Pie
DNS Problem - The remote name could not be resolved
Hello everyone. I'm currently troubleshooting my VPN connection and could use some help.
Using OpenVPN GUI 2.3.11-I601, VPN connects successfully and fully operational.
But using the Eddie client, connections always halted with the message "The remote name could not be resolved."
The only way the client can connect is if I have the DNS Switch mode Disabled in Preferences - Advanced - DNS, otherwise the operation stopped while checking route with a statement The operation has timed out.
Any insight on where should I start looking would be greatly appreciated, and sorry for any mistakes as English is not my native language.
Thank you.
Operating system : Windows 10 64 bit
All connections set to DHCP (IP and DNS)
I 22.37.57 - Session starting.
I 22.37.57 - IPv6 disabled.
I 22.37.57 - Checking authorization ...
! 22.37.58 - Connecting to Cetus (Canada, Vancouver)
. 22.37.59 - OpenVPN > OpenVPN 2.3.8 x86_64-w64-mingw32 [SSL (OpenSSL)] [LZO] [IPv6] built on Aug 13 2015
. 22.37.59 - OpenVPN > library versions: OpenSSL 1.0.2d 9 Jul 2015, LZO 2.08
. 22.37.59 - OpenVPN > MANAGEMENT: TCP Socket listening on [AF_INET]127.0.0.1:3100
. 22.37.59 - OpenVPN > Control Channel Authentication: tls-auth using INLINE static key file
. 22.37.59 - OpenVPN > Outgoing Control Channel Authentication: Using 160 bit message hash 'SHA1' for HMAC authentication
. 22.37.59 - OpenVPN > Incoming Control Channel Authentication: Using 160 bit message hash 'SHA1' for HMAC authentication
. 22.37.59 - OpenVPN > Socket Buffers: R=[65536->131072] S=[65536->131072]
. 22.37.59 - OpenVPN > UDPv4 link local: [undef]
. 22.37.59 - OpenVPN > UDPv4 link remote: [AF_INET]71.19.249.195:443
. 22.37.59 - OpenVPN > TLS: Initial packet from [AF_INET]71.19.249.195:443, sid=6def05a5 c8eb86ab
. 22.37.59 - OpenVPN > VERIFY OK: depth=1, C=IT, ST=IT, L=Perugia, O=airvpn.org, CN=airvpn.org CA, emailAddress=info@airvpn.org
. 22.37.59 - OpenVPN > Validating certificate key usage
. 22.37.59 - OpenVPN > ++ Certificate has key usage  00a0, expects 00a0
. 22.37.59 - OpenVPN > VERIFY KU OK
. 22.37.59 - OpenVPN > Validating certificate extended key usage
. 22.37.59 - OpenVPN > ++ Certificate has EKU (str) TLS Web Server Authentication, expects TLS Web Server Authentication
. 22.37.59 - OpenVPN > VERIFY EKU OK
. 22.37.59 - OpenVPN > VERIFY OK: depth=0, C=IT, ST=IT, L=Perugia, O=airvpn.org, CN=server, emailAddress=info@airvpn.org
. 22.38.01 - OpenVPN > Data Channel Encrypt: Cipher 'AES-256-CBC' initialized with 256 bit key
. 22.38.01 - OpenVPN > Data Channel Encrypt: Using 160 bit message hash 'SHA1' for HMAC authentication
. 22.38.01 - OpenVPN > Data Channel Decrypt: Cipher 'AES-256-CBC' initialized with 256 bit key
. 22.38.01 - OpenVPN > Data Channel Decrypt: Using 160 bit message hash 'SHA1' for HMAC authentication
. 22.38.01 - OpenVPN > Control Channel: TLSv1.2, cipher TLSv1/SSLv3 DHE-RSA-AES256-GCM-SHA384, 4096 bit RSA
. 22.38.01 - OpenVPN > [server] Peer Connection Initiated with [AF_INET]71.19.249.195:443
. 22.38.03 - OpenVPN > SENT CONTROL [server]: 'PUSH_REQUEST' (status=1)
. 22.38.04 - OpenVPN > PUSH: Received control message: 'PUSH_REPLY,redirect-gateway def1 bypass-dhcp,dhcp-option DNS 10.4.0.1,comp-lzo no,route-gateway 10.4.0.1,topology subnet,ping 10,ping-restart 60,ifconfig 10.4.25.219 255.255.0.0'
. 22.38.04 - OpenVPN > OPTIONS IMPORT: timers and/or timeouts modified
. 22.38.04 - OpenVPN > OPTIONS IMPORT: LZO parms modified
. 22.38.04 - OpenVPN > OPTIONS IMPORT: --ifconfig/up options modified
. 22.38.04 - OpenVPN > OPTIONS IMPORT: route options modified
. 22.38.04 - OpenVPN > OPTIONS IMPORT: route-related options modified
. 22.38.04 - OpenVPN > OPTIONS IMPORT: --ip-win32 and/or --dhcp-option options modified
. 22.38.04 - OpenVPN > do_ifconfig, tt->ipv6=0, tt->did_ifconfig_ipv6_setup=0
. 22.38.04 - OpenVPN > open_tun, tt->ipv6=0
. 22.38.04 - OpenVPN > TAP-WIN32 device [VPN] opened: \\.\Global\{F5022C7A-40B9-456F-9049-DE3500514C86}.tap
. 22.38.04 - OpenVPN > TAP-Windows Driver Version 9.21
. 22.38.04 - OpenVPN > Set TAP-Windows TUN subnet mode network/local/netmask = 10.4.0.0/10.4.25.219/255.255.0.0 [SUCCEEDED]
. 22.38.04 - OpenVPN > Notified TAP-Windows driver to set a DHCP IP/netmask of 10.4.25.219/255.255.0.0 on interface {F5022C7A-40B9-456F-9049-DE3500514C86} [DHCP-serv: 10.4.255.254, lease-time: 31536000]
. 22.38.04 - OpenVPN > Successful ARP Flush on interface [20] {F5022C7A-40B9-456F-9049-DE3500514C86}
. 22.38.09 - OpenVPN > TEST ROUTES: 1/1 succeeded len=0 ret=1 a=0 u/d=up
. 22.38.09 - OpenVPN > C:\WINDOWS\system32\route.exe ADD 71.19.249.195 MASK 255.255.255.255 192.168.1.1
. 22.38.09 - OpenVPN > ROUTE: CreateIpForwardEntry succeeded with dwForwardMetric1=10 and dwForwardType=4
. 22.38.09 - OpenVPN > Route addition via IPAPI succeeded [adaptive]
. 22.38.09 - OpenVPN > C:\WINDOWS\system32\route.exe ADD 192.168.1.1 MASK 255.255.255.255 192.168.1.1 IF 2
. 22.38.09 - OpenVPN > C:\WINDOWS\system32\route.exe ADD 0.0.0.0 MASK 128.0.0.0 10.4.0.1
. 22.38.09 - OpenVPN > ROUTE: CreateIpForwardEntry succeeded with dwForwardMetric1=20 and dwForwardType=4
. 22.38.09 - OpenVPN > C:\WINDOWS\system32\route.exe ADD 128.0.0.0 MASK 128.0.0.0 10.4.0.1
. 22.38.09 - Starting Management Interface
. 22.38.09 - OpenVPN > Initialization Sequence Completed
I 22.38.09 - DNS of a network adapter forced (TAP-Windows Adapter V9)
I 22.38.09 - DNS of a network adapter forced (Realtek PCIe GBE Family Controller)
I 22.38.09 - Flushing DNS
I 22.38.09 - Checking route
W 22.38.21 - Checking route, 1° try failed (The operation has timed out)
W 22.38.33 - Checking route, 2° try failed (The operation has timed out)
W 22.38.33 - Checking route, 3° try failed (The remote name could not be resolved: 'cetus_exit.airservers.org')
W 22.38.33 - Checking route, 4° try failed (The remote name could not be resolved: 'cetus_exit.airservers.org')
W 22.38.33 - Checking route, 5° try failed (The remote name could not be resolved: 'cetus_exit.airservers.org')
W 22.38.33 - The remote name could not be resolved: 'cetus_exit.airservers.org'
! 22.38.33 - Disconnecting
. 22.38.33 - Management - Send 'signal SIGTERM'
. 22.38.33 - OpenVpn Management > >INFO:OpenVPN Management Interface Version 1 -- type 'help' for more info
. 22.38.33 - OpenVPN > MANAGEMENT: CMD 'signal SIGTERM'
. 22.38.33 - OpenVPN > SIGTERM received, sending exit notification to peer
. 22.38.38 - OpenVPN > C:\WINDOWS\system32\route.exe DELETE 71.19.249.195 MASK 255.255.255.255 192.168.1.1
. 22.38.38 - OpenVPN > Route deletion via IPAPI succeeded [adaptive]
. 22.38.38 - OpenVPN > C:\WINDOWS\system32\route.exe DELETE 192.168.1.1 MASK 255.255.255.255 192.168.1.1
. 22.38.38 - OpenVPN > C:\WINDOWS\system32\route.exe DELETE 0.0.0.0 MASK 128.0.0.0 10.4.0.1
. 22.38.38 - OpenVPN > C:\WINDOWS\system32\route.exe DELETE 128.0.0.0 MASK 128.0.0.0 10.4.0.1
. 22.38.38 - OpenVPN > Closing TUN/TAP interface
. 22.38.38 - OpenVPN > SIGTERM[soft,exit-with-notification] received, process exiting
. 22.38.38 - Connection terminated.
I 22.38.38 - DNS of a network adapter restored to original settings (TAP-Windows Adapter V9)
I 22.38.38 - DNS of a network adapter restored to original settings (Realtek PCIe GBE Family Controller)
I 22.38.40 - Cancel requested.
I 22.38.40 - IPv6 restored.
! 22.38.40 - Session terminated.
Hello to everyone,
I have exactly the same problem on my windows 10 machine....
So it would be great, if someone had some Ideas.
Thank you,
Suea
