Spaceghost
Keep disconnecting
So I have been using AirVPN for a few years now, I used to use the AirVPN client and that worked great but then once I upgraded to windows 10 it kept disconnecting me. I switched over to the OpenVPN client and that seemed to solve things, but in the last few days I started to disconnect again so I upgraded to the latest OpenVPN client but I am still having the same issues. Can anyone help me?
Hello !
Maybe you could try this: https://airvpn.org/topic/16052-latest-windows-10-build-breaks-openvpn-tap-driver/
Likewise, you can also take a look at this: https://airvpn.org/topic/16573-tap-driver-9210-causing-a-myriad-of-issues/
Alternatively, maybe you should try the TCP mode, if you were using the UDP mode, from the Config generator.
Feel free to add your logs too, in spoiler tags.
So I have tried TCP mode which didn't make any difference. I also tried uninstalling the latest TAP (and disabled auto update in AirVPN client), and installed 9.9.2.3, rebooted but then neither airvpn or openvpn wanted to even connect, so I went back to the latest version and I can connect again although it disconnects pretty quickly. Maybe I'll try again later, and post some logs.
Ok so I tried again: made sure eddie was closed, uninstalled TAP, rebooted, installed 9.9.1, and then tried Eddie again and it won't connect. Here are the logs:
I 2016.06.23 16:48:18 - AirVPN client version: 2.10.3 / x64, System: Windows, Name: Microsoft Windows NT 6.2.9200.0 / x64
. 2016.06.23 16:48:18 - Reading options from C:\Users\Ryan\AppData\Local\AirVPN\AirVPN.xml
. 2016.06.23 16:48:18 - Data Path: C:\Users\Ryan\AppData\Local\AirVPN
. 2016.06.23 16:48:18 - App Path: C:\Program Files\AirVPN
. 2016.06.23 16:48:18 - Executable Path: C:\Program Files\AirVPN\AirVPN.exe
. 2016.06.23 16:48:18 - Command line arguments (1): path="home"
. 2016.06.23 16:48:18 - Operating System: Microsoft Windows NT 6.2.9200.0
. 2016.06.23 16:48:18 - Updating systems & servers data ...
W 2016.06.23 16:48:19 - Tunnel driver will be upgraded, from 9.9.2 to 9.21.1.
. 2016.06.23 16:48:19 - Systems & servers data update completed
E 2016.06.23 16:48:19 - OpenVPN Driver - Not available
I 2016.06.23 16:48:19 - OpenVPN - Version: OpenVPN 2.3.8 (C:\Program Files\AirVPN\openvpn.exe)
I 2016.06.23 16:48:19 - SSH - Version: plink 0.63 (C:\Program Files\AirVPN\plink.exe)
I 2016.06.23 16:48:19 - SSL - Version: stunnel 5.17 (C:\Program Files\AirVPN\stunnel.exe)
! 2016.06.23 16:48:19 - Ready
W 2016.06.23 16:48:22 - Tunnel driver will be upgraded, from 9.9.2 to 9.21.1.
I 2016.06.23 16:48:40 - Session starting.
I 2016.06.23 16:48:40 - IPv6 disabled.
I 2016.06.23 16:48:40 - Checking authorization ...
! 2016.06.23 16:48:40 - Connecting to Rukbat (Netherlands, Alblasserdam)
. 2016.06.23 16:48:40 - OpenVPN > OpenVPN 2.3.8 x86_64-w64-mingw32 [sSL (OpenSSL)] [LZO] [iPv6] built on Aug 13 2015
. 2016.06.23 16:48:40 - OpenVPN > library versions: OpenSSL 1.0.2d 9 Jul 2015, LZO 2.08
. 2016.06.23 16:48:40 - OpenVPN > MANAGEMENT: TCP Socket listening on [AF_INET]127.0.0.1:3100
. 2016.06.23 16:48:40 - OpenVPN > Control Channel Authentication: tls-auth using INLINE static key file
. 2016.06.23 16:48:40 - OpenVPN > Outgoing Control Channel Authentication: Using 160 bit message hash 'SHA1' for HMAC authentication
. 2016.06.23 16:48:40 - OpenVPN > Incoming Control Channel Authentication: Using 160 bit message hash 'SHA1' for HMAC authentication
. 2016.06.23 16:48:40 - OpenVPN > Socket Buffers: R=[65536->131072] S=[65536->131072]
. 2016.06.23 16:48:40 - OpenVPN > UDPv4 link local: [undef]
. 2016.06.23 16:48:40 - OpenVPN > UDPv4 link remote: [AF_INET]213.152.162.83:443
. 2016.06.23 16:48:40 - OpenVPN > TLS: Initial packet from [AF_INET]213.152.162.83:443, sid=59f2008a 30d53c89
. 2016.06.23 16:48:40 - OpenVPN > VERIFY OK: depth=1, C=IT, ST=IT, L=Perugia, O=airvpn.org, CN=airvpn.org CA, emailAddress=info@airvpn.org
. 2016.06.23 16:48:40 - OpenVPN > Validating certificate key usage
. 2016.06.23 16:48:40 - OpenVPN > ++ Certificate has key usage  00a0, expects 00a0
. 2016.06.23 16:48:40 - OpenVPN > VERIFY KU OK
. 2016.06.23 16:48:40 - OpenVPN > Validating certificate extended key usage
. 2016.06.23 16:48:40 - OpenVPN > ++ Certificate has EKU (str) TLS Web Server Authentication, expects TLS Web Server Authentication
. 2016.06.23 16:48:40 - OpenVPN > VERIFY EKU OK
. 2016.06.23 16:48:40 - OpenVPN > VERIFY OK: depth=0, C=IT, ST=IT, L=Perugia, O=airvpn.org, CN=server, emailAddress=info@airvpn.org
. 2016.06.23 16:48:41 - OpenVPN > Data Channel Encrypt: Cipher 'AES-256-CBC' initialized with 256 bit key
. 2016.06.23 16:48:41 - OpenVPN > Data Channel Encrypt: Using 160 bit message hash 'SHA1' for HMAC authentication
. 2016.06.23 16:48:41 - OpenVPN > Data Channel Decrypt: Cipher 'AES-256-CBC' initialized with 256 bit key
. 2016.06.23 16:48:41 - OpenVPN > Data Channel Decrypt: Using 160 bit message hash 'SHA1' for HMAC authentication
. 2016.06.23 16:48:41 - OpenVPN > Control Channel: TLSv1.2, cipher TLSv1/SSLv3 DHE-RSA-AES256-GCM-SHA384, 4096 bit RSA
. 2016.06.23 16:48:41 - OpenVPN > [server] Peer Connection Initiated with [AF_INET]213.152.162.83:443
. 2016.06.23 16:48:43 - OpenVPN > SENT CONTROL [server]: 'PUSH_REQUEST' (status=1)
. 2016.06.23 16:48:43 - OpenVPN > PUSH: Received control message: 'PUSH_REPLY,redirect-gateway def1 bypass-dhcp,dhcp-option DNS 10.4.0.1,comp-lzo no,route-gateway 10.4.0.1,topology subnet,ping 10,ping-restart 60,ifconfig 10.4.34.209 255.255.0.0'
. 2016.06.23 16:48:43 - OpenVPN > OPTIONS IMPORT: timers and/or timeouts modified
. 2016.06.23 16:48:43 - OpenVPN > OPTIONS IMPORT: LZO parms modified
. 2016.06.23 16:48:43 - OpenVPN > OPTIONS IMPORT: --ifconfig/up options modified
. 2016.06.23 16:48:43 - OpenVPN > OPTIONS IMPORT: route options modified
. 2016.06.23 16:48:43 - OpenVPN > OPTIONS IMPORT: route-related options modified
. 2016.06.23 16:48:43 - OpenVPN > OPTIONS IMPORT: --ip-win32 and/or --dhcp-option options modified
. 2016.06.23 16:48:43 - OpenVPN > do_ifconfig, tt->ipv6=0, tt->did_ifconfig_ipv6_setup=0
. 2016.06.23 16:48:43 - OpenVPN > open_tun, tt->ipv6=0
. 2016.06.23 16:48:43 - OpenVPN > TAP-WIN32 device [Ethernet 2] opened: \\.\Global\{386BE721-5F16-40B3-8C70-482C62650CF1}.tap
. 2016.06.23 16:48:43 - OpenVPN > TAP-Windows Driver Version 9.9
. 2016.06.23 16:48:43 - OpenVPN > Set TAP-Windows TUN subnet mode network/local/netmask = 10.4.0.0/10.4.34.209/255.255.0.0 [sUCCEEDED]
. 2016.06.23 16:48:43 - OpenVPN > Notified TAP-Windows driver to set a DHCP IP/netmask of 10.4.34.209/255.255.0.0 on interface {386BE721-5F16-40B3-8C70-482C62650CF1} [DHCP-serv: 10.4.255.254, lease-time: 31536000]
. 2016.06.23 16:48:43 - OpenVPN > Successful ARP Flush on interface [31] {386BE721-5F16-40B3-8C70-482C62650CF1}
. 2016.06.23 16:48:48 - OpenVPN > TEST ROUTES: 1/1 succeeded len=0 ret=1 a=0 u/d=up
. 2016.06.23 16:48:48 - OpenVPN > C:\WINDOWS\system32\route.exe ADD 213.152.162.83 MASK 255.255.255.255 192.168.1.254
. 2016.06.23 16:48:48 - OpenVPN > ROUTE: CreateIpForwardEntry succeeded with dwForwardMetric1=25 and dwForwardType=4
. 2016.06.23 16:48:48 - OpenVPN > Route addition via IPAPI succeeded [adaptive]
. 2016.06.23 16:48:48 - OpenVPN > C:\WINDOWS\system32\route.exe ADD 192.168.1.254 MASK 255.255.255.255 192.168.1.254 IF 9
. 2016.06.23 16:48:48 - OpenVPN > C:\WINDOWS\system32\route.exe ADD 0.0.0.0 MASK 128.0.0.0 10.4.0.1
. 2016.06.23 16:48:48 - OpenVPN > ROUTE: CreateIpForwardEntry succeeded with dwForwardMetric1=30 and dwForwardType=4
. 2016.06.23 16:48:48 - OpenVPN > C:\WINDOWS\system32\route.exe ADD 128.0.0.0 MASK 128.0.0.0 10.4.0.1
. 2016.06.23 16:48:48 - Starting Management Interface
. 2016.06.23 16:48:48 - OpenVPN > Initialization Sequence Completed
I 2016.06.23 16:48:48 - DNS of a network adapter forced (TAP-Windows Adapter V9)
I 2016.06.23 16:48:48 - DNS of a network adapter forced (Edimax nLite Wireless USB Adapter)
I 2016.06.23 16:48:48 - Flushing DNS
I 2016.06.23 16:48:48 - Checking route
W 2016.06.23 16:48:48 - Unable to connect to the remote server
! 2016.06.23 16:48:48 - Disconnecting
. 2016.06.23 16:48:48 - Management - Send 'signal SIGTERM'
. 2016.06.23 16:48:48 - OpenVPN > MANAGEMENT: CMD 'signal SIGTERM'
. 2016.06.23 16:48:48 - OpenVPN > SIGTERM received, sending exit notification to peer
. 2016.06.23 16:48:48 - OpenVpn Management > >INFO:OpenVPN Management Interface Version 1 -- type 'help' for more info
. 2016.06.23 16:48:53 - OpenVPN > C:\WINDOWS\system32\route.exe DELETE 213.152.162.83 MASK 255.255.255.255 192.168.1.254
. 2016.06.23 16:48:53 - OpenVPN > Route deletion via IPAPI succeeded [adaptive]
. 2016.06.23 16:48:53 - OpenVPN > C:\WINDOWS\system32\route.exe DELETE 192.168.1.254 MASK 255.255.255.255 192.168.1.254
. 2016.06.23 16:48:53 - OpenVPN > C:\WINDOWS\system32\route.exe DELETE 0.0.0.0 MASK 128.0.0.0 10.4.0.1
. 2016.06.23 16:48:53 - OpenVPN > C:\WINDOWS\system32\route.exe DELETE 128.0.0.0 MASK 128.0.0.0 10.4.0.1
. 2016.06.23 16:48:53 - OpenVPN > Closing TUN/TAP interface
. 2016.06.23 16:48:53 - OpenVPN > SIGTERM[soft,exit-with-notification] received, process exiting
. 2016.06.23 16:48:53 - Connection terminated.
I 2016.06.23 16:48:53 - DNS of a network adapter restored to original settings (TAP-Windows Adapter V9)
I 2016.06.23 16:48:53 - DNS of a network adapter restored to original settings (Edimax nLite Wireless USB Adapter)
I 2016.06.23 16:48:56 - Checking authorization ...
! 2016.06.23 16:48:56 - Connecting to Rukbat (Netherlands, Alblasserdam)
. 2016.06.23 16:48:56 - OpenVPN > OpenVPN 2.3.8 x86_64-w64-mingw32 [sSL (OpenSSL)] [LZO] [iPv6] built on Aug 13 2015
. 2016.06.23 16:48:56 - OpenVPN > library versions: OpenSSL 1.0.2d 9 Jul 2015, LZO 2.08
. 2016.06.23 16:48:56 - OpenVPN > MANAGEMENT: TCP Socket listening on [AF_INET]127.0.0.1:3100
. 2016.06.23 16:48:56 - OpenVPN > Control Channel Authentication: tls-auth using INLINE static key file
. 2016.06.23 16:48:56 - OpenVPN > Outgoing Control Channel Authentication: Using 160 bit message hash 'SHA1' for HMAC authentication
. 2016.06.23 16:48:56 - OpenVPN > Incoming Control Channel Authentication: Using 160 bit message hash 'SHA1' for HMAC authentication
. 2016.06.23 16:48:56 - OpenVPN > Socket Buffers: R=[65536->131072] S=[65536->131072]
. 2016.06.23 16:48:56 - OpenVPN > UDPv4 link local: [undef]
. 2016.06.23 16:48:56 - OpenVPN > UDPv4 link remote: [AF_INET]213.152.162.83:443
. 2016.06.23 16:48:56 - OpenVPN > TLS: Initial packet from [AF_INET]213.152.162.83:443, sid=b60d2634 7bbb9b65
. 2016.06.23 16:48:56 - OpenVPN > VERIFY OK: depth=1, C=IT, ST=IT, L=Perugia, O=airvpn.org, CN=airvpn.org CA, emailAddress=info@airvpn.org
. 2016.06.23 16:48:56 - OpenVPN > Validating certificate key usage
. 2016.06.23 16:48:56 - OpenVPN > ++ Certificate has key usage  00a0, expects 00a0
. 2016.06.23 16:48:56 - OpenVPN > VERIFY KU OK
. 2016.06.23 16:48:56 - OpenVPN > Validating certificate extended key usage
. 2016.06.23 16:48:56 - OpenVPN > ++ Certificate has EKU (str) TLS Web Server Authentication, expects TLS Web Server Authentication
. 2016.06.23 16:48:56 - OpenVPN > VERIFY EKU OK
. 2016.06.23 16:48:56 - OpenVPN > VERIFY OK: depth=0, C=IT, ST=IT, L=Perugia, O=airvpn.org, CN=server, emailAddress=info@airvpn.org
. 2016.06.23 16:48:57 - OpenVPN > Data Channel Encrypt: Cipher 'AES-256-CBC' initialized with 256 bit key
. 2016.06.23 16:48:57 - OpenVPN > Data Channel Encrypt: Using 160 bit message hash 'SHA1' for HMAC authentication
. 2016.06.23 16:48:57 - OpenVPN > Data Channel Decrypt: Cipher 'AES-256-CBC' initialized with 256 bit key
. 2016.06.23 16:48:57 - OpenVPN > Data Channel Decrypt: Using 160 bit message hash 'SHA1' for HMAC authentication
. 2016.06.23 16:48:57 - OpenVPN > Control Channel: TLSv1.2, cipher TLSv1/SSLv3 DHE-RSA-AES256-GCM-SHA384, 4096 bit RSA
. 2016.06.23 16:48:57 - OpenVPN > [server] Peer Connection Initiated with [AF_INET]213.152.162.83:443
. 2016.06.23 16:49:00 - OpenVPN > SENT CONTROL [server]: 'PUSH_REQUEST' (status=1)
. 2016.06.23 16:49:00 - OpenVPN > PUSH: Received control message: 'PUSH_REPLY,redirect-gateway def1 bypass-dhcp,dhcp-option DNS 10.4.0.1,comp-lzo no,route-gateway 10.4.0.1,topology subnet,ping 10,ping-restart 60,ifconfig 10.4.34.209 255.255.0.0'
. 2016.06.23 16:49:00 - OpenVPN > OPTIONS IMPORT: timers and/or timeouts modified
. 2016.06.23 16:49:00 - OpenVPN > OPTIONS IMPORT: LZO parms modified
. 2016.06.23 16:49:00 - OpenVPN > OPTIONS IMPORT: --ifconfig/up options modified
. 2016.06.23 16:49:00 - OpenVPN > OPTIONS IMPORT: route options modified
. 2016.06.23 16:49:00 - OpenVPN > OPTIONS IMPORT: route-related options modified
. 2016.06.23 16:49:00 - OpenVPN > OPTIONS IMPORT: --ip-win32 and/or --dhcp-option options modified
. 2016.06.23 16:49:00 - OpenVPN > do_ifconfig, tt->ipv6=0, tt->did_ifconfig_ipv6_setup=0
. 2016.06.23 16:49:00 - OpenVPN > open_tun, tt->ipv6=0
. 2016.06.23 16:49:00 - OpenVPN > TAP-WIN32 device [Ethernet 2] opened: \\.\Global\{386BE721-5F16-40B3-8C70-482C62650CF1}.tap
. 2016.06.23 16:49:00 - OpenVPN > TAP-Windows Driver Version 9.9
. 2016.06.23 16:49:00 - OpenVPN > Set TAP-Windows TUN subnet mode network/local/netmask = 10.4.0.0/10.4.34.209/255.255.0.0 [sUCCEEDED]
. 2016.06.23 16:49:00 - OpenVPN > Notified TAP-Windows driver to set a DHCP IP/netmask of 10.4.34.209/255.255.0.0 on interface {386BE721-5F16-40B3-8C70-482C62650CF1} [DHCP-serv: 10.4.255.254, lease-time: 31536000]
. 2016.06.23 16:49:00 - OpenVPN > Successful ARP Flush on interface [31] {386BE721-5F16-40B3-8C70-482C62650CF1}
. 2016.06.23 16:49:05 - OpenVPN > TEST ROUTES: 1/1 succeeded len=0 ret=1 a=0 u/d=up
. 2016.06.23 16:49:05 - OpenVPN > C:\WINDOWS\system32\route.exe ADD 213.152.162.83 MASK 255.255.255.255 192.168.1.254
. 2016.06.23 16:49:05 - OpenVPN > ROUTE: CreateIpForwardEntry succeeded with dwForwardMetric1=25 and dwForwardType=4
. 2016.06.23 16:49:05 - OpenVPN > Route addition via IPAPI succeeded [adaptive]
. 2016.06.23 16:49:05 - OpenVPN > C:\WINDOWS\system32\route.exe ADD 192.168.1.254 MASK 255.255.255.255 192.168.1.254 IF 9
. 2016.06.23 16:49:05 - OpenVPN > C:\WINDOWS\system32\route.exe ADD 0.0.0.0 MASK 128.0.0.0 10.4.0.1
. 2016.06.23 16:49:05 - OpenVPN > ROUTE: CreateIpForwardEntry succeeded with dwForwardMetric1=30 and dwForwardType=4
. 2016.06.23 16:49:05 - OpenVPN > C:\WINDOWS\system32\route.exe ADD 128.0.0.0 MASK 128.0.0.0 10.4.0.1
. 2016.06.23 16:49:05 - Starting Management Interface
. 2016.06.23 16:49:05 - OpenVPN > Initialization Sequence Completed
I 2016.06.23 16:49:05 - DNS of a network adapter forced (TAP-Windows Adapter V9)
I 2016.06.23 16:49:06 - DNS of a network adapter forced (Edimax nLite Wireless USB Adapter)
I 2016.06.23 16:49:06 - Flushing DNS
I 2016.06.23 16:49:06 - Checking route
W 2016.06.23 16:49:06 - Unable to connect to the remote server
! 2016.06.23 16:49:06 - Disconnecting
. 2016.06.23 16:49:06 - Management - Send 'signal SIGTERM'
. 2016.06.23 16:49:06 - OpenVpn Management > >INFO:OpenVPN Management Interface Version 1 -- type 'help' for more info
. 2016.06.23 16:49:06 - OpenVPN > MANAGEMENT: CMD 'signal SIGTERM'
. 2016.06.23 16:49:06 - OpenVPN > SIGTERM received, sending exit notification to peer
. 2016.06.23 16:49:11 - OpenVPN > C:\WINDOWS\system32\route.exe DELETE 213.152.162.83 MASK 255.255.255.255 192.168.1.254
. 2016.06.23 16:49:11 - OpenVPN > Route deletion via IPAPI succeeded [adaptive]
. 2016.06.23 16:49:11 - OpenVPN > C:\WINDOWS\system32\route.exe DELETE 192.168.1.254 MASK 255.255.255.255 192.168.1.254
. 2016.06.23 16:49:11 - OpenVPN > C:\WINDOWS\system32\route.exe DELETE 0.0.0.0 MASK 128.0.0.0 10.4.0.1
. 2016.06.23 16:49:11 - OpenVPN > C:\WINDOWS\system32\route.exe DELETE 128.0.0.0 MASK 128.0.0.0 10.4.0.1
. 2016.06.23 16:49:11 - OpenVPN > Closing TUN/TAP interface
. 2016.06.23 16:49:11 - OpenVPN > SIGTERM[soft,exit-with-notification] received, process exiting
. 2016.06.23 16:49:11 - Connection terminated.
I 2016.06.23 16:49:11 - DNS of a network adapter restored to original settings (TAP-Windows Adapter V9)
I 2016.06.23 16:49:11 - DNS of a network adapter restored to original settings (Edimax nLite Wireless USB Adapter)
I 2016.06.23 16:49:13 - Cancel requested.
I 2016.06.23 16:49:13 - IPv6 restored.
! 2016.06.23 16:49:13 - Session terminated.
i have this problem too
it seems your windows fcuked by nLite
im try too (nlite , write , install , test) about 4 days
i dont found the reason or fix until now
