Firas22
Should My IP4 Address be Visible ?
Firefox and Chrome have the WebRTC function.  WebRTC leaks your ISP IP address thru your browser.
FireFox and Chrome both have add-ons/extensions that block this function.
On firefox you can just go to “about:config” and set “media.peerconnection.enabled” to false
Please note that in the screenshot your public IPv4 address does not appear anywhere. You are talking about the local IP address of your machine inside your local network. Nothing wrong or worrying therefore.
So how to hid it ?  or what should i do use an other web browser ??  I am Currently using Vivaldi
I looked at the chrome they have 2 and both are fo to try out
I am already paying here   I dont want to pay for a stupid extension
any other suggestion ?
Your the best  ,
Kloppix
             It worked
But this is a Little sad Because I use vivaldi as my main browser
maybe I have to switch now
excellent, you solved it by yourself. Anyway you can just not bother about your local IP address sent out by WebRTC etc., it's not significant. The real leaks from any process binding to the physical network interface are prevented by Network Lock.
Hello !
Seems a bit odd to use such a new browser as your main, but ok. You could use whatever browser you want, in a VM. I don't know why you assumed the browser extensions were paid either.
Your the best  ,
Kloppix
             It worked
I use vivaldi myself, it is based on chromium but rather good, in the Vivaldi settings under Privacy it has an option to disable WebRTC
Your the best  ,
Kloppix
             It worked
Thank you again  I dont know what webRTC    until now  therefor I  never saw this option
[post=http://pasteboard.co/8yk4OmWls.png][/post]
thank you so much
