velli
Client suddenly not working anymore
Hi, I recently bought month subcription, and its been working great until yesterday, everytime I try and connect I get this
I 2016.07.20 19:33:55 - AirVPN client version: 2.10.3 / x86, System: OSX, Name: 10.10.2 / x64
. 2016.07.20 19:33:56 - Command line arguments (0):
. 2016.07.20 19:33:56 - Updating systems & servers data ...
. 2016.07.20 19:33:56 - Operating System: Unix 14.1.0.0 - Darwin Reids-MacBook-Pro.local 14.1.0 Darwin Kernel Version 14.1.0: Mon Dec 22 23:10:38 PST 2014; root:xnu-2782.10.72~2/RELEASE_X86_64 x86_64
I 2016.07.20 19:33:56 - OpenVPN Driver - Expected
I 2016.07.20 19:33:56 - OpenVPN - Version: OpenVPN 2.3.8 (/Users/Reid/Downloads/AirVPN.app/Contents/MacOS/openvpn)
I 2016.07.20 19:33:56 - SSH - Version: OpenSSH_6.2p2, OSSLShim 0.9.8r 8 Dec 2011 (/usr/bin/ssh)
I 2016.07.20 19:33:56 - SSL - Version: stunnel 5.17 (/Users/Reid/Downloads/AirVPN.app/Contents/MacOS/stunnel)
! 2016.07.20 19:33:56 - Ready
. 2016.07.20 19:34:01 - Systems & servers data update completed
I 2016.07.20 19:35:28 - Session starting.
I 2016.07.20 19:35:28 - IPv6 disabled on network adapter (SAMSUNG_Android)
I 2016.07.20 19:35:28 - IPv6 disabled on network adapter (Android Phone 2)
I 2016.07.20 19:35:28 - IPv6 disabled on network adapter (Android Phone)
I 2016.07.20 19:35:28 - IPv6 disabled on network adapter (SAMSUNG Modem)
I 2016.07.20 19:35:28 - IPv6 disabled on network adapter (Bluetooth DUN)
I 2016.07.20 19:35:28 - IPv6 disabled on network adapter (Thunderbolt Ethernet)
I 2016.07.20 19:35:28 - IPv6 disabled on network adapter (Wi-Fi)
I 2016.07.20 19:35:29 - IPv6 disabled on network adapter (iPhone USB)
I 2016.07.20 19:35:29 - IPv6 disabled on network adapter (Bluetooth PAN)
I 2016.07.20 19:35:29 - IPv6 disabled on network adapter (Thunderbolt Bridge)
I 2016.07.20 19:35:29 - IPv6 disabled on network adapter (VPN Unlimited (Streaming, IPSec))
I 2016.07.20 19:35:29 - IPv6 disabled on network adapter (VPN Unlimited (Streaming, PPTP))
I 2016.07.20 19:35:29 - IPv6 disabled on network adapter (TotalVPN)
I 2016.07.20 19:35:29 - Checking authorization ...
! 2016.07.20 19:35:29 - Connecting to Homam (Canada, Vancouver)
. 2016.07.20 19:35:29 - OpenVPN > OpenVPN 2.3.8 x86_64-apple-darwin14.4.0 [sSL (OpenSSL)] [LZO] [MH] [iPv6] built on Aug 13 2015
. 2016.07.20 19:35:29 - OpenVPN > library versions: OpenSSL 1.0.2d 9 Jul 2015, LZO 2.08
. 2016.07.20 19:35:29 - OpenVPN > MANAGEMENT: TCP Socket listening on [AF_INET]127.0.0.1:3100
. 2016.07.20 19:35:29 - OpenVPN > Control Channel Authentication: tls-auth using INLINE static key file
. 2016.07.20 19:35:29 - OpenVPN > Outgoing Control Channel Authentication: Using 160 bit message hash 'SHA1' for HMAC authentication
. 2016.07.20 19:35:29 - OpenVPN > Incoming Control Channel Authentication: Using 160 bit message hash 'SHA1' for HMAC authentication
. 2016.07.20 19:35:30 - OpenVPN > Socket Buffers: R=[196724->131072] S=[9216->131072]
. 2016.07.20 19:35:30 - OpenVPN > UDPv4 link local: [undef]
. 2016.07.20 19:35:30 - OpenVPN > UDPv4 link remote: [AF_INET]71.19.252.26:443
. 2016.07.20 19:35:31 - OpenVPN > TLS: Initial packet from [AF_INET]71.19.252.26:443, sid=d8531cb9 524098f2
. 2016.07.20 19:35:31 - OpenVPN > VERIFY OK: depth=1, C=IT, ST=IT, L=Perugia, O=airvpn.org, CN=airvpn.org CA, emailAddress=info@airvpn.org
. 2016.07.20 19:35:31 - OpenVPN > Validating certificate key usage
. 2016.07.20 19:35:31 - OpenVPN > ++ Certificate has key usage  00a0, expects 00a0
. 2016.07.20 19:35:31 - OpenVPN > VERIFY KU OK
. 2016.07.20 19:35:31 - OpenVPN > Validating certificate extended key usage
. 2016.07.20 19:35:31 - OpenVPN > ++ Certificate has EKU (str) TLS Web Server Authentication, expects TLS Web Server Authentication
. 2016.07.20 19:35:31 - OpenVPN > VERIFY EKU OK
. 2016.07.20 19:35:31 - OpenVPN > VERIFY OK: depth=0, C=IT, ST=IT, L=Perugia, O=airvpn.org, CN=server, emailAddress=info@airvpn.org
. 2016.07.20 19:35:32 - OpenVPN > Data Channel Encrypt: Cipher 'AES-256-CBC' initialized with 256 bit key
. 2016.07.20 19:35:32 - OpenVPN > Data Channel Encrypt: Using 160 bit message hash 'SHA1' for HMAC authentication
. 2016.07.20 19:35:32 - OpenVPN > Data Channel Decrypt: Cipher 'AES-256-CBC' initialized with 256 bit key
. 2016.07.20 19:35:32 - OpenVPN > Data Channel Decrypt: Using 160 bit message hash 'SHA1' for HMAC authentication
. 2016.07.20 19:35:32 - OpenVPN > Control Channel: TLSv1.2, cipher TLSv1/SSLv3 DHE-RSA-AES256-GCM-SHA384, 4096 bit RSA
. 2016.07.20 19:35:32 - OpenVPN > [server] Peer Connection Initiated with [AF_INET]71.19.252.26:443
. 2016.07.20 19:35:34 - OpenVPN > SENT CONTROL [server]: 'PUSH_REQUEST' (status=1)
. 2016.07.20 19:35:35 - OpenVPN > PUSH: Received control message: 'PUSH_REPLY,redirect-gateway def1 bypass-dhcp,dhcp-option DNS 10.4.0.1,comp-lzo no,route-gateway 10.4.0.1,topology subnet,ping 10,ping-restart 60,ifconfig 10.4.30.140 255.255.0.0'
. 2016.07.20 19:35:35 - OpenVPN > OPTIONS IMPORT: timers and/or timeouts modified
. 2016.07.20 19:35:35 - OpenVPN > OPTIONS IMPORT: LZO parms modified
. 2016.07.20 19:35:35 - OpenVPN > OPTIONS IMPORT: --ifconfig/up options modified
. 2016.07.20 19:35:35 - OpenVPN > OPTIONS IMPORT: route options modified
. 2016.07.20 19:35:35 - OpenVPN > OPTIONS IMPORT: route-related options modified
. 2016.07.20 19:35:35 - OpenVPN > OPTIONS IMPORT: --ip-win32 and/or --dhcp-option options modified
. 2016.07.20 19:35:35 - OpenVPN > Opened utun device utun0
. 2016.07.20 19:35:35 - OpenVPN > do_ifconfig, tt->ipv6=0, tt->did_ifconfig_ipv6_setup=0
. 2016.07.20 19:35:35 - OpenVPN > /sbin/ifconfig utun0 delete
. 2016.07.20 19:35:35 - OpenVPN > ifconfig: ioctl (SIOCDIFADDR): Can't assign requested address
. 2016.07.20 19:35:35 - OpenVPN > NOTE: Tried to delete pre-existing tun/tap instance -- No Problem if failure
. 2016.07.20 19:35:35 - OpenVPN > /sbin/ifconfig utun0 10.4.30.140 10.4.30.140 netmask 255.255.0.0 mtu 1500 up
. 2016.07.20 19:35:35 - OpenVPN > /sbin/route add -net 10.4.0.0 10.4.30.140 255.255.0.0
. 2016.07.20 19:35:35 - OpenVPN > add net 10.4.0.0: gateway 10.4.30.140
. 2016.07.20 19:35:35 - OpenVPN > /sbin/route add -net 71.19.252.26 192.168.1.1 255.255.255.255
. 2016.07.20 19:35:35 - OpenVPN > add net 71.19.252.26: gateway 192.168.1.1
. 2016.07.20 19:35:35 - OpenVPN > /sbin/route add -net 0.0.0.0 10.4.0.1 128.0.0.0
. 2016.07.20 19:35:35 - OpenVPN > add net 0.0.0.0: gateway 10.4.0.1
. 2016.07.20 19:35:35 - OpenVPN > /sbin/route add -net 128.0.0.0 10.4.0.1 128.0.0.0
. 2016.07.20 19:35:35 - OpenVPN > add net 128.0.0.0: gateway 10.4.0.1
. 2016.07.20 19:35:35 - Starting Management Interface
. 2016.07.20 19:35:35 - OpenVPN > Initialization Sequence Completed
I 2016.07.20 19:35:35 - DNS of a network adapter forced (SAMSUNG_Android)
I 2016.07.20 19:35:35 - DNS of a network adapter forced (Android Phone 2)
I 2016.07.20 19:35:35 - DNS of a network adapter forced (Android Phone)
I 2016.07.20 19:35:35 - DNS of a network adapter forced (SAMSUNG Modem)
I 2016.07.20 19:35:35 - DNS of a network adapter forced (Bluetooth DUN)
I 2016.07.20 19:35:35 - DNS of a network adapter forced (Thunderbolt Ethernet)
I 2016.07.20 19:35:35 - DNS of a network adapter forced (Wi-Fi)
I 2016.07.20 19:35:35 - DNS of a network adapter forced (iPhone USB)
I 2016.07.20 19:35:35 - DNS of a network adapter forced (Bluetooth PAN)
I 2016.07.20 19:35:35 - DNS of a network adapter forced (Thunderbolt Bridge)
I 2016.07.20 19:35:36 - DNS of a network adapter forced (VPN Unlimited (Streaming, IPSec))
I 2016.07.20 19:35:36 - DNS of a network adapter forced (VPN Unlimited (Streaming, PPTP))
I 2016.07.20 19:35:36 - DNS of a network adapter forced (TotalVPN)
I 2016.07.20 19:35:36 - Flushing DNS
I 2016.07.20 19:35:36 - Checking route
It keeps checking route then failing again and again. Any help would be greatly appreciated. Thanks
Hello ! Welcome to AirVPN!
​Maybe you should check this.
