junkeebizness
AirVPN not connecting.
El Capitan, AirVPN ver 2.10.3
This is my first time using a VPN, and already running into connection problems. After I run AirVPN, it tries to connect to various servers, but disconnects eventually, tries again and disconnects again and it doesn't connect ever. I was able to connect to a server few days ago, but the speed was max 2 Mbps. And now it doesn't even connect. I have attached a gif of what my main window does. Anyone know where I messed up?
. 2016.08.15 21:54:04 - OpenVPN > ifconfig: ioctl (SIOCDIFADDR): Can't assign requested address
. 2016.08.15 21:54:04 - OpenVPN > route: writing to routing socket: File exists
. 2016.08.15 21:54:04 - OpenVPN > NOTE: Tried to delete pre-existing tun/tap instance -- No Problem if failure
. 2016.08.15 21:54:04 - OpenVPN > /sbin/ifconfig utun1 10.4.70.225 10.4.70.225 netmask 255.255.0.0 mtu 1500 up
. 2016.08.15 21:54:04 - OpenVPN > /sbin/route add -net 10.4.0.0 10.4.70.225 255.255.0.0
. 2016.08.15 21:54:04 - OpenVPN > add net 10.4.0.0: gateway 10.4.70.225: File exists
Normally a reboot should fix it (or if you decide to manually bring it down and flush the routes with sudo terminal). This sometimes happen on OSX.
