Why i should is port forwarding for torrent or p2p? What port forwardinf do or diferent without it/?
The AirVPN server acts as a router similar to your router at home. It utilizes NAT.
Simplified, NAT allows different devices/clients attached to the same network to use one shared IP address. Every connection attempt to this IP will end up being sent to the router and not to the computers behind it. You forward a port so that the router receiving connections to some port will pass it on, or forward, to the computer actually accepting the connection. Since P2P is based on clients talking to each other instead of talking to a central server, forwarding a port is key. Without it, P2P functionality is limited.
Yes, if you enable port forwarding, more peers can connect to you, which leads to better download / upload speeds.
The whole bittorrent protocol would not work, if noone would forward any ports, because noone could connect to each other.
Regards
Fox
Hello !
No portforwarding = Bad or worse experience
​Portwarding when you torrent = Good experience
​That's the simple explanation, out of the 3 provided. Starting at advanced, going to medium and then finally simplified lol. Hard, medium, easy. Gj guyz.
