spazzedguy 0 Posted ... I'm on a university network so I've previously used NordVPN to play video games that can't be played through port forwarding however about 2 months ago it stopped working and get stuck on connecting. I've just got a 3 day sub to AirVPN with the hope that it would work however I'm getting the same issue in that it gets stuck on connecting. Any help would be appreciated! Logs: I 2016.06.05 08:12:04 - Session starting.I 2016.06.05 08:12:04 - IPv6 disabled.I 2016.06.05 08:12:04 - Checking authorization ...! 2016.06.05 08:12:04 - Connecting to Alchiba (Netherlands, Alblasserdam). 2016.06.05 08:12:04 - OpenVPN > OpenVPN 2.3.8 x86_64-w64-mingw32 [sSL (OpenSSL)] [LZO] [iPv6] built on Aug 13 2015. 2016.06.05 08:12:04 - OpenVPN > library versions: OpenSSL 1.0.2d 9 Jul 2015, LZO 2.08. 2016.06.05 08:12:04 - OpenVPN > MANAGEMENT: TCP Socket listening on [AF_INET]127.0.0.1:3100. 2016.06.05 08:12:05 - OpenVPN > Control Channel Authentication: tls-auth using INLINE static key file. 2016.06.05 08:12:05 - OpenVPN > Outgoing Control Channel Authentication: Using 160 bit message hash 'SHA1' for HMAC authentication. 2016.06.05 08:12:05 - OpenVPN > Incoming Control Channel Authentication: Using 160 bit message hash 'SHA1' for HMAC authentication. 2016.06.05 08:12:05 - OpenVPN > Socket Buffers: R=[65536->131072] S=[65536->131072]. 2016.06.05 08:12:05 - OpenVPN > UDPv4 link local: [undef]. 2016.06.05 08:12:05 - OpenVPN > UDPv4 link remote: [AF_INET]213.152.161.180:443. 2016.06.05 08:12:38 - OpenVPN > [uNDEF] Inactivity timeout (--ping-exit), exiting. 2016.06.05 08:12:38 - OpenVPN > SIGTERM received, sending exit notification to peer. 2016.06.05 08:12:44 - OpenVPN > SIGTERM[soft,exit-with-notification] received, process exiting! 2016.06.05 08:12:44 - Disconnecting. 2016.06.05 08:12:44 - Connection terminated.I 2016.06.05 08:12:47 - Checking authorization ...! 2016.06.05 08:12:47 - Connecting to Caph (Netherlands, Alblasserdam). 2016.06.05 08:12:47 - OpenVPN > OpenVPN 2.3.8 x86_64-w64-mingw32 [sSL (OpenSSL)] [LZO] [iPv6] built on Aug 13 2015. 2016.06.05 08:12:47 - OpenVPN > library versions: OpenSSL 1.0.2d 9 Jul 2015, LZO 2.08. 2016.06.05 08:12:47 - OpenVPN > MANAGEMENT: TCP Socket listening on [AF_INET]127.0.0.1:3100. 2016.06.05 08:12:47 - OpenVPN > Control Channel Authentication: tls-auth using INLINE static key file. 2016.06.05 08:12:47 - OpenVPN > Outgoing Control Channel Authentication: Using 160 bit message hash 'SHA1' for HMAC authentication. 2016.06.05 08:12:47 - OpenVPN > Incoming Control Channel Authentication: Using 160 bit message hash 'SHA1' for HMAC authentication. 2016.06.05 08:12:47 - OpenVPN > Socket Buffers: R=[65536->131072] S=[65536->131072]. 2016.06.05 08:12:47 - OpenVPN > UDPv4 link local: [undef]. 2016.06.05 08:12:47 - OpenVPN > UDPv4 link remote: [AF_INET]213.152.162.169:443 Quote Share this post Link to post
Staff 10323 Posted ... Hello, please test OpenVPN over SSL connection mode, it's worth a try. You can change connection modes in Air client software window "AirVPN" > "Preferences" > "Protocols". Select "SSL Tunnel - Port 443", click "Save" and test connections to various servers in different locations. Kind regards 1 RobHight reacted to this Quote Share this post Link to post
