pr1v
Help with chip cores
I am not too much into hardware and I need your help guys:
Is it faster a computer with 2 cores chips at 2.4 each one or 4 cores chips at 1.3 each one to run gnu/linux or liveusb gnu/linux?
Thank you very much!
there's no quick answer to that question.  processes that thread well and will use all cores efficiently may be faster on the 4 core CPU.  processes that don't thread well/are single threaded will be faster on the 2 core CPU which has faster clock cycle.  what will be the main tasks of this machine?
Mostly vpn, tor, browsing, listen music and watch videos.
if it'll be running openvpn then the CPU with the faster clock cycle is better.  openvpn does not run multi-threaded at this time.
Ok, thanks
if openvpn performance is a high priority then you may want to make sure the CPU has AES-NI and/or some other encryption/decryption acceleration.
