Very slow connection without any reason
Suddenly I starded have verry slow connection. When i turn off AirVpn everything get normal and I have normal (fast) Internet. This issue is connected with any application (Firefox, P2P etc.).
Hello !
Do you mind posting your logs and which server you're connected to?
Thanks.
Alrami , Sweden
I
2016.07.10 21:59:26 - AirVPN client version: 2.10.3 / x64, System: Windows, Name: Microsoft Windows NT 6.2.9200.0 / x64
. 2016.07.10 21:59:26 - Reading options from C:\Users\usernname\AppData\Local\AirVPN\AirVPN.xml
. 2016.07.10 21:59:26 - Data Path: C:\Users\usernname\AppData\Local\AirVPN
. 2016.07.10 21:59:26 - App Path: C:\Program Files\AirVPN
. 2016.07.10 21:59:26 - Executable Path: C:\Program Files\AirVPN\AirVPN.exe
. 2016.07.10 21:59:26 - Command line arguments (1): path="home"
. 2016.07.10 21:59:26 - Operating System: Microsoft Windows NT 6.2.9200.0
. 2016.07.10 21:59:26 - Updating systems & servers data ...
I 2016.07.10 21:59:27 - OpenVPN Driver - TAP-Windows Adapter V9, version 9.21.1
I 2016.07.10 21:59:27 - OpenVPN - Version: OpenVPN 2.3.8 (C:\Program Files\AirVPN\openvpn.exe)
I 2016.07.10 21:59:27 - SSH - Version: plink 0.63 (C:\Program Files\AirVPN\plink.exe)
I 2016.07.10 21:59:27 - SSL - Version: stunnel 5.17 (C:\Program Files\AirVPN\stunnel.exe)
! 2016.07.10 21:59:27 - Activation of Network Lock - Windows Firewall
. 2016.07.10 21:59:27 - Systems & servers data update completed
I 2016.07.10 21:59:31 - Session starting.
I 2016.07.10 21:59:32 - Network adapter DHCP switched to static (Qualcomm Atheros AR9485WB-EG Wireless Network Adapter)
I 2016.07.10 21:59:35 - Checking authorization ...
W 2016.07.10 21:59:35 - Authorization check failed, continue anyway ({1])
! 2016.07.10 21:59:35 - Connecting to Alrami (Sweden, Uppsala)
. 2016.07.10 21:59:35 - OpenVPN > OpenVPN 2.3.8 x86_64-w64-mingw32 [SSL (OpenSSL)] [LZO] [IPv6] built on Aug 13 2015
. 2016.07.10 21:59:35 - OpenVPN > library versions: OpenSSL 1.0.2d 9 Jul 2015, LZO 2.08
. 2016.07.10 21:59:35 - OpenVPN > MANAGEMENT: TCP Socket listening on [AF_INET]127.0.0.1:3100
. 2016.07.10 21:59:36 - OpenVPN > Control Channel Authentication: tls-auth using INLINE static key file
. 2016.07.10 21:59:36 - OpenVPN > Outgoing Control Channel Authentication: Using 160 bit message hash 'SHA1' for HMAC authentication
. 2016.07.10 21:59:36 - OpenVPN > Incoming Control Channel Authentication: Using 160 bit message hash 'SHA1' for HMAC authentication
. 2016.07.10 21:59:36 - OpenVPN > Socket Buffers: R=[65536->131072] S=[65536->131072]
. 2016.07.10 21:59:36 - OpenVPN > UDPv4 link local: [undef]
. 2016.07.10 21:59:36 - OpenVPN > UDPv4 link remote: [AF_INET]62.102.148.145:443
. 2016.07.10 21:59:38 - OpenVPN > TLS: Initial packet from [AF_INET]62.102.148.145:443, sid=a1da594d 8058cd5d
. 2016.07.10 21:59:38 - OpenVPN > VERIFY OK: depth=1, C=IT, ST=IT, L=Perugia, O=airvpn.org, CN=airvpn.org CA, emailAddress=info@airvpn.org
. 2016.07.10 21:59:38 - OpenVPN > Validating certificate key usage
. 2016.07.10 21:59:38 - OpenVPN > ++ Certificate has key usage  00a0, expects 00a0
. 2016.07.10 21:59:38 - OpenVPN > VERIFY KU OK
. 2016.07.10 21:59:38 - OpenVPN > Validating certificate extended key usage
. 2016.07.10 21:59:38 - OpenVPN > ++ Certificate has EKU (str) TLS Web Server Authentication, expects TLS Web Server Authentication
. 2016.07.10 21:59:38 - OpenVPN > VERIFY EKU OK
. 2016.07.10 21:59:38 - OpenVPN > VERIFY OK: depth=0, C=IT, ST=IT, L=Perugia, O=airvpn.org, CN=server, emailAddress=info@airvpn.org
. 2016.07.10 21:59:39 - OpenVPN > Data Channel Encrypt: Cipher 'AES-256-CBC' initialized with 256 bit key
. 2016.07.10 21:59:39 - OpenVPN > Data Channel Encrypt: Using 160 bit message hash 'SHA1' for HMAC authentication
. 2016.07.10 21:59:39 - OpenVPN > Data Channel Decrypt: Cipher 'AES-256-CBC' initialized with 256 bit key
. 2016.07.10 21:59:39 - OpenVPN > Data Channel Decrypt: Using 160 bit message hash 'SHA1' for HMAC authentication
. 2016.07.10 21:59:39 - OpenVPN > Control Channel: TLSv1.2, cipher TLSv1/SSLv3 DHE-RSA-AES256-GCM-SHA384, 4096 bit RSA
. 2016.07.10 21:59:39 - OpenVPN > [server] Peer Connection Initiated with [AF_INET]62.102.148.145:443
. 2016.07.10 21:59:41 - OpenVPN > SENT CONTROL [server]: 'PUSH_REQUEST' (status=1)
. 2016.07.10 21:59:41 - OpenVPN > PUSH: Received control message: 'PUSH_REPLY,redirect-gateway def1 bypass-dhcp,dhcp-option DNS 10.4.0.1,comp-lzo no,route-gateway 10.4.0.1,topology subnet,ping 10,ping-restart 60,ifconfig 10.4.17.227 255.255.0.0'
. 2016.07.10 21:59:41 - OpenVPN > OPTIONS IMPORT: timers and/or timeouts modified
. 2016.07.10 21:59:41 - OpenVPN > OPTIONS IMPORT: LZO parms modified
. 2016.07.10 21:59:41 - OpenVPN > OPTIONS IMPORT: --ifconfig/up options modified
. 2016.07.10 21:59:41 - OpenVPN > OPTIONS IMPORT: route options modified
. 2016.07.10 21:59:41 - OpenVPN > OPTIONS IMPORT: route-related options modified
. 2016.07.10 21:59:41 - OpenVPN > OPTIONS IMPORT: --ip-win32 and/or --dhcp-option options modified
. 2016.07.10 21:59:41 - OpenVPN > do_ifconfig, tt->ipv6=0, tt->did_ifconfig_ipv6_setup=0
. 2016.07.10 21:59:41 - OpenVPN > open_tun, tt->ipv6=0
. 2016.07.10 21:59:42 - OpenVPN > TAP-WIN32 device [Ethernet 3] opened: \\.\Global\{FF0E0776-C4CD-41C4-9989-04A4ADDB4BC9}.tap
. 2016.07.10 21:59:42 - OpenVPN > TAP-Windows Driver Version 9.21
. 2016.07.10 21:59:42 - OpenVPN > Set TAP-Windows TUN subnet mode network/local/netmask = 10.4.0.0/10.4.17.227/255.255.0.0 [SUCCEEDED]
. 2016.07.10 21:59:42 - OpenVPN > Notified TAP-Windows driver to set a DHCP IP/netmask of 10.4.17.227/255.255.0.0 on interface {FF0E0776-C4CD-41C4-9989-04A4ADDB4BC9} [DHCP-serv: 10.4.255.254, lease-time: 31536000]
. 2016.07.10 21:59:42 - OpenVPN > Successful ARP Flush on interface [19] {FF0E0776-C4CD-41C4-9989-04A4ADDB4BC9}
. 2016.07.10 21:59:47 - OpenVPN > TEST ROUTES: 1/1 succeeded len=0 ret=1 a=0 u/d=up
. 2016.07.10 21:59:47 - OpenVPN > C:\WINDOWS\system32\route.exe ADD 62.102.148.145 MASK 255.255.255.255 192.168.0.1
. 2016.07.10 21:59:47 - OpenVPN > ROUTE: CreateIpForwardEntry succeeded with dwForwardMetric1=25 and dwForwardType=4
. 2016.07.10 21:59:47 - OpenVPN > Route addition via IPAPI succeeded [adaptive]
. 2016.07.10 21:59:47 - OpenVPN > C:\WINDOWS\system32\route.exe ADD 0.0.0.0 MASK 128.0.0.0 10.4.0.1
. 2016.07.10 21:59:47 - OpenVPN > ROUTE: CreateIpForwardEntry succeeded with dwForwardMetric1=20 and dwForwardType=4
. 2016.07.10 21:59:47 - OpenVPN > C:\WINDOWS\system32\route.exe ADD 128.0.0.0 MASK 128.0.0.0 10.4.0.1
. 2016.07.10 21:59:47 - Starting Management Interface
. 2016.07.10 21:59:47 - OpenVPN > Initialization Sequence Completed
I 2016.07.10 21:59:47 - DNS of a network adapter forced (Qualcomm Atheros AR9485WB-EG Wireless Network Adapter)
I 2016.07.10 21:59:47 - DNS of a network adapter forced (TAP-Windows Adapter V9)
I 2016.07.10 21:59:47 - Flushing DNS
I 2016.07.10 21:59:47 - Checking route
I 2016.07.10 21:59:48 - Checking DNS
! 2016.07.10 21:59:48 - Connected.
. 2016.07.10 21:59:48 - OpenVPN > MANAGEMENT: Client connected from [AF_INET]127.0.0.1:3100
. 2016.07.10 21:59:48 - OpenVpn Management > >INFO:OpenVPN Management Interface Version 1 -- type 'help' for more info
. 2016.07.10 22:05:24 - OpenVPN > Authenticate/Decrypt packet error: bad packet ID (may be a replay): [ #288364 ] -- see the man page entry for --no-replay and --replay-window for more info or silence this warning with --mute-replay-warnings
. 2016.07.10 22:05:25 - OpenVPN > Authenticate/Decrypt packet error: bad packet ID (may be a replay): [ #289460 ] -- see the man page entry for --no-replay and --replay-window for more info or silence this warning with --mute-replay-warnings
. 2016.07.10 22:05:25 - OpenVPN > Authenticate/Decrypt packet error: bad packet ID (may be a replay): [ #289467 ] -- see the man page entry for --no-replay and --replay-window for more info or silence this warning with --mute-replay-warnings
. 2016.07.10 22:05:25 - OpenVPN > Authenticate/Decrypt packet error: bad packet ID (may be a replay): [ #289468 ] -- see the man page entry for --no-replay and --replay-window for more info or silence this warning with --mute-replay-warnings
. 2016.07.10 22:05:25 - OpenVPN > Authenticate/Decrypt packet error: bad packet ID (may be a replay): [ #289469 ] -- see the man page entry for --no-replay and --replay-window for more info or silence this warning with --mute-replay-warnings
. 2016.07.10 22:08:04 - OpenVPN > Authenticate/Decrypt packet error: bad packet ID (may be a replay): [ #466519 ] -- see the man page entry for --no-replay and --replay-window for more info or silence this warning with --mute-replay-warnings
. 2016.07.10 22:08:04 - OpenVPN > Authenticate/Decrypt packet error: bad packet ID (may be a replay): [ #466523 ] -- see the man page entry for --no-replay and --replay-window for more info or silence this warning with --mute-replay-warnings
. 2016.07.10 22:08:44 - OpenVPN > Authenticate/Decrypt packet error: bad packet ID (may be a replay): [ #518212 ] -- see the man page entry for --no-replay and --replay-window for more info or silence this warning with --mute-replay-warnings
. 2016.07.10 22:08:44 - OpenVPN > Authenticate/Decrypt packet error: bad packet ID (may be a replay): [ #518213 ] -- see the man page entry for --no-replay and --replay-window for more info or silence this warning with --mute-replay-warnings
. 2016.07.10 22:08:44 - OpenVPN > Authenticate/Decrypt packet error: bad packet ID (may be a replay): [ #518214 ] -- see the man page entry for --no-replay and --replay-window for more info or silence this warning with --mute-replay-warnings
. 2016.07.10 22:08:44 - OpenVPN > Authenticate/Decrypt packet error: bad packet ID (may be a replay): [ #518219 ] -- see the man page entry for --no-replay and --replay-window for more info or silence this warning with --mute-replay-warnings
. 2016.07.10 22:08:44 - OpenVPN > Authenticate/Decrypt packet error: bad packet ID (may be a replay): [ #518222 ] -- see the man page entry for --no-replay and --replay-window for more info or silence this warning with --mute-replay-warnings
. 2016.07.10 22:08:44 - OpenVPN > Authenticate/Decrypt packet error: bad packet ID (may be a replay): [ #518223 ] -- see the man page entry for --no-replay and --replay-window for more info or silence this warning with --mute-replay-warnings
. 2016.07.10 22:08:44 - OpenVPN > Authenticate/Decrypt packet error: bad packet ID (may be a replay): [ #518224 ] -- see the man page entry for --no-replay and --replay-window for more info or silence this warning with --mute-replay-warnings
. 2016.07.10 22:08:44 - OpenVPN > Authenticate/Decrypt packet error: bad packet ID (may be a replay): [ #518225 ] -- see the man page entry for --no-replay and --replay-window for more info or silence this warning with --mute-replay-warnings
. 2016.07.10 22:08:44 - OpenVPN > Authenticate/Decrypt packet error: bad packet ID (may be a replay): [ #518226 ] -- see the man page entry for --no-replay and --replay-window for more info or silence this warning with --mute-replay-warnings
. 2016.07.10 22:08:44 - OpenVPN > Authenticate/Decrypt packet error: bad packet ID (may be a replay): [ #518229 ] -- see the man page entry for --no-replay and --replay-window for more info or silence this warning with --mute-replay-warnings
. 2016.07.10 22:09:19 - OpenVPN > Authenticate/Decrypt packet error: bad packet ID (may be a replay): [ #577301 ] -- see the man page entry for --no-replay and --replay-window for more info or silence this warning with --mute-replay-warnings
. 2016.07.10 22:09:19 - OpenVPN > Authenticate/Decrypt packet error: bad packet ID (may be a replay): [ #577302 ] -- see the man page entry for --no-replay and --replay-window for more info or silence this warning with --mute-replay-warnings
. 2016.07.10 22:09:19 - OpenVPN > Authenticate/Decrypt packet error: bad packet ID (may be a replay): [ #577305 ] -- see the man page entry for --no-replay and --replay-window for more info or silence this warning with --mute-replay-warnings
. 2016.07.10 22:09:19 - OpenVPN > Authenticate/Decrypt packet error: bad packet ID (may be a replay): [ #577306 ] -- see the man page entry for --no-replay and --replay-window for more info or silence this warning with --mute-replay-warnings
. 2016.07.10 22:09:19 - OpenVPN > Authenticate/Decrypt packet error: bad packet ID (may be a replay): [ #577307 ] -- see the man page entry for --no-replay and --replay-window for more info or silence this warning with --mute-replay-warnings
. 2016.07.10 22:09:19 - OpenVPN > Authenticate/Decrypt packet error: bad packet ID (may be a replay): [ #577308 ] -- see the man page entry for --no-replay and --replay-window for more info or silence this warning with --mute-replay-warnings
. 2016.07.10 22:09:19 - OpenVPN > Authenticate/Decrypt packet error: bad packet ID (may be a replay): [ #577309 ] -- see the man page entry for --no-replay and --replay-window for more info or silence this warning with --mute-replay-warnings
. 2016.07.10 22:09:19 - OpenVPN > Authenticate/Decrypt packet error: bad packet ID (may be a replay): [ #577310 ] -- see the man page entry for --no-replay and --replay-window for more info or silence this warning with --mute-replay-warnings
. 2016.07.10 22:09:19 - OpenVPN > Authenticate/Decrypt packet error: bad packet ID (may be a replay): [ #577311 ] -- see the man page entry for --no-replay and --replay-window for more info or silence this warning with --mute-replay-warnings
. 2016.07.10 22:09:19 - OpenVPN > Authenticate/Decrypt packet error: bad packet ID (may be a replay): [ #577312 ] -- see the man page entry for --no-replay and --replay-window for more info or silence this warning with --mute-replay-warnings
. 2016.07.10 22:09:19 - OpenVPN > Authenticate/Decrypt packet error: bad packet ID (may be a replay): [ #577313 ] -- see the man page entry for --no-replay and --replay-window for more info or silence this warning with --mute-replay-warnings
. 2016.07.10 22:09:19 - OpenVPN > Authenticate/Decrypt packet error: bad packet ID (may be a replay): [ #577314 ] -- see the man page entry for --no-replay and --replay-window for more info or silence this warning with --mute-replay-warnings
. 2016.07.10 22:09:39 - OpenVPN > Authenticate/Decrypt packet error: bad packet ID (may be a replay): [ #611115 ] -- see the man page entry for --no-replay and --replay-window for more info or silence this warning with --mute-replay-warnings
. 2016.07.10 22:09:39 - OpenVPN > Authenticate/Decrypt packet error: bad packet ID (may be a replay): [ #611116 ] -- see the man page entry for --no-replay and --replay-window for more info or silence this warning with --mute-replay-warnings
. 2016.07.10 22:09:39 - OpenVPN > Authenticate/Decrypt packet error: bad packet ID (may be a replay): [ #611117 ] -- see the man page entry for --no-replay and --replay-window for more info or silence this warning with --mute-replay-warnings
. 2016.07.10 22:09:39 - OpenVPN > Authenticate/Decrypt packet error: bad packet ID (may be a replay): [ #611118 ] -- see the man page entry for --no-replay and --replay-window for more info or silence this warning with --mute-replay-warnings
. 2016.07.10 22:09:39 - OpenVPN > Authenticate/Decrypt packet error: bad packet ID (may be a replay): [ #611119 ] -- see the man page entry for --no-replay and --replay-window for more info or silence this warning with --mute-replay-warnings
. 2016.07.10 22:09:39 - OpenVPN > Authenticate/Decrypt packet error: bad packet ID (may be a replay): [ #611120 ] -- see the man page entry for --no-replay and --replay-window for more info or silence this warning with --mute-replay-warnings
. 2016.07.10 22:09:47 - OpenVPN > Authenticate/Decrypt packet error: bad packet ID (may be a replay): [ #625016 ] -- see the man page entry for --no-replay and --replay-window for more info or silence this warning with --mute-replay-warnings
. 2016.07.10 22:09:47 - OpenVPN > Authenticate/Decrypt packet error: bad packet ID (may be a replay): [ #625017 ] -- see the man page entry for --no-replay and --replay-window for more info or silence this warning with --mute-replay-warnings
. 2016.07.10 22:09:47 - OpenVPN > Authenticate/Decrypt packet error: bad packet ID (may be a replay): [ #625018 ] -- see the man page entry for --no-replay and --replay-window for more info or silence this warning with --mute-replay-warnings
. 2016.07.10 22:11:28 - OpenVPN > Authenticate/Decrypt packet error: bad packet ID (may be a replay): [ #760611 ] -- see the man page entry for --no-replay and --replay-window for more info or silence this warning with --mute-replay-warnings
. 2016.07.10 22:11:28 - OpenVPN > Authenticate/Decrypt packet error: bad packet ID (may be a replay): [ #760612 ] -- see the man page entry for --no-replay and --replay-window for more info or silence this warning with --mute-replay-warnings
. 2016.07.10 22:11:28 - OpenVPN > Authenticate/Decrypt packet error: bad packet ID (may be a replay): [ #760613 ] -- see the man page entry for --no-replay and --replay-window for more info or silence this warning with --mute-replay-warnings
. 2016.07.10 22:12:03 - OpenVPN > Authenticate/Decrypt packet error: bad packet ID (may be a replay): [ #811909 ] -- see the man page entry for --no-replay and --replay-window for more info or silence this warning with --mute-replay-warnings
. 2016.07.10 22:12:03 - OpenVPN > Authenticate/Decrypt packet error: bad packet ID (may be a replay): [ #811910 ] -- see the man page entry for --no-replay and --replay-window for more info or silence this warning with --mute-replay-warnings
. 2016.07.10 22:12:03 - OpenVPN > Authenticate/Decrypt packet error: bad packet ID (may be a replay): [ #811911 ] -- see the man page entry for --no-replay and --replay-window for more info or silence this warning with --mute-replay-warnings
Hello !
Thanks.
Looks like I should see if I can enlarge my signature even more. The red warning color isn't cutting it, damn
You've got TAP driver 9.21. Try a downgrade. There's a stickied thread in the forum.
If you've been using network lock, you can also try resetting quitting the program and disabling network lock and then resetting windows firewall. Before then re-applying the lock.
Are you trying to use SSH/SSL?
Unfortunetly my AIRVpn does not want to older version of driver - photo . (I have cheek in option "disable driver upgrade").
Unfortunetly my AIRVpn does not want to older version of driver - photo attachicon.gifBez tytułu.jpg. (I have cheek in option "disable driver upgrade").
Try to install the Tap driver manually
