Not connected, Your IP: 216.73.216.36
hackers2016
I have idea for a new project, but I have no skills to do it
​Hi there,
As I said I have no skills to do it and may be it already started somewhere
Flash Player that can simulate Adobe flash player, but open source, like a uBlock can show the ads that been seen something similar but for youtube
there is a lots of interesting stuff on youtube I like watching, but their NAZI policy it is freaking me out
Would be difficult to publish something similar without violating Adobe's licensing. Their software is all but free
You talk about YouTube like it still uses Flash. YouTube stopped using it some time ago. HTML5 is the default "player" now.
​I understand. I am not saying to violate their copyright but something similar to flash player like example VLC player but plugin for firefox that can play youtube videos. When I use their HTML5 player my DTS processor working on single channel, but that's not why I ask for just something that prevent info leak.
A VLC plugin for Firefox does exist and is installed with VLC on Windows, actually. It's superfluous since Firefox can play all web video formats itself.
Don't know what you mean with info leak. You can disable HTML5 and enable the VLC plugin. VLC can play YouTube videos and can even handle YouTube playlist, though I can't remember whether a plugin is needed for this.
cm0s, there are Firefox plugins for this. try Flash and Video Download. You just select the quality and format and it downloads it with the browser's download manager directly. Far better than any third party tool.
(Sent via Tapatalk - this generally means I'm not sitting in front of my PC)
had use code coz some reason 'not an image' error when pasting...
there are other url tricks you can do some work some don't
like using the 'embed' or the /v/ however to really enjoy
any vid it's just a lot easier for me to find the vid's
source from the youtube server and down the vid
bypass age restriction example:
https://www.youtube.com/watch?v=VCA-blahblah
make it like this:
http://www.nsfwyoutube.com/watch?v=VCA-blahblah
from there you can either download the vid if ya
want or get the video source via
http://www.clipconverter.cc/
http://dirpy.com/
http://www.youtubeinmp4.com
there are many others online some have bunch of ad crap
i tried to find ya the cleanest ones, idea is you either want to
download your vid or view it vlc from the youtube server direct
better quality usually no ads, but i tend to just down the vid
coz that way when i pause it and come back i don't mess up the
buffer
here's vid link source example this was age restricted so i goofed the url up
so it's a fake same as above
right click copy link location either from video window or download button:
http://www.youtubeinmp4.com/redirect.php?video=VCA-blahblah=lrlOZ1kIm1CRWI316GBy%2BWoSzsLet%2B0YOkWkZvissyA%3D
hope this helps
sincerely, cm0s
​Thanks for the tips.These url`s makes life a little easier . For me clipconverter is the best.
​So far i downloaded the raw versions from youtube etc via Vlc.No bad either.
Gr,Casper
