quickoats
Network Lock when using AirVPN on router
I'm planning on installing the Merlin firmware on my RT-N66U router and importing an OpenVPN cert from AirVPN's generator. Normally when I run the client on my PC I always activate the network lock. Does anyone know if there is a way of ensuring only traffic through the VPN will be going out through my router much like using the network lock in the client?
Thanks in advance for any input.
I think that works with Merlin Firmware
"Another setting exposed when enabling Policy routing is to prevent your routed clients from accessing the Internet if the VPN tunnel goes down. To do so, enable "Block routed clients if tunnel goes down"."
On bottom
https://github.com/RMerl/asuswrt-merlin/wiki/Policy-based-routing
yep, do as dj77 said.
but I warn you, the N66 will be slow for openvpn.
Thanks a lot guys. I wasn't aware Merlin had that option. I'm prepared for a performance hit with my router, hopefully it's not too bad.
