b0bd3n4rd
Keeps checking authorization
I'm having a problem since this morning. Whichever server I am trying to log into, AirVPN keeps "checking authorization" in a loop. I can't connect to any server...
Seems I am having a similar issue and can not keep any kind over connection open aside in the Eddie client and over one that is over a SSH or SSL tunnel....
i've had this same problem for about 2 weeks. i raised a ticket with the staff. apparently its an issue with mono (at least on my system). posting your logs here would help. the only work around is to use openvpn through the terminal (i'm assuming you are using a unix like system).
I don't know if it is related, but it seems to me it started when I updated TOR to 6.0. I am using AirVPN over TOR.
Mon Jun  6 10:48:27 BST 2016
Auth problems since upgrading TorBrowser to 6.0
% lsof -ni | grep tor
tor.real  5706 rprimus   20u  IPv4 0x6f0fd2a4f924aded      0t0  TCP 127.0.0.1:9150 (LISTEN)
tor.real  5706 rprimus   21u  IPv4 0x6f0fd2a4ef0b9fdd      0t0  TCP 127.0.0.1:9151 (LISTEN)
tor.real  5706 rprimus   23u  IPv4 0x6f0fd2a4f94ab6e5      0t0  TCP 192.168.0.7:50592->178.254.13.126:https (ESTABLISHED)
tor.real  5706 rprimus   24u  IPv4 0x6f0fd2a4ee8206e5      0t0  TCP 127.0.0.1:9151->127.0.0.1:50591 (ESTABLISHED)
tor.real  5706 rprimus   26u  IPv4 0x6f0fd2a4f9270305      0t0  TCP 127.0.0.1:9151->127.0.0.1:50593 (ESTABLISHED)
tor.real  5706 rprimus   28u  IPv4 0x6f0fd2a4f9249bfd      0t0  TCP 192.168.0.7:50595->91.121.54.8:etlservicemgr (ESTABLISHED)
tor.real  5706 rprimus   29u  IPv4 0x6f0fd2a4f927eded      0t0  TCP 127.0.0.1:9151->127.0.0.1:50596 (ESTABLISHED)
AirVpn logs:
I 2016.06.06 10:46:16 - AirVPN client version: 2.10.3 / x86, System: OSX, Name: 10.11.6 / x64
. 2016.06.06 10:46:16 - Reading options from /Users/rprimus/.airvpn/AirVPN.xml
. 2016.06.06 10:46:16 - Data Path: /Users/rprimus/.airvpn
. 2016.06.06 10:46:16 - App Path: /Applications/AirVPN.app/Contents/MacOS
. 2016.06.06 10:46:16 - Executable Path: /Applications/AirVPN.app/Contents/MacOS/AirVPN
. 2016.06.06 10:46:16 - Command line arguments (0):
. 2016.06.06 10:46:16 - Updating systems & servers data ...
. 2016.06.06 10:46:16 - Operating System: Unix 15.6.0.0 - Darwin rp-mbp-2.local 15.6.0 Darwin Kernel Version 15.6.0: Tue May 17 20:05:28 PDT 2016; root:xnu-3248.60.3~4/RELEASE_X86_64 x86_64
. 2016.06.06 10:46:16 - Updating systems & servers data ..., 1° try failed (CUrl is not installed on this system, and it's required for SOCKS proxy.)
. 2016.06.06 10:46:16 - Updating systems & servers data ..., 2° try failed (CUrl is not installed on this system, and it's required for SOCKS proxy.)
I 2016.06.06 10:46:16 - OpenVPN Driver - Expected
I 2016.06.06 10:46:16 - OpenVPN - Version: OpenVPN 2.3.8 (/Applications/AirVPN.app/Contents/MacOS/openvpn)
I 2016.06.06 10:46:16 - SSH - Version: OpenSSH_6.9p1, LibreSSL 2.1.8 (/usr/bin/ssh)
I 2016.06.06 10:46:16 - SSL - Version: stunnel 5.17 (/Applications/AirVPN.app/Contents/MacOS/stunnel)
I 2016.06.06 10:46:16 - Session starting.
. 2016.06.06 10:46:17 - Systems & servers data update completed
I 2016.06.06 10:46:17 - IPv6 disabled on network adapter (*Bluetooth PAN)
I 2016.06.06 10:46:17 - IPv6 disabled on network adapter (*BeagleBoneBlack)
I 2016.06.06 10:46:18 - IPv6 disabled on network adapter (*USB-Serial Controller)
I 2016.06.06 10:46:18 - IPv6 disabled on network adapter (*FireWire)
I 2016.06.06 10:46:18 - IPv6 disabled on network adapter (*Cisco USB Console)
I 2016.06.06 10:46:18 - IPv6 disabled on network adapter (*HUAWEI Mobile)
I 2016.06.06 10:46:18 - IPv6 disabled on network adapter (FT232R USB UART)
I 2016.06.06 10:46:23 - Checking authorization ...
! 2016.06.06 10:46:23 - Connecting to Alchiba (Netherlands, Alblasserdam)
W 2016.06.06 10:46:27 - Unable to communicate with Tor (Unable to find your Tor path.). Is Tor up and running?
I 2016.06.06 10:46:27 - Checking authorization ...
! 2016.06.06 10:46:28 - Connecting to Alchiba (Netherlands, Alblasserdam)
W 2016.06.06 10:46:32 - Unable to communicate with Tor (Unable to find your Tor path.). Is Tor up and running?
I 2016.06.06 10:46:32 - Checking authorization ...
! 2016.06.06 10:46:33 - Connecting to Alchiba (Netherlands, Alblasserdam)
W 2016.06.06 10:46:37 - Unable to communicate with Tor (Unable to find your Tor path.). Is Tor up and running?
I 2016.06.06 10:46:37 - Cancel requested.
I 2016.06.06 10:46:37 - IPv6 restored on network adapter (*Bluetooth PAN)
I 2016.06.06 10:46:37 - IPv6 restored on network adapter (*BeagleBoneBlack)
I 2016.06.06 10:46:37 - IPv6 restored on network adapter (*USB-Serial Controller)
I 2016.06.06 10:46:37 - IPv6 restored on network adapter (*FireWire)
I 2016.06.06 10:46:37 - IPv6 restored on network adapter (*Cisco USB Console)
I 2016.06.06 10:46:37 - IPv6 restored on network adapter (*HUAWEI Mobile)
I 2016.06.06 10:46:37 - IPv6 restored on network adapter (FT232R USB UART)
! 2016.06.06 10:46:37 - Session terminated.
ps:
rprimus          5706   0.0  0.4  2467068  23724   ??  S    10:35am   0:03.04 ./tor.real --defaults-torrc /Applications/TorBrowser.app/Contents/Resources/TorBrowser/Tor/torrc-defaults -f /Users/rprimus/Library/Application Support/TorBrowser-Data/Tor/torrc DataDirectory /Users/rprimus/Library/Application Support/TorBrowser-Data/Tor GeoIPFile /Applications/TorBrowser.app/Contents/Resources/TorBrowser/Tor/geoip GeoIPv6File /Applications/TorBrowser.app/Contents/Resources/TorBrowser/Tor/geoip6 HashedControlPassword <removed> __OwningControllerProcess 5695
cat /Applications/TorBrowser.app/Contents/Resources/TorBrowser/Tor/torrc-defaults
# torrc-defaults for Tor Browser
# This file is distributed with Tor Browser and should not be modified (it
# may be overwritten during the next Tor Browser update). To customize your
# Tor configuration, shut down Tor Browser and edit the torrc file.
# If non-zero, try to write to disk less frequently than we would otherwise.
AvoidDiskWrites 1
# Where to send logging messages.  Format is minSeverity[-maxSeverity]
# (stderr|stdout|syslog|file FILENAME).
Log notice stdout
# Bind to this address to listen to connections from SOCKS-speaking
# applications.
SocksPort 9150 IPv6Traffic PreferIPv6 KeepAliveIsolateSOCKSAuth
ControlPort 9151
CookieAuthentication 1
## obfs4proxy configuration
ClientTransportPlugin obfs2,obfs3,obfs4,scramblesuit exec PluggableTransports/obfs4proxy
## meek configuration
ClientTransportPlugin meek exec PluggableTransports/meek-client-torbrowser -- PluggableTransports/meek-client
 % cat "/Users/rprimus/Library/Application Support/TorBrowser-Data/Tor/torrc"
# This file was generated by Tor; if you edit it, comments will not be preserved
# The old torrc file was renamed to torrc.orig.1 or similar, and Tor will ignore it
DataDirectory /Applications/TorBrowser.app/TorBrowser/Data/Tor
GeoIPFile /Applications/TorBrowser.app/TorBrowser/Data/Tor/geoip
GeoIPv6File /Applications/TorBrowser.app/TorBrowser/Data/Tor/geoip6
