soupy 7 Posted ... Hey everyone I noticed in the logs I keep getting this error . 2016.08.09 01:12:07 - OpenVPN > Authenticate/Decrypt packet error: bad packet ID (may be a replay): [ #1544386 ] -- see the man page entry for --no-replay and --replay-window for more info or silence this warning with --mute-replay-warnings Seems a lot more disconnects recently too. windows 10, newest tap driver. Quote Share this post Link to post
LZ1 680 Posted ... Hello! Which version of Eddie are you using? If you're using it. Perhaps you should try the latest experimental version. It would also be best with full logs. Sent to you from me with datalove Quote Hide LZ1's signature Hide all signatures Hi there, are you new to AirVPN? Many of your questions are already answered in this guide. You may also read the Eddie Android FAQ. Moderators do not speak on behalf of AirVPN. Only the Official Staff account does. Please also do not run Tor Exit Servers behind AirVPN, thank you. Did you make a guide or how-to for something? Then contact me to get it listed in my new user guide's Guides Section, so that the community can find it more easily. Share this post Link to post
nick75 25 Posted ... . 2016.08.09 01:12:07 - OpenVPN > Authenticate/Decrypt packet error: bad packet ID (may be a replay): [ #1544386 ] -- see the man page entry for --no-replay and --replay-window for more info or silence this warning with --mute-replay-warningsHi! If you see this while using a torrent client then it's "normal". I get a lot of them when my download speed is over 2 MB/s but not while uploading. Quote Share this post Link to post
foxmulder 43 Posted ... Those errors occur very often, especially when torrenting at high speeds. You can try adapting your MTU with the "mssfix" directive in the Eddie client, according to this guide: https://www.sonassi.com/help/magestack/setting-correct-mtu-for-openvpn If that doesn't help, try using a different server closer to your location. And if that also fails, switching to TCP instead of UDP can be a last resort. Or you just might switch off those annoying messages by using the "mute-replay-warnings" directive. Regards Fox Quote Share this post Link to post
