akmolina28
Trouble connecting with DD-WRT
Hello
I need some help troubleshooting an issue with my connection over DD-WRT.
I am trying to connect to AirVPN with DD-WRT v3.0-r27506. This firmware is running on a TP-LINK Archer C5 AC1200 router.
I have followed the online instructions and everything seems correct, but the AirVPN website says I am disconnected and my IP has not changed.
Here is my client log:
Clientlog:
20160424 19:17:04 I OpenVPN 2.3.7 mips-unknown-linux-gnu [sSL (OpenSSL)] [LZO] [EPOLL] [MH] [iPv6] built on Jul 9 2015
20160424 19:17:04 I library versions: OpenSSL 1.0.2c 12 Jun 2015 LZO 2.09
20160424 19:17:04 MANAGEMENT: TCP Socket listening on [AF_INET]127.0.0.1:16
20160424 19:17:04 W NOTE: the current --script-security setting may allow this configuration to call user-defined scripts
20160424 19:17:04 W WARNING: file '/tmp/openvpncl/client.key' is group or others accessible
20160424 19:17:04 W WARNING: file '/tmp/openvpncl/ta.key' is group or others accessible
20160424 19:17:04 I Control Channel Authentication: using '/tmp/openvpncl/ta.key' as a OpenVPN static key file
20160424 19:17:04 Outgoing Control Channel Authentication: Using 160 bit message hash 'SHA1' for HMAC authentication
20160424 19:17:04 Incoming Control Channel Authentication: Using 160 bit message hash 'SHA1' for HMAC authentication
20160424 19:17:04 Socket Buffers: R=[172032->131072] S=[172032->131072]
20160424 19:17:04 I UDPv4 link local: [undef]
20160424 19:17:04 I UDPv4 link remote: [AF_INET]173.44.55.154:443
20160424 19:17:04 TLS: Initial packet from [AF_INET]173.44.55.154:443 sid=13e801b2 be484d12
20160424 19:17:04 VERIFY OK: depth=1 C=IT ST=IT L=Perugia O=airvpn.org CN=airvpn.org CA emailAddress=info@airvpn.org
20160424 19:17:04 VERIFY OK: nsCertType=SERVER
20160424 19:17:04 NOTE: --mute triggered...
20160424 19:17:09 6 variation(s) on previous 3 message(s) suppressed by --mute
20160424 19:17:09 I [server] Peer Connection Initiated with [AF_INET]173.44.55.154:443
20160424 19:17:11 SENT CONTROL [server]: 'PUSH_REQUEST' (status=1)
20160424 19:17:11 PUSH: Received control message: 'PUSH_REPLY redirect-gateway def1 bypass-dhcp dhcp-option DNS 10.4.0.1 comp-lzo no route-gateway 10.4.0.1 topology subnet ping 10 ping-restart 60 ifconfig 10.4.43.45 255.255.0.0'
20160424 19:17:11 OPTIONS IMPORT: timers and/or timeouts modified
20160424 19:17:11 NOTE: --mute triggered...
20160424 19:17:11 5 variation(s) on previous 3 message(s) suppressed by --mute
20160424 19:17:11 I TUN/TAP device tun1 opened
20160424 19:17:11 TUN/TAP TX queue length set to 100
20160424 19:17:11 I do_ifconfig tt->ipv6=1 tt->did_ifconfig_ipv6_setup=0
20160424 19:17:11 I /sbin/ifconfig tun1 10.4.43.45 netmask 255.255.0.0 mtu 1500 broadcast 10.4.255.255
20160424 19:17:11 W NOTE: unable to redirect default gateway -- Cannot read current default gateway from system
20160424 19:17:12 I Initialization Sequence Completed
20160424 19:17:16 MANAGEMENT: Client connected from [AF_INET]127.0.0.1:16
20160424 19:17:16 D MANAGEMENT: CMD 'state'
20160424 19:17:16 MANAGEMENT: Client disconnected
20160424 19:17:16 D MANAGEMENT: CMD 'status 2'
20160424 19:17:16 D MANAGEMENT: CMD 'log 500'
20160424 19:17:22 MANAGEMENT: Client connected from [AF_INET]127.0.0.1:16
20160424 19:17:22 D MANAGEMENT: CMD 'state'
20160424 19:17:22 MANAGEMENT: Client disconnected
20160424 19:17:22 D MANAGEMENT: CMD 'status 2'
20160424 19:17:22 D MANAGEMENT: CMD 'log 500'
20160424 19:17:39 MANAGEMENT: Client connected from [AF_INET]127.0.0.1:16
20160424 19:17:39 D MANAGEMENT: CMD 'state'
20160424 19:17:39 MANAGEMENT: Client disconnected
20160424 19:17:39 D MANAGEMENT: CMD 'status 2'
20160424 19:17:39 D MANAGEMENT: CMD 'log 500'
19691231 19:00:00
ca /tmp/openvpncl/ca.crt cert /tmp/openvpncl/client.crt key /tmp/openvpncl/client.key management 127.0.0.1 16 management-log-cache 100 verb 3 mute 3 syslog writepid /var/run/openvpncl.pid client resolv-retry infinite nobind persist-key persist-tun script-security 2 dev tun1 proto udp cipher aes-256-cbc auth sha1 remote 173.44.55.154 443 comp-lzo yes tls-client tun-mtu 1500 mtu-disc yes ns-cert-type server fast-io tun-ipv6 tls-auth /tmp/openvpncl/ta.key 1 tls-cipher TLS-DHE-RSA-WITH-AES-256-GCM-SHA384
Thank you
Solved this myself by flashing to an earlier firmware, r28015. Seems to be working well now but I will report back if it goes awry.
