pippinoparrinello
Raspberry gateway portforwading
i set up a raspberry as vpn gateway. I would like now to forward all the packets from vpn port 3000 , interface tun0 to a local pc connected to the local lan eth0 with local ip of 192.168.1.80 port 8080. Could someone give me the right iptables rule?
I did as you suggested trying to route port 80 to 192.168.1.1
sudo iptables -I FORWARD -i tun0 -p udp -d 192.168.1.1 --dport 80 -j ACCEPT
sudo iptables -I FORWARD -i tun0 -p tcp -d 192.168.1.1 --dport 80 -j ACCEPT
sudo iptables -t nat -I PREROUTING -i tun0 -p tcp --dport 80 -j DNAT --to-destination 192.168.1.1
sudo iptables -t nat -I PREROUTING -i tun0 -p udp --dport 80 -j DNAT --to-destination 192.168.1.1
and then i opened using the forwarded port interface of your site
62070
Protocol: TCP & UDP Local port: 80 DDNS: external Connected to server: Tauri Mapped to public IP: 46.165.208.105
NO answare CONTACTING
46.165.208.105:62070 Could you please help me further?!
Many thanks
I tryied all this different set... none is working
SET 1
sudo iptables -I FORWARD -i tun0 -p udp -d 192.168.1.250 --dport 80 -j ACCEPT
sudo iptables -I FORWARD -i tun0 -p tcp -d 192.168.1.250 --dport 80 -j ACCEPT
sudo iptables -t nat -I PREROUTING -i tun0 -p tcp --dport 80 -j DNAT --to-destination 192.168.1.250
sudo iptables -t nat -I PREROUTING -i tun0 -p udp --dport 80 -j DNAT --to-destination 192.168.1.250
SET2
sudo iptables -A FORWARD -i tun0 -o eth0 -p tcp --syn --dport 80 -m conntrack --ctstate NEW -j ACCEPT
sudo iptables -A FORWARD -i tun0 -o eth0 -m conntrack --ctstate ESTABLISHED,RELATED -j ACCEPT
sudo iptables -A FORWARD -i eth0 -o tun0 -m conntrack --ctstate ESTABLISHED,RELATED -j ACCEPT
sudo iptables -t nat -A PREROUTING -i tun0 -p tcp --dport 80 -j DNAT --to-destination 192.168.1.250
SET3
sudo iptables -t nat -A POSTROUTING --out-interface eth0 -j MASQUERADE
sudo iptables -A FORWARD --in-interface tun0 -j ACCEPT
sudo iptables -t nat -A PREROUTING -p tcp -i tun0 -m tcp --dport 80 -j DNAT --to-destination 192.168.1.250:80
make sure you have read the reply to your ticket, there is an important information which should help you fix the issue (we see packets reaching your system which are actively rejected).
I see connection timeout. probably you see the rejection because my subscription to airvpn ended yesyerday. Now i have a new 3 days subscription. Please test it again. Thanks everybody for the effort
Base case (no modification) iptables are:
# Generated by iptables-save v1.4.21 on Sun May  1 14:26:26 2016
*filter
:INPUT ACCEPT [290:31586]
:FORWARD ACCEPT [0:0]
:OUTPUT ACCEPT [110:8444]
-A FORWARD -i tun0 -o eth0 -m state --state RELATED,ESTABLISHED -j ACCEPT
-A FORWARD -i eth0 -o tun0 -j ACCEPT
-A OUTPUT -o tun0 -m comment --comment vpn -j ACCEPT
-A OUTPUT -o eth0 -p icmp -m comment --comment icmp -j ACCEPT
-A OUTPUT -d 192.168.1.0/24 -o eth0 -m comment --comment lan -j ACCEPT
-A OUTPUT -o eth0 -p udp -m udp --dport 443 -m comment --comment openvpn -j ACCEPT
-A OUTPUT -o eth0 -p tcp -m tcp --sport 22 -m comment --comment ssh -j ACCEPT
-A OUTPUT -o eth0 -p udp -m udp --dport 123 -m comment --comment ntp -j ACCEPT
-A OUTPUT -o eth0 -p udp -m udp --dport 53 -m comment --comment dns -j ACCEPT
-A OUTPUT -o eth0 -p tcp -m tcp --dport 53 -m comment --comment dns -j ACCEPT
-A OUTPUT -o eth0 -j DROP
COMMIT
# Completed on Sun May  1 14:26:26 2016
*nat
:PREROUTING ACCEPT [44:5055]
:INPUT ACCEPT [41:4580]
:OUTPUT ACCEPT [55:5869]
:POSTROUTING ACCEPT [41:2931]
-A POSTROUTING -o tun0 -j MASQUERADE
COMMIT
*filter
COMMIT
*nat
COMMIT
we see refused connections because packets are rejected, otherwise we would have seen timeouts (no replies at all from your client) as you correctly notice, not to mention the fact that your account expiration date was irrelevant: obviously we tested when your client was connected to some VPN server.
