palfguy 0 Posted ... Network stuff is what I'm least knowledgeable about when it comes to computers, so I'm having a very hard time getting things working properly. I was hoping to be able to download the AirVPN client and enable it when needed and be more or less done but I've been wrestling with it for many hours and have accomplished little. Initially I had the problem where it got stuck on "checking to see if the tunnel works" and then "checking DNS", disabled all those, did all kinds of fooling around with installing an older version of the adapter driver and eventually was able to get connected (albeit using the newer, supposedly problematic driver). Although it didn't seem like the connect I had was very good, I was on a kinda crappy hotspot but I saw a 70% drop in speed when connected and couldn't access airvpn.org for some reason. Now, I'm at a public library where I'm planning on doing a lot of studying for the next couple weeks. Always have had an issue with public wifi spots that force launch a login page, fooled around with my settings enough to find that on my physical adapter it was set to manually connect to a DNS server - pretty sure it was one that had to do with my school's intranet or something. Changed that to automatic, and connected just fine.. Now trying to get AirVPN to go and receive a fatal error and complete inability to connect (see log). Thank you for any help, please let me know what other info to give. I 2016.07.18 12:34:54 - AirVPN client version: 2.10.3 / x64, System: Windows, Name: Microsoft Windows NT 6.2.9200.0 / x64. 2016.07.18 12:34:54 - Reading options from C:\Users\User\AppData\Local\AirVPN\AirVPN.xml. 2016.07.18 12:34:54 - Data Path: C:\Users\User\AppData\Local\AirVPN. 2016.07.18 12:34:54 - App Path: C:\Program Files\AirVPN. 2016.07.18 12:34:54 - Executable Path: C:\Program Files\AirVPN\AirVPN.exe. 2016.07.18 12:34:54 - Command line arguments (1): path="home". 2016.07.18 12:34:54 - Operating System: Microsoft Windows NT 6.2.9200.0. 2016.07.18 12:34:54 - Updating systems & servers data .... 2016.07.18 12:34:54 - Cannot find tunnel adapter.. 2016.07.18 12:34:55 - Systems & servers data update completedE 2016.07.18 12:34:57 - OpenVPN Driver - Not availableI 2016.07.18 12:34:57 - OpenVPN - Version: OpenVPN 2.3.8 (C:\Program Files\AirVPN\openvpn.exe)I 2016.07.18 12:34:57 - SSH - Version: plink 0.63 (C:\Program Files\AirVPN\plink.exe)I 2016.07.18 12:34:57 - SSL - Version: stunnel 5.17 (C:\Program Files\AirVPN\stunnel.exe)W 2016.07.18 12:34:57 - Recovery. Unexpected crash?I 2016.07.18 12:34:57 - DNS of a network adapter restored to original settings (Intel® Dual Band Wireless-AC 7260)I 2016.07.18 12:34:57 - IPv6 restored.! 2016.07.18 12:34:57 - Ready. 2016.07.18 12:35:30 - Updating systems & servers data .... 2016.07.18 12:35:33 - Systems & servers data update completedI 2016.07.18 12:35:37 - Session starting.. 2016.07.18 12:35:37 - Cannot find tunnel adapter.! 2016.07.18 12:35:37 - Installing tunnel driverI 2016.07.18 12:35:42 - IPv6 disabled.I 2016.07.18 12:35:42 - Checking authorization ...! 2016.07.18 12:35:43 - Connecting to Miaplacidus (United States, Newark, New Jersey). 2016.07.18 12:35:43 - OpenVPN > OpenVPN 2.3.8 x86_64-w64-mingw32 [sSL (OpenSSL)] [LZO] [iPv6] built on Aug 13 2015. 2016.07.18 12:35:43 - OpenVPN > library versions: OpenSSL 1.0.2d 9 Jul 2015, LZO 2.08. 2016.07.18 12:35:43 - OpenVPN > MANAGEMENT: TCP Socket listening on [AF_INET]127.0.0.1:3100. 2016.07.18 12:35:43 - OpenVPN > Control Channel Authentication: tls-auth using INLINE static key file. 2016.07.18 12:35:43 - OpenVPN > Outgoing Control Channel Authentication: Using 160 bit message hash 'SHA1' for HMAC authentication. 2016.07.18 12:35:43 - OpenVPN > Incoming Control Channel Authentication: Using 160 bit message hash 'SHA1' for HMAC authentication. 2016.07.18 12:35:43 - OpenVPN > Socket Buffers: R=[65536->131072] S=[65536->131072]. 2016.07.18 12:35:43 - OpenVPN > UDPv4 link local: [undef]. 2016.07.18 12:35:43 - OpenVPN > UDPv4 link remote: [AF_INET]173.234.159.196:443. 2016.07.18 12:35:43 - OpenVPN > TLS: Initial packet from [AF_INET]173.234.159.196:443, sid=3f7b855c a641340f. 2016.07.18 12:35:43 - OpenVPN > VERIFY OK: depth=1, C=IT, ST=IT, L=Perugia, O=airvpn.org, CN=airvpn.org CA, emailAddress=info@airvpn.org. 2016.07.18 12:35:43 - OpenVPN > Validating certificate key usage. 2016.07.18 12:35:43 - OpenVPN > ++ Certificate has key usage 00a0, expects 00a0. 2016.07.18 12:35:43 - OpenVPN > VERIFY KU OK. 2016.07.18 12:35:43 - OpenVPN > Validating certificate extended key usage. 2016.07.18 12:35:43 - OpenVPN > ++ Certificate has EKU (str) TLS Web Server Authentication, expects TLS Web Server Authentication. 2016.07.18 12:35:43 - OpenVPN > VERIFY EKU OK. 2016.07.18 12:35:43 - OpenVPN > VERIFY OK: depth=0, C=IT, ST=IT, L=Perugia, O=airvpn.org, CN=server, emailAddress=info@airvpn.org. 2016.07.18 12:35:43 - OpenVPN > Data Channel Encrypt: Cipher 'AES-256-CBC' initialized with 256 bit key. 2016.07.18 12:35:43 - OpenVPN > Data Channel Encrypt: Using 160 bit message hash 'SHA1' for HMAC authentication. 2016.07.18 12:35:43 - OpenVPN > Data Channel Decrypt: Cipher 'AES-256-CBC' initialized with 256 bit key. 2016.07.18 12:35:43 - OpenVPN > Data Channel Decrypt: Using 160 bit message hash 'SHA1' for HMAC authentication. 2016.07.18 12:35:43 - OpenVPN > Control Channel: TLSv1.2, cipher TLSv1/SSLv3 DHE-RSA-AES256-GCM-SHA384, 4096 bit RSA. 2016.07.18 12:35:43 - OpenVPN > [server] Peer Connection Initiated with [AF_INET]173.234.159.196:443. 2016.07.18 12:35:46 - OpenVPN > SENT CONTROL [server]: 'PUSH_REQUEST' (status=1). 2016.07.18 12:35:46 - OpenVPN > PUSH: Received control message: 'PUSH_REPLY,redirect-gateway def1 bypass-dhcp,dhcp-option DNS 10.4.0.1,comp-lzo no,route-gateway 10.4.0.1,topology subnet,ping 10,ping-restart 60,ifconfig 10.4.18.30 255.255.0.0'. 2016.07.18 12:35:46 - OpenVPN > OPTIONS IMPORT: timers and/or timeouts modified. 2016.07.18 12:35:46 - OpenVPN > OPTIONS IMPORT: LZO parms modified. 2016.07.18 12:35:46 - OpenVPN > OPTIONS IMPORT: --ifconfig/up options modified. 2016.07.18 12:35:46 - OpenVPN > OPTIONS IMPORT: route options modified. 2016.07.18 12:35:46 - OpenVPN > OPTIONS IMPORT: route-related options modified. 2016.07.18 12:35:46 - OpenVPN > OPTIONS IMPORT: --ip-win32 and/or --dhcp-option options modified. 2016.07.18 12:35:46 - OpenVPN > do_ifconfig, tt->ipv6=0, tt->did_ifconfig_ipv6_setup=0. 2016.07.18 12:35:46 - OpenVPN > open_tun, tt->ipv6=0. 2016.07.18 12:35:46 - OpenVPN > TAP-WIN32 device [Ethernet 2] opened: \\.\Global\{B09537F0-8B20-4B8E-A0E7-5B729DF4B397}.tap. 2016.07.18 12:35:46 - OpenVPN > TAP-Windows Driver Version 9.21. 2016.07.18 12:35:46 - OpenVPN > Set TAP-Windows TUN subnet mode network/local/netmask = 10.4.0.0/10.4.18.30/255.255.0.0 [sUCCEEDED]. 2016.07.18 12:35:46 - OpenVPN > Notified TAP-Windows driver to set a DHCP IP/netmask of 10.4.18.30/255.255.0.0 on interface {B09537F0-8B20-4B8E-A0E7-5B729DF4B397} [DHCP-serv: 10.4.255.254, lease-time: 31536000]. 2016.07.18 12:35:46 - OpenVPN > Successful ARP Flush on interface [12] {B09537F0-8B20-4B8E-A0E7-5B729DF4B397}. 2016.07.18 12:35:52 - OpenVPN > TEST ROUTES: 1/1 succeeded len=0 ret=1 a=0 u/d=up. 2016.07.18 12:35:52 - OpenVPN > C:\WINDOWS\system32\route.exe ADD 173.234.159.196 MASK 255.255.255.255 10.128.128.128. 2016.07.18 12:35:52 - OpenVPN > ROUTE: CreateIpForwardEntry succeeded with dwForwardMetric1=10 and dwForwardType=4. 2016.07.18 12:35:52 - OpenVPN > Route addition via IPAPI succeeded [adaptive]. 2016.07.18 12:35:52 - OpenVPN > C:\WINDOWS\system32\route.exe ADD 10.128.128.128 MASK 255.255.255.255 10.128.128.128 IF 10. 2016.07.18 12:35:52 - OpenVPN > ROUTE: CreateIpForwardEntry succeeded with dwForwardMetric1=10 and dwForwardType=4. 2016.07.18 12:35:52 - OpenVPN > Route addition via IPAPI succeeded [adaptive]. 2016.07.18 12:35:52 - OpenVPN > C:\WINDOWS\system32\route.exe ADD 0.0.0.0 MASK 128.0.0.0 10.4.0.1. 2016.07.18 12:35:52 - OpenVPN > ROUTE: CreateIpForwardEntry succeeded with dwForwardMetric1=20 and dwForwardType=4. 2016.07.18 12:35:52 - OpenVPN > Route addition via IPAPI succeeded [adaptive]. 2016.07.18 12:35:52 - OpenVPN > C:\WINDOWS\system32\route.exe ADD 128.0.0.0 MASK 128.0.0.0 10.4.0.1. 2016.07.18 12:35:52 - OpenVPN > ROUTE: CreateIpForwardEntry succeeded with dwForwardMetric1=20 and dwForwardType=4. 2016.07.18 12:35:52 - OpenVPN > Route addition via IPAPI succeeded [adaptive]. 2016.07.18 12:35:52 - Starting Management Interface. 2016.07.18 12:35:52 - OpenVPN > Initialization Sequence CompletedI 2016.07.18 12:35:52 - DNS of a network adapter forced (Intel® Dual Band Wireless-AC 7260)I 2016.07.18 12:35:52 - DNS of a network adapter forced (TAP-Windows Adapter V9)I 2016.07.18 12:35:52 - Flushing DNS! 2016.07.18 12:35:52 - Connected.. 2016.07.18 12:35:52 - OpenVPN > MANAGEMENT: Client connected from [AF_INET]127.0.0.1:3100. 2016.07.18 12:35:52 - OpenVpn Management > >INFO:OpenVPN Management Interface Version 1 -- type 'help' for more info! 2016.07.18 12:37:34 - Disconnecting. 2016.07.18 12:37:34 - Management - Send 'signal SIGTERM'. 2016.07.18 12:37:34 - OpenVPN > MANAGEMENT: CMD 'signal SIGTERM'. 2016.07.18 12:37:34 - OpenVPN > SIGTERM received, sending exit notification to peer. 2016.07.18 12:37:39 - OpenVPN > C:\WINDOWS\system32\route.exe DELETE 173.234.159.196 MASK 255.255.255.255 10.128.128.128. 2016.07.18 12:37:39 - OpenVPN > Route deletion via IPAPI succeeded [adaptive]. 2016.07.18 12:37:39 - OpenVPN > C:\WINDOWS\system32\route.exe DELETE 10.128.128.128 MASK 255.255.255.255 10.128.128.128. 2016.07.18 12:37:39 - OpenVPN > Route deletion via IPAPI succeeded [adaptive]. 2016.07.18 12:37:39 - OpenVPN > C:\WINDOWS\system32\route.exe DELETE 0.0.0.0 MASK 128.0.0.0 10.4.0.1. 2016.07.18 12:37:39 - OpenVPN > Route deletion via IPAPI succeeded [adaptive]. 2016.07.18 12:37:39 - OpenVPN > C:\WINDOWS\system32\route.exe DELETE 128.0.0.0 MASK 128.0.0.0 10.4.0.1. 2016.07.18 12:37:39 - OpenVPN > Route deletion via IPAPI succeeded [adaptive]. 2016.07.18 12:37:39 - OpenVPN > Closing TUN/TAP interface. 2016.07.18 12:37:39 - OpenVPN > SIGTERM[soft,exit-with-notification] received, process exiting. 2016.07.18 12:37:39 - Connection terminated.I 2016.07.18 12:37:39 - DNS of a network adapter restored to original settings (Intel® Dual Band Wireless-AC 7260)I 2016.07.18 12:37:39 - DNS of a network adapter restored to original settings (TAP-Windows Adapter V9)I 2016.07.18 12:37:39 - IPv6 restored.! 2016.07.18 12:37:39 - Session terminated.I 2016.07.18 12:37:58 - Session starting.I 2016.07.18 12:37:58 - IPv6 disabled.I 2016.07.18 12:37:58 - Checking authorization ...! 2016.07.18 12:38:01 - Connecting to Azha (United States, Atlanta, Georgia). 2016.07.18 12:38:01 - OpenVPN > OpenVPN 2.3.8 x86_64-w64-mingw32 [sSL (OpenSSL)] [LZO] [iPv6] built on Aug 13 2015. 2016.07.18 12:38:01 - OpenVPN > library versions: OpenSSL 1.0.2d 9 Jul 2015, LZO 2.08. 2016.07.18 12:38:01 - OpenVPN > MANAGEMENT: TCP Socket listening on [AF_INET]127.0.0.1:3100. 2016.07.18 12:38:01 - OpenVPN > Control Channel Authentication: tls-auth using INLINE static key file. 2016.07.18 12:38:01 - OpenVPN > Outgoing Control Channel Authentication: Using 160 bit message hash 'SHA1' for HMAC authentication. 2016.07.18 12:38:01 - OpenVPN > Incoming Control Channel Authentication: Using 160 bit message hash 'SHA1' for HMAC authentication. 2016.07.18 12:38:01 - OpenVPN > Socket Buffers: R=[65536->131072] S=[65536->131072]. 2016.07.18 12:38:01 - OpenVPN > UDPv4 link local: [undef]. 2016.07.18 12:38:01 - OpenVPN > UDPv4 link remote: [AF_INET]104.129.24.186:443. 2016.07.18 12:38:01 - OpenVPN > TLS: Initial packet from [AF_INET]104.129.24.186:443, sid=bfab23ae a7522840. 2016.07.18 12:38:01 - OpenVPN > VERIFY OK: depth=1, C=IT, ST=IT, L=Perugia, O=airvpn.org, CN=airvpn.org CA, emailAddress=info@airvpn.org. 2016.07.18 12:38:01 - OpenVPN > Validating certificate key usage. 2016.07.18 12:38:01 - OpenVPN > ++ Certificate has key usage 00a0, expects 00a0. 2016.07.18 12:38:01 - OpenVPN > VERIFY KU OK. 2016.07.18 12:38:01 - OpenVPN > Validating certificate extended key usage. 2016.07.18 12:38:01 - OpenVPN > ++ Certificate has EKU (str) TLS Web Server Authentication, expects TLS Web Server Authentication. 2016.07.18 12:38:01 - OpenVPN > VERIFY EKU OK. 2016.07.18 12:38:01 - OpenVPN > VERIFY OK: depth=0, C=IT, ST=IT, L=Perugia, O=airvpn.org, CN=server, emailAddress=info@airvpn.org. 2016.07.18 12:38:02 - OpenVPN > Data Channel Encrypt: Cipher 'AES-256-CBC' initialized with 256 bit key. 2016.07.18 12:38:02 - OpenVPN > Data Channel Encrypt: Using 160 bit message hash 'SHA1' for HMAC authentication. 2016.07.18 12:38:02 - OpenVPN > Data Channel Decrypt: Cipher 'AES-256-CBC' initialized with 256 bit key. 2016.07.18 12:38:02 - OpenVPN > Data Channel Decrypt: Using 160 bit message hash 'SHA1' for HMAC authentication. 2016.07.18 12:38:02 - OpenVPN > Control Channel: TLSv1.2, cipher TLSv1/SSLv3 DHE-RSA-AES256-GCM-SHA384, 4096 bit RSA. 2016.07.18 12:38:02 - OpenVPN > [server] Peer Connection Initiated with [AF_INET]104.129.24.186:443. 2016.07.18 12:38:04 - OpenVPN > SENT CONTROL [server]: 'PUSH_REQUEST' (status=1). 2016.07.18 12:38:04 - OpenVPN > PUSH: Received control message: 'PUSH_REPLY,redirect-gateway def1 bypass-dhcp,dhcp-option DNS 10.4.0.1,comp-lzo no,route-gateway 10.4.0.1,topology subnet,ping 10,ping-restart 60,ifconfig 10.4.12.229 255.255.0.0'. 2016.07.18 12:38:04 - OpenVPN > OPTIONS IMPORT: timers and/or timeouts modified. 2016.07.18 12:38:04 - OpenVPN > OPTIONS IMPORT: LZO parms modified. 2016.07.18 12:38:04 - OpenVPN > OPTIONS IMPORT: --ifconfig/up options modified. 2016.07.18 12:38:04 - OpenVPN > OPTIONS IMPORT: route options modified. 2016.07.18 12:38:04 - OpenVPN > OPTIONS IMPORT: route-related options modified. 2016.07.18 12:38:04 - OpenVPN > OPTIONS IMPORT: --ip-win32 and/or --dhcp-option options modified. 2016.07.18 12:38:04 - OpenVPN > do_ifconfig, tt->ipv6=0, tt->did_ifconfig_ipv6_setup=0. 2016.07.18 12:38:04 - OpenVPN > open_tun, tt->ipv6=0. 2016.07.18 12:38:04 - OpenVPN > TAP-WIN32 device [Ethernet 2] opened: \\.\Global\{B09537F0-8B20-4B8E-A0E7-5B729DF4B397}.tap. 2016.07.18 12:38:04 - OpenVPN > TAP-Windows Driver Version 9.21. 2016.07.18 12:38:05 - OpenVPN > NETSH: C:\WINDOWS\system32\netsh.exe interface ip set address Ethernet 2 dhcp. 2016.07.18 12:38:05 - OpenVPN > ERROR: netsh command failed: returned error code 1. 2016.07.18 12:38:10 - OpenVPN > NETSH: C:\WINDOWS\system32\netsh.exe interface ip set address Ethernet 2 dhcp. 2016.07.18 12:38:11 - OpenVPN > ERROR: netsh command failed: returned error code 1. 2016.07.18 12:38:16 - OpenVPN > NETSH: C:\WINDOWS\system32\netsh.exe interface ip set address Ethernet 2 dhcp. 2016.07.18 12:38:16 - OpenVPN > ERROR: netsh command failed: returned error code 1. 2016.07.18 12:38:21 - OpenVPN > NETSH: C:\WINDOWS\system32\netsh.exe interface ip set address Ethernet 2 dhcp. 2016.07.18 12:38:21 - OpenVPN > ERROR: netsh command failed: returned error code 1. 2016.07.18 12:38:25 - OpenVPN > NETSH: command failed. 2016.07.18 12:38:25 - OpenVPN > Exiting due to fatal error! 2016.07.18 12:38:25 - Disconnecting. 2016.07.18 12:38:25 - Connection terminated.I 2016.07.18 12:38:28 - Checking authorization ...! 2016.07.18 12:38:28 - Connecting to Miaplacidus (United States, Newark, New Jersey). 2016.07.18 12:38:28 - OpenVPN > OpenVPN 2.3.8 x86_64-w64-mingw32 [sSL (OpenSSL)] [LZO] [iPv6] built on Aug 13 2015. 2016.07.18 12:38:28 - OpenVPN > library versions: OpenSSL 1.0.2d 9 Jul 2015, LZO 2.08. 2016.07.18 12:38:28 - OpenVPN > MANAGEMENT: TCP Socket listening on [AF_INET]127.0.0.1:3100. 2016.07.18 12:38:28 - OpenVPN > Control Channel Authentication: tls-auth using INLINE static key file. 2016.07.18 12:38:28 - OpenVPN > Outgoing Control Channel Authentication: Using 160 bit message hash 'SHA1' for HMAC authentication. 2016.07.18 12:38:28 - OpenVPN > Incoming Control Channel Authentication: Using 160 bit message hash 'SHA1' for HMAC authentication. 2016.07.18 12:38:28 - OpenVPN > Socket Buffers: R=[65536->131072] S=[65536->131072]. 2016.07.18 12:38:28 - OpenVPN > UDPv4 link local: [undef]. 2016.07.18 12:38:28 - OpenVPN > UDPv4 link remote: [AF_INET]173.234.159.194:443. 2016.07.18 12:38:28 - OpenVPN > TLS: Initial packet from [AF_INET]173.234.159.194:443, sid=4d3ae50b d4e569a5. 2016.07.18 12:38:29 - OpenVPN > VERIFY OK: depth=1, C=IT, ST=IT, L=Perugia, O=airvpn.org, CN=airvpn.org CA, emailAddress=info@airvpn.org. 2016.07.18 12:38:29 - OpenVPN > Validating certificate key usage. 2016.07.18 12:38:29 - OpenVPN > ++ Certificate has key usage 00a0, expects 00a0. 2016.07.18 12:38:29 - OpenVPN > VERIFY KU OK. 2016.07.18 12:38:29 - OpenVPN > Validating certificate extended key usage. 2016.07.18 12:38:29 - OpenVPN > ++ Certificate has EKU (str) TLS Web Server Authentication, expects TLS Web Server Authentication. 2016.07.18 12:38:29 - OpenVPN > VERIFY EKU OK. 2016.07.18 12:38:29 - OpenVPN > VERIFY OK: depth=0, C=IT, ST=IT, L=Perugia, O=airvpn.org, CN=server, emailAddress=info@airvpn.org. 2016.07.18 12:38:29 - OpenVPN > Data Channel Encrypt: Cipher 'AES-256-CBC' initialized with 256 bit key. 2016.07.18 12:38:29 - OpenVPN > Data Channel Encrypt: Using 160 bit message hash 'SHA1' for HMAC authentication. 2016.07.18 12:38:29 - OpenVPN > Data Channel Decrypt: Cipher 'AES-256-CBC' initialized with 256 bit key. 2016.07.18 12:38:29 - OpenVPN > Data Channel Decrypt: Using 160 bit message hash 'SHA1' for HMAC authentication. 2016.07.18 12:38:29 - OpenVPN > Control Channel: TLSv1.2, cipher TLSv1/SSLv3 DHE-RSA-AES256-GCM-SHA384, 4096 bit RSA. 2016.07.18 12:38:29 - OpenVPN > [server] Peer Connection Initiated with [AF_INET]173.234.159.194:443. 2016.07.18 12:38:31 - OpenVPN > SENT CONTROL [server]: 'PUSH_REQUEST' (status=1). 2016.07.18 12:38:31 - OpenVPN > PUSH: Received control message: 'PUSH_REPLY,redirect-gateway def1 bypass-dhcp,dhcp-option DNS 10.4.0.1,comp-lzo no,route-gateway 10.4.0.1,topology subnet,ping 10,ping-restart 60,ifconfig 10.4.18.30 255.255.0.0'. 2016.07.18 12:38:31 - OpenVPN > OPTIONS IMPORT: timers and/or timeouts modified. 2016.07.18 12:38:31 - OpenVPN > OPTIONS IMPORT: LZO parms modified. 2016.07.18 12:38:31 - OpenVPN > OPTIONS IMPORT: --ifconfig/up options modified. 2016.07.18 12:38:31 - OpenVPN > OPTIONS IMPORT: route options modified. 2016.07.18 12:38:31 - OpenVPN > OPTIONS IMPORT: route-related options modified. 2016.07.18 12:38:31 - OpenVPN > OPTIONS IMPORT: --ip-win32 and/or --dhcp-option options modified. 2016.07.18 12:38:31 - OpenVPN > do_ifconfig, tt->ipv6=0, tt->did_ifconfig_ipv6_setup=0. 2016.07.18 12:38:31 - OpenVPN > open_tun, tt->ipv6=0. 2016.07.18 12:38:31 - OpenVPN > TAP-WIN32 device [Ethernet 2] opened: \\.\Global\{B09537F0-8B20-4B8E-A0E7-5B729DF4B397}.tap. 2016.07.18 12:38:31 - OpenVPN > TAP-Windows Driver Version 9.21. 2016.07.18 12:38:32 - OpenVPN > NETSH: C:\WINDOWS\system32\netsh.exe interface ip set address Ethernet 2 dhcp. 2016.07.18 12:38:32 - OpenVPN > ERROR: netsh command failed: returned error code 1. 2016.07.18 12:38:37 - OpenVPN > NETSH: C:\WINDOWS\system32\netsh.exe interface ip set address Ethernet 2 dhcp. 2016.07.18 12:38:37 - OpenVPN > ERROR: netsh command failed: returned error code 1. 2016.07.18 12:38:42 - OpenVPN > NETSH: C:\WINDOWS\system32\netsh.exe interface ip set address Ethernet 2 dhcp. 2016.07.18 12:38:42 - OpenVPN > ERROR: netsh command failed: returned error code 1. 2016.07.18 12:38:47 - OpenVPN > NETSH: C:\WINDOWS\system32\netsh.exe interface ip set address Ethernet 2 dhcp. 2016.07.18 12:38:48 - OpenVPN > ERROR: netsh command failed: returned error code 1. 2016.07.18 12:38:52 - OpenVPN > NETSH: command failed. 2016.07.18 12:38:52 - OpenVPN > Exiting due to fatal error! 2016.07.18 12:38:52 - Disconnecting. 2016.07.18 12:38:52 - Connection terminated.I 2016.07.18 12:38:55 - Checking authorization ...! 2016.07.18 12:38:55 - Connecting to Miaplacidus (United States, Newark, New Jersey). 2016.07.18 12:38:55 - OpenVPN > OpenVPN 2.3.8 x86_64-w64-mingw32 [sSL (OpenSSL)] [LZO] [iPv6] built on Aug 13 2015. 2016.07.18 12:38:55 - OpenVPN > library versions: OpenSSL 1.0.2d 9 Jul 2015, LZO 2.08. 2016.07.18 12:38:55 - OpenVPN > MANAGEMENT: TCP Socket listening on [AF_INET]127.0.0.1:3100. 2016.07.18 12:38:55 - OpenVPN > Control Channel Authentication: tls-auth using INLINE static key file. 2016.07.18 12:38:55 - OpenVPN > Outgoing Control Channel Authentication: Using 160 bit message hash 'SHA1' for HMAC authentication. 2016.07.18 12:38:55 - OpenVPN > Incoming Control Channel Authentication: Using 160 bit message hash 'SHA1' for HMAC authentication. 2016.07.18 12:38:55 - OpenVPN > Socket Buffers: R=[65536->131072] S=[65536->131072]. 2016.07.18 12:38:55 - OpenVPN > UDPv4 link local: [undef]. 2016.07.18 12:38:55 - OpenVPN > UDPv4 link remote: [AF_INET]173.234.159.194:443. 2016.07.18 12:38:55 - OpenVPN > TLS: Initial packet from [AF_INET]173.234.159.194:443, sid=242f88c8 5f78b3c0. 2016.07.18 12:38:55 - OpenVPN > VERIFY OK: depth=1, C=IT, ST=IT, L=Perugia, O=airvpn.org, CN=airvpn.org CA, emailAddress=info@airvpn.org. 2016.07.18 12:38:55 - OpenVPN > Validating certificate key usage. 2016.07.18 12:38:55 - OpenVPN > ++ Certificate has key usage 00a0, expects 00a0. 2016.07.18 12:38:55 - OpenVPN > VERIFY KU OK. 2016.07.18 12:38:55 - OpenVPN > Validating certificate extended key usage. 2016.07.18 12:38:55 - OpenVPN > ++ Certificate has EKU (str) TLS Web Server Authentication, expects TLS Web Server Authentication. 2016.07.18 12:38:55 - OpenVPN > VERIFY EKU OK. 2016.07.18 12:38:55 - OpenVPN > VERIFY OK: depth=0, C=IT, ST=IT, L=Perugia, O=airvpn.org, CN=server, emailAddress=info@airvpn.org. 2016.07.18 12:38:55 - OpenVPN > Data Channel Encrypt: Cipher 'AES-256-CBC' initialized with 256 bit key. 2016.07.18 12:38:55 - OpenVPN > Data Channel Encrypt: Using 160 bit message hash 'SHA1' for HMAC authentication. 2016.07.18 12:38:55 - OpenVPN > Data Channel Decrypt: Cipher 'AES-256-CBC' initialized with 256 bit key. 2016.07.18 12:38:55 - OpenVPN > Data Channel Decrypt: Using 160 bit message hash 'SHA1' for HMAC authentication. 2016.07.18 12:38:56 - OpenVPN > Control Channel: TLSv1.2, cipher TLSv1/SSLv3 DHE-RSA-AES256-GCM-SHA384, 4096 bit RSA. 2016.07.18 12:38:56 - OpenVPN > [server] Peer Connection Initiated with [AF_INET]173.234.159.194:443. 2016.07.18 12:38:58 - OpenVPN > SENT CONTROL [server]: 'PUSH_REQUEST' (status=1). 2016.07.18 12:38:58 - OpenVPN > PUSH: Received control message: 'PUSH_REPLY,redirect-gateway def1 bypass-dhcp,dhcp-option DNS 10.4.0.1,comp-lzo no,route-gateway 10.4.0.1,topology subnet,ping 10,ping-restart 60,ifconfig 10.4.18.30 255.255.0.0'. 2016.07.18 12:38:58 - OpenVPN > OPTIONS IMPORT: timers and/or timeouts modified. 2016.07.18 12:38:58 - OpenVPN > OPTIONS IMPORT: LZO parms modified. 2016.07.18 12:38:58 - OpenVPN > OPTIONS IMPORT: --ifconfig/up options modified. 2016.07.18 12:38:58 - OpenVPN > OPTIONS IMPORT: route options modified. 2016.07.18 12:38:58 - OpenVPN > OPTIONS IMPORT: route-related options modified. 2016.07.18 12:38:58 - OpenVPN > OPTIONS IMPORT: --ip-win32 and/or --dhcp-option options modified. 2016.07.18 12:38:58 - OpenVPN > do_ifconfig, tt->ipv6=0, tt->did_ifconfig_ipv6_setup=0. 2016.07.18 12:38:58 - OpenVPN > open_tun, tt->ipv6=0. 2016.07.18 12:38:58 - OpenVPN > TAP-WIN32 device [Ethernet 2] opened: \\.\Global\{B09537F0-8B20-4B8E-A0E7-5B729DF4B397}.tap. 2016.07.18 12:38:58 - OpenVPN > TAP-Windows Driver Version 9.21. 2016.07.18 12:38:59 - OpenVPN > NETSH: C:\WINDOWS\system32\netsh.exe interface ip set address Ethernet 2 dhcp. 2016.07.18 12:38:59 - OpenVPN > ERROR: netsh command failed: returned error code 1. 2016.07.18 12:39:04 - OpenVPN > NETSH: C:\WINDOWS\system32\netsh.exe interface ip set address Ethernet 2 dhcp. 2016.07.18 12:39:04 - OpenVPN > ERROR: netsh command failed: returned error code 1. 2016.07.18 12:39:09 - OpenVPN > NETSH: C:\WINDOWS\system32\netsh.exe interface ip set address Ethernet 2 dhcp. 2016.07.18 12:39:09 - OpenVPN > ERROR: netsh command failed: returned error code 1. 2016.07.18 12:39:14 - OpenVPN > NETSH: C:\WINDOWS\system32\netsh.exe interface ip set address Ethernet 2 dhcp. 2016.07.18 12:39:14 - OpenVPN > ERROR: netsh command failed: returned error code 1. 2016.07.18 12:39:18 - OpenVPN > NETSH: command failed. 2016.07.18 12:39:18 - OpenVPN > Exiting due to fatal error! 2016.07.18 12:39:18 - Disconnecting. 2016.07.18 12:39:18 - Connection terminated.I 2016.07.18 12:39:18 - Cancel requested.I 2016.07.18 12:39:18 - IPv6 restored.! 2016.07.18 12:39:18 - Session terminated.I 2016.07.18 12:39:23 - Session starting.I 2016.07.18 12:39:23 - IPv6 disabled.I 2016.07.18 12:39:23 - Checking authorization ...! 2016.07.18 12:39:23 - Connecting to Azha (United States, Atlanta, Georgia). 2016.07.18 12:39:23 - OpenVPN > OpenVPN 2.3.8 x86_64-w64-mingw32 [sSL (OpenSSL)] [LZO] [iPv6] built on Aug 13 2015. 2016.07.18 12:39:23 - OpenVPN > library versions: OpenSSL 1.0.2d 9 Jul 2015, LZO 2.08. 2016.07.18 12:39:23 - OpenVPN > MANAGEMENT: TCP Socket listening on [AF_INET]127.0.0.1:3100. 2016.07.18 12:39:23 - OpenVPN > Control Channel Authentication: tls-auth using INLINE static key file. 2016.07.18 12:39:23 - OpenVPN > Outgoing Control Channel Authentication: Using 160 bit message hash 'SHA1' for HMAC authentication. 2016.07.18 12:39:23 - OpenVPN > Incoming Control Channel Authentication: Using 160 bit message hash 'SHA1' for HMAC authentication. 2016.07.18 12:39:23 - OpenVPN > Socket Buffers: R=[65536->131072] S=[65536->131072]. 2016.07.18 12:39:23 - OpenVPN > UDPv4 link local: [undef]. 2016.07.18 12:39:23 - OpenVPN > UDPv4 link remote: [AF_INET]104.129.24.186:443. 2016.07.18 12:39:23 - OpenVPN > TLS: Initial packet from [AF_INET]104.129.24.186:443, sid=2e7579a6 cd283e87. 2016.07.18 12:39:23 - OpenVPN > VERIFY OK: depth=1, C=IT, ST=IT, L=Perugia, O=airvpn.org, CN=airvpn.org CA, emailAddress=info@airvpn.org. 2016.07.18 12:39:23 - OpenVPN > Validating certificate key usage. 2016.07.18 12:39:23 - OpenVPN > ++ Certificate has key usage 00a0, expects 00a0. 2016.07.18 12:39:23 - OpenVPN > VERIFY KU OK. 2016.07.18 12:39:23 - OpenVPN > Validating certificate extended key usage. 2016.07.18 12:39:23 - OpenVPN > ++ Certificate has EKU (str) TLS Web Server Authentication, expects TLS Web Server Authentication. 2016.07.18 12:39:23 - OpenVPN > VERIFY EKU OK. 2016.07.18 12:39:23 - OpenVPN > VERIFY OK: depth=0, C=IT, ST=IT, L=Perugia, O=airvpn.org, CN=server, emailAddress=info@airvpn.org. 2016.07.18 12:39:24 - OpenVPN > Data Channel Encrypt: Cipher 'AES-256-CBC' initialized with 256 bit key. 2016.07.18 12:39:24 - OpenVPN > Data Channel Encrypt: Using 160 bit message hash 'SHA1' for HMAC authentication. 2016.07.18 12:39:24 - OpenVPN > Data Channel Decrypt: Cipher 'AES-256-CBC' initialized with 256 bit key. 2016.07.18 12:39:24 - OpenVPN > Data Channel Decrypt: Using 160 bit message hash 'SHA1' for HMAC authentication. 2016.07.18 12:39:24 - OpenVPN > Control Channel: TLSv1.2, cipher TLSv1/SSLv3 DHE-RSA-AES256-GCM-SHA384, 4096 bit RSA. 2016.07.18 12:39:24 - OpenVPN > [server] Peer Connection Initiated with [AF_INET]104.129.24.186:443. 2016.07.18 12:39:26 - OpenVPN > SENT CONTROL [server]: 'PUSH_REQUEST' (status=1). 2016.07.18 12:39:26 - OpenVPN > PUSH: Received control message: 'PUSH_REPLY,redirect-gateway def1 bypass-dhcp,dhcp-option DNS 10.4.0.1,comp-lzo no,route-gateway 10.4.0.1,topology subnet,ping 10,ping-restart 60,ifconfig 10.4.12.229 255.255.0.0'. 2016.07.18 12:39:26 - OpenVPN > OPTIONS IMPORT: timers and/or timeouts modified. 2016.07.18 12:39:26 - OpenVPN > OPTIONS IMPORT: LZO parms modified. 2016.07.18 12:39:26 - OpenVPN > OPTIONS IMPORT: --ifconfig/up options modified. 2016.07.18 12:39:26 - OpenVPN > OPTIONS IMPORT: route options modified. 2016.07.18 12:39:26 - OpenVPN > OPTIONS IMPORT: route-related options modified. 2016.07.18 12:39:26 - OpenVPN > OPTIONS IMPORT: --ip-win32 and/or --dhcp-option options modified. 2016.07.18 12:39:26 - OpenVPN > do_ifconfig, tt->ipv6=0, tt->did_ifconfig_ipv6_setup=0. 2016.07.18 12:39:26 - OpenVPN > open_tun, tt->ipv6=0. 2016.07.18 12:39:26 - OpenVPN > TAP-WIN32 device [Ethernet 2] opened: \\.\Global\{B09537F0-8B20-4B8E-A0E7-5B729DF4B397}.tap. 2016.07.18 12:39:26 - OpenVPN > TAP-Windows Driver Version 9.21. 2016.07.18 12:39:27 - OpenVPN > NETSH: C:\WINDOWS\system32\netsh.exe interface ip set address Ethernet 2 dhcp. 2016.07.18 12:39:27 - OpenVPN > ERROR: netsh command failed: returned error code 1. 2016.07.18 12:39:32 - OpenVPN > NETSH: C:\WINDOWS\system32\netsh.exe interface ip set address Ethernet 2 dhcp. 2016.07.18 12:39:32 - OpenVPN > ERROR: netsh command failed: returned error code 1. 2016.07.18 12:39:37 - OpenVPN > NETSH: C:\WINDOWS\system32\netsh.exe interface ip set address Ethernet 2 dhcp. 2016.07.18 12:39:37 - OpenVPN > ERROR: netsh command failed: returned error code 1. 2016.07.18 12:39:42 - OpenVPN > NETSH: C:\WINDOWS\system32\netsh.exe interface ip set address Ethernet 2 dhcp. 2016.07.18 12:39:42 - OpenVPN > ERROR: netsh command failed: returned error code 1. 2016.07.18 12:39:46 - OpenVPN > NETSH: command failed. 2016.07.18 12:39:46 - OpenVPN > Exiting due to fatal error! 2016.07.18 12:39:46 - Disconnecting. 2016.07.18 12:39:46 - Connection terminated.I 2016.07.18 12:39:49 - Checking authorization ...! 2016.07.18 12:39:50 - Connecting to Miaplacidus (United States, Newark, New Jersey). 2016.07.18 12:39:50 - OpenVPN > OpenVPN 2.3.8 x86_64-w64-mingw32 [sSL (OpenSSL)] [LZO] [iPv6] built on Aug 13 2015. 2016.07.18 12:39:50 - OpenVPN > library versions: OpenSSL 1.0.2d 9 Jul 2015, LZO 2.08. 2016.07.18 12:39:50 - OpenVPN > MANAGEMENT: TCP Socket listening on [AF_INET]127.0.0.1:3100. 2016.07.18 12:39:50 - OpenVPN > Control Channel Authentication: tls-auth using INLINE static key file. 2016.07.18 12:39:50 - OpenVPN > Outgoing Control Channel Authentication: Using 160 bit message hash 'SHA1' for HMAC authentication. 2016.07.18 12:39:50 - OpenVPN > Incoming Control Channel Authentication: Using 160 bit message hash 'SHA1' for HMAC authentication. 2016.07.18 12:39:50 - OpenVPN > Socket Buffers: R=[65536->131072] S=[65536->131072]. 2016.07.18 12:39:50 - OpenVPN > UDPv4 link local: [undef]. 2016.07.18 12:39:50 - OpenVPN > UDPv4 link remote: [AF_INET]173.234.159.194:443. 2016.07.18 12:39:50 - OpenVPN > TLS: Initial packet from [AF_INET]173.234.159.194:443, sid=6662fc36 9a73127e. 2016.07.18 12:39:50 - OpenVPN > VERIFY OK: depth=1, C=IT, ST=IT, L=Perugia, O=airvpn.org, CN=airvpn.org CA, emailAddress=info@airvpn.org. 2016.07.18 12:39:50 - OpenVPN > Validating certificate key usage. 2016.07.18 12:39:50 - OpenVPN > ++ Certificate has key usage 00a0, expects 00a0. 2016.07.18 12:39:50 - OpenVPN > VERIFY KU OK. 2016.07.18 12:39:50 - OpenVPN > Validating certificate extended key usage. 2016.07.18 12:39:50 - OpenVPN > ++ Certificate has EKU (str) TLS Web Server Authentication, expects TLS Web Server Authentication. 2016.07.18 12:39:50 - OpenVPN > VERIFY EKU OK. 2016.07.18 12:39:50 - OpenVPN > VERIFY OK: depth=0, C=IT, ST=IT, L=Perugia, O=airvpn.org, CN=server, emailAddress=info@airvpn.org. 2016.07.18 12:39:50 - OpenVPN > Data Channel Encrypt: Cipher 'AES-256-CBC' initialized with 256 bit key. 2016.07.18 12:39:50 - OpenVPN > Data Channel Encrypt: Using 160 bit message hash 'SHA1' for HMAC authentication. 2016.07.18 12:39:50 - OpenVPN > Data Channel Decrypt: Cipher 'AES-256-CBC' initialized with 256 bit key. 2016.07.18 12:39:50 - OpenVPN > Data Channel Decrypt: Using 160 bit message hash 'SHA1' for HMAC authentication. 2016.07.18 12:39:50 - OpenVPN > Control Channel: TLSv1.2, cipher TLSv1/SSLv3 DHE-RSA-AES256-GCM-SHA384, 4096 bit RSA. 2016.07.18 12:39:50 - OpenVPN > [server] Peer Connection Initiated with [AF_INET]173.234.159.194:443. 2016.07.18 12:39:53 - OpenVPN > SENT CONTROL [server]: 'PUSH_REQUEST' (status=1). 2016.07.18 12:39:53 - OpenVPN > PUSH: Received control message: 'PUSH_REPLY,redirect-gateway def1 bypass-dhcp,dhcp-option DNS 10.4.0.1,comp-lzo no,route-gateway 10.4.0.1,topology subnet,ping 10,ping-restart 60,ifconfig 10.4.18.30 255.255.0.0'. 2016.07.18 12:39:53 - OpenVPN > OPTIONS IMPORT: timers and/or timeouts modified. 2016.07.18 12:39:53 - OpenVPN > OPTIONS IMPORT: LZO parms modified. 2016.07.18 12:39:53 - OpenVPN > OPTIONS IMPORT: --ifconfig/up options modified. 2016.07.18 12:39:53 - OpenVPN > OPTIONS IMPORT: route options modified. 2016.07.18 12:39:53 - OpenVPN > OPTIONS IMPORT: route-related options modified. 2016.07.18 12:39:53 - OpenVPN > OPTIONS IMPORT: --ip-win32 and/or --dhcp-option options modified. 2016.07.18 12:39:53 - OpenVPN > do_ifconfig, tt->ipv6=0, tt->did_ifconfig_ipv6_setup=0. 2016.07.18 12:39:53 - OpenVPN > open_tun, tt->ipv6=0. 2016.07.18 12:39:53 - OpenVPN > TAP-WIN32 device [Ethernet 2] opened: \\.\Global\{B09537F0-8B20-4B8E-A0E7-5B729DF4B397}.tap. 2016.07.18 12:39:53 - OpenVPN > TAP-Windows Driver Version 9.21. 2016.07.18 12:39:54 - OpenVPN > NETSH: C:\WINDOWS\system32\netsh.exe interface ip set address Ethernet 2 dhcp. 2016.07.18 12:39:54 - OpenVPN > ERROR: netsh command failed: returned error code 1. 2016.07.18 12:39:59 - OpenVPN > NETSH: C:\WINDOWS\system32\netsh.exe interface ip set address Ethernet 2 dhcp. 2016.07.18 12:39:59 - OpenVPN > ERROR: netsh command failed: returned error code 1. 2016.07.18 12:40:04 - OpenVPN > NETSH: C:\WINDOWS\system32\netsh.exe interface ip set address Ethernet 2 dhcp. 2016.07.18 12:40:04 - OpenVPN > ERROR: netsh command failed: returned error code 1. 2016.07.18 12:40:09 - OpenVPN > NETSH: C:\WINDOWS\system32\netsh.exe interface ip set address Ethernet 2 dhcp. 2016.07.18 12:40:09 - OpenVPN > ERROR: netsh command failed: returned error code 1. 2016.07.18 12:40:13 - OpenVPN > NETSH: command failed. 2016.07.18 12:40:13 - OpenVPN > Exiting due to fatal error! 2016.07.18 12:40:13 - Disconnecting. 2016.07.18 12:40:13 - Connection terminated.I 2016.07.18 12:40:14 - Cancel requested.I 2016.07.18 12:40:14 - IPv6 restored.! 2016.07.18 12:40:14 - Session terminated. Quote Share this post Link to post
LZ1 677 Posted ... Hello !Welcome to AirVPN.Did you mean you tried the TAP drivers? It wasn't clear if you were referring to having downgraded these or tried the new ones - it doesn't look like you changed them. Do try to set all of your network adapters to "Obtain Automatically" - that includes the TAP adapter. Excellent first post you made; refreshing to see the logs in spoilers lol. Quote Hide LZ1's signature Hide all signatures Hi there, are you new to AirVPN? Many of your questions are already answered in this guide. You may also read the Eddie Android FAQ. Moderators do not speak on behalf of AirVPN. Only the Official Staff account does. Please also do not run Tor Exit Servers behind AirVPN, thank you. Did you make a guide or how-to for something? Then contact me to get it listed in my new user guide's Guides Section, so that the community can find it more easily. Share this post Link to post
Tech Jedi Alex 1500 Posted ... First, let me welcome you to AirVPN. Your first connection was successful, from the looks of it. Then you disconnected manually, after that every connection failed because it couldn't enable DHCP on Ethernet 2. You could try running AirVPN as admin.There's an experimental version of the AirVPN client with updated software versions, you could try this one. I linked to the installer package. Before installing, uninstall AirVPN, OpenVPN and the TAP driver and reboot once. Quote Hide Tech Jedi Alex's signature Hide all signatures NOT AN AIRVPN TEAM MEMBER. USE TICKETS FOR PROFESSIONAL SUPPORT. LZ1's New User Guide to AirVPN « Plenty of stuff for advanced users, too! Want to contact me directly? All relevant methods are on my About me page. Share this post Link to post
