odBXOS4hh-TpR3HPez2NULGYHB
ANSWERED openSUSE Tumbleweed NetworkManager doesn't connect
​Hi,
​So I am trying to get airvpn to work with network manager on openSUSE Tumbleweed (Plasma 5). I can import the config files successfully, but when trying to connect nothing at all happens. Which is strange, because my other vpn works just fine. Here's what systemd says, I guess it has to do with the first line, but I couldn't find anything to change... Any help would be much appreciated!!
May 14 12:53:55 linux-327r NetworkManager[1029]: Options error: Unknown key direction ' 1' -- must be '0' or '1'
May 14 12:53:55 linux-327r NetworkManager[1029]: nm-openvpn-Message: openvpn started with pid 13474
May 14 12:53:55 linux-327r NetworkManager[1029]: (nm-openvpn-service:2238): nm-openvpn-WARNING **: Directory '/var/lib/openvpn/chroot' not usable for chroot by 'nm-openvpn', openvpn will not be chrooted.
May 14 12:53:55 linux-327r NetworkManager[1029]: (nm-openvpn-service:2238): nm-openvpn-WARNING **: (nm-openvpn-service.c:1269):nm_openvpn_start_openvpn_binary: runtime check failed: (priv->mgt_path == NULL)
May 14 12:53:55 linux-327r polkitd[1061]: Operator of unix-session:1 successfully authenticated as unix-user:root to gain ONE-SHOT authorization for action org.freedesktop.NetworkManager.network-control for unix-process:1604:904 [/usr/bi
May 14 12:53:55 linux-327r audit[13471]: USER_ACCT pid=13471 uid=1000 auid=1000 ses=1 msg='op=PAM:accounting grantors=pam_unix acct="root" exe="/usr/lib/polkit-1/polkit-agent-helper-1" hostname=? addr=? terminal=? res=success'
​Hi,
I don't know how your network manager works, however the OpenVPN directions seems to have been faulted when you imported the configs it's set to " 1" when it should be "1" it has a space infront of it you need to find a way to remove that in the config else it won't connect.
