33781782 1 Posted ... Wondering if there'd be any leaks if I used them both? Or is it just added security overall? Thanks. Quote Share this post Link to post
Guest Posted ... the possibility for leaks is there if you use both yeah since the network lock does NOT work with Tor Quote Share this post Link to post
LZ1 676 Posted ... Hello !AirVPN lets you use the VPN with Tor, which has a number of security advantages, yes. You could say there's always a risk of a leak; it depends on the operator and the setup. But depending on what you're trying to accomplish, there's different answers. But this is quite a good one if you're really looking for security. You can also check ipleak.net often. Quote Hide LZ1's signature Hide all signatures Hi there, are you new to AirVPN? Many of your questions are already answered in this guide. You may also read the Eddie Android FAQ. Moderators do not speak on behalf of AirVPN. Only the Official Staff account does. Please also do not run Tor Exit Servers behind AirVPN, thank you. Did you make a guide or how-to for something? Then contact me to get it listed in my new user guide's Guides Section, so that the community can find it more easily. Share this post Link to post
lordbeau 8 Posted ... the possibility for leaks is there if you use both yeah since the network lock does NOT work with Tor Really? Launch airVPN, then launch Tor, and is network lock not still running if Tor disconnects? Are you saying that Tor will carry on running? Do explain. Quote Share this post Link to post
lordbeau 8 Posted ... Sorry, I mean if Air disconnects while Tor is running. Quote Share this post Link to post
Staff 10307 Posted ... Hello, with "OpenVPN over Tor" Network Lock can not work because it should know in advance the Tor guard IP address before the circuit is created, which is of course not possible. With "Tor over OpenVPN" Network Lock works fine as usual. "OpenVPN over Tor" is the connection method you can see in the first picture and paragraph here: https://airvpn.org/tor Kind regards Quote Share this post Link to post
