drummer45
Stuck at Checking Route...Again!
The problem persists with the Dutch servers I tested and after client restart (I did neither reboot the system nor I delete the .airvpn folder).
The problem always happens after 4 to 5 minutes of successful connection:
. 2016.08.02 15:49:58 - OpenVPN > [server] Inactivity timeout (--ping-restart), restarting
. 2016.08.02 15:49:58 - OpenVPN > SIGUSR1[soft,ping-restart] received, process restarting
. 2016.08.02 15:49:58 - OpenVPN > Restart pause, 2 second(s)
! 2016.08.02 15:49:58 - Disconnecting
. 2016.08.02 15:49:58 - Management - Send 'signal SIGTERM'
. 2016.08.02 15:49:58 - OpenVPN > MANAGEMENT: CMD 'signal SIGTERM'
. 2016.08.02 15:49:58 - OpenVPN > MANAGEMENT: Client disconnected
. 2016.08.02 15:49:58 - OpenVPN > Assertion failed at misc.c:785
. 2016.08.02 15:49:58 - OpenVPN > Exiting due to fatal error
. 2016.08.02 15:49:58 - Connection terminated.
Different problem then. This thread will not help you, feel free to open a ticket at your convenience.
Original thread issue has been solved by tech support for me. OSX Mavericks. Version 2.10.3  Eddie client. Original default settings. No tweaks or work-arounds. Works as before. I hope their fix works for all others as well.
Works on Debian as well. Thank you for the fix.
I 2016.08.02 10:12:39 - Eddie client version: 2.11.3 / x86, System: Linux, Name: Debian GNU/Linux 7 \n \l / x86
. 2016.08.02 10:12:39 - Reading options from /home/user1/.airvpn/AirVPN.xml
. 2016.08.02 10:12:39 - Data Path: /home/user1/.airvpn
. 2016.08.02 10:12:39 - App Path: /usr/lib/AirVPN
. 2016.08.02 10:12:39 - Executable Path: /usr/lib/AirVPN/AirVPN.exe
. 2016.08.02 10:12:39 - Command line arguments (1): path="/home/user1/.airvpn"
. 2016.08.02 10:12:39 - Operating System: Unix 3.2.0.4 - Linux debian1 3.2.0-4-686-pae #1 SMP Debian 3.2.81-1 i686 GNU/Linux
I 2016.08.02 10:12:40 - OpenVPN Driver - Found, /dev/net/tun
I 2016.08.02 10:12:40 - OpenVPN - Version: OpenVPN 2.2.1 (/usr/sbin/openvpn)
I 2016.08.02 10:12:40 - SSH - Version: OpenSSH_6.0p1 Debian-4+deb7u5, OpenSSL 1.0.1e 11 Feb 2013 (/usr/bin/ssh)
I 2016.08.02 10:12:40 - SSL - Version: stunnel 4.53 (/usr/bin/stunnel4)
! 2016.08.02 10:12:40 - Ready
. 2016.08.02 10:12:40 - Updating systems & servers data ...
! 2016.08.02 10:12:42 - Activation of Network Lock - Linux IPTables
. 2016.08.02 10:12:44 - Systems & servers data update completed
I 2016.08.02 10:12:51 - Session starting.
I 2016.08.02 10:12:51 - Checking authorization ...
! 2016.08.02 10:12:52 - Connecting to Sabik (United States, Los Angeles)
. 2016.08.02 10:12:52 - OpenVPN > OpenVPN 2.2.1 i486-linux-gnu [SSL] [LZO2] [EPOLL] [PKCS11] [eurephia] [MH] [PF_INET6] [IPv6 payload 20110424-2 (2.2RC2)] built on Dec  1 2014
. 2016.08.02 10:12:52 - OpenVPN > RESOLVE: NOTE: localhost resolves to 2 addresses
. 2016.08.02 10:12:52 - OpenVPN > MANAGEMENT: TCP Socket listening on [AF_INET]127.0.0.1:3100
. 2016.08.02 10:12:52 - OpenVPN > NOTE: OpenVPN 2.1 requires '--script-security 2' or higher to call user-defined scripts or executables
. 2016.08.02 10:12:52 - OpenVPN > Control Channel Authentication: tls-auth using INLINE static key file
. 2016.08.02 10:12:52 - OpenVPN > Outgoing Control Channel Authentication: Using 160 bit message hash 'SHA1' for HMAC authentication
. 2016.08.02 10:12:52 - OpenVPN > Incoming Control Channel Authentication: Using 160 bit message hash 'SHA1' for HMAC authentication
. 2016.08.02 10:12:52 - OpenVPN > LZO compression initialized
. 2016.08.02 10:12:52 - OpenVPN > Control Channel MTU parms [ L:1558 D:166 EF:66 EB:0 ET:0 EL:0 ]
. 2016.08.02 10:12:52 - OpenVPN > Socket Buffers: R=[163840->131072] S=[163840->131072]
. 2016.08.02 10:12:52 - OpenVPN > Data Channel MTU parms [ L:1558 D:1450 EF:58 EB:135 ET:0 EL:0 AF:3/1 ]
. 2016.08.02 10:12:52 - OpenVPN > Local Options hash (VER=V4): '9e7066d2'
. 2016.08.02 10:12:52 - OpenVPN > Expected Remote Options hash (VER=V4): '162b04de'
. 2016.08.02 10:12:52 - OpenVPN > UDPv4 link local: [undef]
. 2016.08.02 10:12:52 - OpenVPN > UDPv4 link remote: [AF_INET]199.241.147.34:443
. 2016.08.02 10:12:52 - OpenVPN > TLS: Initial packet from [AF_INET]199.241.147.34:443, sid=ad51bd5e e8237dd5
. 2016.08.02 10:12:52 - OpenVPN > VERIFY OK: depth=1, /C=IT/ST=IT/L=Perugia/O=airvpn.org/CN=airvpn.org_CA/emailAddress=info@airvpn.org
. 2016.08.02 10:12:52 - OpenVPN > Validating certificate key usage
. 2016.08.02 10:12:52 - OpenVPN > ++ Certificate has key usage  00a0, expects 00a0
. 2016.08.02 10:12:52 - OpenVPN > VERIFY KU OK
. 2016.08.02 10:12:52 - OpenVPN > Validating certificate extended key usage
. 2016.08.02 10:12:52 - OpenVPN > ++ Certificate has EKU (str) TLS Web Server Authentication, expects TLS Web Server Authentication
. 2016.08.02 10:12:52 - OpenVPN > VERIFY EKU OK
. 2016.08.02 10:12:52 - OpenVPN > VERIFY OK: depth=0, /C=IT/ST=IT/L=Perugia/O=airvpn.org/CN=server/emailAddress=info@airvpn.org
. 2016.08.02 10:12:53 - OpenVPN > Data Channel Encrypt: Cipher 'AES-256-CBC' initialized with 256 bit key
. 2016.08.02 10:12:53 - OpenVPN > Data Channel Encrypt: Using 160 bit message hash 'SHA1' for HMAC authentication
. 2016.08.02 10:12:53 - OpenVPN > Data Channel Decrypt: Cipher 'AES-256-CBC' initialized with 256 bit key
. 2016.08.02 10:12:53 - OpenVPN > Data Channel Decrypt: Using 160 bit message hash 'SHA1' for HMAC authentication
. 2016.08.02 10:12:53 - OpenVPN > Control Channel: TLSv1, cipher TLSv1/SSLv3 DHE-RSA-AES256-SHA, 4096 bit RSA
. 2016.08.02 10:12:53 - OpenVPN > [server] Peer Connection Initiated with [AF_INET]199.241.147.34:443
. 2016.08.02 10:12:55 - OpenVPN > SENT CONTROL [server]: 'PUSH_REQUEST' (status=1)
. 2016.08.02 10:12:55 - OpenVPN > PUSH: Received control message: 'PUSH_REPLY,redirect-gateway def1 bypass-dhcp,dhcp-option DNS 10.4.0.1,comp-lzo no,route-gateway 10.4.0.1,topology subnet,ping 10,ping-restart 60,ifconfig 10.4.10.33 255.255.0.0'
. 2016.08.02 10:12:55 - OpenVPN > OPTIONS IMPORT: timers and/or timeouts modified
. 2016.08.02 10:12:55 - OpenVPN > OPTIONS IMPORT: LZO parms modified
. 2016.08.02 10:12:55 - OpenVPN > OPTIONS IMPORT: --ifconfig/up options modified
. 2016.08.02 10:12:55 - OpenVPN > OPTIONS IMPORT: route options modified
. 2016.08.02 10:12:55 - OpenVPN > OPTIONS IMPORT: route-related options modified
. 2016.08.02 10:12:56 - OpenVPN > OPTIONS IMPORT: --ip-win32 and/or --dhcp-option options modified
. 2016.08.02 10:12:56 - OpenVPN > ROUTE default_gateway=10.0.2.2
. 2016.08.02 10:12:56 - OpenVPN > TUN/TAP device tun0 opened
. 2016.08.02 10:12:56 - OpenVPN > TUN/TAP TX queue length set to 100
. 2016.08.02 10:12:56 - OpenVPN > do_ifconfig, tt->ipv6=0, tt->did_ifconfig_ipv6_setup=0
. 2016.08.02 10:12:56 - OpenVPN > /sbin/ifconfig tun0 10.4.10.33 netmask 255.255.0.0 mtu 1500 broadcast 10.4.255.255
. 2016.08.02 10:13:01 - OpenVPN > /sbin/route add -net 199.241.147.34 netmask 255.255.255.255 gw 10.0.2.2
. 2016.08.02 10:13:01 - OpenVPN > /sbin/route add -net 0.0.0.0 netmask 128.0.0.0 gw 10.4.0.1
. 2016.08.02 10:13:01 - OpenVPN > /sbin/route add -net 128.0.0.0 netmask 128.0.0.0 gw 10.4.0.1
. 2016.08.02 10:13:01 - Starting Management Interface
. 2016.08.02 10:13:01 - OpenVPN > Initialization Sequence Completed
I 2016.08.02 10:13:01 - /etc/resolv.conf renamed to /etc/resolv.conf.airvpn as backup
I 2016.08.02 10:13:01 - DNS of the system updated to VPN DNS (Rename method: /etc/resolv.conf generated)
I 2016.08.02 10:13:01 - Flushing DNS
I 2016.08.02 10:13:01 - Checking route
I 2016.08.02 10:13:02 - Checking DNS
! 2016.08.02 10:13:02 - Connected.
. 2016.08.02 10:13:02 - OpenVPN > MANAGEMENT: Client connected from [AF_INET]127.0.0.1:3100
. 2016.08.02 10:13:02 - OpenVpn Management > >INFO:OpenVPN Management Interface Version 1 -- type 'help' for more info
. 2016.08.02 10:22:46 - Updating systems & servers data ...
. 2016.08.02 10:22:47 - Systems & servers data update completed
OSX uses bonjour to discover hosts on the local LAN and the services they offer. Bonjour won't (to my knowledge) transit a VPN (it gets lost at the concentrator). My workaround has just been to use the FQDN to access fileservers, etc when connected via VPN
