Ninjai
Could not connect to tracker error with torrents
Since yesterday (11th of June), I can not use torrents anymore via AirVPN.
For all torrents, I'm getting following error message:
udp://trrntdns-ssatuqjrxpijozfn.dnstest.doileak.com:6888
Got an error "Could not connect to tracker" xx second(s) ago
This happens for different torrents/trackers and I also tried several AirVPN servers:
Matar - Netherlands
Jabbah - Netherlands
Albali - Sweden
Rotanev - Canada
I'm using AirVPN client version 2.10.3 and Transmission as torrent client (on Windows 10) with preferences:
Enable uTP for peer connections = on
Use PEX to find more peers = on
Use DHT to find more peers = on
Anyway, couple of days ago no problems at all and now torrents are not working at all.
Please help me out,
Thanks!
For me it's working again.
I saw in Transmission, port for incoming connections was different from forward port configuration in AirVPN Client Area.
I do not know if these ports need to be the same, but after changing port in Transmission torrents are working again.
Hello !
Have you made sure your firewall rules are in order and checked Airs remote port forwarding?
Restarting the torrent client can also help.
Just delete the trackers that come with the torrent file. Just stick with DHT and PEX. And turn off uTP as is usually slows down your connection. This only applies if you are on public trackers, of course.
Regards
Fox
same here.  really dont want to deluge.
Ubuntu 14.04 headless
connecting to air via openvpn (not eddie)
i did check the forwarded ports are the same
if i disconnect the vpn it all works fine
