Hello
Just got Airvpn and I'm having some problems I hope I could get help with. I looked in the getting started guide and set the DNS and IP address to get obtained autmatically, DNS wasn't set to that, Still same issues. Speed test on the website shows me some nice 15mbs but on the AirVPN the downloads fluctuate from 0 b/s to 700 kb/s and keeps dropping to 0.
Hello !
Welcome to AirVPN.
Did you change it to automatic on all relevant network adapters and not just one of them? I'm assuming you're running windows. If you're getting disconnects, then feel free to post your logs
On some occassions it can also help to download the TCP version of the configuration files, in the Config Generator, rather than the UDP version. At the bottom.
Hello !
Welcome to AirVPN.
I'm stupid. i was looking at the speeds on the main tab but that shows speed that are currently un use, hence not DL anything it was fluctuating. Lol.
It's okay to make mistakes.
