arran777
need help with port fowarding
need to foward port 16000 to play at voobly.com   but it says Port 16000 already reserved by another user.   So does this mean I can't foward port 16000 on air vpn?
Hello !
As a translation of what zhang said, put the number you wish to forward, into the "local port" field in the port-forwarding area. Then just click the add button; unless you know TCP or UDP specifically is needed. Then a number will automatically be generated in the biggest box at the top .
