uldch 0 Posted ... Hello guys, for me the win firewall deactivation problem after disabling network lock is still alive and it sucks hard.As far as i know there is no suitable workaround from staff so far.Anyone else is still having that problem? 1. Win Firewall on2. Start Eddie3. Activate Network Lock4. Connect to Server5. Close Eddie / Disconnect and disable NL6. Win Firewall is not restored and is deactivated Quote Share this post Link to post
LZ1 678 Posted ... Hello! Are you using the latest stable version of Eddie? If so, perhaps you should check out the beta version . Sent to you from me with datalove Quote Hide LZ1's signature Hide all signatures Hi there, are you new to AirVPN? Many of your questions are already answered in this guide. You may also read the Eddie Android FAQ. Moderators do not speak on behalf of AirVPN. Only the Official Staff account does. Please also do not run Tor Exit Servers behind AirVPN, thank you. Did you make a guide or how-to for something? Then contact me to get it listed in my new user guide's Guides Section, so that the community can find it more easily. Share this post Link to post
Staff 10433 Posted ... A very rare Windows bug since it has never been reproduced in our machines. Reported anyway by another user who solved it with system re-installation (not very useful...), probably a broken update consequence. Hopefully solved by new Windows Filtering Platform used in the Eddie 2.11.x versions. Kind regards 1 foxmulder reacted to this Quote Share this post Link to post
foxmulder 43 Posted ... I also suffered from this bug on my WIN 7 Laptop. How I finally solved it ? I switched to Linux! Regards Fox Quote Share this post Link to post
uldch 0 Posted ... I switched to Linux!thats probably the best solution, but i need at least one copy of windows for specific tasks Are you using the latest stable version of Eddie? If so, perhaps you should check out the beta version Yes i use the latest stable version, but i cannot find the Beta Version, maybe you can give me a hint A very rare Windows bugI would assume that only a minority of users report this bug in the forums Quote Share this post Link to post
Staff 10433 Posted ... I would assume that only a minority of users report this bug in the forums Yes, even in tickets, and above all we have never been able to reproduce it. Kind regards Quote Share this post Link to post
LZ1 678 Posted ... Simply go to the place you first downloaded the client and look for something mentioning "Other version" or something to that effect. Then download the experimental version Sent to you from me with datalove Quote Hide LZ1's signature Hide all signatures Hi there, are you new to AirVPN? Many of your questions are already answered in this guide. You may also read the Eddie Android FAQ. Moderators do not speak on behalf of AirVPN. Only the Official Staff account does. Please also do not run Tor Exit Servers behind AirVPN, thank you. Did you make a guide or how-to for something? Then contact me to get it listed in my new user guide's Guides Section, so that the community can find it more easily. Share this post Link to post
