16 01:05:32 - OpenVPN > Route deletion via IPAPI succeeded [adaptive]. 2016.08.16 01:05:32 - OpenVPN > Closing TUN/TAP interface. 2016.08.16 01:05:32 - OpenVPN > SIGTERM[soft,exit-with-notification] received, process exiting. 2016.08.16 01:05:32 - Connection terminated.I 2016.08.16 01:05:32 - DNS of a network adapter restored to original settings (Killer E2200 Gigabit Ethernet Controller)I 2016.08.16 01:05:32 - DNS of a network adapter restored to original settings (TAP-Windows Adapter V9)I 2016.08.16 01:05:32 - Cancel requested.I 2016.08.16 01:05:32 - IPv6 restored.! 2016.08.16 01:05:32 - Session terminated. thank you Quote Hide Firas22's signature Hide all signatures Share this post Link to post
Firas22 1 Posted ... Ok I have uninstalled eddie can any one please look here and tell me if I have made a Mistake ? I have unchecked a few things here if there is something I need to check it back please let me know Alternative if Pictures dont show http://pasteboard.co/978bYsOqI.png http://pasteboard.co/978ZXkmJu.png http://pasteboard.co/UvVFGSp4.png http://pasteboard.co/979ze2NCB.png thank you Quote Hide Firas22's signature Hide all signatures Share this post Link to post
Firas22 1 Posted ... Ok I have uninstalled and installed vpn 8 times i have installed tap-windows-9.9.2_3 just to see whats going on nothing is working , i cant connect to anything every time I go to ip4 properties there is this number that is stuck I chose automatic and it comes back the same number look here please http://pasteboard.co/VfIkMtGC.png I wanted to upload Logs But my luck instead of copying them I hit the clear button Will be waiting for any to help me out I just dont get it why i cant connect to anything anymore Here is my host file Just incase I did something wrong please look at it and let me know # BitDefender has clean hosts file127.0.0.1 localhost#Original code from this file#:# Copyright © 1993-2009 Microsoft Corp.#:##:# This is a sample HOSTS file used by Microsoft TCP/IP for Windows.#:##:# This file contains the mappings of IP addresses to host names. Each#:# entry should be kept on an individual line. The IP address should#:# be placed in the first column followed by the corresponding host name.#:# The IP address and the host name should be separated by at least one#:# space.#:##:# Additionally, comments (such as these) may be inserted on individual#:# lines or following the machine name denoted by a '#' symbol.#:##:# For example:#:##:# 102.54.94.97 rhino.acme.com # source server#:# 38.25.63.10 x.acme.com # x client host#:# localhost name resolution is handled within DNS itself.#:# 127.0.0.1 localhost#:# ::1 localhost#:0.0.0.0 vortex.data.microsoft.com#:0.0.0.0 vortex-win.data.microsoft.com#:0.0.0.0 telecommand.telemetry.microsoft.com#:0.0.0.0 telecommand.telemetry.microsoft.com.nsatc.net#:0.0.0.0 oca.telemetry.microsoft.com#:0.0.0.0 oca.telemetry.microsoft.com.nsatc.net#:0.0.0.0 sqm.telemetry.microsoft.com#:0.0.0.0 sqm.telemetry.microsoft.com.nsatc.net#:0.0.0.0 watson.telemetry.microsoft.com#:0.0.0.0 watson.telemetry.microsoft.com.nsatc.net#:0.0.0.0 redir.metaservices.microsoft.com#:0.0.0.0 choice.microsoft.com#:0.0.0.0 choice.microsoft.com.nsatc.net#:0.0.0.0 df.telemetry.microsoft.com#:0.0.0.0 reports.wes.df.telemetry.microsoft.com#:0.0.0.0 wes.df.telemetry.microsoft.com#:0.0.0.0 services.wes.df.telemetry.microsoft.com#:0.0.0.0 sqm.df.telemetry.microsoft.com#:0.0.0.0 telemetry.microsoft.com#:0.0.0.0 watson.ppe.telemetry.microsoft.com#:0.0.0.0 telemetry.appex.bing.net#:0.0.0.0 telemetry.urs.microsoft.com#:0.0.0.0 telemetry.appex.bing.net:443#:0.0.0.0 settings-sandbox.data.microsoft.com#:0.0.0.0 vortex-sandbox.data.microsoft.com#:0.0.0.0 survey.watson.microsoft.com#:0.0.0.0 watson.live.com#:0.0.0.0 watson.microsoft.com#:0.0.0.0 statsfe2.ws.microsoft.com#:0.0.0.0 corpext.msitadfs.glbdns2.microsoft.com#:0.0.0.0 compatexchange.cloudapp.net#:0.0.0.0 cs1.wpc.v0cdn.net#:0.0.0.0 a-0001.a-msedge.net#:0.0.0.0 statsfe2.update.microsoft.com.akadns.net#:0.0.0.0 sls.update.microsoft.com.akadns.net#:0.0.0.0 fe2.update.microsoft.com.akadns.net#:0.0.0.0 diagnostics.support.microsoft.com#:0.0.0.0 corp.sts.microsoft.com#:0.0.0.0 statsfe1.ws.microsoft.com#:0.0.0.0 pre.footprintpredict.com#:0.0.0.0 i1.services.social.microsoft.com#:0.0.0.0 i1.services.social.microsoft.com.nsatc.net#:0.0.0.0 feedback.windows.com#:0.0.0.0 feedback.microsoft-hohm.com#:0.0.0.0 feedback.search.microsoft.com#:0.0.0.0 rad.msn.com#:0.0.0.0 preview.msn.com#:0.0.0.0 ad.doubleclick.net#:0.0.0.0 ads.msn.com#:0.0.0.0 ads1.msads.net#:0.0.0.0 ads1.msn.com#:0.0.0.0 a.ads1.msn.com#:0.0.0.0 a.ads2.msn.com#:0.0.0.0 adnexus.net#:0.0.0.0 adnxs.com#:0.0.0.0 az361816.vo.msecnd.net#:0.0.0.0 az512334.vo.msecnd.net#:0.0.0.0 statsfe2.update.microsoft.com.akadns.net#:0.0.0.0 fe2.update.microsoft.com.akadns.net#:0.0.0.0 s0.2mdn.net#:0.0.0.0 survey.watson.microsoft.com#:0.0.0.0 view.atdmt.com#:0.0.0.0 watson.microsoft.com#:0.0.0.0 watson.ppe.telemetry.microsoft.com#:0.0.0.0 vortex.data.microsoft.com#:0.0.0.0 vortex-win.data.microsoft.com#:0.0.0.0 telecommand.telemetry.microsoft.com#:0.0.0.0 telecommand.telemetry.microsoft.com.nsatc.net#:0.0.0.0 oca.telemetry.microsoft.com#:0.0.0.0 sqm.telemetry.microsoft.com#:0.0.0.0 sqm.telemetry.microsoft.com.nsatc.net#:0.0.0.0 watson.telemetry.microsoft.com#:0.0.0.0 watson.telemetry.microsoft.com.nsatc.net#:0.0.0.0 redir.metaservices.microsoft.com#:0.0.0.0 choice.microsoft.com#:0.0.0.0 choice.microsoft.com.nsatc.net#:0.0.0.0 wes.df.telemetry.microsoft.com#:0.0.0.0 services.wes.df.telemetry.microsoft.com#:0.0.0.0 sqm.df.telemetry.microsoft.com#:0.0.0.0 telemetry.microsoft.com#:0.0.0.0 telemetry.appex.bing.net#:0.0.0.0 telemetry.urs.microsoft.com#:0.0.0.0 settings-sandbox.data.microsoft.com#:0.0.0.0 watson.live.com#:0.0.0.0 statsfe2.ws.microsoft.com#:0.0.0.0 corpext.msitadfs.glbdns2.microsoft.com#:0.0.0.0 compatexchange.cloudapp.net#:0.0.0.0 a-0001.a-msedge.net#:0.0.0.0 sls.update.microsoft.com.akadns.net#:0.0.0.0 diagnostics.support.microsoft.com#:0.0.0.0 corp.sts.microsoft.com#:0.0.0.0 statsfe1.ws.microsoft.com#:0.0.0.0 feedback.windows.com#:0.0.0.0 feedback.microsoft-hohm.com#:0.0.0.0 feedback.search.microsoft.com#:0.0.0.0 rad.msn.com#:0.0.0.0 preview.msn.com#:0.0.0.0 ad.doubleclick.net#:0.0.0.0 ads.msn.com#:0.0.0.0 ads1.msads.net#:0.0.0.0 ads1.msn.com#:0.0.0.0 a.ads1.msn.com#:0.0.0.0 a.ads2.msn.com#:0.0.0.0 adnexus.net#:0.0.0.0 adnxs.com#:0.0.0.0 az361816.vo.msecnd.net#:0.0.0.0 az512334.vo.msecnd.net#:0.0.0.0 ssw.live.com#:0.0.0.0 ca.telemetry.microsoft.com#:0.0.0.0 i1.services.social.microsoft.com#:0.0.0.0 df.telemetry.microsoft.com#:0.0.0.0 reports.wes.df.telemetry.microsoft.com#:0.0.0.0 cs1.wpc.v0cdn.net#:0.0.0.0 vortex-sandbox.data.microsoft.com#:0.0.0.0 oca.telemetry.microsoft.com.nsatc.net#:0.0.0.0 pre.footprintpredict.com#:0.0.0.0 spynet2.microsoft.com#:0.0.0.0 spynetalt.microsoft.com#:0.0.0.0 fe3.delivery.dsp.mp.microsoft.com.nsatc.net#:0.0.0.0 cache.datamart.windows.com#:0.0.0.0 db3wns2011111.wns.windows.com#:0.0.0.0 settings-win.data.microsoft.com#:0.0.0.0 v10.vortex-win.data.microsoft.com#:0.0.0.0 win10.ipv6.microsoft.com#:0.0.0.0 ca.telemetry.microsoft.com#:0.0.0.0 i1.services.social.microsoft.com.nsatc.net#:0.0.0.0 msnbot-207-46-194-33.search.msn.com#:0.0.0.0 settings.data.microsof.com#:0.0.0.0 telecommand.telemetry.microsoft.com.nsat-c.net216.58.208.46 google.com52.3.150.1 keepersecurity.com216.58.208.37 gmail.com184.172.52.106 www.tenforums.com54.230.45.162 www.deviantart.com209.58.128.90 www.xda-developers.com23.235.33.196 www.filehippo.com185.21.102.73 www.f2ko.de172.227.137.219 www.steamcommunity.com213.152.180.16 www.airvpn.org213.152.180.16 airvpn.org104.25.126.10 www.cheathappens.com104.25.126.10 cheathappens.com thank you Quote Hide Firas22's signature Hide all signatures Share this post Link to post
LZ1 676 Posted ... Hello ! Perhaps the easiest thing for you, would be a re-install of your OS, as you seem to have many issues and perhaps programs which interfere with Eddie. I think it's of questionable value to provide Eddie logs and then uninstall Eddie, however. Sent to you from me with datalove Quote Hide LZ1's signature Hide all signatures Hi there, are you new to AirVPN? Many of your questions are already answered in this guide. You may also read the Eddie Android FAQ. Moderators do not speak on behalf of AirVPN. Only the Official Staff account does. Please also do not run Tor Exit Servers behind AirVPN, thank you. Did you make a guide or how-to for something? Then contact me to get it listed in my new user guide's Guides Section, so that the community can find it more easily. Share this post Link to post
LZ1 676 Posted ... You've been posting a lot. I recommend that you try to keep your posts confined to one thread, insofar as this is possible. It makes it easier and more manageable for everyone; including yourself. I think your problem might be that your version of OpenVPN is outdated. There are newer TAP drivers available, besides the one you mentioned. If you try out the Beta version of Eddie, you'll automatically get the newest one. Otherwise please go to around page 3, in the stickied thread about TAP drivers, in the troubleshooting forum and read what giganerd said. Without logs we're pretty blind as to what the problem is. You could perhaps just wait until the problem occurs again though and get the logs then. You'll also have to be specific as to what number is "stuck". If it's in the DNS field for instance and mentions 10.4 whatever, it might be Airs. I previously told you to simply make sure that all adapters, both IPv4 and DNS fields, were set to obtain automatically and then click ok. (if you were having issues, as it can sometimes solve them). Constant re-installs will not automatically help you find out what the problem is. For that, we do need logs. Also, as an aside, make sure you don't have any anti-virus software messing with Air software, as you did recently make a thread about such software. You can try to look for exceptions lists in that software and see if you can add Eddie and openvpn.exe to it. Finally, you can either try out different protocols in the Eddie protocol tab or make sure your firewall is working fine too, by resetting it. Lastly, you're also welcome to ask AirVPN support, if you haven't already. But they'll need more information about the issue, just like us. Sent to you from me with datalove Quote Hide LZ1's signature Hide all signatures Hi there, are you new to AirVPN? Many of your questions are already answered in this guide. You may also read the Eddie Android FAQ. Moderators do not speak on behalf of AirVPN. Only the Official Staff account does. Please also do not run Tor Exit Servers behind AirVPN, thank you. Did you make a guide or how-to for something? Then contact me to get it listed in my new user guide's Guides Section, so that the community can find it more easily. Share this post Link to post
TheDieselBoiler 5 Posted ... Use CCleaner to clean out your PC, maybe that will clean some issues with OpenVPN, and uninstall any previous OpenVPN drivers and programs. Also check if your ISP is blocking AirVPN traffic. Maybe check your firewall options too. Quote Hide TheDieselBoiler's signature Hide all signatures - Share this post Link to post
Guest Posted ... I only just got to read your thread, I 2016.08.16 01:03:25 - Checking routeW 2016.08.16 01:03:49 - The remote name could not be resolved: 'velorum_exit.airservers.org' this line is persistantly appearing with different servers, it seems you are having DNS problems and I do not know what could be cause or how we could fix it since I don't have access to your system, but we can try and test with something, if you'd be so kind try and install the experimental AirVPN client then open settings and go to DNS, on the DNS switch mode set it to Disabled and unmark check AirVPN DNS, then save it and try and connect. IF there are issues come back here with logs... infact even if there isn't issues I'd appreciate logs it'd be useful to try and find out what is different this time around. Quote Share this post Link to post
Firas22 1 Posted ... I only just got to read your thread, I 2016.08.16 01:03:25 - Checking routeW 2016.08.16 01:03:49 - The remote name could not be resolved: 'velorum_exit.airservers.org' this line is persistantly appearing with different servers, it seems you are having DNS problems and I do not know what could be cause or how we could fix it since I don't have access to your system, but we can try and test with something, if you'd be so kind try and install the experimental AirVPN client then open settings and go to DNS, on the DNS switch mode set it to Disabled and unmark check AirVPN DNS, then save it and try and connect. IF there are issues come back here with logs... infact even if there isn't issues I'd appreciate logs it'd be useful to try and find out what is different this time around. Thank you for your Reply can you please tell me where can i find the // experimental AirVPN // ? Second @ LZ1 I thank you for your help as always I have fallowed your instructions and did a new fresh windows 10 install , I have set up my PC to the point where I want it to be , and have don 2 backups just to be on the safe side each backup is on a different HDDand Before i was on windows 10 Home 64 version 1607 now i am on the OEM version windows 10 1511 Please look at this Link you will understand me more https://support.microsoft.com/en-us/help/12387/windows-10-update-history After all of this windows is clean from any spyware malware or anything els ,, so I installed airvpn and Indeed i got connected but after 5 minutes or so my internet icon shows i have no internet please look here http://pasteboard.co/9UkWt2ikg.png But I can still surf the internet and download ,, BUT why is it already showing bad signs just like it did it before ,, these are the same signs what happened last time So I am certian that me the pc and windows Version have nothing to do with the problem I hop you and the staff here can look into my Issue many thanks and here is my very first LOG I 2016.08.18 01:19:32 - AirVPN client version: 2.10.3 / x64, System: Windows, Name: Microsoft Windows NT 6.2.9200.0 / x64. 2016.08.18 01:19:32 - Reading options from C:\Users\NXTGen3\AppData\Local\AirVPN\AirVPN.xml. 2016.08.18 01:19:32 - Profile options not found, using defaults.. 2016.08.18 01:19:33 - Data Path: C:\Users\NXTGen3\AppData\Local\AirVPN. 2016.08.18 01:19:33 - App Path: C:\Program Files\AirVPN. 2016.08.18 01:19:33 - Executable Path: C:\Program Files\AirVPN\AirVPN.exe. 2016.08.18 01:19:33 - Command line arguments (1): path="home". 2016.08.18 01:19:33 - Operating System: Microsoft Windows NT 6.2.9200.0. 2016.08.18 01:19:33 - Updating systems & servers data .... 2016.08.18 01:19:33 - Cannot find tunnel adapter.. 2016.08.18 01:19:33 - Systems & servers data update completedE 2016.08.18 01:19:33 - OpenVPN Driver - Not availableI 2016.08.18 01:19:33 - OpenVPN - Version: OpenVPN 2.3.8 (C:\Program Files\AirVPN\openvpn.exe)I 2016.08.18 01:19:33 - SSH - Version: plink 0.63 (C:\Program Files\AirVPN\plink.exe)I 2016.08.18 01:19:33 - SSL - Version: stunnel 5.17 (C:\Program Files\AirVPN\stunnel.exe)! 2016.08.18 01:19:33 - ReadyI 2016.08.18 01:20:13 - Checking login ...! 2016.08.18 01:20:14 - Logged in.I 2016.08.18 01:21:37 - Session starting.. 2016.08.18 01:21:37 - Cannot find tunnel adapter.! 2016.08.18 01:21:37 - Installing tunnel driverI 2016.08.18 01:21:46 - IPv6 disabled.I 2016.08.18 01:21:46 - Checking authorization ...! 2016.08.18 01:21:46 - Connecting to Tauri (Germany, Frankfurt). 2016.08.18 01:21:46 - OpenVPN > OpenVPN 2.3.8 x86_64-w64-mingw32 [sSL (OpenSSL)] [LZO] [iPv6] built on Aug 13 2015. 2016.08.18 01:21:46 - OpenVPN > library versions: OpenSSL 1.0.2d 9 Jul 2015, LZO 2.08. 2016.08.18 01:21:46 - OpenVPN > MANAGEMENT: TCP Socket listening on [AF_INET]127.0.0.1:3100. 2016.08.18 01:21:46 - OpenVPN > Control Channel Authentication: tls-auth using INLINE static key file. 2016.08.18 01:21:46 - OpenVPN > Outgoing Control Channel Authentication: Using 160 bit message hash 'SHA1' for HMAC authentication. 2016.08.18 01:21:46 - OpenVPN > Incoming Control Channel Authentication: Using 160 bit message hash 'SHA1' for HMAC authentication. 2016.08.18 01:21:46 - OpenVPN > Socket Buffers: R=[65536->131072] S=[65536->131072]. 2016.08.18 01:21:46 - OpenVPN > UDPv4 link local: [undef]. 2016.08.18 01:21:46 - OpenVPN > UDPv4 link remote: [AF_INET]46.165.208.65:443. 2016.08.18 01:21:46 - OpenVPN > TLS: Initial packet from [AF_INET]46.165.208.65:443, sid=b169e80f 00d3d44a. 2016.08.18 01:21:46 - OpenVPN > VERIFY OK: depth=1, C=IT, ST=IT, L=Perugia, O=airvpn.org, CN=airvpn.org CA, emailAddress=info@airvpn.org. 2016.08.18 01:21:46 - OpenVPN > Validating certificate key usage. 2016.08.18 01:21:46 - OpenVPN > ++ Certificate has key usage 00a0, expects 00a0. 2016.08.18 01:21:46 - OpenVPN > VERIFY KU OK. 2016.08.18 01:21:46 - OpenVPN > Validating certificate extended key usage. 2016.08.18 01:21:46 - OpenVPN > ++ Certificate has EKU (str) TLS Web Server Authentication, expects TLS Web Server Authentication. 2016.08.18 01:21:46 - OpenVPN > VERIFY EKU OK. 2016.08.18 01:21:46 - OpenVPN > VERIFY OK: depth=0, C=IT, ST=IT, L=Perugia, O=airvpn.org, CN=server, emailAddress=info@airvpn.org. 2016.08.18 01:21:47 - OpenVPN > Data Channel Encrypt: Cipher 'AES-256-CBC' initialized with 256 bit key. 2016.08.18 01:21:47 - OpenVPN > Data Channel Encrypt: Using 160 bit message hash 'SHA1' for HMAC authentication. 2016.08.18 01:21:47 - OpenVPN > Data Channel Decrypt: Cipher 'AES-256-CBC' initialized with 256 bit key. 2016.08.18 01:21:47 - OpenVPN > Data Channel Decrypt: Using 160 bit message hash 'SHA1' for HMAC authentication. 2016.08.18 01:21:47 - OpenVPN > Control Channel: TLSv1.2, cipher TLSv1/SSLv3 DHE-RSA-AES256-GCM-SHA384, 4096 bit RSA. 2016.08.18 01:21:47 - OpenVPN > [server] Peer Connection Initiated with [AF_INET]46.165.208.65:443. 2016.08.18 01:21:49 - OpenVPN > SENT CONTROL [server]: 'PUSH_REQUEST' (status=1). 2016.08.18 01:21:49 - OpenVPN > PUSH: Received control message: 'PUSH_REPLY,redirect-gateway def1 bypass-dhcp,dhcp-option DNS 10.4.0.1,comp-lzo no,route-gateway 10.4.0.1,topology subnet,ping 10,ping-restart 60,ifconfig 10.4.27.60 255.255.0.0'. 2016.08.18 01:21:49 - OpenVPN > OPTIONS IMPORT: timers and/or timeouts modified. 2016.08.18 01:21:49 - OpenVPN > OPTIONS IMPORT: LZO parms modified. 2016.08.18 01:21:49 - OpenVPN > OPTIONS IMPORT: --ifconfig/up options modified. 2016.08.18 01:21:49 - OpenVPN > OPTIONS IMPORT: route options modified. 2016.08.18 01:21:49 - OpenVPN > OPTIONS IMPORT: route-related options modified. 2016.08.18 01:21:49 - OpenVPN > OPTIONS IMPORT: --ip-win32 and/or --dhcp-option options modified. 2016.08.18 01:21:49 - OpenVPN > do_ifconfig, tt->ipv6=0, tt->did_ifconfig_ipv6_setup=0. 2016.08.18 01:21:49 - OpenVPN > open_tun, tt->ipv6=0. 2016.08.18 01:21:49 - OpenVPN > TAP-WIN32 device [Ethernet 2] opened: \\.\Global\{3A8EBBF0-65E6-4014-89B1-E9F76DAA9B3E}.tap. 2016.08.18 01:21:49 - OpenVPN > TAP-Windows Driver Version 9.21. 2016.08.18 01:21:49 - OpenVPN > Set TAP-Windows TUN subnet mode network/local/netmask = 10.4.0.0/10.4.27.60/255.255.0.0 [sUCCEEDED]. 2016.08.18 01:21:49 - OpenVPN > Notified TAP-Windows driver to set a DHCP IP/netmask of 10.4.27.60/255.255.0.0 on interface {3A8EBBF0-65E6-4014-89B1-E9F76DAA9B3E} [DHCP-serv: 10.4.255.254, lease-time: 31536000]. 2016.08.18 01:21:49 - OpenVPN > Successful ARP Flush on interface [18] {3A8EBBF0-65E6-4014-89B1-E9F76DAA9B3E}. 2016.08.18 01:21:54 - OpenVPN > TEST ROUTES: 1/1 succeeded len=0 ret=1 a=0 u/d=up. 2016.08.18 01:21:54 - OpenVPN > C:\Windows\system32\route.exe ADD 46.165.208.65 MASK 255.255.255.255 192.168.178.1. 2016.08.18 01:21:54 - OpenVPN > ROUTE: CreateIpForwardEntry succeeded with dwForwardMetric1=20 and dwForwardType=4. 2016.08.18 01:21:54 - OpenVPN > Route addition via IPAPI succeeded [adaptive]. 2016.08.18 01:21:54 - OpenVPN > C:\Windows\system32\route.exe ADD 192.168.178.1 MASK 255.255.255.255 192.168.178.1 IF 10. 2016.08.18 01:21:54 - OpenVPN > ROUTE: CreateIpForwardEntry succeeded with dwForwardMetric1=20 and dwForwardType=4. 2016.08.18 01:21:54 - OpenVPN > Route addition via IPAPI succeeded [adaptive]. 2016.08.18 01:21:54 - OpenVPN > C:\Windows\system32\route.exe ADD 0.0.0.0 MASK 128.0.0.0 10.4.0.1. 2016.08.18 01:21:54 - OpenVPN > ROUTE: CreateIpForwardEntry succeeded with dwForwardMetric1=20 and dwForwardType=4. 2016.08.18 01:21:54 - OpenVPN > Route addition via IPAPI succeeded [adaptive]. 2016.08.18 01:21:54 - OpenVPN > C:\Windows\system32\route.exe ADD 128.0.0.0 MASK 128.0.0.0 10.4.0.1. 2016.08.18 01:21:54 - OpenVPN > ROUTE: CreateIpForwardEntry succeeded with dwForwardMetric1=20 and dwForwardType=4. 2016.08.18 01:21:54 - OpenVPN > Route addition via IPAPI succeeded [adaptive]. 2016.08.18 01:21:54 - Starting Management Interface. 2016.08.18 01:21:54 - OpenVPN > Initialization Sequence CompletedI 2016.08.18 01:21:54 - DNS of a network adapter forced (Killer e2200 Gigabit Ethernet Controller)I 2016.08.18 01:21:54 - DNS of a network adapter forced (TAP-Windows Adapter V9)I 2016.08.18 01:21:54 - Flushing DNSI 2016.08.18 01:21:54 - Checking routeI 2016.08.18 01:22:18 - Checking DNS! 2016.08.18 01:22:19 - Connected.. 2016.08.18 01:22:19 - OpenVPN > MANAGEMENT: Client connected from [AF_INET]127.0.0.1:3100. 2016.08.18 01:22:19 - OpenVpn Management > >INFO:OpenVPN Management Interface Version 1 -- type 'help' for more info. 2016.08.18 01:50:27 - Updating systems & servers data .... 2016.08.18 01:50:29 - Systems & servers data update completed NOT if you look at the bottom of the logs it says can not find tunnel adapter Quote Hide Firas22's signature Hide all signatures Share this post Link to post
zhang888 1067 Posted ... @Firas22 please write a short description of the issue you have.There are very clear instructions on how to post issues and/or bug reports in the sticky threads. The logs you posted so far indicate a DNS issue.Please reset all your network adapter settings and try again. Also, if you keep the posts with the bare minimum info, it will take less time to solve it. Quote Hide zhang888's signature Hide all signatures Occasional moderator, sometimes BOFH. Opinions are my own, except when my wife disagrees. Share this post Link to post
Firas22 1 Posted ... @Firas22 please write a short description of the issue you have.There are very clear instructions on how to post issues and/or bug reports in the sticky threads. The logs you posted so far indicate a DNS issue.Please reset all your network adapter settings and try again. Also, if you keep the posts with the bare minimum info, it will take less time to solve it. OK thank youmore log info because it is disconnecting again I 2016.08.18 03:32:52 - AirVPN client version: 2.10.3 / x64, System: Windows, Name: Microsoft Windows NT 6.2.9200.0 / x64. 2016.08.18 03:32:52 - Reading options from C:\Users\NXTGen3\AppData\Local\AirVPN\AirVPN.xml. 2016.08.18 03:32:52 - Data Path: C:\Users\NXTGen3\AppData\Local\AirVPN. 2016.08.18 03:32:52 - App Path: C:\Program Files\AirVPN. 2016.08.18 03:32:52 - Executable Path: C:\Program Files\AirVPN\AirVPN.exe. 2016.08.18 03:32:52 - Command line arguments (1): path="home". 2016.08.18 03:32:52 - Operating System: Microsoft Windows NT 6.2.9200.0. 2016.08.18 03:32:52 - Updating systems & servers data ...I 2016.08.18 03:32:53 - OpenVPN Driver - TAP-Windows Adapter V9, version 9.21.1I 2016.08.18 03:32:53 - OpenVPN - Version: OpenVPN 2.3.8 (C:\Program Files\AirVPN\openvpn.exe)I 2016.08.18 03:32:53 - SSH - Version: plink 0.63 (C:\Program Files\AirVPN\plink.exe)I 2016.08.18 03:32:53 - SSL - Version: stunnel 5.17 (C:\Program Files\AirVPN\stunnel.exe)! 2016.08.18 03:32:53 - Ready. 2016.08.18 03:32:57 - Systems & servers data update completedI 2016.08.18 03:33:00 - Session starting.I 2016.08.18 03:33:01 - IPv6 disabled.I 2016.08.18 03:33:01 - Checking authorization ...! 2016.08.18 03:33:01 - Connecting to Tauri (Germany, Frankfurt). 2016.08.18 03:33:01 - OpenVPN > OpenVPN 2.3.8 x86_64-w64-mingw32 [sSL (OpenSSL)] [LZO] [iPv6] built on Aug 13 2015. 2016.08.18 03:33:01 - OpenVPN > library versions: OpenSSL 1.0.2d 9 Jul 2015, LZO 2.08. 2016.08.18 03:33:01 - OpenVPN > MANAGEMENT: TCP Socket listening on [AF_INET]127.0.0.1:3100. 2016.08.18 03:33:01 - OpenVPN > Control Channel Authentication: tls-auth using INLINE static key file. 2016.08.18 03:33:01 - OpenVPN > Outgoing Control Channel Authentication: Using 160 bit message hash 'SHA1' for HMAC authentication. 2016.08.18 03:33:01 - OpenVPN > Incoming Control Channel Authentication: Using 160 bit message hash 'SHA1' for HMAC authentication. 2016.08.18 03:33:01 - OpenVPN > Socket Buffers: R=[65536->131072] S=[65536->131072]. 2016.08.18 03:33:01 - OpenVPN > UDPv4 link local: [undef]. 2016.08.18 03:33:01 - OpenVPN > UDPv4 link remote: [AF_INET]46.165.208.65:443. 2016.08.18 03:33:04 - OpenVPN > TLS: Initial packet from [AF_INET]46.165.208.65:443, sid=aff3563e 2e0c72ca. 2016.08.18 03:33:04 - OpenVPN > VERIFY OK: depth=1, C=IT, ST=IT, L=Perugia, O=airvpn.org, CN=airvpn.org CA, emailAddress=info@airvpn.org. 2016.08.18 03:33:04 - OpenVPN > Validating certificate key usage. 2016.08.18 03:33:04 - OpenVPN > ++ Certificate has key usage 00a0, expects 00a0. 2016.08.18 03:33:04 - OpenVPN > VERIFY KU OK. 2016.08.18 03:33:04 - OpenVPN > Validating certificate extended key usage. 2016.08.18 03:33:04 - OpenVPN > ++ Certificate has EKU (str) TLS Web Server Authentication, expects TLS Web Server Authentication. 2016.08.18 03:33:04 - OpenVPN > VERIFY EKU OK. 2016.08.18 03:33:04 - OpenVPN > VERIFY OK: depth=0, C=IT, ST=IT, L=Perugia, O=airvpn.org, CN=server, emailAddress=info@airvpn.org. 2016.08.18 03:33:05 - OpenVPN > Data Channel Encrypt: Cipher 'AES-256-CBC' initialized with 256 bit key. 2016.08.18 03:33:05 - OpenVPN > Data Channel Encrypt: Using 160 bit message hash 'SHA1' for HMAC authentication. 2016.08.18 03:33:05 - OpenVPN > Data Channel Decrypt: Cipher 'AES-256-CBC' initialized with 256 bit key. 2016.08.18 03:33:05 - OpenVPN > Data Channel Decrypt: Using 160 bit message hash 'SHA1' for HMAC authentication. 2016.08.18 03:33:05 - OpenVPN > Control Channel: TLSv1.2, cipher TLSv1/SSLv3 DHE-RSA-AES256-GCM-SHA384, 4096 bit RSA. 2016.08.18 03:33:05 - OpenVPN > [server] Peer Connection Initiated with [AF_INET]46.165.208.65:443. 2016.08.18 03:33:07 - OpenVPN > SENT CONTROL [server]: 'PUSH_REQUEST' (status=1). 2016.08.18 03:33:07 - OpenVPN > PUSH: Received control message: 'PUSH_REPLY,redirect-gateway def1 bypass-dhcp,dhcp-option DNS 10.4.0.1,comp-lzo no,route-gateway 10.4.0.1,topology subnet,ping 10,ping-restart 60,ifconfig 10.4.27.60 255.255.0.0'. 2016.08.18 03:33:07 - OpenVPN > OPTIONS IMPORT: timers and/or timeouts modified. 2016.08.18 03:33:07 - OpenVPN > OPTIONS IMPORT: LZO parms modified. 2016.08.18 03:33:07 - OpenVPN > OPTIONS IMPORT: --ifconfig/up options modified. 2016.08.18 03:33:07 - OpenVPN > OPTIONS IMPORT: route options modified. 2016.08.18 03:33:07 - OpenVPN > OPTIONS IMPORT: route-related options modified. 2016.08.18 03:33:07 - OpenVPN > OPTIONS IMPORT: --ip-win32 and/or --dhcp-option options modified. 2016.08.18 03:33:07 - OpenVPN > do_ifconfig, tt->ipv6=0, tt->did_ifconfig_ipv6_setup=0. 2016.08.18 03:33:07 - OpenVPN > open_tun, tt->ipv6=0. 2016.08.18 03:33:07 - OpenVPN > TAP-WIN32 device [Ethernet 2] opened: \\.\Global\{3A8EBBF0-65E6-4014-89B1-E9F76DAA9B3E}.tap. 2016.08.18 03:33:07 - OpenVPN > TAP-Windows Driver Version 9.21. 2016.08.18 03:33:07 - OpenVPN > Set TAP-Windows TUN subnet mode network/local/netmask = 10.4.0.0/10.4.27.60/255.255.0.0 [sUCCEEDED]. 2016.08.18 03:33:07 - OpenVPN > Notified TAP-Windows driver to set a DHCP IP/netmask of 10.4.27.60/255.255.0.0 on interface {3A8EBBF0-65E6-4014-89B1-E9F76DAA9B3E} [DHCP-serv: 10.4.255.254, lease-time: 31536000]. 2016.08.18 03:33:07 - OpenVPN > Successful ARP Flush on interface [4] {3A8EBBF0-65E6-4014-89B1-E9F76DAA9B3E}. 2016.08.18 03:33:12 - OpenVPN > TEST ROUTES: 1/1 succeeded len=0 ret=1 a=0 u/d=up. 2016.08.18 03:33:12 - OpenVPN > C:\Windows\system32\route.exe ADD 46.165.208.65 MASK 255.255.255.255 192.168.178.1. 2016.08.18 03:33:12 - OpenVPN > ROUTE: CreateIpForwardEntry succeeded with dwForwardMetric1=20 and dwForwardType=4. 2016.08.18 03:33:12 - OpenVPN > Route addition via IPAPI succeeded [adaptive]. 2016.08.18 03:33:12 - OpenVPN > C:\Windows\system32\route.exe ADD 192.168.178.1 MASK 255.255.255.255 192.168.178.1 IF 11. 2016.08.18 03:33:12 - OpenVPN > ROUTE: CreateIpForwardEntry succeeded with dwForwardMetric1=20 and dwForwardType=4. 2016.08.18 03:33:12 - OpenVPN > Route addition via IPAPI succeeded [adaptive]. 2016.08.18 03:33:12 - OpenVPN > C:\Windows\system32\route.exe ADD 0.0.0.0 MASK 128.0.0.0 10.4.0.1. 2016.08.18 03:33:12 - OpenVPN > ROUTE: CreateIpForwardEntry succeeded with dwForwardMetric1=20 and dwForwardType=4. 2016.08.18 03:33:12 - OpenVPN > Route addition via IPAPI succeeded [adaptive]. 2016.08.18 03:33:12 - OpenVPN > C:\Windows\system32\route.exe ADD 128.0.0.0 MASK 128.0.0.0 10.4.0.1. 2016.08.18 03:33:12 - OpenVPN > ROUTE: CreateIpForwardEntry succeeded with dwForwardMetric1=20 and dwForwardType=4. 2016.08.18 03:33:12 - OpenVPN > Route addition via IPAPI succeeded [adaptive]. 2016.08.18 03:33:12 - Starting Management Interface. 2016.08.18 03:33:12 - OpenVPN > Initialization Sequence CompletedI 2016.08.18 03:33:12 - DNS of a network adapter forced (Killer e2200 Gigabit Ethernet Controller)I 2016.08.18 03:33:12 - DNS of a network adapter forced (TAP-Windows Adapter V9)I 2016.08.18 03:33:12 - Flushing DNSI 2016.08.18 03:33:13 - Checking routeI 2016.08.18 03:33:37 - Checking DNS! 2016.08.18 03:33:37 - Connected.. 2016.08.18 03:33:37 - OpenVpn Management > >INFO:OpenVPN Management Interface Version 1 -- type 'help' for more info. 2016.08.18 03:33:37 - OpenVPN > MANAGEMENT: Client connected from [AF_INET]127.0.0.1:3100. 2016.08.18 03:35:41 - OpenVPN > [server] Inactivity timeout (--ping-restart), restarting. 2016.08.18 03:35:41 - OpenVPN > SIGUSR1[soft,ping-restart] received, process restarting. 2016.08.18 03:35:41 - OpenVPN > Restart pause, 2 second(s)! 2016.08.18 03:35:41 - Disconnecting. 2016.08.18 03:35:41 - Management - Send 'signal SIGTERM'. 2016.08.18 03:35:41 - OpenVPN > MANAGEMENT: CMD 'signal SIGTERM'. 2016.08.18 03:35:41 - OpenVPN > MANAGEMENT: Client disconnected. 2016.08.18 03:35:41 - OpenVPN > Assertion failed at misc.c:779. 2016.08.18 03:35:41 - OpenVPN > Exiting due to fatal error. 2016.08.18 03:35:41 - Connection terminated.I 2016.08.18 03:35:41 - DNS of a network adapter restored to original settings (Killer e2200 Gigabit Ethernet Controller)I 2016.08.18 03:35:42 - DNS of a network adapter restored to original settings (TAP-Windows Adapter V9)I 2016.08.18 03:35:45 - Checking authorization ...! 2016.08.18 03:35:45 - Connecting to Velorum (Germany, Frankfurt). 2016.08.18 03:35:45 - OpenVPN > OpenVPN 2.3.8 x86_64-w64-mingw32 [sSL (OpenSSL)] [LZO] [iPv6] built on Aug 13 2015. 2016.08.18 03:35:45 - OpenVPN > library versions: OpenSSL 1.0.2d 9 Jul 2015, LZO 2.08. 2016.08.18 03:35:45 - OpenVPN > MANAGEMENT: TCP Socket listening on [AF_INET]127.0.0.1:3100. 2016.08.18 03:35:45 - OpenVPN > Control Channel Authentication: tls-auth using INLINE static key file. 2016.08.18 03:35:45 - OpenVPN > Outgoing Control Channel Authentication: Using 160 bit message hash 'SHA1' for HMAC authentication. 2016.08.18 03:35:45 - OpenVPN > Incoming Control Channel Authentication: Using 160 bit message hash 'SHA1' for HMAC authentication. 2016.08.18 03:35:45 - OpenVPN > Socket Buffers: R=[65536->131072] S=[65536->131072]. 2016.08.18 03:35:45 - OpenVPN > UDPv4 link local: [undef]. 2016.08.18 03:35:45 - OpenVPN > UDPv4 link remote: [AF_INET]46.165.208.69:443. 2016.08.18 03:35:45 - OpenVPN > TLS: Initial packet from [AF_INET]46.165.208.69:443, sid=c188ab9f 76a66187. 2016.08.18 03:35:45 - OpenVPN > VERIFY OK: depth=1, C=IT, ST=IT, L=Perugia, O=airvpn.org, CN=airvpn.org CA, emailAddress=info@airvpn.org. 2016.08.18 03:35:45 - OpenVPN > Validating certificate key usage. 2016.08.18 03:35:45 - OpenVPN > ++ Certificate has key usage 00a0, expects 00a0. 2016.08.18 03:35:45 - OpenVPN > VERIFY KU OK. 2016.08.18 03:35:45 - OpenVPN > Validating certificate extended key usage. 2016.08.18 03:35:45 - OpenVPN > ++ Certificate has EKU (str) TLS Web Server Authentication, expects TLS Web Server Authentication. 2016.08.18 03:35:45 - OpenVPN > VERIFY EKU OK. 2016.08.18 03:35:45 - OpenVPN > VERIFY OK: depth=0, C=IT, ST=IT, L=Perugia, O=airvpn.org, CN=server, emailAddress=info@airvpn.org. 2016.08.18 03:35:45 - OpenVPN > Data Channel Encrypt: Cipher 'AES-256-CBC' initialized with 256 bit key. 2016.08.18 03:35:45 - OpenVPN > Data Channel Encrypt: Using 160 bit message hash 'SHA1' for HMAC authentication. 2016.08.18 03:35:45 - OpenVPN > Data Channel Decrypt: Cipher 'AES-256-CBC' initialized with 256 bit key. 2016.08.18 03:35:45 - OpenVPN > Data Channel Decrypt: Using 160 bit message hash 'SHA1' for HMAC authentication. 2016.08.18 03:35:45 - OpenVPN > Control Channel: TLSv1.2, cipher TLSv1/SSLv3 DHE-RSA-AES256-GCM-SHA384, 4096 bit RSA. 2016.08.18 03:35:45 - OpenVPN > [server] Peer Connection Initiated with [AF_INET]46.165.208.69:443. 2016.08.18 03:35:48 - OpenVPN > SENT CONTROL [server]: 'PUSH_REQUEST' (status=1). 2016.08.18 03:35:48 - OpenVPN > PUSH: Received control message: 'PUSH_REPLY,redirect-gateway def1 bypass-dhcp,dhcp-option DNS 10.4.0.1,comp-lzo no,route-gateway 10.4.0.1,topology subnet,ping 10,ping-restart 60,ifconfig 10.4.21.208 255.255.0.0'. 2016.08.18 03:35:48 - OpenVPN > OPTIONS IMPORT: timers and/or timeouts modified. 2016.08.18 03:35:48 - OpenVPN > OPTIONS IMPORT: LZO parms modified. 2016.08.18 03:35:48 - OpenVPN > OPTIONS IMPORT: --ifconfig/up options modified. 2016.08.18 03:35:48 - OpenVPN > OPTIONS IMPORT: route options modified. 2016.08.18 03:35:48 - OpenVPN > OPTIONS IMPORT: route-related options modified. 2016.08.18 03:35:48 - OpenVPN > OPTIONS IMPORT: --ip-win32 and/or --dhcp-option options modified. 2016.08.18 03:35:48 - OpenVPN > do_ifconfig, tt->ipv6=0, tt->did_ifconfig_ipv6_setup=0. 2016.08.18 03:35:48 - OpenVPN > open_tun, tt->ipv6=0. 2016.08.18 03:35:48 - OpenVPN > TAP-WIN32 device [Ethernet 2] opened: \\.\Global\{3A8EBBF0-65E6-4014-89B1-E9F76DAA9B3E}.tap. 2016.08.18 03:35:48 - OpenVPN > TAP-Windows Driver Version 9.21. 2016.08.18 03:35:48 - OpenVPN > Set TAP-Windows TUN subnet mode network/local/netmask = 10.4.0.0/10.4.21.208/255.255.0.0 [sUCCEEDED]. 2016.08.18 03:35:48 - OpenVPN > Notified TAP-Windows driver to set a DHCP IP/netmask of 10.4.21.208/255.255.0.0 on interface {3A8EBBF0-65E6-4014-89B1-E9F76DAA9B3E} [DHCP-serv: 10.4.255.254, lease-time: 31536000]. 2016.08.18 03:35:48 - OpenVPN > Successful ARP Flush on interface [4] {3A8EBBF0-65E6-4014-89B1-E9F76DAA9B3E}. 2016.08.18 03:35:53 - OpenVPN > TEST ROUTES: 1/1 succeeded len=0 ret=1 a=0 u/d=up. 2016.08.18 03:35:53 - OpenVPN > C:\Windows\system32\route.exe ADD 46.165.208.69 MASK 255.255.255.255 192.168.178.1. 2016.08.18 03:35:53 - OpenVPN > ROUTE: CreateIpForwardEntry succeeded with dwForwardMetric1=20 and dwForwardType=4. 2016.08.18 03:35:53 - OpenVPN > Route addition via IPAPI succeeded [adaptive]. 2016.08.18 03:35:53 - OpenVPN > C:\Windows\system32\route.exe ADD 192.168.178.1 MASK 255.255.255.255 192.168.178.1 IF 11. 2016.08.18 03:35:53 - OpenVPN > ROUTE: route addition failed using CreateIpForwardEntry: The object already exists. [status=5010 if_index=11]. 2016.08.18 03:35:53 - OpenVPN > Route addition via IPAPI failed [adaptive]. 2016.08.18 03:35:53 - OpenVPN > Route addition fallback to route.exe. 2016.08.18 03:35:53 - OpenVPN > env_block: add PATH=C:\Windows\System32;C:\WINDOWS;C:\WINDOWS\System32\Wbem. 2016.08.18 03:35:53 - OpenVPN > C:\Windows\system32\route.exe ADD 0.0.0.0 MASK 128.0.0.0 10.4.0.1. 2016.08.18 03:35:53 - OpenVPN > ROUTE: route addition failed using CreateIpForwardEntry: The object already exists. [status=5010 if_index=4]. 2016.08.18 03:35:53 - OpenVPN > Route addition via IPAPI failed [adaptive]. 2016.08.18 03:35:53 - OpenVPN > Route addition fallback to route.exe. 2016.08.18 03:35:53 - OpenVPN > env_block: add PATH=C:\Windows\System32;C:\WINDOWS;C:\WINDOWS\System32\Wbem. 2016.08.18 03:35:53 - OpenVPN > C:\Windows\system32\route.exe ADD 128.0.0.0 MASK 128.0.0.0 10.4.0.1. 2016.08.18 03:35:53 - OpenVPN > ROUTE: route addition failed using CreateIpForwardEntry: The object already exists. [status=5010 if_index=4]. 2016.08.18 03:35:53 - OpenVPN > Route addition via IPAPI failed [adaptive]. 2016.08.18 03:35:53 - OpenVPN > Route addition fallback to route.exe. 2016.08.18 03:35:53 - OpenVPN > env_block: add PATH=C:\Windows\System32;C:\WINDOWS;C:\WINDOWS\System32\Wbem. 2016.08.18 03:35:53 - Starting Management Interface. 2016.08.18 03:35:53 - OpenVPN > Initialization Sequence CompletedI 2016.08.18 03:35:53 - DNS of a network adapter forced (Killer e2200 Gigabit Ethernet Controller)I 2016.08.18 03:35:53 - DNS of a network adapter forced (TAP-Windows Adapter V9)I 2016.08.18 03:35:53 - Flushing DNSI 2016.08.18 03:35:53 - Checking routeI 2016.08.18 03:36:17 - Checking DNS! 2016.08.18 03:36:17 - Connected.. 2016.08.18 03:36:17 - OpenVPN > MANAGEMENT: Client connected from [AF_INET]127.0.0.1:3100. 2016.08.18 03:36:17 - OpenVpn Management > >INFO:OpenVPN Management Interface Version 1 -- type 'help' for more info! 2016.08.18 03:36:17 - Disconnecting. 2016.08.18 03:36:17 - Management - Send 'signal SIGTERM'. 2016.08.18 03:36:17 - OpenVPN > MANAGEMENT: CMD 'signal SIGTERM'. 2016.08.18 03:36:17 - OpenVPN > SIGTERM received, sending exit notification to peer. 2016.08.18 03:36:22 - OpenVPN > C:\Windows\system32\route.exe DELETE 46.165.208.69 MASK 255.255.255.255 192.168.178.1. 2016.08.18 03:36:22 - OpenVPN > Route deletion via IPAPI succeeded [adaptive]. 2016.08.18 03:36:22 - OpenVPN > C:\Windows\system32\route.exe DELETE 192.168.178.1 MASK 255.255.255.255 192.168.178.1. 2016.08.18 03:36:22 - OpenVPN > Route deletion via IPAPI succeeded [adaptive]. 2016.08.18 03:36:22 - OpenVPN > C:\Windows\system32\route.exe DELETE 0.0.0.0 MASK 128.0.0.0 10.4.0.1. 2016.08.18 03:36:22 - OpenVPN > Route deletion via IPAPI succeeded [adaptive]. 2016.08.18 03:36:22 - OpenVPN > C:\Windows\system32\route.exe DELETE 128.0.0.0 MASK 128.0.0.0 10.4.0.1. 2016.08.18 03:36:22 - OpenVPN > Route deletion via IPAPI succeeded [adaptive]. 2016.08.18 03:36:22 - OpenVPN > Closing TUN/TAP interface. 2016.08.18 03:36:22 - OpenVPN > SIGTERM[soft,exit-with-notification] received, process exiting. 2016.08.18 03:36:22 - Connection terminated.I 2016.08.18 03:36:22 - DNS of a network adapter restored to original settings (Killer e2200 Gigabit Ethernet Controller)I 2016.08.18 03:36:22 - DNS of a network adapter restored to original settings (TAP-Windows Adapter V9)I 2016.08.18 03:36:22 - IPv6 restored.! 2016.08.18 03:36:23 - Session terminated. Quote Hide Firas22's signature Hide all signatures Share this post Link to post
Guest Posted ... I only just got to read your thread, I 2016.08.16 01:03:25 - Checking routeW 2016.08.16 01:03:49 - The remote name could not be resolved: 'velorum_exit.airservers.org' this line is persistantly appearing with different servers, it seems you are having DNS problems and I do not know what could be cause or how we could fix it since I don't have access to your system, but we can try and test with something, if you'd be so kind try and install the experimental AirVPN client then open settings and go to DNS, on the DNS switch mode set it to Disabled and unmark check AirVPN DNS, then save it and try and connect. IF there are issues come back here with logs... infact even if there isn't issues I'd appreciate logs it'd be useful to try and find out what is different this time around. Thank you for your Reply can you please tell me where can i find the // experimental AirVPN // ? Second @ LZ1 I thank you for your help as always I have fallowed your instructions and did a new fresh windows 10 install , I have set up my PC to the point where I want it to be , and have don 2 backups just to be on the safe side each backup is on a different HDDand Before i was on windows 10 Home 64 version 1607 now i am on the OEM version windows 10 1511 Please look at this Link you will understand me more https://support.microsoft.com/en-us/help/12387/windows-10-update-history After all of this windows is clean from any spyware malware or anything els ,, so I installed airvpn and Indeed i got connected but after 5 minutes or so my internet icon shows i have no internet please look here http://pasteboard.co/9UkWt2ikg.png But I can still surf the internet and download ,, BUT why is it already showing bad signs just like it did it before ,, these are the same signs what happened last time So I am certian that me the pc and windows Version have nothing to do with the problem I hop you and the staff here can look into my Issue many thanks and here is my very first LOG I 2016.08.18 01:19:32 - AirVPN client version: 2.10.3 / x64, System: Windows, Name: Microsoft Windows NT 6.2.9200.0 / x64. 2016.08.18 01:19:32 - Reading options from C:\Users\NXTGen3\AppData\Local\AirVPN\AirVPN.xml. 2016.08.18 01:19:32 - Profile options not found, using defaults.. 2016.08.18 01:19:33 - Data Path: C:\Users\NXTGen3\AppData\Local\AirVPN. 2016.08.18 01:19:33 - App Path: C:\Program Files\AirVPN. 2016.08.18 01:19:33 - Executable Path: C:\Program Files\AirVPN\AirVPN.exe. 2016.08.18 01:19:33 - Command line arguments (1): path="home". 2016.08.18 01:19:33 - Operating System: Microsoft Windows NT 6.2.9200.0. 2016.08.18 01:19:33 - Updating systems & servers data .... 2016.08.18 01:19:33 - Cannot find tunnel adapter.. 2016.08.18 01:19:33 - Systems & servers data update completedE 2016.08.18 01:19:33 - OpenVPN Driver - Not availableI 2016.08.18 01:19:33 - OpenVPN - Version: OpenVPN 2.3.8 (C:\Program Files\AirVPN\openvpn.exe)I 2016.08.18 01:19:33 - SSH - Version: plink 0.63 (C:\Program Files\AirVPN\plink.exe)I 2016.08.18 01:19:33 - SSL - Version: stunnel 5.17 (C:\Program Files\AirVPN\stunnel.exe)! 2016.08.18 01:19:33 - ReadyI 2016.08.18 01:20:13 - Checking login ...! 2016.08.18 01:20:14 - Logged in.I 2016.08.18 01:21:37 - Session starting.. 2016.08.18 01:21:37 - Cannot find tunnel adapter.! 2016.08.18 01:21:37 - Installing tunnel driverI 2016.08.18 01:21:46 - IPv6 disabled.I 2016.08.18 01:21:46 - Checking authorization ...! 2016.08.18 01:21:46 - Connecting to Tauri (Germany, Frankfurt). 2016.08.18 01:21:46 - OpenVPN > OpenVPN 2.3.8 x86_64-w64-mingw32 [sSL (OpenSSL)] [LZO] [iPv6] built on Aug 13 2015. 2016.08.18 01:21:46 - OpenVPN > library versions: OpenSSL 1.0.2d 9 Jul 2015, LZO 2.08. 2016.08.18 01:21:46 - OpenVPN > MANAGEMENT: TCP Socket listening on [AF_INET]127.0.0.1:3100. 2016.08.18 01:21:46 - OpenVPN > Control Channel Authentication: tls-auth using INLINE static key file. 2016.08.18 01:21:46 - OpenVPN > Outgoing Control Channel Authentication: Using 160 bit message hash 'SHA1' for HMAC authentication. 2016.08.18 01:21:46 - OpenVPN > Incoming Control Channel Authentication: Using 160 bit message hash 'SHA1' for HMAC authentication. 2016.08.18 01:21:46 - OpenVPN > Socket Buffers: R=[65536->131072] S=[65536->131072]. 2016.08.18 01:21:46 - OpenVPN > UDPv4 link local: [undef]. 2016.08.18 01:21:46 - OpenVPN > UDPv4 link remote: [AF_INET]46.165.208.65:443. 2016.08.18 01:21:46 - OpenVPN > TLS: Initial packet from [AF_INET]46.165.208.65:443, sid=b169e80f 00d3d44a. 2016.08.18 01:21:46 - OpenVPN > VERIFY OK: depth=1, C=IT, ST=IT, L=Perugia, O=airvpn.org, CN=airvpn.org CA, emailAddress=info@airvpn.org. 2016.08.18 01:21:46 - OpenVPN > Validating certificate key usage. 2016.08.18 01:21:46 - OpenVPN > ++ Certificate has key usage 00a0, expects 00a0. 2016.08.18 01:21:46 - OpenVPN > VERIFY KU OK. 2016.08.18 01:21:46 - OpenVPN > Validating certificate extended key usage. 2016.08.18 01:21:46 - OpenVPN > ++ Certificate has EKU (str) TLS Web Server Authentication, expects TLS Web Server Authentication. 2016.08.18 01:21:46 - OpenVPN > VERIFY EKU OK. 2016.08.18 01:21:46 - OpenVPN > VERIFY OK: depth=0, C=IT, ST=IT, L=Perugia, O=airvpn.org, CN=server, emailAddress=info@airvpn.org. 2016.08.18 01:21:47 - OpenVPN > Data Channel Encrypt: Cipher 'AES-256-CBC' initialized with 256 bit key. 2016.08.18 01:21:47 - OpenVPN > Data Channel Encrypt: Using 160 bit message hash 'SHA1' for HMAC authentication. 2016.08.18 01:21:47 - OpenVPN > Data Channel Decrypt: Cipher 'AES-256-CBC' initialized with 256 bit key. 2016.08.18 01:21:47 - OpenVPN > Data Channel Decrypt: Using 160 bit message hash 'SHA1' for HMAC authentication. 2016.08.18 01:21:47 - OpenVPN > Control Channel: TLSv1.2, cipher TLSv1/SSLv3 DHE-RSA-AES256-GCM-SHA384, 4096 bit RSA. 2016.08.18 01:21:47 - OpenVPN > [server] Peer Connection Initiated with [AF_INET]46.165.208.65:443. 2016.08.18 01:21:49 - OpenVPN > SENT CONTROL [server]: 'PUSH_REQUEST' (status=1). 2016.08.18 01:21:49 - OpenVPN > PUSH: Received control message: 'PUSH_REPLY,redirect-gateway def1 bypass-dhcp,dhcp-option DNS 10.4.0.1,comp-lzo no,route-gateway 10.4.0.1,topology subnet,ping 10,ping-restart 60,ifconfig 10.4.27.60 255.255.0.0'. 2016.08.18 01:21:49 - OpenVPN > OPTIONS IMPORT: timers and/or timeouts modified. 2016.08.18 01:21:49 - OpenVPN > OPTIONS IMPORT: LZO parms modified. 2016.08.18 01:21:49 - OpenVPN > OPTIONS IMPORT: --ifconfig/up options modified. 2016.08.18 01:21:49 - OpenVPN > OPTIONS IMPORT: route options modified. 2016.08.18 01:21:49 - OpenVPN > OPTIONS IMPORT: route-related options modified. 2016.08.18 01:21:49 - OpenVPN > OPTIONS IMPORT: --ip-win32 and/or --dhcp-option options modified. 2016.08.18 01:21:49 - OpenVPN > do_ifconfig, tt->ipv6=0, tt->did_ifconfig_ipv6_setup=0. 2016.08.18 01:21:49 - OpenVPN > open_tun, tt->ipv6=0. 2016.08.18 01:21:49 - OpenVPN > TAP-WIN32 device [Ethernet 2] opened: \\.\Global\{3A8EBBF0-65E6-4014-89B1-E9F76DAA9B3E}.tap. 2016.08.18 01:21:49 - OpenVPN > TAP-Windows Driver Version 9.21. 2016.08.18 01:21:49 - OpenVPN > Set TAP-Windows TUN subnet mode network/local/netmask = 10.4.0.0/10.4.27.60/255.255.0.0 [sUCCEEDED]. 2016.08.18 01:21:49 - OpenVPN > Notified TAP-Windows driver to set a DHCP IP/netmask of 10.4.27.60/255.255.0.0 on interface {3A8EBBF0-65E6-4014-89B1-E9F76DAA9B3E} [DHCP-serv: 10.4.255.254, lease-time: 31536000]. 2016.08.18 01:21:49 - OpenVPN > Successful ARP Flush on interface [18] {3A8EBBF0-65E6-4014-89B1-E9F76DAA9B3E}. 2016.08.18 01:21:54 - OpenVPN > TEST ROUTES: 1/1 succeeded len=0 ret=1 a=0 u/d=up. 2016.08.18 01:21:54 - OpenVPN > C:\Windows\system32\route.exe ADD 46.165.208.65 MASK 255.255.255.255 192.168.178.1. 2016.08.18 01:21:54 - OpenVPN > ROUTE: CreateIpForwardEntry succeeded with dwForwardMetric1=20 and dwForwardType=4. 2016.08.18 01:21:54 - OpenVPN > Route addition via IPAPI succeeded [adaptive]. 2016.08.18 01:21:54 - OpenVPN > C:\Windows\system32\route.exe ADD 192.168.178.1 MASK 255.255.255.255 192.168.178.1 IF 10. 2016.08.18 01:21:54 - OpenVPN > ROUTE: CreateIpForwardEntry succeeded with dwForwardMetric1=20 and dwForwardType=4. 2016.08.18 01:21:54 - OpenVPN > Route addition via IPAPI succeeded [adaptive]. 2016.08.18 01:21:54 - OpenVPN > C:\Windows\system32\route.exe ADD 0.0.0.0 MASK 128.0.0.0 10.4.0.1. 2016.08.18 01:21:54 - OpenVPN > ROUTE: CreateIpForwardEntry succeeded with dwForwardMetric1=20 and dwForwardType=4. 2016.08.18 01:21:54 - OpenVPN > Route addition via IPAPI succeeded [adaptive]. 2016.08.18 01:21:54 - OpenVPN > C:\Windows\system32\route.exe ADD 128.0.0.0 MASK 128.0.0.0 10.4.0.1. 2016.08.18 01:21:54 - OpenVPN > ROUTE: CreateIpForwardEntry succeeded with dwForwardMetric1=20 and dwForwardType=4. 2016.08.18 01:21:54 - OpenVPN > Route addition via IPAPI succeeded [adaptive]. 2016.08.18 01:21:54 - Starting Management Interface. 2016.08.18 01:21:54 - OpenVPN > Initialization Sequence CompletedI 2016.08.18 01:21:54 - DNS of a network adapter forced (Killer e2200 Gigabit Ethernet Controller)I 2016.08.18 01:21:54 - DNS of a network adapter forced (TAP-Windows Adapter V9)I 2016.08.18 01:21:54 - Flushing DNSI 2016.08.18 01:21:54 - Checking routeI 2016.08.18 01:22:18 - Checking DNS! 2016.08.18 01:22:19 - Connected.. 2016.08.18 01:22:19 - OpenVPN > MANAGEMENT: Client connected from [AF_INET]127.0.0.1:3100. 2016.08.18 01:22:19 - OpenVpn Management > >INFO:OpenVPN Management Interface Version 1 -- type 'help' for more info. 2016.08.18 01:50:27 - Updating systems & servers data .... 2016.08.18 01:50:29 - Systems & servers data update completed NOT if you look at the bottom of the logs it says can not find tunnel adapter First off I need to tell you my expertise with windows 10 is very theoretical as I have no experience with it what so ever, anyway the tap driver you are using I have heard causes issues generally on windows 10 and other versions of windows, also I have been told that windows 10 makes using VPNs a lot harder. Anyway installing the 9.9.2_3 driver which is my recommended one might help on some issues. ! 2016.08.18 03:36:17 - Connected.. 2016.08.18 03:36:17 - OpenVPN > MANAGEMENT: Client connected from [AF_INET]127.0.0.1:3100. 2016.08.18 03:36:17 - OpenVpn Management > >INFO:OpenVPN Management Interface Version 1 -- type 'help' for more info! 2016.08.18 03:36:17 - Disconnecting. 2016.08.18 03:36:17 - Management - Send 'signal SIGTERM' if you look here it shows that same second that you get connected something blocks OpenVPN and it is forced to disconnect and it is very difficult for us to know what that may be. Also in regards to the experimental version, if you go on the page to download the client and click other versions at the bottom of the list is experimental Quote Share this post Link to post
Firas22 1 Posted ... @ EdensSpire thank you for your help BUT i think this will never work I just signed up for openDNS and i have an account and I am using there dns numbers ,, Airvpn after 30 minutes or so disconnects and uses this stupid number again 10.4.0.1 I tried the opendns numbers without airvpn and it looks Like i was getting a much faster speed I also have a Killer Network manager for my games i have disabled this completely and airvpn will not work I will uninstall it and wait untail some one from staff has a solution for me other than that I cant do any more if i can get some refund thats ok if not that is also ok I dont have any more options here are my logs I 2016.08.18 03:32:52 - AirVPN client version: 2.10.3 / x64, System: Windows, Name: Microsoft Windows NT 6.2.9200.0 / x64. 2016.08.18 03:32:52 - Reading options from C:\Users\NXTGen3\AppData\Local\AirVPN\AirVPN.xml. 2016.08.18 03:32:52 - Data Path: C:\Users\NXTGen3\AppData\Local\AirVPN. 2016.08.18 03:32:52 - App Path: C:\Program Files\AirVPN. 2016.08.18 03:32:52 - Executable Path: C:\Program Files\AirVPN\AirVPN.exe. 2016.08.18 03:32:52 - Command line arguments (1): path="home". 2016.08.18 03:32:52 - Operating System: Microsoft Windows NT 6.2.9200.0. 2016.08.18 03:32:52 - Updating systems & servers data ...I 2016.08.18 03:32:53 - OpenVPN Driver - TAP-Windows Adapter V9, version 9.21.1I 2016.08.18 03:32:53 - OpenVPN - Version: OpenVPN 2.3.8 (C:\Program Files\AirVPN\openvpn.exe)I 2016.08.18 03:32:53 - SSH - Version: plink 0.63 (C:\Program Files\AirVPN\plink.exe)I 2016.08.18 03:32:53 - SSL - Version: stunnel 5.17 (C:\Program Files\AirVPN\stunnel.exe)! 2016.08.18 03:32:53 - Ready. 2016.08.18 03:32:57 - Systems & servers data update completedI 2016.08.18 03:33:00 - Session starting.I 2016.08.18 03:33:01 - IPv6 disabled.I 2016.08.18 03:33:01 - Checking authorization ...! 2016.08.18 03:33:01 - Connecting to Tauri (Germany, Frankfurt). 2016.08.18 03:33:01 - OpenVPN > OpenVPN 2.3.8 x86_64-w64-mingw32 [sSL (OpenSSL)] [LZO] [iPv6] built on Aug 13 2015. 2016.08.18 03:33:01 - OpenVPN > library versions: OpenSSL 1.0.2d 9 Jul 2015, LZO 2.08. 2016.08.18 03:33:01 - OpenVPN > MANAGEMENT: TCP Socket listening on [AF_INET]127.0.0.1:3100. 2016.08.18 03:33:01 - OpenVPN > Control Channel Authentication: tls-auth using INLINE static key file. 2016.08.18 03:33:01 - OpenVPN > Outgoing Control Channel Authentication: Using 160 bit message hash 'SHA1' for HMAC authentication. 2016.08.18 03:33:01 - OpenVPN > Incoming Control Channel Authentication: Using 160 bit message hash 'SHA1' for HMAC authentication. 2016.08.18 03:33:01 - OpenVPN > Socket Buffers: R=[65536->131072] S=[65536->131072]. 2016.08.18 03:33:01 - OpenVPN > UDPv4 link local: [undef]. 2016.08.18 03:33:01 - OpenVPN > UDPv4 link remote: [AF_INET]46.165.208.65:443. 2016.08.18 03:33:04 - OpenVPN > TLS: Initial packet from [AF_INET]46.165.208.65:443, sid=aff3563e 2e0c72ca. 2016.08.18 03:33:04 - OpenVPN > VERIFY OK: depth=1, C=IT, ST=IT, L=Perugia, O=airvpn.org, CN=airvpn.org CA, emailAddress=info@airvpn.org. 2016.08.18 03:33:04 - OpenVPN > Validating certificate key usage. 2016.08.18 03:33:04 - OpenVPN > ++ Certificate has key usage 00a0, expects 00a0. 2016.08.18 03:33:04 - OpenVPN > VERIFY KU OK. 2016.08.18 03:33:04 - OpenVPN > Validating certificate extended key usage. 2016.08.18 03:33:04 - OpenVPN > ++ Certificate has EKU (str) TLS Web Server Authentication, expects TLS Web Server Authentication. 2016.08.18 03:33:04 - OpenVPN > VERIFY EKU OK. 2016.08.18 03:33:04 - OpenVPN > VERIFY OK: depth=0, C=IT, ST=IT, L=Perugia, O=airvpn.org, CN=server, emailAddress=info@airvpn.org. 2016.08.18 03:33:05 - OpenVPN > Data Channel Encrypt: Cipher 'AES-256-CBC' initialized with 256 bit key. 2016.08.18 03:33:05 - OpenVPN > Data Channel Encrypt: Using 160 bit message hash 'SHA1' for HMAC authentication. 2016.08.18 03:33:05 - OpenVPN > Data Channel Decrypt: Cipher 'AES-256-CBC' initialized with 256 bit key. 2016.08.18 03:33:05 - OpenVPN > Data Channel Decrypt: Using 160 bit message hash 'SHA1' for HMAC authentication. 2016.08.18 03:33:05 - OpenVPN > Control Channel: TLSv1.2, cipher TLSv1/SSLv3 DHE-RSA-AES256-GCM-SHA384, 4096 bit RSA. 2016.08.18 03:33:05 - OpenVPN > [server] Peer Connection Initiated with [AF_INET]46.165.208.65:443. 2016.08.18 03:33:07 - OpenVPN > SENT CONTROL [server]: 'PUSH_REQUEST' (status=1). 2016.08.18 03:33:07 - OpenVPN > PUSH: Received control message: 'PUSH_REPLY,redirect-gateway def1 bypass-dhcp,dhcp-option DNS 10.4.0.1,comp-lzo no,route-gateway 10.4.0.1,topology subnet,ping 10,ping-restart 60,ifconfig 10.4.27.60 255.255.0.0'. 2016.08.18 03:33:07 - OpenVPN > OPTIONS IMPORT: timers and/or timeouts modified. 2016.08.18 03:33:07 - OpenVPN > OPTIONS IMPORT: LZO parms modified. 2016.08.18 03:33:07 - OpenVPN > OPTIONS IMPORT: --ifconfig/up options modified. 2016.08.18 03:33:07 - OpenVPN > OPTIONS IMPORT: route options modified. 2016.08.18 03:33:07 - OpenVPN > OPTIONS IMPORT: route-related options modified. 2016.08.18 03:33:07 - OpenVPN > OPTIONS IMPORT: --ip-win32 and/or --dhcp-option options modified. 2016.08.18 03:33:07 - OpenVPN > do_ifconfig, tt->ipv6=0, tt->did_ifconfig_ipv6_setup=0. 2016.08.18 03:33:07 - OpenVPN > open_tun, tt->ipv6=0. 2016.08.18 03:33:07 - OpenVPN > TAP-WIN32 device [Ethernet 2] opened: \\.\Global\{3A8EBBF0-65E6-4014-89B1-E9F76DAA9B3E}.tap. 2016.08.18 03:33:07 - OpenVPN > TAP-Windows Driver Version 9.21. 2016.08.18 03:33:07 - OpenVPN > Set TAP-Windows TUN subnet mode network/local/netmask = 10.4.0.0/10.4.27.60/255.255.0.0 [sUCCEEDED]. 2016.08.18 03:33:07 - OpenVPN > Notified TAP-Windows driver to set a DHCP IP/netmask of 10.4.27.60/255.255.0.0 on interface {3A8EBBF0-65E6-4014-89B1-E9F76DAA9B3E} [DHCP-serv: 10.4.255.254, lease-time: 31536000]. 2016.08.18 03:33:07 - OpenVPN > Successful ARP Flush on interface [4] {3A8EBBF0-65E6-4014-89B1-E9F76DAA9B3E}. 2016.08.18 03:33:12 - OpenVPN > TEST ROUTES: 1/1 succeeded len=0 ret=1 a=0 u/d=up. 2016.08.18 03:33:12 - OpenVPN > C:\Windows\system32\route.exe ADD 46.165.208.65 MASK 255.255.255.255 192.168.178.1. 2016.08.18 03:33:12 - OpenVPN > ROUTE: CreateIpForwardEntry succeeded with dwForwardMetric1=20 and dwForwardType=4. 2016.08.18 03:33:12 - OpenVPN > Route addition via IPAPI succeeded [adaptive]. 2016.08.18 03:33:12 - OpenVPN > C:\Windows\system32\route.exe ADD 192.168.178.1 MASK 255.255.255.255 192.168.178.1 IF 11. 2016.08.18 03:33:12 - OpenVPN > ROUTE: CreateIpForwardEntry succeeded with dwForwardMetric1=20 and dwForwardType=4. 2016.08.18 03:33:12 - OpenVPN > Route addition via IPAPI succeeded [adaptive]. 2016.08.18 03:33:12 - OpenVPN > C:\Windows\system32\route.exe ADD 0.0.0.0 MASK 128.0.0.0 10.4.0.1. 2016.08.18 03:33:12 - OpenVPN > ROUTE: CreateIpForwardEntry succeeded with dwForwardMetric1=20 and dwForwardType=4. 2016.08.18 03:33:12 - OpenVPN > Route addition via IPAPI succeeded [adaptive]. 2016.08.18 03:33:12 - OpenVPN > C:\Windows\system32\route.exe ADD 128.0.0.0 MASK 128.0.0.0 10.4.0.1. 2016.08.18 03:33:12 - OpenVPN > ROUTE: CreateIpForwardEntry succeeded with dwForwardMetric1=20 and dwForwardType=4. 2016.08.18 03:33:12 - OpenVPN > Route addition via IPAPI succeeded [adaptive]. 2016.08.18 03:33:12 - Starting Management Interface. 2016.08.18 03:33:12 - OpenVPN > Initialization Sequence CompletedI 2016.08.18 03:33:12 - DNS of a network adapter forced (Killer e2200 Gigabit Ethernet Controller)I 2016.08.18 03:33:12 - DNS of a network adapter forced (TAP-Windows Adapter V9)I 2016.08.18 03:33:12 - Flushing DNSI 2016.08.18 03:33:13 - Checking routeI 2016.08.18 03:33:37 - Checking DNS! 2016.08.18 03:33:37 - Connected.. 2016.08.18 03:33:37 - OpenVpn Management > >INFO:OpenVPN Management Interface Version 1 -- type 'help' for more info. 2016.08.18 03:33:37 - OpenVPN > MANAGEMENT: Client connected from [AF_INET]127.0.0.1:3100. 2016.08.18 03:35:41 - OpenVPN > [server] Inactivity timeout (--ping-restart), restarting. 2016.08.18 03:35:41 - OpenVPN > SIGUSR1[soft,ping-restart] received, process restarting. 2016.08.18 03:35:41 - OpenVPN > Restart pause, 2 second(s)! 2016.08.18 03:35:41 - Disconnecting. 2016.08.18 03:35:41 - Management - Send 'signal SIGTERM'. 2016.08.18 03:35:41 - OpenVPN > MANAGEMENT: CMD 'signal SIGTERM'. 2016.08.18 03:35:41 - OpenVPN > MANAGEMENT: Client disconnected. 2016.08.18 03:35:41 - OpenVPN > Assertion failed at misc.c:779. 2016.08.18 03:35:41 - OpenVPN > Exiting due to fatal error. 2016.08.18 03:35:41 - Connection terminated.I 2016.08.18 03:35:41 - DNS of a network adapter restored to original settings (Killer e2200 Gigabit Ethernet Controller)I 2016.08.18 03:35:42 - DNS of a network adapter restored to original settings (TAP-Windows Adapter V9)I 2016.08.18 03:35:45 - Checking authorization ...! 2016.08.18 03:35:45 - Connecting to Velorum (Germany, Frankfurt). 2016.08.18 03:35:45 - OpenVPN > OpenVPN 2.3.8 x86_64-w64-mingw32 [sSL (OpenSSL)] [LZO] [iPv6] built on Aug 13 2015. 2016.08.18 03:35:45 - OpenVPN > library versions: OpenSSL 1.0.2d 9 Jul 2015, LZO 2.08. 2016.08.18 03:35:45 - OpenVPN > MANAGEMENT: TCP Socket listening on [AF_INET]127.0.0.1:3100. 2016.08.18 03:35:45 - OpenVPN > Control Channel Authentication: tls-auth using INLINE static key file. 2016.08.18 03:35:45 - OpenVPN > Outgoing Control Channel Authentication: Using 160 bit message hash 'SHA1' for HMAC authentication. 2016.08.18 03:35:45 - OpenVPN > Incoming Control Channel Authentication: Using 160 bit message hash 'SHA1' for HMAC authentication. 2016.08.18 03:35:45 - OpenVPN > Socket Buffers: R=[65536->131072] S=[65536->131072]. 2016.08.18 03:35:45 - OpenVPN > UDPv4 link local: [undef]. 2016.08.18 03:35:45 - OpenVPN > UDPv4 link remote: [AF_INET]46.165.208.69:443. 2016.08.18 03:35:45 - OpenVPN > TLS: Initial packet from [AF_INET]46.165.208.69:443, sid=c188ab9f 76a66187. 2016.08.18 03:35:45 - OpenVPN > VERIFY OK: depth=1, C=IT, ST=IT, L=Perugia, O=airvpn.org, CN=airvpn.org CA, emailAddress=info@airvpn.org. 2016.08.18 03:35:45 - OpenVPN > Validating certificate key usage. 2016.08.18 03:35:45 - OpenVPN > ++ Certificate has key usage 00a0, expects 00a0. 2016.08.18 03:35:45 - OpenVPN > VERIFY KU OK. 2016.08.18 03:35:45 - OpenVPN > Validating certificate extended key usage. 2016.08.18 03:35:45 - OpenVPN > ++ Certificate has EKU (str) TLS Web Server Authentication, expects TLS Web Server Authentication. 2016.08.18 03:35:45 - OpenVPN > VERIFY EKU OK. 2016.08.18 03:35:45 - OpenVPN > VERIFY OK: depth=0, C=IT, ST=IT, L=Perugia, O=airvpn.org, CN=server, emailAddress=info@airvpn.org. 2016.08.18 03:35:45 - OpenVPN > Data Channel Encrypt: Cipher 'AES-256-CBC' initialized with 256 bit key. 2016.08.18 03:35:45 - OpenVPN > Data Channel Encrypt: Using 160 bit message hash 'SHA1' for HMAC authentication. 2016.08.18 03:35:45 - OpenVPN > Data Channel Decrypt: Cipher 'AES-256-CBC' initialized with 256 bit key. 2016.08.18 03:35:45 - OpenVPN > Data Channel Decrypt: Using 160 bit message hash 'SHA1' for HMAC authentication. 2016.08.18 03:35:45 - OpenVPN > Control Channel: TLSv1.2, cipher TLSv1/SSLv3 DHE-RSA-AES256-GCM-SHA384, 4096 bit RSA. 2016.08.18 03:35:45 - OpenVPN > [server] Peer Connection Initiated with [AF_INET]46.165.208.69:443. 2016.08.18 03:35:48 - OpenVPN > SENT CONTROL [server]: 'PUSH_REQUEST' (status=1). 2016.08.18 03:35:48 - OpenVPN > PUSH: Received control message: 'PUSH_REPLY,redirect-gateway def1 bypass-dhcp,dhcp-option DNS 10.4.0.1,comp-lzo no,route-gateway 10.4.0.1,topology subnet,ping 10,ping-restart 60,ifconfig 10.4.21.208 255.255.0.0'. 2016.08.18 03:35:48 - OpenVPN > OPTIONS IMPORT: timers and/or timeouts modified. 2016.08.18 03:35:48 - OpenVPN > OPTIONS IMPORT: LZO parms modified. 2016.08.18 03:35:48 - OpenVPN > OPTIONS IMPORT: --ifconfig/up options modified. 2016.08.18 03:35:48 - OpenVPN > OPTIONS IMPORT: route options modified. 2016.08.18 03:35:48 - OpenVPN > OPTIONS IMPORT: route-related options modified. 2016.08.18 03:35:48 - OpenVPN > OPTIONS IMPORT: --ip-win32 and/or --dhcp-option options modified. 2016.08.18 03:35:48 - OpenVPN > do_ifconfig, tt->ipv6=0, tt->did_ifconfig_ipv6_setup=0. 2016.08.18 03:35:48 - OpenVPN > open_tun, tt->ipv6=0. 2016.08.18 03:35:48 - OpenVPN > TAP-WIN32 device [Ethernet 2] opened: \\.\Global\{3A8EBBF0-65E6-4014-89B1-E9F76DAA9B3E}.tap. 2016.08.18 03:35:48 - OpenVPN > TAP-Windows Driver Version 9.21. 2016.08.18 03:35:48 - OpenVPN > Set TAP-Windows TUN subnet mode network/local/netmask = 10.4.0.0/10.4.21.208/255.255.0.0 [sUCCEEDED]. 2016.08.18 03:35:48 - OpenVPN > Notified TAP-Windows driver to set a DHCP IP/netmask of 10.4.21.208/255.255.0.0 on interface {3A8EBBF0-65E6-4014-89B1-E9F76DAA9B3E} [DHCP-serv: 10.4.255.254, lease-time: 31536000]. 2016.08.18 03:35:48 - OpenVPN > Successful ARP Flush on interface [4] {3A8EBBF0-65E6-4014-89B1-E9F76DAA9B3E}. 2016.08.18 03:35:53 - OpenVPN > TEST ROUTES: 1/1 succeeded len=0 ret=1 a=0 u/d=up. 2016.08.18 03:35:53 - OpenVPN > C:\Windows\system32\route.exe ADD 46.165.208.69 MASK 255.255.255.255 192.168.178.1. 2016.08.18 03:35:53 - OpenVPN > ROUTE: CreateIpForwardEntry succeeded with dwForwardMetric1=20 and dwForwardType=4. 2016.08.18 03:35:53 - OpenVPN > Route addition via IPAPI succeeded [adaptive]. 2016.08.18 03:35:53 - OpenVPN > C:\Windows\system32\route.exe ADD 192.168.178.1 MASK 255.255.255.255 192.168.178.1 IF 11. 2016.08.18 03:35:53 - OpenVPN > ROUTE: route addition failed using CreateIpForwardEntry: The object already exists. [status=5010 if_index=11]. 2016.08.18 03:35:53 - OpenVPN > Route addition via IPAPI failed [adaptive]. 2016.08.18 03:35:53 - OpenVPN > Route addition fallback to route.exe. 2016.08.18 03:35:53 - OpenVPN > env_block: add PATH=C:\Windows\System32;C:\WINDOWS;C:\WINDOWS\System32\Wbem. 2016.08.18 03:35:53 - OpenVPN > C:\Windows\system32\route.exe ADD 0.0.0.0 MASK 128.0.0.0 10.4.0.1. 2016.08.18 03:35:53 - OpenVPN > ROUTE: route addition failed using CreateIpForwardEntry: The object already exists. [status=5010 if_index=4]. 2016.08.18 03:35:53 - OpenVPN > Route addition via IPAPI failed [adaptive]. 2016.08.18 03:35:53 - OpenVPN > Route addition fallback to route.exe. 2016.08.18 03:35:53 - OpenVPN > env_block: add PATH=C:\Windows\System32;C:\WINDOWS;C:\WINDOWS\System32\Wbem. 2016.08.18 03:35:53 - OpenVPN > C:\Windows\system32\route.exe ADD 128.0.0.0 MASK 128.0.0.0 10.4.0.1. 2016.08.18 03:35:53 - OpenVPN > ROUTE: route addition failed using CreateIpForwardEntry: The object already exists. [status=5010 if_index=4]. 2016.08.18 03:35:53 - OpenVPN > Route addition via IPAPI failed [adaptive]. 2016.08.18 03:35:53 - OpenVPN > Route addition fallback to route.exe. 2016.08.18 03:35:53 - OpenVPN > env_block: add PATH=C:\Windows\System32;C:\WINDOWS;C:\WINDOWS\System32\Wbem. 2016.08.18 03:35:53 - Starting Management Interface. 2016.08.18 03:35:53 - OpenVPN > Initialization Sequence CompletedI 2016.08.18 03:35:53 - DNS of a network adapter forced (Killer e2200 Gigabit Ethernet Controller)I 2016.08.18 03:35:53 - DNS of a network adapter forced (TAP-Windows Adapter V9)I 2016.08.18 03:35:53 - Flushing DNSI 2016.08.18 03:35:53 - Checking routeI 2016.08.18 03:36:17 - Checking DNS! 2016.08.18 03:36:17 - Connected.. 2016.08.18 03:36:17 - OpenVPN > MANAGEMENT: Client connected from [AF_INET]127.0.0.1:3100. 2016.08.18 03:36:17 - OpenVpn Management > >INFO:OpenVPN Management Interface Version 1 -- type 'help' for more info! 2016.08.18 03:36:17 - Disconnecting. 2016.08.18 03:36:17 - Management - Send 'signal SIGTERM'. 2016.08.18 03:36:17 - OpenVPN > MANAGEMENT: CMD 'signal SIGTERM'. 2016.08.18 03:36:17 - OpenVPN > SIGTERM received, sending exit notification to peer. 2016.08.18 03:36:22 - OpenVPN > C:\Windows\system32\route.exe DELETE 46.165.208.69 MASK 255.255.255.255 192.168.178.1. 2016.08.18 03:36:22 - OpenVPN > Route deletion via IPAPI succeeded [adaptive]. 2016.08.18 03:36:22 - OpenVPN > C:\Windows\system32\route.exe DELETE 192.168.178.1 MASK 255.255.255.255 192.168.178.1. 2016.08.18 03:36:22 - OpenVPN > Route deletion via IPAPI succeeded [adaptive]. 2016.08.18 03:36:22 - OpenVPN > C:\Windows\system32\route.exe DELETE 0.0.0.0 MASK 128.0.0.0 10.4.0.1. 2016.08.18 03:36:22 - OpenVPN > Route deletion via IPAPI succeeded [adaptive]. 2016.08.18 03:36:22 - OpenVPN > C:\Windows\system32\route.exe DELETE 128.0.0.0 MASK 128.0.0.0 10.4.0.1. 2016.08.18 03:36:22 - OpenVPN > Route deletion via IPAPI succeeded [adaptive]. 2016.08.18 03:36:22 - OpenVPN > Closing TUN/TAP interface. 2016.08.18 03:36:22 - OpenVPN > SIGTERM[soft,exit-with-notification] received, process exiting. 2016.08.18 03:36:22 - Connection terminated.I 2016.08.18 03:36:22 - DNS of a network adapter restored to original settings (Killer e2200 Gigabit Ethernet Controller)I 2016.08.18 03:36:22 - DNS of a network adapter restored to original settings (TAP-Windows Adapter V9)I 2016.08.18 03:36:22 - IPv6 restored.! 2016.08.18 03:36:23 - Session terminated.I 2016.08.18 03:58:53 - Session starting.I 2016.08.18 03:58:53 - IPv6 disabled.I 2016.08.18 03:58:53 - Checking authorization ...! 2016.08.18 03:58:54 - Connecting to Brachium (Spain, Valencia). 2016.08.18 03:58:54 - OpenVPN > OpenVPN 2.3.8 x86_64-w64-mingw32 [sSL (OpenSSL)] [LZO] [iPv6] built on Aug 13 2015. 2016.08.18 03:58:54 - OpenVPN > library versions: OpenSSL 1.0.2d 9 Jul 2015, LZO 2.08. 2016.08.18 03:58:54 - OpenVPN > MANAGEMENT: TCP Socket listening on [AF_INET]127.0.0.1:3100. 2016.08.18 03:58:54 - OpenVPN > Control Channel Authentication: tls-auth using INLINE static key file. 2016.08.18 03:58:54 - OpenVPN > Outgoing Control Channel Authentication: Using 160 bit message hash 'SHA1' for HMAC authentication. 2016.08.18 03:58:54 - OpenVPN > Incoming Control Channel Authentication: Using 160 bit message hash 'SHA1' for HMAC authentication. 2016.08.18 03:58:54 - OpenVPN > Socket Buffers: R=[65536->131072] S=[65536->131072]. 2016.08.18 03:58:54 - OpenVPN > UDPv4 link local: [undef]. 2016.08.18 03:58:54 - OpenVPN > UDPv4 link remote: [AF_INET]95.215.62.91:443. 2016.08.18 03:58:54 - OpenVPN > TLS: Initial packet from [AF_INET]95.215.62.91:443, sid=2c6842bd dcbd38bf. 2016.08.18 03:58:54 - OpenVPN > VERIFY OK: depth=1, C=IT, ST=IT, L=Perugia, O=airvpn.org, CN=airvpn.org CA, emailAddress=info@airvpn.org. 2016.08.18 03:58:54 - OpenVPN > Validating certificate key usage. 2016.08.18 03:58:54 - OpenVPN > ++ Certificate has key usage 00a0, expects 00a0. 2016.08.18 03:58:54 - OpenVPN > VERIFY KU OK. 2016.08.18 03:58:54 - OpenVPN > Validating certificate extended key usage. 2016.08.18 03:58:54 - OpenVPN > ++ Certificate has EKU (str) TLS Web Server Authentication, expects TLS Web Server Authentication. 2016.08.18 03:58:54 - OpenVPN > VERIFY EKU OK. 2016.08.18 03:58:54 - OpenVPN > VERIFY OK: depth=0, C=IT, ST=IT, L=Perugia, O=airvpn.org, CN=server, emailAddress=info@airvpn.org. 2016.08.18 03:58:55 - OpenVPN > Data Channel Encrypt: Cipher 'AES-256-CBC' initialized with 256 bit key. 2016.08.18 03:58:55 - OpenVPN > Data Channel Encrypt: Using 160 bit message hash 'SHA1' for HMAC authentication. 2016.08.18 03:58:55 - OpenVPN > Data Channel Decrypt: Cipher 'AES-256-CBC' initialized with 256 bit key. 2016.08.18 03:58:55 - OpenVPN > Data Channel Decrypt: Using 160 bit message hash 'SHA1' for HMAC authentication. 2016.08.18 03:58:55 - OpenVPN > Control Channel: TLSv1.2, cipher TLSv1/SSLv3 DHE-RSA-AES256-GCM-SHA384, 4096 bit RSA. 2016.08.18 03:58:55 - OpenVPN > [server] Peer Connection Initiated with [AF_INET]95.215.62.91:443. 2016.08.18 03:58:57 - OpenVPN > SENT CONTROL [server]: 'PUSH_REQUEST' (status=1). 2016.08.18 03:58:57 - OpenVPN > PUSH: Received control message: 'PUSH_REPLY,redirect-gateway def1 bypass-dhcp,dhcp-option DNS 10.4.0.1,comp-lzo no,route-gateway 10.4.0.1,topology subnet,ping 10,ping-restart 60,ifconfig 10.4.19.64 255.255.0.0'. 2016.08.18 03:58:57 - OpenVPN > OPTIONS IMPORT: timers and/or timeouts modified. 2016.08.18 03:58:57 - OpenVPN > OPTIONS IMPORT: LZO parms modified. 2016.08.18 03:58:57 - OpenVPN > OPTIONS IMPORT: --ifconfig/up options modified. 2016.08.18 03:58:57 - OpenVPN > OPTIONS IMPORT: route options modified. 2016.08.18 03:58:57 - OpenVPN > OPTIONS IMPORT: route-related options modified. 2016.08.18 03:58:57 - OpenVPN > OPTIONS IMPORT: --ip-win32 and/or --dhcp-option options modified. 2016.08.18 03:58:57 - OpenVPN > do_ifconfig, tt->ipv6=0, tt->did_ifconfig_ipv6_setup=0. 2016.08.18 03:58:57 - OpenVPN > open_tun, tt->ipv6=0. 2016.08.18 03:58:57 - OpenVPN > TAP-WIN32 device [Ethernet 2] opened: \\.\Global\{3A8EBBF0-65E6-4014-89B1-E9F76DAA9B3E}.tap. 2016.08.18 03:58:57 - OpenVPN > TAP-Windows Driver Version 9.21. 2016.08.18 03:58:57 - OpenVPN > Set TAP-Windows TUN subnet mode network/local/netmask = 10.4.0.0/10.4.19.64/255.255.0.0 [sUCCEEDED]. 2016.08.18 03:58:57 - OpenVPN > Notified TAP-Windows driver to set a DHCP IP/netmask of 10.4.19.64/255.255.0.0 on interface {3A8EBBF0-65E6-4014-89B1-E9F76DAA9B3E} [DHCP-serv: 10.4.255.254, lease-time: 31536000]. 2016.08.18 03:58:57 - OpenVPN > Successful ARP Flush on interface [4] {3A8EBBF0-65E6-4014-89B1-E9F76DAA9B3E}. 2016.08.18 03:59:02 - OpenVPN > TEST ROUTES: 1/1 succeeded len=0 ret=1 a=0 u/d=up. 2016.08.18 03:59:02 - OpenVPN > C:\Windows\system32\route.exe ADD 95.215.62.91 MASK 255.255.255.255 192.168.178.1. 2016.08.18 03:59:02 - OpenVPN > ROUTE: CreateIpForwardEntry succeeded with dwForwardMetric1=20 and dwForwardType=4. 2016.08.18 03:59:02 - OpenVPN > Route addition via IPAPI succeeded [adaptive]. 2016.08.18 03:59:02 - OpenVPN > C:\Windows\system32\route.exe ADD 192.168.178.1 MASK 255.255.255.255 192.168.178.1 IF 11. 2016.08.18 03:59:02 - OpenVPN > ROUTE: CreateIpForwardEntry succeeded with dwForwardMetric1=20 and dwForwardType=4. 2016.08.18 03:59:02 - OpenVPN > Route addition via IPAPI succeeded [adaptive]. 2016.08.18 03:59:02 - OpenVPN > C:\Windows\system32\route.exe ADD 0.0.0.0 MASK 128.0.0.0 10.4.0.1. 2016.08.18 03:59:02 - OpenVPN > ROUTE: CreateIpForwardEntry succeeded with dwForwardMetric1=20 and dwForwardType=4. 2016.08.18 03:59:02 - OpenVPN > Route addition via IPAPI succeeded [adaptive]. 2016.08.18 03:59:02 - OpenVPN > C:\Windows\system32\route.exe ADD 128.0.0.0 MASK 128.0.0.0 10.4.0.1. 2016.08.18 03:59:02 - OpenVPN > ROUTE: CreateIpForwardEntry succeeded with dwForwardMetric1=20 and dwForwardType=4. 2016.08.18 03:59:02 - OpenVPN > Route addition via IPAPI succeeded [adaptive]. 2016.08.18 03:59:02 - Starting Management Interface. 2016.08.18 03:59:02 - OpenVPN > Initialization Sequence CompletedI 2016.08.18 03:59:03 - DNS of a network adapter forced (Killer e2200 Gigabit Ethernet Controller)I 2016.08.18 03:59:03 - DNS of a network adapter forced (TAP-Windows Adapter V9)I 2016.08.18 03:59:03 - Flushing DNSI 2016.08.18 03:59:03 - Checking routeI 2016.08.18 03:59:27 - Checking DNS! 2016.08.18 03:59:27 - Connected.. 2016.08.18 03:59:28 - OpenVpn Management > >INFO:OpenVPN Management Interface Version 1 -- type 'help' for more info. 2016.08.18 03:59:28 - OpenVPN > MANAGEMENT: Client connected from [AF_INET]127.0.0.1:3100. 2016.08.18 04:03:41 - Updating systems & servers data .... 2016.08.18 04:03:41 - Systems & servers data update completed. 2016.08.18 04:33:18 - OpenVPN > [server] Inactivity timeout (--ping-restart), restarting. 2016.08.18 04:33:18 - OpenVPN > SIGUSR1[soft,ping-restart] received, process restarting. 2016.08.18 04:33:18 - OpenVPN > Restart pause, 2 second(s)! 2016.08.18 04:33:18 - Disconnecting. 2016.08.18 04:33:18 - Management - Send 'signal SIGTERM'. 2016.08.18 04:33:18 - OpenVPN > MANAGEMENT: CMD 'signal SIGTERM'. 2016.08.18 04:33:18 - OpenVPN > MANAGEMENT: Client disconnected. 2016.08.18 04:33:18 - OpenVPN > Assertion failed at misc.c:779. 2016.08.18 04:33:18 - OpenVPN > Exiting due to fatal error. 2016.08.18 04:33:18 - Connection terminated.I 2016.08.18 04:33:18 - DNS of a network adapter restored to original settings (Killer e2200 Gigabit Ethernet Controller)I 2016.08.18 04:33:18 - DNS of a network adapter restored to original settings (TAP-Windows Adapter V9). 2016.08.18 04:34:02 - Updating systems & servers data ...I 2016.08.18 04:34:06 - Checking authorization .... 2016.08.18 04:34:42 - Cannot retrieve systems & servers data. Please retry later or contact us for help. (The request was aborted: The operation has timed out.)W 2016.08.18 04:34:46 - Authorization check failed, continue anyway ({1])! 2016.08.18 04:34:46 - Connecting to Velorum (Germany, Frankfurt). 2016.08.18 04:34:52 - OpenVPN > OpenVPN 2.3.8 x86_64-w64-mingw32 [sSL (OpenSSL)] [LZO] [iPv6] built on Aug 13 2015. 2016.08.18 04:34:52 - OpenVPN > library versions: OpenSSL 1.0.2d 9 Jul 2015, LZO 2.08. 2016.08.18 04:34:52 - OpenVPN > MANAGEMENT: TCP Socket listening on [AF_INET]127.0.0.1:3100. 2016.08.18 04:34:52 - OpenVPN > Control Channel Authentication: tls-auth using INLINE static key file. 2016.08.18 04:34:52 - OpenVPN > Outgoing Control Channel Authentication: Using 160 bit message hash 'SHA1' for HMAC authentication. 2016.08.18 04:34:52 - OpenVPN > Incoming Control Channel Authentication: Using 160 bit message hash 'SHA1' for HMAC authentication. 2016.08.18 04:34:52 - OpenVPN > Socket Buffers: R=[65536->131072] S=[65536->131072]. 2016.08.18 04:34:52 - OpenVPN > UDPv4 link local: [undef]. 2016.08.18 04:34:52 - OpenVPN > UDPv4 link remote: [AF_INET]46.165.208.69:443. 2016.08.18 04:35:19 - OpenVPN > [uNDEF] Inactivity timeout (--ping-exit), exiting. 2016.08.18 04:35:19 - OpenVPN > SIGTERM received, sending exit notification to peer. 2016.08.18 04:35:24 - OpenVPN > SIGTERM[soft,exit-with-notification] received, process exiting! 2016.08.18 04:35:24 - Disconnecting. 2016.08.18 04:35:24 - Connection terminated.I 2016.08.18 04:35:27 - Checking authorization ...W 2016.08.18 04:36:07 - Authorization check failed, continue anyway ({1])! 2016.08.18 04:36:07 - Connecting to Velorum (Germany, Frankfurt). 2016.08.18 04:36:07 - OpenVPN > OpenVPN 2.3.8 x86_64-w64-mingw32 [sSL (OpenSSL)] [LZO] [iPv6] built on Aug 13 2015. 2016.08.18 04:36:07 - OpenVPN > library versions: OpenSSL 1.0.2d 9 Jul 2015, LZO 2.08. 2016.08.18 04:36:08 - OpenVPN > MANAGEMENT: TCP Socket listening on [AF_INET]127.0.0.1:3100. 2016.08.18 04:36:08 - OpenVPN > Control Channel Authentication: tls-auth using INLINE static key file. 2016.08.18 04:36:08 - OpenVPN > Outgoing Control Channel Authentication: Using 160 bit message hash 'SHA1' for HMAC authentication. 2016.08.18 04:36:08 - OpenVPN > Incoming Control Channel Authentication: Using 160 bit message hash 'SHA1' for HMAC authentication. 2016.08.18 04:36:08 - OpenVPN > Socket Buffers: R=[65536->131072] S=[65536->131072]. 2016.08.18 04:36:08 - OpenVPN > UDPv4 link local: [undef]. 2016.08.18 04:36:08 - OpenVPN > UDPv4 link remote: [AF_INET]46.165.208.69:443. 2016.08.18 04:36:41 - OpenVPN > [uNDEF] Inactivity timeout (--ping-exit), exiting. 2016.08.18 04:36:41 - OpenVPN > SIGTERM received, sending exit notification to peer. 2016.08.18 04:36:47 - OpenVPN > SIGTERM[soft,exit-with-notification] received, process exiting! 2016.08.18 04:36:47 - Disconnecting. 2016.08.18 04:36:47 - Connection terminated.I 2016.08.18 04:36:50 - Checking authorization ...W 2016.08.18 04:37:30 - Authorization check failed, continue anyway ({1])! 2016.08.18 04:37:30 - Connecting to Velorum (Germany, Frankfurt). 2016.08.18 04:37:30 - OpenVPN > OpenVPN 2.3.8 x86_64-w64-mingw32 [sSL (OpenSSL)] [LZO] [iPv6] built on Aug 13 2015. 2016.08.18 04:37:30 - OpenVPN > library versions: OpenSSL 1.0.2d 9 Jul 2015, LZO 2.08. 2016.08.18 04:37:30 - OpenVPN > MANAGEMENT: TCP Socket listening on [AF_INET]127.0.0.1:3100. 2016.08.18 04:37:30 - OpenVPN > Control Channel Authentication: tls-auth using INLINE static key file. 2016.08.18 04:37:30 - OpenVPN > Outgoing Control Channel Authentication: Using 160 bit message hash 'SHA1' for HMAC authentication. 2016.08.18 04:37:30 - OpenVPN > Incoming Control Channel Authentication: Using 160 bit message hash 'SHA1' for HMAC authentication. 2016.08.18 04:37:30 - OpenVPN > Socket Buffers: R=[65536->131072] S=[65536->131072]. 2016.08.18 04:37:30 - OpenVPN > UDPv4 link local: [undef]. 2016.08.18 04:37:30 - OpenVPN > UDPv4 link remote: [AF_INET]46.165.208.69:443. 2016.08.18 04:37:44 - OpenVPN > TLS: Initial packet from [AF_INET]46.165.208.69:443, sid=79dc4073 b54cde5b. 2016.08.18 04:37:44 - OpenVPN > VERIFY OK: depth=1, C=IT, ST=IT, L=Perugia, O=airvpn.org, CN=airvpn.org CA, emailAddress=info@airvpn.org. 2016.08.18 04:37:44 - OpenVPN > Validating certificate key usage. 2016.08.18 04:37:44 - OpenVPN > ++ Certificate has key usage 00a0, expects 00a0. 2016.08.18 04:37:44 - OpenVPN > VERIFY KU OK. 2016.08.18 04:37:44 - OpenVPN > Validating certificate extended key usage. 2016.08.18 04:37:44 - OpenVPN > ++ Certificate has EKU (str) TLS Web Server Authentication, expects TLS Web Server Authentication. 2016.08.18 04:37:44 - OpenVPN > VERIFY EKU OK. 2016.08.18 04:37:44 - OpenVPN > VERIFY OK: depth=0, C=IT, ST=IT, L=Perugia, O=airvpn.org, CN=server, emailAddress=info@airvpn.org. 2016.08.18 04:37:44 - OpenVPN > Data Channel Encrypt: Cipher 'AES-256-CBC' initialized with 256 bit key. 2016.08.18 04:37:44 - OpenVPN > Data Channel Encrypt: Using 160 bit message hash 'SHA1' for HMAC authentication. 2016.08.18 04:37:44 - OpenVPN > Data Channel Decrypt: Cipher 'AES-256-CBC' initialized with 256 bit key. 2016.08.18 04:37:44 - OpenVPN > Data Channel Decrypt: Using 160 bit message hash 'SHA1' for HMAC authentication. 2016.08.18 04:37:44 - OpenVPN > Control Channel: TLSv1.2, cipher TLSv1/SSLv3 DHE-RSA-AES256-GCM-SHA384, 4096 bit RSA. 2016.08.18 04:37:44 - OpenVPN > [server] Peer Connection Initiated with [AF_INET]46.165.208.69:443. 2016.08.18 04:37:46 - OpenVPN > SENT CONTROL [server]: 'PUSH_REQUEST' (status=1). 2016.08.18 04:37:47 - OpenVPN > PUSH: Received control message: 'PUSH_REPLY,redirect-gateway def1 bypass-dhcp,dhcp-option DNS 10.4.0.1,comp-lzo no,route-gateway 10.4.0.1,topology subnet,ping 10,ping-restart 60,ifconfig 10.4.21.208 255.255.0.0'. 2016.08.18 04:37:47 - OpenVPN > OPTIONS IMPORT: timers and/or timeouts modified. 2016.08.18 04:37:47 - OpenVPN > OPTIONS IMPORT: LZO parms modified. 2016.08.18 04:37:47 - OpenVPN > OPTIONS IMPORT: --ifconfig/up options modified. 2016.08.18 04:37:47 - OpenVPN > OPTIONS IMPORT: route options modified. 2016.08.18 04:37:47 - OpenVPN > OPTIONS IMPORT: route-related options modified. 2016.08.18 04:37:47 - OpenVPN > OPTIONS IMPORT: --ip-win32 and/or --dhcp-option options modified. 2016.08.18 04:37:47 - OpenVPN > do_ifconfig, tt->ipv6=0, tt->did_ifconfig_ipv6_setup=0. 2016.08.18 04:37:47 - OpenVPN > open_tun, tt->ipv6=0. 2016.08.18 04:37:47 - OpenVPN > TAP-WIN32 device [Ethernet 2] opened: \\.\Global\{3A8EBBF0-65E6-4014-89B1-E9F76DAA9B3E}.tap. 2016.08.18 04:37:47 - OpenVPN > TAP-Windows Driver Version 9.21. 2016.08.18 04:37:47 - OpenVPN > Set TAP-Windows TUN subnet mode network/local/netmask = 10.4.0.0/10.4.21.208/255.255.0.0 [sUCCEEDED]. 2016.08.18 04:37:47 - OpenVPN > Notified TAP-Windows driver to set a DHCP IP/netmask of 10.4.21.208/255.255.0.0 on interface {3A8EBBF0-65E6-4014-89B1-E9F76DAA9B3E} [DHCP-serv: 10.4.255.254, lease-time: 31536000]. 2016.08.18 04:37:47 - OpenVPN > Successful ARP Flush on interface [4] {3A8EBBF0-65E6-4014-89B1-E9F76DAA9B3E}. 2016.08.18 04:37:52 - OpenVPN > TEST ROUTES: 1/1 succeeded len=0 ret=1 a=0 u/d=up. 2016.08.18 04:37:52 - OpenVPN > C:\Windows\system32\route.exe ADD 46.165.208.69 MASK 255.255.255.255 192.168.178.1. 2016.08.18 04:37:52 - OpenVPN > ROUTE: CreateIpForwardEntry succeeded with dwForwardMetric1=20 and dwForwardType=4. 2016.08.18 04:37:52 - OpenVPN > Route addition via IPAPI succeeded [adaptive]. 2016.08.18 04:37:52 - OpenVPN > C:\Windows\system32\route.exe ADD 192.168.178.1 MASK 255.255.255.255 192.168.178.1 IF 11. 2016.08.18 04:37:52 - OpenVPN > ROUTE: route addition failed using CreateIpForwardEntry: The object already exists. [status=5010 if_index=11]. 2016.08.18 04:37:52 - OpenVPN > Route addition via IPAPI failed [adaptive]. 2016.08.18 04:37:52 - OpenVPN > Route addition fallback to route.exe. 2016.08.18 04:37:52 - OpenVPN > env_block: add PATH=C:\Windows\System32;C:\WINDOWS;C:\WINDOWS\System32\Wbem. 2016.08.18 04:37:52 - OpenVPN > C:\Windows\system32\route.exe ADD 0.0.0.0 MASK 128.0.0.0 10.4.0.1. 2016.08.18 04:37:52 - OpenVPN > ROUTE: route addition failed using CreateIpForwardEntry: The object already exists. [status=5010 if_index=4]. 2016.08.18 04:37:52 - OpenVPN > Route addition via IPAPI failed [adaptive]. 2016.08.18 04:37:52 - OpenVPN > Route addition fallback to route.exe. 2016.08.18 04:37:52 - OpenVPN > env_block: add PATH=C:\Windows\System32;C:\WINDOWS;C:\WINDOWS\System32\Wbem. 2016.08.18 04:37:52 - OpenVPN > C:\Windows\system32\route.exe ADD 128.0.0.0 MASK 128.0.0.0 10.4.0.1. 2016.08.18 04:37:52 - OpenVPN > ROUTE: route addition failed using CreateIpForwardEntry: The object already exists. [status=5010 if_index=4]. 2016.08.18 04:37:52 - OpenVPN > Route addition via IPAPI failed [adaptive]. 2016.08.18 04:37:52 - OpenVPN > Route addition fallback to route.exe. 2016.08.18 04:37:52 - OpenVPN > env_block: add PATH=C:\Windows\System32;C:\WINDOWS;C:\WINDOWS\System32\Wbem. 2016.08.18 04:37:52 - Starting Management Interface. 2016.08.18 04:37:52 - OpenVPN > Initialization Sequence CompletedI 2016.08.18 04:37:52 - DNS of a network adapter forced (Killer e2200 Gigabit Ethernet Controller)I 2016.08.18 04:37:52 - DNS of a network adapter forced (TAP-Windows Adapter V9)I 2016.08.18 04:37:52 - Flushing DNSI 2016.08.18 04:37:52 - Checking routeI 2016.08.18 04:38:16 - Checking DNS! 2016.08.18 04:38:16 - Connected.. 2016.08.18 04:38:16 - OpenVPN > MANAGEMENT: Client connected from [AF_INET]127.0.0.1:3100. 2016.08.18 04:38:16 - OpenVpn Management > >INFO:OpenVPN Management Interface Version 1 -- type 'help' for more info. 2016.08.18 04:42:23 - OpenVPN > [server] Inactivity timeout (--ping-restart), restarting. 2016.08.18 04:42:23 - OpenVPN > SIGUSR1[soft,ping-restart] received, process restarting. 2016.08.18 04:42:23 - OpenVPN > Restart pause, 2 second(s)! 2016.08.18 04:42:23 - Disconnecting. 2016.08.18 04:42:23 - Management - Send 'signal SIGTERM'. 2016.08.18 04:42:23 - OpenVPN > MANAGEMENT: CMD 'signal SIGTERM'. 2016.08.18 04:42:23 - OpenVPN > MANAGEMENT: Client disconnected. 2016.08.18 04:42:23 - OpenVPN > Assertion failed at misc.c:779. 2016.08.18 04:42:23 - OpenVPN > Exiting due to fatal error. 2016.08.18 04:42:23 - Connection terminated.I 2016.08.18 04:42:23 - DNS of a network adapter restored to original settings (Killer e2200 Gigabit Ethernet Controller)I 2016.08.18 04:42:23 - DNS of a network adapter restored to original settings (TAP-Windows Adapter V9)I 2016.08.18 04:42:26 - Checking authorization ...W 2016.08.18 04:43:06 - Authorization check failed, continue anyway ({1])! 2016.08.18 04:43:06 - Connecting to Tauri (Germany, Frankfurt). 2016.08.18 04:43:06 - OpenVPN > OpenVPN 2.3.8 x86_64-w64-mingw32 [sSL (OpenSSL)] [LZO] [iPv6] built on Aug 13 2015. 2016.08.18 04:43:06 - OpenVPN > library versions: OpenSSL 1.0.2d 9 Jul 2015, LZO 2.08. 2016.08.18 04:43:06 - OpenVPN > MANAGEMENT: TCP Socket listening on [AF_INET]127.0.0.1:3100. 2016.08.18 04:43:06 - OpenVPN > Control Channel Authentication: tls-auth using INLINE static key file. 2016.08.18 04:43:06 - OpenVPN > Outgoing Control Channel Authentication: Using 160 bit message hash 'SHA1' for HMAC authentication. 2016.08.18 04:43:06 - OpenVPN > Incoming Control Channel Authentication: Using 160 bit message hash 'SHA1' for HMAC authentication. 2016.08.18 04:43:06 - OpenVPN > Socket Buffers: R=[65536->131072] S=[65536->131072]. 2016.08.18 04:43:06 - OpenVPN > UDPv4 link local: [undef]. 2016.08.18 04:43:06 - OpenVPN > UDPv4 link remote: [AF_INET]46.165.208.65:443. 2016.08.18 04:43:06 - OpenVPN > TLS: Initial packet from [AF_INET]46.165.208.65:443, sid=a5aae14a e59a18c0. 2016.08.18 04:43:06 - OpenVPN > VERIFY OK: depth=1, C=IT, ST=IT, L=Perugia, O=airvpn.org, CN=airvpn.org CA, emailAddress=info@airvpn.org. 2016.08.18 04:43:06 - OpenVPN > Validating certificate key usage. 2016.08.18 04:43:06 - OpenVPN > ++ Certificate has key usage 00a0, expects 00a0. 2016.08.18 04:43:06 - OpenVPN > VERIFY KU OK. 2016.08.18 04:43:06 - OpenVPN > Validating certificate extended key usage. 2016.08.18 04:43:06 - OpenVPN > ++ Certificate has EKU (str) TLS Web Server Authentication, expects TLS Web Server Authentication. 2016.08.18 04:43:06 - OpenVPN > VERIFY EKU OK. 2016.08.18 04:43:06 - OpenVPN > VERIFY OK: depth=0, C=IT, ST=IT, L=Perugia, O=airvpn.org, CN=server, emailAddress=info@airvpn.org. 2016.08.18 04:43:07 - OpenVPN > Data Channel Encrypt: Cipher 'AES-256-CBC' initialized with 256 bit key. 2016.08.18 04:43:07 - OpenVPN > Data Channel Encrypt: Using 160 bit message hash 'SHA1' for HMAC authentication. 2016.08.18 04:43:07 - OpenVPN > Data Channel Decrypt: Cipher 'AES-256-CBC' initialized with 256 bit key. 2016.08.18 04:43:07 - OpenVPN > Data Channel Decrypt: Using 160 bit message hash 'SHA1' for HMAC authentication. 2016.08.18 04:43:07 - OpenVPN > Control Channel: TLSv1.2, cipher TLSv1/SSLv3 DHE-RSA-AES256-GCM-SHA384, 4096 bit RSA. 2016.08.18 04:43:07 - OpenVPN > [server] Peer Connection Initiated with [AF_INET]46.165.208.65:443. 2016.08.18 04:43:09 - OpenVPN > SENT CONTROL [server]: 'PUSH_REQUEST' (status=1). 2016.08.18 04:43:09 - OpenVPN > PUSH: Received control message: 'PUSH_REPLY,redirect-gateway def1 bypass-dhcp,dhcp-option DNS 10.4.0.1,comp-lzo no,route-gateway 10.4.0.1,topology subnet,ping 10,ping-restart 60,ifconfig 10.4.27.60 255.255.0.0'. 2016.08.18 04:43:09 - OpenVPN > OPTIONS IMPORT: timers and/or timeouts modified. 2016.08.18 04:43:09 - OpenVPN > OPTIONS IMPORT: LZO parms modified. 2016.08.18 04:43:09 - OpenVPN > OPTIONS IMPORT: --ifconfig/up options modified. 2016.08.18 04:43:09 - OpenVPN > OPTIONS IMPORT: route options modified. 2016.08.18 04:43:09 - OpenVPN > OPTIONS IMPORT: route-related options modified. 2016.08.18 04:43:09 - OpenVPN > OPTIONS IMPORT: --ip-win32 and/or --dhcp-option options modified. 2016.08.18 04:43:09 - OpenVPN > do_ifconfig, tt->ipv6=0, tt->did_ifconfig_ipv6_setup=0. 2016.08.18 04:43:09 - OpenVPN > open_tun, tt->ipv6=0. 2016.08.18 04:43:09 - OpenVPN > CreateFile failed on TAP device: \\.\Global\{3A8EBBF0-65E6-4014-89B1-E9F76DAA9B3E}.tap. 2016.08.18 04:43:09 - OpenVPN > All TAP-Windows adapters on this system are currently in use.. 2016.08.18 04:43:09 - OpenVPN > Exiting due to fatal error! 2016.08.18 04:43:09 - Disconnecting. 2016.08.18 04:43:09 - Connection terminated.I 2016.08.18 04:43:12 - Checking authorization ...! 2016.08.18 04:43:23 - Connecting to Tauri (Germany, Frankfurt). 2016.08.18 04:43:23 - OpenVPN > OpenVPN 2.3.8 x86_64-w64-mingw32 [sSL (OpenSSL)] [LZO] [iPv6] built on Aug 13 2015. 2016.08.18 04:43:23 - OpenVPN > library versions: OpenSSL 1.0.2d 9 Jul 2015, LZO 2.08. 2016.08.18 04:43:23 - OpenVPN > MANAGEMENT: TCP Socket listening on [AF_INET]127.0.0.1:3100. 2016.08.18 04:43:23 - OpenVPN > Control Channel Authentication: tls-auth using INLINE static key file. 2016.08.18 04:43:23 - OpenVPN > Outgoing Control Channel Authentication: Using 160 bit message hash 'SHA1' for HMAC authentication. 2016.08.18 04:43:23 - OpenVPN > Incoming Control Channel Authentication: Using 160 bit message hash 'SHA1' for HMAC authentication. 2016.08.18 04:43:23 - OpenVPN > Socket Buffers: R=[65536->131072] S=[65536->131072]. 2016.08.18 04:43:23 - OpenVPN > UDPv4 link local: [undef]. 2016.08.18 04:43:23 - OpenVPN > UDPv4 link remote: [AF_INET]46.165.208.65:443. 2016.08.18 04:43:23 - OpenVPN > TLS: Initial packet from [AF_INET]46.165.208.65:443, sid=1d116a79 74373580. 2016.08.18 04:43:23 - OpenVPN > VERIFY OK: depth=1, C=IT, ST=IT, L=Perugia, O=airvpn.org, CN=airvpn.org CA, emailAddress=info@airvpn.org. 2016.08.18 04:43:23 - OpenVPN > Validating certificate key usage. 2016.08.18 04:43:23 - OpenVPN > ++ Certificate has key usage 00a0, expects 00a0. 2016.08.18 04:43:23 - OpenVPN > VERIFY KU OK. 2016.08.18 04:43:23 - OpenVPN > Validating certificate extended key usage. 2016.08.18 04:43:23 - OpenVPN > ++ Certificate has EKU (str) TLS Web Server Authentication, expects TLS Web Server Authentication. 2016.08.18 04:43:23 - OpenVPN > VERIFY EKU OK. 2016.08.18 04:43:23 - OpenVPN > VERIFY OK: depth=0, C=IT, ST=IT, L=Perugia, O=airvpn.org, CN=server, emailAddress=info@airvpn.org. 2016.08.18 04:43:24 - OpenVPN > Data Channel Encrypt: Cipher 'AES-256-CBC' initialized with 256 bit key. 2016.08.18 04:43:24 - OpenVPN > Data Channel Encrypt: Using 160 bit message hash 'SHA1' for HMAC authentication. 2016.08.18 04:43:24 - OpenVPN > Data Channel Decrypt: Cipher 'AES-256-CBC' initialized with 256 bit key. 2016.08.18 04:43:24 - OpenVPN > Data Channel Decrypt: Using 160 bit message hash 'SHA1' for HMAC authentication. 2016.08.18 04:43:24 - OpenVPN > Control Channel: TLSv1.2, cipher TLSv1/SSLv3 DHE-RSA-AES256-GCM-SHA384, 4096 bit RSA. 2016.08.18 04:43:24 - OpenVPN > [server] Peer Connection Initiated with [AF_INET]46.165.208.65:443. 2016.08.18 04:43:26 - OpenVPN > SENT CONTROL [server]: 'PUSH_REQUEST' (status=1). 2016.08.18 04:43:26 - OpenVPN > PUSH: Received control message: 'PUSH_REPLY,redirect-gateway def1 bypass-dhcp,dhcp-option DNS 10.4.0.1,comp-lzo no,route-gateway 10.4.0.1,topology subnet,ping 10,ping-restart 60,ifconfig 10.4.27.60 255.255.0.0'. 2016.08.18 04:43:26 - OpenVPN > OPTIONS IMPORT: timers and/or timeouts modified. 2016.08.18 04:43:26 - OpenVPN > OPTIONS IMPORT: LZO parms modified. 2016.08.18 04:43:26 - OpenVPN > OPTIONS IMPORT: --ifconfig/up options modified. 2016.08.18 04:43:26 - OpenVPN > OPTIONS IMPORT: route options modified. 2016.08.18 04:43:26 - OpenVPN > OPTIONS IMPORT: route-related options modified. 2016.08.18 04:43:26 - OpenVPN > OPTIONS IMPORT: --ip-win32 and/or --dhcp-option options modified. 2016.08.18 04:43:26 - OpenVPN > do_ifconfig, tt->ipv6=0, tt->did_ifconfig_ipv6_setup=0. 2016.08.18 04:43:26 - OpenVPN > open_tun, tt->ipv6=0. 2016.08.18 04:43:26 - OpenVPN > TAP-WIN32 device [Ethernet 2] opened: \\.\Global\{3A8EBBF0-65E6-4014-89B1-E9F76DAA9B3E}.tap. 2016.08.18 04:43:26 - OpenVPN > TAP-Windows Driver Version 9.21. 2016.08.18 04:43:26 - OpenVPN > Set TAP-Windows TUN subnet mode network/local/netmask = 10.4.0.0/10.4.27.60/255.255.0.0 [sUCCEEDED]. 2016.08.18 04:43:26 - OpenVPN > Notified TAP-Windows driver to set a DHCP IP/netmask of 10.4.27.60/255.255.0.0 on interface {3A8EBBF0-65E6-4014-89B1-E9F76DAA9B3E} [DHCP-serv: 10.4.255.254, lease-time: 31536000]. 2016.08.18 04:43:26 - OpenVPN > Successful ARP Flush on interface [4] {3A8EBBF0-65E6-4014-89B1-E9F76DAA9B3E}. 2016.08.18 04:43:32 - OpenVPN > TEST ROUTES: 1/1 succeeded len=0 ret=1 a=0 u/d=up. 2016.08.18 04:43:32 - OpenVPN > C:\Windows\system32\route.exe ADD 46.165.208.65 MASK 255.255.255.255 192.168.178.1. 2016.08.18 04:43:32 - OpenVPN > ROUTE: route addition failed using CreateIpForwardEntry: The object already exists. [status=5010 if_index=11]. 2016.08.18 04:43:32 - OpenVPN > Route addition via IPAPI failed [adaptive]. 2016.08.18 04:43:32 - OpenVPN > Route addition fallback to route.exe. 2016.08.18 04:43:32 - OpenVPN > env_block: add PATH=C:\Windows\System32;C:\WINDOWS;C:\WINDOWS\System32\Wbem. 2016.08.18 04:43:32 - OpenVPN > C:\Windows\system32\route.exe ADD 192.168.178.1 MASK 255.255.255.255 192.168.178.1 IF 11. 2016.08.18 04:43:32 - OpenVPN > ROUTE: route addition failed using CreateIpForwardEntry: The object already exists. [status=5010 if_index=11]. 2016.08.18 04:43:32 - OpenVPN > Route addition via IPAPI failed [adaptive]. 2016.08.18 04:43:32 - OpenVPN > Route addition fallback to route.exe. 2016.08.18 04:43:32 - OpenVPN > env_block: add PATH=C:\Windows\System32;C:\WINDOWS;C:\WINDOWS\System32\Wbem. 2016.08.18 04:43:32 - OpenVPN > C:\Windows\system32\route.exe ADD 0.0.0.0 MASK 128.0.0.0 10.4.0.1. 2016.08.18 04:43:32 - OpenVPN > ROUTE: route addition failed using CreateIpForwardEntry: The object already exists. [status=5010 if_index=4]. 2016.08.18 04:43:32 - OpenVPN > Route addition via IPAPI failed [adaptive]. 2016.08.18 04:43:32 - OpenVPN > Route addition fallback to route.exe. 2016.08.18 04:43:32 - OpenVPN > env_block: add PATH=C:\Windows\System32;C:\WINDOWS;C:\WINDOWS\System32\Wbem. 2016.08.18 04:43:32 - OpenVPN > C:\Windows\system32\route.exe ADD 128.0.0.0 MASK 128.0.0.0 10.4.0.1. 2016.08.18 04:43:32 - OpenVPN > ROUTE: route addition failed using CreateIpForwardEntry: The object already exists. [status=5010 if_index=4]. 2016.08.18 04:43:32 - OpenVPN > Route addition via IPAPI failed [adaptive]. 2016.08.18 04:43:32 - OpenVPN > Route addition fallback to route.exe. 2016.08.18 04:43:32 - OpenVPN > env_block: add PATH=C:\Windows\System32;C:\WINDOWS;C:\WINDOWS\System32\Wbem. 2016.08.18 04:43:32 - Starting Management Interface. 2016.08.18 04:43:32 - OpenVPN > Initialization Sequence CompletedI 2016.08.18 04:43:32 - DNS of a network adapter forced (Killer e2200 Gigabit Ethernet Controller)I 2016.08.18 04:43:32 - DNS of a network adapter forced (TAP-Windows Adapter V9)I 2016.08.18 04:43:32 - Flushing DNSI 2016.08.18 04:43:32 - Checking routeI 2016.08.18 04:43:56 - Checking DNS! 2016.08.18 04:43:56 - Connected.. 2016.08.18 04:43:56 - OpenVPN > MANAGEMENT: Client connected from [AF_INET]127.0.0.1:3100. 2016.08.18 04:43:56 - OpenVpn Management > >INFO:OpenVPN Management Interface Version 1 -- type 'help' for more info! 2016.08.18 04:44:29 - Disconnecting. 2016.08.18 04:44:29 - Management - Send 'signal SIGTERM'. 2016.08.18 04:44:29 - OpenVPN > MANAGEMENT: CMD 'signal SIGTERM'. 2016.08.18 04:44:29 - OpenVPN > SIGTERM received, sending exit notification to peer. 2016.08.18 04:44:34 - OpenVPN > C:\Windows\system32\route.exe DELETE 46.165.208.65 MASK 255.255.255.255 192.168.178.1. 2016.08.18 04:44:34 - OpenVPN > Route deletion via IPAPI succeeded [adaptive]. 2016.08.18 04:44:34 - OpenVPN > C:\Windows\system32\route.exe DELETE 192.168.178.1 MASK 255.255.255.255 192.168.178.1. 2016.08.18 04:44:34 - OpenVPN > Route deletion via IPAPI succeeded [adaptive]. 2016.08.18 04:44:34 - OpenVPN > C:\Windows\system32\route.exe DELETE 0.0.0.0 MASK 128.0.0.0 10.4.0.1. 2016.08.18 04:44:34 - OpenVPN > Route deletion via IPAPI succeeded [adaptive]. 2016.08.18 04:44:34 - OpenVPN > C:\Windows\system32\route.exe DELETE 128.0.0.0 MASK 128.0.0.0 10.4.0.1. 2016.08.18 04:44:34 - OpenVPN > Route deletion via IPAPI succeeded [adaptive]. 2016.08.18 04:44:34 - OpenVPN > Closing TUN/TAP interface. 2016.08.18 04:44:34 - OpenVPN > SIGTERM[soft,exit-with-notification] received, process exiting. 2016.08.18 04:44:34 - Connection terminated.I 2016.08.18 04:44:34 - DNS of a network adapter restored to original settings (Killer e2200 Gigabit Ethernet Controller)I 2016.08.18 04:44:34 - DNS of a network adapter restored to original settings (TAP-Windows Adapter V9)I 2016.08.18 04:44:34 - IPv6 restored.! 2016.08.18 04:44:34 - Session terminated. Thank you Quote Hide Firas22's signature Hide all signatures Share this post Link to post
Guest Posted ... @ EdensSpire I just signed up for openDNS and i have an account and I am using there dns numbers ,, Airvpn after 30 minutes or so disconnects and uses this stupid number again 10.4.0.1 Thank youAs I told you further up, it will ALWAYS use the DNS server on the airvpn servers since it has most security if you do NOT wanna use them you have to disable the DNS changer, or even better add the DNS IPs that you wanna use in the client and it'll use those. But as it is Staff likely can't do any more than we have done here since the problem so far is something we can't determine and if we can't the staff here likely can't either. Quote Share this post Link to post
Firas22 1 Posted ... Ok I have been reading all night about this DNS thing I found this DNSjumber and I have downloaded airvpn again with the TAP 9.9.2.3 and ran it togather , for the first hour and half I did not do anything i was just watching it to see where it will disconnect then reconnect then tried a few downloads and every thing is ok but i did noticed big time internet slowdown also I dont know why but i cant get any ports to get the green light for testing and this 10.4.0.1 is still there http://pasteboard.co/a81thDKoH.png http://pasteboard.co/a8220uEn5.png thank you Quote Hide Firas22's signature Hide all signatures Share this post Link to post
Firas22 1 Posted ... Good Day I am trying to get a forward port but non of them get the green light when i hit the check button so i have opened the same port number on my firewall and now i have a green light My Question is did I do this correctly ? thank you will be waiting update airvpn is still running smooth ever since i have used this DNSjumper Quote Hide Firas22's signature Hide all signatures Share this post Link to post
Tech Jedi Alex 1499 Posted ... After all of this windows is clean from any spyware malware or anything els "Windows is a supertrojan. It contains spyware, can download new malicious code automatically and is so advanced, it's there before you get the chance to use your computer for the first time. To top it all, it disguises itself as a useful program." 1 Firas22 reacted to this Quote Hide Tech Jedi Alex's signature Hide all signatures NOT AN AIRVPN TEAM MEMBER. USE TICKETS FOR PROFESSIONAL SUPPORT. LZ1's New User Guide to AirVPN « Plenty of stuff for advanced users, too! Want to contact me directly? All relevant methods are on my About me page. Share this post Link to post
Firas22 1 Posted ... Ok I have been reading all night about this DNS thing I found this DNSjumber and I have downloaded airvpn again with the TAP 9.9.2.3 and ran it togather , for the first hour and half I did not do anything i was just watching it to see where it will disconnect then reconnect then tried a few downloads and every thing is ok but i did noticed big time internet slowdown also I dont know why but i cant get any ports to get the green light for testing and this 10.4.0.1 is still there http://pasteboard.co/a81thDKoH.png http://pasteboard.co/a8220uEn5.png thank you I am gonna get a little harsh in this post but, you STILL have not disabled the DNS feature in the AIRVPN CLIENT! if you do not disable it, it will ALWAYS freaking change your DNS address to 10.4.0.1 Thank you very much never saw that didnt even know i had other options untail you told me many thanks your the best http://pasteboard.co/aAKT2eLqa.png Quote Hide Firas22's signature Hide all signatures Share this post Link to post
Firas22 1 Posted ... After all of this windows is clean from any spyware malware or anything els "Windows is a supertrojan. It contains spyware, can download new malicious code automatically and is so advanced, it's there before you get the chance to use your computer for the first time. To top it all, it disguises itself as a useful program." So should i go back to Linux ? Quote Hide Firas22's signature Hide all signatures Share this post Link to post
Tech Jedi Alex 1499 Posted ... After all of this windows is clean from any spyware malware or anything els "Windows is a supertrojan. It contains spyware, can download new malicious code automatically and is so advanced, it's there before you get the chance to use your computer for the first time. To top it all, it disguises itself as a useful program." So should i go back to Linux ? Use what you can use. Quote Hide Tech Jedi Alex's signature Hide all signatures NOT AN AIRVPN TEAM MEMBER. USE TICKETS FOR PROFESSIONAL SUPPORT. LZ1's New User Guide to AirVPN « Plenty of stuff for advanced users, too! Want to contact me directly? All relevant methods are on my About me page. Share this post Link to post
