RedSoxWin2013
Can't connect when network lock is activated
I am using Windows 7 x64 and Eddie doesn't connect when the network lock is enabled. Also when using SSL and the network lock is enabled, stunnel crashes. Here are my logs from Eddie:
I 2016.06.25 13:04:29 - Session starting.
I 2016.06.25 13:04:29 - IPv6 disabled.
I 2016.06.25 13:04:29 - Checking authorization ...
! 2016.06.25 13:04:30 - Connecting to Arkab (Canada, Toronto, Ontario)
. 2016.06.25 13:04:30 - OpenVPN > OpenVPN 2.3.8 x86_64-w64-mingw32 [sSL (OpenSSL)] [LZO] [iPv6] built on Aug 13 2015
. 2016.06.25 13:04:30 - OpenVPN > library versions: OpenSSL 1.0.2d 9 Jul 2015, LZO 2.08
. 2016.06.25 13:04:30 - OpenVPN > MANAGEMENT: TCP Socket listening on [AF_INET]127.0.0.1:3100
. 2016.06.25 13:04:30 - OpenVPN > Control Channel Authentication: tls-auth using INLINE static key file
. 2016.06.25 13:04:30 - OpenVPN > Outgoing Control Channel Authentication: Using 160 bit message hash 'SHA1' for HMAC authentication
. 2016.06.25 13:04:30 - OpenVPN > Incoming Control Channel Authentication: Using 160 bit message hash 'SHA1' for HMAC authentication
. 2016.06.25 13:04:30 - OpenVPN > Socket Buffers: R=[8192->131072] S=[8192->131072]
. 2016.06.25 13:04:30 - OpenVPN > UDPv4 link local: [undef]
. 2016.06.25 13:04:30 - OpenVPN > UDPv4 link remote: [AF_INET]184.75.221.212:2018
. 2016.06.25 13:04:30 - OpenVPN > TLS: Initial packet from [AF_INET]184.75.221.212:2018, sid=29d3e3ac 3cea8fb2
. 2016.06.25 13:04:30 - OpenVPN > VERIFY OK: depth=1, C=IT, ST=IT, L=Perugia, O=airvpn.org, CN=airvpn.org CA, emailAddress=info@airvpn.org
. 2016.06.25 13:04:30 - OpenVPN > Validating certificate key usage
. 2016.06.25 13:04:30 - OpenVPN > ++ Certificate has key usage 00a0, expects 00a0
. 2016.06.25 13:04:30 - OpenVPN > VERIFY KU OK
. 2016.06.25 13:04:30 - OpenVPN > Validating certificate extended key usage
. 2016.06.25 13:04:30 - OpenVPN > ++ Certificate has EKU (str) TLS Web Server Authentication, expects TLS Web Server Authentication
. 2016.06.25 13:04:30 - OpenVPN > VERIFY EKU OK
. 2016.06.25 13:04:30 - OpenVPN > VERIFY OK: depth=0, C=IT, ST=IT, L=Perugia, O=airvpn.org, CN=server, emailAddress=info@airvpn.org
. 2016.06.25 13:04:31 - OpenVPN > Data Channel Encrypt: Cipher 'AES-256-CBC' initialized with 256 bit key
. 2016.06.25 13:04:31 - OpenVPN > Data Channel Encrypt: Using 160 bit message hash 'SHA1' for HMAC authentication
. 2016.06.25 13:04:31 - OpenVPN > Data Channel Decrypt: Cipher 'AES-256-CBC' initialized with 256 bit key
. 2016.06.25 13:04:31 - OpenVPN > Data Channel Decrypt: Using 160 bit message hash 'SHA1' for HMAC authentication
. 2016.06.25 13:04:31 - OpenVPN > Control Channel: TLSv1.2, cipher TLSv1/SSLv3 DHE-RSA-AES256-GCM-SHA384, 4096 bit RSA
. 2016.06.25 13:04:31 - OpenVPN > [server] Peer Connection Initiated with [AF_INET]184.75.221.212:2018
. 2016.06.25 13:04:33 - OpenVPN > SENT CONTROL [server]: 'PUSH_REQUEST' (status=1)
. 2016.06.25 13:04:33 - OpenVPN > PUSH: Received control message: 'PUSH_REPLY,redirect-gateway def1 bypass-dhcp,dhcp-option DNS 10.30.0.1,comp-lzo no,route-gateway 10.30.0.1,topology subnet,ping 10,ping-restart 60,ifconfig 10.30.0.55 255.255.0.0'
. 2016.06.25 13:04:33 - OpenVPN > OPTIONS IMPORT: timers and/or timeouts modified
. 2016.06.25 13:04:33 - OpenVPN > OPTIONS IMPORT: LZO parms modified
. 2016.06.25 13:04:33 - OpenVPN > OPTIONS IMPORT: --ifconfig/up options modified
. 2016.06.25 13:04:33 - OpenVPN > OPTIONS IMPORT: route options modified
. 2016.06.25 13:04:33 - OpenVPN > OPTIONS IMPORT: route-related options modified
. 2016.06.25 13:04:33 - OpenVPN > OPTIONS IMPORT: --ip-win32 and/or --dhcp-option options modified
. 2016.06.25 13:04:33 - OpenVPN > do_ifconfig, tt->ipv6=0, tt->did_ifconfig_ipv6_setup=0
. 2016.06.25 13:04:33 - OpenVPN > open_tun, tt->ipv6=0
. 2016.06.25 13:04:33 - OpenVPN > TAP-WIN32 device [Local Area Connection 2] opened: \\.\Global\{B0D6E88B-32A4-47D8-8FB3-708680F5FD76}.tap
. 2016.06.25 13:04:33 - OpenVPN > TAP-Windows Driver Version 9.21
. 2016.06.25 13:04:33 - OpenVPN > Set TAP-Windows TUN subnet mode network/local/netmask = 10.30.0.0/10.30.0.55/255.255.0.0 [sUCCEEDED]
. 2016.06.25 13:04:33 - OpenVPN > Notified TAP-Windows driver to set a DHCP IP/netmask of 10.30.0.55/255.255.0.0 on interface {B0D6E88B-32A4-47D8-8FB3-708680F5FD76} [DHCP-serv: 10.30.255.254, lease-time: 31536000]
. 2016.06.25 13:04:33 - OpenVPN > Successful ARP Flush on interface [17] {B0D6E88B-32A4-47D8-8FB3-708680F5FD76}
. 2016.06.25 13:04:38 - OpenVPN > TEST ROUTES: 1/1 succeeded len=0 ret=1 a=0 u/d=up
. 2016.06.25 13:04:38 - OpenVPN > C:\Windows\system32\route.exe ADD 184.75.221.212 MASK 255.255.255.255 192.168.16.1
. 2016.06.25 13:04:38 - OpenVPN > ROUTE: CreateIpForwardEntry succeeded with dwForwardMetric1=25 and dwForwardType=4
. 2016.06.25 13:04:38 - OpenVPN > Route addition via IPAPI succeeded [adaptive]
. 2016.06.25 13:04:38 - OpenVPN > C:\Windows\system32\route.exe ADD 192.168.16.1 MASK 255.255.255.255 192.168.16.1 IF 16
. 2016.06.25 13:04:38 - OpenVPN > ROUTE: route addition failed using CreateIpForwardEntry: The object already exists. [status=5010 if_index=16]
. 2016.06.25 13:04:38 - OpenVPN > Route addition via IPAPI failed [adaptive]
. 2016.06.25 13:04:38 - OpenVPN > Route addition fallback to route.exe
. 2016.06.25 13:04:38 - OpenVPN > env_block: add PATH=C:\Windows\System32;C:\WINDOWS;C:\WINDOWS\System32\Wbem
. 2016.06.25 13:04:38 - OpenVPN > C:\Windows\system32\route.exe ADD 0.0.0.0 MASK 128.0.0.0 10.30.0.1
. 2016.06.25 13:04:38 - OpenVPN > ROUTE: route addition failed using CreateIpForwardEntry: The object already exists. [status=5010 if_index=17]
. 2016.06.25 13:04:38 - OpenVPN > C:\Windows\system32\route.exe ADD 128.0.0.0 MASK 128.0.0.0 10.30.0.1
. 2016.06.25 13:04:38 - Starting Management Interface
W 2016.06.25 13:04:38 - An attempt was made to access a socket in a way forbidden by its access permissions 127.0.0.1:3100
. 2016.06.25 13:04:38 - OpenVPN > read UDPv4: Connection reset by peer (WSAECONNRESET) (code=10054)
! 2016.06.25 13:04:38 - Disconnecting
. 2016.06.25 13:04:38 - Connection terminated.
I 2016.06.25 13:04:39 - Cancel requested.
I 2016.06.25 13:04:39 - IPv6 restored.
! 2016.06.25 13:04:39 - Session terminated.
Hello !
You have TAP Driver 9.21. I recommend trying to downgrade
Also, please use spoiler tags for your logs.
Hello !
Still can't connect when lock is enabled. I uninstalled version 9.21 in the Device Manager and installed 9.9.1. Here are more logs after I attempted to connect with 9.9.1:
I 2016.06.25 17:28:53 - Session starting.
I 2016.06.25 17:28:53 - IPv6 disabled.
I 2016.06.25 17:28:53 - Checking authorization ...
! 2016.06.25 17:28:54 - Connecting to Sargas (Canada, Toronto, Ontario)
. 2016.06.25 17:28:54 - OpenVPN > OpenVPN 2.3.8 x86_64-w64-mingw32 [sSL (OpenSSL)] [LZO] [iPv6] built on Aug 13 2015
. 2016.06.25 17:28:54 - OpenVPN > library versions: OpenSSL 1.0.2d 9 Jul 2015, LZO 2.08
. 2016.06.25 17:28:54 - OpenVPN > MANAGEMENT: TCP Socket listening on [AF_INET]127.0.0.1:3100
. 2016.06.25 17:28:54 - OpenVPN > Control Channel Authentication: tls-auth using INLINE static key file
. 2016.06.25 17:28:54 - OpenVPN > Outgoing Control Channel Authentication: Using 160 bit message hash 'SHA1' for HMAC authentication
. 2016.06.25 17:28:54 - OpenVPN > Incoming Control Channel Authentication: Using 160 bit message hash 'SHA1' for HMAC authentication
. 2016.06.25 17:28:54 - OpenVPN > Socket Buffers: R=[8192->131072] S=[8192->131072]
. 2016.06.25 17:28:54 - OpenVPN > Attempting to establish TCP connection with [AF_INET]184.75.223.196:2018 [nonblock]
. 2016.06.25 17:28:55 - OpenVPN > TCP connection established with [AF_INET]184.75.223.196:2018
. 2016.06.25 17:28:55 - OpenVPN > TCPv4_CLIENT link local: [undef]
. 2016.06.25 17:28:55 - OpenVPN > TCPv4_CLIENT link remote: [AF_INET]184.75.223.196:2018
. 2016.06.25 17:28:55 - OpenVPN > TLS: Initial packet from [AF_INET]184.75.223.196:2018, sid=86f36e17 bf317eee
. 2016.06.25 17:28:55 - OpenVPN > VERIFY OK: depth=1, C=IT, ST=IT, L=Perugia, O=airvpn.org, CN=airvpn.org CA, emailAddress=info@airvpn.org
. 2016.06.25 17:28:55 - OpenVPN > Validating certificate key usage
. 2016.06.25 17:28:55 - OpenVPN > ++ Certificate has key usage 00a0, expects 00a0
. 2016.06.25 17:28:55 - OpenVPN > VERIFY KU OK
. 2016.06.25 17:28:55 - OpenVPN > Validating certificate extended key usage
. 2016.06.25 17:28:55 - OpenVPN > ++ Certificate has EKU (str) TLS Web Server Authentication, expects TLS Web Server Authentication
. 2016.06.25 17:28:55 - OpenVPN > VERIFY EKU OK
. 2016.06.25 17:28:55 - OpenVPN > VERIFY OK: depth=0, C=IT, ST=IT, L=Perugia, O=airvpn.org, CN=server, emailAddress=info@airvpn.org
. 2016.06.25 17:28:57 - OpenVPN > Data Channel Encrypt: Cipher 'AES-256-CBC' initialized with 256 bit key
. 2016.06.25 17:28:57 - OpenVPN > Data Channel Encrypt: Using 160 bit message hash 'SHA1' for HMAC authentication
. 2016.06.25 17:28:57 - OpenVPN > Data Channel Decrypt: Cipher 'AES-256-CBC' initialized with 256 bit key
. 2016.06.25 17:28:57 - OpenVPN > Data Channel Decrypt: Using 160 bit message hash 'SHA1' for HMAC authentication
. 2016.06.25 17:28:57 - OpenVPN > Control Channel: TLSv1.2, cipher TLSv1/SSLv3 DHE-RSA-AES256-GCM-SHA384, 4096 bit RSA
. 2016.06.25 17:28:57 - OpenVPN > [server] Peer Connection Initiated with [AF_INET]184.75.223.196:2018
. 2016.06.25 17:29:00 - OpenVPN > SENT CONTROL [server]: 'PUSH_REQUEST' (status=1)
. 2016.06.25 17:29:00 - OpenVPN > PUSH: Received control message: 'PUSH_REPLY,redirect-gateway def1 bypass-dhcp,dhcp-option DNS 10.50.0.1,comp-lzo no,route-gateway 10.50.0.1,topology subnet,ping 10,ping-restart 60,ifconfig 10.50.1.6 255.255.0.0'
. 2016.06.25 17:29:00 - OpenVPN > OPTIONS IMPORT: timers and/or timeouts modified
. 2016.06.25 17:29:00 - OpenVPN > OPTIONS IMPORT: LZO parms modified
. 2016.06.25 17:29:00 - OpenVPN > OPTIONS IMPORT: --ifconfig/up options modified
. 2016.06.25 17:29:00 - OpenVPN > OPTIONS IMPORT: route options modified
. 2016.06.25 17:29:00 - OpenVPN > OPTIONS IMPORT: route-related options modified
. 2016.06.25 17:29:00 - OpenVPN > OPTIONS IMPORT: --ip-win32 and/or --dhcp-option options modified
. 2016.06.25 17:29:00 - OpenVPN > do_ifconfig, tt->ipv6=0, tt->did_ifconfig_ipv6_setup=0
. 2016.06.25 17:29:00 - OpenVPN > open_tun, tt->ipv6=0
. 2016.06.25 17:29:00 - OpenVPN > TAP-WIN32 device [Local Area Connection 2] opened: \\.\Global\{53B25EB9-6978-494C-B799-3C246E2009B7}.tap
. 2016.06.25 17:29:00 - OpenVPN > TAP-Windows Driver Version 9.9
. 2016.06.25 17:29:00 - OpenVPN > Set TAP-Windows TUN subnet mode network/local/netmask = 10.50.0.0/10.50.1.6/255.255.0.0 [sUCCEEDED]
. 2016.06.25 17:29:00 - OpenVPN > Notified TAP-Windows driver to set a DHCP IP/netmask of 10.50.1.6/255.255.0.0 on interface {53B25EB9-6978-494C-B799-3C246E2009B7} [DHCP-serv: 10.50.255.254, lease-time: 31536000]
. 2016.06.25 17:29:00 - OpenVPN > Successful ARP Flush on interface [25] {53B25EB9-6978-494C-B799-3C246E2009B7}
. 2016.06.25 17:29:05 - OpenVPN > TEST ROUTES: 1/1 succeeded len=0 ret=1 a=0 u/d=up
. 2016.06.25 17:29:05 - OpenVPN > C:\Windows\system32\route.exe ADD 184.75.223.196 MASK 255.255.255.255 192.168.16.1
. 2016.06.25 17:29:05 - OpenVPN > ROUTE: route addition failed using CreateIpForwardEntry: The object already exists. [status=5010 if_index=16]
. 2016.06.25 17:29:05 - OpenVPN > Route addition via IPAPI failed [adaptive]
. 2016.06.25 17:29:05 - OpenVPN > Route addition fallback to route.exe
. 2016.06.25 17:29:05 - OpenVPN > env_block: add PATH=C:\Windows\System32;C:\WINDOWS;C:\WINDOWS\System32\Wbem
. 2016.06.25 17:29:05 - OpenVPN > C:\Windows\system32\route.exe ADD 192.168.16.1 MASK 255.255.255.255 192.168.16.1 IF 16
. 2016.06.25 17:29:05 - OpenVPN > C:\Windows\system32\route.exe ADD 0.0.0.0 MASK 128.0.0.0 10.50.0.1
. 2016.06.25 17:29:05 - OpenVPN > ROUTE: route addition failed using CreateIpForwardEntry: The object already exists. [status=5010 if_index=25]
. 2016.06.25 17:29:05 - OpenVPN > C:\Windows\system32\route.exe ADD 128.0.0.0 MASK 128.0.0.0 10.50.0.1
. 2016.06.25 17:29:05 - Starting Management Interface
W 2016.06.25 17:29:05 - An attempt was made to access a socket in a way forbidden by its access permissions 127.0.0.1:3100
! 2016.06.25 17:29:06 - Disconnecting
. 2016.06.25 17:29:06 - Connection terminated.
I 2016.06.25 17:29:08 - Cancel requested.
I 2016.06.25 17:29:08 - IPv6 restored.
! 2016.06.25 17:29:08 - Session terminated.
Looks more like a firewall configuration problem.
Are you using Windows firewall rules or the router's firewall?
I am using the default Windows firewall rules.
I can get Comodo Firewall to work but am only having problems with Windows firewall.
I have noticed the same 2 discrepancies in both logs:
1) AirVPN client can not force the change of the DNS servers for your router and Tap Adapter,
so no connection to a server;
2) same socket error referencing 127.x.x.1:31xx.
If AirVPN works with Comodo check the AirVPN client logs with the Comodo firewall working to find the difference with Windows firewall setup.
