CL28
Transmission Synology over Airvpn
I'm having problems since the last update of DSM/transmission on my nas.
I've changed nothing on a working setup (worked a couple of months) but now i can't download (nothing happens).
Is someone else having this problem too?
I am on DSM version 6.0.1-7393 and using download station.
I just checked Download Station and it is working fine.
I have not tried Transmission.
Please share the following information:
What exact issue you are facing?
What is your current DSM  version number?
Have you tried the download on Download Station?
Which AirVPN server are connected to? Have you tried some other AirVPN servers also?
When was the last time it was working fine for you?
Have you checked the UDP port numbers are same as earlier in Transmission?
The issue is this: I updated DSM to the current version, and since the update i have a 50% chance transmission works.
I have not changed a thing to my settings (who worked 100% for months). Now i can have a period that transmission doesn't find any trackers, any peers or else. This situation stays for a day and then it works again for half a day. Nothing changed, nothing done, just suddenly it works again. This is going on for 2-3 days.
I have restarted the synology: no effect
i disabled my firewall: no effect
What is your current DSM  version number? DSM 6.0.1-7393
Have you tried the download on Download Station? No, but i can download with airvpn on the same server/same protocol/same port without issues on my home pc.
Which AirVPN server are connected to? Have you tried some other AirVPN servers also? Elnath alternative ip udp port 53 / no, i would be needing to switch my entire setup for that, and since it works on my home pc.
When was the last time it was working fine for you? It works at this moment, but i'm not sure about tomorrow.
Have you checked the UDP port numbers are same as earlier in Transmission? yes, still the same
I know that it's possible that the solution is needed from synology/synocommunity, but i wanted to post here to see if other people had the problem? (since i'm seeing alot of posts about torrents lately on the forum)
HI,
As I mentioned I am currently using the same DSM version and it is working absolutely fine with Download Station.
You should try Download Station once to be sure that it is not transmission which is causing this issue.
Also, please see if you have DNS servers settings correct in Synology. I also remember facing the same issue (where search in Download Station was not finding anything) then changing to Google DNS/OpenNIC DNS fixed that. I am not sure but may be you need to open port 53 also for DNS queries.
At least try these changes (one at a time) to see if it works.
