Firas22
Many Problems with DNS not responding
Good Day
I have been having many problems with DNS  not reachable  or DNS not responding and so on
I had to Delete Airvpn  still that did not work then i deleted drivers for Ethernet card   and reinstall them
and yes i did the flush dns  and reset and every thing
I would Like if some one can help me in this department about DNS problems please
every time I went to ip4  then properties  the dns number was the same number for the vpn adapter
I just need help to set it up correctly
I will install client again
thank you
Before I download  I also would Like to know
do i have to get the windows version ?
or what is this SSH  and SSL  can i use them ?
Here i am confused  I would really like to set it up right this time
windows 10 home 64x  with Anniversary update
so i will just wait until some one will direct me on what to download
thank you
Hello !
If you're on windows then yes download the windows version. The installer comes with everything you need.
Unless you're being blocked or want to hide that you're using a VPN, SSH and SSL aren't necessary. Just stick to UDP or TCP. It's an automatic setting, so there's no need to change anything.
In the IPv4 properties area, check that both IPv4 and the DNS fields have "Obtain xx automatically" checked. You can disable IPv6 as well, as it's not recommend that you use it.
After downloading, you might also want to change your TAP drivers; simply check out the stickied threads in the troubleshooting forum.
If there's anything else, please provide logs, from the logs tab, in the Eddie client, thank you. Also, Eddie already does things like flushing the DNS.
LZ1
Thank you for you answer
I was waiting all day hhhh
I will install and come back and update you
you say that     DNS fields have "Obtain xx automatically"  ok this was not the case with me  they always had  a  number
thank you
Ok  Finally got connected  here is my Logs please look and see
I dont know if this is normal  But it took a very long time to connect
I 2016.08.14 14:33:59 - AirVPN client version: 2.10.3 / x64, System: Windows, Name: Microsoft Windows NT 6.2.9200.0 / x64
. 2016.08.14 14:33:59 - Reading options from C:\Users\Emudem\AppData\Local\AirVPN\AirVPN.xml
. 2016.08.14 14:33:59 - Data Path: C:\Users\Emudem\AppData\Local\AirVPN
. 2016.08.14 14:33:59 - App Path: C:\AirVPN
. 2016.08.14 14:33:59 - Executable Path: C:\AirVPN\AirVPN.exe
. 2016.08.14 14:33:59 - Command line arguments (1): path="home"
. 2016.08.14 14:33:59 - Operating System: Microsoft Windows NT 6.2.9200.0
. 2016.08.14 14:33:59 - Updating systems & servers data ...
. 2016.08.14 14:33:59 - Systems & servers data update completed
I 2016.08.14 14:33:59 - OpenVPN Driver - TAP-Windows Adapter V9, version 9.21.1
I 2016.08.14 14:33:59 - OpenVPN - Version: OpenVPN 2.3.8 (C:\AirVPN\openvpn.exe)
I 2016.08.14 14:33:59 - SSH - Version: plink 0.63 (C:\AirVPN\plink.exe)
I 2016.08.14 14:33:59 - SSL - Version: stunnel 5.17 (C:\AirVPN\stunnel.exe)
! 2016.08.14 14:33:59 - Ready
I 2016.08.14 14:34:06 - Session starting.
I 2016.08.14 14:34:06 - IPv6 disabled.
I 2016.08.14 14:34:51 - Checking authorization ...
! 2016.08.14 14:34:51 - Connecting to Miram (Netherlands, Alblasserdam)
. 2016.08.14 14:36:50 - OpenVPN > OpenVPN 2.3.8 x86_64-w64-mingw32 [sSL (OpenSSL)] [LZO] [iPv6] built on Aug 13 2015
. 2016.08.14 14:36:50 - OpenVPN > library versions: OpenSSL 1.0.2d 9 Jul 2015, LZO 2.08
. 2016.08.14 14:36:50 - OpenVPN > MANAGEMENT: TCP Socket listening on [AF_INET]127.0.0.1:3100
. 2016.08.14 14:36:50 - OpenVPN > Control Channel Authentication: tls-auth using INLINE static key file
. 2016.08.14 14:36:50 - OpenVPN > Outgoing Control Channel Authentication: Using 160 bit message hash 'SHA1' for HMAC authentication
. 2016.08.14 14:36:50 - OpenVPN > Incoming Control Channel Authentication: Using 160 bit message hash 'SHA1' for HMAC authentication
. 2016.08.14 14:36:50 - OpenVPN > Socket Buffers: R=[65536->131072] S=[65536->131072]
. 2016.08.14 14:36:50 - OpenVPN > UDPv4 link local: [undef]
. 2016.08.14 14:36:50 - OpenVPN > UDPv4 link remote: [AF_INET]213.152.162.88:443
. 2016.08.14 14:36:50 - OpenVPN > TLS: Initial packet from [AF_INET]213.152.162.88:443, sid=0e47506f 13b40e71
. 2016.08.14 14:36:50 - OpenVPN > VERIFY OK: depth=1, C=IT, ST=IT, L=Perugia, O=airvpn.org, CN=airvpn.org CA, emailAddress=info@airvpn.org
. 2016.08.14 14:36:50 - OpenVPN > Validating certificate key usage
. 2016.08.14 14:36:50 - OpenVPN > ++ Certificate has key usage 00a0, expects 00a0
. 2016.08.14 14:36:50 - OpenVPN > VERIFY KU OK
. 2016.08.14 14:36:50 - OpenVPN > Validating certificate extended key usage
. 2016.08.14 14:36:50 - OpenVPN > ++ Certificate has EKU (str) TLS Web Server Authentication, expects TLS Web Server Authentication
. 2016.08.14 14:36:50 - OpenVPN > VERIFY EKU OK
. 2016.08.14 14:36:50 - OpenVPN > VERIFY OK: depth=0, C=IT, ST=IT, L=Perugia, O=airvpn.org, CN=server, emailAddress=info@airvpn.org
. 2016.08.14 14:36:50 - OpenVPN > Data Channel Encrypt: Cipher 'AES-256-CBC' initialized with 256 bit key
. 2016.08.14 14:36:50 - OpenVPN > Data Channel Encrypt: Using 160 bit message hash 'SHA1' for HMAC authentication
. 2016.08.14 14:36:50 - OpenVPN > Data Channel Decrypt: Cipher 'AES-256-CBC' initialized with 256 bit key
. 2016.08.14 14:36:50 - OpenVPN > Data Channel Decrypt: Using 160 bit message hash 'SHA1' for HMAC authentication
. 2016.08.14 14:36:50 - OpenVPN > Control Channel: TLSv1.2, cipher TLSv1/SSLv3 DHE-RSA-AES256-GCM-SHA384, 4096 bit RSA
. 2016.08.14 14:36:50 - OpenVPN > [server] Peer Connection Initiated with [AF_INET]213.152.162.88:443
. 2016.08.14 14:36:50 - OpenVPN > SENT CONTROL [server]: 'PUSH_REQUEST' (status=1)
. 2016.08.14 14:36:50 - OpenVPN > PUSH: Received control message: 'PUSH_REPLY,redirect-gateway def1 bypass-dhcp,dhcp-option DNS 10.4.0.1,comp-lzo no,route-gateway 10.4.0.1,topology subnet,ping 10,ping-restart 60,ifconfig 10.4.75.147 255.255.0.0'
. 2016.08.14 14:36:50 - OpenVPN > OPTIONS IMPORT: timers and/or timeouts modified
. 2016.08.14 14:36:50 - OpenVPN > OPTIONS IMPORT: LZO parms modified
. 2016.08.14 14:36:50 - OpenVPN > OPTIONS IMPORT: --ifconfig/up options modified
. 2016.08.14 14:36:50 - OpenVPN > OPTIONS IMPORT: route options modified
. 2016.08.14 14:36:50 - OpenVPN > OPTIONS IMPORT: route-related options modified
. 2016.08.14 14:36:50 - OpenVPN > OPTIONS IMPORT: --ip-win32 and/or --dhcp-option options modified
. 2016.08.14 14:36:50 - OpenVPN > do_ifconfig, tt->ipv6=0, tt->did_ifconfig_ipv6_setup=0
. 2016.08.14 14:36:50 - OpenVPN > open_tun, tt->ipv6=0
. 2016.08.14 14:36:50 - OpenVPN > TAP-WIN32 device [Ethernet 2] opened: \\.\Global\{5342D826-9FD5-4B3E-A915-554A736E2963}.tap
. 2016.08.14 14:36:50 - OpenVPN > TAP-Windows Driver Version 9.21
. 2016.08.14 14:36:50 - OpenVPN > Set TAP-Windows TUN subnet mode network/local/netmask = 10.4.0.0/10.4.75.147/255.255.0.0 [sUCCEEDED]
. 2016.08.14 14:36:50 - OpenVPN > Notified TAP-Windows driver to set a DHCP IP/netmask of 10.4.75.147/255.255.0.0 on interface {5342D826-9FD5-4B3E-A915-554A736E2963} [DHCP-serv: 10.4.255.254, lease-time: 31536000]
. 2016.08.14 14:36:50 - OpenVPN > Successful ARP Flush on interface [6] {5342D826-9FD5-4B3E-A915-554A736E2963}
. 2016.08.14 14:36:50 - OpenVPN > TEST ROUTES: 1/1 succeeded len=0 ret=1 a=0 u/d=up
. 2016.08.14 14:36:50 - OpenVPN > C:\WINDOWS\system32\route.exe ADD 213.152.162.88 MASK 255.255.255.255 192.168.178.1
. 2016.08.14 14:36:50 - OpenVPN > ROUTE: CreateIpForwardEntry succeeded with dwForwardMetric1=35 and dwForwardType=4
. 2016.08.14 14:36:50 - OpenVPN > Route addition via IPAPI succeeded [adaptive]
. 2016.08.14 14:36:50 - OpenVPN > C:\WINDOWS\system32\route.exe ADD 192.168.178.1 MASK 255.255.255.255 192.168.178.1 IF 4
. 2016.08.14 14:36:50 - OpenVPN > C:\WINDOWS\system32\route.exe ADD 0.0.0.0 MASK 128.0.0.0 10.4.0.1
. 2016.08.14 14:36:50 - OpenVPN > C:\WINDOWS\system32\route.exe ADD 128.0.0.0 MASK 128.0.0.0 10.4.0.1
. 2016.08.14 14:36:50 - Starting Management Interface
. 2016.08.14 14:36:50 - OpenVPN > Initialization Sequence Completed
. 2016.08.14 14:36:50 - OpenVPN > [server] Inactivity timeout (--ping-restart), restarting
. 2016.08.14 14:36:50 - OpenVPN > SIGUSR1[soft,ping-restart] received, process restarting
. 2016.08.14 14:36:50 - OpenVPN > Restart pause, 2 second(s)
! 2016.08.14 14:36:50 - Disconnecting
. 2016.08.14 14:36:50 - Management - Send 'signal SIGTERM'
. 2016.08.14 14:36:50 - OpenVpn Management > >INFO:OpenVPN Management Interface Version 1 -- type 'help' for more info
I 2016.08.14 14:36:50 - DNS of a network adapter forced (Killer E2200 Gigabit Ethernet Controller)
I 2016.08.14 14:36:50 - DNS of a network adapter forced (TAP-Windows Adapter V9)
I 2016.08.14 14:36:50 - Flushing DNS
W 2016.08.14 14:36:51 - Waiting TUN interface
. 2016.08.14 14:36:51 - Connection terminated.
I 2016.08.14 14:36:51 - DNS of a network adapter restored to original settings (Killer E2200 Gigabit Ethernet Controller)
I 2016.08.14 14:36:51 - DNS of a network adapter restored to original settings (TAP-Windows Adapter V9)
W 2016.08.14 14:36:53 - Waiting TUN interface
I 2016.08.14 14:36:54 - Checking authorization ...
! 2016.08.14 14:36:54 - Connecting to Miram (Netherlands, Alblasserdam)
. 2016.08.14 14:36:54 - OpenVPN > OpenVPN 2.3.8 x86_64-w64-mingw32 [sSL (OpenSSL)] [LZO] [iPv6] built on Aug 13 2015
. 2016.08.14 14:36:54 - OpenVPN > library versions: OpenSSL 1.0.2d 9 Jul 2015, LZO 2.08
. 2016.08.14 14:36:54 - OpenVPN > MANAGEMENT: TCP Socket listening on [AF_INET]127.0.0.1:3100
. 2016.08.14 14:36:54 - OpenVPN > Control Channel Authentication: tls-auth using INLINE static key file
. 2016.08.14 14:36:54 - OpenVPN > Outgoing Control Channel Authentication: Using 160 bit message hash 'SHA1' for HMAC authentication
. 2016.08.14 14:36:54 - OpenVPN > Incoming Control Channel Authentication: Using 160 bit message hash 'SHA1' for HMAC authentication
. 2016.08.14 14:36:54 - OpenVPN > Socket Buffers: R=[65536->131072] S=[65536->131072]
. 2016.08.14 14:36:54 - OpenVPN > UDPv4 link local: [undef]
. 2016.08.14 14:36:54 - OpenVPN > UDPv4 link remote: [AF_INET]213.152.162.88:443
. 2016.08.14 14:36:54 - OpenVPN > TLS: Initial packet from [AF_INET]213.152.162.88:443, sid=c138a80f a742af18
. 2016.08.14 14:36:54 - OpenVPN > VERIFY OK: depth=1, C=IT, ST=IT, L=Perugia, O=airvpn.org, CN=airvpn.org CA, emailAddress=info@airvpn.org
. 2016.08.14 14:36:54 - OpenVPN > Validating certificate key usage
. 2016.08.14 14:36:54 - OpenVPN > ++ Certificate has key usage 00a0, expects 00a0
. 2016.08.14 14:36:54 - OpenVPN > VERIFY KU OK
. 2016.08.14 14:36:54 - OpenVPN > Validating certificate extended key usage
. 2016.08.14 14:36:54 - OpenVPN > ++ Certificate has EKU (str) TLS Web Server Authentication, expects TLS Web Server Authentication
. 2016.08.14 14:36:54 - OpenVPN > VERIFY EKU OK
. 2016.08.14 14:36:54 - OpenVPN > VERIFY OK: depth=0, C=IT, ST=IT, L=Perugia, O=airvpn.org, CN=server, emailAddress=info@airvpn.org
W 2016.08.14 14:36:55 - Waiting TUN interface
. 2016.08.14 14:37:01 - OpenVPN > Data Channel Encrypt: Cipher 'AES-256-CBC' initialized with 256 bit key
. 2016.08.14 14:37:01 - OpenVPN > Data Channel Encrypt: Using 160 bit message hash 'SHA1' for HMAC authentication
. 2016.08.14 14:37:01 - OpenVPN > Data Channel Decrypt: Cipher 'AES-256-CBC' initialized with 256 bit key
. 2016.08.14 14:37:01 - OpenVPN > Data Channel Decrypt: Using 160 bit message hash 'SHA1' for HMAC authentication
. 2016.08.14 14:37:01 - OpenVPN > Control Channel: TLSv1.2, cipher TLSv1/SSLv3 DHE-RSA-AES256-GCM-SHA384, 4096 bit RSA
. 2016.08.14 14:37:01 - OpenVPN > [server] Peer Connection Initiated with [AF_INET]213.152.162.88:443
W 2016.08.14 14:37:01 - Tunnel not ready in 10 seconds, contact our support. Last interface status: Down
. 2016.08.14 14:37:01 - OpenVPN > MANAGEMENT: Client connected from [AF_INET]127.0.0.1:3100
. 2016.08.14 14:37:01 - OpenVPN > MANAGEMENT: CMD 'signal SIGTERM'
. 2016.08.14 14:37:01 - OpenVPN > MANAGEMENT: Client disconnected
. 2016.08.14 14:37:01 - OpenVPN > Assertion failed at misc.c:779
. 2016.08.14 14:37:01 - OpenVPN > Exiting due to fatal error
! 2016.08.14 14:37:01 - Disconnecting
. 2016.08.14 14:37:01 - Connection terminated.
I 2016.08.14 14:37:04 - Cancel requested.
I 2016.08.14 14:37:04 - IPv6 restored.
! 2016.08.14 14:37:04 - Session terminated.
I 2016.08.14 14:37:37 - Session starting.
I 2016.08.14 14:37:37 - IPv6 disabled.
I 2016.08.14 14:37:37 - Checking authorization ...
! 2016.08.14 14:37:37 - Connecting to Velorum (Germany, Frankfurt)
. 2016.08.14 14:38:54 - OpenVPN > OpenVPN 2.3.8 x86_64-w64-mingw32 [sSL (OpenSSL)] [LZO] [iPv6] built on Aug 13 2015
. 2016.08.14 14:38:54 - OpenVPN > library versions: OpenSSL 1.0.2d 9 Jul 2015, LZO 2.08
. 2016.08.14 14:38:54 - OpenVPN > MANAGEMENT: TCP Socket listening on [AF_INET]127.0.0.1:3100
. 2016.08.14 14:38:54 - OpenVPN > Control Channel Authentication: tls-auth using INLINE static key file
. 2016.08.14 14:38:54 - OpenVPN > Outgoing Control Channel Authentication: Using 160 bit message hash 'SHA1' for HMAC authentication
. 2016.08.14 14:38:54 - OpenVPN > Incoming Control Channel Authentication: Using 160 bit message hash 'SHA1' for HMAC authentication
. 2016.08.14 14:38:54 - OpenVPN > Socket Buffers: R=[65536->131072] S=[65536->131072]
. 2016.08.14 14:38:54 - OpenVPN > UDPv4 link local: [undef]
. 2016.08.14 14:38:54 - OpenVPN > UDPv4 link remote: [AF_INET]46.165.208.69:443
. 2016.08.14 14:38:54 - OpenVPN > TLS: Initial packet from [AF_INET]46.165.208.69:443, sid=8cb0179f 4c5155bf
. 2016.08.14 14:38:54 - OpenVPN > VERIFY OK: depth=1, C=IT, ST=IT, L=Perugia, O=airvpn.org, CN=airvpn.org CA, emailAddress=info@airvpn.org
. 2016.08.14 14:38:54 - OpenVPN > Validating certificate key usage
. 2016.08.14 14:38:54 - OpenVPN > ++ Certificate has key usage 00a0, expects 00a0
. 2016.08.14 14:38:54 - OpenVPN > VERIFY KU OK
. 2016.08.14 14:38:54 - OpenVPN > Validating certificate extended key usage
. 2016.08.14 14:38:54 - OpenVPN > ++ Certificate has EKU (str) TLS Web Server Authentication, expects TLS Web Server Authentication
. 2016.08.14 14:38:54 - OpenVPN > VERIFY EKU OK
. 2016.08.14 14:38:54 - OpenVPN > VERIFY OK: depth=0, C=IT, ST=IT, L=Perugia, O=airvpn.org, CN=server, emailAddress=info@airvpn.org
. 2016.08.14 14:38:54 - OpenVPN > Data Channel Encrypt: Cipher 'AES-256-CBC' initialized with 256 bit key
. 2016.08.14 14:38:54 - OpenVPN > Data Channel Encrypt: Using 160 bit message hash 'SHA1' for HMAC authentication
. 2016.08.14 14:38:54 - OpenVPN > Data Channel Decrypt: Cipher 'AES-256-CBC' initialized with 256 bit key
. 2016.08.14 14:38:54 - OpenVPN > Data Channel Decrypt: Using 160 bit message hash 'SHA1' for HMAC authentication
. 2016.08.14 14:38:54 - OpenVPN > Control Channel: TLSv1.2, cipher TLSv1/SSLv3 DHE-RSA-AES256-GCM-SHA384, 4096 bit RSA
. 2016.08.14 14:38:54 - OpenVPN > [server] Peer Connection Initiated with [AF_INET]46.165.208.69:443
. 2016.08.14 14:38:54 - OpenVPN > SENT CONTROL [server]: 'PUSH_REQUEST' (status=1)
. 2016.08.14 14:38:54 - OpenVPN > PUSH: Received control message: 'PUSH_REPLY,redirect-gateway def1 bypass-dhcp,dhcp-option DNS 10.4.0.1,comp-lzo no,route-gateway 10.4.0.1,topology subnet,ping 10,ping-restart 60,ifconfig 10.4.21.208 255.255.0.0'
. 2016.08.14 14:38:54 - OpenVPN > OPTIONS IMPORT: timers and/or timeouts modified
. 2016.08.14 14:38:54 - OpenVPN > OPTIONS IMPORT: LZO parms modified
. 2016.08.14 14:38:54 - OpenVPN > OPTIONS IMPORT: --ifconfig/up options modified
. 2016.08.14 14:38:54 - OpenVPN > OPTIONS IMPORT: route options modified
. 2016.08.14 14:38:54 - OpenVPN > OPTIONS IMPORT: route-related options modified
. 2016.08.14 14:38:54 - OpenVPN > OPTIONS IMPORT: --ip-win32 and/or --dhcp-option options modified
. 2016.08.14 14:38:54 - OpenVPN > do_ifconfig, tt->ipv6=0, tt->did_ifconfig_ipv6_setup=0
. 2016.08.14 14:38:54 - OpenVPN > open_tun, tt->ipv6=0
. 2016.08.14 14:38:54 - OpenVPN > TAP-WIN32 device [Ethernet 2] opened: \\.\Global\{5342D826-9FD5-4B3E-A915-554A736E2963}.tap
. 2016.08.14 14:38:54 - OpenVPN > TAP-Windows Driver Version 9.21
. 2016.08.14 14:38:54 - OpenVPN > Set TAP-Windows TUN subnet mode network/local/netmask = 10.4.0.0/10.4.21.208/255.255.0.0 [sUCCEEDED]
. 2016.08.14 14:38:54 - OpenVPN > Notified TAP-Windows driver to set a DHCP IP/netmask of 10.4.21.208/255.255.0.0 on interface {5342D826-9FD5-4B3E-A915-554A736E2963} [DHCP-serv: 10.4.255.254, lease-time: 31536000]
. 2016.08.14 14:38:54 - OpenVPN > Successful ARP Flush on interface [6] {5342D826-9FD5-4B3E-A915-554A736E2963}
. 2016.08.14 14:38:54 - OpenVPN > write UDPv4: No Route to Host (WSAEHOSTUNREACH) (code=10065)
. 2016.08.14 14:38:54 - OpenVPN > TEST ROUTES: 1/1 succeeded len=0 ret=1 a=0 u/d=up
. 2016.08.14 14:38:54 - OpenVPN > C:\WINDOWS\system32\route.exe ADD 46.165.208.69 MASK 255.255.255.255 192.168.178.1
. 2016.08.14 14:38:54 - OpenVPN > ROUTE: CreateIpForwardEntry succeeded with dwForwardMetric1=35 and dwForwardType=4
. 2016.08.14 14:38:54 - OpenVPN > Route addition via IPAPI succeeded [adaptive]
. 2016.08.14 14:38:54 - OpenVPN > C:\WINDOWS\system32\route.exe ADD 192.168.178.1 MASK 255.255.255.255 192.168.178.1 IF 4
. 2016.08.14 14:38:54 - OpenVPN > ROUTE: route addition failed using CreateIpForwardEntry: The object already exists. [status=5010 if_index=4]
. 2016.08.14 14:38:54 - OpenVPN > Route addition via IPAPI failed [adaptive]
. 2016.08.14 14:38:54 - OpenVPN > Route addition fallback to route.exe
. 2016.08.14 14:38:54 - OpenVPN > env_block: add PATH=C:\Windows\System32;C:\WINDOWS;C:\WINDOWS\System32\Wbem
. 2016.08.14 14:38:54 - OpenVPN > C:\WINDOWS\system32\route.exe ADD 0.0.0.0 MASK 128.0.0.0 10.4.0.1
. 2016.08.14 14:38:54 - OpenVPN > ROUTE: route addition failed using CreateIpForwardEntry: The object already exists. [status=5010 if_index=6]
. 2016.08.14 14:38:54 - OpenVPN > C:\WINDOWS\system32\route.exe ADD 128.0.0.0 MASK 128.0.0.0 10.4.0.1
. 2016.08.14 14:38:54 - Starting Management Interface
. 2016.08.14 14:38:54 - OpenVPN > Initialization Sequence Completed
. 2016.08.14 14:38:54 - OpenVPN > [server] Inactivity timeout (--ping-restart), restarting
. 2016.08.14 14:38:54 - OpenVPN > SIGUSR1[soft,ping-restart] received, process restarting
. 2016.08.14 14:38:54 - OpenVPN > Restart pause, 2 second(s)
I 2016.08.14 14:38:54 - DNS of a network adapter forced (Killer E2200 Gigabit Ethernet Controller)
I 2016.08.14 14:38:54 - DNS of a network adapter forced (TAP-Windows Adapter V9)
! 2016.08.14 14:38:54 - Disconnecting
. 2016.08.14 14:38:54 - Management - Send 'signal SIGTERM'
. 2016.08.14 14:38:54 - OpenVpn Management > >INFO:OpenVPN Management Interface Version 1 -- type 'help' for more info
I 2016.08.14 14:38:54 - Flushing DNS
W 2016.08.14 14:38:54 - Waiting TUN interface
. 2016.08.14 14:38:54 - Connection terminated.
I 2016.08.14 14:38:54 - DNS of a network adapter restored to original settings (Killer E2200 Gigabit Ethernet Controller)
I 2016.08.14 14:38:54 - DNS of a network adapter restored to original settings (TAP-Windows Adapter V9)
W 2016.08.14 14:38:56 - Waiting TUN interface
I 2016.08.14 14:38:57 - Checking authorization ...
! 2016.08.14 14:38:57 - Connecting to Velorum (Germany, Frankfurt)
. 2016.08.14 14:38:57 - OpenVPN > OpenVPN 2.3.8 x86_64-w64-mingw32 [sSL (OpenSSL)] [LZO] [iPv6] built on Aug 13 2015
. 2016.08.14 14:38:57 - OpenVPN > library versions: OpenSSL 1.0.2d 9 Jul 2015, LZO 2.08
. 2016.08.14 14:38:57 - OpenVPN > MANAGEMENT: TCP Socket listening on [AF_INET]127.0.0.1:3100
. 2016.08.14 14:38:57 - OpenVPN > Control Channel Authentication: tls-auth using INLINE static key file
. 2016.08.14 14:38:57 - OpenVPN > Outgoing Control Channel Authentication: Using 160 bit message hash 'SHA1' for HMAC authentication
. 2016.08.14 14:38:57 - OpenVPN > Incoming Control Channel Authentication: Using 160 bit message hash 'SHA1' for HMAC authentication
. 2016.08.14 14:38:57 - OpenVPN > Socket Buffers: R=[65536->131072] S=[65536->131072]
. 2016.08.14 14:38:57 - OpenVPN > UDPv4 link local: [undef]
. 2016.08.14 14:38:57 - OpenVPN > UDPv4 link remote: [AF_INET]46.165.208.69:443
. 2016.08.14 14:38:57 - OpenVPN > TLS: Initial packet from [AF_INET]46.165.208.69:443, sid=f9a7e463 00364f98
. 2016.08.14 14:38:58 - OpenVPN > VERIFY OK: depth=1, C=IT, ST=IT, L=Perugia, O=airvpn.org, CN=airvpn.org CA, emailAddress=info@airvpn.org
. 2016.08.14 14:38:58 - OpenVPN > Validating certificate key usage
. 2016.08.14 14:38:58 - OpenVPN > ++ Certificate has key usage 00a0, expects 00a0
. 2016.08.14 14:38:58 - OpenVPN > VERIFY KU OK
. 2016.08.14 14:38:58 - OpenVPN > Validating certificate extended key usage
. 2016.08.14 14:38:58 - OpenVPN > ++ Certificate has EKU (str) TLS Web Server Authentication, expects TLS Web Server Authentication
. 2016.08.14 14:38:58 - OpenVPN > VERIFY EKU OK
. 2016.08.14 14:38:58 - OpenVPN > VERIFY OK: depth=0, C=IT, ST=IT, L=Perugia, O=airvpn.org, CN=server, emailAddress=info@airvpn.org
. 2016.08.14 14:38:58 - OpenVPN > Data Channel Encrypt: Cipher 'AES-256-CBC' initialized with 256 bit key
. 2016.08.14 14:38:58 - OpenVPN > Data Channel Encrypt: Using 160 bit message hash 'SHA1' for HMAC authentication
. 2016.08.14 14:38:58 - OpenVPN > Data Channel Decrypt: Cipher 'AES-256-CBC' initialized with 256 bit key
. 2016.08.14 14:38:58 - OpenVPN > Data Channel Decrypt: Using 160 bit message hash 'SHA1' for HMAC authentication
. 2016.08.14 14:38:58 - OpenVPN > Control Channel: TLSv1.2, cipher TLSv1/SSLv3 DHE-RSA-AES256-GCM-SHA384, 4096 bit RSA
. 2016.08.14 14:38:58 - OpenVPN > [server] Peer Connection Initiated with [AF_INET]46.165.208.69:443
W 2016.08.14 14:38:58 - Waiting TUN interface
. 2016.08.14 14:39:00 - OpenVPN > SENT CONTROL [server]: 'PUSH_REQUEST' (status=1)
. 2016.08.14 14:39:00 - OpenVPN > PUSH: Received control message: 'PUSH_REPLY,redirect-gateway def1 bypass-dhcp,dhcp-option DNS 10.4.0.1,comp-lzo no,route-gateway 10.4.0.1,topology subnet,ping 10,ping-restart 60,ifconfig 10.4.21.208 255.255.0.0'
. 2016.08.14 14:39:00 - OpenVPN > OPTIONS IMPORT: timers and/or timeouts modified
. 2016.08.14 14:39:00 - OpenVPN > OPTIONS IMPORT: LZO parms modified
. 2016.08.14 14:39:00 - OpenVPN > OPTIONS IMPORT: --ifconfig/up options modified
. 2016.08.14 14:39:00 - OpenVPN > OPTIONS IMPORT: route options modified
. 2016.08.14 14:39:00 - OpenVPN > OPTIONS IMPORT: route-related options modified
. 2016.08.14 14:39:00 - OpenVPN > OPTIONS IMPORT: --ip-win32 and/or --dhcp-option options modified
. 2016.08.14 14:39:00 - OpenVPN > do_ifconfig, tt->ipv6=0, tt->did_ifconfig_ipv6_setup=0
. 2016.08.14 14:39:00 - OpenVPN > open_tun, tt->ipv6=0
. 2016.08.14 14:39:00 - OpenVPN > TAP-WIN32 device [Ethernet 2] opened: \\.\Global\{5342D826-9FD5-4B3E-A915-554A736E2963}.tap
. 2016.08.14 14:39:00 - OpenVPN > TAP-Windows Driver Version 9.21
. 2016.08.14 14:39:00 - OpenVPN > Set TAP-Windows TUN subnet mode network/local/netmask = 10.4.0.0/10.4.21.208/255.255.0.0 [sUCCEEDED]
. 2016.08.14 14:39:00 - OpenVPN > Notified TAP-Windows driver to set a DHCP IP/netmask of 10.4.21.208/255.255.0.0 on interface {5342D826-9FD5-4B3E-A915-554A736E2963} [DHCP-serv: 10.4.255.254, lease-time: 31536000]
. 2016.08.14 14:39:00 - OpenVPN > Successful ARP Flush on interface [6] {5342D826-9FD5-4B3E-A915-554A736E2963}
I 2016.08.14 14:39:02 - Checking route
I 2016.08.14 14:39:05 - Checking DNS
. 2016.08.14 14:39:05 - OpenVPN > TEST ROUTES: 1/1 succeeded len=0 ret=1 a=0 u/d=up
. 2016.08.14 14:39:05 - OpenVPN > C:\WINDOWS\system32\route.exe ADD 46.165.208.69 MASK 255.255.255.255 192.168.178.1
. 2016.08.14 14:39:05 - OpenVPN > ROUTE: route addition failed using CreateIpForwardEntry: The object already exists. [status=5010 if_index=4]
. 2016.08.14 14:39:05 - OpenVPN > Route addition via IPAPI failed [adaptive]
. 2016.08.14 14:39:05 - OpenVPN > Route addition fallback to route.exe
. 2016.08.14 14:39:05 - OpenVPN > env_block: add PATH=C:\Windows\System32;C:\WINDOWS;C:\WINDOWS\System32\Wbem
. 2016.08.14 14:39:05 - OpenVPN > C:\WINDOWS\system32\route.exe ADD 192.168.178.1 MASK 255.255.255.255 192.168.178.1 IF 4
. 2016.08.14 14:39:05 - OpenVPN > C:\WINDOWS\system32\route.exe ADD 0.0.0.0 MASK 128.0.0.0 10.4.0.1
. 2016.08.14 14:39:05 - OpenVPN > ROUTE: route addition failed using CreateIpForwardEntry: The object already exists. [status=5010 if_index=6]
. 2016.08.14 14:39:05 - OpenVPN > C:\WINDOWS\system32\route.exe ADD 128.0.0.0 MASK 128.0.0.0 10.4.0.1
. 2016.08.14 14:39:05 - Starting Management Interface
. 2016.08.14 14:39:05 - OpenVPN > Initialization Sequence Completed
I 2016.08.14 14:39:05 - DNS of a network adapter forced (Killer E2200 Gigabit Ethernet Controller)
I 2016.08.14 14:39:05 - DNS of a network adapter forced (TAP-Windows Adapter V9)
I 2016.08.14 14:39:05 - Flushing DNS
! 2016.08.14 14:39:05 - Connected.
. 2016.08.14 14:39:05 - OpenVPN > MANAGEMENT: Client connected from [AF_INET]127.0.0.1:3100
. 2016.08.14 14:39:05 - OpenVPN > MANAGEMENT: CMD 'signal SIGTERM'
. 2016.08.14 14:39:05 - OpenVPN > MANAGEMENT: Client disconnected
. 2016.08.14 14:39:05 - OpenVPN > Assertion failed at misc.c:779
. 2016.08.14 14:39:05 - OpenVPN > Exiting due to fatal error
! 2016.08.14 14:39:05 - Disconnecting
. 2016.08.14 14:39:05 - Management - Send 'signal SIGTERM'
. 2016.08.14 14:39:05 - OpenVpn Management > >INFO:OpenVPN Management Interface Version 1 -- type 'help' for more info
. 2016.08.14 14:39:05 - OpenVPN > SIGTERM received, sending exit notification to peer
. 2016.08.14 14:39:10 - OpenVPN > C:\WINDOWS\system32\route.exe DELETE 46.165.208.69 MASK 255.255.255.255 192.168.178.1
. 2016.08.14 14:39:10 - OpenVPN > Route deletion via IPAPI succeeded [adaptive]
. 2016.08.14 14:39:10 - OpenVPN > C:\WINDOWS\system32\route.exe DELETE 192.168.178.1 MASK 255.255.255.255 192.168.178.1
. 2016.08.14 14:39:10 - OpenVPN > C:\WINDOWS\system32\route.exe DELETE 0.0.0.0 MASK 128.0.0.0 10.4.0.1
. 2016.08.14 14:39:10 - OpenVPN > C:\WINDOWS\system32\route.exe DELETE 128.0.0.0 MASK 128.0.0.0 10.4.0.1
. 2016.08.14 14:39:10 - OpenVPN > Closing TUN/TAP interface
. 2016.08.14 14:39:10 - OpenVPN > SIGTERM[soft,exit-with-notification] received, process exiting
. 2016.08.14 14:39:10 - Connection terminated.
I 2016.08.14 14:39:10 - DNS of a network adapter restored to original settings (Killer E2200 Gigabit Ethernet Controller)
I 2016.08.14 14:39:10 - DNS of a network adapter restored to original settings (TAP-Windows Adapter V9)
I 2016.08.14 14:39:13 - Checking authorization ...
! 2016.08.14 14:39:13 - Connecting to Velorum (Germany, Frankfurt)
. 2016.08.14 14:39:13 - OpenVPN > OpenVPN 2.3.8 x86_64-w64-mingw32 [sSL (OpenSSL)] [LZO] [iPv6] built on Aug 13 2015
. 2016.08.14 14:39:13 - OpenVPN > library versions: OpenSSL 1.0.2d 9 Jul 2015, LZO 2.08
. 2016.08.14 14:39:13 - OpenVPN > MANAGEMENT: TCP Socket listening on [AF_INET]127.0.0.1:3100
. 2016.08.14 14:39:13 - OpenVPN > Control Channel Authentication: tls-auth using INLINE static key file
. 2016.08.14 14:39:13 - OpenVPN > Outgoing Control Channel Authentication: Using 160 bit message hash 'SHA1' for HMAC authentication
. 2016.08.14 14:39:13 - OpenVPN > Incoming Control Channel Authentication: Using 160 bit message hash 'SHA1' for HMAC authentication
. 2016.08.14 14:39:13 - OpenVPN > Socket Buffers: R=[65536->131072] S=[65536->131072]
. 2016.08.14 14:39:13 - OpenVPN > UDPv4 link local: [undef]
. 2016.08.14 14:39:13 - OpenVPN > UDPv4 link remote: [AF_INET]46.165.208.69:443
. 2016.08.14 14:39:13 - OpenVPN > TLS: Initial packet from [AF_INET]46.165.208.69:443, sid=4968314e 3d41d362
. 2016.08.14 14:39:13 - OpenVPN > VERIFY OK: depth=1, C=IT, ST=IT, L=Perugia, O=airvpn.org, CN=airvpn.org CA, emailAddress=info@airvpn.org
. 2016.08.14 14:39:13 - OpenVPN > Validating certificate key usage
. 2016.08.14 14:39:13 - OpenVPN > ++ Certificate has key usage 00a0, expects 00a0
. 2016.08.14 14:39:13 - OpenVPN > VERIFY KU OK
. 2016.08.14 14:39:13 - OpenVPN > Validating certificate extended key usage
. 2016.08.14 14:39:13 - OpenVPN > ++ Certificate has EKU (str) TLS Web Server Authentication, expects TLS Web Server Authentication
. 2016.08.14 14:39:13 - OpenVPN > VERIFY EKU OK
. 2016.08.14 14:39:13 - OpenVPN > VERIFY OK: depth=0, C=IT, ST=IT, L=Perugia, O=airvpn.org, CN=server, emailAddress=info@airvpn.org
. 2016.08.14 14:39:14 - OpenVPN > Data Channel Encrypt: Cipher 'AES-256-CBC' initialized with 256 bit key
. 2016.08.14 14:39:14 - OpenVPN > Data Channel Encrypt: Using 160 bit message hash 'SHA1' for HMAC authentication
. 2016.08.14 14:39:14 - OpenVPN > Data Channel Decrypt: Cipher 'AES-256-CBC' initialized with 256 bit key
. 2016.08.14 14:39:14 - OpenVPN > Data Channel Decrypt: Using 160 bit message hash 'SHA1' for HMAC authentication
. 2016.08.14 14:39:14 - OpenVPN > Control Channel: TLSv1.2, cipher TLSv1/SSLv3 DHE-RSA-AES256-GCM-SHA384, 4096 bit RSA
. 2016.08.14 14:39:14 - OpenVPN > [server] Peer Connection Initiated with [AF_INET]46.165.208.69:443
. 2016.08.14 14:39:16 - OpenVPN > SENT CONTROL [server]: 'PUSH_REQUEST' (status=1)
. 2016.08.14 14:39:16 - OpenVPN > PUSH: Received control message: 'PUSH_REPLY,redirect-gateway def1 bypass-dhcp,dhcp-option DNS 10.4.0.1,comp-lzo no,route-gateway 10.4.0.1,topology subnet,ping 10,ping-restart 60,ifconfig 10.4.21.208 255.255.0.0'
. 2016.08.14 14:39:16 - OpenVPN > OPTIONS IMPORT: timers and/or timeouts modified
. 2016.08.14 14:39:16 - OpenVPN > OPTIONS IMPORT: LZO parms modified
. 2016.08.14 14:39:16 - OpenVPN > OPTIONS IMPORT: --ifconfig/up options modified
. 2016.08.14 14:39:16 - OpenVPN > OPTIONS IMPORT: route options modified
. 2016.08.14 14:39:16 - OpenVPN > OPTIONS IMPORT: route-related options modified
. 2016.08.14 14:39:16 - OpenVPN > OPTIONS IMPORT: --ip-win32 and/or --dhcp-option options modified
. 2016.08.14 14:39:16 - OpenVPN > do_ifconfig, tt->ipv6=0, tt->did_ifconfig_ipv6_setup=0
. 2016.08.14 14:39:16 - OpenVPN > open_tun, tt->ipv6=0
. 2016.08.14 14:39:16 - OpenVPN > TAP-WIN32 device [Ethernet 2] opened: \\.\Global\{5342D826-9FD5-4B3E-A915-554A736E2963}.tap
. 2016.08.14 14:39:16 - OpenVPN > TAP-Windows Driver Version 9.21
. 2016.08.14 14:39:16 - OpenVPN > Set TAP-Windows TUN subnet mode network/local/netmask = 10.4.0.0/10.4.21.208/255.255.0.0 [sUCCEEDED]
. 2016.08.14 14:39:16 - OpenVPN > Notified TAP-Windows driver to set a DHCP IP/netmask of 10.4.21.208/255.255.0.0 on interface {5342D826-9FD5-4B3E-A915-554A736E2963} [DHCP-serv: 10.4.255.254, lease-time: 31536000]
. 2016.08.14 14:39:16 - OpenVPN > Successful ARP Flush on interface [6] {5342D826-9FD5-4B3E-A915-554A736E2963}
. 2016.08.14 14:39:21 - OpenVPN > TEST ROUTES: 1/1 succeeded len=0 ret=1 a=0 u/d=up
. 2016.08.14 14:39:21 - OpenVPN > C:\WINDOWS\system32\route.exe ADD 46.165.208.69 MASK 255.255.255.255 192.168.178.1
. 2016.08.14 14:39:21 - OpenVPN > ROUTE: CreateIpForwardEntry succeeded with dwForwardMetric1=35 and dwForwardType=4
. 2016.08.14 14:39:21 - OpenVPN > Route addition via IPAPI succeeded [adaptive]
. 2016.08.14 14:39:21 - OpenVPN > C:\WINDOWS\system32\route.exe ADD 192.168.178.1 MASK 255.255.255.255 192.168.178.1 IF 4
. 2016.08.14 14:39:21 - OpenVPN > C:\WINDOWS\system32\route.exe ADD 0.0.0.0 MASK 128.0.0.0 10.4.0.1
. 2016.08.14 14:39:21 - OpenVPN > C:\WINDOWS\system32\route.exe ADD 128.0.0.0 MASK 128.0.0.0 10.4.0.1
. 2016.08.14 14:39:21 - Starting Management Interface
. 2016.08.14 14:39:21 - OpenVPN > Initialization Sequence Completed
I 2016.08.14 14:39:21 - DNS of a network adapter forced (Killer E2200 Gigabit Ethernet Controller)
I 2016.08.14 14:39:21 - DNS of a network adapter forced (TAP-Windows Adapter V9)
I 2016.08.14 14:39:21 - Flushing DNS
I 2016.08.14 14:39:21 - Checking route
I 2016.08.14 14:39:21 - Checking DNS
! 2016.08.14 14:39:33 - Connected.
. 2016.08.14 14:39:33 - OpenVPN > MANAGEMENT: Client connected from [AF_INET]127.0.0.1:3100
. 2016.08.14 14:39:33 - OpenVpn Management > >INFO:OpenVPN Management Interface Version 1 -- type 'help' for more info
Also thank you for the Eddi   it has so much useful information   that I never knew ,,  Because I never had problems in the Past
Also this is My system report if it is any useful
I was reading through it fast  and , Saw  things as IP falsch   or something like that
Network Interface: Ethernet (Killer E2200 Gigabit Ethernet Controller, ID:{2FD98B4D-584E-498F-AB71-675966D8B132}) - Ethernet - Up
Network Interface: Ethernet 2 (TAP-Windows Adapter V9, ID:{5342D826-9FD5-4B3E-A915-554A736E2963}) - Ethernet - Up
Network Interface: Loopback Pseudo-Interface 1 (Software Loopback Interface 1, ID:{BC5151B0-5B76-11E6-81ED-806E6F6E6963}) - Loopback - Up
Routing:
Address: 0.0.0.0, Mask: 0.0.0.0, Gateway: 192.168.178.1, Interface: 4, Metrics: 35, Flags: , Mss: , Window: , Irtt:
Address: 0.0.0.0, Mask: 128.0.0.0, Gateway: 10.4.0.1, Interface: 6, Metrics: 35, Flags: , Mss: , Window: , Irtt:
Address: 10.4.0.0, Mask: 255.255.0.0, Gateway: On-link, Interface: 6, Metrics: 291, Flags: , Mss: , Window: , Irtt:
Address: 10.4.21.208, Mask: 255.255.255.255, Gateway: On-link, Interface: 6, Metrics: 291, Flags: , Mss: , Window: , Irtt:
Address: 10.4.255.255, Mask: 255.255.255.255, Gateway: On-link, Interface: 6, Metrics: 291, Flags: , Mss: , Window: , Irtt:
Address: 46.165.208.69, Mask: 255.255.255.255, Gateway: 192.168.178.1, Interface: 4, Metrics: 35, Flags: , Mss: , Window: , Irtt:
Address: 127.0.0.0, Mask: 255.0.0.0, Gateway: On-link, Interface: 1, Metrics: 331, Flags: , Mss: , Window: , Irtt:
Address: 127.0.0.1, Mask: 255.255.255.255, Gateway: On-link, Interface: 1, Metrics: 331, Flags: , Mss: , Window: , Irtt:
Address: 127.255.255.255, Mask: 255.255.255.255, Gateway: On-link, Interface: 1, Metrics: 331, Flags: , Mss: , Window: , Irtt:
Address: 128.0.0.0, Mask: 128.0.0.0, Gateway: 10.4.0.1, Interface: 6, Metrics: 35, Flags: , Mss: , Window: , Irtt:
Address: 192.168.178.0, Mask: 255.255.255.0, Gateway: On-link, Interface: 4, Metrics: 291, Flags: , Mss: , Window: , Irtt:
Address: 192.168.178.1, Mask: 255.255.255.255, Gateway: 192.168.178.1, Interface: 4, Metrics: 35, Flags: , Mss: , Window: , Irtt:
Address: 192.168.178.54, Mask: 255.255.255.255, Gateway: On-link, Interface: 4, Metrics: 291, Flags: , Mss: , Window: , Irtt:
Address: 192.168.178.255, Mask: 255.255.255.255, Gateway: On-link, Interface: 4, Metrics: 291, Flags: , Mss: , Window: , Irtt:
Address: 213.152.162.88, Mask: 255.255.255.255, Gateway: 192.168.178.1, Interface: 4, Metrics: 35, Flags: , Mss: , Window: , Irtt:
Address: 224.0.0.0, Mask: 240.0.0.0, Gateway: On-link, Interface: 1, Metrics: 331, Flags: , Mss: , Window: , Irtt:
Address: 224.0.0.0, Mask: 240.0.0.0, Gateway: On-link, Interface: 6, Metrics: 291, Flags: , Mss: , Window: , Irtt:
Address: 224.0.0.0, Mask: 240.0.0.0, Gateway: On-link, Interface: 4, Metrics: 291, Flags: , Mss: , Window: , Irtt:
Address: 255.255.255.255, Mask: 255.255.255.255, Gateway: On-link, Interface: 1, Metrics: 331, Flags: , Mss: , Window: , Irtt:
Address: 255.255.255.255, Mask: 255.255.255.255, Gateway: On-link, Interface: 6, Metrics: 291, Flags: , Mss: , Window: , Irtt:
Address: 255.255.255.255, Mask: 255.255.255.255, Gateway: On-link, Interface: 4, Metrics: 291, Flags: , Mss: , Window: , Irtt:
Default gateways:
192.168.178.1, Killer E2200 Gigabit Ethernet Controller
-- Windows-Only informations
Network Adapter: [00000000] Microsoft Kernel Debug Network Adapter
DNS: null
Details:
ArpAlwaysSourceRoute: null
ArpUseEtherSNAP: null
Caption: [00000000] Microsoft Kernel Debug Network Adapter
DatabasePath: null
DeadGWDetectEnabled: null
DefaultIPGateway: null
DefaultTOS: null
DefaultTTL: null
Description: Microsoft Kernel Debug Network Adapter
DHCPEnabled: true
DHCPLeaseExpires: null
DHCPLeaseObtained: null
DHCPServer: null
DNSDomain: null
DNSDomainSuffixSearchOrder: null
DNSEnabledForWINSResolution: null
DNSHostName: null
DNSServerSearchOrder: null
DomainDNSRegistrationEnabled: null
ForwardBufferMemory: null
FullDNSRegistrationEnabled: null
GatewayCostMetric: null
IGMPLevel: null
Index: 0
InterfaceIndex: 7
IPAddress: null
IPConnectionMetric: null
IPEnabled: false
IPFilterSecurityEnabled: null
IPPortSecurityEnabled: null
IPSecPermitIPProtocols: null
IPSecPermitTCPPorts: null
IPSecPermitUDPPorts: null
IPSubnet: null
IPUseZeroBroadcast: null
IPXAddress: null
IPXEnabled: null
IPXFrameType: null
IPXMediaType: null
IPXNetworkNumber: null
IPXVirtualNetNumber: null
KeepAliveInterval: null
KeepAliveTime: null
MACAddress: null
MTU: null
NumForwardPackets: null
PMTUBHDetectEnabled: null
PMTUDiscoveryEnabled: null
ServiceName: kdnic
SettingID: {60A076CF-D3DF-479E-B6B2-89B2DB55596F}
TcpipNetbiosOptions: null
TcpMaxConnectRetransmissions: null
TcpMaxDataRetransmissions: null
TcpNumConnections: null
TcpUseRFC1122UrgentPointer: null
TcpWindowSize: null
WINSEnableLMHostsLookup: null
WINSHostLookupFile: null
WINSPrimaryServer: null
WINSScopeID: null
WINSSecondaryServer: null
Network Adapter: [00000001] Killer E2200 Gigabit Ethernet Controller
DNS: 10.4.0.1
Details:
Caption: [00000001] Killer E2200 Gigabit Ethernet Controller
DatabasePath: %SystemRoot%\System32\drivers\etc
DefaultIPGateway: 192.168.178.1
DefaultTOS: null
DefaultTTL: null
Description: Killer E2200 Gigabit Ethernet Controller
DHCPEnabled: true
DHCPLeaseExpires: 20160824143854.000000+120
DHCPLeaseObtained: 20160814143854.000000+120
DHCPServer: 192.168.178.1
DNSDomain: fritz.box
DNSDomainSuffixSearchOrder: fritz.box
DNSEnabledForWINSResolution: false
DNSHostName: KingWeimar
DNSServerSearchOrder: 10.4.0.1
DomainDNSRegistrationEnabled: false
FullDNSRegistrationEnabled: true
GatewayCostMetric: System.UInt16[]
IGMPLevel: null
Index: 1
InterfaceIndex: 4
IPAddress: 192.168.178.54,fe80::9950:1e9d:ae6:e8a3
IPConnectionMetric: 35
IPEnabled: true
IPFilterSecurityEnabled: false
IPSubnet: 255.255.255.0,64
IPXAddress: null
IPXEnabled: null
IPXFrameType: null
IPXMediaType: null
KeepAliveTime: null
MACAddress: D4:3D:7E:F7:C9:01
MTU: null
ServiceName: KillerEth
SettingID: {2FD98B4D-584E-498F-AB71-675966D8B132}
TcpipNetbiosOptions: 0
TcpWindowSize: null
WINSEnableLMHostsLookup: true
WINSScopeID:
Network Adapter: [00000002] WAN Miniport (SSTP)
DNS: null
Details:
Caption: [00000002] WAN Miniport (SSTP)
DatabasePath: null
DefaultTOS: null
DefaultTTL: null
Description: WAN Miniport (SSTP)
DHCPEnabled: false
DHCPServer: null
DNSDomain: null
DNSHostName: null
IGMPLevel: null
Index: 2
InterfaceIndex: 10
IPAddress: null
IPEnabled: false
IPSubnet: null
IPXAddress: null
IPXEnabled: null
IPXFrameType: null
IPXMediaType: null
KeepAliveTime: null
MACAddress: null
MTU: null
ServiceName: RasSstp
SettingID: {9789502E-CE90-4886-88E5-72D7FBA9C647}
TcpWindowSize: null
WINSScopeID: null
Network Adapter: [00000003] Microsoft ISATAP Adapter
DNS: null
Details:
Caption: [00000003] Microsoft ISATAP Adapter
DatabasePath: null
DefaultTOS: null
DefaultTTL: null
Description: Microsoft ISATAP Adapter
DHCPEnabled: false
DHCPServer: null
DNSDomain: null
DNSHostName: null
IGMPLevel: null
Index: 3
InterfaceIndex: 12
IPAddress: null
IPEnabled: false
IPSubnet: null
IPXAddress: null
IPXEnabled: null
IPXFrameType: null
IPXMediaType: null
KeepAliveTime: null
MACAddress: null
MTU: null
ServiceName: tunnel
SettingID: {BE229F2C-1372-4931-90FE-56192CC8E6B0}
TcpWindowSize: null
WINSScopeID: null
Network Adapter: [00000004] Microsoft Teredo Tunneling Adapter
DNS: null
Details:
Caption: [00000004] Microsoft Teredo Tunneling Adapter
DatabasePath: null
DefaultTOS: null
DefaultTTL: null
Description: Microsoft Teredo Tunneling Adapter
DHCPEnabled: false
DHCPServer: null
DNSDomain: null
DNSHostName: null
IGMPLevel: null
Index: 4
InterfaceIndex: 13
IPAddress: null
IPEnabled: false
IPSubnet: null
IPXAddress: null
IPXEnabled: null
IPXFrameType: null
IPXMediaType: null
KeepAliveTime: null
MACAddress: null
MTU: null
ServiceName: tunnel
SettingID: {D5D414C3-97AD-4EF0-B3C2-9BA25367CFE1}
TcpWindowSize: null
WINSScopeID: null
Network Adapter: [00000005] TAP-Windows Adapter V9
DNS: 10.4.0.1
Details:
Caption: [00000005] TAP-Windows Adapter V9
DefaultTOS: null
DefaultTTL: null
Description: TAP-Windows Adapter V9
DHCPEnabled: true
DHCPLeaseExpires: 20170814143921.000000+120
DHCPLeaseObtained: 20160814143921.000000+120
DHCPServer: 10.4.255.254
DNSDomain: null
IGMPLevel: null
Index: 5
InterfaceIndex: 6
IPAddress: 10.4.21.208,fe80::5098:bc7b:32b9:d96c
IPEnabled: true
IPSubnet: 255.255.0.0,64
IPXAddress: null
IPXEnabled: null
IPXFrameType: null
IPXMediaType: null
KeepAliveTime: null
MACAddress: 00:FF:53:42:D8:26
MTU: null
ServiceName: tap0901
SettingID: {5342D826-9FD5-4B3E-A915-554A736E2963}
TcpWindowSize: null
WINSScopeID:
Network Adapter: [00000006] WAN Miniport (IKEv2)
DNS: null
Details:
Caption: [00000006] WAN Miniport (IKEv2)
DatabasePath: null
DefaultTOS: null
DefaultTTL: null
Description: WAN Miniport (IKEv2)
DHCPEnabled: false
DHCPServer: null
DNSDomain: null
DNSHostName: null
IGMPLevel: null
Index: 6
InterfaceIndex: 5
IPAddress: null
IPEnabled: false
IPSubnet: null
IPXAddress: null
IPXEnabled: null
IPXFrameType: null
IPXMediaType: null
KeepAliveTime: null
MACAddress: null
MTU: null
ServiceName: RasAgileVpn
SettingID: {3FF728D1-91CF-4ABF-8CBF-040DE2B1CA2A}
TcpWindowSize: null
WINSScopeID: null
Network Adapter: [00000007] WAN Miniport (L2TP)
DNS: null
Details:
Caption: [00000007] WAN Miniport (L2TP)
DatabasePath: null
DefaultTOS: null
DefaultTTL: null
Description: WAN Miniport (L2TP)
DHCPEnabled: false
DHCPServer: null
DNSDomain: null
DNSHostName: null
IGMPLevel: null
Index: 7
InterfaceIndex: 3
IPAddress: null
IPEnabled: false
IPSubnet: null
IPXAddress: null
IPXEnabled: null
IPXFrameType: null
IPXMediaType: null
KeepAliveTime: null
MACAddress: null
MTU: null
ServiceName: Rasl2tp
SettingID: {1C554A31-8475-42ED-808D-21C0BD08E7E6}
TcpWindowSize: null
WINSScopeID: null
Network Adapter: [00000008] WAN Miniport (PPTP)
DNS: null
Details:
Caption: [00000008] WAN Miniport (PPTP)
DatabasePath: null
DefaultTOS: null
DefaultTTL: null
Description: WAN Miniport (PPTP)
DHCPEnabled: false
DHCPServer: null
DNSDomain: null
DNSHostName: null
IGMPLevel: null
Index: 8
InterfaceIndex: 11
IPAddress: null
IPEnabled: false
IPSubnet: null
IPXAddress: null
IPXEnabled: null
IPXFrameType: null
IPXMediaType: null
KeepAliveTime: null
MACAddress: null
MTU: null
ServiceName: PptpMiniport
SettingID: {A901DD40-FE87-4FB0-B957-1A00DB337D9F}
TcpWindowSize: null
WINSScopeID: null
Network Adapter: [00000009] WAN Miniport (PPPOE)
DNS: null
Details:
Caption: [00000009] WAN Miniport (PPPOE)
DatabasePath: null
DefaultTOS: null
DefaultTTL: null
Description: WAN Miniport (PPPOE)
DHCPEnabled: false
DHCPServer: null
DNSDomain: null
DNSHostName: null
IGMPLevel: null
Index: 9
InterfaceIndex: 14
IPAddress: null
IPEnabled: false
IPSubnet: null
IPXAddress: null
IPXEnabled: null
IPXFrameType: null
IPXMediaType: null
KeepAliveTime: null
MACAddress: null
MTU: null
ServiceName: RasPppoe
SettingID: {D9765D11-C3E0-4C68-BB35-AFF6B742FCB1}
TcpWindowSize: null
WINSScopeID: null
Network Adapter: [00000010] WAN Miniport (IP)
DNS: null
Details:
Caption: [00000010] WAN Miniport (IP)
DatabasePath: null
DefaultTOS: null
DefaultTTL: null
Description: WAN Miniport (IP)
DHCPEnabled: false
DHCPServer: null
DNSDomain: null
DNSHostName: null
IGMPLevel: null
Index: 10
InterfaceIndex: 8
IPAddress: null
IPEnabled: false
IPSubnet: null
IPXAddress: null
IPXEnabled: null
IPXFrameType: null
IPXMediaType: null
KeepAliveTime: null
MACAddress: null
MTU: null
ServiceName: NdisWan
SettingID: {8031CEAD-2330-443B-AEBA-F7E843C4B7E8}
TcpWindowSize: null
WINSScopeID: null
Network Adapter: [00000011] WAN Miniport (IPv6)
DNS: null
Details:
Caption: [00000011] WAN Miniport (IPv6)
DatabasePath: null
DefaultTOS: null
DefaultTTL: null
Description: WAN Miniport (IPv6)
DHCPEnabled: false
DHCPServer: null
DNSDomain: null
DNSHostName: null
IGMPLevel: null
Index: 11
InterfaceIndex: 9
IPAddress: null
IPEnabled: false
IPSubnet: null
IPXAddress: null
IPXEnabled: null
IPXFrameType: null
IPXMediaType: null
KeepAliveTime: null
MACAddress: null
MTU: null
SettingID: {928CB700-75F2-41F2-8224-544D74450B5C}
TcpWindowSize: null
WINSScopeID: null
Network Adapter: [00000012] WAN Miniport (Network Monitor)
DNS: null
Details:
Caption: [00000012] WAN Miniport (Network Monitor)
DatabasePath: null
DefaultTOS: null
DefaultTTL: null
Description: WAN Miniport (Network Monitor)
DHCPEnabled: false
DHCPServer: null
DNSDomain: null
DNSHostName: null
IGMPLevel: null
Index: 12
InterfaceIndex: 2
IPAddress: null
IPEnabled: false
IPSubnet: null
IPXAddress: null
IPXEnabled: null
IPXFrameType: null
IPXMediaType: null
KeepAliveTime: null
MACAddress: null
MTU: null
SettingID: {0C9AA2D3-E3C3-44C4-95B4-45D74E643F34}
TcpWindowSize: null
WINSScopeID: null
thank you
To reply quickly, I recommend you check out my guide, in my signature. Otherwise found in the how to forum. It'll be more detailed than I can be here, at the moment. Includes troubleshooting steps .
Your Guide   Has helped me alot
Many thanks
