mehāniskākaravīrs935
www.g2a.com NOT accesible from Aquilae
Someone probably did something bad while connected to that server.
support@g2a.com I don't know the e-mail of that server so I'd recommend sending an e-mail to them and telling them it's a VPN that's widely used, generally blocking one VPN server gives them nothing since people will just switch server meanwhile other customers get blocked due to it as well.
Luving my g2a lols
Or you don't send them a mail, causing them to look up the name of the VPN, possibly resulting in an actual permanent block of all servers.
I don't see that really happening but sure.
