I'm having some problems with the interface in Debian. I switched over from xfce to Gnome and now I cannot get Eddie to connect to a server. It connects and then disconnects immediately after. I think it might be a problem with the network lock, though when I disable it I get the same problem. I've tried “apt-get remove airvpn” and then reinstalling but I get the same problem. Any solutions, or any idea how I do a full removal of airvpn for a reinstall? For example, do I include the word “purge” after “apt-get remove airvpn?” When I do a normal reinstall it remembers all of the log in information. Any idea how I completely uninstall airvpn?
Best,
Rabbit
Do you have any logs that you could make available, from the Air client? It should also remove itself entirely when asked.
