the_source
DD-WRT running at 1/10th speed with openvpn
Hi all, I just got my AirVPN service and decided to dive in without doing a trial which im slightly regretting but hope this is a resolvable config issue.
Im in CT using Comcast 105Mbps service. I can normally get 85-100Mbps from a local speedtest.net check and torrents can sometimes saturate that as well.
In testing with PA and NJ VPN servers, regardless of what port/protocal I try I am consistently getting < 10Mbps from a speedtest.net and downloading test files over HTTP seem to get the same slow speeds.
My DD-WRT config:
The log from last connect attempt (the connection to VPN always works):
Clientlog:
20160807 22:58:52 I OpenVPN 2.3.11 mipsel-unknown-linux-gnu [SSL (OpenSSL)] [LZO] [EPOLL] [MH] [IPv6] built on Aug 4 2016
20160807 22:58:52 I library versions: OpenSSL 1.0.2h 3 May 2016 LZO 2.09
20160807 22:58:52 MANAGEMENT: TCP Socket listening on [AF_INET]127.0.0.1:16
20160807 22:58:52 W NOTE: the current --script-security setting may allow this configuration to call user-defined scripts
20160807 22:58:52 W WARNING: file '/tmp/openvpncl/client.key' is group or others accessible
20160807 22:58:52 W WARNING: file '/tmp/openvpncl/ta.key' is group or others accessible
20160807 22:58:52 I Control Channel Authentication: using '/tmp/openvpncl/ta.key' as a OpenVPN static key file
20160807 22:58:52 Outgoing Control Channel Authentication: Using 160 bit message hash 'SHA1' for HMAC authentication
20160807 22:58:52 Incoming Control Channel Authentication: Using 160 bit message hash 'SHA1' for HMAC authentication
20160807 22:58:52 Socket Buffers: R=[87380->87380] S=[16384->16384]
20160807 22:58:52 I Attempting to establish TCP connection with [AF_INET]104.243.24.235:2018 [nonblock]
20160807 22:58:53 I TCP connection established with [AF_INET]104.243.24.235:2018
20160807 22:58:53 I TCPv4_CLIENT link local: [undef]
20160807 22:58:53 I TCPv4_CLIENT link remote: [AF_INET]104.243.24.235:2018
20160807 22:58:53 TLS: Initial packet from [AF_INET]104.243.24.235:2018 sid=6da32614 10c0c0da
20160807 22:58:53 VERIFY OK: depth=1 C=IT ST=IT L=Perugia O=airvpn.org CN=airvpn.org CA emailAddress=info@airvpn.org
20160807 22:58:53 VERIFY OK: nsCertType=SERVER
20160807 22:58:53 NOTE: --mute triggered...
20160807 22:59:06 1 variation(s) on previous 3 message(s) suppressed by --mute
20160807 22:59:06 MANAGEMENT: Client connected from [AF_INET]127.0.0.1:16
20160807 22:59:06 D MANAGEMENT: CMD 'state'
20160807 22:59:06 MANAGEMENT: Client disconnected
20160807 22:59:06 D MANAGEMENT: CMD 'status 2'
20160807 22:59:06 D MANAGEMENT: CMD 'log 500'
20160807 22:59:06 Data Channel Encrypt: Cipher 'AES-256-CBC' initialized with 256 bit key
20160807 22:59:06 Data Channel Encrypt: Using 160 bit message hash 'SHA1' for HMAC authentication
20160807 22:59:06 Data Channel Decrypt: Cipher 'AES-256-CBC' initialized with 256 bit key
20160807 22:59:06 NOTE: --mute triggered...
20160807 22:59:06 2 variation(s) on previous 3 message(s) suppressed by --mute
20160807 22:59:06 I [server] Peer Connection Initiated with [AF_INET]104.243.24.235:2018
20160807 22:59:08 SENT CONTROL [server]: 'PUSH_REQUEST' (status=1)
20160807 22:59:09 PUSH: Received control message: 'PUSH_REPLY redirect-gateway def1 bypass-dhcp dhcp-option DNS 10.50.0.1 comp-lzo no route-gateway 10.50.0.1 topology subnet ping 10 ping-restart 60 ifconfig 10.50.4.185 255.255.0.0'
20160807 22:59:09 OPTIONS IMPORT: timers and/or timeouts modified
20160807 22:59:09 NOTE: --mute triggered...
20160807 22:59:09 5 variation(s) on previous 3 message(s) suppressed by --mute
20160807 22:59:09 I TUN/TAP device tun1 opened
20160807 22:59:09 TUN/TAP TX queue length set to 100
20160807 22:59:09 I do_ifconfig tt->ipv6=1 tt->did_ifconfig_ipv6_setup=0
20160807 22:59:09 I /sbin/ifconfig tun1 10.50.4.185 netmask 255.255.0.0 mtu 1500 broadcast 10.50.255.255
20160807 22:59:09 /sbin/route add -net 104.243.24.235 netmask 255.255.255.255 gw 71.235.104.1
20160807 22:59:09 /sbin/route add -net 0.0.0.0 netmask 128.0.0.0 gw 10.50.0.1
20160807 22:59:09 /sbin/route add -net 128.0.0.0 netmask 128.0.0.0 gw 10.50.0.1
20160807 22:59:09 I Initialization Sequence Completed
20160807 22:59:10 MANAGEMENT: Client connected from [AF_INET]127.0.0.1:16
20160807 22:59:10 D MANAGEMENT: CMD 'state'
20160807 22:59:10 MANAGEMENT: Client disconnected
20160807 22:59:10 D MANAGEMENT: CMD 'status 2'
20160807 22:59:11 MANAGEMENT: Client connected from [AF_INET]127.0.0.1:16
20160807 22:59:11 D MANAGEMENT: CMD 'log 500'
20160807 22:59:11 MANAGEMENT: Client disconnected
20160807 22:59:20 MANAGEMENT: Client connected from [AF_INET]127.0.0.1:16
20160807 22:59:20 D MANAGEMENT: CMD 'state'
20160807 22:59:20 MANAGEMENT: Client disconnected
20160807 22:59:20 D MANAGEMENT: CMD 'status 2'
20160807 22:59:20 D MANAGEMENT: CMD 'log 500'
20160807 23:00:18 MANAGEMENT: Client connected from [AF_INET]127.0.0.1:16
20160807 23:00:18 D MANAGEMENT: CMD 'state'
20160807 23:00:18 MANAGEMENT: Client disconnected
20160807 23:00:18 D MANAGEMENT: CMD 'status 2'
20160807 23:00:18 D MANAGEMENT: CMD 'log 500'
19691231 19:00:00
ca /tmp/openvpncl/ca.crt cert /tmp/openvpncl/client.crt key /tmp/openvpncl/client.key management 127.0.0.1 16 management-log-cache 100 verb 3 mute 3 syslog writepid /var/run/openvpncl.pid client resolv-retry infinite nobind persist-key persist-tun script-security 2 dev tun1 proto tcp-client cipher aes-256-cbc auth sha1 remote 104.243.24.235 2018 comp-lzo yes tun-mtu 1500 mtu-disc yes ns-cert-type server tun-ipv6 tls-auth /tmp/openvpncl/ta.key 1
Image/log may show different protocol/port but the logs didnt show anything much different each attempt.
Im not sure what to try to identify where the issue is.
Hi
I use a new ASUS RT-AC88U with the last version of Merlin , and I have at home an adsl 50.000 , with this router I get the max power of my internet ...
if someone is looking for a new router this one is the best model (ASUS RT-AC88U)
ciao
What is the router model?
Adjusting the socket buffers to 256KB might help, but don't expect anything beyond 30Mbit from any "home" router.
Its a Netgear R6300.
