bingos
Speed drops to zero after one minute
I'm having repeated issues with connection speeds when using AirVPN/Eddie. I can (usually) connect OK, but after about one minute the data throughput drops to zero (although the connection remains up in Eddie) and I can't resolve domains or actually use the connection at all. If I force disconnection and reconnect, it works for a minute and then drops to zero speed again. I'm running TAP 9.9.2 on Win 10 64-bit over a wired connection.
Grateful for any advice.
LOG (note that I couldn't connect to Ukraine server at the start, but it connected ok to NL afterwards):
I 2016.05.31 10:12:23 - AirVPN client version: 2.10.3 / x64, System: Windows, Name: Microsoft Windows NT 6.2.9200.0 / x64
. 2016.05.31 10:12:23 - Reading options from C:\Users\*****\AppData\Local\AirVPN\AirVPN.xml
. 2016.05.31 10:12:23 - Data Path: C:\Users\*****\AppData\Local\AirVPN
. 2016.05.31 10:12:23 - App Path: C:\Program Files\AirVPN
. 2016.05.31 10:12:23 - Executable Path: C:\Program Files\AirVPN\AirVPN.exe
. 2016.05.31 10:12:23 - Command line arguments (1): path="home"
. 2016.05.31 10:12:23 - Operating System: Microsoft Windows NT 6.2.9200.0
. 2016.05.31 10:12:23 - Updating systems & servers data ...
. 2016.05.31 10:12:23 - Systems & servers data update completed
I 2016.05.31 10:12:23 - OpenVPN Driver - TAP-Windows Adapter V9, version 9.9.2
I 2016.05.31 10:12:23 - OpenVPN - Version: OpenVPN 2.3.8 (C:\Program Files\AirVPN\openvpn.exe)
I 2016.05.31 10:12:23 - SSH - Version: plink 0.63 (C:\Program Files\AirVPN\plink.exe)
I 2016.05.31 10:12:23 - SSL - Version: stunnel 5.17 (C:\Program Files\AirVPN\stunnel.exe)
! 2016.05.31 10:12:23 - Ready
! 2016.05.31 10:12:34 - Activation of Network Lock - Windows Firewall
I 2016.05.31 10:12:53 - Session starting.
I 2016.05.31 10:12:53 - IPv6 disabled.
I 2016.05.31 10:12:53 - Checking authorization ...
! 2016.05.31 10:12:53 - Connecting to Alcor (Ukraine, Kiev)
. 2016.05.31 10:12:54 - OpenVPN > OpenVPN 2.3.8 x86_64-w64-mingw32 [sSL (OpenSSL)] [LZO] [iPv6] built on Aug 13 2015
. 2016.05.31 10:12:54 - OpenVPN > library versions: OpenSSL 1.0.2d 9 Jul 2015, LZO 2.08
. 2016.05.31 10:12:54 - OpenVPN > MANAGEMENT: TCP Socket listening on [AF_INET]127.0.0.1:3100
. 2016.05.31 10:12:54 - OpenVPN > Control Channel Authentication: tls-auth using INLINE static key file
. 2016.05.31 10:12:54 - OpenVPN > Outgoing Control Channel Authentication: Using 160 bit message hash 'SHA1' for HMAC authentication
. 2016.05.31 10:12:54 - OpenVPN > Incoming Control Channel Authentication: Using 160 bit message hash 'SHA1' for HMAC authentication
. 2016.05.31 10:12:54 - OpenVPN > Socket Buffers: R=[65536->131072] S=[65536->131072]
. 2016.05.31 10:12:54 - OpenVPN > UDPv4 link local: [undef]
. 2016.05.31 10:12:54 - OpenVPN > UDPv4 link remote: [AF_INET]91.231.84.39:443
. 2016.05.31 10:12:54 - OpenVPN > TLS: Initial packet from [AF_INET]91.231.84.39:443, sid=37baaec2 0c1a85d6
. 2016.05.31 10:12:54 - OpenVPN > VERIFY OK: depth=1, C=IT, ST=IT, L=Perugia, O=airvpn.org, CN=airvpn.org CA, emailAddress=info@airvpn.org
. 2016.05.31 10:12:54 - OpenVPN > Validating certificate key usage
. 2016.05.31 10:12:54 - OpenVPN > ++ Certificate has key usage  00a0, expects 00a0
. 2016.05.31 10:12:54 - OpenVPN > VERIFY KU OK
. 2016.05.31 10:12:54 - OpenVPN > Validating certificate extended key usage
. 2016.05.31 10:12:54 - OpenVPN > ++ Certificate has EKU (str) TLS Web Server Authentication, expects TLS Web Server Authentication
. 2016.05.31 10:12:54 - OpenVPN > VERIFY EKU OK
. 2016.05.31 10:12:54 - OpenVPN > VERIFY OK: depth=0, C=IT, ST=IT, L=Perugia, O=airvpn.org, CN=server, emailAddress=info@airvpn.org
. 2016.05.31 10:12:55 - OpenVPN > Data Channel Encrypt: Cipher 'AES-256-CBC' initialized with 256 bit key
. 2016.05.31 10:12:55 - OpenVPN > Data Channel Encrypt: Using 160 bit message hash 'SHA1' for HMAC authentication
. 2016.05.31 10:12:55 - OpenVPN > Data Channel Decrypt: Cipher 'AES-256-CBC' initialized with 256 bit key
. 2016.05.31 10:12:55 - OpenVPN > Data Channel Decrypt: Using 160 bit message hash 'SHA1' for HMAC authentication
. 2016.05.31 10:12:55 - OpenVPN > Control Channel: TLSv1.2, cipher TLSv1/SSLv3 DHE-RSA-AES256-GCM-SHA384, 4096 bit RSA
. 2016.05.31 10:12:55 - OpenVPN > [server] Peer Connection Initiated with [AF_INET]91.231.84.39:443
. 2016.05.31 10:12:57 - OpenVPN > SENT CONTROL [server]: 'PUSH_REQUEST' (status=1)
. 2016.05.31 10:13:11 - OpenVPN > PUSH: Received control message: 'PUSH_REPLY,redirect-gateway def1 bypass-dhcp,dhcp-option DNS 10.4.0.1,comp-lzo no,route-gateway 10.4.0.1,topology subnet,ping 10,ping-restart 60,ifconfig 10.4.1.0 255.255.0.0'
. 2016.05.31 10:13:11 - OpenVPN > OPTIONS IMPORT: timers and/or timeouts modified
. 2016.05.31 10:13:11 - OpenVPN > OPTIONS IMPORT: LZO parms modified
. 2016.05.31 10:13:11 - OpenVPN > OPTIONS IMPORT: --ifconfig/up options modified
. 2016.05.31 10:13:11 - OpenVPN > OPTIONS IMPORT: route options modified
. 2016.05.31 10:13:11 - OpenVPN > OPTIONS IMPORT: route-related options modified
. 2016.05.31 10:13:11 - OpenVPN > OPTIONS IMPORT: --ip-win32 and/or --dhcp-option options modified
. 2016.05.31 10:13:11 - OpenVPN > do_ifconfig, tt->ipv6=0, tt->did_ifconfig_ipv6_setup=0
. 2016.05.31 10:13:11 - OpenVPN > open_tun, tt->ipv6=0
. 2016.05.31 10:13:11 - OpenVPN > TAP-WIN32 device [Ethernet 4] opened: \\.\Global\{13FA5C83-1319-4706-8D85-06FBA481BBE7}.tap
. 2016.05.31 10:13:11 - OpenVPN > TAP-Windows Driver Version 9.9
. 2016.05.31 10:13:11 - OpenVPN > Set TAP-Windows TUN subnet mode network/local/netmask = 10.4.0.0/10.4.1.0/255.255.0.0 [sUCCEEDED]
. 2016.05.31 10:13:11 - OpenVPN > Notified TAP-Windows driver to set a DHCP IP/netmask of 10.4.1.0/255.255.0.0 on interface {13FA5C83-1319-4706-8D85-06FBA481BBE7} [DHCP-serv: 10.4.255.254, lease-time: 31536000]
. 2016.05.31 10:13:11 - OpenVPN > Successful ARP Flush on interface [2] {13FA5C83-1319-4706-8D85-06FBA481BBE7}
. 2016.05.31 10:13:16 - OpenVPN > TEST ROUTES: 1/1 succeeded len=0 ret=1 a=0 u/d=up
. 2016.05.31 10:13:16 - OpenVPN > C:\WINDOWS\system32\route.exe ADD 91.231.84.39 MASK 255.255.255.255 192.168.1.254
. 2016.05.31 10:13:16 - OpenVPN > ROUTE: CreateIpForwardEntry succeeded with dwForwardMetric1=20 and dwForwardType=4
. 2016.05.31 10:13:16 - OpenVPN > Route addition via IPAPI succeeded [adaptive]
. 2016.05.31 10:13:16 - OpenVPN > C:\WINDOWS\system32\route.exe ADD 192.168.1.254 MASK 255.255.255.255 192.168.1.254 IF 13
. 2016.05.31 10:13:16 - OpenVPN > C:\WINDOWS\system32\route.exe ADD 0.0.0.0 MASK 128.0.0.0 10.4.0.1
. 2016.05.31 10:13:16 - OpenVPN > ROUTE: CreateIpForwardEntry succeeded with dwForwardMetric1=30 and dwForwardType=4
. 2016.05.31 10:13:16 - OpenVPN > C:\WINDOWS\system32\route.exe ADD 128.0.0.0 MASK 128.0.0.0 10.4.0.1
. 2016.05.31 10:13:16 - Starting Management Interface
. 2016.05.31 10:13:16 - OpenVPN > Initialization Sequence Completed
I 2016.05.31 10:13:16 - DNS of a network adapter forced (Realtek PCIe FE Family Controller)
I 2016.05.31 10:13:16 - DNS of a network adapter forced (TAP-Windows Adapter V9)
I 2016.05.31 10:13:16 - Flushing DNS
I 2016.05.31 10:13:17 - Checking route
W 2016.05.31 10:14:07 - The operation has timed out
! 2016.05.31 10:14:07 - Disconnecting
. 2016.05.31 10:14:07 - Management - Send 'signal SIGTERM'
. 2016.05.31 10:14:07 - OpenVPN > MANAGEMENT: CMD 'signal SIGTERM'
. 2016.05.31 10:14:07 - OpenVpn Management > >INFO:OpenVPN Management Interface Version 1 -- type 'help' for more info
. 2016.05.31 10:14:07 - OpenVPN > SIGTERM received, sending exit notification to peer
. 2016.05.31 10:14:12 - OpenVPN > C:\WINDOWS\system32\route.exe DELETE 91.231.84.39 MASK 255.255.255.255 192.168.1.254
. 2016.05.31 10:14:12 - OpenVPN > Route deletion via IPAPI succeeded [adaptive]
. 2016.05.31 10:14:12 - OpenVPN > C:\WINDOWS\system32\route.exe DELETE 192.168.1.254 MASK 255.255.255.255 192.168.1.254
. 2016.05.31 10:14:12 - OpenVPN > C:\WINDOWS\system32\route.exe DELETE 0.0.0.0 MASK 128.0.0.0 10.4.0.1
. 2016.05.31 10:14:12 - OpenVPN > C:\WINDOWS\system32\route.exe DELETE 128.0.0.0 MASK 128.0.0.0 10.4.0.1
. 2016.05.31 10:14:12 - OpenVPN > Closing TUN/TAP interface
. 2016.05.31 10:14:12 - OpenVPN > SIGTERM[soft,exit-with-notification] received, process exiting
. 2016.05.31 10:14:12 - Connection terminated.
I 2016.05.31 10:14:12 - DNS of a network adapter restored to original settings (Realtek PCIe FE Family Controller)
I 2016.05.31 10:14:12 - DNS of a network adapter restored to original settings (TAP-Windows Adapter V9)
I 2016.05.31 10:14:15 - Checking authorization ...
! 2016.05.31 10:14:15 - Connecting to Alcor (Ukraine, Kiev)
. 2016.05.31 10:14:15 - OpenVPN > OpenVPN 2.3.8 x86_64-w64-mingw32 [sSL (OpenSSL)] [LZO] [iPv6] built on Aug 13 2015
. 2016.05.31 10:14:15 - OpenVPN > library versions: OpenSSL 1.0.2d 9 Jul 2015, LZO 2.08
. 2016.05.31 10:14:15 - OpenVPN > MANAGEMENT: TCP Socket listening on [AF_INET]127.0.0.1:3100
. 2016.05.31 10:14:15 - OpenVPN > Control Channel Authentication: tls-auth using INLINE static key file
. 2016.05.31 10:14:15 - OpenVPN > Outgoing Control Channel Authentication: Using 160 bit message hash 'SHA1' for HMAC authentication
. 2016.05.31 10:14:15 - OpenVPN > Incoming Control Channel Authentication: Using 160 bit message hash 'SHA1' for HMAC authentication
. 2016.05.31 10:14:15 - OpenVPN > Socket Buffers: R=[65536->131072] S=[65536->131072]
. 2016.05.31 10:14:15 - OpenVPN > UDPv4 link local: [undef]
. 2016.05.31 10:14:15 - OpenVPN > UDPv4 link remote: [AF_INET]91.231.84.39:443
. 2016.05.31 10:14:17 - OpenVPN > TLS: Initial packet from [AF_INET]91.231.84.39:443, sid=be1b324a 2d995e38
. 2016.05.31 10:14:17 - OpenVPN > VERIFY OK: depth=1, C=IT, ST=IT, L=Perugia, O=airvpn.org, CN=airvpn.org CA, emailAddress=info@airvpn.org
. 2016.05.31 10:14:17 - OpenVPN > Validating certificate key usage
. 2016.05.31 10:14:17 - OpenVPN > ++ Certificate has key usage  00a0, expects 00a0
. 2016.05.31 10:14:17 - OpenVPN > VERIFY KU OK
. 2016.05.31 10:14:17 - OpenVPN > Validating certificate extended key usage
. 2016.05.31 10:14:17 - OpenVPN > ++ Certificate has EKU (str) TLS Web Server Authentication, expects TLS Web Server Authentication
. 2016.05.31 10:14:17 - OpenVPN > VERIFY EKU OK
. 2016.05.31 10:14:17 - OpenVPN > VERIFY OK: depth=0, C=IT, ST=IT, L=Perugia, O=airvpn.org, CN=server, emailAddress=info@airvpn.org
. 2016.05.31 10:14:18 - OpenVPN > Data Channel Encrypt: Cipher 'AES-256-CBC' initialized with 256 bit key
. 2016.05.31 10:14:18 - OpenVPN > Data Channel Encrypt: Using 160 bit message hash 'SHA1' for HMAC authentication
. 2016.05.31 10:14:18 - OpenVPN > Data Channel Decrypt: Cipher 'AES-256-CBC' initialized with 256 bit key
. 2016.05.31 10:14:18 - OpenVPN > Data Channel Decrypt: Using 160 bit message hash 'SHA1' for HMAC authentication
. 2016.05.31 10:14:18 - OpenVPN > Control Channel: TLSv1.2, cipher TLSv1/SSLv3 DHE-RSA-AES256-GCM-SHA384, 4096 bit RSA
. 2016.05.31 10:14:18 - OpenVPN > [server] Peer Connection Initiated with [AF_INET]91.231.84.39:443
. 2016.05.31 10:14:20 - OpenVPN > SENT CONTROL [server]: 'PUSH_REQUEST' (status=1)
. 2016.05.31 10:14:34 - OpenVPN > PUSH: Received control message: 'PUSH_REPLY,redirect-gateway def1 bypass-dhcp,dhcp-option DNS 10.4.0.1,comp-lzo no,route-gateway 10.4.0.1,topology subnet,ping 10,ping-restart 60,ifconfig 10.4.1.0 255.255.0.0'
. 2016.05.31 10:14:34 - OpenVPN > OPTIONS IMPORT: timers and/or timeouts modified
. 2016.05.31 10:14:34 - OpenVPN > OPTIONS IMPORT: LZO parms modified
. 2016.05.31 10:14:34 - OpenVPN > OPTIONS IMPORT: --ifconfig/up options modified
. 2016.05.31 10:14:34 - OpenVPN > OPTIONS IMPORT: route options modified
. 2016.05.31 10:14:34 - OpenVPN > OPTIONS IMPORT: route-related options modified
. 2016.05.31 10:14:34 - OpenVPN > OPTIONS IMPORT: --ip-win32 and/or --dhcp-option options modified
. 2016.05.31 10:14:34 - OpenVPN > do_ifconfig, tt->ipv6=0, tt->did_ifconfig_ipv6_setup=0
. 2016.05.31 10:14:34 - OpenVPN > open_tun, tt->ipv6=0
. 2016.05.31 10:14:34 - OpenVPN > TAP-WIN32 device [Ethernet 4] opened: \\.\Global\{13FA5C83-1319-4706-8D85-06FBA481BBE7}.tap
. 2016.05.31 10:14:34 - OpenVPN > TAP-Windows Driver Version 9.9
. 2016.05.31 10:14:34 - OpenVPN > Set TAP-Windows TUN subnet mode network/local/netmask = 10.4.0.0/10.4.1.0/255.255.0.0 [sUCCEEDED]
. 2016.05.31 10:14:34 - OpenVPN > Notified TAP-Windows driver to set a DHCP IP/netmask of 10.4.1.0/255.255.0.0 on interface {13FA5C83-1319-4706-8D85-06FBA481BBE7} [DHCP-serv: 10.4.255.254, lease-time: 31536000]
. 2016.05.31 10:14:34 - OpenVPN > Successful ARP Flush on interface [2] {13FA5C83-1319-4706-8D85-06FBA481BBE7}
. 2016.05.31 10:14:39 - OpenVPN > TEST ROUTES: 1/1 succeeded len=0 ret=1 a=0 u/d=up
. 2016.05.31 10:14:39 - OpenVPN > C:\WINDOWS\system32\route.exe ADD 91.231.84.39 MASK 255.255.255.255 192.168.1.254
. 2016.05.31 10:14:39 - OpenVPN > ROUTE: CreateIpForwardEntry succeeded with dwForwardMetric1=20 and dwForwardType=4
. 2016.05.31 10:14:39 - OpenVPN > Route addition via IPAPI succeeded [adaptive]
. 2016.05.31 10:14:39 - OpenVPN > C:\WINDOWS\system32\route.exe ADD 192.168.1.254 MASK 255.255.255.255 192.168.1.254 IF 13
. 2016.05.31 10:14:39 - OpenVPN > C:\WINDOWS\system32\route.exe ADD 0.0.0.0 MASK 128.0.0.0 10.4.0.1
. 2016.05.31 10:14:39 - OpenVPN > ROUTE: CreateIpForwardEntry succeeded with dwForwardMetric1=30 and dwForwardType=4
. 2016.05.31 10:14:39 - OpenVPN > C:\WINDOWS\system32\route.exe ADD 128.0.0.0 MASK 128.0.0.0 10.4.0.1
. 2016.05.31 10:14:39 - Starting Management Interface
. 2016.05.31 10:14:39 - OpenVPN > Initialization Sequence Completed
I 2016.05.31 10:14:39 - DNS of a network adapter forced (Realtek PCIe FE Family Controller)
I 2016.05.31 10:14:39 - DNS of a network adapter forced (TAP-Windows Adapter V9)
I 2016.05.31 10:14:39 - Flushing DNS
I 2016.05.31 10:14:39 - Checking route
W 2016.05.31 10:15:30 - The operation has timed out
! 2016.05.31 10:15:31 - Disconnecting
. 2016.05.31 10:15:31 - Management - Send 'signal SIGTERM'
. 2016.05.31 10:15:31 - OpenVpn Management > >INFO:OpenVPN Management Interface Version 1 -- type 'help' for more info
. 2016.05.31 10:15:31 - OpenVPN > MANAGEMENT: CMD 'signal SIGTERM'
. 2016.05.31 10:15:31 - OpenVPN > SIGTERM received, sending exit notification to peer
. 2016.05.31 10:15:36 - OpenVPN > C:\WINDOWS\system32\route.exe DELETE 91.231.84.39 MASK 255.255.255.255 192.168.1.254
. 2016.05.31 10:15:36 - OpenVPN > Route deletion via IPAPI succeeded [adaptive]
. 2016.05.31 10:15:36 - OpenVPN > C:\WINDOWS\system32\route.exe DELETE 192.168.1.254 MASK 255.255.255.255 192.168.1.254
. 2016.05.31 10:15:36 - OpenVPN > C:\WINDOWS\system32\route.exe DELETE 0.0.0.0 MASK 128.0.0.0 10.4.0.1
. 2016.05.31 10:15:36 - OpenVPN > C:\WINDOWS\system32\route.exe DELETE 128.0.0.0 MASK 128.0.0.0 10.4.0.1
. 2016.05.31 10:15:36 - OpenVPN > Closing TUN/TAP interface
. 2016.05.31 10:15:36 - OpenVPN > SIGTERM[soft,exit-with-notification] received, process exiting
. 2016.05.31 10:15:36 - Connection terminated.
I 2016.05.31 10:15:36 - DNS of a network adapter restored to original settings (Realtek PCIe FE Family Controller)
I 2016.05.31 10:15:36 - DNS of a network adapter restored to original settings (TAP-Windows Adapter V9)
I 2016.05.31 10:15:39 - Checking authorization ...
! 2016.05.31 10:15:39 - Connecting to Alcor (Ukraine, Kiev)
. 2016.05.31 10:15:40 - OpenVPN > OpenVPN 2.3.8 x86_64-w64-mingw32 [sSL (OpenSSL)] [LZO] [iPv6] built on Aug 13 2015
. 2016.05.31 10:15:40 - OpenVPN > library versions: OpenSSL 1.0.2d 9 Jul 2015, LZO 2.08
. 2016.05.31 10:15:40 - OpenVPN > MANAGEMENT: TCP Socket listening on [AF_INET]127.0.0.1:3100
. 2016.05.31 10:15:40 - OpenVPN > Control Channel Authentication: tls-auth using INLINE static key file
. 2016.05.31 10:15:40 - OpenVPN > Outgoing Control Channel Authentication: Using 160 bit message hash 'SHA1' for HMAC authentication
. 2016.05.31 10:15:40 - OpenVPN > Incoming Control Channel Authentication: Using 160 bit message hash 'SHA1' for HMAC authentication
. 2016.05.31 10:15:40 - OpenVPN > Socket Buffers: R=[65536->131072] S=[65536->131072]
. 2016.05.31 10:15:40 - OpenVPN > UDPv4 link local: [undef]
. 2016.05.31 10:15:40 - OpenVPN > UDPv4 link remote: [AF_INET]91.231.84.39:443
. 2016.05.31 10:15:42 - OpenVPN > TLS: Initial packet from [AF_INET]91.231.84.39:443, sid=98159ea4 df950ea0
. 2016.05.31 10:15:42 - OpenVPN > VERIFY OK: depth=1, C=IT, ST=IT, L=Perugia, O=airvpn.org, CN=airvpn.org CA, emailAddress=info@airvpn.org
. 2016.05.31 10:15:42 - OpenVPN > Validating certificate key usage
. 2016.05.31 10:15:42 - OpenVPN > ++ Certificate has key usage  00a0, expects 00a0
. 2016.05.31 10:15:42 - OpenVPN > VERIFY KU OK
. 2016.05.31 10:15:42 - OpenVPN > Validating certificate extended key usage
. 2016.05.31 10:15:42 - OpenVPN > ++ Certificate has EKU (str) TLS Web Server Authentication, expects TLS Web Server Authentication
. 2016.05.31 10:15:42 - OpenVPN > VERIFY EKU OK
. 2016.05.31 10:15:42 - OpenVPN > VERIFY OK: depth=0, C=IT, ST=IT, L=Perugia, O=airvpn.org, CN=server, emailAddress=info@airvpn.org
. 2016.05.31 10:15:43 - OpenVPN > Data Channel Encrypt: Cipher 'AES-256-CBC' initialized with 256 bit key
. 2016.05.31 10:15:43 - OpenVPN > Data Channel Encrypt: Using 160 bit message hash 'SHA1' for HMAC authentication
. 2016.05.31 10:15:43 - OpenVPN > Data Channel Decrypt: Cipher 'AES-256-CBC' initialized with 256 bit key
. 2016.05.31 10:15:43 - OpenVPN > Data Channel Decrypt: Using 160 bit message hash 'SHA1' for HMAC authentication
. 2016.05.31 10:15:43 - OpenVPN > Control Channel: TLSv1.2, cipher TLSv1/SSLv3 DHE-RSA-AES256-GCM-SHA384, 4096 bit RSA
. 2016.05.31 10:15:43 - OpenVPN > [server] Peer Connection Initiated with [AF_INET]91.231.84.39:443
. 2016.05.31 10:15:45 - OpenVPN > SENT CONTROL [server]: 'PUSH_REQUEST' (status=1)
. 2016.05.31 10:15:59 - OpenVPN > PUSH: Received control message: 'PUSH_REPLY,redirect-gateway def1 bypass-dhcp,dhcp-option DNS 10.4.0.1,comp-lzo no,route-gateway 10.4.0.1,topology subnet,ping 10,ping-restart 60,ifconfig 10.4.1.0 255.255.0.0'
. 2016.05.31 10:15:59 - OpenVPN > OPTIONS IMPORT: timers and/or timeouts modified
. 2016.05.31 10:15:59 - OpenVPN > OPTIONS IMPORT: LZO parms modified
. 2016.05.31 10:15:59 - OpenVPN > OPTIONS IMPORT: --ifconfig/up options modified
. 2016.05.31 10:15:59 - OpenVPN > OPTIONS IMPORT: route options modified
. 2016.05.31 10:15:59 - OpenVPN > OPTIONS IMPORT: route-related options modified
. 2016.05.31 10:15:59 - OpenVPN > OPTIONS IMPORT: --ip-win32 and/or --dhcp-option options modified
. 2016.05.31 10:15:59 - OpenVPN > do_ifconfig, tt->ipv6=0, tt->did_ifconfig_ipv6_setup=0
. 2016.05.31 10:15:59 - OpenVPN > open_tun, tt->ipv6=0
. 2016.05.31 10:15:59 - OpenVPN > TAP-WIN32 device [Ethernet 4] opened: \\.\Global\{13FA5C83-1319-4706-8D85-06FBA481BBE7}.tap
. 2016.05.31 10:15:59 - OpenVPN > TAP-Windows Driver Version 9.9
. 2016.05.31 10:15:59 - OpenVPN > Set TAP-Windows TUN subnet mode network/local/netmask = 10.4.0.0/10.4.1.0/255.255.0.0 [sUCCEEDED]
. 2016.05.31 10:15:59 - OpenVPN > Notified TAP-Windows driver to set a DHCP IP/netmask of 10.4.1.0/255.255.0.0 on interface {13FA5C83-1319-4706-8D85-06FBA481BBE7} [DHCP-serv: 10.4.255.254, lease-time: 31536000]
. 2016.05.31 10:15:59 - OpenVPN > Successful ARP Flush on interface [2] {13FA5C83-1319-4706-8D85-06FBA481BBE7}
. 2016.05.31 10:16:04 - OpenVPN > TEST ROUTES: 1/1 succeeded len=0 ret=1 a=0 u/d=up
. 2016.05.31 10:16:04 - OpenVPN > C:\WINDOWS\system32\route.exe ADD 91.231.84.39 MASK 255.255.255.255 192.168.1.254
. 2016.05.31 10:16:04 - OpenVPN > ROUTE: CreateIpForwardEntry succeeded with dwForwardMetric1=20 and dwForwardType=4
. 2016.05.31 10:16:04 - OpenVPN > Route addition via IPAPI succeeded [adaptive]
. 2016.05.31 10:16:04 - OpenVPN > C:\WINDOWS\system32\route.exe ADD 192.168.1.254 MASK 255.255.255.255 192.168.1.254 IF 13
. 2016.05.31 10:16:04 - OpenVPN > C:\WINDOWS\system32\route.exe ADD 0.0.0.0 MASK 128.0.0.0 10.4.0.1
. 2016.05.31 10:16:04 - OpenVPN > ROUTE: CreateIpForwardEntry succeeded with dwForwardMetric1=30 and dwForwardType=4
. 2016.05.31 10:16:04 - OpenVPN > C:\WINDOWS\system32\route.exe ADD 128.0.0.0 MASK 128.0.0.0 10.4.0.1
. 2016.05.31 10:16:04 - Starting Management Interface
. 2016.05.31 10:16:04 - OpenVPN > Initialization Sequence Completed
I 2016.05.31 10:16:04 - DNS of a network adapter forced (Realtek PCIe FE Family Controller)
I 2016.05.31 10:16:04 - DNS of a network adapter forced (TAP-Windows Adapter V9)
I 2016.05.31 10:16:04 - Flushing DNS
I 2016.05.31 10:16:04 - Checking route
W 2016.05.31 10:16:56 - The operation has timed out
! 2016.05.31 10:16:57 - Disconnecting
. 2016.05.31 10:16:57 - Management - Send 'signal SIGTERM'
. 2016.05.31 10:16:57 - OpenVpn Management > >INFO:OpenVPN Management Interface Version 1 -- type 'help' for more info
. 2016.05.31 10:16:57 - OpenVPN > MANAGEMENT: CMD 'signal SIGTERM'
. 2016.05.31 10:16:57 - OpenVPN > SIGTERM received, sending exit notification to peer
. 2016.05.31 10:17:02 - OpenVPN > C:\WINDOWS\system32\route.exe DELETE 91.231.84.39 MASK 255.255.255.255 192.168.1.254
. 2016.05.31 10:17:02 - OpenVPN > Route deletion via IPAPI succeeded [adaptive]
. 2016.05.31 10:17:02 - OpenVPN > C:\WINDOWS\system32\route.exe DELETE 192.168.1.254 MASK 255.255.255.255 192.168.1.254
. 2016.05.31 10:17:02 - OpenVPN > C:\WINDOWS\system32\route.exe DELETE 0.0.0.0 MASK 128.0.0.0 10.4.0.1
. 2016.05.31 10:17:02 - OpenVPN > C:\WINDOWS\system32\route.exe DELETE 128.0.0.0 MASK 128.0.0.0 10.4.0.1
. 2016.05.31 10:17:02 - OpenVPN > Closing TUN/TAP interface
. 2016.05.31 10:17:02 - OpenVPN > SIGTERM[soft,exit-with-notification] received, process exiting
. 2016.05.31 10:17:02 - Connection terminated.
I 2016.05.31 10:17:02 - DNS of a network adapter restored to original settings (Realtek PCIe FE Family Controller)
I 2016.05.31 10:17:02 - DNS of a network adapter restored to original settings (TAP-Windows Adapter V9)
I 2016.05.31 10:17:05 - Checking authorization ...
! 2016.05.31 10:17:05 - Connecting to Alcor (Ukraine, Kiev)
. 2016.05.31 10:17:06 - OpenVPN > OpenVPN 2.3.8 x86_64-w64-mingw32 [sSL (OpenSSL)] [LZO] [iPv6] built on Aug 13 2015
. 2016.05.31 10:17:06 - OpenVPN > library versions: OpenSSL 1.0.2d 9 Jul 2015, LZO 2.08
. 2016.05.31 10:17:06 - OpenVPN > MANAGEMENT: TCP Socket listening on [AF_INET]127.0.0.1:3100
. 2016.05.31 10:17:06 - OpenVPN > Control Channel Authentication: tls-auth using INLINE static key file
. 2016.05.31 10:17:06 - OpenVPN > Outgoing Control Channel Authentication: Using 160 bit message hash 'SHA1' for HMAC authentication
. 2016.05.31 10:17:06 - OpenVPN > Incoming Control Channel Authentication: Using 160 bit message hash 'SHA1' for HMAC authentication
. 2016.05.31 10:17:06 - OpenVPN > Socket Buffers: R=[65536->131072] S=[65536->131072]
. 2016.05.31 10:17:06 - OpenVPN > UDPv4 link local: [undef]
. 2016.05.31 10:17:06 - OpenVPN > UDPv4 link remote: [AF_INET]91.231.84.39:443
. 2016.05.31 10:17:08 - OpenVPN > TLS: Initial packet from [AF_INET]91.231.84.39:443, sid=94ed7961 17a9fb17
. 2016.05.31 10:17:08 - OpenVPN > VERIFY OK: depth=1, C=IT, ST=IT, L=Perugia, O=airvpn.org, CN=airvpn.org CA, emailAddress=info@airvpn.org
. 2016.05.31 10:17:08 - OpenVPN > Validating certificate key usage
. 2016.05.31 10:17:08 - OpenVPN > ++ Certificate has key usage  00a0, expects 00a0
. 2016.05.31 10:17:08 - OpenVPN > VERIFY KU OK
. 2016.05.31 10:17:08 - OpenVPN > Validating certificate extended key usage
. 2016.05.31 10:17:08 - OpenVPN > ++ Certificate has EKU (str) TLS Web Server Authentication, expects TLS Web Server Authentication
. 2016.05.31 10:17:08 - OpenVPN > VERIFY EKU OK
. 2016.05.31 10:17:08 - OpenVPN > VERIFY OK: depth=0, C=IT, ST=IT, L=Perugia, O=airvpn.org, CN=server, emailAddress=info@airvpn.org
. 2016.05.31 10:17:09 - OpenVPN > Data Channel Encrypt: Cipher 'AES-256-CBC' initialized with 256 bit key
. 2016.05.31 10:17:09 - OpenVPN > Data Channel Encrypt: Using 160 bit message hash 'SHA1' for HMAC authentication
. 2016.05.31 10:17:09 - OpenVPN > Data Channel Decrypt: Cipher 'AES-256-CBC' initialized with 256 bit key
. 2016.05.31 10:17:09 - OpenVPN > Data Channel Decrypt: Using 160 bit message hash 'SHA1' for HMAC authentication
. 2016.05.31 10:17:09 - OpenVPN > Control Channel: TLSv1.2, cipher TLSv1/SSLv3 DHE-RSA-AES256-GCM-SHA384, 4096 bit RSA
. 2016.05.31 10:17:09 - OpenVPN > [server] Peer Connection Initiated with [AF_INET]91.231.84.39:443
. 2016.05.31 10:17:11 - OpenVPN > SENT CONTROL [server]: 'PUSH_REQUEST' (status=1)
. 2016.05.31 10:17:27 - OpenVPN > PUSH: Received control message: 'PUSH_REPLY,redirect-gateway def1 bypass-dhcp,dhcp-option DNS 10.4.0.1,comp-lzo no,route-gateway 10.4.0.1,topology subnet,ping 10,ping-restart 60,ifconfig 10.4.1.0 255.255.0.0'
. 2016.05.31 10:17:27 - OpenVPN > OPTIONS IMPORT: timers and/or timeouts modified
. 2016.05.31 10:17:27 - OpenVPN > OPTIONS IMPORT: LZO parms modified
. 2016.05.31 10:17:27 - OpenVPN > OPTIONS IMPORT: --ifconfig/up options modified
. 2016.05.31 10:17:27 - OpenVPN > OPTIONS IMPORT: route options modified
. 2016.05.31 10:17:27 - OpenVPN > OPTIONS IMPORT: route-related options modified
. 2016.05.31 10:17:27 - OpenVPN > OPTIONS IMPORT: --ip-win32 and/or --dhcp-option options modified
. 2016.05.31 10:17:27 - OpenVPN > do_ifconfig, tt->ipv6=0, tt->did_ifconfig_ipv6_setup=0
. 2016.05.31 10:17:27 - OpenVPN > open_tun, tt->ipv6=0
. 2016.05.31 10:17:27 - OpenVPN > TAP-WIN32 device [Ethernet 4] opened: \\.\Global\{13FA5C83-1319-4706-8D85-06FBA481BBE7}.tap
. 2016.05.31 10:17:27 - OpenVPN > TAP-Windows Driver Version 9.9
. 2016.05.31 10:17:27 - OpenVPN > Set TAP-Windows TUN subnet mode network/local/netmask = 10.4.0.0/10.4.1.0/255.255.0.0 [sUCCEEDED]
. 2016.05.31 10:17:27 - OpenVPN > Notified TAP-Windows driver to set a DHCP IP/netmask of 10.4.1.0/255.255.0.0 on interface {13FA5C83-1319-4706-8D85-06FBA481BBE7} [DHCP-serv: 10.4.255.254, lease-time: 31536000]
. 2016.05.31 10:17:27 - OpenVPN > Successful ARP Flush on interface [2] {13FA5C83-1319-4706-8D85-06FBA481BBE7}
. 2016.05.31 10:17:32 - OpenVPN > TEST ROUTES: 1/1 succeeded len=0 ret=1 a=0 u/d=up
. 2016.05.31 10:17:32 - OpenVPN > C:\WINDOWS\system32\route.exe ADD 91.231.84.39 MASK 255.255.255.255 192.168.1.254
. 2016.05.31 10:17:32 - OpenVPN > ROUTE: CreateIpForwardEntry succeeded with dwForwardMetric1=20 and dwForwardType=4
. 2016.05.31 10:17:32 - OpenVPN > Route addition via IPAPI succeeded [adaptive]
. 2016.05.31 10:17:32 - OpenVPN > C:\WINDOWS\system32\route.exe ADD 192.168.1.254 MASK 255.255.255.255 192.168.1.254 IF 13
. 2016.05.31 10:17:32 - OpenVPN > C:\WINDOWS\system32\route.exe ADD 0.0.0.0 MASK 128.0.0.0 10.4.0.1
. 2016.05.31 10:17:32 - OpenVPN > ROUTE: CreateIpForwardEntry succeeded with dwForwardMetric1=30 and dwForwardType=4
. 2016.05.31 10:17:32 - OpenVPN > C:\WINDOWS\system32\route.exe ADD 128.0.0.0 MASK 128.0.0.0 10.4.0.1
. 2016.05.31 10:17:32 - Starting Management Interface
. 2016.05.31 10:17:32 - OpenVPN > Initialization Sequence Completed
I 2016.05.31 10:17:32 - DNS of a network adapter forced (Realtek PCIe FE Family Controller)
I 2016.05.31 10:17:32 - DNS of a network adapter forced (TAP-Windows Adapter V9)
I 2016.05.31 10:17:32 - Flushing DNS
I 2016.05.31 10:17:32 - Checking route
W 2016.05.31 10:18:22 - The operation has timed out
! 2016.05.31 10:18:23 - Disconnecting
. 2016.05.31 10:18:23 - Management - Send 'signal SIGTERM'
. 2016.05.31 10:18:23 - OpenVpn Management > >INFO:OpenVPN Management Interface Version 1 -- type 'help' for more info
. 2016.05.31 10:18:23 - OpenVPN > MANAGEMENT: CMD 'signal SIGTERM'
. 2016.05.31 10:18:23 - OpenVPN > SIGTERM received, sending exit notification to peer
. 2016.05.31 10:18:28 - OpenVPN > C:\WINDOWS\system32\route.exe DELETE 91.231.84.39 MASK 255.255.255.255 192.168.1.254
. 2016.05.31 10:18:28 - OpenVPN > Route deletion via IPAPI succeeded [adaptive]
. 2016.05.31 10:18:28 - OpenVPN > C:\WINDOWS\system32\route.exe DELETE 192.168.1.254 MASK 255.255.255.255 192.168.1.254
. 2016.05.31 10:18:28 - OpenVPN > C:\WINDOWS\system32\route.exe DELETE 0.0.0.0 MASK 128.0.0.0 10.4.0.1
. 2016.05.31 10:18:28 - OpenVPN > C:\WINDOWS\system32\route.exe DELETE 128.0.0.0 MASK 128.0.0.0 10.4.0.1
. 2016.05.31 10:18:28 - OpenVPN > Closing TUN/TAP interface
. 2016.05.31 10:18:28 - OpenVPN > SIGTERM[soft,exit-with-notification] received, process exiting
. 2016.05.31 10:18:28 - Connection terminated.
I 2016.05.31 10:18:28 - DNS of a network adapter restored to original settings (Realtek PCIe FE Family Controller)
I 2016.05.31 10:18:28 - DNS of a network adapter restored to original settings (TAP-Windows Adapter V9)
I 2016.05.31 10:18:31 - Checking authorization ...
I 2016.05.31 10:18:32 - Cancel requested.
I 2016.05.31 10:18:32 - IPv6 restored.
! 2016.05.31 10:18:32 - Session terminated.
I 2016.05.31 10:18:55 - Session starting.
I 2016.05.31 10:18:56 - IPv6 disabled.
I 2016.05.31 10:18:56 - Checking authorization ...
! 2016.05.31 10:18:56 - Connecting to Caph (Netherlands, Alblasserdam)
. 2016.05.31 10:18:56 - OpenVPN > OpenVPN 2.3.8 x86_64-w64-mingw32 [sSL (OpenSSL)] [LZO] [iPv6] built on Aug 13 2015
. 2016.05.31 10:18:56 - OpenVPN > library versions: OpenSSL 1.0.2d 9 Jul 2015, LZO 2.08
. 2016.05.31 10:18:56 - OpenVPN > MANAGEMENT: TCP Socket listening on [AF_INET]127.0.0.1:3100
. 2016.05.31 10:18:56 - OpenVPN > Control Channel Authentication: tls-auth using INLINE static key file
. 2016.05.31 10:18:56 - OpenVPN > Outgoing Control Channel Authentication: Using 160 bit message hash 'SHA1' for HMAC authentication
. 2016.05.31 10:18:56 - OpenVPN > Incoming Control Channel Authentication: Using 160 bit message hash 'SHA1' for HMAC authentication
. 2016.05.31 10:18:56 - OpenVPN > Socket Buffers: R=[65536->131072] S=[65536->131072]
. 2016.05.31 10:18:56 - OpenVPN > UDPv4 link local: [undef]
. 2016.05.31 10:18:56 - OpenVPN > UDPv4 link remote: [AF_INET]213.152.162.169:443
. 2016.05.31 10:18:56 - OpenVPN > TLS: Initial packet from [AF_INET]213.152.162.169:443, sid=959266ce 797e6c9e
. 2016.05.31 10:18:57 - OpenVPN > VERIFY OK: depth=1, C=IT, ST=IT, L=Perugia, O=airvpn.org, CN=airvpn.org CA, emailAddress=info@airvpn.org
. 2016.05.31 10:18:57 - OpenVPN > Validating certificate key usage
. 2016.05.31 10:18:57 - OpenVPN > ++ Certificate has key usage  00a0, expects 00a0
. 2016.05.31 10:18:57 - OpenVPN > VERIFY KU OK
. 2016.05.31 10:18:57 - OpenVPN > Validating certificate extended key usage
. 2016.05.31 10:18:57 - OpenVPN > ++ Certificate has EKU (str) TLS Web Server Authentication, expects TLS Web Server Authentication
. 2016.05.31 10:18:57 - OpenVPN > VERIFY EKU OK
. 2016.05.31 10:18:57 - OpenVPN > VERIFY OK: depth=0, C=IT, ST=IT, L=Perugia, O=airvpn.org, CN=server, emailAddress=info@airvpn.org
. 2016.05.31 10:18:57 - OpenVPN > Data Channel Encrypt: Cipher 'AES-256-CBC' initialized with 256 bit key
. 2016.05.31 10:18:57 - OpenVPN > Data Channel Encrypt: Using 160 bit message hash 'SHA1' for HMAC authentication
. 2016.05.31 10:18:57 - OpenVPN > Data Channel Decrypt: Cipher 'AES-256-CBC' initialized with 256 bit key
. 2016.05.31 10:18:57 - OpenVPN > Data Channel Decrypt: Using 160 bit message hash 'SHA1' for HMAC authentication
. 2016.05.31 10:18:57 - OpenVPN > Control Channel: TLSv1.2, cipher TLSv1/SSLv3 DHE-RSA-AES256-GCM-SHA384, 4096 bit RSA
. 2016.05.31 10:18:57 - OpenVPN > [server] Peer Connection Initiated with [AF_INET]213.152.162.169:443
. 2016.05.31 10:18:59 - OpenVPN > SENT CONTROL [server]: 'PUSH_REQUEST' (status=1)
. 2016.05.31 10:18:59 - OpenVPN > PUSH: Received control message: 'PUSH_REPLY,redirect-gateway def1 bypass-dhcp,dhcp-option DNS 10.4.0.1,comp-lzo no,route-gateway 10.4.0.1,topology subnet,ping 10,ping-restart 60,ifconfig 10.4.40.45 255.255.0.0'
. 2016.05.31 10:18:59 - OpenVPN > OPTIONS IMPORT: timers and/or timeouts modified
. 2016.05.31 10:18:59 - OpenVPN > OPTIONS IMPORT: LZO parms modified
. 2016.05.31 10:18:59 - OpenVPN > OPTIONS IMPORT: --ifconfig/up options modified
. 2016.05.31 10:18:59 - OpenVPN > OPTIONS IMPORT: route options modified
. 2016.05.31 10:18:59 - OpenVPN > OPTIONS IMPORT: route-related options modified
. 2016.05.31 10:18:59 - OpenVPN > OPTIONS IMPORT: --ip-win32 and/or --dhcp-option options modified
. 2016.05.31 10:18:59 - OpenVPN > do_ifconfig, tt->ipv6=0, tt->did_ifconfig_ipv6_setup=0
. 2016.05.31 10:18:59 - OpenVPN > open_tun, tt->ipv6=0
. 2016.05.31 10:19:00 - OpenVPN > TAP-WIN32 device [Ethernet 4] opened: \\.\Global\{13FA5C83-1319-4706-8D85-06FBA481BBE7}.tap
. 2016.05.31 10:19:00 - OpenVPN > TAP-Windows Driver Version 9.9
. 2016.05.31 10:19:00 - OpenVPN > Set TAP-Windows TUN subnet mode network/local/netmask = 10.4.0.0/10.4.40.45/255.255.0.0 [sUCCEEDED]
. 2016.05.31 10:19:00 - OpenVPN > Notified TAP-Windows driver to set a DHCP IP/netmask of 10.4.40.45/255.255.0.0 on interface {13FA5C83-1319-4706-8D85-06FBA481BBE7} [DHCP-serv: 10.4.255.254, lease-time: 31536000]
. 2016.05.31 10:19:00 - OpenVPN > Successful ARP Flush on interface [2] {13FA5C83-1319-4706-8D85-06FBA481BBE7}
. 2016.05.31 10:19:04 - OpenVPN > TEST ROUTES: 1/1 succeeded len=0 ret=1 a=0 u/d=up
. 2016.05.31 10:19:04 - OpenVPN > C:\WINDOWS\system32\route.exe ADD 213.152.162.169 MASK 255.255.255.255 192.168.1.254
. 2016.05.31 10:19:04 - OpenVPN > ROUTE: CreateIpForwardEntry succeeded with dwForwardMetric1=20 and dwForwardType=4
. 2016.05.31 10:19:04 - OpenVPN > Route addition via IPAPI succeeded [adaptive]
. 2016.05.31 10:19:04 - OpenVPN > C:\WINDOWS\system32\route.exe ADD 192.168.1.254 MASK 255.255.255.255 192.168.1.254 IF 13
. 2016.05.31 10:19:04 - OpenVPN > C:\WINDOWS\system32\route.exe ADD 0.0.0.0 MASK 128.0.0.0 10.4.0.1
. 2016.05.31 10:19:04 - OpenVPN > ROUTE: CreateIpForwardEntry succeeded with dwForwardMetric1=30 and dwForwardType=4
. 2016.05.31 10:19:04 - OpenVPN > C:\WINDOWS\system32\route.exe ADD 128.0.0.0 MASK 128.0.0.0 10.4.0.1
. 2016.05.31 10:19:04 - Starting Management Interface
. 2016.05.31 10:19:04 - OpenVPN > Initialization Sequence Completed
I 2016.05.31 10:19:04 - Flushing DNS
I 2016.05.31 10:19:04 - Checking route
I 2016.05.31 10:19:04 - Checking DNS
! 2016.05.31 10:19:04 - Connected.
. 2016.05.31 10:19:04 - OpenVPN > MANAGEMENT: Client connected from [AF_INET]127.0.0.1:3100
. 2016.05.31 10:19:04 - OpenVpn Management > >INFO:OpenVPN Management Interface Version 1 -- type 'help' for more info
. 2016.05.31 10:20:15 - OpenVPN > Authenticate/Decrypt packet error: bad packet ID (may be a replay): [ #19486 ] -- see the man page entry for --no-replay and --replay-window for more info or silence this warning with --mute-replay-warnings
. 2016.05.31 10:20:17 - OpenVPN > Authenticate/Decrypt packet error: bad packet ID (may be a replay): [ #23483 ] -- see the man page entry for --no-replay and --replay-window for more info or silence this warning with --mute-replay-warnings
. 2016.05.31 10:20:25 - OpenVPN > Authenticate/Decrypt packet error: bad packet ID (may be a replay): [ #34664 ] -- see the man page entry for --no-replay and --replay-window for more info or silence this warning with --mute-replay-warnings
. 2016.05.31 10:20:25 - OpenVPN > Authenticate/Decrypt packet error: bad packet ID (may be a replay): [ #34665 ] -- see the man page entry for --no-replay and --replay-window for more info or silence this warning with --mute-replay-warnings
. 2016.05.31 10:20:25 - OpenVPN > Authenticate/Decrypt packet error: bad packet ID (may be a replay): [ #34666 ] -- see the man page entry for --no-replay and --replay-window for more info or silence this warning with --mute-replay-warnings
. 2016.05.31 10:20:25 - OpenVPN > Authenticate/Decrypt packet error: bad packet ID (may be a replay): [ #34667 ] -- see the man page entry for --no-replay and --replay-window for more info or silence this warning with --mute-replay-warnings
. 2016.05.31 10:20:25 - OpenVPN > Authenticate/Decrypt packet error: bad packet ID (may be a replay): [ #34668 ] -- see the man page entry for --no-replay and --replay-window for more info or silence this warning with --mute-replay-warnings
. 2016.05.31 10:20:25 - OpenVPN > Authenticate/Decrypt packet error: bad packet ID (may be a replay): [ #34669 ] -- see the man page entry for --no-replay and --replay-window for more info or silence this warning with --mute-replay-warnings
. 2016.05.31 10:20:25 - OpenVPN > Authenticate/Decrypt packet error: bad packet ID (may be a replay): [ #34674 ] -- see the man page entry for --no-replay and --replay-window for more info or silence this warning with --mute-replay-warnings
. 2016.05.31 10:20:25 - OpenVPN > Authenticate/Decrypt packet error: bad packet ID (may be a replay): [ #34676 ] -- see the man page entry for --no-replay and --replay-window for more info or silence this warning with --mute-replay-warnings
. 2016.05.31 10:20:25 - OpenVPN > Authenticate/Decrypt packet error: bad packet ID (may be a replay): [ #34677 ] -- see the man page entry for --no-replay and --replay-window for more info or silence this warning with --mute-replay-warnings
. 2016.05.31 10:20:40 - OpenVPN > Authenticate/Decrypt packet error: bad packet ID (may be a replay): [ #61925 ] -- see the man page entry for --no-replay and --replay-window for more info or silence this warning with --mute-replay-warnings
. 2016.05.31 10:20:43 - OpenVPN > Authenticate/Decrypt packet error: bad packet ID (may be a replay): [ #66216 ] -- see the man page entry for --no-replay and --replay-window for more info or silence this warning with --mute-replay-warnings
. 2016.05.31 10:20:43 - OpenVPN > Authenticate/Decrypt packet error: bad packet ID (may be a replay): [ #66217 ] -- see the man page entry for --no-replay and --replay-window for more info or silence this warning with --mute-replay-warnings
. 2016.05.31 10:20:43 - OpenVPN > Authenticate/Decrypt packet error: bad packet ID (may be a replay): [ #66218 ] -- see the man page entry for --no-replay and --replay-window for more info or silence this warning with --mute-replay-warnings
. 2016.05.31 10:20:43 - OpenVPN > Authenticate/Decrypt packet error: bad packet ID (may be a replay): [ #66219 ] -- see the man page entry for --no-replay and --replay-window for more info or silence this warning with --mute-replay-warnings
. 2016.05.31 10:20:43 - OpenVPN > Authenticate/Decrypt packet error: bad packet ID (may be a replay): [ #66220 ] -- see the man page entry for --no-replay and --replay-window for more info or silence this warning with --mute-replay-warnings
. 2016.05.31 10:20:43 - OpenVPN > Authenticate/Decrypt packet error: bad packet ID (may be a replay): [ #66221 ] -- see the man page entry for --no-replay and --replay-window for more info or silence this warning with --mute-replay-warnings
. 2016.05.31 10:20:43 - OpenVPN > Authenticate/Decrypt packet error: bad packet ID (may be a replay): [ #66222 ] -- see the man page entry for --no-replay and --replay-window for more info or silence this warning with --mute-replay-warnings
. 2016.05.31 10:20:46 - OpenVPN > Authenticate/Decrypt packet error: bad packet ID (may be a replay): [ #71109 ] -- see the man page entry for --no-replay and --replay-window for more info or silence this warning with --mute-replay-warnings
. 2016.05.31 10:20:46 - OpenVPN > Authenticate/Decrypt packet error: bad packet ID (may be a replay): [ #71110 ] -- see the man page entry for --no-replay and --replay-window for more info or silence this warning with --mute-replay-warnings
. 2016.05.31 10:20:46 - OpenVPN > Authenticate/Decrypt packet error: bad packet ID (may be a replay): [ #71111 ] -- see the man page entry for --no-replay and --replay-window for more info or silence this warning with --mute-replay-warnings
. 2016.05.31 10:20:46 - OpenVPN > Authenticate/Decrypt packet error: bad packet ID (may be a replay): [ #71112 ] -- see the man page entry for --no-replay and --replay-window for more info or silence this warning with --mute-replay-warnings
. 2016.05.31 10:20:46 - OpenVPN > Authenticate/Decrypt packet error: bad packet ID (may be a replay): [ #71113 ] -- see the man page entry for --no-replay and --replay-window for more info or silence this warning with --mute-replay-warnings
. 2016.05.31 10:20:49 - OpenVPN > Authenticate/Decrypt packet error: bad packet ID (may be a replay): [ #77756 ] -- see the man page entry for --no-replay and --replay-window for more info or silence this warning with --mute-replay-warnings
. 2016.05.31 10:20:49 - OpenVPN > Authenticate/Decrypt packet error: bad packet ID (may be a replay): [ #77757 ] -- see the man page entry for --no-replay and --replay-window for more info or silence this warning with --mute-replay-warnings
. 2016.05.31 10:20:49 - OpenVPN > Authenticate/Decrypt packet error: bad packet ID (may be a replay): [ #77758 ] -- see the man page entry for --no-replay and --replay-window for more info or silence this warning with --mute-replay-warnings
. 2016.05.31 10:20:49 - OpenVPN > Authenticate/Decrypt packet error: bad packet ID (may be a replay): [ #77761 ] -- see the man page entry for --no-replay and --replay-window for more info or silence this warning with --mute-replay-warnings
. 2016.05.31 10:20:49 - OpenVPN > Authenticate/Decrypt packet error: bad packet ID (may be a replay): [ #77762 ] -- see the man page entry for --no-replay and --replay-window for more info or silence this warning with --mute-replay-warnings
. 2016.05.31 10:20:49 - OpenVPN > Authenticate/Decrypt packet error: bad packet ID (may be a replay): [ #77763 ] -- see the man page entry for --no-replay and --replay-window for more info or silence this warning with --mute-replay-warnings
. 2016.05.31 10:20:49 - OpenVPN > Authenticate/Decrypt packet error: bad packet ID (may be a replay): [ #77764 ] -- see the man page entry for --no-replay and --replay-window for more info or silence this warning with --mute-replay-warnings
. 2016.05.31 10:20:49 - OpenVPN > Authenticate/Decrypt packet error: bad packet ID (may be a replay): [ #77765 ] -- see the man page entry for --no-replay and --replay-window for more info or silence this warning with --mute-replay-warnings
. 2016.05.31 10:20:49 - OpenVPN > Authenticate/Decrypt packet error: bad packet ID (may be a replay): [ #77766 ] -- see the man page entry for --no-replay and --replay-window for more info or silence this warning with --mute-replay-warnings
. 2016.05.31 10:20:49 - OpenVPN > Authenticate/Decrypt packet error: bad packet ID (may be a replay): [ #77767 ] -- see the man page entry for --no-replay and --replay-window for more info or silence this warning with --mute-replay-warnings
. 2016.05.31 10:20:49 - OpenVPN > Authenticate/Decrypt packet error: bad packet ID (may be a replay): [ #77773 ] -- see the man page entry for --no-replay and --replay-window for more info or silence this warning with --mute-replay-warnings
. 2016.05.31 10:20:49 - OpenVPN > Authenticate/Decrypt packet error: bad packet ID (may be a replay): [ #77774 ] -- see the man page entry for --no-replay and --replay-window for more info or silence this warning with --mute-replay-warnings
. 2016.05.31 10:20:49 - OpenVPN > Authenticate/Decrypt packet error: bad packet ID (may be a replay): [ #77775 ] -- see the man page entry for --no-replay and --replay-window for more info or silence this warning with --mute-replay-warnings
. 2016.05.31 10:20:49 - OpenVPN > Authenticate/Decrypt packet error: bad packet ID (may be a replay): [ #77776 ] -- see the man page entry for --no-replay and --replay-window for more info or silence this warning with --mute-replay-warnings
. 2016.05.31 10:20:49 - OpenVPN > Authenticate/Decrypt packet error: bad packet ID (may be a replay): [ #77777 ] -- see the man page entry for --no-replay and --replay-window for more info or silence this warning with --mute-replay-warnings
. 2016.05.31 10:20:49 - OpenVPN > Authenticate/Decrypt packet error: bad packet ID (may be a replay): [ #77778 ] -- see the man page entry for --no-replay and --replay-window for more info or silence this warning with --mute-replay-warnings
. 2016.05.31 10:20:49 - OpenVPN > Authenticate/Decrypt packet error: bad packet ID (may be a replay): [ #77779 ] -- see the man page entry for --no-replay and --replay-window for more info or silence this warning with --mute-replay-warnings
. 2016.05.31 10:20:49 - OpenVPN > Authenticate/Decrypt packet error: bad packet ID (may be a replay): [ #77780 ] -- see the man page entry for --no-replay and --replay-window for more info or silence this warning with --mute-replay-warnings
. 2016.05.31 10:20:49 - OpenVPN > Authenticate/Decrypt packet error: bad packet ID (may be a replay): [ #77781 ] -- see the man page entry for --no-replay and --replay-window for more info or silence this warning with --mute-replay-warnings
. 2016.05.31 10:20:49 - OpenVPN > Authenticate/Decrypt packet error: bad packet ID (may be a replay): [ #77785 ] -- see the man page entry for --no-replay and --replay-window for more info or silence this warning with --mute-replay-warnings
. 2016.05.31 10:20:53 - OpenVPN > Authenticate/Decrypt packet error: bad packet ID (may be a replay): [ #85102 ] -- see the man page entry for --no-replay and --replay-window for more info or silence this warning with --mute-replay-warnings
. 2016.05.31 10:20:53 - OpenVPN > Authenticate/Decrypt packet error: bad packet ID (may be a replay): [ #85103 ] -- see the man page entry for --no-replay and --replay-window for more info or silence this warning with --mute-replay-warnings
. 2016.05.31 10:20:53 - OpenVPN > Authenticate/Decrypt packet error: bad packet ID (may be a replay): [ #85104 ] -- see the man page entry for --no-replay and --replay-window for more info or silence this warning with --mute-replay-warnings
. 2016.05.31 10:20:58 - OpenVPN > Authenticate/Decrypt packet error: bad packet ID (may be a replay): [ #95145 ] -- see the man page entry for --no-replay and --replay-window for more info or silence this warning with --mute-replay-warnings
. 2016.05.31 10:20:58 - OpenVPN > Authenticate/Decrypt packet error: bad packet ID (may be a replay): [ #95146 ] -- see the man page entry for --no-replay and --replay-window for more info or silence this warning with --mute-replay-warnings
. 2016.05.31 10:20:59 - OpenVPN > Authenticate/Decrypt packet error: bad packet ID (may be a replay): [ #97848 ] -- see the man page entry for --no-replay and --replay-window for more info or silence this warning with --mute-replay-warnings
. 2016.05.31 10:20:59 - OpenVPN > Authenticate/Decrypt packet error: bad packet ID (may be a replay): [ #97850 ] -- see the man page entry for --no-replay and --replay-window for more info or silence this warning with --mute-replay-warnings
. 2016.05.31 10:20:59 - OpenVPN > Authenticate/Decrypt packet error: bad packet ID (may be a replay): [ #97851 ] -- see the man page entry for --no-replay and --replay-window for more info or silence this warning with --mute-replay-warnings
. 2016.05.31 10:20:59 - OpenVPN > Authenticate/Decrypt packet error: bad packet ID (may be a replay): [ #97852 ] -- see the man page entry for --no-replay and --replay-window for more info or silence this warning with --mute-replay-warnings
. 2016.05.31 10:20:59 - OpenVPN > Authenticate/Decrypt packet error: bad packet ID (may be a replay): [ #97853 ] -- see the man page entry for --no-replay and --replay-window for more info or silence this warning with --mute-replay-warnings
. 2016.05.31 10:20:59 - OpenVPN > Authenticate/Decrypt packet error: bad packet ID (may be a replay): [ #97854 ] -- see the man page entry for --no-replay and --replay-window for more info or silence this warning with --mute-replay-warnings
. 2016.05.31 10:21:03 - OpenVPN > Authenticate/Decrypt packet error: bad packet ID (may be a replay): [ #106068 ] -- see the man page entry for --no-replay and --replay-window for more info or silence this warning with --mute-replay-warnings
. 2016.05.31 10:21:03 - OpenVPN > Authenticate/Decrypt packet error: bad packet ID (may be a replay): [ #106069 ] -- see the man page entry for --no-replay and --replay-window for more info or silence this warning with --mute-replay-warnings
. 2016.05.31 10:21:03 - OpenVPN > Authenticate/Decrypt packet error: bad packet ID (may be a replay): [ #106070 ] -- see the man page entry for --no-replay and --replay-window for more info or silence this warning with --mute-replay-warnings
. 2016.05.31 10:21:03 - OpenVPN > Authenticate/Decrypt packet error: bad packet ID (may be a replay): [ #106082 ] -- see the man page entry for --no-replay and --replay-window for more info or silence this warning with --mute-replay-warnings
. 2016.05.31 10:21:03 - OpenVPN > Authenticate/Decrypt packet error: bad packet ID (may be a replay): [ #106083 ] -- see the man page entry for --no-replay and --replay-window for more info or silence this warning with --mute-replay-warnings
. 2016.05.31 10:21:03 - OpenVPN > Authenticate/Decrypt packet error: bad packet ID (may be a replay): [ #106085 ] -- see the man page entry for --no-replay and --replay-window for more info or silence this warning with --mute-replay-warnings
. 2016.05.31 10:21:03 - OpenVPN > Authenticate/Decrypt packet error: bad packet ID (may be a replay): [ #106086 ] -- see the man page entry for --no-replay and --replay-window for more info or silence this warning with --mute-replay-warnings
. 2016.05.31 10:21:03 - OpenVPN > Authenticate/Decrypt packet error: bad packet ID (may be a replay): [ #106087 ] -- see the man page entry for --no-replay and --replay-window for more info or silence this warning with --mute-replay-warnings
. 2016.05.31 10:21:03 - OpenVPN > Authenticate/Decrypt packet error: bad packet ID (may be a replay): [ #106088 ] -- see the man page entry for --no-replay and --replay-window for more info or silence this warning with --mute-replay-warnings
. 2016.05.31 10:21:03 - OpenVPN > Authenticate/Decrypt packet error: bad packet ID (may be a replay): [ #106089 ] -- see the man page entry for --no-replay and --replay-window for more info or silence this warning with --mute-replay-warnings
. 2016.05.31 10:21:03 - OpenVPN > Authenticate/Decrypt packet error: bad packet ID (may be a replay): [ #106090 ] -- see the man page entry for --no-replay and --replay-window for more info or silence this warning with --mute-replay-warnings
. 2016.05.31 10:21:03 - OpenVPN > Authenticate/Decrypt packet error: bad packet ID (may be a replay): [ #106091 ] -- see the man page entry for --no-replay and --replay-window for more info or silence this warning with --mute-replay-warnings
. 2016.05.31 10:21:03 - OpenVPN > Authenticate/Decrypt packet error: bad packet ID (may be a replay): [ #106093 ] -- see the man page entry for --no-replay and --replay-window for more info or silence this warning with --mute-replay-warnings
. 2016.05.31 10:21:03 - OpenVPN > Authenticate/Decrypt packet error: bad packet ID (may be a replay): [ #106098 ] -- see the man page entry for --no-replay and --replay-window for more info or silence this warning with --mute-replay-warnings
. 2016.05.31 10:21:03 - OpenVPN > Authenticate/Decrypt packet error: bad packet ID (may be a replay): [ #106099 ] -- see the man page entry for --no-replay and --replay-window for more info or silence this warning with --mute-replay-warnings
. 2016.05.31 10:21:03 - OpenVPN > Authenticate/Decrypt packet error: bad packet ID (may be a replay): [ #106100 ] -- see the man page entry for --no-replay and --replay-window for more info or silence this warning with --mute-replay-warnings
. 2016.05.31 10:21:03 - OpenVPN > Authenticate/Decrypt packet error: bad packet ID (may be a replay): [ #106101 ] -- see the man page entry for --no-replay and --replay-window for more info or silence this warning with --mute-replay-warnings
. 2016.05.31 10:21:03 - OpenVPN > Authenticate/Decrypt packet error: bad packet ID (may be a replay): [ #106102 ] -- see the man page entry for --no-replay and --replay-window for more info or silence this warning with --mute-replay-warnings
. 2016.05.31 10:21:03 - OpenVPN > Authenticate/Decrypt packet error: bad packet ID (may be a replay): [ #106103 ] -- see the man page entry for --no-replay and --replay-window for more info or silence this warning with --mute-replay-warnings
. 2016.05.31 10:21:03 - OpenVPN > Authenticate/Decrypt packet error: bad packet ID (may be a replay): [ #106104 ] -- see the man page entry for --no-replay and --replay-window for more info or silence this warning with --mute-replay-warnings
. 2016.05.31 10:21:03 - OpenVPN > Authenticate/Decrypt packet error: bad packet ID (may be a replay): [ #106105 ] -- see the man page entry for --no-replay and --replay-window for more info or silence this warning with --mute-replay-warnings
. 2016.05.31 10:21:03 - OpenVPN > Authenticate/Decrypt packet error: bad packet ID (may be a replay): [ #106106 ] -- see the man page entry for --no-replay and --replay-window for more info or silence this warning with --mute-replay-warnings
. 2016.05.31 10:21:04 - OpenVPN > Authenticate/Decrypt packet error: bad packet ID (may be a replay): [ #107501 ] -- see the man page entry for --no-replay and --replay-window for more info or silence this warning with --mute-replay-warnings
. 2016.05.31 10:21:04 - OpenVPN > Authenticate/Decrypt packet error: bad packet ID (may be a replay): [ #107502 ] -- see the man page entry for --no-replay and --replay-window for more info or silence this warning with --mute-replay-warnings
. 2016.05.31 10:21:04 - OpenVPN > Authenticate/Decrypt packet error: bad packet ID (may be a replay): [ #107503 ] -- see the man page entry for --no-replay and --replay-window for more info or silence this warning with --mute-replay-warnings
. 2016.05.31 10:21:04 - OpenVPN > Authenticate/Decrypt packet error: bad packet ID (may be a replay): [ #107504 ] -- see the man page entry for --no-replay and --replay-window for more info or silence this warning with --mute-replay-warnings
. 2016.05.31 10:21:04 - OpenVPN > Authenticate/Decrypt packet error: bad packet ID (may be a replay): [ #107516 ] -- see the man page entry for --no-replay and --replay-window for more info or silence this warning with --mute-replay-warnings
. 2016.05.31 10:21:04 - OpenVPN > Authenticate/Decrypt packet error: bad packet ID (may be a replay): [ #107517 ] -- see the man page entry for --no-replay and --replay-window for more info or silence this warning with --mute-replay-warnings
. 2016.05.31 10:21:04 - OpenVPN > Authenticate/Decrypt packet error: bad packet ID (may be a replay): [ #107518 ] -- see the man page entry for --no-replay and --replay-window for more info or silence this warning with --mute-replay-warnings
. 2016.05.31 10:21:04 - OpenVPN > Authenticate/Decrypt packet error: bad packet ID (may be a replay): [ #107519 ] -- see the man page entry for --no-replay and --replay-window for more info or silence this warning with --mute-replay-warnings
. 2016.05.31 10:21:04 - OpenVPN > Authenticate/Decrypt packet error: bad packet ID (may be a replay): [ #107520 ] -- see the man page entry for --no-replay and --replay-window for more info or silence this warning with --mute-replay-warnings
. 2016.05.31 10:21:04 - OpenVPN > Authenticate/Decrypt packet error: bad packet ID (may be a replay): [ #107523 ] -- see the man page entry for --no-replay and --replay-window for more info or silence this warning with --mute-replay-warnings
. 2016.05.31 10:21:04 - OpenVPN > Authenticate/Decrypt packet error: bad packet ID (may be a replay): [ #107524 ] -- see the man page entry for --no-replay and --replay-window for more info or silence this warning with --mute-replay-warnings
. 2016.05.31 10:21:04 - OpenVPN > Authenticate/Decrypt packet error: bad packet ID (may be a replay): [ #107525 ] -- see the man page entry for --no-replay and --replay-window for more info or silence this warning with --mute-replay-warnings
. 2016.05.31 10:21:04 - OpenVPN > Authenticate/Decrypt packet error: bad packet ID (may be a replay): [ #107526 ] -- see the man page entry for --no-replay and --replay-window for more info or silence this warning with --mute-replay-warnings
. 2016.05.31 10:21:04 - OpenVPN > Authenticate/Decrypt packet error: bad packet ID (may be a replay): [ #107527 ] -- see the man page entry for --no-replay and --replay-window for more info or silence this warning with --mute-replay-warnings
. 2016.05.31 10:21:04 - OpenVPN > Authenticate/Decrypt packet error: bad packet ID (may be a replay): [ #107528 ] -- see the man page entry for --no-replay and --replay-window for more info or silence this warning with --mute-replay-warnings
. 2016.05.31 10:21:04 - OpenVPN > Authenticate/Decrypt packet error: bad packet ID (may be a replay): [ #107529 ] -- see the man page entry for --no-replay and --replay-window for more info or silence this warning with --mute-replay-warnings
. 2016.05.31 10:21:04 - OpenVPN > Authenticate/Decrypt packet error: bad packet ID (may be a replay): [ #107531 ] -- see the man page entry for --no-replay and --replay-window for more info or silence this warning with --mute-replay-warnings
. 2016.05.31 10:21:04 - OpenVPN > Authenticate/Decrypt packet error: bad packet ID (may be a replay): [ #107535 ] -- see the man page entry for --no-replay and --replay-window for more info or silence this warning with --mute-replay-warnings
. 2016.05.31 10:21:04 - OpenVPN > Authenticate/Decrypt packet error: bad packet ID (may be a replay): [ #107536 ] -- see the man page entry for --no-replay and --replay-window for more info or silence this warning with --mute-replay-warnings
. 2016.05.31 10:21:07 - OpenVPN > Authenticate/Decrypt packet error: bad packet ID (may be a replay): [ #114239 ] -- see the man page entry for --no-replay and --replay-window for more info or silence this warning with --mute-replay-warnings
. 2016.05.31 10:21:07 - OpenVPN > Authenticate/Decrypt packet error: bad packet ID (may be a replay): [ #114240 ] -- see the man page entry for --no-replay and --replay-window for more info or silence this warning with --mute-replay-warnings
. 2016.05.31 10:21:07 - OpenVPN > Authenticate/Decrypt packet error: bad packet ID (may be a replay): [ #114241 ] -- see the man page entry for --no-replay and --replay-window for more info or silence this warning with --mute-replay-warnings
. 2016.05.31 10:21:07 - OpenVPN > Authenticate/Decrypt packet error: bad packet ID (may be a replay): [ #114242 ] -- see the man page entry for --no-replay and --replay-window for more info or silence this warning with --mute-replay-warnings
. 2016.05.31 10:21:07 - OpenVPN > Authenticate/Decrypt packet error: bad packet ID (may be a replay): [ #114243 ] -- see the man page entry for --no-replay and --replay-window for more info or silence this warning with --mute-replay-warnings
. 2016.05.31 10:21:07 - OpenVPN > Authenticate/Decrypt packet error: bad packet ID (may be a replay): [ #114245 ] -- see the man page entry for --no-replay and --replay-window for more info or silence this warning with --mute-replay-warnings
. 2016.05.31 10:21:07 - OpenVPN > Authenticate/Decrypt packet error: bad packet ID (may be a replay): [ #114246 ] -- see the man page entry for --no-replay and --replay-window for more info or silence this warning with --mute-replay-warnings
. 2016.05.31 10:21:07 - OpenVPN > Authenticate/Decrypt packet error: bad packet ID (may be a replay): [ #114440 ] -- see the man page entry for --no-replay and --replay-window for more info or silence this warning with --mute-replay-warnings
. 2016.05.31 10:21:07 - OpenVPN > Authenticate/Decrypt packet error: bad packet ID (may be a replay): [ #114441 ] -- see the man page entry for --no-replay and --replay-window for more info or silence this warning with --mute-replay-warnings
. 2016.05.31 10:21:07 - OpenVPN > Authenticate/Decrypt packet error: bad packet ID (may be a replay): [ #114442 ] -- see the man page entry for --no-replay and --replay-window for more info or silence this warning with --mute-replay-warnings
. 2016.05.31 10:21:07 - OpenVPN > Authenticate/Decrypt packet error: bad packet ID (may be a replay): [ #114444 ] -- see the man page entry for --no-replay and --replay-window for more info or silence this warning with --mute-replay-warnings
. 2016.05.31 10:21:07 - OpenVPN > Authenticate/Decrypt packet error: bad packet ID (may be a replay): [ #114445 ] -- see the man page entry for --no-replay and --replay-window for more info or silence this warning with --mute-replay-warnings
. 2016.05.31 10:21:07 - OpenVPN > Authenticate/Decrypt packet error: bad packet ID (may be a replay): [ #114446 ] -- see the man page entry for --no-replay and --replay-window for more info or silence this warning with --mute-replay-warnings
. 2016.05.31 10:21:07 - OpenVPN > Authenticate/Decrypt packet error: bad packet ID (may be a replay): [ #114447 ] -- see the man page entry for --no-replay and --replay-window for more info or silence this warning with --mute-replay-warnings
. 2016.05.31 10:21:07 - OpenVPN > Authenticate/Decrypt packet error: bad packet ID (may be a replay): [ #114448 ] -- see the man page entry for --no-replay and --replay-window for more info or silence this warning with --mute-replay-warnings
. 2016.05.31 10:21:09 - OpenVPN > Authenticate/Decrypt packet error: bad packet ID (may be a replay): [ #117777 ] -- see the man page entry for --no-replay and --replay-window for more info or silence this warning with --mute-replay-warnings
. 2016.05.31 10:21:09 - OpenVPN > Authenticate/Decrypt packet error: bad packet ID (may be a replay): [ #117778 ] -- see the man page entry for --no-replay and --replay-window for more info or silence this warning with --mute-replay-warnings
. 2016.05.31 10:21:09 - OpenVPN > Authenticate/Decrypt packet error: bad packet ID (may be a replay): [ #117779 ] -- see the man page entry for --no-replay and --replay-window for more info or silence this warning with --mute-replay-warnings
. 2016.05.31 10:21:09 - OpenVPN > Authenticate/Decrypt packet error: bad packet ID (may be a replay): [ #117780 ] -- see the man page entry for --no-replay and --replay-window for more info or silence this warning with --mute-replay-warnings
. 2016.05.31 10:21:09 - OpenVPN > Authenticate/Decrypt packet error: bad packet ID (may be a replay): [ #117781 ] -- see the man page entry for --no-replay and --replay-window for more info or silence this warning with --mute-replay-warnings
. 2016.05.31 10:21:09 - OpenVPN > Authenticate/Decrypt packet error: bad packet ID (may be a replay): [ #117782 ] -- see the man page entry for --no-replay and --replay-window for more info or silence this warning with --mute-replay-warnings
. 2016.05.31 10:21:09 - OpenVPN > Authenticate/Decrypt packet error: bad packet ID (may be a replay): [ #117783 ] -- see the man page entry for --no-replay and --replay-window for more info or silence this warning with --mute-replay-warnings
. 2016.05.31 10:21:09 - OpenVPN > Authenticate/Decrypt packet error: bad packet ID (may be a replay): [ #117784 ] -- see the man page entry for --no-replay and --replay-window for more info or silence this warning with --mute-replay-warnings
. 2016.05.31 10:21:09 - OpenVPN > Authenticate/Decrypt packet error: bad packet ID (may be a replay): [ #117785 ] -- see the man page entry for --no-replay and --replay-window for more info or silence this warning with --mute-replay-warnings
. 2016.05.31 10:21:09 - OpenVPN > Authenticate/Decrypt packet error: bad packet ID (may be a replay): [ #117786 ] -- see the man page entry for --no-replay and --replay-window for more info or silence this warning with --mute-replay-warnings
. 2016.05.31 10:21:09 - OpenVPN > Authenticate/Decrypt packet error: bad packet ID (may be a replay): [ #117787 ] -- see the man page entry for --no-replay and --replay-window for more info or silence this warning with --mute-replay-warnings
. 2016.05.31 10:21:09 - OpenVPN > Authenticate/Decrypt packet error: bad packet ID (may be a replay): [ #117788 ] -- see the man page entry for --no-replay and --replay-window for more info or silence this warning with --mute-replay-warnings
. 2016.05.31 10:21:09 - OpenVPN > Authenticate/Decrypt packet error: bad packet ID (may be a replay): [ #117789 ] -- see the man page entry for --no-replay and --replay-window for more info or silence this warning with --mute-replay-warnings
. 2016.05.31 10:21:09 - OpenVPN > Authenticate/Decrypt packet error: bad packet ID (may be a replay): [ #117790 ] -- see the man page entry for --no-replay and --replay-window for more info or silence this warning with --mute-replay-warnings
. 2016.05.31 10:21:09 - OpenVPN > Authenticate/Decrypt packet error: bad packet ID (may be a replay): [ #117798 ] -- see the man page entry for --no-replay and --replay-window for more info or silence this warning with --mute-replay-warnings
. 2016.05.31 10:21:09 - OpenVPN > Authenticate/Decrypt packet error: bad packet ID (may be a replay): [ #117799 ] -- see the man page entry for --no-replay and --replay-window for more info or silence this warning with --mute-replay-warnings
. 2016.05.31 10:21:09 - OpenVPN > Authenticate/Decrypt packet error: bad packet ID (may be a replay): [ #117800 ] -- see the man page entry for --no-replay and --replay-window for more info or silence this warning with --mute-replay-warnings
. 2016.05.31 10:21:09 - OpenVPN > Authenticate/Decrypt packet error: bad packet ID (may be a replay): [ #117801 ] -- see the man page entry for --no-replay and --replay-window for more info or silence this warning with --mute-replay-warnings
. 2016.05.31 10:21:09 - OpenVPN > Authenticate/Decrypt packet error: bad packet ID (may be a replay): [ #117802 ] -- see the man page entry for --no-replay and --replay-window for more info or silence this warning with --mute-replay-warnings
. 2016.05.31 10:21:09 - OpenVPN > Authenticate/Decrypt packet error: bad packet ID (may be a replay): [ #117803 ] -- see the man page entry for --no-replay and --replay-window for more info or silence this warning with --mute-replay-warnings
. 2016.05.31 10:21:09 - OpenVPN > Authenticate/Decrypt packet error: bad packet ID (may be a replay): [ #117807 ] -- see the man page entry for --no-replay and --replay-window for more info or silence this warning with --mute-replay-warnings
. 2016.05.31 10:21:09 - OpenVPN > Authenticate/Decrypt packet error: bad packet ID (may be a replay): [ #117808 ] -- see the man page entry for --no-replay and --replay-window for more info or silence this warning with --mute-replay-warnings
. 2016.05.31 10:21:09 - OpenVPN > Authenticate/Decrypt packet error: bad packet ID (may be a replay): [ #117809 ] -- see the man page entry for --no-replay and --replay-window for more info or silence this warning with --mute-replay-warnings
. 2016.05.31 10:21:09 - OpenVPN > Authenticate/Decrypt packet error: bad packet ID (may be a replay): [ #117810 ] -- see the man page entry for --no-replay and --replay-window for more info or silence this warning with --mute-replay-warnings
. 2016.05.31 10:21:09 - OpenVPN > Authenticate/Decrypt packet error: bad packet ID (may be a replay): [ #117811 ] -- see the man page entry for --no-replay and --replay-window for more info or silence this warning with --mute-replay-warnings
. 2016.05.31 10:21:09 - OpenVPN > Authenticate/Decrypt packet error: bad packet ID (may be a replay): [ #117812 ] -- see the man page entry for --no-replay and --replay-window for more info or silence this warning with --mute-replay-warnings
. 2016.05.31 10:21:09 - OpenVPN > Authenticate/Decrypt packet error: bad packet ID (may be a replay): [ #117813 ] -- see the man page entry for --no-replay and --replay-window for more info or silence this warning with --mute-replay-warnings
. 2016.05.31 10:21:09 - OpenVPN > Authenticate/Decrypt packet error: bad packet ID (may be a replay): [ #117814 ] -- see the man page entry for --no-replay and --replay-window for more info or silence this warning with --mute-replay-warnings
. 2016.05.31 10:21:09 - OpenVPN > Authenticate/Decrypt packet error: bad packet ID (may be a replay): [ #117815 ] -- see the man page entry for --no-replay and --replay-window for more info or silence this warning with --mute-replay-warnings
. 2016.05.31 10:21:09 - OpenVPN > Authenticate/Decrypt packet error: bad packet ID (may be a replay): [ #117816 ] -- see the man page entry for --no-replay and --replay-window for more info or silence this warning with --mute-replay-warnings
. 2016.05.31 10:21:09 - OpenVPN > Authenticate/Decrypt packet error: bad packet ID (may be a replay): [ #117817 ] -- see the man page entry for --no-replay and --replay-window for more info or silence this warning with --mute-replay-warnings
. 2016.05.31 10:21:09 - OpenVPN > Authenticate/Decrypt packet error: bad packet ID (may be a replay): [ #117818 ] -- see the man page entry for --no-replay and --replay-window for more info or silence this warning with --mute-replay-warnings
. 2016.05.31 10:21:09 - OpenVPN > Authenticate/Decrypt packet error: bad packet ID (may be a replay): [ #117819 ] -- see the man page entry for --no-replay and --replay-window for more info or silence this warning with --mute-replay-warnings
. 2016.05.31 10:21:09 - OpenVPN > Authenticate/Decrypt packet error: bad packet ID (may be a replay): [ #117820 ] -- see the man page entry for --no-replay and --replay-window for more info or silence this warning with --mute-replay-warnings
. 2016.05.31 10:21:09 - OpenVPN > Authenticate/Decrypt packet error: bad packet ID (may be a replay): [ #117821 ] -- see the man page entry for --no-replay and --replay-window for more info or silence this warning with --mute-replay-warnings
. 2016.05.31 10:21:09 - OpenVPN > Authenticate/Decrypt packet error: bad packet ID (may be a replay): [ #117822 ] -- see the man page entry for --no-replay and --replay-window for more info or silence this warning with --mute-replay-warnings
. 2016.05.31 10:21:09 - OpenVPN > Authenticate/Decrypt packet error: bad packet ID (may be a replay): [ #117823 ] -- see the man page entry for --no-replay and --replay-window for more info or silence this warning with --mute-replay-warnings
. 2016.05.31 10:21:09 - OpenVPN > Authenticate/Decrypt packet error: bad packet ID (may be a replay): [ #117824 ] -- see the man page entry for --no-replay and --replay-window for more info or silence this warning with --mute-replay-warnings
. 2016.05.31 10:21:09 - OpenVPN > Authenticate/Decrypt packet error: bad packet ID (may be a replay): [ #117825 ] -- see the man page entry for --no-replay and --replay-window for more info or silence this warning with --mute-replay-warnings
. 2016.05.31 10:21:09 - OpenVPN > Authenticate/Decrypt packet error: bad packet ID (may be a replay): [ #117826 ] -- see the man page entry for --no-replay and --replay-window for more info or silence this warning with --mute-replay-warnings
. 2016.05.31 10:21:09 - OpenVPN > Authenticate/Decrypt packet error: bad packet ID (may be a replay): [ #117827 ] -- see the man page entry for --no-replay and --replay-window for more info or silence this warning with --mute-replay-warnings
. 2016.05.31 10:21:09 - OpenVPN > Authenticate/Decrypt packet error: bad packet ID (may be a replay): [ #117831 ] -- see the man page entry for --no-replay and --replay-window for more info or silence this warning with --mute-replay-warnings
. 2016.05.31 10:21:09 - OpenVPN > Authenticate/Decrypt packet error: bad packet ID (may be a replay): [ #117832 ] -- see the man page entry for --no-replay and --replay-window for more info or silence this warning with --mute-replay-warnings
. 2016.05.31 10:21:09 - OpenVPN > Authenticate/Decrypt packet error: bad packet ID (may be a replay): [ #117833 ] -- see the man page entry for --no-replay and --replay-window for more info or silence this warning with --mute-replay-warnings
. 2016.05.31 10:21:09 - OpenVPN > Authenticate/Decrypt packet error: bad packet ID (may be a replay): [ #117835 ] -- see the man page entry for --no-replay and --replay-window for more info or silence this warning with --mute-replay-warnings
. 2016.05.31 10:21:09 - OpenVPN > Authenticate/Decrypt packet error: bad packet ID (may be a replay): [ #117837 ] -- see the man page entry for --no-replay and --replay-window for more info or silence this warning with --mute-replay-warnings
. 2016.05.31 10:21:09 - OpenVPN > Authenticate/Decrypt packet error: bad packet ID (may be a replay): [ #117839 ] -- see the man page entry for --no-replay and --replay-window for more info or silence this warning with --mute-replay-warnings
. 2016.05.31 10:21:09 - OpenVPN > Authenticate/Decrypt packet error: bad packet ID (may be a replay): [ #117840 ] -- see the man page entry for --no-replay and --replay-window for more info or silence this warning with --mute-replay-warnings
. 2016.05.31 10:21:09 - OpenVPN > Authenticate/Decrypt packet error: bad packet ID (may be a replay): [ #117841 ] -- see the man page entry for --no-replay and --replay-window for more info or silence this warning with --mute-replay-warnings
. 2016.05.31 10:21:09 - OpenVPN > Authenticate/Decrypt packet error: bad packet ID (may be a replay): [ #117842 ] -- see the man page entry for --no-replay and --replay-window for more info or silence this warning with --mute-replay-warnings
. 2016.05.31 10:21:09 - OpenVPN > Authenticate/Decrypt packet error: bad packet ID (may be a replay): [ #117843 ] -- see the man page entry for --no-replay and --replay-window for more info or silence this warning with --mute-replay-warnings
. 2016.05.31 10:21:09 - OpenVPN > Authenticate/Decrypt packet error: bad packet ID (may be a replay): [ #117844 ] -- see the man page entry for --no-replay and --replay-window for more info or silence this warning with --mute-replay-warnings
. 2016.05.31 10:21:11 - OpenVPN > Authenticate/Decrypt packet error: bad packet ID (may be a replay): [ #124729 ] -- see the man page entry for --no-replay and --replay-window for more info or silence this warning with --mute-replay-warnings
. 2016.05.31 10:21:11 - OpenVPN > Authenticate/Decrypt packet error: bad packet ID (may be a replay): [ #124730 ] -- see the man page entry for --no-replay and --replay-window for more info or silence this warning with --mute-replay-warnings
. 2016.05.31 10:21:11 - OpenVPN > Authenticate/Decrypt packet error: bad packet ID (may be a replay): [ #124731 ] -- see the man page entry for --no-replay and --replay-window for more info or silence this warning with --mute-replay-warnings
. 2016.05.31 10:21:11 - OpenVPN > Authenticate/Decrypt packet error: bad packet ID (may be a replay): [ #124732 ] -- see the man page entry for --no-replay and --replay-window for more info or silence this warning with --mute-replay-warnings
. 2016.05.31 10:21:11 - OpenVPN > Authenticate/Decrypt packet error: bad packet ID (may be a replay): [ #124733 ] -- see the man page entry for --no-replay and --replay-window for more info or silence this warning with --mute-replay-warnings
. 2016.05.31 10:21:11 - OpenVPN > Authenticate/Decrypt packet error: bad packet ID (may be a replay): [ #124734 ] -- see the man page entry for --no-replay and --replay-window for more info or silence this warning with --mute-replay-warnings
. 2016.05.31 10:21:11 - OpenVPN > Authenticate/Decrypt packet error: bad packet ID (may be a replay): [ #124735 ] -- see the man page entry for --no-replay and --replay-window for more info or silence this warning with --mute-replay-warnings
. 2016.05.31 10:21:11 - OpenVPN > Authenticate/Decrypt packet error: bad packet ID (may be a replay): [ #124736 ] -- see the man page entry for --no-replay and --replay-window for more info or silence this warning with --mute-replay-warnings
. 2016.05.31 10:21:11 - OpenVPN > Authenticate/Decrypt packet error: bad packet ID (may be a replay): [ #124737 ] -- see the man page entry for --no-replay and --replay-window for more info or silence this warning with --mute-replay-warnings
. 2016.05.31 10:21:11 - OpenVPN > Authenticate/Decrypt packet error: bad packet ID (may be a replay): [ #124738 ] -- see the man page entry for --no-replay and --replay-window for more info or silence this warning with --mute-replay-warnings
. 2016.05.31 10:21:11 - OpenVPN > Authenticate/Decrypt packet error: bad packet ID (may be a replay): [ #124739 ] -- see the man page entry for --no-replay and --replay-window for more info or silence this warning with --mute-replay-warnings
. 2016.05.31 10:21:11 - OpenVPN > Authenticate/Decrypt packet error: bad packet ID (may be a replay): [ #124740 ] -- see the man page entry for --no-replay and --replay-window for more info or silence this warning with --mute-replay-warnings
. 2016.05.31 10:21:11 - OpenVPN > Authenticate/Decrypt packet error: bad packet ID (may be a replay): [ #124741 ] -- see the man page entry for --no-replay and --replay-window for more info or silence this warning with --mute-replay-warnings
. 2016.05.31 10:21:11 - OpenVPN > Authenticate/Decrypt packet error: bad packet ID (may be a replay): [ #124751 ] -- see the man page entry for --no-replay and --replay-window for more info or silence this warning with --mute-replay-warnings
. 2016.05.31 10:21:11 - OpenVPN > Authenticate/Decrypt packet error: bad packet ID (may be a replay): [ #124752 ] -- see the man page entry for --no-replay and --replay-window for more info or silence this warning with --mute-replay-warnings
. 2016.05.31 10:21:11 - OpenVPN > Authenticate/Decrypt packet error: bad packet ID (may be a replay): [ #124753 ] -- see the man page entry for --no-replay and --replay-window for more info or silence this warning with --mute-replay-warnings
. 2016.05.31 10:21:11 - OpenVPN > Authenticate/Decrypt packet error: bad packet ID (may be a replay): [ #124754 ] -- see the man page entry for --no-replay and --replay-window for more info or silence this warning with --mute-replay-warnings
. 2016.05.31 10:21:11 - OpenVPN > Authenticate/Decrypt packet error: bad packet ID (may be a replay): [ #124755 ] -- see the man page entry for --no-replay and --replay-window for more info or silence this warning with --mute-replay-warnings
. 2016.05.31 10:21:11 - OpenVPN > Authenticate/Decrypt packet error: bad packet ID (may be a replay): [ #124756 ] -- see the man page entry for --no-replay and --replay-window for more info or silence this warning with --mute-replay-warnings
. 2016.05.31 10:21:11 - OpenVPN > Authenticate/Decrypt packet error: bad packet ID (may be a replay): [ #124757 ] -- see the man page entry for --no-replay and --replay-window for more info or silence this warning with --mute-replay-warnings
. 2016.05.31 10:21:11 - OpenVPN > Authenticate/Decrypt packet error: bad packet ID (may be a replay): [ #124758 ] -- see the man page entry for --no-replay and --replay-window for more info or silence this warning with --mute-replay-warnings
. 2016.05.31 10:21:11 - OpenVPN > Authenticate/Decrypt packet error: bad packet ID (may be a replay): [ #124759 ] -- see the man page entry for --no-replay and --replay-window for more info or silence this warning with --mute-replay-warnings
. 2016.05.31 10:21:11 - OpenVPN > Authenticate/Decrypt packet error: bad packet ID (may be a replay): [ #124760 ] -- see the man page entry for --no-replay and --replay-window for more info or silence this warning with --mute-replay-warnings
. 2016.05.31 10:21:11 - OpenVPN > Authenticate/Decrypt packet error: bad packet ID (may be a replay): [ #124761 ] -- see the man page entry for --no-replay and --replay-window for more info or silence this warning with --mute-replay-warnings
. 2016.05.31 10:21:11 - OpenVPN > Authenticate/Decrypt packet error: bad packet ID (may be a replay): [ #124762 ] -- see the man page entry for --no-replay and --replay-window for more info or silence this warning with --mute-replay-warnings
. 2016.05.31 10:21:11 - OpenVPN > Authenticate/Decrypt packet error: bad packet ID (may be a replay): [ #124763 ] -- see the man page entry for --no-replay and --replay-window for more info or silence this warning with --mute-replay-warnings
. 2016.05.31 10:21:11 - OpenVPN > Authenticate/Decrypt packet error: bad packet ID (may be a replay): [ #124764 ] -- see the man page entry for --no-replay and --replay-window for more info or silence this warning with --mute-replay-warnings
. 2016.05.31 10:21:11 - OpenVPN > Authenticate/Decrypt packet error: bad packet ID (may be a replay): [ #124765 ] -- see the man page entry for --no-replay and --replay-window for more info or silence this warning with --mute-replay-warnings
. 2016.05.31 10:21:11 - OpenVPN > Authenticate/Decrypt packet error: bad packet ID (may be a replay): [ #124766 ] -- see the man page entry for --no-replay and --replay-window for more info or silence this warning with --mute-replay-warnings
. 2016.05.31 10:21:11 - OpenVPN > Authenticate/Decrypt packet error: bad packet ID (may be a replay): [ #124767 ] -- see the man page entry for --no-replay and --replay-window for more info or silence this warning with --mute-replay-warnings
. 2016.05.31 10:21:11 - OpenVPN > Authenticate/Decrypt packet error: bad packet ID (may be a replay): [ #124768 ] -- see the man page entry for --no-replay and --replay-window for more info or silence this warning with --mute-replay-warnings
. 2016.05.31 10:21:13 - OpenVPN > Authenticate/Decrypt packet error: bad packet ID (may be a replay): [ #131164 ] -- see the man page entry for --no-replay and --replay-window for more info or silence this warning with --mute-replay-warnings
. 2016.05.31 10:21:13 - OpenVPN > Authenticate/Decrypt packet error: bad packet ID (may be a replay): [ #131165 ] -- see the man page entry for --no-replay and --replay-window for more info or silence this warning with --mute-replay-warnings
. 2016.05.31 10:21:13 - OpenVPN > Authenticate/Decrypt packet error: bad packet ID (may be a replay): [ #131166 ] -- see the man page entry for --no-replay and --replay-window for more info or silence this warning with --mute-replay-warnings
. 2016.05.31 10:21:13 - OpenVPN > Authenticate/Decrypt packet error: bad packet ID (may be a replay): [ #131167 ] -- see the man page entry for --no-replay and --replay-window for more info or silence this warning with --mute-replay-warnings
. 2016.05.31 10:21:13 - OpenVPN > Authenticate/Decrypt packet error: bad packet ID (may be a replay): [ #131168 ] -- see the man page entry for --no-replay and --replay-window for more info or silence this warning with --mute-replay-warnings
. 2016.05.31 10:21:13 - OpenVPN > Authenticate/Decrypt packet error: bad packet ID (may be a replay): [ #131169 ] -- see the man page entry for --no-replay and --replay-window for more info or silence this warning with --mute-replay-warnings
. 2016.05.31 10:21:13 - OpenVPN > Authenticate/Decrypt packet error: bad packet ID (may be a replay): [ #131170 ] -- see the man page entry for --no-replay and --replay-window for more info or silence this warning with --mute-replay-warnings
. 2016.05.31 10:21:13 - OpenVPN > Authenticate/Decrypt packet error: bad packet ID (may be a replay): [ #131172 ] -- see the man page entry for --no-replay and --replay-window for more info or silence this warning with --mute-replay-warnings
. 2016.05.31 10:21:13 - OpenVPN > Authenticate/Decrypt packet error: bad packet ID (may be a replay): [ #131173 ] -- see the man page entry for --no-replay and --replay-window for more info or silence this warning with --mute-replay-warnings
. 2016.05.31 10:21:13 - OpenVPN > Authenticate/Decrypt packet error: bad packet ID (may be a replay): [ #131174 ] -- see the man page entry for --no-replay and --replay-window for more info or silence this warning with --mute-replay-warnings
. 2016.05.31 10:21:13 - OpenVPN > Authenticate/Decrypt packet error: bad packet ID (may be a replay): [ #131175 ] -- see the man page entry for --no-replay and --replay-window for more info or silence this warning with --mute-replay-warnings
. 2016.05.31 10:21:13 - OpenVPN > Authenticate/Decrypt packet error: bad packet ID (may be a replay): [ #131176 ] -- see the man page entry for --no-replay and --replay-window for more info or silence this warning with --mute-replay-warnings
. 2016.05.31 10:21:13 - OpenVPN > Authenticate/Decrypt packet error: bad packet ID (may be a replay): [ #131177 ] -- see the man page entry for --no-replay and --replay-window for more info or silence this warning with --mute-replay-warnings
. 2016.05.31 10:21:13 - OpenVPN > Authenticate/Decrypt packet error: bad packet ID (may be a replay): [ #131178 ] -- see the man page entry for --no-replay and --replay-window for more info or silence this warning with --mute-replay-warnings
. 2016.05.31 10:21:13 - OpenVPN > Authenticate/Decrypt packet error: bad packet ID (may be a replay): [ #131179 ] -- see the man page entry for --no-replay and --replay-window for more info or silence this warning with --mute-replay-warnings
. 2016.05.31 10:21:13 - OpenVPN > Authenticate/Decrypt packet error: bad packet ID (may be a replay): [ #131180 ] -- see the man page entry for --no-replay and --replay-window for more info or silence this warning with --mute-replay-warnings
. 2016.05.31 10:21:13 - OpenVPN > Authenticate/Decrypt packet error: bad packet ID (may be a replay): [ #131181 ] -- see the man page entry for --no-replay and --replay-window for more info or silence this warning with --mute-replay-warnings
. 2016.05.31 10:21:13 - OpenVPN > Authenticate/Decrypt packet error: bad packet ID (may be a replay): [ #131185 ] -- see the man page entry for --no-replay and --replay-window for more info or silence this warning with --mute-replay-warnings
. 2016.05.31 10:21:13 - OpenVPN > Authenticate/Decrypt packet error: bad packet ID (may be a replay): [ #131186 ] -- see the man page entry for --no-replay and --replay-window for more info or silence this warning with --mute-replay-warnings
. 2016.05.31 10:21:13 - OpenVPN > Authenticate/Decrypt packet error: bad packet ID (may be a replay): [ #131187 ] -- see the man page entry for --no-replay and --replay-window for more info or silence this warning with --mute-replay-warnings
. 2016.05.31 10:21:13 - OpenVPN > Authenticate/Decrypt packet error: bad packet ID (may be a replay): [ #131188 ] -- see the man page entry for --no-replay and --replay-window for more info or silence this warning with --mute-replay-warnings
. 2016.05.31 10:21:13 - OpenVPN > Authenticate/Decrypt packet error: bad packet ID (may be a replay): [ #131189 ] -- see the man page entry for --no-replay and --replay-window for more info or silence this warning with --mute-replay-warnings
. 2016.05.31 10:21:13 - OpenVPN > Authenticate/Decrypt packet error: bad packet ID (may be a replay): [ #131190 ] -- see the man page entry for --no-replay and --replay-window for more info or silence this warning with --mute-replay-warnings
. 2016.05.31 10:21:13 - OpenVPN > Authenticate/Decrypt packet error: bad packet ID (may be a replay): [ #131191 ] -- see the man page entry for --no-replay and --replay-window for more info or silence this warning with --mute-replay-warnings
. 2016.05.31 10:21:13 - OpenVPN > Authenticate/Decrypt packet error: bad packet ID (may be a replay): [ #131192 ] -- see the man page entry for --no-replay and --replay-window for more info or silence this warning with --mute-replay-warnings
. 2016.05.31 10:21:13 - OpenVPN > Authenticate/Decrypt packet error: bad packet ID (may be a replay): [ #131193 ] -- see the man page entry for --no-replay and --replay-window for more info or silence this warning with --mute-replay-warnings
. 2016.05.31 10:21:13 - OpenVPN > Authenticate/Decrypt packet error: bad packet ID (may be a replay): [ #131194 ] -- see the man page entry for --no-replay and --replay-window for more info or silence this warning with --mute-replay-warnings
. 2016.05.31 10:21:13 - OpenVPN > Authenticate/Decrypt packet error: bad packet ID (may be a replay): [ #131196 ] -- see the man page entry for --no-replay and --replay-window for more info or silence this warning with --mute-replay-warnings
. 2016.05.31 10:21:13 - OpenVPN > Authenticate/Decrypt packet error: bad packet ID (may be a replay): [ #131197 ] -- see the man page entry for --no-replay and --replay-window for more info or silence this warning with --mute-replay-warnings
. 2016.05.31 10:21:13 - OpenVPN > Authenticate/Decrypt packet error: bad packet ID (may be a replay): [ #131198 ] -- see the man page entry for --no-replay and --replay-window for more info or silence this warning with --mute-replay-warnings
. 2016.05.31 10:21:13 - OpenVPN > Authenticate/Decrypt packet error: bad packet ID (may be a replay): [ #131199 ] -- see the man page entry for --no-replay and --replay-window for more info or silence this warning with --mute-replay-warnings
. 2016.05.31 10:21:13 - OpenVPN > Authenticate/Decrypt packet error: bad packet ID (may be a replay): [ #131200 ] -- see the man page entry for --no-replay and --replay-window for more info or silence this warning with --mute-replay-warnings
. 2016.05.31 10:21:13 - OpenVPN > Authenticate/Decrypt packet error: bad packet ID (may be a replay): [ #131201 ] -- see the man page entry for --no-replay and --replay-window for more info or silence this warning with --mute-replay-warnings
. 2016.05.31 10:21:13 - OpenVPN > Authenticate/Decrypt packet error: bad packet ID (may be a replay): [ #131202 ] -- see the man page entry for --no-replay and --replay-window for more info or silence this warning with --mute-replay-warnings
. 2016.05.31 10:21:13 - OpenVPN > Authenticate/Decrypt packet error: bad packet ID (may be a replay): [ #131203 ] -- see the man page entry for --no-replay and --replay-window for more info or silence this warning with --mute-replay-warnings
. 2016.05.31 10:21:13 - OpenVPN > Authenticate/Decrypt packet error: bad packet ID (may be a replay): [ #131204 ] -- see the man page entry for --no-replay and --replay-window for more info or silence this warning with --mute-replay-warnings
. 2016.05.31 10:21:13 - OpenVPN > Authenticate/Decrypt packet error: bad packet ID (may be a replay): [ #131206 ] -- see the man page entry for --no-replay and --replay-window for more info or silence this warning with --mute-replay-warnings
. 2016.05.31 10:21:13 - OpenVPN > Authenticate/Decrypt packet error: bad packet ID (may be a replay): [ #131207 ] -- see the man page entry for --no-replay and --replay-window for more info or silence this warning with --mute-replay-warnings
. 2016.05.31 10:21:13 - OpenVPN > Authenticate/Decrypt packet error: bad packet ID (may be a replay): [ #131214 ] -- see the man page entry for --no-replay and --replay-window for more info or silence this warning with --mute-replay-warnings
. 2016.05.31 10:21:13 - OpenVPN > Authenticate/Decrypt packet error: bad packet ID (may be a replay): [ #131442 ] -- see the man page entry for --no-replay and --replay-window for more info or silence this warning with --mute-replay-warnings
. 2016.05.31 10:21:13 - OpenVPN > Authenticate/Decrypt packet error: bad packet ID (may be a replay): [ #131443 ] -- see the man page entry for --no-replay and --replay-window for more info or silence this warning with --mute-replay-warnings
. 2016.05.31 10:21:13 - OpenVPN > Authenticate/Decrypt packet error: bad packet ID (may be a replay): [ #131444 ] -- see the man page entry for --no-replay and --replay-window for more info or silence this warning with --mute-replay-warnings
. 2016.05.31 10:21:13 - OpenVPN > Authenticate/Decrypt packet error: bad packet ID (may be a replay): [ #131445 ] -- see the man page entry for --no-replay and --replay-window for more info or silence this warning with --mute-replay-warnings
. 2016.05.31 10:21:13 - OpenVPN > Authenticate/Decrypt packet error: bad packet ID (may be a replay): [ #131446 ] -- see the man page entry for --no-replay and --replay-window for more info or silence this warning with --mute-replay-warnings
. 2016.05.31 10:21:13 - OpenVPN > Authenticate/Decrypt packet error: bad packet ID (may be a replay): [ #131447 ] -- see the man page entry for --no-replay and --replay-window for more info or silence this warning with --mute-replay-warnings
. 2016.05.31 10:21:13 - OpenVPN > Authenticate/Decrypt packet error: bad packet ID (may be a replay): [ #131448 ] -- see the man page entry for --no-replay and --replay-window for more info or silence this warning with --mute-replay-warnings
. 2016.05.31 10:21:13 - OpenVPN > Authenticate/Decrypt packet error: bad packet ID (may be a replay): [ #131449 ] -- see the man page entry for --no-replay and --replay-window for more info or silence this warning with --mute-replay-warnings
. 2016.05.31 10:21:13 - OpenVPN > Authenticate/Decrypt packet error: bad packet ID (may be a replay): [ #131450 ] -- see the man page entry for --no-replay and --replay-window for more info or silence this warning with --mute-replay-warnings
. 2016.05.31 10:21:13 - OpenVPN > Authenticate/Decrypt packet error: bad packet ID (may be a replay): [ #131451 ] -- see the man page entry for --no-replay and --replay-window for more info or silence this warning with --mute-replay-warnings
. 2016.05.31 10:21:13 - OpenVPN > Authenticate/Decrypt packet error: bad packet ID (may be a replay): [ #131452 ] -- see the man page entry for --no-replay and --replay-window for more info or silence this warning with --mute-replay-warnings
. 2016.05.31 10:21:13 - OpenVPN > Authenticate/Decrypt packet error: bad packet ID (may be a replay): [ #131453 ] -- see the man page entry for --no-replay and --replay-window for more info or silence this warning with --mute-replay-warnings
. 2016.05.31 10:21:13 - OpenVPN > Authenticate/Decrypt packet error: bad packet ID (may be a replay): [ #131454 ] -- see the man page entry for --no-replay and --replay-window for more info or silence this warning with --mute-replay-warnings
. 2016.05.31 10:21:13 - OpenVPN > Authenticate/Decrypt packet error: bad packet ID (may be a replay): [ #131455 ] -- see the man page entry for --no-replay and --replay-window for more info or silence this warning with --mute-replay-warnings
. 2016.05.31 10:21:13 - OpenVPN > Authenticate/Decrypt packet error: bad packet ID (may be a replay): [ #131457 ] -- see the man page entry for --no-replay and --replay-window for more info or silence this warning with --mute-replay-warnings
